0233-0505
    WAGO(万可电子)
0233-0505 数据手册
Printview: PCB terminal strip; 2 solder pins/pole; 5-pole; pin spacing 2.54 mm / 0.1 in; with push-button Item No.: 233-505 . PCB terminal strip; 2 solder pins/pole; 5-pole; pin spacing 2.54 mm / 0.1 in; with push-button Item No.: 233-505 . PCB terminal strip; 2 solder pins/pole; 5-pole; pin spacing 2.54 mm / 0.1 in; with push-button . Marking . Business data Supplier WAGO Item no. 233-505 GTIN / EAN 4045454050290 Content 1 Order amount 85 Customer item number . Notes Terminal strips with push-button actuated CAGE CLAMP®Double solder pins for high mechanical stability on PCBIdeal for in-the-field wiring thanks to simplified push-button actuationConvenient, tool-free operation Technical data Miscellaneous No. of poles 5 Pin Spacing 2.54 mm / 0.1 in % Total number of connection points 5 Total number of potentials 5 Color orange Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III Pollution degree (1) 2 WAGO Kontakttechnik GmbH & Co. KG 1 Printview: PCB terminal strip; 2 solder pins/pole; 5-pole; pin spacing 2.54 mm / 0.1 in; with push-button Item No.: 233-505 Technical data Rated voltage EN (1) [V] 160 [V] Rated surge voltage (1) [kV] 2.5 [kV] Nominal current [A] 6 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 320 [V] Rated surge voltage (2) [kV] 2.5 [kV] Nominal current (2) [A] 6 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 63 [V] Rated surge voltage (3) [kV] 2.5 [kV] Nominal current (3) [A] 6 [A] Number of individual connection objects at the product 1 Connection technology (1) CAGE CLAMP® Solid sizes 1 0.08 … 0.5 mm² / 28 … 20 AWG Fine-stranded wires 1 0.08 … 0.5 mm² / 28 … 20 AWG Fine-stranded wires with insulated ferrule 1 0.25 mm² / AWG Fine-stranded wires with uninsulated ferrule 1 0.25 mm² / AWG Strip length 1 5 … 6 mm / 0.2 … 0.24 in Conductor entry angle to the PCB 1 [°] 30 [°] Solder pin arrangement in-line solder pin Solder pin length [mm] 4 [mm] Solder pin width A [mm] 0.5 [mm] Solder pin width B [mm] 0.75 [mm] Tolerance of drilled hole [mm] 1.1(+ 0.1) [mm] Material group I Insulating material Polyamide 66 (PA 66) Flammability rating per UL 94 V0 Limit temperature range -60 C … 105 C Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Electrolytic copper (Ecu) Contact plating tin-plated Fire load [MJ] 0.039 [MJ] WAGO Kontakttechnik GmbH & Co. KG 2 Printview: PCB terminal strip; 2 solder pins/pole; 5-pole; pin spacing 2.54 mm / 0.1 in; with push-button Item No.: 233-505 Technical data Weight [g] 2.092 [g] Width 15 mm / 0.591 in Height 19.5 mm / 0.768 in Height from the surface 15.5 mm / 0.61 in Length 13.9 mm / 0.547 in WAGO Kontakttechnik GmbH & Co. KG 3 Printview: PCB terminal strip; 2 solder pins/pole; 5-pole; pin spacing 2.54 mm / 0.1 in; with push-button Item No.: 233-505 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 4 Printview: PCB terminal strip; 2 solder pins/pole; 5-pole; pin spacing 2.54 mm / 0.1 in; with push-button Item No.: 233-505 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 5
0233-0505 价格&库存
很抱歉,暂时无法提供与“0233-0505”相匹配的价格&库存,您可以联系我们找货
