Printview: 4-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature
metric fuse; 12 … 30 V; with blown fuse indication by led - Item No.: 2002-1811/1000-541
holder; for 5 x 20 mm miniature metric fuse; 12 … 30 V; with blown
4-conductor fuse disconnect terminal block with pivoting fuse holder; for 5 x 20 mm miniature metric fuse; 12 … 30 V;
Marking
Business data
Supplier
WAGO
Item no.
2002-1811/1000-541
GTIN / EAN
4045454790073
Content
1
Order amount
50
Customer item number
Notes
Safety information 1: Electrical ratings are given by the fuse and blown fuse indication.
Technical data
Miscellaneous
Total number of connection points
4
Total number of potentials
1
Color
gray
Ratings according to 1
IEC/EN 60947-7-3
Pollution degree (1)
3
Rated voltage EN (1) [V]
250 [V]
Rated surge voltage (1) [kV]
6 [kV]
Nominal current [A]
6.3 [A]
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Connection technology (1)
Push-in CAGE CLAMP®
Nominal cross section 1
2.5 mm²
Solid sizes 1
0.25 … 4 mm² / 22 … 12 AWG
solid, directly pluggable 1
0.75 … 4 mm² / 18 … 12 AWG
Fine-stranded wires 1
min. fine-stranded with insulated ferrule, push-in terminati 0.75 mm² / 18 AWG
Strip length 1
10 … 12 mm / 0.39 … 0.47 in
Type of wiring
Front-entry wiring
Design
horizontal
Marking level
Center/Side marking
Insulating material
Polyamide 66 (PA 66)
Weight [g]
8.426 [g]
Width
6.2 mm / 0.244 in
Height from upper-edge of DIN-rail [mm]
57.2 [mm]
57.2 mm / 2.252 in
Length
87.5 mm / 3.445 in
Type of mounting
DIN 35 rail
Safety information 2
Leakage current in case of blown fuse: LED 2mA
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“2002-1811/1000-541”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+300.975831+37.66395
- 10+217.3097710+27.19402
- 25+195.6164625+24.47934
- 50+182.8579950+22.88275
- 100+172.72473100+21.61468
- 250+162.58442250+20.34572
- 500+156.85813500+19.62914
