| : 221-2523
Mounting carrier; 3-way; for inline splicing connector with lever; for screw mounting;
gray
https://www.wago.com/221-2523
gray
Physical data
Width
29.8 mm / 1.173 inches
Height from the surface
6.5 mm / 0.256 inches
Depth
56 mm / 2.205 inches
Material data
Note (material data)
Information on material data can be found here
Color
gray
Fire load
0 MJ
Weight
4.4 g
Commercial data
PU (SPU)
25 (5) Pieces
Packaging type
Box
Country of origin VKOrg Germany
CN
GTIN
4066966119947
Customs tariff number VKOrg Germany
39269097900
Downloads
Environmental Product Compliance
Compliance Search
Compliance 221-2523
Seite 1/3
Stand: 24.05.2022
Fortsetzung nächste Seite ››
| : 221-2523
Documentation
Additional Information
Technical Section
pdf
2142.18 KB
CAD/CAE-Data
CAD data
CAE data
2D/3D Models
221-2523
ZUKEN Portal
221-2523
1 Compatible products
1.1 Optional accessories
1.1.1 Installation
1.1.1.1 Mounting accessories
: 209-119
Fixing screw; for 209-120 mounting carri
er
: 209-123
Mounting foot with screw; can be
screwed on terminal blocks with fixing
flange; 6.4 mm wide; gray
: 209-120
Mounting foot; can be snapped on termi
nal blocks with snap-in mounting foot; for
mounting on relay-modules; 6.4 mm wide;
gray
Push the connector to the center positi
on until it snaps into place.
Mounting carrier without strain relief –
snapped onto DIN-rail
1.1.2 Marking
1.1.2.1 Marking strip
: 210-334
Marking strips; as a DIN A4 sheet; Strip
width 5 mm; Strip length 182 mm; plain;
Self-adhesive; white
Installation notes
Installation
Place the inline splicing connector on the
carrier in front of the mounting position.
Seite 2/3
Stand: 24.05.2022
| : 221-2523
Various combinations of 1- to 5-connector
mounting carriers are possible via side-byside latching mechanism.
Strain relief
3-pole mounting carrier with strain relief
Änderungen vorbehalten. Bitte beachten Sie auch die weitere Produktdokumentation!
Adressen finden Sie unter: w w w.wago.com
Seite 3/3
Stand: 24.05.2022
很抱歉,暂时无法提供与“0221-2523”相匹配的价格&库存,您可以联系我们找货
