209-120
209-120
    WAGO(万可电子)
    模块化接线端子,带固定法兰或卡扣式安装脚
209-120 数据手册
Interface Modules Full Line Catalog 2010/2011 4 WAGO Registered Trademarks WAGO® CAGE CLAMP® CAGE CLAMP®@ POWER CAGE CLAMP FIT CLAMP® PUSH WIRE® TOPJOB® TOPJOB®@ X-COM® X-COM®@ WINSTA® JUMPFLEX® TO-PASS® ProServe® WAGO trademarks are registered brand names or regionally registered makes of products from WAGO Kontakttechnik GmbH & Co. KG WAGO Full Line Catalogs 7PMVNF 3BJM.PVOUFE5FSNJOBM#MPDL4ZTUFNT tRail-Mounted Terminal Blocks tModular Connectors (X-COM® 4:45&. tTerminal Strips tPatchboard Systems t4IJFME 4DSFFO $POOFDUJOH4ZTUFN tPUSH WIRE®$POOFDUPSTGPS+VODUJPO#PYFT 7PMVNF $POOFDUPSTBOE1$#5FSNJOBM#MPDLT tPCB Terminal Blocks tFeedthrough Terminal Blocks tMULTI CONNECTION SYSTEM tPCB Connectors tSpecialty Connectors Volume *04:45&. t.PEVMBS*04:45&.*1 t8JSFMFTT5FDIOPMPHZ TO-PASS® Telecontrol Technology t*OEVTUSJBM4XJUDIFT PERSPECTO t.PEVMBS*04:45&.*1 #MPDL*04:45&.*1 t4FOTPS"DUVBUPS#PYFT*1 $BCMFTBOE$POOFDUPST*1 t1PXFS4VQQMJFT Volume *OUFSGBDF.PEVMFT tRelay – Optocouplers – Special Functions tInterface Modules tTransducers t1PXFS4VQQMJFT tOvervoltage Protection tWireless Technology tEmpty Housings and Mounting Carriers 7PMVNF WINSTA® Connector System tWINSTA® MINI tWINSTA® MIDI tWINSTA® MAXI tWINSTA® RD tWINSTA® KNX tWINSTA® IDC Connectors Connectors Connectors Cable Assemblies Connectors Flat Cables Handling of WAGO Connection Technologies* Universal connection with “@PECIAL” S Handling: 0QFOUIFDMBNQ JOTFSUXJSFBOESFMFBTFUIFDMBNQo done! Solid conductors and fine-stranded conductors XJUIGFSSVMFTBSFDPOOFDUFECZTJNQMZQVTIJOHUIFNJO – no operating tool needed. Universal connection of solid, stranded and fine-stranded conductors Handling: 0QFOUIFDMBNQ JOTFSUXJSFBOESFMFBTFUIFDMBNQo done! Universal connection of conductors larger than 6 AWG (16 mm2) Handling: - 5PPQFOUIFDMBNQXJUIBTUBOEBSEIFYXSFODIPSPQFSBUJOH UPPM BOEUVSOBQQSPYJNBUFMZUXJDFDPVOUFSDMPDLXJTF - Latch holds clamp open. - Insert conductor. "TNBMMDPVOUFSDMPDLXJTFSPUBUJPOSFMFBTFTUIFMBUDI. Insulation displacement connection (IDC) Handling: Push unstripped conductor into the IDC contact using an operating tool. PUSH WIRE® connection for solid wires and stranded wires (depending on product used) Handling: Solid and stranded conductors that are rigid enough are connected by simply pushing them in – no operating tool needed. 1MFBTFGPMMPXUIFQSPEVDUJOTUSVDUJPOTGPSQSPEVDUTQFDJmDIBOEMJOH Contents Volume 4 Relays – Optocouplers – Special Functions 1 1 Interface Modules 2 2 Transducers 3 3 Power Supplies 4 4 Overvoltage Protection 5 5 Wireless Technology 6 6 Empty Housings and Mounting Carriers 7 7 Accessories 8 8 Technical Section 9 9 0 An Interface Solution for 4 JUMPFLEX®– Transducers / Relay and Optocoupler Modules 857 Series JUMPFLEX®– 8-Channel Adapter 857 Series Interface Modules 289 Series Overvoltage Protection 288 Series EPSITRON Power Supplies 787 Series 0 All Applications 5 Relay Modules and Optocoupler Modules 859 Series Pluggable Function Modules 286 and 786 Series Sockets for Miniature Switching Relay / Optocoupler 788 Series Relay Modules in DIN-Rail Mounted Enclosure 789 Series Sockets with Industrial Relay 858 Series 0 6 WAGO Interface Modules Design and housing possibilities Nowadays when equipment is designed 857 Series Transducers and many scenarios need to be considered. Relay Modules Some of which are user and maintenance friendly, limited budgets, safety, availability, space requirements and simplicity in design and usage. 286 / 786 Series Pluggable Function Modules WAGO AUTOMATION offers interface modules in various shapes and sizes to overcome any of the restraints posed by space requirements. This enables any demands and needs to be fulfilled using these different designs, such as pluggable function and interface modules, relay and optocoupler modules, etc. Transducers and relay modules Pluggable function modules The WAGO Series 788 relay socket forms an excellent basis for switching applications using pluggable miniature switching relays (1 or 2 changeover contacts) in industrial and process automation. The new 6mm-wide WAGO isolation amplifiers and transducers not only share a common profile, but in addition one in line jumper can be used to connect the supply voltages, etc, to all modules, doing away with the need to wire each connection. The smaller relay modules also fit perfectly in this scenario. The pluggable relays can simply be replaced from the top. The terminal blocks for pluggable modules offer the greatest degree of flexibility and maintenance-friendly service. The terminal block for pluggable modules is mounted on the carrier rail and wired like a normal terminal block. If service is required, this element can be replaced in one step, without having to deal with the system wiring. This saves space and additional wiring effort. Relay socket with pluggable miniature switching relay Relay module with pluggable miniature switching relay Pluggable function modules In addition to its compact design 15x53x86mm (W x H x D), the relay socket also stands out thanks to a number of user-oriented features, with the associated benefits for the user. The lever facilitates relay replacement even when the relay sockets are placed close to each other. The sockets can be ordered as complete components including relay and status indication or as a single component. In order to cover all application areas with one product family, it is intended to offer five different groups for the transducers alone: these include fixed and configurable isolating amplifiers, passive isolators, power supply isolators (also for HART applications), signal duplicators and temperature transducers for Pt100 and thermocouples. The optocoupler and relay modules are ideal additions to a comprehensive function module program, allowing any required functions to be implemented in a control cabinet by means of a pluggable module system. Large enclosures of the Series 786 are available for more complex functions, such as transducers. Transducer Pluggable signal conditioning modules 788 Series Relay Sockets with Pluggable Miniature Switching Relay 0 789 Series Relay Modules in DIN-Rail-Mountable Enclosure The range of uses for the WAGO latching relays and switching relays of Series 789 spans from simple lighting controls in building services, such as in construction of apartments, hotels, office buildings or parking garages, etc., up to installations in industrial control cabinets. 287 / 288 Series DIN-Rail-Mountable Modules - Relay Modules and Sockets The relay and PLC interface modules in the mounting socket that can be fitted 859 Series Relay Modules and on carrier rails ensure quick and easy Optocoupler Modules linking of signals from periphery devices. The Series 859 is a complete product The fully wired modules, with up to 16 series that is ideal for the interface level high-performance relay outputs, provide The 17.5mm-wide design in series bay in any industrial application, thanks to the for direct switching of actuators and other enclosures is particularly well-suited for wide range of relays and optocouplers. coupling elements in the field. installation in distribution boards and meter mounting boards. Relay module DIN-rail-mountable modules - relay modules Relay modules in DIN-rail-mountable enclosure These units excel in tight spaces, thanks to their narrow 6mm design. Simple commoning at the control and load side enables quick and easy looping through of common input and output potential. The requisite free-wheeling and reverse voltage protection diodes are also integrated to ensure a long service life of the products. The series bay enclosures are used for installation of other electronics devices having a large scope of functions and higher switching capacities; these come in sizes of 2 module spaces (35mm) and 4 module spaces (70mm). Other interface modules available as: Multiple modules with plugged relays that are easy to replace, without affecting existing wiring. Optocoupler module DIN-rail-mountable modules - relay modules Its robust design and the shock-proof CAGE-CLAMP® connecting technology used ensures continuous and uninterrupted operation of any kind of system. EnOcean radio receiver in DIN-rail-mountable enclosure PCB terminal blocks and connectors from the extensive WAGO program can be installed in the enclosures to obtain customized development of interface components. Installation is quick and reliable on the 35mm carrier rail. Relay socket 7 0 8 WAGO Transducers and Relay Modules JUMPLFEX® , 857 Series At the input side the devices required active signals, i.e., the sensor signal is generated by a dedicated supply voltage. These devices provide a filtered and amplified signal at the output side. The perfect match of housing and electronics is the key to a highly successful device. This is exactly what has been achieved by WAGO with the transducers and relay modules of the 857 Series. The WAGOframe FDT frame application provides a wizard, which simplifies the operation of components, such as WAGO JUMPFLEX® DTMs. This wizard guides the user through the different operating modes of DTM device drivers. This can be calculated using the following equation: US ≥ UE = UV + 20 mA x RB US ____> Analog systems technology — Basics Problems can arise in signal processing in industrial systems of analog standard signals (such as 0-10V or 0-20mA) which can have an adverse effect on overall fault-free signal processing. Problems such as potential differentials arising from interlinked measuring circuits can be efficiently prevented using WAGO transducers, with their associated electrical isolation. Decoupling (Isolation) methods A basic distinction is made between active and passive isolation. Passive isolation A passive isolator draws power for signal transmission from the input circuit. In this case, the sensor must supply a power level adequate for the device and must also drive the working resistance. As a result, it must be ensured that the current-driving power of the sensor is sufficient to drive the maximum current of 20mA via the passive isolator (with the device-specific voltage drop), as well as the working resistance. Parameterization, commissioning and diagnostics using WAGO-frame A portion of the JUMPFLEX® transducer can be configured for parameterization, commissioning and diagnostics of field devices using WAGOframe, a software based on the FDT/DTM standard. UE I I I RB __________________> UV = 2.0 V 3 different connecting techniques are employed for acquisition of resistance thermometers: 2-wire connecting technique 1 Active isolation Depending on the design and model in use, devices are available that incorporate electrical 3-way isolation. 4-way isolation is provided in a signal duplicator. This means that all inputs, outputs and supply circuits are electrically isolated from one another with a 2.5 kV proof voltage. 2.5 KV Safe Isolation This ensures that the greatest possible safety and reliability is achieved for the system and any devices connected to the system. For 3-way isolation provides for electrical isolation between the transducers and the control system and between the control system and the control elements. Typical equation for a passive isolator (857-451) for a 20mA signal. 2 3 4 US ≥ UE = 2.0 V + 20 mA x 600 Ω US ≥ UE = 14 V Temperature measuring techniques Resistance thermometers, such as Pt100 sensors, alter their resistance level as a function of temperature. For example, a rise in temperature will result in an increase in the resistance level. This reistance level is registered by the JUMPFLEX® devices (for example 857-800) and transformed into an analog output signal and simultaneously electrically isolated using a 2.5kV proof voltage. The analog standard signal can be a current signal in the 0-20 mA, 4-20 mA 0-10 mA or 2-10 mA range, or a voltage signal in the 0-10 V, 2-10 V, 0-5 V or 1-5 V range. 2-wire The resistance thermometer is connected to the JUMPFLEX® transducer via a twowire conductor. As the feed-in resistance can directly affect results, which would invalidate them, it must be ensured that the distance between the measuring point and the device is kept as small as possible. This distance should not exceed 10m in this case. If this distance can not be ensured, the 857-801 unit can be used provide compensation for the incoming resistance using the configuration software. 0 9 Compensation for line resistance (2-wire) A resistance value can be input into this field for compensation of the line resistance for 2-wire sensors within a range of 0-50 Ω . Adjusting the values for resistance compensation is only possible by setting the sensor wire connection to 2-wire. Otherwise the field is displayed in gray and no values can be entered. Using 3- and 4-wire sensors, the input cable resistance is compensated via the connection technology and does not enter into the measuring results. 3-wire connecting technique 1 2 3 drop for the incoming and outgoing lines can be measured separately and compensation provided for as required. Again, no line adjustment is required here. Table for Thermocouples Thermocouples In contrast to resistance thermometers, thermocouples are active sources that generate output in the microvolts range. Thermocouples have very low resistance and are therefore noise-free. Preferred applications include tasks in environments with high temperatures, such as in ovens or machines in the plastics industry. The joining of two different materials at the thermocouple results in different energy of formation of the metal atom electrons, yielding a thermoelectric voltage. The level of this thermoelectric voltage is a function of the material and of temperature. Fe 4 Cu 4-wire connecting technique 1 2 3 4 CuNi __ 2 __ 1 _> 3-wire The 3-wire connecting technique minimizes the effect of line resistance. The resistance thermometer is gauged via two measuring circuits implemented in the JUMPFLEX® transducer. One measuring circuit serves as the reference circuit. Line resistance can be compensated for in this manner. The measuring results can, however, nevertheless be affected by different line lengths or by different ambient temperatures. No further line adjustment is usually necessary, as the same line lengths and the same ambient temperatures exist in most cases. vated and de-activated just by a click using the configuration software (default setting: ON (activated)). Cu If the temperature at measuring point ϑ1 is the same as the temperature at reference point ϑ2, no current will flow, as the two component voltages cancel one another out. However, if the temperatures at the measuring point and at the reference point are different, differing voltage levels are produced which do not completely cancel one another out, resulting in a flow of current. To summarize then, a thermocouple only measures a difference in temperature. This is yielded from the difference between the thermoelectric voltage levels at the measuring point and at the reference point. The voltage fluctuation produced by the thermoelectric effect is very low and is generally only a few microvolts per Kelvin. Therefore, only the difference between the thermoelectric voltages of the materials used is of significance, for example, thermocouple type J, iron (Fe) and constantan (CuNi). Type of sensor Thermocouple materials Measuring range J *) Fe-CuNi -210 °C ... +1200 °C K *) NiCr-Ni -200 °C ... +1372 °C E *) NiCr-CuNi -200 °C ... +1000 °C N *) NiCrSi-NiSi -200 °C ... +1300 °C R *) Pt13Rh-Pt +250 °C ... +1768 °C S *) Pt10Rh-Pt -50 °C ... +1664 °C T *) Cu-CuNi -200 °C ... +400 °C B *) Pt30Rh-Pt6Rh +250 °C ... +1820 °C C 0 °C ... +2320 °C *) Thermocouples based on IEC 584 / EN 60584 Other thermocouples available upon request. Relay modules with mounted miniature switching relays The JUMPFLEX® product family is rounded out by the relay modules that fit perfectly with the transducers. A logical enclosure concept with options for linking all levels offers a variety of synergy and cost-savings potential. This allows for efficient optimization of installation efforts. The pluggable relays can be replaced quickly and easily when required. 4-wire The most accurate measuring method employs the 4-wire connecting technique. This involves feeding in a low supply current via two fully isolated measuring circuits via two lines and measuring the voltage drop across the resistance thermometer via the other two lines. This method offers the advantage not being influenced by line resistance or temperature-induced fluctuations, as the voltage Also of some significance in the connection point temperature. This temperature must be known in order to derive the ambient temperature from the thermoelectric voltage level. This is why the temperature at the connection point is measured by JUMPFLEX® transducers. This value, also referred to as the reference or cold For further information about the relays junction, can then be compensated for. go to pages 10 - 12. (cold junction compensation) Cold-junction compensation can be acti- 0 WAGO Relay Modules 10 WAGO Relay Modules. The professional interface between electronics and peripheral equipment. Even in modern automation systems, electromechanical relays guarantee a safe connection between process control systems and process and signalling systems. They provide: t a high isolation level between input and output circuit t ability to match different signal levels t signal amplification and/or signal multiplication, especially for different potentials in the input and output circuits. Modernized relays also offer the following advantages: t unaffected by electromagnetic fields and surges t high short-term overload capacity for the input and output sides t small switching power losses t a module for switching of AC or DC WAGO AUTOMATION offers a complete range of relay modules that provide these functions for a wide range of applications. Depending on the function and operating conditions, the relay modules are available with different contacts, contact materials, housings and shapes. The following relay types are also available: bistable switching relays, timedelay relays, current pulse switching and safety relays with force-guided contacts. Definitions of several important technical terms Coil-side information The relays can be used within the stated temperature range with nominal voltage plus tolerance at 100% contin uous duty rating. According to the type and application, the relays are triggered with DC or AC signal. The DC versions (residual ripple ≤6%) are, unless otherwise stated, equipped with LED function indicators, a recovery diode and a reverse voltage protection diode. AC versions of select relays equipped with series connected rectifiers (refer to the wiring diagrams) can be triggered with AC and DC at the stated nominal voltage. The free-wheel function is in this case actuated by the rectifier. In order to guarantee a safe operation it has to be observed that “residual voltages” due to cable capacitance in case of long connecting lines or leakage currents of semi-conductor switches and their protection circuits are lower than the release voltage of the relay. For DC relays, the release voltage is specified with a value of ≤5% of the nominal voltage; for AC relays it is 15% of the nominal voltage (acc. to VDE 0435). If a high residual voltage exists, it is possible that the relay will not reset. For a nominal voltage of ≤12VDC, the LED is connected in parallel to the coil. Addition of a parallel connection of an RC element of: R = 100-220Ω C = 220-470nF could remedy this situation. For a nominal voltage ≥24VDC, the LED isconnected in series with the coil. Alternatively, the 286-904 relay module is available. This specially developed module features a defined release point at 110VAC ± 10% at an operating voltage (coil volt age) of 230 VAC. 0 11 Contact material To ensure a long service life and low contact resistance, various materials may be used for relay contacts (depending on the load type, switching current, voltage and duty cycle). Possible mate rials, their properties and advantages are shown in the table. Properties and use Ag Ni 0.15 + 5 μ Au High corrosion resistance, low and constant contact resistance at small power ratings, for dry circuits μV . . . 30 V μA . . . 0.2 A Ag Ni plated with Au Ag + Au Same properties as a 5 μ gold contact, however with five times greater resistance to wear, for all circuits from the μW range up to 100 W/1 kVA 100 mV/10 μA Ag Cd 0 + 1 μ Au Low tendency to contact weld, high resistance to contact burn-out at higher power rating, also suitable for lower power ratings ≥5V ≥ 10 mA Ag Cd 0, with gold flash Low tendency to contact weld, high resistance to contact burn-out at higher power rating, with gold flash for additional protection during storage ≥ 12 V ≥ 100 mA Ag Ni 0.15 + HV High mechanical strength, low tendency to contact weld and low contact resistance, universal application at medium loads ≥ 12 V 5 mA – 10 A Ag Sn 02 Small tendency to contact weld, high resistance to contact burn-out at higher power rating, small migration of material, for circuits with high input and output ratings, DC circuits ≥ 5 V/100 mA ≥ 10 V/10 mA ≥ 24 V/1 mA Ag alloy, with gold flash High mechanical strength, small tendency to contact weld, wide scope of application for low to medium ratings 10 –3 W Additional off-delay Switching of load Range of values Defined limitation of inductive voltage Attenuation when used with bipolar circuits Circulating diode Advantages / disadvantages Advantages: simple device t cost-effective, reliable t sizing not critical t small inductive voltages t + __________< UD – large yes (VD) no Load Disadvantages: limit only via load resistance t longer turn-off time t Series of diode /Zener diode Advantages: sizing not critical t + __________< Contact switching protection When switching inductive loads (e.g., for contractors or solenoid valves) transients with peak voltages up to thousands of volts will arise. Suppression is necessary as these transients frequently exceed admissible EMC limits. Moreover, they cause electric arcs at the switching contact that destroy the contact and significantly reduce the relay’s service life and functional safety. In practical use the following switching protections, which are connected directly at the source in parallel to the load, have proved to be efficient: Contact material UZD – Load medium to small yes (VZD) no Suppressor diode Disadvantages: limits only above VZD t Advantages: cost-effective sizing not critical t limitation of positive peaks t suitable for alternating voltages t + t __________< UZD – Load medium to small yes (VZD) yes Disadvantages: attenuation only above VZD t Varistor Advantages: t high energy absorption t sizing not critical t suitable for AC voltages + – __________< VDR UVDR Load medium to small yes (VVDR) yes R/C combination Disadvantages: t attenuation only above VVDR Advantages: limiting by energy storage t suitable for alternating voltages t limiting independent of level t + C – __________> R URC Load medium to small no yes Disadvantages: exact component values t high turn-on current pulse t 0 WAGO Relay Modules 12 Service life The difference between mechanical life and electrical life must be distinguished. Mechanical life consists the amount of switching operations without contact load; electrical life at maximum load refers to the amount of switching operations with maximum switching capacity and resistive load. Smaller switching capacities increase the operation at maximum load. The following illustration shows the typical course between switching current and relay's operational life. Live x 104 switching operations 1000 500 200 250VAV, resistive load 100 250VAC, inductive load (cos.ϕ = 0.4) 50 20 10 1 2 3 4 5 6 7 8 9 10 Switching current A More details upon request. After removing the control signal, the relay returns to its respective position and can only be switched over by a control signal circuit. The bistable switching relays are only available for direct voltage with positive or negative triggering. As shown in the fig. “Example of Circuit Configuration,“ two SF relays are controlled by one output interface. The NO contacts 13–14/19–20 of relay A and B switch over the peripheral equipment. After switching off equipment a ... d the control circuit (NC contacts 5–6/11–12) verifies that all main circuits are interrupted. Current pulse switching relay When the control circuit is closed, the One current pulse is needed to change next operation cycle will be executed by the relay from the rest position to the wor- the CPU or by the control logic. king position and vice versa. Depending on the safety requirements, During the triggering process, one of two an open control circuit prevents status indicators displays the actual con- operation of either the entire machine or tact position. The current pulse specified components. switching relay is available for direct and If a partial or complete standstill is alternating voltage. required in the event of a failure (for ex. in medical technology or chemical processes) each control contact can Safety relay be polled and evaluated. Force-guided safety relays, have become increasingly recommended and specified Independent of a single or complete for self-regulated systems as they provide control for the NO contact, the SF relay operates in such a way that the other protection for personnel, machines and equipment is switched off even if a NO installations. Relays with force-guided contact is welded. The failure is recognicontacts are an essentially safety comzed by the control contact while the other ponent for these circuits, particularly when defects occur. WAGO offers these contacts are still able to open to interrupt circuits. functions in special relay modules with force-guided contacts as based on to ZH1/457 Time delay relays (Specification of the employer’s liability insurance association). Example of circuit configuration: Input interface CPU or control logic Description of select relays Bistable switching relays Bistable switching relays have 3 coil contacts. According to the wiring scheme, the relay is switched into “working condition“ (contacts 11–14 closed) by the common connection A 3 and the connection A 1 and into “rest position“ (contacts 11–14 opened) by the connection A 2. Monitoring circuit Output interface B 19 11 14 11 A3 _ A2 + a 12 13 b 5 6 A 19 A1 + 20 11 14 20 c 12 13 5 6 12 14 Control of different peripheral equipment (a, b, c, d) with monitoring d WAGO time delay relay modules are electromechanical time relays with an integrated time response, e.g., acc. to VDE 0435, part 201/5.83. The time ranges can be adjusted via potentiometer for either continuously variable or linear operation. A status LED indicates the switching condition of the relay. 0 WAGO Optocouplers 13 t electrical isolation between input and output circuit t adaptation to different signal levels t signal amplification. The optocoupler modules are available in WAGO’s component plug technology that is designed to plug directly into railmounted carrier terminal blocks. The terminal blocks are fitted to the carrier rail and offer all advantages of CAGE CLAMP® technology, which provides safe and maintenance-free connection of the signal wires for cross sections ranging from 0.08 mm2 to 2.5 mm2/ AWG 28–12. In addition to optimizing space through the combination of terminal points and the “function module,” maximum flexibility and ease of service are also achieved. Input circuit According to the type, triggering the optocoupler modules is performed via direct voltage (residual ripple RR 18 u V ˆû V 0 (_ T _) _) T1 =1,2 m s (_ Voltage pulses 1.2 /50 per IEC 60060-1 /DIN VDE 0432 P. 2 % 100 90 50 10 surge conduction, resulting in lower impedance and higher leakage. T1 = 8m s When subjected to continuous (AC or DC) voltages in excess to the device rating, MOVs Current pulses 8 /20 can overheat, and even explode, in certain circumstances. This is why a quality surge pro- per IEC 60060-1 /DIN VDE 0432 P. 2 tection device is important, it will incorporate protective measures to disconnect faulty com- Application recommendations ponents before safety is compromised. The advantages of gas-filled surge arresters lie in their high current carrying capacity, making them ideal for coarse protection. One Suppression diode disadvantage, particularly in the medium pro(or silicon avalanche diode) tection range, is the relatively long response time, as well as the power follow current. Varistors have a considerably shorter response time; however they also have lower leakage currents. This makes them more suitable for medium protection, as they offer limited applications for coarse protection. If the connection lines of electronic equipment are already “fine” protected, general coarse and medium protection measures are sufficient. If this is not the case, suppressor diodes with very short response time may be employed as fine protection. WAGO AUTOMATION offers a complete range of modular terminal blocks with inteThese devices have electrical characteristics grated surge arresters for coarse, medium similar to Zener diodes, but are rated for sur- and fine protection. ge currents. Depending on the application, one can choose the appropriate type from the preOnce the rated breakdown voltage is excee- viously mentioned surge arresters. These are ded (in the non-conductive direction), the electrically connected in the modular terminal diode becomes a conductor. The suppressor blocks between the connection point and diode differs from a Zener in its higher current the mounting rail. Snapping the terminal carrying capability and faster response time block onto the grounded (earthed) moun(in the picosecond range). ting rail automatically ensures the required overvoltage protection. Test impulse Surge arresters are subject to standardized test pulses in order to classify capabilities; the effectiveness of protection measures with reference to dissipation capacity and voltage arresting. The form and level of the test pulses are defined by IEC 60060-1/DIN VDE 0432, part 2. Preference is given to voltage pulses of 1.2/50 and current pulses of 8/20. 0 19 Max. surge current (lSmax) Definition of several important technical terms The maximum surge current lSmax defines the maximum value of a current having Nominal operating voltage (VBN) the 8/20μs waveform, which can flow through the surge arrester once without The nominal operating voltage corresponds to destroying it. the voltage which may be permanently connected to the appropriate connection terminals of the overvoltage protection module. Alternating voltages are quoted as effective values. Double-deck terminal block with varistor, direct connection to the DIN 35 rail Protection level The protection level is the value of the residual voltage occurring on the “protected” side of the surge arrester when applying the rated discharge current. Max. operating voltage (VBmax) Frequently, only one surge arrester is fitted for cost reasons. However, due to the fact that one surge arrester alone cannot optimally ensure several protection functions, combinations are recommended. Care must be taken to ensure that the single-stage protection devices are decoupled sufficiently by inductors or resistors. The maximum operating voltage corresponds to the voltage which may be permanently connected to the appropriate connection Response time (tan) terminals without the operating properties changing or activating the individual module's The response time is primarily based protection elements. In addition to single-stage surge arresters, WAGO AUTOMATION also offers multistage surge arresters, combining components for different applications. These pluggable modules are snapped into “carrier” terminal blocks. These are DIN rail-mounted and offer secure and maintenance-free CAGE CLAMP® terminations for conductors 0.08mm2/AWG 28 to 2.5mm2/AWG 14. The nominal current corresponds to the current which may permanently flow through the connection terminals of the overvoltage protection device. Nominal current (IN) Nominal discharge current (ISN) The nominal discharge current is the maximum value of a current having the 8/20 μs waveform (DIN VDE 0432/10.78 part 3), which can flow through the surge arrester five times within a time period of 30 seconds (VDE) without destroying it. V 600 V 600 V 600 10 500 500 500 8 400 400 400 6 300 300 300 4 200 200 200 100 100 100 0 0 kV 12 Pluggable surge suppression modules with on-unit warnings Addition of interference suppression to surge suppression devices. In addition to overvoltage protection, a high frequency interference filter can be added to the circuitry. This filter cannot only protect the equipment from high frequency energy transmitted by connecting wires, but also prevents a transmission of disturbances to the supply lines. The main component of a filter is an LC network, which produces a mismatch between the filter impedance and the impedance of the disturbance path. This reflects any disturbance back to its source. on the physical properties of the surge arresters and is dependent upon the wave front duration of the surge voltage. WAGO's data refers to a voltage rise of 1kV/μs. 1 kV/m s duration of surge voltage 2 0 0 20 40 60μ s 0 1 2μ s 0 1 La 0 2μ s 0 1 2μ s La VDC = 24 V a) or R gas-filled surge arrester Function diagram of a multi-stage surge voltage protection module varistor suppression diode applicance to be protected 0 Overview: Relay Modules 20 859 Series 857 Series 788 Series 858 Series 288 and 287 Series 286 Series 789 Series Relays with Changeover Contacts Nominal voltage 1 changeover contact 5V 12 V 24 V 48 V 60 V 115 V Page Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page 859-302 286-302 32 101 859-303 857-303 788-303 286-303 287-853 32 50 64 101 93 859-304 859-314 859-390 859-398 859-392 857-304 857-314 788-304 788-404 788-324 788-354 788-374 286-304 286-394 286-380 286-381 288-304 287-774 287-804 287-824 287-854 288-380 789-304 788-506 32 33 36 37 38 50 50 64 66 68 70 73 101 102 109 109 89 91 92 92 93 95 140 65 859-305 857-305 788-305 286-305 286-395 32 50 64 101 102 859-306 857-306 788-306 286-306 32 50 64 101 859-307 859-317 859-391 857-307 857-317 788-307 286-307 32 33 37 50 50 64 101 859-308 859-318 857-308 857-318 286-308 32 35 50 50 101 859-360 859-367 788-507 788-607 286-507 34 35 65 67 101 32 101 859-354 857-354 857-364 286-504 286-594 288-554 288-504 288-758 287-814 287-834 789-504 32 50 50 101 102 89 89 90 92 92 140 859-355 286-505 101 859-357 857-357 857-367 288-761 32 50 50 90 859-359 859-368 788-508 788-608 788-528 286-508 286-904 288-508 288-762 789-508 859-358 857-358 857-368 34 36 65 67 69 101 108 89 90 140 32 50 50 DC AC 286-502 101 859-353 286-503 Item No. Page Item No. Page Item No. Page 286-310 103 788-311 286-311 64 103 286-510 103 286-511 103 788-312 788-412 788-334 788-384 788-375 286-312 286-384 288-312 288-437 789-312 788-512 286-512 64 66 68 72 73 103 107 90 96 141 65 103 288-512 789-512 90 141 AC/DC Nominal voltage 2 changeover contacts 5V 12 V 24 V DC 32 101 286-506 Item No. Page Item No. Page Item No. Page Item No. Page 788-313 286-313 789-313 64 103 141 788-314 286-314 64 103 788-315 286-315 789-315 64 103 141 286-316 103 286-513 103 286-514 103 788-515 788-615 286-515 789-515 65 67 103 141 788-516 788-616 788-538 286-516 789-516 65 67 69 103 141 Page Item No. Page Item No. Page Item No. Page 286-578 106 858-508 858-518 286-579 83 83 106 48 V 60 V 115 V AC AC/DC Nominal voltage 4 changeover contacts DC AC 230 V Item No. 5V Item No. 12 V Page Item No. 24 V Page 48 V Item No. Page 858-304 858-314 286-375 82 82 106 Item No. 60 V 230 V 115 V 230 V 0 Relays with Make Contacts Nominal voltage 1 make contact 5V Item No. 21 12 V Page Item No. 24 V Page DC AC AC/DC Nominal voltage 2 make contacts DC 5V 12 V 48 V 60 V 115 V Item No. Page Item No. Page Item No. Page 286-364 788-355 288-364 288-320 287-475 287-474 789-571 286-376 286-564 100 71 88 94 94 94 144 107 100 286-365 100 286-366 100 288-564 88 288-565 24 V 88 48 V 60 V 230 V Item No. Page Item No. Page 286-566 100 286-567 789-570 100 144 288-567 88 115 V Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page 286-326 104 286-327 104 286-328 104 286-329 104 286-330 104 Item No. 230 V Page Item No. Page 286-332 104 AC AC/DC Nominal voltage 4 make contacts DC 5V 12 V 24 V 48 V 60 V 115 V 230 V Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page 286-350 106 286-351 106 286-352 789-352 286-552 106 143 106 286-353 106 286-354 106 286-355 106 286-555 789-552 143 AC 789-551 AC/DC 143 Item No. Page 106 286-556 106 Page Item No. Page Item No. Page 286-324 104 286-570 109 Relays with break contacts and make contacts Nominal voltage 1 break contact 5V Item No. 12 V Page Item No. 24 V Page DC AC AC/DC Nominal voltage 1 break contact/ 1 make contact 5V 12 V 48 V 60 V 115 V Item No. Page Item No. Page Item No. Page 286-368 100 286-369 100 286-370 100 286-568 100 288-568 88 24 V 48 V 60 V Page Item No. Page Item No. Page Item No. Page Item No. Page 286-318 104 286-319 104 286-320 286-906 286-571 286-520 104 108 109 104 286-321 104 286-322 104 AC 230 V 115 V Item No. DC Item No. Item No. Page 230 V AC/DC Nominal voltage 2 break contacts/ 2 make contacts DC 5V 12 V 24 V DC 115 V 230 V Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page 286-334 105 286-335 105 286-336 789-336 286-536 105 142 105 286-337 105 286-338 105 286-339 105 142 789-536 142 789-535 AC/DC 1 break contact/ 3 make contacts 60 V Page AC Nominal voltage 48 V Item No. 5V 12 V 24 V 48 V 60 V 115 V Page 286-540 105 230 V Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page 286-342 105 286-343 105 286-344 105 286-345 105 286-346 105 286-347 105 286-544 105 286-547 105 AC Item No. Item No. Page 286-548 105 AC/DC Nominal voltage Safety relays 4 break contacts/ 4 make contacts DC 5V Item No. 288-412 288-422 12 V Page 97 97 Item No. 288-413 288-423 24 V Page 97 97 Item No. 288-435 48 V Page 96 Item No. 60 V Page Item No. 115 V Page AC AC/DC 288-414 288-424 97 97 288-415 288-425 97 97 288-416 288-426 97 97 Item No. 230 V Page Item No. Page 288-418 288-428 97 97 0 Overview: Timing Relays, Optocouplers and Special Functions 22 Timing Relay with Changeover Contact Nominal voltage Timer Range 1 changeover contact 0.1 s ... 1 s 1 s ... 10 s 10 s ... 100 s 0.1 s ... 1 s 1 s ... 10 s 10 s ... 100 s 0.3 s ... 3 s 3 s ... 12 s 10 s ... 100 s 100 s ... 800 s 0.3 s ... 3 s 3 s ... 12 s 10 s ... 100 s 100 s ... 800 s 24 V DC 230 V AC Multirange Timing Relay 24 V AC, 115 V AC, 230 V AC, 24 V DC Multifunction Timing Relays 24 V DC 859 Series On-Delay Off-Delay Pulsing Pulse Lengthening Item No. Page Item No. Page Item No. Page Item No. Page 286-600 286-602 286-604 286-610 286-612 286-614 110 110 110 110 110 110 286-440 286-442 286-444 286-446 286-448 286-450 112 112 112 112 112 112 286-460 286-462 286-464 286-470 286-472 286-474 113 113 113 113 113 113 286-426 286-427 286-428 111 111 111 286-616 114 857 Series 286-640 286-640/004-000 788 Series 115 138 286 Series Optocouplers Function Input Output 5 V DC 24 V DC 60 V DC Max. Perm. Continuous. Current 859 Series Page 859-795 859-793 859-796 859-794 40 39 40 41 24 V DC 48 V DC 2-Wire Optocouplers 859-730 859-740 42 42 121 122 2 x 24 V DC 286-790 286-792 123 122 115 V AC/DC 230 V AC/DC 2-Wire Optocouplers with zero volt switch 4A 286-732 286-733 286-734 286-752/002-000 286-750 286-751 286-752 286-723 120 120 120 119 116 116 116 119 3-Wire Optocouplers positive switching 300 mA 286-938 123 0.5 A 286-754 286-756 286-758 117 117 117 286-726 286-728 286-700 286-701 286-702 286-720 120 120 116 116 116 118 24 V DC 230 V AC 5 V DC 12 V DC 3-Wire Optocouplers negative switching 286-721 286-730 286-704 286-706 286-708 286-725 286-740 286-741 286-742 118 120 117 117 117 121 124 124 125 24 V DC 230 V AC Power Optocouplers Supply Module 60 V DC 100 mA 240 V AC 1A 2 x 24 V DC 2 x 250 mA 48 V DC 240 V AC 24 V DC 48 V DC 240 V AC 24 V DC 100 mA 1A 2A 100 mA 1A 2A 0.5 A 5 V DC 12 V DC 24 V DC 5 V DC 10 V ... 30 V AC/DC S0 current meter interface passive S0 current meter interfaces 3.5 A 5A 100 mA 230 V AC 24 V DC 5 V DC 15 V DC 24 V DC 24 V DC programmable (L or H) 5 V DC 15 V DC 24 V DC 24 V DC 0.5 A 110 V DC 1.6 A 5 V DC 15 V DC 0.5 A 24 V DC 110 V DC 5 V DC 15 V DC 24 V DC AC Output DC Output 2A 3A 5A 1.6 A 60 Item No. Page 788-700 788-701 78 78 56 39 857-714 58 788-720 857-707 857-717 857-727 857-708 857-718 857-728 859-902 859-752 859-756 45 46 859-758 46 859-772 859-702 43 44 859-706 45 859-708 44 859-720 41 859-712 79 56 58 60 57 59 61 47 0.5 A 1 mA ... 500 mA 857-724 857-704 859-791 1A 0,5 A Page 286 Series 286-791 286-794 3A Item No. 788 Series Page 2A 24 V DC 857 Series Item No. 100 mA Item No. 43 0 23 286 Series 289 Series Special Functions 289 / 789 Series 286 Series Function Item No. NAMUR Switching Amplifiers Current Flow Monitoring Modules Switching Module with relay output 250 V AC /120 V DC with transistor output 24 V DC AC/DC 15 mA DC/35 mA ... 300 mA AC AC 80 mA ... 6 A AC 0.2 A ... 3 A AC 1 A ... 10 A DC 0.4 A ... 1.5 A 1-pole changeover Hand-0-Automatik Umschalter 230 V / 1 A AC 230 V / 1 A AC Bridge Rectifiers 24 V / 1 A AC Operating voltage 24 V AC/DC Fuse Module for replaceable microfuses 5 x 20 mm Operating voltage 230 V AC/DC common anode Diode Gate Modules common cathode Polarized Diode Gate Open Diode Gate common anode common cathode with 8 diodes, individual connection possible AND Gate Module Flip-Flop Module LED Indicator Module with 9 diodes, individual connection possible with 6 inputs, relay output with 1 make contact Operating voltage 24 V DC with 8 LEDs LED Gate Module with 16 LEDs Lamp Test Circuit Open Resistor Gate Resistor Gate with 20 diodes for testing 10 lamps with 8 resistors, individual connection possible with 1 end commoned, 8 resistors Auxiliary and fault indication voltage 230 V AC 60 V DC 24 V DC Fault Indicator Modules, with reset Connection Modules for sensors and actuators 8 x 3-conductor sensors 8 actuators Page Optocoupler Transformer 1 changeover contact 1 changeover contact 1 make contact with changeover rocker switch with momentary switch 789-323 common cathode common anode common cathode 289-121 289-111 289-101 289-103 289-105 289-202 289-201 289-151 289-114 289-113 with ground (earth) contact 289-664 289-665 289-666 289-667 289-671 126 126 128 128 129 129 129 127 127 280-804/281-419 286-840 286-830 286-890 286-891 286-803 286-805 286-807 286-809 286-813 286-815 286-817 286-819 131 130 130 132 132 133 133 133 133 133 133 133 133 286-826 286-825 286-822 134 135 134 286-681 286-684 286-683 136 136 137 188 188 186 186 187 189 189 189 190 190 Alarm with continuous light Alarm with continuous light Indication of original fault with single flashing light LED indicator for positive switching LED indicator for negative switching Page 145 with varistor protection Blown fuse indication, LED green Blown fuse indication, neon lamp 3 diodes 5 diodes 7 diodes 9 diodes 3 diodes 5 diodes 7 diodes 9 diodes 14 diodes 14 diodes Diode 1 N 4007 Diode P 600 B Diode 1 N 5408 Item No. 286-880 286-881 286-659 286-661 286-664 286-665 286-662 286-895 286-896 184 184 184 184 184 0 Overview: Transducers 24 857 Series JUMPFLEX®– Transducers Function Input Signal Output Signal (switchable in a calibrated way) (switchable in a calibrated way) 0 ... 20 mA, 4 ... 20 mA, 0 ... 5 V, 0 ... 10 V, 2 ... 10 V, 1 ... 5 V Isolation Amplifier Isolation Amplifier, Configurable with Digital Output 0 ... 20 mA, 4 ... 20 mA, 0 ... 5 V, 0 ... 10 V, 2 ... 10 V, 1 ... 5 V 0 ... 20 mA, 4 ... 20 mA, -10...+10 V, -20...+20 mA, 0...+30 V 0 ... 10 V, 2 ... 10 V, 0... 5 V, 1 ... 5 V, (31,2 V (VIN) 100 mA (IIN) 0 ... 10 mA, 2 ... 10 mA Configuration Electrical Isolation Supply Voltage VN Item No. Page DIP switch 3 ways, 2.5 kV 24 V DC 857-400 194 DIP switch or configuration software 3 ways, 2.5 kV 24 V DC 857-401 196 Bipolar Isolation Amplifier ± 5 V, 0 ... 5 V, 1 ... 5 V, ± 10 V, 0 ... 10 V,2 ... 10 V, ± 10 mA, 0 ... 10 mA, 2 ... 10 mA, ± 20 mA, 0 ... 20 mA, 4 ... 20 mA ± 5 V, 0 ... 5 V, 1 ... 5 V, ± 10 V, 0 ... 10 V,2 ... 10 V, ± 10 mA, 0 ... 10 mA, 2 ... 10 mA, ± 20 mA, 0 ... 20 mA, 4 ... 20 mA DIP switch 3 ways, 2.5 kV 24 V DC 857-409 198 Isolation Amplifier Fixed (Current) 0(4) ... 20 mA 0(4) ... 20 mA _ 3 ways, 2.5 kV 24 V DC 857-411 200 Isolation Amplifier Fixed (Voltage) 0(2) ... 10 V 0(2) ... 10 V _ 3 ways, 2.5 kV 24 V DC 857-412 200 Passive Isolator 1-Channel 0(4) ... 20 mA 0(4) ... 20 mA _ 2 ways, 2.5 kV 24 V DC 857-451 201 Passive Isolator 2-Channel 0(4) ... 20 mA 0(4) ... 20 mA _ 2 ways, 2.5 kV 24 V DC 857-452 201 Repeater Power Supply 0 ... 20 mA, 4 ... 20 mA 0 ... 20 mA, 4 ... 20 mA, 0 ... 5 V, 0 ... 10 V, 2 ... 10 V, 1 ... 5 V DIP switch 3 ways, 2.5 kV 24 V DC 857-420 202 Repeater Power Supply HART 4 ... 20 mA 4 ... 20 mA _ 3 ways, 2.5 kV 24 V DC 857-421 204 0 ... 20 mA, 4 ... 20 mA, 0 ... 5 V, 0 ... 10 V, 2 ... 10 V, 1 ... 5 V 2 x 0(4) ... 20 mA DIP switch 4 ways, 2.5 kV 24 V DC 857-423 206 Signal Splitter Millivolt Transducer -100 mV ... +100 mV, 0 ... 20 mA, 4 ... 20 mA, 0 mV ... 200 mV bis 0 mV ... 1000 mV 0 ... 10 V, 2 ... 10 V, 0... 5 V, 1 ... 5 V, (in steps of 100) 0 ... 10 mA, 2 ... 10 mA DIP switch or configuration software 3 ways, 2.5 kV 24 V DC 857-819 216 Threshold Value Switch -10...+10 V, -20...+20 mA, 0...+30 V 1 changeover contact (relay max. 6A) 1 digital switching output (31,2 V (VIN) 100 mA (IIN) DIP switch, teach-in, configuration software 4 ways, 2.5 kV 24 V DC 857-531 218 786 Series Signal Conditioning Modules Function Input Output 0 … 10 V 0 … 10 V 0 … 20 mA 4 … 20 mA 0 … 10 V Signal Conditioning Modules for Standard Signals 0 … 20 mA 0 … 20 mA 4 … 20 mA 0 … 10 V 4 … 20 mA 0 … 20 mA 4 … 20 mA Electrical Isolation 2 ways, 4 kV 3 ways, 4 kV 2 ways, 4 kV 3 ways, 4 kV 2 ways, 4 kV 3 ways, 4 kV 2 ways, 4 kV 3 ways, 4 kV 2 ways, 4 kV 3 ways, 4 kV 2 ways, 4 kV 3 ways, 4 kV 2 ways, 4 kV 3 ways, 4 kV 2 ways, 4 kV 3 ways, 4 kV 2 ways, 4 kV 3 ways, 4 kV Supply Voltage VN 24 V DC 24 V DC 24 V DC Item No. Page 786-301 786-321 786-302 786-322 786-303 786-323 786-304 786-324 786-305 786-325 786-306 786-326 786-307 786-337 786-308 786-338 786-309 786-339 230 230 230 230 230 230 231 232 231 232 231 232 231 232 231 232 231 232 0 25 857 Series JUMPFLEX®– Temperature Transducers for RTD and Thermocouples Function Input Signal Temperature Transducers for RTD Pt 100, Pt 200, Pt 500, Pt 1000 0 …1 kΩ, 0 …4.5 kΩ Temperature Transducers for RTD Pt 100, Pt 200, Pt 500, Pt 1000 0 …1 kΩ, 0 …4.5 kΩ Temperature Transducers for Thermocouples Temperature Transducers for Thermocouples Thermocouples of types J and K Thermocouples of types J and K Connection Output Signal 0 ... 20 mA, 4 ... 20 mA, 2 wire, 3 wire, 4 wire 0 ... 10 V, 2 ... 10 V, 0 ... 5 V, 1 ... 5 V, 0 ... 10 mA, 2 ... 10 mA 0 ... 20 mA, 4 ... 20 mA, 2 wire, 3 wire, 4 wire 0 ... 10 V, 2 ... 10 V, 0 ... 5 V, 1 ... 5 V, 0 ... 10 mA, 2 ... 10 mA 0 ... 20 mA, 4 ... 20 mA, 0 ... 10 V, 2 ... 10 V, 0 ... 5 V, 1 ... 5 V, 0 ... 10 mA, 2 ... 10 mA 0 ... 20 mA, 4 ... 20 mA, 0 ... 10 V, 2 ... 10 V, 0 ... 5 V, 1 ... 5 V, 0 ... 10 mA, 2 ... 10 mA Electrical Isolation Configuration Supply Voltage VN Item No. Page Dip switch 3 ways, 2.5 kV 24 V DC 857-800 208 Dip switch or configuration Software 3 ways, 2.5 kV 24 V DC 857-801 210 Dip switch 3 ways, 2.5 kV 24 V DC 857-810 212 Dip switch or configuration Software 3 ways, 2.5 kV 24 V DC 857-811 214 286 Series Temperature Transducers Function Input Temperature Range 0 °C ... 100 °C Pt 100 -30 °C ... +150 °C Temperature Transducers 0 °C ... 300 °C Pt 1000 0 °C ... 100 °C Thermocouple Typ J 0 °C ... 750 °C Thermocouple Typ K 0 °C ... 1000 °C Connection 2 3 2 3 2 3 2 3 2 3 2 3 2 3 2 3 2 3 wire wire wire wire wire wire wire wire wire wire wire wire wire wire wire wire wire wire 2 wire Output Electrical Isolation Supply Voltage VN 0 … 10 V 0 … 20 mA — 24 V DC — 24 V DC — 24 V DC — 24 V DC — 24 V DC — 24 V DC 4 … 20 mA 0 … 10 V 0 … 20 mA 4 … 20 mA 0 … 10 V 0 … 20 mA 4 … 20 mA 0 … 10 V 0 … 20 mA 4 … 20 mA 0 … 10 V 0 … 20 mA 4 … 20 mA 0 … 10 V 0 … 20 mA 4 … 20 mA Item No. Page 286-860 286-870 286-861 286-871 286-862 286-872 286-860/150--030 286-870/150--030 286-861/150--030 286-871/150--030 286-862/150--030 286-872/150--030 286-860/000-300 286-870/000-300 286-861/000-300 286-871/000-300 286-862/000-300 286-872/000-300 286-873 286-874 286-875 286-863 286-865 286-867 286-864 286-866 286-868 224 224 224 224 224 224 226 226 226 226 226 226 227 227 227 227 227 227 228 228 228 225 225 225 225 225 225 0 *OTUBMMBUJPO/PUFT 26 859 Series Relay Modules and Optocoupler Modules 857 Series JUMPFLEX®– Transducers / Relay and Optocoupler Modules $POOFDUJPOPGDPOEVDUPS $POOFDUJPOPGDPOEVDUPS 0QFSBUJPOPGUIFSFMBZFKFDUPS &BTZDPNNPOJOHVTJOH BEKBDFOUKVNQFST &BTZDPNNPOJOHVTJOH BEKBDFOUKVNQFST Configuration of the Transducers with WAGO-USB-Service-Cable 750-923 .BSLJOHVTJOH.JOJBUVSFRVJDL NBSLJOHDBSE .BSLJOHVTJOH8.#.VMUJNBSLFST 0 27 788 Series Sockets for Miniature Switching Relay / Optocoupler 858 Series Sockets with Industrial Relay Connection of conductor &BTZDPNNPOJOHVTJOH BEKBDFOUKVNQFST &BTZDPNNPOJOHVTJOH BEKBDFOUKVNQFST Remove jumper with screwdriver .BSLJOHVTJOH8.#.VMUJNBSLFSTBOE HSPVQNBSLFSDBSSJFST 0 *OTUBMMBUJPO/PUFT 28 287 / 288 Series Mounting Carriers with Miniature Switching Relay 286 / 786 Series Pluggable Function Modules 789 Series Relay Modules in DIN-Rail Mounted Enclosure $POOFDUJPOPGDPOEVDUPS nGSPOUFOUSZo $PEJOHFOTVSFTDPSSFDUQPMBSJUZ Connection of conductor $POOFDUJPOPGDPOEVDUPS nTJEFFOUSZo 1MVHHBCMFFMFDUSPOJDNPEVMFT GPS BQQMJDBUJPOPOPSDPOEVDUPS DBSSJFSUFSNJOBMCMPDLT &BTZDPNNPOJOHVTJOH BEKBDFOUKVNQFST "TTFNCMZPGBNPEVMFPOUIF DBSSJFSSBJM .BSLJOHVTJOH8.#.VMUJNBSLFST .BSLJOHVTJOH.JOJBUVSFRVJDLNBSLJOH DBSE 3FNPWBMPGBNPEVMFGSPNUIF DBSSJFSSBJM &BTZUFTUJOHBUUPVDIQSPPGDPOUBDUT 0 29 289 Series Interface Modules 289 Series Interface Modules 289 Series Interface Modules Mounting carrier, gray, snap-fit mounting of universal mounting feet $POOFDUJPOPGDPOEVDUPS nGSPOUFOUSZo "TTFNCMZPGBNPEVMFPOUIF DBSSJFSSBJM Fitting of an individual module to the mounting carrier $POOFDUJPOPGDPOEVDUPS nTJEFFOUSZo 3FNPWBMPGBNPEVMFGSPNUIF DBSSJFSSBJM Removal of an individual module from the mounting carrier 1 30 WAGO Application: Cerestar (Cargill GmbH), Barby, Saxony-Anhalt, Germany Manufacturer of starches and starch derivatives. WAGO Products: Matrix Patchboards and Pluggable Electronic Modules 1 Relays – Optocouplers – Special Functions 31 1 859 Series Rail-Mounted Terminal Blocks with Miniature Switching Relay Rail-Mounted Terminal Blocks with Optocoupler Rail-Mounted Terminal Blocks with Miniature Switching Relays and Optocouplers with an Extended Input Voltage and Operating Temperature Range Accessories, 859 Series 32 – 38 39 – 47 48 49 857 Series JUMPFLEX® Relay Socket with Miniature Switching Relay Miniature Switching Relays, Sockets, JUMPFLEX® 8-Channel Adapters for System Wiring JUMPFLEX® Relay Socket with Solid State Relay Solid State Relays Accessories, 857 Series 50 – 51 52 – 55 56 – 61 62 63 788 Series Sockets with Miniature Switching Relay Miniature Switching Relays, Sockets Sockets with Solid State Relay Accessories, 788 Series 64 – 73 74 – 77 78 – 79 80 – 81 858 Series Sockets with Industrial Relay Industrial Relays, Sockets Accessories, 858 Series 82 – 83 84 – 85 86 287/288 Series Mounting Carriers with Miniature Switching Relay 88 – 99 286 Series Pluggable Modules – Relays, Time Relays, Optocouplers, S0 Optocouplers, S0 Supply Module, NAMUR Switching Amplifiers, Current Flow Monitoring, Switches, Bridge Rectifiers, Fuses, Diode Gates, AND Gate and LED Indicator, Flip-Flop, Fault Indication, Surge Suppression Devices 100 – 139 789 Series Relay Modules in DIN-Rail Mounted Enclosure Accessories, Series 789 4-Channel EnOcean Radio Receiver in DIN-Rail-Mountable Enclosure Manual Control Modules 140 – 145 146 148 149 1 1 Rail-Mounted Terminal Blocks with Miniature Switching Relay 32 Relay with 1 changeover contact (1u) for normal switching power Nominal input voltage VN 5 V, 12 V, 24 V, 48 V, 60 V, 110 V, 220 V DC Relay with 1 changeover contact (1u) for normal switching power Nominal input voltage VN 12 V, 24 V, 48 V, 115 V, 230 V AC/DC 14 14 A2 – A2 11 Note: Inductive loads have to be attenuated by an appropriate protective circuit in order to protect relay coils and contacts. 11 A1 A1 + 12 12 Description VN IN Item No. Pack. Unit Rail-mounted terminal blocks with miniature switching relay, for DIN 35 rail 5 V DC 12 V DC 24 V DC 48 V DC 60 V DC 120 V DC 220 V DC 31 mA 17 mA 10 mA 6.5 mA 5.2 mA 3.5 mA 3.2 mA 859-302 859-303 859-304 859-305 859-306 859-307 859-308 1 1 1 1 1 1 1 Technical Data Contact material Input voltage range Max. switching voltage Max. continuous current (terminal blocks in a row) Max. Switching power (resistive) Recommended minimum load Max. switching rate with / without load Operating power Pull-in/drop-out/bounce time typ. Nominal operating mode Dielectric strength contact-coil Dielectric strength contact-coil (1.2/50 μs) Surge capacity open contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature (VN) Ambient operating temperature (1.2 x VN) Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals VN IN Item No. Pack. Unit 12 V AC/DC 24 V AC/DC 48 V AC/DC 115 V AC/DC 230 V AC/DC 15 mA 8 mA 5.3 mA 3.5 mA 3.5 mA 859-353 859-354 859-355 859-357 859-358 1 1 1 1 1 Accessories see page 49 Accessories see page 49 AgSnO2 VN -15 % ... +10 % 250 V AC 5A 1250 VA AC ; DC see load limit curve  100 mA / 12 V AC/DC 6 min-1 / 20 s-1 < 320 mW 5 ms / 6 ms / 5 ms continuous duty 4 kV 6 kV 1 kV 250 V / 4 kV / 3 AgSnO2 VN -15 % ... +10 % 250 V AC 5A 1250 VA AC ; DC see load limit curve  100 mA / 12 V AC/DC 6 min-1 / 20 s-1 < 300 mW 5 ms / 6 ms / 5 ms continuous duty 4 kV 6 kV 1 kV 250 V / 4 kV / 3 5 x 106 switching operations 3 x 105 switching operations -25 °C ... +50 °C -25 °C ... +40 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; UL 508; EEx nC II T4 / DEMKO 02 ATEX 132280U; g 5 x 106 switching operations 3 x 104 switching operations -25 °C ... +50 °C -25 °C ... +40 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; UL 508; EEx nC II T4 / DEMKO 02 ATEX 132280U; g 1 33 Relay with 1 changeover contact (1u) Contacts 5 μm Au hard gold plated for normal switching power Nominal input voltage VN 24 V DC Relay with 1 changeover contact (1u) Contacts 5 μm Au hard gold plated with an extended Input voltage range: VN -30 % ... +25 % Operating temperature range: -25 °C ... +70 °C for normal switching power Nominal input voltage VN 115 V DC 56 mm/2.2 in 1 91 mm/3.58 in 14 14 A2 – * In order to prevent the gold layer from being damaged these values should not be exceeded. Higher switching power leads to evaporation of the gold layer. The resulting deposits in the enclosure may cause sparkovers between the coil and the contact. A2 – 11 A1 + 11 A1 + 12 12 Description VN IN Item No. Pack. Unit VN IN Item No. Pack. Unit Rail-mounted terminal blocks with miniature switching relay, for DIN 35 rail 24 V DC 10 mA 859-314 1 115 V DC 3.1 mA 859-317 1 Technical Data Contact material Input voltage range Max. switching voltage Max. continuous current (terminal blocks in a row) Recommended minimum load Max. switching rate with / without load Operating power Pull-in/drop-out/bounce time typ. Nominal operating mode Dielectric strength contact-coil Dielectric strength contact-coil (1.2/50 μs) Surge capacity open contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature (VN) Ambient operating temperature (1.2 x VN) Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 49 Accessories see page 49 AgSnO2 + 5 μm Au VN -15 % ... +20 % 36 V DC * 50 mA * 10 μA / 100 mV 6 min-1 / 20 s-1 < 320 mW 5 ms / 6 ms / 5 ms continuous duty 4 kV 6 kV 1 kV 250 V / 4 kV / 3 AgSnO2 + 5 μm Au VN -30 % ... +25 % 36 V DC * 50 mA * 10 μA / 100 mV 6 min-1 / 20 s-1 < 320 mW 5 ms / 6 ms / 5 ms continuous duty 4 kV 6 kV 1 kV 250 V / 4 kV / 3 5 x 106 switching operations 5 x 106 switching operations -25 °C ... +50 °C -25 °C ... +40 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; UL 508; EEx nC II T4 / DEMKO 02 ATEX 132280U; g 5 x 106 switching operations 5 x 106 switching operations -25 °C ... +70 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; UL 508; EEx nC II T4 / DEMKO 02 ATEX 132280U; g 1 Rail-Mounted Terminal Blocks with Miniature Switching Relay 34 Relay with 1 changeover contact (1u) Contacts 5 μm Au hard gold plated for normal switching power Nominal input voltage VN 230 V AC 56 mm/2.2 in Relay with 1 changeover contact (1u) Contacts 5 μm Au hard gold plated for normal switching power Nominal input voltage VN 115 V AC 91 mm/3.58 in 14 * In order to prevent the gold layer from being damaged these values should not be exceeded. Higher switching power leads to evaporation of the gold layer. The resulting deposits in the enclosure may cause sparkovers between the coil and the contact. A2 ~ 14 A2 ~ 11 A1 ~ 11 A1 ~ 12 12 Description VN IN Item No. Pack. Unit VN IN Item No. Pack. Unit Rail-mounted terminal blocks with miniature switching relay, for DIN 35 rail 230 V AC 3.5 mA 859-359 1 115 V AC 3.1 mA 859-360 1 Technical Data Contact material Input voltage range Max. switching voltage Max. continuous current (terminal blocks in a row) Recommended minimum load Max. switching rate with / without load Operating power Pull-in/drop-out/bounce time typ. Nominal operating mode Dielectric strength contact-coil Dielectric strength contact-coil (1.2/50 μs) Surge capacity open contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature (VN) Ambient operating temperature (1.2 x VN) Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 49 Accessories see page 49 AgSnO2 + 5 μm Au VN -15 % ... +10 % 36 V DC * 50 mA * 10 μA / 100 mV 6 min-1 / 20 s-1 < 820 mW 5 ms / 6 ms / 5 ms continuous duty 4 kV 6 kV 1 kV 250 V / 4 kV / 3 AgSnO2 + 5 μm Au VN -15 % ... +20 % 36 V DC * 50 mA * 10 μA / 100 mV 6 min-1 / 20 s-1 < 370 mW 5 ms / 6 ms / 5 ms continuous duty 4 kV 6 kV 1 kV 250 V / 4 kV / 3 5 x 106 switching operations 5 x 106 switching operations -25 °C ... +50 °C -25 °C ... +40 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; UL 508; EEx nC II T4 / DEMKO 02 ATEX 132280U; g 5 x 106 switching operations 5 x 106 switching operations -25 °C ... +50 °C -25 °C ... +40 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; UL 508; EEx nC II T4 / DEMKO 02 ATEX 132280U; g 1 35 Relay with 1 changeover contact (1u) Contacts 5 μm Au hard gold plated for low switching power Nominal input voltage VN 220 V DC Relay with 1 changeover contact (1u) for normal switching power Nominal input voltage VN 115 V AC 1 * In order to prevent the gold layer from being damaged these values should not be exceeded. Higher switching power leads to evaporation of the gold layer. The resulting deposits in the endosure may cause sparkover between the coil and the contact. Description VN IN Item No. Pack. Unit VN IN Item No. Pack. Unit Rail-mounted terminal blocks with miniature switching relay, for DIN 35 rail 220 V DC 3.2 mA 859-318 1 115 V AC 4.2 mA 859-367 1 Technical Data Contact material Input voltage range Turn-on threshold relay/LED Turn-off threshold relay/LED Max. switching voltage Max. continuous current (terminal blocks in a row) Max. Switching power (resistive) Recommended minimum load Max. switching rate with / without load Operating power Pull-in/drop-out/bounce time typ. Nominal operating mode Dielectric strength contact-coil Dielectric strength contact-coil (1.2/50 μs) Surge capacity open contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature (VN) Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 49 Accessories see page 49 AgSnO2 + 5 μm Au VN -15 % ... +20 % AgSnO2 VN ± 10 % 95 V AC/ 80 V AC 60 V AC/60 V AC 250 V AC 5A 1250 VA AC ; DC see load limit curve  100 mA / 12 V AC/DC 6 min-1 / 20 s-1 < 820 mW 5 ms / 6 ms / 5 ms continuous duty 4 kV 6 kV 1 kV 250 V / 4 kV / 3 36 V DC * 50 mA * 50 mW 6 min-1 / 20 s-1 < 750 mW 5 ms / 6 ms / 5 ms continuous duty 4 kV 6 kV 1 kV 250 V / 4 kV / 3 5 x 106 switching operations 5 x 106 switching operations -25 °C ... +50 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0435 (corresp. parts); DIN EN 61810; DIN VDE 0140, DIN EN 61140 E175199, UL 508; g 5 x 106 switching operations 3 x 104 switching operation -25 °C ... +50 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in DIN VDE 0160, DIN EN 50178; VDE 0435 (corresp. parts); DIN EN 61810; VDE 0140, DIN EN 61140; g 1 Rail-Mounted Terminal Blocks with Miniature Switching Relay 36 Relay with 1 changeover contact (1u) defined turn-on/turn-off threshold for normal switching power Nominal input voltage VN 230 V AC Relay with 1 changeover contact (1u) with an extended Input voltage range: VN -30 % ... +25 % Operating temperature range: -25 °C ... +70 °C for normal switching power Nominal input voltage VN 24 V DC 14 14 Note: Inductive loads have to be attenuated by an appropriate protective circuit in order to protect relay coils and contacts. A2 – A2 ~ 11 A1 ~ 12 11 A1 + 12 Description VN IN Item No. Pack. Unit VN IN Item No. Pack. Unit Rail-mounted terminal blocks with miniature switching relay, for DIN 35 rail 230 V AC 4.2 mA 859-368 1 24 V DC 12 mA 859-390 1 Technical Data Contact material Input voltage range Turn-on threshold relay/LED Turn-off threshold relay/LED Max. switching voltage Max. continuous current (terminal blocks in a row) Max. Switching power (resistive) Recommended minimum load Max. switching rate with / without load Operating power Pull-in/drop-out/bounce time typ. Nominal operating mode Dielectric strength contact-coil Dielectric strength contact-coil (1.2/50 μs) Surge capacity open contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature (VN) Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 49 Accessories see page 49 AgSnO2 VN ± 10 % 190 V AC / 165 V AC 140 V AC / 150 V AC 250 V AC 5A 1250 VA AC ; DC see load limit curve  100 mA / 12 V AC/DC 6 min-1 / 20 s-1 < 820 mW 5 ms / 6 ms / 5 ms continuous duty 4 kV 6 kV 1 kV 250 V / 4 kV / 3 AgSnO2 VN -30 % ... +25 % 250 V AC 3A 750 VA AC ; DC see load limit curve  100 mA / 15 V AC/DC 6 min-1 / 20 s-1 < 320 mW 5 ms / 6 ms / 5 ms continuous duty 4 kV 6 kV 1 kV 250 V / 4 kV / 3 5 x 106 switching operations 3 x 104 switching operation -25 °C ... +50 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; UL 508; EEx nC II T4 / DEMKO 02 ATEX 132280U; g 5 x 106 switching operations 3 x 105 switching operation -25 °C ... +70 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; UL 508; EEx nC II T4 / DEMKO 02 ATEX 132280U; g 1 37 Relay with 1 changeover contact (1u) with an extended Input voltage range: VN ±30 % Operating temperature range: -25 °C ... +70 °C for normal switching power Nominal input voltage VN 110 V DC Relay with 1 changeover contact (1u) with an extended Input voltage range: VN ±40 % Operating temperature range: -25 °C ... +70 °C for normal switching power Nominal input voltage VN 24 V DC 1 14 A2 – 11 NOTE: Inductive loads have to be attenuated by an appropriate protective circuit in order to protect relay coils and contacts. A1 + 12 Description VN IN Item No. Pack. Unit VN IN Item No. Pack. Unit Rail-mounted terminal blocks with miniature switching relay, for DIN 35 rail 110 V DC 2.7 mA 859-391 1 24 V DC 14.4 mA 859-398 1 Technical Data Contact material Input voltage range Max. switching voltage Max. continuous current (terminal blocks in a row) Max. Switching power (resistive) Recommended minimum load Max. switching rate with / without load Operating power Pull-in/drop-out/bounce time typ. Nominal operating mode Dielectric strength contact-coil Dielectric strength contact-coil (1.2/50 μs) Surge capacity open contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature (VN) Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 49 Accessories see page 49 AgSnO2 VN ± 30 % 250 V AC 3A 750 VA AC ; DC see load limit curve  100 mA / 15 V AC/DC 6 min-1 / 20 s-1 < 370 mW 5 ms / 6 ms / 5 ms continuous duty 4 kV 6 kV 1 kV 250 V / 4 kV / 3 AgSnO2 VN ± 40 % 250 V AC 3A 750 VA AC ; DC see load limit curve  100 mA / 12 V AC/DC 6 min-1 / 20 s-1 < 400 mW 5 ms / 6 ms / 5 ms continuous duty 4 kV 6 kV 1 kV 250 V / 4 kV / 3 5 x 106 switching operations 3 x 104 switching operation -25 °C ... +70 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; UL 508; EEx nC II T4 / DEMKO 02 ATEX 132280U; g 1 x 107switching operations 3 x 104 switching operation -25 °C ... +70 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in DIN VDE 0160 and IEC 60255; VDE 0435 (corresp. parts); DIN VDE 0140, DIN EN 61140; DIN VDE 0115 Part 200; DIN EN 50155; g 1 Rail-Mounted Terminal Blocks with Miniature Switching Relay 38 56 mm/2.2 in Relay with 1 changeover contact (1u) Contacts 5 μm Au hard gold plated with an extended Input voltage range: VN -30 % ... +25 % Operating temperature range: -25 °C ... +70 °C for normal switching power Nominal input voltage VN 24 V DC 91 mm/3.58 in 14 A2 – * In order to prevent the gold layer from being damaged these values should not be exceeded. Higher switching power leads to evaporation of the gold layer. The resulting deposits in the enclosure may cause sparkovers between the coil and the contact. 11 A1 + 12 Description VN IN Item No. Pack. Unit Rail-mounted terminal blocks with miniature switching relay, for DIN 35 rail 24 V DC 10 mA 859-392 1 Technical Data Contact material Input voltage range Max. switching voltage Max. continuous current (terminal blocks in a row) Recommended minimum load Max. switching rate with / without load Operating power Pull-in/drop-out/bounce time typ. Nominal operating mode Dielectric strength contact-coil Dielectric strength contact-coil (1.2/50 μs) Surge capacity open contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature (VN) Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 49 AgSnO2 + 5 μm Au VN -30 % ... +25 % 36 V DC * 50 mA * 10 μA / 100 mV 6 min-1 / 20 s-1 < 320 mW 5 ms / 6 ms / 5 ms continuous duty 4 kV 6 kV 1 kV 250 V / 4 kV / 3 5 x 106 switching operations 2 x 107switching operations -25 °C ... +70 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; VDE 0115 Part 200 / EN 50155; UL 508; EEx nC II T4 / DEMKO 02 ATEX 132280U; g 1 Rail-Mounted Terminal Blocks with Optocoupler 39 Optocoupler Input: 5 V DC Output: 60 V DC/100 mA with an extended output voltage and operating temperature range for use in railway traffic Optocoupler Input: 24 V DC Output: 60 V DC/100 mA with an extended output voltage and operating temperature range for use in railway traffic 56 mm/2.2 in 1 91 mm/3.58 in 1 + A1 + 1 + A1 + RL 2 – A2 – RL 2 – A2 – Description VN Item No. Pack. Unit VN Item No. Pack. Unit Rail-mounted terminal blocks with optocoupler, for DIN 35 rail 5 V DC 859-793 1 24 V DC 859-791 1 Technical Data Nominal input voltage (VN) Input voltage range low level Input voltage range high level Input current range Current at nominal voltage Output nominal voltage Output voltage range Max. continuous current (20°C) Max. continuous current (70°C) Reverse voltage transistor Switch on /switch off time Max. operating frequency Leakage current at nominal voltage Voltage drop at output Test voltage input / output Nominal operating mode Ambient operating temperature Max. operating temperature with reduced current Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 49 Accessories see page 49 5 V DC 0 V ... 0.8 V DC 2 V ... 6.25 V DC 1.3 mA ... 10 mA DC 7.5 mA DC 24 V DC 3 V ... 60 V DC 100 mA 50 mA 100 V 20 μs / 120 μs 1.5 kHz 25 μA  2.5 V 2.5 kV eff. continuous duty -25 °C ... +40 °C +70 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; VDE 0115 Part 200 / EN 50155; UL 508; EEx nA II T4 / DEMKO 02 ATEX 132280U 24 V DC 0 V ... 5 V DC 16 V ... 30 V DC 2 mA ... 5.5 mA DC 4 mA DC 24 V DC 7 V ... 60 V DC 100 mA 50 mA 100 V 20 μs / 120 μs 3 kHz 30 μA  1.5 V 4 kV eff. continuous duty -25 °C ... +40 °C +70 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; VDE 0115 Part 200 / EN 50155; UL 508; EEx nA II T4 / DEMKO 02 ATEX 132280U 1 Rail-Mounted Terminal Blocks with Optocoupler 40 Optocoupler Input: 24 V DC Output: 24 V DC/100 mA 56 mm/2.2 in Optocoupler Input: 5 V DC Output: 24 V DC/100 mA 91 mm/3.58 in 1 + A1 + 1 + A1 + RL RL 2 – A2 – 2 – A2 – Description VN Item No. Pack. Unit VN Item No. Pack. Unit Rail-mounted terminal blocks with optocoupler, for DIN 35 rail 24 V DC 859-796 1 5 V DC 859-795 1 Technical Data Nominal input voltage (VN) Input voltage range low level Input voltage range high level Input current range Current at nominal voltage Output nominal voltage Output voltage range Max. continuous current (20°C) Max. continuous current (70°C) Reverse voltage transistor Switch on /switch off time Max. operating frequency Leakage current at nominal voltage Voltage drop at output Test voltage input / output Nominal operating mode Ambient operating temperature Max. operating temperature with reduced current Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 49 Accessories see page 49 24 V DC 0 V ... 5 V DC 18 V ... 30 V DC 3.8 mA ... 12.5 mA DC 9.2 mA DC 24 V DC 3 V ... 30 V DC 100 mA 50 mA 65 V 10 μs / 50 μs 10 kHz 25 μA 1V 2.5 kV eff. continuous duty -25 °C ... +40 °C +70 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; UL 508; EEx nA II T4 / DEMKO 02 ATEX 132280U 5 V DC 0 V ... 0.8 V DC 2 V ... 6.25 V DC 3.8 mA ... 23 mA DC 17.5 mA DC 24 V DC 3 V ... 30 V DC 100 mA 50 mA 65 V 10 μs / 50 μs 10 kHz 25 μA 1V 2.5 kV eff. continuous duty -25 °C ... +40 °C +70 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; UL 508; EEx nA II T4 / DEMKO 02 ATEX 132280U 1 41 Optocoupler Input: 24 V DC Output: 24 V DC/100 mA Optocoupler Input: 24 V DC Output: 24 V DC/3 A Negative switching 56 mm/2.2 in 1 91 mm/3.58 in 24V A1 + 1 + A1 + RL RL A 2 – A2 – A2 – Description VN Item No. Pack. Unit Rail-mounted terminal blocks with optocoupler, for DIN 35 rail 24 V DC 859-794 1 Technical Data Nominal input voltage (VN) Input voltage range Input voltage range low level Input voltage range high level Input current range Current at nominal voltage Output nominal voltage Output voltage range Max. continuous current Max. continuous current (20°C) Max. continuous current (70°C) Peak output current Reverse voltage transistor Switch on /switch off time Max. operating frequency Switching frequency IL < 2 A / IL < 1 A / IL < 500 mA Leakage current at nominal voltage Collector / emitter voltage drop Vce sat Voltage drop at output Test voltage input / output Nominal operating mode Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals 0V VN Item No. Pack. Unit 24 V DC 859-720 1 Accessories see page 49 Accessories see page 49 24 V DC 24 V DC 16 V ... 30 V DC 0 V ... 5 V DC 16 V ... 30 V DC 2 mA ... 5.5 mA DC 4.2 mA DC 24 V DC 9 V ... 60 V DC 2.5 mA ... 5.5 mA DC 4 mA DC 24 V DC 10 V ... 30 V DC 3A 100 mA 50 mA 100 V 20 μs / 120 μs 1.5 kHz 25 μA 2V 2.5 kV eff. continuous duty -25 °C ... +40 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; UL 508; EEx nA II T4 / DEMKO 02 ATEX 132280U 20 A 55 V 25 μs / 75 μs f < 500 Hz f < 1 kHz / f < 2 kHz / f < 3 kHz < 25 μA  0.5 V 2.5 kV eff. continuous duty -25 °C ... +40 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; UL 508; EEx nA II T4 / DEMKO 02 ATEX 132280U 1 Rail-Mounted Terminal Blocks with Optocoupler 42 Optocoupler Input: 24 V DC Output: 24 V DC/3 A 56 mm/2.2 in Optocoupler Input: 24 V DC Output: 3V ... 30 V DC/3A 3 A power optocoupler 91 mm/3.58 in A1 + +A A2 – -2 RL Description VN Item No. Pack. Unit VN Item No. Pack. Unit Rail-mounted terminal blocks with optocoupler, for DIN 35 rail 24 V DC 859-730 1 24 V DC 859-740 1 Technical Data Nominal input voltage (VN) Input voltage range low level Input voltage range high level Current at nominal voltage Input wiring Output circuit Output nominal voltage Output voltage range Max. continuous current Peak output current Reverse voltage transistor Voltage drop Switch on /switch off time Switching frequency Test voltage input / output Nominal operating mode Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 49 Accessories see page 49 24 V DC 0 V ... 5 V DC 15 V ... 27 V DC 14 mA DC Status LED (red) 2-wire, isolated 24 V DC 3 V ... 30 V DC 3A 25 A 55 V < 0.4 V 25 μs / 450 μs f < 350 Hz 2.5 kV eff. continuous duty -25 °C ... +55 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; VDE 0435 / EN 61810-5; UL 508; EEx nA II T4 / DEMKO 02 ATEX 132280U 24 V DC 0 V ... 9 V DC 19 V ... 27 V DC 7 mA DC status indication LED (yellow), reverse voltage protection 2-wire, isolated, overvoltage protection 24 V DC 3 V ... 30 V DC 3A 25 A < 0.2 V 25 μs / 450 μs f < 350 Hz 2.5 kV eff. continuous duty -25 °C ... +55 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in IEC 60664 / IEC 60664A / DIN VDE 0110; degree of pollution 2, overvoltage category III 1 43 Optocoupler Input: 230 V DC Output: 24 V DC/0.5 A Negative switching 1 56 mm/2.2 in Optocoupler Input: 230 V AC Output: 24 V DC/0.5 A Positive switching increased input frequency up to 100 Hz Input voltage up to 270 V AC 91 mm/3.58 in 1 + A1 ~ 24 V 3 A2 ~ 0V A  A RL RL 859-772 • Increased input frequency up to 100 Hz • Input voltage up to 270 V AC A2 ~ Description VN Item No. Pack. Unit VN Item No. Pack. Unit Rail-mounted terminal blocks with optocoupler, for DIN 35 rail 230 V AC 859-772 1 230 V AC 859-712 1 Technical Data Nominal input voltage (VN) Input voltage range low level Input voltage range high level Input current range Current at nominal voltage Input wiring Output circuit Output nominal voltage Output voltage range Max. continuous current Reverse voltage transistor Switch on /switch off time Leakage current at nominal voltage Collector / emitter voltage drop Vce sat Max. output (reverse current) Test voltage input / output Nominal operating mode Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals 2 – 0V A1 ~ +24 V Accessories see page 49 Accessories see page 49 230 V AC/ 50 Hz ... 60 Hz 0 V ... 90 V AC 175 V ... 270 V AC 0.04 mA ... 0.7 mA 0.6 mA Varistor 300 V Protection diode, operation indicator 24 V DC 20 V ... 30 V DC 500 mA 80 V < 30 ms / < 30 ms 10 μA < 1.2 V 12 mA 2.5 kV eff. continuous duty -25 °C ... +55 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; UL 508; EEx nA II T4 / DEMKO 02 ATEX 132280U 230 V AC 0 V ... 90 V AC 175 V ... 250 V AC 0.4 mA ... 0.7 mA 0.6 mA Varistor 300 V Protection diode, operation indicator LED (red) 24 V DC 20 V ... 30 V DC 500 mA 80 V < 30 ms / < 30 ms 10 μA < 1.2 V 11 mA 2.5 kV eff. continuous duty -25 °C ... +55 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; UL 508; EEx nA II T4 / DEMKO 02 ATEX 132280U 1 Rail-Mounted Terminal Blocks with Optocoupler 44 Optocoupler Input: 5 V DC Output: 24 V DC/0.5A/25 kHz Negative switching 56 mm/2.2 in Optocoupler Input: 24 V DC Output: 24 V DC/0.5A/25 kHz Negative switching 91 mm/3.58 in A2 — 0V A2 — 0V  A  A RL A1 + RL +24 V A1 + +24 V Description VN Item No. Pack. Unit VN Item No. Pack. Unit Rail-mounted terminal blocks with optocoupler, for DIN 35 rail 5 V DC 859-702 1 24 V DC 859-708 1 Technical Data Nominal input voltage (VN) Input voltage range low level Input voltage range high level Input current range Current at nominal voltage Input wiring Output circuit Output nominal voltage Output voltage range Max. continuous current Reverse voltage transistor Switch on /switch off time Max. operating frequency Leakage current at nominal voltage Collector / emitter voltage drop Vce sat Max. output (reverse current) Test voltage input / output Nominal operating mode Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 49 Accessories see page 49 5 V DC 0 V ... 1 V DC 4 V ... 6.25 V DC 7 mA ... 13 mA 9.6 mA DC Reverse voltage protection Protection diode, operation indicator LED (red) 24 V DC 20 V ... 30 V DC 500 mA 80 V < 7 μs / < 15 μs 10 kHz < 10 μA < 1.2 V 11 mA 2.5 kV eff. continuous duty -25 °C ... +55 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; UL 508; EEx nA II T4 / DEMKO 02 ATEX 132280U 24 V DC 0 V ... 5 V DC 19 V ... 30 V DC 5.7 mA ... 10.2 mA 7.7 mA DC Reverse voltage protection Protection diode, operation indicator LED (red) 24 V DC 20 V ... 30 V DC 500 mA 80 V < 10 μs / < 10 μs 10 kHz < 10 μA < 1.2 V 11 mA 2.5 kV eff. continuous duty -25 °C ... +55 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; UL 508; EEx nA II T4 / DEMKO 02 ATEX 132280U 1 45 Optocoupler Input: 24 V DC Output: 5 V DC/0.5A/25 kHz Negative switching Optocoupler Input: 5 V DC Output: 24 V DC/0.5 A/10 kHz Positive switching 56 mm/2.2 in 1 91 mm/3.58 in A2 — 0V A2 — 0V RL  A RL A1 +  A +5 V A1 + +24 V Description VN Item No. Pack. Unit VN Item No. Pack. Unit Rail-mounted terminal blocks with optocoupler, for DIN 35 rail 24 V DC 859-706 1 5 V DC 859-752 1 Technical Data Nominal input voltage (VN) Input voltage range low level Input voltage range high level Input current range Current at nominal voltage Input wiring Output circuit Output nominal voltage Output voltage range Max. continuous current Reverse voltage transistor Switch on /switch off time Max. operating frequency Leakage current at nominal voltage Collector / emitter voltage drop Vce sat Max. output (reverse current) Test voltage input / output Nominal operating mode Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 49 Accessories see page 49 24 V DC 0 V ... 5 V DC 18 V ... 30 V DC 8 mA ... 14 mA 11 mA DC Reverse voltage protection Protection diode, operation indicator LED (red) 5 V DC 4 V ... 6.25 V DC 500 mA 80 V < 7 μs / < 15 μs 10 kHz < 10 μA < 1.2 V 7 mA 2.5 kV eff. continuous duty -25 °C ... +55 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; UL 508; EEx nA II T4 / DEMKO 02 ATEX 132280U 5 V DC 0 V ... 1 V DC 4 V ... 6 V DC 7 mA ... 13 mA 10 mA Reverse voltage protection Protection diode, operation indicator LED (red) 24 V DC 20 V ... 30 V DC 500 mA 80 V < 15 μs / < 30 μs 10 kHz < 10 μA < 1.2 V 12.5 mA 2.5 kV eff. continuous duty -25 °C ... +40 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; UL 508; EEx nA II T4 / DEMKO 02 ATEX 132280U 1 Rail-Mounted Terminal Blocks with Optocoupler 46 Optocoupler Input: 24 V DC Output: 24 V DC/0.5 A/10 kHz Positive switching 56 mm/2.2 in Optocoupler Input: 24 V DC Output: 5 V DC/0.5 A/10 kHz Positive switching 91 mm/3.58 in A2 — 0V A2 — 0V RL RL  A  A A1 + +24 V A1 + +5 V Description VN Item No. Pack. Unit VN Item No. Pack. Unit Rail-mounted terminal blocks with optocoupler, for DIN 35 rail 24 V DC 859-758 1 24 V DC 859-756 1 Technical Data Nominal input voltage (VN) Input voltage range low level Input voltage range high level Input current range Current at nominal voltage Input wiring Output circuit Output nominal voltage Output voltage range Max. continuous current Reverse voltage transistor Switch on /switch off time Max. operating frequency Leakage current at nominal voltage Collector / emitter voltage drop Vce sat Max. output (reverse current) Test voltage input / output Nominal operating mode Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 49 Accessories see page 49 24 V DC 0 V ... 5 V DC 18 V ... 30 V DC 5.5 mA ... 10.6 mA 8 mA Reverse voltage protection Protection diode, operation indicator LED (red) 24 V DC 20 V ... 30 V DC 500 mA 80 V < 15 μs / < 30 μs 10 kHz < 10 μA < 1.2 V 11 mA 2.5 kV eff. continuous duty -25 °C ... +40 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; UL 508; EEx nA II T4 / DEMKO 02 ATEX 132280U 24 V DC 0 V ... 5 V DC 18 V ... 30 V DC 8 mA ... 14.5 mA 11 mA Reverse voltage protection Protection diode, operation indicator LED (red) 5 V DC 4 V ... 6.25 V DC 500 mA 80 V < 15 μs / < 30 μs 10 kHz < 10 μA < 1.2 V 4.5 mA 2.5 kV eff. continuous duty -25 °C ... +40 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in VDE 0110 / EN 60664; UL 508; EEx nA II T4 / DEMKO 02 ATEX 132280U 1 47 Optocoupler Input: 5 V DC Output: 230 V AC/0.5 A 56 mm/2.2 in 1 91 mm/3.58 in Description VN Item No. Pack. Unit Rail-mounted terminal blocks with optocoupler, for DIN 35 rail 5 V DC 859-902 1 Technical Data Nominal input voltage (VN) Input voltage range low level Input voltage range high level Input current range Current at nominal voltage Input wiring Output circuit Output nominal voltage Output voltage range Max. continuous current (20°C) Surge current (t=20 ms) Min. load current Peak reverse voltage Triac Switch on /switch off time Leakage current at nominal voltage Voltage drop at output Test voltage input / output Nominal operating mode Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 49 5 V DC 0 V ... 1 V DC 4 V ... 6.25 V DC DC 5.6 mA ... 10.3 mA 7.7 mA DC Reverse voltage protection varistor /RC module 230 V AC 24 V ... 260 V AC (50 Hz ... 60 Hz) 500 mA 30 A 50 mA 600 V 10 ms / 10 ms (1 half-wave) < 1 mA 100 mA / 12 V AC/DC 4 kVA AC, DC see load limit curve 400 mW 15 ms / 5 ms / continious duty 5 kV 1 kV 250 V / 4 kV / 3 10 x 106 switching operations min. 100.000 switching operations see table lamp loads IP20 ALZ -25 °C ... +50 °C -40 °C ... +70 °C 15 x 54 x 86 Height from upper-edge of DIN 35 rail CAGE CLAMP®S 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in DIN VDE 0140 part 1, DIN EN 61140; DIN VDE 0160, EN 50178; degree of protection II; UL 508 Type of load Capability Electrical life Incandescent lamp Halogen lamp 230 V AC Halogen trafo Fluorescent lamp not comp., CB, cos ϕ 0,4-0,6 Fluorescent lamp comp., Conv. ballast, C parallel Fluorescent lamp comp., Conv. ballast, Duo-circuit Fluorescent lamp with electronic ballast Energy saving lamp 15 W Energy saving lamp 13 W Energy saving lamp 9 W Gas discharge lamp Dulux-Lamp not compensated Dulux-Lamp compensated Max. capacitance at 230 V AC 2200 W 1400 W 120 VA 20 x 58 W 9 x 58 W 600 W 12 x 58 W 25 pcs 30 pcs 38 pcs 1000 W 800 W 500 W 60 µF 20.000 50.000 20.000 25.000 25.000 20.000 25.000 20.000 20.000 20.000 20.000 20.000 20.000 min. 5.000 S 1 71 Relay with 1 make contact and status indication (Relay height: 25 mm) Nominal input voltage VN 24 V DC 1 300 200 resistive load DC voltage (Vdc) 100 50 40 30 Contact life at different lamp loads Load Switching operations 12 A, 250 V AC, cos ϕ = 1 TV 8 acc. to UL 508 2500 W, 230 V AC Halogen lamp 1000 W, 250 V AC Incandesent lamp 3000 W, 250 V AC Incandesent lamp 1500 VA, Fluorescent lamp 163 µF 3 x 105 25 x 103 > 104 2.3 x 105 3.6 x 104 104 • 20 10 0,1 0,2 0,5 1 2 5 10 20 DC current (A) 14 13 Description VN IN Item No. Pack. unit Relay sockets with pluggable miniature switching relay, for DIN 35 rail 24 V DC 21.8 mA 788-355 1 Technical Data Contact material Input voltage range Max. switching voltage Max. continuous current Max. make current (resistive) at a 10 % duty cycle Peak inrush current Recommended minimum load Max. Switching power (resistive) Operating power Pull-in/drop-out/bounce time typ. Nominal operating mode Dielectric strength contact-coil Dielectric strength open contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Service life at lamp load Degree of protection Type of relay Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see pages 74 ... 77 + 80 ... 81 AgSnO2 UN -15 % ... +20 % 250 V AC 16 A 4 s 25 A (AC) 20 ms / 120 A > 100 mA / 12 V AC/DC 4 kVA AC, DC see load limit curve 500 mW 8 ms / 2 ms / 2 ms continious duty 4 kV 1 kV 250 V / 4 kV / 3 30 x 106 switching operations see table lamp loads IP20 RP3SL -25 °C ... +50 °C -40 °C ... +70 °C 15 x 64 x 86 Height from upper-edge of DIN 35 rail CAGE CLAMP®S 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in DIN VDE 0140 part 1, DIN EN 61140; DIN VDE 0160, EN 50178; degree of protection II; UL 508 1 Sockets with Miniature Switching Relay 72 Voltage (V) Safety relay SR2M (2 changeover contacts) with forced guided contacts and status indication (Relay height: 25 mm) Nominal input voltage VN 24 V DC 300 200 resistive load 100 50 40 30 20 10 0.1 0.2 0.5 1 2 5 10 20 Current (A) In accordance with EN 50205, it is only permitted to use 1 make contact / 1 break contact for safety circuits (11-14 and 22-21 or 12-11 and 21-24) Description VN IN Item No. Pack. unit Relay sockets with pluggable miniature switching relay, for DIN 35 rail 24 V DC 31 mA 788-384 1 Technical Data Contact material Input voltage range Max. switching voltage Max. continuous current Max. make current (resistive) at a 10 % duty cycle Recommended minimum load Max. Switching power (resistive) Max. switching rate with / without load Operating power Pull-in/drop-out time typ. Nominal operating mode Dielectric strength contact-coil Dielectric strength open contact Dielectric strength contact-contact Clearance and creepage distance contact / coil Adjacent contacts Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Degree of protection Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see pages 74 ... 77 + 80 ... 81 AgNi VN ± 10 % 250 V AC 6A 4 s 14 A (AC) > 50 mW AC 1500 VA; DC see load limit curve 6 min-1 / 300 min-1 700 mW 10 ms / 4 ms continious duty 4 kV 1.5 kV 3 kV 8 mm 5.5 mm 250 V / 4 kV / 3 10 x 106 switching operations IP20 -25 °C ... +50 °C -40 °C ... +70 °C 15 x 64 x 86 Height from upper-edge of DIN 35 rail CAGE CLAMP®S 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in EN 50205; UL 508 S 1 73 Relay with 1 changeover contact manual operation and status indication (Relay height: 25 mm) Nominal input voltage VN 24 V DC Relay with 2 changeover contact manual operation and status indication (Relay height: 25 mm) Nominal input voltage VN 24 V DC 1 Description VN IN Item No. Pack. unit VN IN Item No. Pack. unit Relay sockets with pluggable miniature switching relay, for DIN 35 rail 24 V DC 24 mA 788-374 1 24 V DC 24 mA 788-375 1 Technical Data Contact material Input voltage range Max. switching voltage Max. continuous current Max. make current (resistive) at a 10 % duty cycle Max. Switching power (resistive) Max. switching rate Operating power Pull-in/drop-out/bounce time typ. Nominal operating mode Dielectric strength contact-coil Dielectric strength open contact Dielectric strength contact-contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Degree of protection Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see pages 74 ... 77 + 80 ... 81 Accessories see pages 74 ... 77 + 80 ... 81 AgCdO VN ± 10 % 250 V AC 16 A 20 ms 50 A (AC) 4 kVA AC 360 / h 500 mW typ. 8 ms / 3 ms / AK 0.5 ms, RK 5 ms continious duty 5 kV 1 kV 250 V / 4 kV / 3 AgCuNi VN ± 10 % 250 V AC 8A 20 ms 30 A (AC) 2 kVA AC 360 / h 500 mW typ. 8 ms / 3 ms / AK 0.5 ms, RK 5 ms continious duty 5 kV 1 kV 2.5 kV 250 V / 4 kV / 3 50 x 106 switching operations IP20 -25 °C ... +50 °C -40 °C ... +70 °C 15 x 64 x 86 Height from upper-edge of DIN 35 rail CAGE CLAMP®S 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in DIN VDE 0140 part 1, DIN EN 61140; DIN VDE 0160, EN 50178; degree of protection II; UL 508 50 x 106 switching operations IP20 -25 °C ... +50 °C -40 °C ... +70 °C 15 x 64 x 86 Height from upper-edge of DIN 35 rail CAGE CLAMP®S 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in DIN VDE 0140 part 1, DIN EN 61140; DIN VDE 0160, EN 50178; degree of protection II; UL 508 1 Accessories, 788 Series 74 Pluggable miniature switching relays (Relay height: 15 mm) 1 changeover contact Pluggable miniature switching relays (Relay height: 15 mm) 2 changeover contact Relay height 15 mm 12.7 3.8 15.7 29.0 Description VN Item No. Pack. unit VN Item No. Pack. unit Pluggable miniature switching relays 12 V DC 24 V DC 48 V DC 60 V DC 110 V DC 24 V AC 115 V AC 230 V AC 788-150 788-154 788-158 788-162 788-166 788-170 788-174 788-178 20 20 20 20 20 20 20 20 12 V DC 24 V DC 48 V DC 60 V DC 110 V DC 24 V AC 115 V AC 230 V AC 788-152 788-156 788-160 788-164 788-168 788-172 788-176 788-180 20 20 20 20 20 20 20 20 Technical Data Contact material Switching current Inrush current Max. switching voltage Switching power Min. switching current Nominal consumption, typ Pull-in/drop-out time typ. Nominal operating mode Mechanical life AC coil Mechanical life DC coil Dielectric strength contact-coil Dielectric strength open contact Dielectric strength contact-contact Weight Degree of protection Ambient operating temperature AC coil Ambient operating temperature DC coil Flammability acc. to UL 94 AgNi 16 A 30 A 250 V AC 4 kVA 10 mA 400 mW 7 ms / 3 ms continious duty > 10 x 106 switching operations > 30 x 106 switching operations 5 kV 1 kV approx. 13.5 g IP40 -40 °C ... +70 °C -40 °C ... +85 °C V0 AgNi 2x8A 15 A 250 V AC 2 kVA 10 mA 400 mW 7 ms / 3 ms continious duty > 5 x 106 switching operations > 30 x 106 switching operations 5 kV 1 kV 2.5 kV approx. 13.3 g IP40 -40 °C ... +70 °C -40 °C ... +85 °C V0 1 75 Pluggable miniature switching relays (Relay height: 15 mm) 1 changeover contact (gold contacts) Pluggable miniature switching relays (Relay height: 15 mm) 2 changeover contact (gold contacts) 1 Relay height 15 mm 12.7 3.8 15.7 29.0 Description VN Item No. Pack. unit VN Item No. Pack. unit Pluggable miniature switching relays 24 V DC 115 V AC 230 V AC 788-155 788-175 788-179 20 20 20 24 V DC 115 V AC 230 V AC 788-157 788-177 788-181 20 20 20 Technical Data Contact material Switching current Max. switching voltage Switching power Rated power consumption Rated power consumption Pull-in/drop-out time typ. Nominal operating mode Mechanical life AC coil Mechanical life DC coil Dielectric strength contact-coil Dielectric strength open contact Dielectric strength contact-contact Weight Degree of protection Ambient operating temperature AC coil Ambient operating temperature DC coil Flammability acc. to UL 94 AgNi + 5 μm Au 50 mA* 36 V* DC min. 50 mW 200 mW DC 0.422 VA AC 7 ms / 3 ms continious duty > 3 x 107 switching operations > 3 x 107 switching operations 5 kV 1 kV approx. 11 g IP40 -40 °C ... +70 °C -40 °C ... +85 °C V0 AgNi + 5 μm Au 2 x 50 mA* 36 V* DC min. 50 mW 200 mW DC 0.422 VA AC 7 ms / 3 ms continious duty > 3 x 107 switching operations > 3 x 107 switching operations 5 kV 1 kV 2.5 kV approx. 15 g IP40 -40 °C ... +70 °C -40 °C ... +85 °C V0 1 Accessories, 788 Series 76 Pluggable miniature switching relays (Relay height: 25 mm) 1 changeover contact Pluggable miniature switching relays (Relay height: 25 mm) 2 changeover contact Relay height 25 mm 12.7 3.3 25.5 29.0 Description VN Item No. Pack. unit VN Item No. Pack. unit Pluggable miniature switching relays 12 V DC 24 V DC 48 V DC 60 V DC 110 V DC 230 V AC 788-182 788-184 788-186 788-188 788-190 788-192 20 20 20 20 20 20 12 V DC 24 V DC 48 V DC 60 V DC 110 V DC 230 V AC 788-183 788-185 788-187 788-189 788-191 788-193 20 20 20 20 20 20 Technical Data Contact material Switching current Max. switching voltage Switching power Min. switching current Rated power consumption Rated power consumption Pull-in/drop-out time typ. Nominal operating mode Mechanical life AC coil Mechanical life DC coil Dielectric strength contact-coil Dielectric strength open contact Dielectric strength contact-contact Weight Degree of protection Ambient operating temperature AC coil Ambient operating temperature DC coil Flammability acc. to UL 94 AgNi AgSnO (788-192) 16 A 250 V AC 4 kVA 100 mA 500 mW DC 1.2 VA AC 9 ms / 3 ms continious duty > 10 x 106 switching operations > 20 x 106 switching operations 5 kV 1 kV approx. 18 g IP40 -40 °C ... +70 °C -40 °C ... +85 °C V0 AgNi AgSnO (788-193) 2x8A 250 V AC 2 kVA 10 mA 500 mW DC 1.2 VA AC 9 ms / 3 ms continious duty > 10 x 106 switching operations > 20 x 106 switching operations 5 kV 1 kV 2.5 kV approx. 18 g IP40 -40 °C ... +70 °C -40 °C ... +85 °C V0 S Sockets for Miniature Switching Relay 1 77 Sockets for miniature switching relay 1 changeover contact / 2 changeover contact 1 changeover contact 2 changeover contacts View on pins Pinning Description Item No. Pack. unit Socket without relay, for DIN 35 rail Relay height 15 mm, 1 changeover contact Relay height 15 mm, 2 changeover contacts Relay height 25 mm, 1 changeover contact Relay height 25 mm, 2 changeover contacts 788-100 788-102 788-101 788-103 1 1 1 1 Technical Data Max. continuous current Nominal input voltage (VN) Dielectric strength Max. switching voltage Max. Switching power (resistive) Nominal operating mode Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Degree of protection Ambient operating temperature Storage temperature Wire connection Cross sections Stripped lengths Approvals 16 A / 2 x 8 A depending on relay; max. 250 V AC 5 kV (depending on relay) 250 V AC 4000 VA AC continious duty 250 V / 4 kV / 3 IP20 -25 °C ... +70 °C (depending on relay) -40 °C ... +80 °C CAGE CLAMP®S 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in DIN VDE 0140 part 1, DIN EN 61140; DIN VDE 0160, EN 50178; degree of protection II 1 1 Sockets with Solid State Relay 78 Solid state relay Input: 24 V DC Output: 0 V ... 24 V DC / 3.5 A Solid state relay Input: 24 V DC Output: 0 V ... 24 V DC / 5 A A1 + 14 - A1 + 14 - A2 - 13 + A2 - 13 + Description Item No. Pack. unit Item No. Pack. unit Relay socket with solid state relay, for DIN 35 rail 788-700 1 788-701 1 Technical Data Control circuit: Nominal input voltage (VN) Input voltage range Control current UN (20°C) Release voltage Control circuit resistance Load circuit: Load switching voltage range Peak reverse voltage Max. switching current Min. switching current Pull-in time Drop-out time Switching frequency (max.) Forward voltage at max. switching current Nominal operating mode Dielectric strength control/switching circuit Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Degree of protection Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see pages 80 ... 81 Accessories see pages 80 ... 81 24 V DC 18 V ... 30 V DC 7 mA ±10 % 8 V DC 3.2 kΩ 24 V DC 15 V ... 30 V DC 9.3 mA ±10 % 2.5 V DC 2.1 kΩ 0 ... 24 V DC 33 V 3.5 A DC < 0.1 V DC continuous duty 2.5 kV 250 V / 2.5 kV / 2 0 ... 30 V DC 36 V DC12/DC13 (5 A DC) 1 mA DC 50 μs 600 μs 100 Hz at 5 A 0.3 V DC continuous duty 2.5 kV 250 V / 2.5 kV / 2 IP 20 -20 °C ... +60°C -40 °C ... +70 °C 15 x 53 x 86 Height from upper-edge of DIN 35 rail CAGE CLAMP®S 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in DIN VDE 0140 part 1, DIN EN 61140; DIN VDE 0160, EN 50178; degree of protection II IP 20 -40 °C ... +60°C -40 °C ... +70 °C 15 x 63 x 86 Height from upper-edge of DIN 35 rail CAGE CLAMP®S 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in DIN VDE 0140 part 1, DIN EN 61140; DIN VDE 0160, EN 50178; degree of protection II S 1 79 Solid state relay Input: 24 V DC Output: 24 V ... 240 V AC / 1 A A1 + 1 14 A2 - 13 Description Item No. Pack. unit Relay socket with solid state relay, for DIN 35 rail 788-720 1 Technical Data Control circuit: Nominal input voltage (VN) Input voltage range Control current UN (20°C) Release voltage Control circuit resistance Load circuit: Max. switching voltage Load switching voltage range Peak reverse voltage Max. switching current Forward voltage at max. switching current Nominal operating mode Dielectric strength control/switching circuit Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Degree of protection Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see pages 80 ... 81 24 V DC 18 V ... 30 V DC 7 mA ±10 % 4 V DC 3.2 kΩ 240 V AC 24 ... 240 V AC 600 V 1 A AC < 1 V AC continuous duty 3.75 kV 250 V / 2.5 kV / 2 IP 20 -20 °C ... +60°C -40 °C ... +70 °C 15 x 53 x 86 Height from upper-edge of DIN 35 rail CAGE CLAMP®S 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in DIN VDE 0140 part 1, DIN EN 61140; DIN VDE 0160, EN 50178; degree of protection II 1 Accessories, 788 Series 80 Status indication Description Power consumption at VN Item No. Pack. Unit Status indication 24 V DC (12 V ... 24 V) Status indication 48 V DC (48 V ... 60 V) Status indication 110 V DC Status indication 24 V AC Status indication 115 V AC Status indication 230 V AC 2.4 mA 1.9 mA 1.9 mA 2.1 mA 1.7 mA 1.6 mA 788-120 788-121 788-122 788-123 788-124 788-125 50 (2x25) 50 (2x25) 50 (2x25) 50 (2x25) 50 (2x25) 50 (2x25) Push-in type jumper bar 788-113 Commoning Push-in type jumper bar Description Item No. Pack. Unit Push-in type jumper bar, I max. 18 A 2-way 3-way 4-way 6-way 8-way (module/module) 788-113 788-114 788-115 788-116 788-117 200 (8x25) 100 (4x25) 100 (4x25) 100 (4x25) 100 (4x25) Push-in type jumper bars, light gray, insulated, 18 A 2-way (intern) 859-402 200 (8x25) WMB Multi marking system Marking Description WMB Multi marking system Marking software and printer/plotter see Section 8 Marking Group marker carrier Item No. Pack. Unit plain 793-501 5 cards 1 ... 10 (10x) 11 ... 20 (10x) 21 ... 30 (10x) 31 ... 40 (10x) 41 ... 50 (10x) 1 ... 50 (2x) 793-502 793-503 793-504 793-505 793-506 793-566 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 209-112 50 (1x50) 10 strips with 10 markers, white with black printing Group marker carrier 1 81 Operating tool Wire connection Description 1 Item No. Pack. Unit Type 2, blade (3.5 x 0.5) mm 210-720 1 Description Sleeve for mm2 / AWG Item No. Pack. Unit Ferrule, red insulated, 12 mm 2 x 1 mm2 / 2 x 18 216-542 500 Operating tool, with partially insulated shaft Ferrule 1 Sockets with Industrial Relay 82 Socket with industrial relay Coil voltage: 24 V DC 4 changeover contacts A1 - * In order to prevent the gold layer from being damaged, these values shall not be exceeded. Higher switching power leads to evaporation of the gold layer. The resulting deposits in the enclosure may cause sparkovers between the coil and the contact. Socket with industrial relay Coil voltage: 24 V DC 4 changeover contacts (gold contacts) 14 14 11 12 24 11 12 24 A1 - 21 22 34 31 32 44 A2 + 21 22 34 31 32 44 A2 + 41 42 41 42 Description Item No. Pack. Unit Item No. Pack. Unit Relay socket with industrial relay, for DIN 35 rail 858-304 1 858-314 1 Technical Data Coil Coil voltage Rated power Coil current Operating range Holding voltage Release voltage Contacts Contact material Continuous current Inrush current Max. switching voltage Switching power (max.) AC1 / AC15 1-phase motor load AC3 Switching current (max.) DC1 Min. switching load Switching frequency under load General Specifications Mechanical life Electrical life Pull-in/drop-out/bounce time typ. Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Dielectric strength contact-coil (1.2/50 μs) Dielectric strength contact-coil (AC, 1 min) Dielectric strength open contact Dielectric strength contact-contact Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Accessories see page 84 ... 86 Accessories see page 84 ... 86 24 V DC 0.9 W 36.9 mA 0.8 ... 1.1 x V 50 % of VN 0.1 x V 24 V DC 0.9 W 36.9 mA 0.8 ... 1.1 x V 50 % of VN 0.1 x V AgCe 5A 15 A / 4 s 250 V AC / 30 V DC 1250 VA / 300 VA 0.12 kW 5 A at 30 V DC 12 V / 100 mA 20 cycles/min. AgCe + 5 μm Au 50 mA* 15 A / 4 s 30 V DC* 1250 VA / 300 VA 0.12 kW 5 A at 30 V DC 12 V / 100 mA 20 cycles/min. 20 x 106 switching operations 1 x 105 switching operations 25 ms / 25 ms / 4 ms 250 V / 2.5 kV / 2 20 x 106 switching operations 1 x 105 switching operations 25 ms / 25 ms / 4 ms 250 V / 2.5 kV / 2 4 kV 1.5 kV 1 kV 1.5 kV -25 °C ... +70 °C (VL + 50 °C) -40 °C ... +80 °C 31 x 73 x 97 Height from upper-edge of DIN 35 rail CAGE CLAMP®S 2 x 0.34 mm² ... 2 x 1.5 mm² / 1 x 2.5 mm²/ AWG 22 ... 16 9 ... 10 mm / 0.37 in 4 kV 1.5 kV 1 kV 1.5 kV -25 °C ... +70 °C (VL + 50 °C) -40 °C ... +80 °C 31 x 73 x 97 Height from upper-edge of DIN 35 rail CAGE CLAMP®S 2 x 0.34 mm² ... 2 x 1.5 mm² / 1 x 2.5 mm²/ AWG 22 ... 16 9 ... 10 mm / 0.37 in S 1 83 Socket with industrial relay Coil voltage: 230 V AC 4 changeover contacts A1 ~ * In order to prevent the gold layer from being damaged, these values shall not be exceeded. Higher switching power leads to evaporation of the gold layer. The resulting deposits in the enclosure may cause sparkovers between the coil and the contact. Socket with industrial relay Coil voltage: 230 V AC 4 changeover contacts (gold contacts) 14 14 11 12 24 11 12 24 A1 ~ 21 22 34 31 32 44 A2 ~ 1 21 22 34 31 32 44 A2 ~ 41 42 41 42 Description Item No. Pack. Unit Item No. Pack. Unit Relay socket with industrial relay, for DIN 35 rail 858-508 1 858-518 1 Technical Data Coil Coil voltage Rated power Coil current Operating range Holding voltage Release voltage Contacts Contact material Continuous current Inrush current Max. switching voltage Switching power (max.) AC1 / AC15 1-phase motor load AC3 Switching current (max.) DC1 Min. switching load Switching frequency under load General Specifications Mechanical life Electrical life Pull-in/drop-out/bounce time typ. Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Dielectric strength contact-coil (1.2/50 μs) Dielectric strength contact-coil (AC, 1 min) Dielectric strength open contact Dielectric strength contact-contact Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Accessories see page 84 ... 86 Accessories see page 84 ... 86 230 V AC 1.2 VA 8.3 mA 0.8 ... 1.1 x V 80 % of VN 0.3 x V 230 V AC 1.2 VA 8.3 mA 0.8 ... 1.1 x V 80 % of VN 0.3 x V AgCe 5A 15 A / 4 s 250 V AC / 30 V DC 1250 VA / 300 VA 0.12 kW 5 A at 30 V DC 12 V / 100 mA 20 cycles/min. AgCe + 5 μm Au 50 mA* 15 A / 4 s 30 V DC* 1250 VA / 300 VA 0.12 kW 5 A at 30 V DC 12 V / 100 mA 20 cycles/min. 20 x 106 switching operations 1 x 105 switching operations 25 ms / 25 ms / 4 ms 250 V / 2.5 kV / 2 20 x 106 switching operations 1 x 105 switching operations 25 ms / 25 ms / 4 ms 250 V / 2.5 kV / 2 4 kV 1.5 kV 1 kV 1.5 kV -25 °C ... +70 °C (VL + 50 °C) -40 °C ... +80 °C 31 x 73 x 97 Height from upper-edge of DIN 35 rail CAGE CLAMP®S 2 x 0.34 mm² ... 2 x 1.5 mm² / 1 x 2.5 mm²/ AWG 22 ... 16 9 ... 10 mm / 0.37 in 4 kV 1.5 kV 1 kV 1.5 kV -25 °C ... +70 °C (VL + 50 °C) -40 °C ... +80 °C 31 x 73 x 97 Height from upper-edge of DIN 35 rail CAGE CLAMP®S 2 x 0.34 mm² ... 2 x 1.5 mm² / 1 x 2.5 mm²/ AWG 22 ... 16 9 ... 10 mm / 0.37 in 1 Accessories, 858 Series 84 Pluggable industrial relays, 4 changeover contacts with integrated LED and recovery diode and manual operation 21,5 max 5,8 35 max 28 max Pluggable industrial relays, 4 changeover contacts with integrated LED and manual operation 13.2 4.4 2 3 4 1 2 3 5 6 7 8 5 6 7 4 8 9 10 11 12 9 10 11 12 13 12.7 14 6.3 14 6.3 13 6.4 6.4 12.7 16.8 1 16.8 * In order to prevent the gold layerfrom being damaged these values should not be exceeded. Higher switching power leads to evaporation of the gold layer. The resulting deposits in the endosure may cause sparkover between the coil and the contact. 13.2 4.4 Description VN Item No. Pack. unit VN Item No. Pack. unit Pluggable industrial relay 24 V DC 24 V DC* 858-150 858-152 1 1 240 V AC 240 V AC* 858-151 858-153 1 1 Technical Data Coil Coil voltage Rated power Coil current Operating range Holding voltage Release voltage Contacts Contact material Continuous current Inrush current Max. switching voltage Switching power (max.) AC1 / AC15 1-phase motor load AC3 Switching current (max.) DC1 Min. switching load Switching frequency under load General Specifications Mechanical life Electrical life Pull-in/drop-out/bounce time typ. Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Dielectric strength contact-coil (1.2/50 μs) Dielectric strength contact-coil (AC, 1 min) Dielectric strength open contact Dielectric strength contact-contact Ambient operating temperature Mounting distance in a row Weight 24 V DC 0.9 W 36.9 mA 0.8 ... 1.1 x V 50 % of VN 0.1 x V AgCe, AgCe + 5 μm Au*AgCe, AgCe + 5 μm Au* 5A* 15 A / 4 s 250 V AC / 30 V DC 1250 VA / 300 VA 0.12 kW 5 A at 30 V DC 12 V / 100 mA 20 cycles/min. 240 V AC 1.2 VA 8.3 mA 0.8 ... 1.1 x V 80 % of VN 0.3 x V AgCe, AgCe + 5 μm Au* 5A* 15 A / 4 s 250 V AC / 30 V DC 1250 VA / 300 VA 0.12 kW 5 A at 30 V DC 12 V / 100 mA 20 cycles/min. 20 x 106 switching operations 1 x 105 switching operations 25 ms / 25 ms / 4 ms 250 V / 2 kV / 2 20 x 106 switching operations 1 x 105 switching operations 25 ms / 25 ms / 4 ms 250 V / 2 kV / 2 4 kV 1.5 kV 1 kV 1.5 kV -25°C ... +70°C 6 mm approx. 37 g 4 kV 1.5 kV 1 kV 1.5 kV -25°C ... +70°C 6 mm approx. 37 g 1 Sockets with Industrial Relay 85 Socket for industrial relays 2 and 4 changeover contacts 42 A2 Note: Inductive loads have to be attenuated by an appropriate protective circuit in order to protect relay coils and contacts. 32 22 A1 12 1 44 41 31 34 21 24 14 11 Description Item No. Pack. Unit Relay socket for industrial relays, for DIN 35 rail 858-100 1 Technical Data Nominal input voltage (VN) Max. switching voltage Max. continuous current Max. Switching power (resistive) Nominal operating mode Dielectric strength Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Degree of protection Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Stripped lengths Cross sections Approvals depending on Relay; max. 250 V AC 250 V AC 4 x 8 A (4 changeover contacts); 2 x 12 A (2 changeover contacts) 4000 VA AC continious duty 4 kV (depending on relay) 250 V / 4 kV / 3 IP 20 -25 °C ... +70 °C (depending on relay) -40 °C ... +80 °C 31 x 39 x 97 Height from upper-edge of DIN 35 rail CAGE CLAMP®S 9 ... 10 mm / 0.37 in 2 x 0.34 mm² ... 2 x 1.5 mm² / 1 x 2.5 mm²/ AWG 22 ... 16 IEC60664 / IEC60664A / DIN VDE0110 Degree of pollution 2 Overvoltage category 2 1 Accessories, 858 Series 86 Holding bracket Description Item No. Pack. unit Holding bracket for industrial relays (height 33.5 mm ... 35.5 mm) 858-110 1 Description Item No. Pack. unit Push-in type jumper bar 858-402 200 Item No. Pack. Unit 788-120 788-121 788-122 788-123 788-124 788-125 50 (2x25) 50 (2x25) 50 (2x25) 50 (2x25) 50 (2x25) 50 (2x25) Push-in type jumper bar Status indication Description Power consumption at VN Status indication 24 V DC (12 V ... 24 V) 2.4 mA Status indication 48 V DC (48 V ... 60 V) 1.9 mA Status indication 110 V DC 1.9 mA Status indication 24 V AC 2.1 mA Status indication 115 V AC 1.7 mA Status indication 230 V AC 1.6 mA NOTE: Only required when using relays without integrated operating indicator! Operating tool Description Operating tool, with partially insulated shaft Type 2, blade (3.5 x 0.5) mm Item No. Pack. unit 210-720 1 1 87 1 1 Rail Mounted Relay Modules 88 Relay with 1 make contact Relay direct soldered with universal mounting carrier Relay with 1 break contact Relay direct soldered with universal mounting carrier A1 + 14 A1 ~ 14 A1 + 12 A1 ~ 12 A2 – 13 A2 ~ 13 A2 – 11 A2 ~ 11 Description VN IN Item No. Pack. Unit Switching relay module 24 V DC 24 V AC/DC 48 V AC/DC 115 V AC/DC 16 mA 16 mA 9.1 mA 4.4 mA 288-364 288-564 288-565 288-567 1 1 1 1 VN IN Item No. Pack. Unit 24 V DC 24 V AC/DC 16 mA 16 mA 288-368 288-568 1 1 Technical Data Contact material Max. switching voltage Max. make / break current Max. continuous current Max. switching power (resistive) Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Dimensions (mm) L x W x H incl. mounting carrier and relay AgNi 0.15 + HV 250 V DC / 250 V AC 4 s 16 A / 8 A 5A 100 W/ 1500 VA 240 mW / 500 mW 4 ms / 6 ms / 2 ms 4 kV 250 V / 4 kV / 3 AgNi 0.15 + HV 250 V DC / 250 V AC 4 s 16 A / 8 A 5A 100 W/ 1500 VA 240 mW / 500 mW 4 ms / 6 ms / 2 ms 4 kV 250 V / 4 kV / 3 30 x 106 switching operations 2 x 105 switching operations -25 °C ... +40 °C 13 x 47 x 85 30 x 106 switching operations 2 x 105 switching operations -25 °C ... +40 °C 13 x 47 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 1 89 Relay with 1 changeover contact Relay direct soldered with connectors Relay with 1 changeover contact Relay direct soldered with universal mounting carrier 12 14 A1 ~ 12 A2 ~ 11 A1 + A2 – A2 – 11 Description VN IN Item No. Pack. Unit Switching relay module 24 V AC/DC 16 mA 288-554 1 12 A1 ~ 14 11 A2 ~ A2 ~ 14 11 VN IN Item No. Pack. Unit 24 V DC 24 V AC/DC 230 V AC 21.8 mA 21.8 mA 6.1 mA 288-304 288-504 288-508 1 1 1 Technical Data Contact material Max. switching voltage Max. make / break current Max. continuous current Max. switching power (resistive) Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Dimensions (mm) L x W x H incl. mounting carrier and relay AgNi 0.15 + HV 250 V DC / 250 V AC 4 s 16 A / 8 A 5A 100 W/ 1500 VA 240 mW / 500 mW 4 ms / 6 ms / 2 ms 4 kV 250 V / 4 kV / 3 AgNi 0.15 + HV 300 V DC / 250 V AC 4 s 20 A / 8 A 6A 192 W/ 1750 VA 261 mW / 533 mW 9 ms / 3 ms / 2 ms 4 kV 250 V / 4 kV / 3 30 x 106 switching operations 2 x 105 switching operations -25 °C ... +40 °C 13 x 52 x 85 30 x 106 switching operations 1 x 105 switching operations -25 °C ... +40 °C 20.5 x 48 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 231 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 8 ... 9 mm / 0.33 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 1 1 Rail Mounted Relay Modules 90 Relay with 2 changeover contacts Relay direct soldered with universal mounting carrier 12 11 12 with 2 relays, 1 changeover contact each Relay direct soldered with universal mounting carrier 11 14 24 A2 A2 – 22 21 Description VN IN Item No. Switching relay module 24 V DC 24 V AC/DC 21.8 mA 21.8 mA 288-312 288-512 1 1 14 12 11 A2 ~ A2 ~ 21 Pack. Unit 11 A2 ~ A2 ~ A1 ~ 14 24 A2 ~ 22 12 A1 ~ A1 ~ A1 + 14 VN IN Item No. Pack. Unit 24 V AC/DC 115 V AC/DC 230 V AC 21.8 mA 4.8 mA 4.1 mA 288-758 288-761 288-762 1 1 1 Technical Data Contact material Max. switching voltage Max. make / break current Max. continuous current Max. switching power (resistive) Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Dimensions (mm) L x W x H incl. mounting carrier and relay AgNi 0.15 + HV 250 V DC / 250 V AC 4 s 14 A / 8 A 6A 100 W/ 1500 VA 261 mW / 533 mW 8 ms / 3 ms / 2 ms 2.5 kV 250 V / 2.5 kV / 3 AgNi 0.15 + HV 300 V DC / 250 V AC 20 A / 8 A 6A 192 W/ 1500 VA 261 mW / 533 mW 9 ms / 3 ms / 2 ms 4 kV 250 V / 4 kV / 3 30 x 106 switching operations 1 x 105 switching operations -25 °C ... +40 °C 22.5 x 48 x 85 30 x 106 switching operations 1 x 105 switching operations -25 °C ... +40 °C 38.5 x 48 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 1 91 with 4 relays, 1 changeover contact each Relay in socket with universal mounting carrier A1 + 12 11 14 A2 + 22 21 24 A4 + _ _ 42 41 44 Description VN IN Item No. Pack. Unit Switching relay module 24 V DC 21.8 mA 287-774 1 Technical Data Contact material Max. switching voltage Max. make / break current Max. continuous current Max. switching power (resistive) Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Dimensions (mm) L x W x H incl. mounting carrier and relay AgNi 0.15 + HV 300 V DC / 250 V AC 20 A / 8 A 6A 192 W/ 1500 VA 261 mW / 533 mW 9 ms / 3 ms / 2 ms 4 kV 250 V / 4 kV / 3 30 x 106 switching operations 1 x 105 switching operations -25 °C ... +40 °C 63.5 x 58 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 1 1 Rail Mounted Relay Modules 92 with 8 relays, 1 changeover contact each Relay direct soldered with universal mounting carrier A1 + 12 14 11 A2 + 22 24 21 A8 + 82 84 81 N N A1 ~ A2 ~ A8 ~ N N with 8 relays, 1 changeover contact each Relay in socket with universal mounting carrier 12 14 11 22 24 21 A1 + 82 84 81 A8 + 12 11 14 A2 + 22 21 24 82 81 84 N N A1 ~ 12 11 14 A2 ~ 22 21 24 A8 ~ N N 82 81 84 Description VN IN Item No. Pack. Unit VN IN Item No. Pack. Unit Switching relay module 24 V DC 24 V AC/DC 10.2 mA 10.2 mA 287-804 287-814 1 1 24 V DC 24 V AC/DC 21.8 mA 21.8 mA 287-824 287-834 1 1 Technical Data Contact material Max. switching voltage Max. make / break current Max. continuous current Max. switching power (resistive) Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Dimensions (mm) L x W x H incl. mounting carrier and relay AgNi 0.15 + HV 250 V DC / 250 V AC 4 s 30 A / 8 A 6A 90 W/ 1500 VA 170 mW / 245 mW 7 ms / 3 ms / 2 ms 4 kV 250 V / 2.5 kV / 3 AgNi 0.15 + HV 300 V DC / 250 V AC 20 A / 8 A 6A 192 W/ 1500 VA 261 mW / 533 mW 9 ms / 3 ms / 2 ms 4 kV 250 V / 2.5 kV / 3 20 x 106 switching operations 2 x 105 switching operations -25 °C ... +40 °C 127 x 38 x 85 20 x 106 switching operations 2 x 105 switching operations -25 °C ... +40 °C 127 x 58 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 1 93 Voltage (V) with 16 relays, 1 changeover contact each Relay in socket with universal mounting carrier 300 200 100 resistive load 20 ms 40 ms 50 40 30 60 ms 8A 20 10 0.1 0.2 0.5 1 2 5 10 20 Current (A) A1 + 12 11 14 A2 + 22 21 24 A16 + N N 162 161 164 Description VN IN Item No. Pack. Unit Switching relay module 12 V DC 24 V DC 43.8 mA 21.8 mA 287-853 287-854 1 1 Technical Data Input voltage range Contact material Max. switching voltage Max. make / break current Max. continuous current Max. switching power (resistive) Recommended minimum load Pull-in / operating power Pull-in/drop-out/bounce time typ. Nominal operating mode Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Storage temperature Dimensions (mm) L x W x H incl. mounting carrier and relay Wire connection Cross sections Stripped lengths Approvals Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier VN -15 % ...+20 % AgNi 0.15 250 V DC / 250 V AC 4 s 16 A (AC) / 5 A (24 V DC) 6A 1500 VA AC; DC see load limit curve 100 mA / 10 V AC/DC ( 1 W, 1 VA) 533 mW 10 ms / 4 ms / 2 ms continuous duty 4 kV 250 V / 2.5 kV / 3 30 x 106 switching operations 1 x 105 switching operations -25 °C ... +40 °C -40 °C ... +70 °C 287 x 58 x 85 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in DIN VDE 0140, DIN VDE 0160 and IEC 60255, DIN VDE 0435 (corresponding parts) see page 323 white 709-198 / transparent 709-197 1 1 Rail Mounted Relay Modules 94 Voltage (V) Relay with 1 make contact Relay direct soldered with universal mounting carrier Designed for switching high inrush current loads i.e. filament lamp loads with 4 relays, 1 make contact each Relay direct soldered with universal mounting carrier Designed for switching high inrush current loads i.e. filament lamp loads 300 200 resistive load 100 50 40 30 12 A 8A 20 10 0.1 0.2 0.5 1 2 5 16 A 10 20 Current (A) Contact life at lamp load Load Switch. oper. 12 A, AC 250 V, cos ϕ = 1 TV 8 acc. UL 508 2500 W, 230 V AC halogen 1000 W, 250 V AC incandescent 3000 W, 250 V AC incandescent 1500 VA, fluorescent 163 µF 3 x 105 25 x 103 > 104 2.3 x 105 3.6 x 104 104 A1 + A1 + 14 13 14 A2 + 23 24 A2 – A2 – A4 + 13 43 N N 44 Description VN IN Item No. Pack. Unit VN IN Item No. Pack. Unit Switching relay module 24 V DC 21.8 mA 288-320 1 24 V DC 21.8 mA 287-475 1 Technical Data Input voltage range Contact material Max. switching voltage Max. make / break current Peak inrush current Max. continuous current Max. switching power (resistive) Recommended minimum load Pull-in / operating power Pull-in/drop-out/bounce time typ. Nominal operating mode Dielectric strength contact-coil (AC, 1 min) Dielectric strength open contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Service life at lamp load Ambient operating temperature Storage temperature Dimensions (mm) L x W x H incl. mounting carrier and relay Wire connection Cross sections Stripped lengths Approvals Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier VN -15 % ...+20 % AgSnO2 440 V AC 4 s 25 A 20 ms/120 A 16 A 4000 VA AC; DC see load limit curve > 100 mA / 12 V AC/DC 500 mW 8 ms / 2 ms / 2 ms continuous duty 4 kV 1 kV 250 V / 4 kV / 3 VN -15 % ...+20 % AgSnO2 440 V AC 4 s 25 A 20 ms/120 A 16 A 4000 VA AC; DC see load limit curve > 100 mA / 12 V AC/DC 500 mW 8 ms / 2 ms / 2 ms continuous duty 4 kV 1 kV 250 V / 4 kV / 3 30 x 106 switching operations see lamp load table -25 °C ... +40 °C -40 °C ... +70 °C 20.5 x 47 x 85 30 x 106 switching operations see lamp load table -25 °C ... +40 °C -40 °C ... +70 °C 64 x 47 x 85 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in DIN VDE 0140 Part 18.01 for AC 250 V; DIN VDE 0160 and IEC 60255; DIN VDE 0435 (corresponding parts); UL 508 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in DIN VDE 0140 Part 18.01 for AC 250 V; DIN VDE 0160 and IEC 60255; DIN VDE 0435 (corresponding parts); UL 508, g see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 1 95 Voltage (V) with 4 relays, 1 make contact each Relay direct soldered with universal mounting carrier Bistable relay with 1 changeover contact Relay direct soldered with universal mounting carrier 300 200 100 resistive load 20 ms 40 ms 50 40 30 60 ms 20 10 16 A 0.1 0.2 0.5 1 2 5 10 20 Current (A) A1 + 11 14 A2 + 21 24 A4 + 41 N N 44 A1 + 12 B1 _ 14 A2 + 11 Description VN IN Item No. Pack. Unit VN IN Item No. Pack. Unit Switching relay module 24 V DC 21.8 mA 287-474 1 24 V DC 41.5 mA 288-380 1 Technical Data Input voltage range Contact material Max. switching voltage Max. make / break current Max. continuous current Max. switching power (resistive) Recommended minimum load Pull-in / operating power Pull-in/drop-out/bounce time typ. Nominal operating mode Dielectric strength contact-coil (AC, 1 min) Dielectric strength open contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Storage temperature Dimensions (mm) L x W x H incl. mounting carrier and relay Wire connection Cross sections Stripped lengths Approvals Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier VN -15 % ...+20 % AgCdO 250 V DC / 250 V AC 1 s 25 A (AC) 16 A 4000 VA AC; DC see load limit curve > 100 mA / 12 V AC/DC 500 mW 8 ms / 2 ms / 2 ms continuous duty 4 kV 1 kV 250 V / 4 kV / 3 VN -15 % ...+20 % AgNi 0.15 + HV 300 V DC / 250 V AC 4 s 20 A / 8 A 6A 192 W / 1750 VA 30 x 106 switching operations 1 x 105 switching operations -25 °C ... +40 °C -40 °C ... +70 °C 64 x 47 x 85 30 x 106 switching operations 1 x 105 switching operations -25 °C ... +40 °C Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in DIN VDE 0160 and IEC 60255; DIN VDE 0435 (corresponding parts), g Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 261 mW / 533 mW 9 ms / 3 ms / 2 ms 4 kV 250 V / 4 kV / 3 20.5 x 48 x 85 1 1 Rail Mounted Relay Modules 96 Relay with 2 changeover contacts with forced operated contacts Relay direct soldered with universal mounting carrier 11 Switching relay module with 2 pluggable safety relays with 3 make contacts and 1 break contact with universal mounting carrier 21 A1 + A2 – A2 – 12 14 22 24 _ 12 14 24 34 A2 + _ 11 13 23 33 12 14 24 34 A1 + 11 13 23 33 Description VN IN Item No. Pack. Unit VN IN Item No. Pack. Unit Switching relay module 24 V DC 30 mA 288-437 1 24 V DC 50 mA 288-435 1 Technical Data Contact material Contact type Max. switching voltage Max. make / break current Max. continuous current Max. switching power (resistive) Recommended minimum load Pull-in / operating power Max. switching rate Pull-in/drop-out/bounce time typ. Nominal operating mode Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Test voltage coil - contact Test voltage contact - contact Test voltage contacts - yoke Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Relay fixing mechanism Dimensions (mm) L x W x H incl. mounting carrier and relay AgNi 10 + 5 μm Au 2 changeover contacts 380 V 0.3 A 5A 7 W / 7 VA 1 mA / 100 mV AC/DC 800 mW 15 ms / 12 ms continuous duty 4 kV 250 V / 2.5 kV / 3 4 kV (1 min) 1 kV (1 min) AgCdO + 0.2 μm Au 3 make contacts / 1 break contact 300 V DC / 230 V AC 10 A / 7 A 6A 120 W / 2000 VA 300 mA / 12 V 1200 mW 5x/s 23 ms / 20 ms continuous duty 2.5 kV 2500 V eff 2500 V eff 2500 V eff 1 x 107 switching operations 50 x 107 switching operations 1 x 105 switching operations -40 °C ... +85 °C soldered 19 x 38 x 85 -25 °C ... +70 °C plastic holden with locking latches (by relay manufacturer) 57 x 90 x 107 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 736 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 1 97 If required a breathing hole can be made in the cover. However be aware that the degree of waterproof protection will reduce from IP67 to IP30! Safety relay type SDS SF 4 with 4 break contacts and 4 make contacts with 1 relay with universal mounting carrier Safety relay type SDS SF 4 with 4 break contacts and 4 make contacts with 2 relays with universal mounting carrier If an outer contact (20) should weld then the forced operated inner contact (12) driven by the actuator (d) remains open. The rotating armature (c) remains free to move. The unaffected contact pairs can operate normally, (i. e. their function to make or break remains unaffected). If an inner contact should weld (12) then the movement of the rotating armature (c) is blocked via the operator (d). Open contacts of all four contact pairs remain open. This arrangement corresponds to conventional, forced contact operation. Description VN IN Item No. Pack. Unit VN IN Item No. Pack. Unit Switching relay module 5 V DC 12 V DC 24 V AC/DC 48 V AC/DC 60 V AC/DC 230 V AC 100 mA 41.7 mA 20.9 mA 10.5 mA 8.4 mA 9.4 mA 288-412 288-413 288-414 288-415 288-416 288-418 1 1 1 1 1 1 5 V DC 12 V DC 24 V AC/DC 48 V AC/DC 60 V AC/DC 230 V AC 100 mA 41.7 mA 20.9 mA 10.5 mA 8.4 mA 9.4 mA 288-422 288-423 288-424 288-425 288-426 288-428 1 1 1 1 1 1 Technical Data Contact material Max. switching voltage Max. make / break current Max. continuous current Max. switching power (resistive) Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Dimensions (mm) L x W x H incl. mounting carrier and relay Wire connection Cross sections Stripped lengths Relay Approvals Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier Ag Sn O 0.1 μm Au 250 V AC 20 A / 6 A 6A 150 W/ 1500 VA 280 mW / 500 mW 18 ms / 6 ms / 4 ms 2.5 kV 250 V / 2.5 kV / 3 Ag Sn O 0.1 μm Au 250 V AC 20 A / 6 A 6A 150 W / 1500 VA 280 mW / 500 mW 18 ms / 6 ms / 4 ms 2.5 kV 250 V / 2.5 kV / 3 1 x 107 switching operations 1 x 105 switching operations -40 °C ... +70 °C 63.5 x 40 x 85 1 x 107 switching operations 1 x 105 switching operations -40 °C ... +70 °C 127 x 40 x 85 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 256 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in SEV approvals, no. D 3.31/192; SUVA approvals, no. 36 62 (delayed operation 5 Amp fuse); TÜV test no. 945/EL 178/88; UL recognized, file no. E 43149 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in SEV approvals, no. D 3.31/192; SUVA approvals, no. 36 62 (delayed operation 5 Amp fuse); TÜV test no. 945/EL 178/88; UL recognized, file no. E 43149 see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 1 1 Accessories for Rail Mounted Modules 98 KAMMERRELAIS® is a registered trademark of the Siemens AG Socket for European standard industrial relay, size 1 with 4 changeover contacts A2 A2 31 41 34 44 42 32 Socket for KAMMRELAIS® Size I with 2 changeover contacts 3 22 22 24 24 •21 21 A2 A2 5 5 7 7 6 6 –4 –4 +13 10 9 6 5 1 2 A1 11 21 14 24 22 12 9 9 8 8 10 10 +1 +1 11 11 12 12 14 •14 A1 A1 –14 –14 11 12 7 8 4 Description Item No. Pack. Unit Item No. Pack. Unit Relay socket, for AC/DC relays Relay socket, for DC relays with free-wheeling diode Relay socket, for DC relays with free-wheeling diode and LED 288-111 288-112 288-113 1 1 1 288-131 288-132 288-133 1 1 1 Technical Data Relay enclosure Operating voltage (dependent on the relay voltage) Nominal current Max. coil current of the LED version Dimensions (mm) L x W x H incl. mounting carrier and universal mounting feet Wire connection Cross sections Stripped lengths Examples of suitable relays 14-pole max. 250 V AC/DC 8-pole max. 250 V AC/DC 5A 25 mA 42.5 x 32 x 62.5 5A 25 mA 42.5 x 32 x 62.5 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in Schrack RA4 and ZG4; Siemens V23 100; SDS HC 4; P+B KH/KHA; Aromat HC+HQ; OMRON MY; IDES RM/RY Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in Schrack ZL2; Siemens V23 154; Siemens V 23 162; SDS K2; P+B R 10; Aromat K Accessories Item No. Pack. Unit Item No. Pack. Unit Mounting carrier, for screw-fixing or DIN-rail mounting (with snap-fit type universal mounting feet to be ordered separately) 288-001 1 288-001 1 Universal mounting foot; snap-fit type; suitable for DIN 15, 32 and 35 rails (also see page 258) 288-002 10 288-002 10 1 99 KAMMERRELAIS® is a registered trademark of the Siemens AG Socket for KAMMRELAIS® Size II with 4 changeover contacts 1 A2 A2 31 12 •14 22 24 41 –1 –1 12 5 7 8 10 15 +4 +4 6 11 13 14 16 9 A1 A1 11 32 34 •42 44 21 Description Item No. Pack. Unit Relay socket, for AC/DC relays Relay socket, for DC relays with free-wheeling diode Relay socket, for DC relays with free-wheeling diode and LED 288-151 288-152 288-153 1 1 1 Technical Data Relay enclosure Operating voltage (dependent on the relay voltage) Nominal current Max. coil current of the LED version Dimensions (mm) L x W x H incl. mounting carrier and universal mounting feet Wire connection Cross sections Stripped lengths Examples of suitable relays 14-pole max. 250 V AC/DC 5A 25 mA 42.5 x 32 x 62.5 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in Schrack ZL4; Siemens V23 154; Siemens V 23 162; SDS K4; P+B R 10; Aromat K Accessories Item No. Pack. Unit Mounting carrier, for screw-fixing or DIN-rail mounting (with snap-fit type universal mounting feet to be ordered separately) 288-001 1 Universal mounting foot; snap-fit type; suitable for DIN 15, 32 and 35 rails (also see page 258) 288-002 10 1 Pluggable Modules - Relays 100 Relay with 1 break contact Module width 10 mm / 0.394 in Module width 10 mm / 0.394 in 82,5 mm / 3,25 in Relay with 1 make contact 50 mm / 1.97 in u 73 mm / 2.87 in v WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A2, 13, 14; Item No.: 209-952 • Marking A1, A2, 11, 12; Item No.: 209-953 5 cards, each containing 10 strips with 10 markers A1 + 13 A1 ~ 13 A1 + 11 A1 ~ 11 A2 – 14 A2 ~ 14 A2 – 12 A2 ~ 12 Description VN IN Item No. Pack. Unit Switching relay module 24 V DC 48 V DC 60 V DC 24 V AC 115 V AC 230 V AC 7.4 mA 8.6 mA 7.3 mA 10.2 mA 10.5 mA 7.3 mA 286-364 286-365 286-366 286-564 286-566 286-567 1 1 1 1 1 1 Technical Data Contact material Max. switching voltage Max. make / break current Max. continuous current Max. Switching power (resistive) Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature IN Item No. Pack. Unit 24 V DC 48 V DC 60 V DC 24 V AC 20.4 mA 11.1 mA 10.7 mA 18.5 mA 286-368 286-369 286-370 286-568 1 1 1 1 Accessories see page 138 ... 139 Accessories see page 138 ... 139 Ag Cd O + 1 μ Au 30 V DC / 250 V AC 5A/5A 5A 150 W / 1250 VA 100 mW / 200 mW 6 ms / 6 ms / 2 ms 2.5 kV 250 V / 2.5 kV / 3 Ag Cd O 250 V DC / 250 V AC 8A/8A 5A 150 W / 1250 VA 300 mW / 450 mW 10 ms / 4 ms / 3 ms 4 kV 250 V / 4 kV / 3 2 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C 1 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in VN 12 mm / 0.472 in 12 mm / 0.472 in 15 mm / 0.591 in Item No. Pack. Unit 280-618 280-608 280-762 1 1 1 12 mm / 0.472 in 12 mm / 0.472 in 15 mm / 0.591 in Item No. Pack. Unit 280-618 280-608 280-762 1 1 1 1 101 Relay with 1 changeover contact Module width 15 mm / 0.591 in Module width 15 mm / 0.591 in 1 82,5 mm / 3,25 in Relay with 1 changeover contact 50 mm / 1.97 in u 73 mm / 2.87 in v 11 11 WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A2, A2, 11, 12, 14, A1, A2, A2; Item No.: 209-994 5 cards, each containing 10 strips with 10 markers A1 ~ A1 + A2 – A2 – A2 ~ A2 ~ 12 14 12 14 Description VN IN Item No. Pack. Unit VN IN Item No. Pack. Unit Switching relay module 5/6 V DC 12 V DC 24 V DC 48 V DC 60 V DC 115 V DC 220 V DC 94.3 mA 49.4 mA 19.4 mA 11.4 mA 9.2 mA 4.8 mA 6.1 mA 286-302 286-303 286-304 286-305 286-306 286-307 286-308 1 1 1 1 1 1 1 5/6 V AC/DC 12 V AC/DC 24 V AC/DC 48 V AC/DC 60 V AC/DC 115 V AC 230 V AC 94.3 mA 49.4 mA 21.8 mA 11.4 mA 9.2 mA 4.8 mA 6.1 mA 286-502 286-503 286-504 286-505 286-506 286-507 286-508 1 1 1 1 1 1 1 Technical Data Accessories see page 138 ... 139 Accessories see page 138 ... 139 Contact material Max. switching voltage Max. make / break current Max. continuous current Max. Switching power (resistive) Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature AgNi 0.15 + HV 300 V DC / 250 V AC 16 A / 8 A (10 % continious duty) 7A 192 W / 1750 VA 261 mW / 533 mW 8 ms / 6 ms / 4 ms 4 kV 250 V / 4 kV / 3 AgNi 0.15 + HV 300 V DC / 250 V AC 16 A / 8 A (10 % continious duty) 7A 192 W / 1750 VA 261 mW / 533 mW 8 ms / 6 ms / 4 ms 4 kV 250 V / 4 kV / 3 30 x 106 switching operations 1 x 105 switching operations -25 °C ... +40 °C 30 x 106 switching operations 1 x 105 switching operations -25 °C ... +40 °C Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 1 Pluggable Modules - Relays 102 Relay with 1 changeover contact Contact 5 μm hard gold plated 82,5 mm / 3,25 in Module width 15 mm / 0.591 in 50 mm / 1.97 in u 73 mm / 2.87 in v 11 11 WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A2, A2, 11, 12, 14, A1, A2, A2; Item No.: 209-994 5 cards, each containing 10 strips with 10 markers A1 + Description VN IN Item No. Pack. Unit Switching relay module 24 V DC 48 V DC 24 V AC/DC 21.8 mA 11.4 mA 21.8 mA 286-394 286-395 286-594 1 1 1 Technical Data Contact material Max. switching voltage Max. continuous current Max. Switching power (resistive) Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature A1 ~ A2 – A2 – 12 14 12 14 Accessories see page 138 ... 139 AgNi + 5μ Au 36 V DC 1A 25 W / 261 mW / 533 mW 9 ms / 3 ms / 2 ms 4 kV 250 V / 4 kV / 3 30 x 106 switching operations 1 x 105 switching operations -25 °C ... +40 °C Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in A2 ~ A2 ~ 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 Item No. Pack. Unit 1 103 Relay with 2 changeover contacts Module width 20 mm / 0.787 in Module width 20 mm / 0.787 in 1 82,5 mm / 3,25 in Relay with 2 changeover contacts 50 mm / 1.97 in u 73 mm / 2.87 in v 12 WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking 12, A1, A2, 24, 11, 14, 21, 22; Item No.: 209-995 5 cards, each containing 10 strips with 10 markers 12 11 A1 + 14 21 14 21 A2 – 24 A2 ~ 24 22 Description VN IN Item No. Pack. Unit Switching relay module 5/6 V DC 12 V DC 24 V DC 48 V DC 60 V DC 115 V DC 220 V DC 82.8 mA 46.1 mA 21.8 mA 10.3 mA 8.8 mA 4.9 mA 5 mA 286-310 286-311 286-312 286-313 286-314 286-315 286-316 1 1 1 1 1 1 1 Technical Data Contact material Max. switching voltage Max. make / break current Max. continuous current Max. Switching power (resistive) Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature 22 VN IN Item No. Pack. Unit 5/6 V AC 12 V AC 24 V AC 48 V AC 60 V AC 115 V AC 230 V AC 174 mA 89 mA 47 mA 23.3 mA 18.1 mA 10.5 mA 5.5 mA 286-510 286-511 286-512 286-513 286-514 286-515 286-516 1 1 1 1 1 1 1 Accessories see page 138 ... 139 Accessories see page 138 ... 139 Ag Ni 0.15 300 V DC / 250 V AC 0.2 s 30 A / 10 A 7A 210 W / 1750 VA 600 mW / 1000 mW 18 ms / 3 ms / 2 ms 4 kV 250 V / 4 kV / 3 Ag Ni 0.15 300 V DC / 250 V AC 0.2 s 30 A / 10 A 7A 210 W / 1750 VA 0.8 VA / 1 VA 15 ms / 5 ms / 2 ms 4 kV 250 V / 4 kV / 3 30 x 107 switching operations 2.5 x 105 switching operations -25 °C ... +40 °C 30 x 107 switching operations 2.5 x 105 switching operations -25 °C ... +40 °C Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 11 A1 ~ 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 1 Pluggable Modules - Relays 104 Relay with 2 make contacts Module width 20 mm / 0.787 in Module width 20 mm / 0.787 in 82,5 mm / 3,25 in Relay with 1 break and 1 make contact 50 mm / 1.97 in u 73 mm / 2.87 in v WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A1, A2, A2, 11, 12, 13, 14, 23, 24; Item No.: 209-693 5 cards, each containing 10 strips with 10 markers A1 + A1 + 11 A1 ~ A1 ~ 14 A2 ~ A2 ~ Description VN IN Item No. Switching relay module 5/6 V DC 12 V DC 24 V DC 48 V DC 60 V DC 220 V DC 24 V AC 47.2 mA 19.9 mA 7.4 mA 3.9 mA 3.9 mA 3.7 mA 8.3 mA 286-318 286-319 286-320 286-321 286-322 286-324 286-520 1 1 1 1 1 1 1 Contact material Max. switching voltage Max. make / break current Max. continuous current Max. Switching power (resistive) Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature A2 – A2 – 24 VN IN Item No. Pack. Unit 5/6 V DC 12 V DC 24 V DC 48 V DC 60 V DC 220 V DC 47.2 mA 19.9 mA 7.4 mA 3.9 mA 3.9 mA 3.7 mA 286-326 286-327 286-328 286-329 286-330 286-332 1 1 1 1 1 1 Accessories see page 138 ... 139 Accessories see page 138 ... 139 Ag Sn O2 250 V DC / 380 V AC 1 s 15 A / 8 A 6A 150 W / 2000 VA 150 mW / 240 mW 10 ms / 4 ms / 1 ms 3 kV 250 V / 4 kV / 3 Ag Sn O2 250 V DC / 380 V AC 1 s 15 A / 8 A 6A 150 W / 2000 VA 150 mW / 240 mW 10 ms / 4 ms / 1 ms 3 kV 250 V / 4 kV / 3 5 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C 5 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 14 23 14 Pack. Unit Technical Data 13 12 13 12 13 A2 – A2 – A1 + A1 + 11 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 1 105 Relay with 1 break contact and 3 make contacts Module width 25 mm / 0.984 in Module width 25 mm / 0.984 in 1 82,5 mm / 3,25 in Relay with 2 break contacts and 2 make contacts 50 mm / 1.97 in u 73 mm / 2.87 in v WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking 12, A1, A2, 23, 24, 11, 13, 14, 21, 22; Item No.: 209-691 • Marking 12, A1, A2, 23, 24, 11, 13, 14, 33, 34; Item No.: 209-690 5 cards, each containing 10 strips with 10 markers 12 A1 + 11 12 11 A1 ~ 13 12 A1 + 11 13 13 12 A1 ~ 13 A2 – 23 14 21 A2 ~ 23 14 21 A2 – 23 14 33 A2 ~ 23 14 33 24 22 24 22 24 34 24 Description VN IN Item No. Pack. Unit Switching relay module 5/6 V DC 12 V DC 24 V DC 48 V DC 60 V DC 115 V DC 24 V AC 230 V AC 42.3 mA 22.2 mA 8.5 mA 5.7 mA 5.7 mA 6.6 mA 11.2 mA 16.2 mA 286-334 286-335 286-336 286-337 286-338 286-339 286-536 286-540 1 1 1 1 1 1 1 1 Technical Data Contact material Max. switching voltage Max. make / break current Max. continuous current Max. Switching power (resistive) Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Terminal block for pluggable modules, with 2conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in VN IN Item No. 5/6 V DC 12 V DC 24 V DC 48 V DC 60 V DC 115 V DC 24 V AC 115 V AC 230 V AC 42.3 mA 22.2 mA 8.5 mA 5.7 mA 5.7 mA 6.6 mA 11.2 mA 10.6 mA 16.2 mA 286-342 286-343 286-344 286-345 286-346 286-347 286-544 286-547 286-548 1 1 1 1 1 1 1 1 1 Accessories see page 138 ... 139 AuAg10 over AgNi 15 250 V DC / 250 V AC 20 A / 5 A 5A 100 W / 1000 VA 50 mW / 205 mW 8 ms / 5 ms / 1 ms 1.5 kV 250 V / 2.5 kV / 3 Au Ag 10 over Ag Ni 15 250 V DC / 250 V AC 20 A / 5 A 5A 100 W / 1000 VA 50 mW / 205 mW 9 ms / 5 ms / 2 ms 1.5 kV 250 V / 2.5 kV / 3 2 x 108 switching operations 1 x 105 switching operations -25 °C ... +40 °C 2 x 108 switching operations 1 x 105 switching operations -25 °C ... +40 °C 27 mm / 1.063 in 27 mm / 1.063 in 30 mm / 1.181 in Item No. Pack. Unit 280-639 280-629 280-765 1 1 1 34 Pack. Unit Accessories see page 138 ... 139 Accessories 11 27 mm / 1.063 in 27 mm / 1.063 in 30 mm / 1.181 in Item No. Pack. Unit 280-639 280-629 280-765 1 1 1 1 Pluggable Modules - Relays 106 Relay with 4 changeover contacts Module width 25 mm / 0.984 in Module width 35 mm / 1.378 in 82,5 mm / 3,25 in Relay with 4 make contacts 50 mm / 1.97 in u 73 mm / 2.87 in v WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking 14, A1, A2, 33, 34, 13, 23, 24, 43, 44; Item No.: 209-692 • Marking A1, A2, 32, 31, 34, 42, 41, 12, 11, 14; Item No.: 249-656 5 cards, each containing 10 strips with 10 markers A1 + A2 – 32 31 34 42 41 Description VN IN Item No. Pack. Unit Switching relay module 5/6 V DC 12 V DC 24 V DC 48 V DC 60 V DC 115 V DC 24 V AC 115 V AC 230 V AC 42.3 mA 22.2 mA 8.5 mA 5.7 mA 5.7 mA 6.6 mA 11.2 mA 10.6 mA 16.2 mA 286-350 286-351 286-352 286-353 286-354 286-355 286-552 286-555 286-556 1 1 1 1 1 1 1 1 1 Technical Data Contact material Max. switching voltage Max. make / break current Max. continuous current Max. Switching power (resistive) Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature 22 21 24 44 VN IN Item No. Pack. Unit 24 V DC 110/120 V AC 230 V AC 32 mA 9.2 mA 9.9 mA 286-375 286-578 286-579 1 1 1 Accessories see page 138 ... 139 Accessories see page 138 ... 139 Au Ag 10 over Ag Ni 15 250 V DC / 250 V AC 20 A / 5 A 5A 100 W / 1000 VA 50 mW / 205 mW 10 ms / 5 ms / 2 ms 1.5 kV 250 V / 2.5 kV / 3 Ag 60 V DC / 250 V AC 4 A AC / 2 A DC 4 A AC/DC 50 W / 1000 VA 50 mW / 205 mW 6 ms / - / 2 ms 1.5 kV 250 V / 4 kV / 3 2 x 108 switching operations 1 x 105 switching operations -25 °C ... +40 °C 5 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 12 11 14 27 mm / 1.063 in 27 mm / 1.063 in 30 mm / 1.181 in Item No. Pack. Unit 280-639 280-629 280-765 1 1 1 37 mm / 1.457 in Item No. Pack. Unit 280-636 1 1 107 Relay with 2 changeover contacts Contacts 5 μm Au Module width 15 mm / 0.591 in Module width 20 mm / 0.787 in 1 82,5 mm / 3,25 in Relay with 1 make contact for higher DC loads 50 mm / 1.97 in u 73 mm / 2.87 in v * In order to prevent the gold layer from being damaged these values should not be exceeded. Higher switching power leads to evaporation of the gold layer. The resulting deposits in the enclosure may cause sparkovers between the coil and the contact. 11 11 A1 + WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking 12, A1, A2, 24, 11, 14, 21, 22; Item No.: 209-995 5 cards, each containing 10 strips with 10 markers 12 14 21 A2 – A2 – A2 – 24 14 Description VN IN Item No. Pack. Unit Switching relay module 24 V DC 20 mA 286-376 1 Technical Data Contact material Max. switching voltage Max. make current (resistive) Max. break current 250 V DC/ 110 V DC/ 60 V DC Recommended minimum load Max. switching rate with / without load Max. continuous current Max. Switching power (resistive) Max. switching power 250 V DC/ 110 V DC/ 60 V DC Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Dielectric strength open contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Mechanical life at max. load DC (resistive) Mechanical life at max. resistive load AC Ambient operating temperature Approvals Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ ire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 11 A1 + 22 VN IN Item No. Pack. Unit 24 V DC 19.4 mA 286-384 1 Accessories see page 138 ... 139 Accessories see page 138 ... 139 AgNi 0.15 250 V DC / 250 V AC 4 s 14A 0.6 A / 1.7 A / 5 A > 12 V / 10 mA AC/DC 10 min-1 / 1200 min-1 5A 2000 VA 150 W / 187 W / 300 W 480 mW 9 ms / 3 ms / 5 ms 4 kV 2 kV 250 V / 4 kV / 3 AgCdO + 5 μm Au 36 V DC * 0.6 A / 1.7 A / 5 A 10 μA / 100 mV 50 mA * 150 W / 187 W / 300 W 500 mW 9 ms / 3 ms / 3 ms 4 kV 1 kV 250 V / 4 kV / 3 20 x 106 switching operations 1 x 107 switching operations 1 x 105 switching operations 2 x 105 switching operations 3 x 105 switching operations -25 °C ... +40 °C DIN VDE 01110/1.89 / DIN VDE 0160 and IEC 60255 / DIN VDE 0435 (corresponding parts) Pack. Item No. Unit 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in 280-619 280-609 280-763 1 1 1 -25 °C ... +40 °C 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 1 Pluggable Modules - Relays 108 Switching relay with specified switching treshold: Von 180 V ± 10 % Voff 150 V ± 10 %; 1 changeover contact Module width 15 mm / 0.591 in Low power ( 7 mW) relay module Low power drive relay (0.3 mA) through amplifier Vcc = DC 24 V 1 break and 1 make contact 82,5 mm / 3,25 in Module width 20 mm / 0.787 in 50 mm / 1.97 in u 73 mm / 2.87 in v WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A2, A2, 11, 12, 14, A1, A2, A2; Item No.: 209-994 • Marking L+, 1, L-, L-, 11, 12, 13, 14; Item No.: 209-954 5 cards, each containing 10 strips with 10 markers 11 A1 ~ A2 ~ A2 ~ L – L – 12 14 Description VN IN Item No. Switching relay module 230 V AC 4 mA 286-904 1 Contact material Max. switching voltage Max. make / break current Max. continuous current Max. Switching power (resistive) Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Turn-on treshold relay / status indication Turn-off treshold relay / status indication Control voltage output 0 Control voltage output 1 14 VN IN Item No. Pack. Unit 24 V DC 10 mA 286-906 1 Accessories see page 138 ... 139 Accessories see page 138 ... 139 AgCdO 250 V DC / 380 V AC 4 s 25 A / 18 A 5A 90 W / 1900 VA 0.8 VA / 1 VA 10 ms / 5 ms / 5 ms 4 kV 250 V / 4 kV / 3 AgCdO, with gold flash 250 V DC / 380 V AC 1 s 15 A / 8 A 6A 150 W / 2000 VA 150 mW / 240 mW 10 ms / 4 ms / 1 ms 3 kV 250 V / 4 kV / 3 5 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C 180 V ± 10 % / 122 V ± 10 % 150 V ±10 % / 113 V ±10 % 5 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C -2 V ... 3 V DC 8 V ... 30 V DC Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 12 13 1 Pack. Unit Technical Data 11 L + 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 1 109 Bistable relay with 1 changeover contact positive switching, negative switching Module width 20 mm / 0.787 in Module width 15 mm / 0.591 in 1 82,5 mm / 3,25 in Latching relay with 1 break contact and 1 make contact 50 mm / 1.97 in u 73 mm / 2.87 in v WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A1, A2, A2, 11, 12, 13, 14, 23, 24; Item No.: 209-693 • Marking A1, A3, A2, 11, 12, 14; Item No.: 249-607 5 cards, each containing 10 strips with 10 markers A1 + A1 + 11 A1 ~ A1 ~ 12 13 A2 – A2 – 14 A2 ~ A2 ~ 11 A1 + 12 A1 _ 12 13 A3 _ 14 A3 + 14 A2 + 11 A2 _ 11 12 14 Description VN IN Item No. Pack. Unit VN IN Item No. Pack. Unit Switching relay module 24 V DC 230 V AC 20.9 mA 20.9 mA 286-571 286-570 1 1 24 V DC 24 V DC 41.5 mA 41.5 mA 286-380 286-381 1 1 Technical Data Contact material Max. switching voltage Max. make / break current Max. continuous current Max. Switching power (resistive) Pull-in / operating power Pull-in/drop-out/bounce time typ. Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Accessories see page 138 ... 139 Accessories see page 138 ... 139 AuAg10 over AgNi 15 30 V DC / 250 V AC 20 A / 5 A 5A 100 W / 1000 VA 50 mW / 205 mW 8 ms / 5 ms / 1 ms 1.5 kV 250 V / 4 kV / 3 AgNi 0.15 + HV 250 V DC / 250 V AC 20 A / 8 A 6A 192 W / 1500 VA 261 mW / 533 mW 9 ms / 3 ms / 2 ms 4 kV 250 V / 4 kV / 3 2 x 108 switching operations 1 x 105 switching operations -25 °C ... +40 °C 30 x 106 switching operations 1 x 105 switching operations -25 °C ... +40 °C Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 1 Pluggable Modules - Time Relays 110 V On-delay timing 1 changeover contact specified time acc. to IEC 255, part 1 On-delay timing 1 changeover contact specified time acc. to IEC 255, part 1 Module width 20 mm / 0.787 in Module width 20 mm / 0.787 in VB VR tv t VB = operating voltage; VSt = control voltage; VR = voltage on relay; tV = delay time On-delay time relay VB on A1+ and A2- applied: relay stays in rest position delay time tV is over: relay switches to working condition WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A1, A2, A2, 12, 11, 11, 14; Item No.: 209-996 5 cards, each containing 10 strips with 10 markers A1 + A1 + 12 A2 – A2 – 11 11 14 A1 ~ A1 ~ 12 A2 ~ A2 ~ 11 11 14 Description Time range Item No. Pack. Unit Time range Item No. Pack. Unit Time relay module 0.1 - 1 s 1 - 10 s 10 - 100 s 286-600 286-602 286-604 1 1 1 0.1 - 1 s 1 - 10 s 10 - 100 s 286-610 286-612 286-614 1 1 1 Technical Data Nominal input voltage (VN) Current input at rated voltage (coil 20 °C) Contact material Max. switching voltage Max. make / break current Max. continuous current Max. Switching power (resistive) Operating power Pull-in/drop-out/bounce time typ. Reset time Repeat accuracy Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Dimensions (mm) L x H x W incl. terminal block Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 24 V DC 12.5 mA AgCdO, with gold flash 250 V DC / 380 V AC 1 s 15 A / 5 A 6A 150 W / 2000 VA 300 mW 0 ms / 15 ms / 1 ms 100 ms ±0.5 % 3 kV 250 V / 4 kV / 3 230 V AC 14.4 mA AgCdO, with gold flash 250 V DC / 380 V AC 1 s 15 A / 5 A 6A 150 W / 2000 VA 3.3 VA 0 ms / 15 ms / 1 ms 100 ms ±0.5 % 3 kV 250 V / 4 kV / 3 5 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C 20 x 82.5 x 50 5 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C 20 x 82.5 x 50 Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 1 111 Pulse lengthening, with trigger voltage 1 changeover contact 1 Module width 20 mm / 0.787 in V VB VSt VR tv t VB = operating voltage; VSt = control voltage; VR = voltage on relay; tV = delay time Pulse lengthening time relay, with auxiliary voltage VB on A1+ and A2- applied: relay stays in rest position; VSt - pulse on St+: relay switches to working condition and switches off after tV is over. WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A1, St, A2, A2, 12, 11, 11, 14; Item No.: 209-601 5 cards, each containing 10 strips with 10 markers A1 + A1 + 12 11 St + 11 A2 – 14 Description Time range Item No. Pack. Unit Time relay module 0.1 - 1 s 1 - 10 s 10 - 100 s 286-426 286-427 286-428 1 1 1 Technical Data Nominal input voltage (VN) Current input at rated voltage (coil 20 °C) Contact material Max. switching voltage Max. make / break current Max. continuous current Max. Switching power (resistive) Operating power Pull-in/drop-out/bounce time typ. Trigger voltage Reset time Repeat accuracy Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Dimensions (mm) L x H x W incl. terminal block Accessories see pages 138 ... 139 24 V DC 15.0 mA AgCdO, with gold flash 250 V DC / 380 V AC 1 s 15 A / 5 A 5A 150 W / 2000 VA 360 mW 10 ms / 0 ms / 1 ms 24 V DC 100 ms ±0.5 % 3 kV 250 V / 4 kV / 3 5 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C 20 x 82.5 x 50 Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 1 Pluggable Modules - Time Relays 112 V Off-delay timing with trigger voltage 1 changeover contact specified time acc. to IEC 255, part 1 Off-delay timing with trigger voltage 1 changeover contact specified time acc. to IEC 255, part 1 Module width 20 mm / 0.787 in Module width 20 mm / 0.787 in VB VR tv t V VSt t VB = operating voltage; VSt = control voltage; VR = voltage on relay; tV = delay time Off-delay time relay with auxiliary voltage VB on A1+ and A2- applied: relay stays in rest position; VSt on St+ applied: relay switches to working condition VSt interrupted: tV is activated; tV is over: relay switches off WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A1, St, A2, A2, 12, 11, 11, 14; Item No.: 209-601 5 cards, each containing 10 strips with 10 markers A1 + A1 + A1 ~ A1 ~ St ~ 12 11 St + 11 A2 ~ 14 Description Time range Item No. Time relay module 0.1 - 1 s 1 - 10 s 10 - 100 s 286-440 286-442 286-444 1 1 1 Nominal input voltage (VN) Current input at rated voltage (coil 20 °C) Contact material Max. switching voltage Max. make / break current Max. continuous current Max. Switching power (resistive) Operating power Pull-in/drop-out/bounce time typ. Trigger voltage Reset time Repeat accuracy Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Dimensions (mm) L x H x W incl. terminal block 14 Time range Item No. Pack. Unit 0.1 - 1 s 1 - 10 s 10 - 100 s 286-446 286-448 286-450 1 1 1 Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 24 V DC 16.0 mA Ag.-Leg., with gold flash 250 V DC / 250 V AC 26 A / 5 A 5A 100 W / 1250 VA 400 mW 15 ms / 0 ms / 2 ms 24 V DC 15 ms ±0.5 % 2 kV 250 V / 4 kV / 3 230 V AC 16.8 mA Ag.-Leg., with gold flash 250 V DC / 250 V AC 26 A / 5 A 5A 100 W / 1250 VA 3.7 VA 15 ms / 0 ms / 2 ms 230 V AC 15 ms ±0.5 % 2 kV 250 V / 2.5 kV / 3 5 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C 20 x 82.5 x 50 5 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C 20 x 82.5 x 50 Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 11 11 A2 – Pack. Unit Technical Data 12 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 1 113 V Pulse time delay relay 1 changeover contact specified time acc. to IEC 255, part 1 Pulse time delay relay 1 changeover contact specified time acc. to IEC 255, part 1 Module width 20 mm / 0.787 in Module width 20 mm / 0.787 in 1 VB VR tv t VB = operating voltage; VSt = control voltage; VR = voltage on relay; tV = delay time Pulse time delay relay VB on A1+ and A2- applied: relay switches to working condition; tV is over: relay switches off WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A1, A2, A2, 12, 11, 11, 14; Item No.: 209-996 5 cards, each containing 10 strips with 10 markers A1 + A1 + 12 A2 – A2 – 11 11 14 A1 ~ A1 ~ 12 A2 ~ A2 ~ 11 11 14 Description Time range Item No. Pack. Unit Time range Item No. Pack. Unit Time relay module 0.1 - 1 s 1 - 10 s 10 - 100 s 286-460 286-462 286-464 1 1 1 0.1 - 1 s 1 - 10 s 10 - 100 s 286-470 286-472 286-474 1 1 1 Technical Data Nominal input voltage (VN) Current input at rated voltage (coil 20 °C) Contact material Max. switching voltage Max. make / break current Max. continuous current Max. Switching power (resistive) Operating power Pull-in/drop-out/bounce time typ. Reset time Repeat accuracy Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Dimensions (mm) L x H x W incl. terminal block Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 24 V DC 37.8 mA AgCdO, with gold flash 250 V DC / 380 V AC 1 s 15 A / 5 A 5A 150 W / 2000 VA 910 mW 15 ms / 15 ms / 1 ms 100 ms ±0.5 % 2.3 kV 250 V / 4 kV / 3 230 V AC 39.7 mA AgCdO, with gold flash 250 V DC / 380 V AC 1 s 15 A / 5 A 5A 150 W / 2000 VA 10 VA 15 ms / 15 ms / 1 ms 100 ms ±0.5 % 3 kV 250 V / 2.5 kV / 3 5 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C 20 x 82.5 x 50 5 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C 20 x 82.5 x 50 Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ ire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 1 Pluggable Modules - Time Relays 114 Multirange timing relay, on-delay 4 selectable time ranges, 4 voltage ranges 1 changeover contact Module width 25 mm / 0.984 in Time range Switchposition 220 V ~ 03-3s OFF ON 3-12s 10-100s 100-800s Switch ON ON OFF 1 OFF ON OFF 2 time adjustment* 110 V ~ time ranges** 1 2 off 24 V ~ 24 V – on 0V * with trimming potentiometer; ** DIL switch Within these time ranges, time adjustment can be mode with the timming potentiometer. WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking U1, U2, U3, U4, 0V, 12, 11, 11, 14, 14; Item No.: 209-951 5 cards, each containing 10 strips with 10 markers AC 220V AC 110V AC 24V 12 11 11 DC 24V 0V 14 14 Description Item No. Pack. Unit Multirange timing relay module; on-delay, 4 voltage ranges 230 V AC, 115 V AC, 24 V AC, 24 V DC; 0.3 s ... 3 s, 3 s ... 12 s, 10 s ... 100 s, 100 s ... 800 s Time ranges selectable with DIL switch 286-616 1 Technical Data Nominal input voltage (VN) Current input at rated voltage (coil 20 °C) Contact material Max. switching voltage Max. make / break current Max. continuous current Max. Switching power (resistive) Pull-in/drop-out/bounce time typ. Reset time Repeat accuracy Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Dimensions (mm) L x H x W incl. terminal block Accessories see pages 138 ... 139 230 V AC, 115 V AC, 24 V AC, 24 V DC 30.4 mA, 32.6 mA, 20.2 mA, 17.5 mA AgNi with gold flash 30 V DC / 240 V AC 5A/5A 5A 120 W / 600 VA 0 ms / 15 ms / 3 ms 100 ms ±0.5 % 2 kV 250 V / 4 kV / 3 2 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C 25 x 82.5 x 50 Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 27 mm / 1.063 in 27 mm / 1.063 in 30 mm / 1.181 in Item No. Pack. Unit 280-639 280-629 280-765 1 1 1 Item No. Pack. Unit 1 115 Multifunction timing relay 4 selectable time ranges, 4 functions 1 changeover contact 1 Module width 20 mm / 0.787 in OFF ON on-delay OFF ON pulsing OFF ON OFF ON OFF ON off-delay with auxiliary OFF voltage ON 10 s ... 100 s S3, S4 flashing OFF ON S1, S2 OFF ON 3 s ... 12 s 0.3 s ... 3 s 100 s ... 800 s Switch position / Function Switch position / Time range S1 S2 S3 S4 (s) OFF OFF off-delay OFF OFF 100 - 800 OFF ON pulsing in make pos. OFF ON 0,3 - 3 ON OFF on-delay ON OFF 3 - 12 ON ON flashing ON ON 10 - 100 Fine adjustment of time within these time ranges can be made with the trimming potentiometer. St+ will only be connected for the function „off-delay“ with auxiliary voltage. WSB marker cards • Marking K; Item No.: 209-782 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A1, St, A2, A2, 12, 11, 11, 14; Item No.: 209-601 5 cards, each containing 10 strips with 10 markers A1 + A1 + 12 11 St + 11 A2 – 14 Description Item No. Pack. Unit Multifunction timing relay module; on-delay, offdelay with auxiliary voltage, pulsing in make position, flashing; input voltage DC 24 V; 0.3 s ... 3 s, 3 s ... 12 s, 10 s ... 100 s, 100 s ... 800 s Function and timing range are selected with a DIL switch 286-640 1 Technical Data Nominal input voltage (VN) Current input at rated voltage (coil 20 °C) Contact material Max. switching voltage Max. make / break current Max. continuous current Max. Switching power (resistive) Pull-in/drop-out/bounce time typ. Trigger voltage Reset time Repeat accuracy Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Dimensions (mm) L x H x W incl. terminal block Accessories see pages 138 ... 139 24 V DC 24 mA Ag.-Leg., with gold flash 300 V DC / 440 V AC 26 A / 5 A 5A 150 W / 1250 VA 0 ms / 0 ms / 2 ms 24 V DC 100 ms ±1 % 3 kV 250 V / 4 kV / 3 1.5 x 107 switching operations 1 x 105 switching operations -25 °C ... +40 °C 20 x 82.5 x 50 Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 1 Pluggable Modules - Optocouplers 116 Optocoupler Input 24 V DC Output 5 V, 15 V, 24 V DC/500 mA Positive switching Module width 15 mm / 0.591 in Module width 15 mm / 0.591 in 82,5 mm / 3,25 in Optocoupler Input 24 V DC Output 5 V, 15 V, 24 V DC/500 mA Negative switching 50 mm / 1.97 in u 73 mm / 2.87 in v A1 + 1 + 3 A2 – 3 2 – A2 – 2 – WSB marker cards • Marking U; Item No.: 209-789 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A2, A2, 1, 3, 2, A1, A2, A2; Item No.: 209-685 5 cards, each containing 10 strips with 10 markers A1 + 1 + A2 – A2 – Description Output Item No. Pack. Unit Output Item No. Pack. Unit Optocoupler module 5 V DC (3 V ... 6 V DC) 15 V DC (10 V ... 20 V DC) 24 V DC (20 V ... 30 V DC) 286-700 286-701 286-702 1 1 1 5 V DC (3 V ... 6 V DC) 15 V DC (10 V ... 20 V DC) 24 V DC (20 V ... 30 V DC 286-750 286-751 286-752 1 1 1 Technical Data Nominal input voltage (VN) Input voltage range Input current range Current at nominal voltage Reverse voltage transistor / Triac Max. permissible continuous current Switch on / Switch off time Max. operating frequency Leakage current at nominal voltage Collector / emitter voltage drop Vce sat Max. output (reverse current) Test voltage input / output Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature RL Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 24 V DC 12 V ... 30 V DC 5 mA ... 20 mA DC 15 mA DC 80 V DC 500 mA < 5 μs / < 15 μs 25 kHz 2.5 μA  1.2 V 5 mA ; 10 mA ; 13 mA 2.5 kV eff. 250 V / 4 kV / 3 24 V DC 12 V ... 30 V DC 5 mA ... 20 mA DC 15 mA DC 80 V DC 500 mA < 7 μs / < 15 μs 25 kHz 2.5 μA  1.2 V 5 mA ; 10 mA ; 12 mA 2.5 kV eff. 250 V / 4 kV / 3 -25 °C ... +40 °C -25 °C ... +40 °C Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in RL 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 1 117 Optocoupler Input 230 V AC Output 5 V, 15 V, 24 V DC/500 mA Positive switching Module width 15 mm / 0.591 in Module width 15 mm / 0.591 in 1 82,5 mm / 3,25 in Optocoupler Input 230 V AC Output 5 V, 15 V, 24 V DC/500 mA Negative switching 50 mm / 1.97 in u 73 mm / 2.87 in v WSB marker cards • Marking U; Item No.: 209-789 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A2, A2, 1, 3, 2, A1, A2, A2; Item No.: 209-685 5 cards, each containing 10 strips with 10 markers A1 ~ 1 + A2 ~ A2 ~ Description Output Item No. Pack. Unit Output Item No. Pack. Unit Optocoupler module 5 V DC (3.5 V ... 7 V DC) 15 V DC (10 V ... 20 V DC) 24 V DC (20 V ... 30 V DC) 286-704 286-706 286-708 1 1 1 5 V DC (3.5 V ... 7 V DC) 15 V DC (10 V ... 20 V DC) 24 V DC (20 V ... 30 V DC) 286-754 286-756 286-758 1 1 1 Technical Data Nominal input voltage (VN) Input voltage range Input current range Current at nominal voltage Reverse voltage transistor / Triac Max. permissible continuous current Switch on / Switch off time Leakage current at nominal voltage Collector / emitter voltage drop Vce sat Max. output (reverse current) Test voltage input / output Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature 1 + 3 A2 ~ 3 2 – A2 ~ 2 – RL Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 230 V AC 40 V ... 250 V AC 0.2 mA ... 2.9 mA AC 2.6 mA AC 80 V DC 500 mA < 10 ms / < 50 ms 2.5 μA  1.2 V 5 mA ; 6 mA ; 5 mA 2.5 kV eff. 250 V / 4 kV / 3 230 V AC 40 V ... 250 V AC 0.2 mA ... 2.9 mA AC 2.6 mA AC 80 V DC 500 mA < 10 ms / < 40 ms 2.5 μA  1.2 V 5 mA ; 7.5 mA ; 7.5 mA 2.5 kV eff. 250 V / 4 kV / 3 -25 °C ... +40 °C -25 °C ... +40 °C Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in A1 ~ RL 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 1 Pluggable Modules - Optocouplers 118 Optocoupler Input 24 V DC Output 24 V DC/5 A Negative switching Module width 15 mm / 0.591 in Module width 15 mm / 0.591 in 82,5 mm / 3,25 in Optocoupler Input 24 V DC Output 24 V DC/2 A Negative switching 50 mm / 1.97 in u 73 mm / 2.87 in v WSB marker cards • Marking U; Item No.: 209-789 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A2, A2, 1, 3, 2, A1, A2, A2; Item No.: 209-685 5 cards, each containing 10 strips with 10 markers A1 + 1 + A1 + 1 + A2 – 3 A2 – 3 A2 – 2 – A2 – 2 – RL RL Description Item No. Pack. Unit Item No. Pack. Unit Optocoupler module 286-720 1 286-721 1 Technical Data Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 24 V DC 15 V ... 30 V DC 7.5 mA ... 18 mA DC 13.5 mA DC 24 V DC 15 V ... 40 V DC 50 V DC 2A < 15 μs / < 40 μs 1 kHz 2.5 μA  0.5 V 2.5 kV eff. 250 V / 4 kV / 3 24 V DC 15 V ... 30 V DC 7.5 mA ... 18 mA DC 13.5 mA DC 24 V DC 15 V ... 40 V DC 50 V DC 5A < 20 μs / < 80 μs 1 kHz 2.5 μA  0.5 V 2.5 kV eff. 250 V / 4 kV / 3 -25 °C ... +40 °C -25 °C ... +40 °C Nominal input voltage (VN) Input voltage range Input current range Current at nominal voltage Output nominal voltage Output voltage range Reverse voltage transistor / Triac Max. permissible continuous current Switch on / Switch off time Max. operating frequency Leakage current at nominal voltage Collector / emitter voltage drop Vce sat Test voltage input / output Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 1 119 Optocoupler Input 24 V DC Output 24 V DC/4 A Positive switching Module width 15 mm / 0.591 in Module width 15 mm / 0.591 in 1 82,5 mm / 3,25 in Optocoupler Input 5 V DC Output 24 V DC/500 mA Positive switching 50 mm / 1.97 in u 73 mm / 2.87 in v WSB marker cards • Marking U; Item No.: 209-789 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A2, A2, 1, 3, 2, A1, A2, A2; Item No.: 209-685 5 cards, each containing 10 strips with 10 markers A1 + 1 + A2 – 3 A2 – 2 – RL A1 + 1 + A2 – 3 A2 – 2 – RL Description Item No. Pack. Unit Item No. Pack. Unit Optocoupler module 286-752/002-000 1 286-723 1 Technical Data Nominal input voltage (VN) Input voltage range Input current range Current at nominal voltage Output nominal voltage Output voltage range Reverse voltage transistor / Triac Max. permissible continuous current Switch on / Switch off time Max. operating frequency Leakage current at nominal voltage Collector / emitter voltage drop Vce sat Max. output (reverse current) Test voltage input / output Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Approvals Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 5 V DC 2 V ... 6.25 V DC 3.3 mA ... > 18.5 mA 14 mA DC 24 V DC 20 V ... 30 V DC 80 V DC 500 mA < 5 μs / < 10 μs 25 kHz 2.5 μA  1.2 V 12 mA 2.5 kV eff. 250 V / 4 kV / 3 24 V DC 15 V ... 30 V DC 7.9 mA ... 18 mA DC 14 mA DC 24 V DC 20 V ... 30 V DC 100 V DC 4 A at 6 R  15 μs /  25 μs 5 kHz 2.5 μA  1.2 V 12 mA 2.5 kV eff. 250 V / 4 kV / 3 -25 °C ... +40 °C IEC 60664 / IEC 60664A / DIN VDE 0110; pollution degree 2; overvoltage category III -25 °C ... +40 °C Accessories Terminal block for pluggable modules, w ith 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 1 Pluggable Modules - Optocouplers 120 Optocoupler Input 5 V DC 12 V DC 24 V DC Output 230 V AC/50 mA ... 1 A Module width 15 mm / 0.591 in Module width 15 mm / 0.591 in 82,5 mm / 3,25 in Optocoupler Input 5 V DC 12 V DC 24 V DC Output 110 V DC/1.6 A Negative switching 50 mm / 1.97 in u 73 mm / 2.87 in v A1 + 1 + A2 – 3 A2 – 2 – A1 + RL 1 ~ Zero Volt switch WSB marker cards • Marking U; Item No.: 209-789 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A2, A2, 1, 3, 2, A1, A2, A2; Item No.: 209-685 • Marking A1, A2, A2, 1, 2, 2, A1, A2, A2; Item No.: 209-686 5 cards, each containing 10 strips with 10 markers A2 – A2 – 2 ~ 2 ~ RL ~ Description Input Item No. Pack. Unit Input Item No. Pack. Unit Optocoupler module 5 V DC (4.5 V ... 6,5 V DC) 12 V DC (10 V ... 20 V DC) 24 V DC (15 V ... 30 V DC) 286-726 286-728 286-730 1 1 1 5 V DC (3.5 V ... 7.5 V DC) 12 V DC (9 V ... 18 V DC) 24 V DC (10 V ... 30 V DC) 286-732 286-733 286-734 1 1 1 Technical Data Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 6.5 mA ... 20 mA DC 4 mA ... 12 mA DC 3.5 mA ... 8 mA DC 6.5 mA DC 6.4 mA DC 6.2 mA DC 110 V DC 99 V ... 121 V DC 150 V DC 1.6 A at 69 R  20 μs /  0.5 ms 350 Hz 3 μA  0.5 V 0.5 mA ... 17 mA DC 4 mA ... 11 mA DC 2 mA ... 8 mA DC 6 mA DC Input current range Current at nominal voltage Output nominal voltage Output voltage range Reverse voltage transistor / Triac Max. permissible continuous current Switch on / Switch off time Max. operating frequency Leakage current at nominal voltage Collector / emitter voltage drop Vce sat Voltage drop at output Test voltage input / output Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in 230 V AC 24 V ... 280 V AC 600 V AC 1A 1 half-wave ms / 1 half-wave ms 5 mA 2.5 kV eff. 250 V / 4 kV / 3 < 1.7 V AC 2.5 kV eff. 250 V / 4 kV / 3 -25 °C ... +40 °C -25 °C ... +40 °C Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 1 121 Optocoupler Input 24 V DC Output 60 V DC/100 mA Module width 15 mm / 0.591 in Module width 10 mm / 0.394 in 1 82,5 mm / 3,25 in Optocoupler Input 10 V ... 30 V AC/DC Output 24 V DC/1 mA ... 0.5 A Negative switching 50 mm / 1.97 in u 73 mm / 2.87 in v WSB marker cards • Marking U; Item No.: 209-789 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A2, A2, 1, 3, 2, A1, A2, A2; Item No.: 209-685 • Marking A1, A2, A2, 1, 2, 2, A1, A2, A2; Item No.: 209-686 5 cards, each containing 10 strips with 10 markers A1 ~ 1 + A2 ~ 3 A2 ~ 2 – 1 + A1 + RL RL 2 – A2 – Description Item No. Pack. Unit Item No. Pack. Unit Optocoupler module 286-725 1 286-791 1 Technical Data Nominal input voltage (VN) Input voltage range Input current range Current at nominal voltage Output nominal voltage Output voltage range Reverse voltage transistor / Triac Max. permissible continuous current Switch on / Switch off time Max. operating frequency Leakage current at nominal voltage Collector / emitter voltage drop Vce sat Max. output (reverse current) Voltage drop at output Test voltage input / output Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 10 V ... 30 V AC/DC 10 V ... 30 V AC/DC 2 mA ... 7 mA AC/DC 24 V DC 15 V ... 30 V DC 7.5 mA ... 18 mA DC 14 mA 60 V DC 20 V ... 60 V DC 80 V DC 100 mA 10 μs / 50 μs 3 kHz 2.5 μA 24 V DC 20 V ... 30 V DC 80 V DC 500 mA < 5 ms / < 30 ms max. 2.5 μA 1V 6.5 mA ... 10 mA DC Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 17 mm / 0.669 in 17 mm / 0.669 in 20 mm/ 0.787 in 2.5 kV eff. 250 V / 4 kV / 3 2V 2.5 kV eff. 250 V / 4 kV / 3 -25 °C ... +40 °C -25 °C ... +40 °C Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 12 mm / 0.472 in 12 mm / 0.472 in 15 mm / 0.591 in Item No. Pack. Unit 280-618 280-608 280-762 1 1 1 1 Pluggable Modules - Optocouplers 122 Dual channel optocoupler 2 inputs 2 x 24 V DC 2 outputs 2 x 24 V DC/2 x 250 mA Module width 10 mm / 0.394 in Module width 20 mm / 0.787 in 82,5 mm / 3,25 in Optocoupler Input 24 V DC Output 60 V DC/100 mA 50 mm / 1.97 in u 73 mm / 2.87 in v WSB marker cards • Marking U; Item No.: 209-789 • Marking 1 ... 10; Item No.: 209-702 • Marking A1, A2, A2, 1, 2, 2, A1, A2, A2; Item No.: 209-686 • Marking A1+, A1+, A2-, A2-, 1, RL1, Rl2, 2; Item No.: 209-955 • Marking A1+, A1+, A2-, A2-, 1+, 1+, A, 2-; Item No.: 249-651 5 cards, each containing 10 strips with 10 markers 1 + A1 + RL 2 – A2 – 1 + RL 2 – 3 + R L 4 – A1 + A2 – A1 + A2 – Description Item No. Pack. Unit Item No. Pack. Unit Optocoupler module 286-794 1 286-792 1 Technical Data Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 24 V DC 18 V ... 30 V DC 2 mA ... 5 mA DC 4 mA DC 60 V DC 20 V ... 60 V DC 80 V DC 100 mA 80 μs / 100 μs 1.5 kHz 2.5 μA 24 V DC 7.5 V ... 30 V DC 4 mA ... 19 mA DC 15 mA DC 24 V DC 20 V ... 30 V DC 80 V DC 250 mA < 60 μs / < 120 μs 1.5 kHz 2.6 μA < 2.5 V Nominal input voltage (VN) Input voltage range Input current range Current at nominal voltage Output nominal voltage Output voltage range Reverse voltage transistor / Triac Max. permissible continuous current Switch on / Switch off time Max. operating frequency Leakage current at nominal voltage Collector / emitter voltage drop Vce sat Voltage drop at output Test voltage input / output Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 12 mm / 0.472 in 12 mm / 0.472 in 15 mm / 0.591 in 2V 2.5 kV eff. 250 V / 4 kV / 3 2.5 kV eff. 250 V / 4 kV / 3 -25 °C ... +60 °C -25 °C ... +40 °C Item No. Pack. Unit 280-618 280-608 280-762 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 1 123 Optocoupler with 2 inverted outputs Input 24 V DC Output 2 x 24 V DC/500 mA Optocoupler with bridge plug and programmable outputs Input 24 V DC Output 24 V DC, Short-circuit protected, positive switching Module width 20 mm/ 0.787 in Module width 20 mm / 0.787 in 286-938: Optocoupler module with short-circuit protected, positive switching output. Two sockets with plug for programming the output. Independent of the input signal the output can be switched over to “H” (high) or “L” (low) by means of a bridge plug (supplied with the module). The short-circuit protected output is equipped with a current limiter which limits load currents above 800 mA to 200 mA. The maximum operating time of the current limiter is 60 s. Status indication: • Input green LED • Output yellow LED • Short circuit red LED A1 + 1 + A1 + A1 + 1 + 1 + RL1 A1 + A2 – RL2 A2 – A2 – 2 – H 1 A L A2 – RL 2 – Description Item No. Pack. Unit Item No. Pack. Unit Optocoupler module 286-790 1 286-938 1 Technical Data Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 24 V DC 20 V ... 30 V DC 7 mA ... 12 mA DC 9 mA DC 24 V DC 20 V ... 30 V DC 100 V DC 500 mA 4 μs / 15 μs 2.5 kHz 2.5 μA < 1.2 V 2.5 kV eff. 250 V / 4 kV / 3 24 V DC 10 V ... 30 V DC 4 mA ... 19 mA DC 14 mA DC 24 V DC 20 V ... 30 V DC 50 V DC 300 mA (800 mA max. 30 s) < 5 μs / < 25 μs 20 kHz at 80 R < 1 μA < 1.1 V 5.5 mA (Input high, output low); 3 mA (Input low, output low); 11 mA (Output high) programmed with bridge plug 2.5 kV eff. 250 V / 4 kV / 3 -25 °C ... +40 °C -25 °C ... +40 °C Nominal input voltage (VN) Input voltage range Input current range Current at nominal voltage Output nominal voltage Output voltage range Reverse voltage transistor / Triac Max. permissible continuous current Switch on / Switch off time Max. operating frequency Leakage current at nominal voltage Collector / emitter voltage drop Vce sat Max. output (reverse current) Test voltage input / output Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 1 Pluggable Modules - S0 Optocouplers 124 The optocoupler for the S0 current meter interface sends counter pulses from the supply lines. Via this interface the user has the possibility to access data which is created by pulse generating current meters with a S0 current meter interface in accordance with DIN 43 864. The user can extract the data without affecting the S0 circuit and use them for their own evaluations, for example, optimizing energy consumption by reducing peak demands. The optocoupler gets the input signal via a shunt resistance that is integrated in a terminal block for pluggable modules. Two parallel connected electrical contacts at the output allow reading of the S0 counter pulses. The optocoupler can be replaced without having to open the current meter circuit. When using passive metering systems, S0 power packs have to be added. Power optocoupler for S0 current meter interface with AC output Power optocoupler for S0 current meter interface with DC output Module width 20 mm / 0.787 in Module width 20 mm / 0.787 in A1 + Technical Data Input current 1-Signal (H) Input current 0-Signal (L) Switch-on treshold Switch-off treshold Transmission frequency Input wiring Operating voltage range Peak reverse voltage Continuous current Surge current t = 20 ms Min. load current Voltage drop at I max Leakage current when turned off Switch on / Switch off time Output circuit Test voltage input / output Wire connection Ambient operating temperature Storage temperature Approvals Mounting position Dimensions (mm) L x H x W incl. terminal block 1 3 14 23 A2 – 14 23 A2 – 24 Description S0 interface Terminal block for pluggable modules, with shunt resistance A1 + 1 3 22 mm / 0.866 in wide Item No. Pack. Unit 286-740 286-740/001-000 1 1 24 22 mm / 0.866 in wide Item No. Pack. Unit 286-741 286-740/001-000 1 1 Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 > 10 mA ... < 27 mA < 2 mA > 8.5 mA < 7 mA > 10 mA ... < 27 mA < 2 mA > 8.5 mA < 7 mA 15/35 mA Output 0 V 10 V ... 250 V AC/DC 45 mW / 900 mW 3V 5 ms 24 V DC 61 mA 50 mA 24 V DC 1.2 W 2 kV 250 V / 4 kV / 3 80 mA ... 6 A AC Current < 80 mA Output 24 V DC Current > 80 mA Output 0 V 5 V ... 250 V AC 1 mVA / 2.8 VA 13 mV ... 460 mV 40 ms 24 V DC 41 mA 50 mA 24 V DC 1.2 W 2 kV 250 V / 4 kV / 3 -25 °C ... +40 °C Operation: LED = green output LOW, current interruption: LED = red output HIGH -25 °C ... +40 °C Operation: LED = green output LOW, current interruption: LED = red output HIGH Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in wide 22 mm / 0.866 in wide 25 mm / 0.984 in wide Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in wide 22 mm / 0.866 in wide 25 mm / 0.984 in wide Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 1 129 AC current flow monitoring module 0.2 A ... 3 A, adjustable (286-664) 1 A ... 10 A, adjustable (286-665) 1 changeover contact (1 u) Module width 15 mm / 0.591 in Module width 25 mm / 0.984 in 1 82,5 mm / 3,25 in DC current flow monitoring module 0.4 A ... 3.5 A 1 make contact 50 mm / 1.97 in u 73 mm / 2.87 in v WSB marker card • Marking U; Item No.: 209-789 • Marking 1 ... 10; Item No.: 209-702 • Marking Lin, Lin, Lout, 11, 14, 14, Lin, Lin, Lout; Item No.: 249-654 • Marking Lin, Lin, Lout, Lout, 24V, 11, 12, 14, 0V; Item No.: 209-997 5 cards, each containing 10 strips with 10 markers I I I I 286-662 1 Pack. Unit 286-664 286-665 1 1 0.4 A ... 3.5 A DC (-20 °C ... +40 °C); 0.4 A ... 3 A DC (-20 °C ... +60 °C); 0.4 A ... 2 A DC (-20 °C ... +70 °C) 12 V ... 28 V DC 45 mW / 630 mW 0.2 A ... 3 A AC (286-664) 1 A ... 10 A AC (286-665) 9 mVA / 1.3 VA (286-664) 23 mVA / 8.5 VA (286-665) min. 0.2 A (adjustable) (286-664) min. 1 A (adjustable) (286-665) 0.35 A / 0.07 A 24 mV ... 210 mV 44 mV ... 430 mV (286-664) 23 mV ... 850 mV (286-665) 300 ms (286-664) 200 ms (286-665) 1 changeover contact 24 V DC 17 mA (286-664) 28 mA (286-665) 5A 250 V AC 1250 VA 2.5 kV 250 V / 4 kV / 3 0.5 ms 1 make contact 0.5 A 200 V DC 10 W 1.5 kV -25 °C ... +40 °C Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in Item No. Accessories see pages 138 ... 139 Response time Switching current Switching voltage Switching power Dielectric strength input / output Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Status indication 0V Accessories see pages 138 ... 139 Switching treshold Output Operating voltage Power consumption 14 14 Current flow monitoring module Turn on / off point Voltage drop 12 U I Pack. Unit Voltage range Nominal power consumption min / max 11 I 14 Item No. Current monitoring range +24V I Description Technical Data I 11 17 mm / 0.669 in wide 17 mm / 0.669 in wide 20 mm/ 0.787 in wide -25 °C ... +40 °C Current < switching treshold LED red, Relay switched Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 27 mm / 1.063 in wide 27 mm / 1.063 in wide 30 mm / 1.181 in wide Item No. Pack. Unit 280-639 280-629 280-765 1 1 1 1 Pluggable Modules - Bridge Rectifiers 130 Bridge with varistor protection for input voltage 250 V AC/1 A Module width 15 mm / 0.591 in Module width 15 mm / 0.591 in 82,5 mm / 3,25 in Bridge with varistor protection for input voltage 24 V AC/1 A 50 mm / 1.97 in u 73 mm / 2.87 in v ~ WSB marker card • Marking V; Item No.: 209-784 • Marking 1 ... 10; Item No.: 209-702 • Marking +/-; Item No.: 209-652 5 cards, each containing 10 strips with 10 markers + ~ + – ~ – ~ Description Item No. Pack. Unit Item No. Pack. Unit Bridge rectifiers 286-830 1 286-840 1 Technical Data Input voltage Nominal current Current pulse limit Max. charging capacitor Max. nominal operating voltage input (Varistor) Max. nominal operating voltage output (Varistor) Ambient operating temperature Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 24 V AC 1A 10 A (10 ms) 2200 μF 35 V 60 V -25 °C ... +40 °C 250 V AC 1A 10 A (10 ms) 500 μF 250 V 300 V -25 °C ... +40 °C Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 17 mm / 0.669 in wide 17 mm / 0.669 in wide 20 mm/ 0.787 in wide Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 17 mm / 0.669 in wide 17 mm / 0.669 in wide 20 mm/ 0.787 in wide Item No. Pack. Unit 280-619 280-609 280-763 1 1 1 1 131 Bridge rectifier for input voltage 250 V AC/1 A 1 Module width 10 mm / 0.394 in ~ + – ~ Description Item No. Pack. Unit Bridge rectifiers 280-804/281-419 1 Technical Data Input voltage Nominal current Max. charging capacitor Ambient operating temperature Accessories see pages 138 ... 139 250 V AC 1A 500 μF -25 °C ... +40 °C Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 12 mm / 0.472 in wide 12 mm / 0.472 in wide 15 mm / 0.591 in wide Item No. Pack. Unit 280-618 280-608 280-762 1 1 1 1 Pluggable Modules - Fuses 132 Fuse modules for replaceable microfuses 5 x 20 mm; max. 6.3 A with blown fuse indication Neon lamp 230 V AC/DC Module width 10 mm / 0.394 in Module width 10 mm / 0.394 in 82,5 mm / 3,25 in Fuse modules for replaceable microfuses 5 x 20 mm; max. 6.3 A with blown fuse indication LED green 24 V AC/DC 50 mm / 1.97 in u 73 mm / 2.87 in v WSB marker card • Marking F1 ... F10; Item No.: 209-787 • Marking 1 ... 10; Item No.: 209-702 • Marking +/-; Item No.: 209-652 5 cards, each containing 10 strips with 10 markers + + – – Description Item No. Pack. Unit Fuse module, with blown fuse indication 286-890 1 Technical Data Operating voltage Max. fuse capacity Operating power Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Leakage current in case of blown fuse Test voltage ˜ ˜ ˜ Item No. Pack. Unit 286-891 1 Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 24 V AC/DC 6.3 A 100 mW 250 V / 4 kV / 3 230 V AC/DC 6.3 A 100 mW 250 V / 4 kV / 3 -25 °C ... +40 °C 5 mA 2.5 kV -25 °C ... +40 °C 0.5 mA 2.5 kV Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator with 4-conductor terminal blocks, orange separator with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in ˜ 12 mm / 0.472 in wide 12 mm / 0.472 in wide 15 mm / 0.591 in wide Item No. Pack. Unit 280-618 280-608 280-762 1 1 1 12 mm / 0.472 in wide 12 mm / 0.472 in wide 15 mm / 0.591 in wide Item No. Pack. Unit 280-618 280-608 280-762 1 1 1 1 Pluggable Modules - Diode Gates 133 Diode gate module with 3, 5, 7 or 9 diodes 1 N 4007, common cathode Module width see Item No. Module width see Item No. 1 82,5 mm / 3,25 in Diode gate module with 3, 5, 7 or 9 diodes 1 N 4007, common anode 50 mm / 1.97 in u 73 mm / 2.87 in v WSB marker card • Marking V; Item No.: 209-784 • Marking 1 ... 10; Item No.: 209-702 • Marking +/-; Item No.: 209-652 5 cards, each containing 10 strips with 10 markers 6 1 2 9 10 5 Description Module width Diode gate module with 3 diodes with 5 diodes with 7 diodes with 9 diodes 10 mm / 0.394 15 mm / 0.591 20 mm / 0.787 25 mm / 0.984 Technical Data Operating voltage Peak reverse voltage Rectified current for each diode, resistive Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature in in in in 6 9 10 5 Item No. Pack. Unit Module width 286-803 286-805 286-807 286-809 1 1 1 1 10 mm / 0.394 15 mm / 0.591 20 mm / 0.787 25 mm / 0.984 in in in in Item No. Pack. Unit 286-813 286-815 286-817 286-819 1 1 1 1 Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 250 V AC/DC 1000 V 1A 250 V / 4 kV / 3 250 V AC/DC 1000 V 1A 250 V / 4 kV / 3 -25 °C ... +40 °C -25 °C ... +40 °C Item No. Pack. Unit 12 mm / 0.472 in wide 12 mm / 0.472 in wide 15 mm / 0.591 in wide 280-618 280-608 280-762 1 1 1 17 mm / 0.669 in wide 17 mm / 0.669 in wide 20 mm / 0.787 in wide 280-619 280-609 280-763 22 mm / 0.866 in wide 22 mm / 0.866 in wide 25 mm / 0.984 in wide 27 mm / 1.063 in wide 27 mm / 1.063 in wide 30 mm / 1.181 in wide Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 1 2 Item No. Pack. Unit 12 mm / 0.472 in wide 12 mm / 0.472 in wide 15 mm / 0.591 in wide 280-618 280-608 280-762 1 1 1 1 1 1 17 mm / 0.669 in wide 17 mm / 0.669 in wide 20 mm/ 0.787 in wide 280-619 280-609 280-763 1 1 1 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in wide 22 mm / 0.866 in wide 25 mm / 0.984 in wide 280-638 280-628 280-764 1 1 1 280-639 280-629 280-765 1 1 1 27 mm / 1.063 in wide 27 mm / 1.063 in wide 30 mm / 1.181 in wide 280-639 280-629 280-765 1 1 1 1 Pluggable Modules - AND Gate and LED Indicator 134 LED indicator module with 8 LED, common cathode Module width 25 mm / 0.984 in Module width 25 mm / 0.984 in 82,5 mm / 3,25 in AND gate module with 6 inputs Relay output with 1 make contact 50 mm / 1.97 in u 73 mm / 2.87 in v 13 14 & A 5 4 3 4 3 E6 2 2 8 E1 7 1 6 – 1 + 5 6 0 0 WSB marker card • Marking D; Item No.: 209-783 • Marking 1 ... 10; Item No.: 209-702 • Marking +, -, 1, 2, 3, 13, 14, 4, 5, 6; Item No.: 249-608 5 cards, each containing 10 strips with 10 markers Description Item No. Pack. Unit Item No. Pack. Unit Gate module 286-826 1 286-822 1 Technical Data Operating voltage Operating voltage range Gate voltage - input Power consumption at VN Relay output Max. switching voltage Max. continuous current Max. Switching power (resistive) Dielectric strength input / output Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 24 V DC 24 V ... 27.5 V DC DC 24 V max. 34.6 mA make contact 250 V AC / 120 V DC 3A 120 W / 750 VA 2.5 kV 250 V / 4 kV / 3 24 V DC 20 V ... 26 V DC -25 °C ... +40 °C Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 5.1 mA each LED 27 mm / 1.063 in wide 27 mm / 1.063 in wide 30 mm / 1.181 in wide -25 °C ... +40 °C Item No. Pack. Unit 280-639 280-629 280-765 1 1 1 27 mm / 1.063 in wide 27 mm / 1.063 in wide 30 mm / 1.181 in wide Item No. Pack. Unit 280-639 280-629 280-765 1 1 1 1 Pluggable Modules - Flip-Flop 135 Flip-Flop Operating voltage 24 V DC 1 82,5 mm / 3,25 in Module width 15 mm / 0.591 in 50 mm / 1.97 in u 73 mm / 2.87 in v 24V IN OUT 0V 0V Description Item No. Pack. Unit Flip Flop module 286-825 1 Technical Data Input voltage Input current Input voltage (High Signal) Input voltage (Low Signal) Pulse frequency Min. output voltage Max. output current Operating voltage Operating voltage range Power consumption Reverse voltage transistor Test voltage input/output Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Accessories see pages 138 ... 139 24 V DC (± 10 %) 0.25 mA >7V 100 mA / 12 V AC/DC 400 mW 7 ms / 3 ms / 3 ms continuous duty 5 kV 1 kV 250 V / 4 kV / 3 AgNi 90/10 VN -15 % ... +10 % 250 V AC/DC 4 s 25 A (AC) 12 A 3000 VA AC, DC see load limit curve > 100 mA / 12 V AC/DC 0.96 VA 15 ms / 15 ms / 3 ms continuous duty 5 kV 1 kV 250 V / 4 kV / 3 30 x 106 switching operations 1.2 x 103 switching operations -25 °C ... +40 °C -40 °C ... +85 °C 17.5 x 55 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in DIN VDE 0160 and IEC 60255; DIN VDE 0435 (corresp. parts) 30 x 106 switching operations 1.2 x 103 switching operations -25 °C ... +40 °C -40 °C ... +85 °C 17.5 x 55 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in DIN VDE 0160 and IEC 60255; DIN VDE 0435 (corresp. parts) 1 141 Voltage (V) Relay with 2 changeover contacts (2 u) Nominal input voltage VN 24 V, 48 V, 110 V DC 300 Relay with 2 changeover contacts (2 u) Nominal input voltage VN 24 V AC/DC, 115 V, 230 V AC 1 2-pole resistive load 200 2 contacts in serie 100 1 contact 50 40 30 20 10 0.1 0.2 0.5 1 2 5 10 20 Current (A) Other coil voltages contact factory A1 + 14 12 24 22 A2 – A2 – 21 11 14 12 24 22 A1 ~ A2 ~ A2 ~ 21 11 Description VN IN Item No. Pack. Unit VN IN Item No. Pack. Unit Relay modules in DIN-rail mounted enclosure, for DIN 35 rail 24 V DC 48 V DC 110 V DC 21 mA 13 mA 6 mA 789-312 789-313 789-315 1 1 1 24 V AC/DC 115 V AC 230 V AC 22 mA 7.6 mA 4.2 mA 789-512 789-515 789-516 1 1 1 Technical Data Contact material Input voltage range Max. switching voltage Max. make current (resistive) at a 10 % duty cycle Max. continuous current Max. Switching power (resistive) Recommended minimum load Operating power Pull-in/drop-out/bounce time typ. Nominal operating mode Dielectric strength contact-coil (AC, 1 min) Dielectric strength open contact Dielectric strength contact-contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 146 Accessories see page 146 AgNi 90/10 VN -15 % ... +10 % 250 V AC/DC 4 s / 15 A 8A 2000 VA AC, DC see load limit curve > 100 mA / 12 V AC/DC 400 mW 7 ms / 2 ms / 3 ms continuous duty 5 kV 1 kV 2.5 kV 250 V / 4 kV / 3 AgNi 90/10 VN -15 % ... +10 % 250 V AC/DC 4 s / 15 A 8A 2000 VA AC, DC see load limit curve > 100 mA / 12 V AC/DC 0.96 VA 7 ms / 2 ms / 3 ms continuous duty 5 kV 1 kV 1.5 kV 250 V / 4 kV / 3 3 x 107 switching operations -25 °C ... +40 °C -40 °C ... +85 °C 17.5 x 55 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in DIN VDE 0160 and IEC 60255; DIN VDE 0435 (corresp. parts) 5 x 106 switching operation -25 °C ... +40 °C -40 °C ... +85 °C 17.5 x 55 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in DIN VDE 0160 and IEC 60255; DIN VDE 0435 (corresp. parts) 1 Relay Modules in DIN-Rail Mounted Enclosure 142 Contact voltage, V Relay with 2 break and 2 make contacts (2 ar) Nominal input voltage VN 24 V DC Relay with 2 break and 2 make contacts ( 2 ar) Nominal input voltage VN 12 V, 24 V AC/DC 1000 DC resistive load AC resistive load 100 10 0.1 1 10 Contact current, A Note:Inductive loads have to be attenuated by an appropriate protective circuit in order to protect relay coils and contacts! 14 24 12 22 14 24 12 22 A1 + A2 – A2 – A1 ~ A2 ~ A2 ~ 13 23 11 21 Description VN IN Item No. Pack. Unit Relay modules in DIN-rail mounted enclosure, for DIN 35 rail 24 V DC 12 mA 789-336 1 Technical Data Contact material Input voltage range Max. switching voltage Max. switching current Max. Switching power (resistive) Recommended minimum load Pull-in/drop-out/bounce time typ. Nominal operating mode Max. switching frequency with load Dielectric strength contact-coil (AC, 1 min) Dielectric strength open contact Dielectric strength contact-contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals 13 23 11 21 VN IN Item No. Pack. Unit 12 V AC/DC 24 V AC/DC 21 mA 12 mA 789-535 789-536 1 1 Accessories see page 146 Accessories see page 146 AuAg10 over AgNi 15 VN -15 % ... +10 % 250 V AC / 30 V DC 4 A AC / 3 A DC 1000 VA / 90 W, resistive see load limit curve > 100 μA / 100 mV DC 15 ms / 10 ms / 1 ms continuous duty 6 min-1 1.5 kV 0.75 kV 1 kV 230 V / 2.5 kV / 3 AuAg10 over AgNi 15 VN -15 % ... +10 % 250 V AC / 30 V DC 4 A AC / 3 A DC 1000 VA / 90 W, resistive see load limit curve > 100 μA / 100 mV DC 20 ms / 20 ms / 1 ms continuous duty 6 min-1 1.5 kV 0.75 kV 1 kV 230 V / 2.5 kV / 3 -25 °C ... +40 °C -40 °C ... +85 °C 17.5 x 55 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in DIN VDE 0110 Part1 / 4.97 IEC 60 664-1; DIN VDE 0435 (corresp. parts), EN 61 810 -25 °C ... +40 °C -40 °C ... +85 °C 17.5 x 55 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in DIN VDE 0110 Part1 / 4.97 IEC 60 664-1; DIN VDE 0435 (corresp. parts), EN 61 810 1 143 Contact voltage, V Relay with 4 make contacts (4 a) Nominal input voltage VN 24 V DC Relay with 4 make contacts (4 a) Nominal input voltage VN 12 V, 24 V AC/DC 1 1000 DC resistive load AC resistive load 100 10 0.1 1 10 Contact current, A 14 24 34 44 14 24 34 44 A1 + A1 ~ A2 – A2 – A2 ~ A2 ~ 13 23 33 43 Description VN IN Item No. Pack. Unit Relay modules in DIN-rail mounted enclosure, for DIN 35 rail 24 V DC 12 mA 789-352 1 Technical Data Contact material Input voltage range Max. switching voltage Max. switching current Max. Switching power (resistive) Recommended minimum load Pull-in/drop-out/bounce time typ. Nominal operating mode Max. switching frequency with load Dielectric strength contact-coil (AC, 1 min) Dielectric strength open contact Dielectric strength contact-contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals 13 23 33 43 VN IN Item No. Pack. Unit 12 V AC/DC 24 V AC/DC 21 mA 12 mA 789-551 789-552 1 1 Accessories see page 146 Accessories see page 146 AuAg10 over AgNi 15 VN -15 % ... +10 % 250 V AC / 30 V DC 4 A AC / 3 A DC 1000 VA / 90 W, resistive see load limit curve > 100 μA / 100 mV DC 15 ms / 10 ms / 1 ms continuous duty 6 min-1 1.5 kV 0.75 kV 1 kV 230 V / 2.5 kV / 3 AuAg10 over AgNi 15 VN -15 % ... +10 % 250 V AC / 30 V DC 4 A AC / 3 A DC 1000 VA / 90 W, resistive see load limit curve > 100 μA / 100 mV DC 20 ms / 20 ms / 1 ms continuous duty 6 min-1 1.5 kV 0.75 kV 1 kV 230 V / 2.5 kV / 3 -25 °C ... +40 °C -40 °C ... +85 °C 17.5 x 55 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in DIN VDE 0110 Part1 / 4.97 IEC 60 664-1; DIN VDE 0435 (corresp. parts), EN 61 810 -25 °C ... +40 °C -40 °C ... +85 °C 17.5 x 55 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in DIN VDE 0110 Part1 / 4.97 IEC 60 664-1; DIN VDE 0435 (corresp. parts), EN 61 810 1 Relay Modules in DIN-Rail Mounted Enclosure 144 Latching relay with 1 make contact (1 a) Nominal input voltage VN 24 V DC 55 mm / 2.17 in Latching relay with 1 make contact (1 a) Nominal input voltage VN 230 V AC 90 mm / 3.54 in Lamp load: max. load 1500 W Fluorescent lamp, dual circuit: max. load 20 x 58 W series compensated Electronic ballasts: 10 x 58 W A1 + 14 A1 ~ 14 A2 – 13 A2 ~ 13 Description VN IN Item No. Pack. Unit VN IN Item No. Pack. Unit Relay modules in DIN-rail mounted enclosure, for DIN 35 rail 24 V DC 42 mA 789-571 1 230 V AC 10 mA 789-570 1 Technical Data Contact material Input voltage range Max. switching voltage Min. switching current Max. switching current Max. continuous current Max. Switching power (resistive) Minimum switch-on time Minimum break time Coil control Fuse protection Nominal operating mode Max. switching frequency with load Max. switching frequency without load Dielectric strength contact-coil (AC, 1 min) Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 146 Accessories see page 146 AgCdO VN -15 % ... +10 % 400 V AC 0.1 A 50 A (20 ms) 16 A 4000 VA AC / 300 W DC 40 ms 180 ms Impuls circuit breaker max. 16 A B-charakteristic continuous duty 6 min-1 4 s-1 4 kV 250 V / 4 kV / 3 AgCdO VN -15 % ... +10 % 400 V AC 0.1 A 50 A (20 ms) 16 A 4000 VA AC / 300 W DC 40 ms 180 ms Impuls circuit breaker max. 16 A B-charakteristic continuous duty 6 min-1 4 s-1 4 kV 250 V / 4 kV / 3 1 x 105 switching operations 5 x 104 switching operations -25 °C ... +40 °C -40 °C ... +85 °C 17.5 x 55 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in DIN VDE 0160 and IEC 60255; DIN VDE 0435 (corresp. parts); DIN VDE 0632 1 x 105 switching operations 5 x 104 switching operations -25 °C ... +40 °C -40 °C ... +85 °C 17.5 x 55 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in DIN VDE 0160 and IEC 60255; DIN VDE 0435 (corresp. parts); DIN VDE 0632 1 145 Current (A) Relay with 1 make contact (1a), manual-0-automatic switch Capability of different lamp loads: (switching operations acc. to EN 60669) 100 AC resistive load 10 1 10 100 1000 Voltage (V) (+24V) Note:Inductive loads have to be attenuated by an appropriate protective circuit in order to protect relay coils and contacts! A1 + A3 + A 0 1 A = Automatisk 0 = OFF 1 = Manuell PA 14 A2 A2 - 13 13 Description VN Item No. Pack. Unit Relay modules in DIN-rail mounted enclosure, for DIN 35 rail 24 V DC 789-323 1 Technical Data Contact material Input voltage range Current input at rated voltage (coil 20 °C) Max. switching voltage Max. make current Max. continuous current Max. Switching power (resistive) Recommended minimum load Operating power Pull-in/drop-out/bounce time typ. Nominal operating mode Dielectric strength contact-coil Surge capacity open contact Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mechanical life Mechanical life at max. load (resistance) Mechanical life at max. lamp load Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 146 Ag-Legierung VN -15 % ... +20 % 19 mA 250 V AC 120 A at 230 V AC (50 ms) 16 A 4000 VA AC, resistance see load limit curve > 100 mA / 12 V AC/DC 400 mW 15 ms / 5 ms continuous duty 4 1 250 V / 4 kV / 3 10 x 106 switching operations min. 100.000 switching operations see "Lamp loads" table -25 °C ... +40 °C -40 °C ... +70 °C 17,5 x 55 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in DIN VDE 0140 part 1, DIN EN 61140; DIN VDE 0160, EN 50178; degree of protection II Type of load Capability Electrical life Incandescent lamp Halogen lamp 230 V AC Halogen trafo Fluorescent lamp not comp., CB, cos ϕ 0,4-0,6 Fluorescent lamp comp., Conv. ballast, C parallel Fluorescent lamp comp., Conv. ballast, Duo-circuit Fluorescent lamp with electronic ballast Energy saving lamp 15 W Energy saving lamp 13 W Energy saving lamp 9 W Gas discharge lamp Dulux-Lamp not compensated Dulux-Lamp compensated Max. capacitance at 230 V AC 2200 W 1400 W 120 VA 20 x 58 W 9 x 58 W 600 W 12 x 58 W 25 pcs 30 pcs 38 pcs 1000 W 800 W 500 W 60 µF 20.000 50.000 20.000 25.000 25.000 20.000 25.000 20.000 20.000 20.000 20.000 20.000 20.000 min. 5.000 1 1 Accessories, 789 Series 146 Push-in type jumper bars Commoning Description Push-in type jumper bars Operating tool uninsulated, 12-way, to be cut to the required length Wire connection Description Marking pen Operating tool, with partially insulated shaft Miniature quick marking card 10 strips with 10 markers, white with black printing Pack. Unit 789-112 100 (4x25) Marking pen with fibre tip Item No. Pack. Unit 210-110 210-720 1 1 Item No. Pack. Unit plain 248-501 5 cards 1 ...10 (10 x) 11 ... 20 (10x) 21 ... 30 (10x) 31 ... 40 (10x) 41 ... 50 (10 x) 1 ... 50 (2 x) K 1 ... K 10 (10 x) K 11 ... K 20 (10 x) K 100 (10 x) U 1 ... U 10 (10 x) U 11 ... U 20 (10 x) U 100 (10 x) 248-502 248-503 248-504 248-505 248-506 248-566 248-450 248-451 248-452 248-453 248-454 248-455 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards for permanent marking Type 2, blade (3.5 x 0.5) mm Marking Description Miniature WSB Quick marking system Marking software and printer/plotter see Section 8 Marking Item No. 1 147 1 1 4-Channel EnOcean Radio Receivers in DIN-Rail Mount Enclosure 148 4-channel EnOcean radio receiver with 4 changeover contacts, 8 A 4-channel EnOcean radio receiver with 4 make contacts, 16 A The 4-channel radio receiver in DIN-rail mount enclosure is used to switch 4 independent electrical devices or loads. The radio receiver processes telegrams transmitted by sensors (binary information) using EnOcean radio technology (PTM + STM modules). The outputs are switched via relay contacts. • Radio receiver for battery-less and wireless sensors • LED indication of switch status • External antenna for optimum transmission range (required) • Frequency band 868 MHz • Transmitter-to-receiver assignment via learn mode 24V DC + - 24V DC + - 4-channel radio receiver Us 4-channel radio receiver Us K1...K4 EnOcean Receiver K1...K4 LRN K1...K4 EnOcean Receiver K1...K4 LRN ... ... 14 12 11 ... 44 42 41 14 13 ... 44 43 Description Item No. Pack. unit Item No. Pack. unit 4-channel EnOcean radio receiver 789-602 1 789-601 1 Technical Data Voltage supply Voltage range Current consumption (internal) Number of receive channels Number of channels Output current (per channel) Type of load Switching frequency Delay time transmitter /output command Switching voltage Fuse protection Isolation Ambient operating temperature Storage temperature Relative air humidity (no condensation) Degree of pollution Degree of protection Mounting position Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories: RF magnetic antenna incl. 3m connecting cable with SMA connector 24 V DC -15 % ... + 20 % max. 90 mA 40 (10 per output) 4 (relay outputs) max. 8 A, AC1 resistive / motor load max. < 5 Hz < 100 ms; 40 ms ... 70 ms typ. 230 V AC Loads: wire breaker, max.16 A potential free contacts 0 °C ... +55 °C -25 °C ... +85 °C 85 % 2 IP20 any 70 x 55 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in Vibration and shock resistance acc. to IEC 60068-2-6 and IEC 60068-2-27 758-910 24 V DC -15 % ... + 20 % max. 90 mA 40 (10 per output) 4 (relay outputs) max. 16 A, AC1 resistive / lamp load max. < 5 Hz < 100 ms; 40 ms ... 70 ms typ. 230 V AC Loads: wire breaker, max.16 A potential free contacts 0 °C ... +55 °C -25 °C ... +85 °C 85 % 2 IP20 any 70 x 55 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in Vibration and shock resistance acc. to IEC 60068-2-6 and IEC 60068-2-27 758-910 1 Manual Control Modules 149 Manual control module, digital, 4 outputs Manual control module, analog, 4 outputs The digital manual control module 789-810 controls the different outputs 0 ... 3 and indicates their status via green LEDs and the changeover contact of the power relay. Depending on both the manual/automatic switch and watchdog input, the states 0 or 1 are transmitted in an electrically isolated from to the output via a relay. The analog manual control module 789-811 controls the different analog outputs 0 ... 3. Depending on both the manual/automatic switch and watchdog input, the voltages set between 0 ... 10 V are transmitted to the output. Watchdog- 24 V Input 0V Manual Input 24 V 0V H-O Manual Input H-C Status H-CM DI 0..3 24 V WD-IN Watchdog W 0..3 0..3 Manual Input 0..3 Auto/Hand H 24 V 0..3 AI 0..3 24 V WD-IN Watchdog W WatchdogInput 0..3 10 V DO 0..3-NC DO 0..3-NO DO 0..3-CM H-O H-C Manual Input Status H-CM Auto/Hand H AO 0..3 24 V Description Item No. Pack. unit Item No. Pack. unit Hand / Auto module 789-810 1 789-811 1 Technical Data Voltage supply Dielectric strength input / output Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Inputs No. 1/10 No. 2 No. 3 ... 6 No. 11 Outputs No. 7 No. 8 No. 9 No. 12/15/18/21 No. 13/16/19/22 No. 14/17/20/23 Max. switching voltage channel nos. 12 ... 23 Max. switching current channel nos. 12 ... 23 24 V DC ± 20 % 4 kV 0 °C ... +50 °C -25 °C ... +70 °C 106 x 58 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 734 and 231 Series) 0.08 mm² ... 1.5 mm² / AWG 28 ... 14 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 7 mm / 0.28 in 8 ... 9 mm / 0.33 in VDE 0110 (corresponding parts) 24 V DC ± 20 % 0 °C ... +50 °C -25 °C ... +70 °C 106 x 58 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 734 and 231 Series) 0.08 mm² ... 1.5 mm² / AWG 28 ... 14 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 7 mm / 0.28 in 8 ... 9 mm / 0.33 in VDE 0110 (corresponding parts) 24 V Operating voltage supply GND ground DI-0 ... 3; Input 0 ... 3; 24 V/max. 20 mA WD-IN; Watchdog input; 24 V/max. 20 mA 24 V Operating voltage supply GND ground AI-0 ... 3; Input 0 ... 3; 0-10 V/max. 20 mA WD-IN; Watchdog input; 24 V/max. 20 mA H-C; Manual operation "closed" H-CM; Manual operation "common" H-O; Manual operation "open" DO-0 ... 3-NC; Break contact; channel 0 ... 3 DO-0 ... 3-CM; Common; channel 0 ... 3 DO-0 ... 3-NO; Make contact; channel 0 ... 3 250 V AC / 30 V DC 8 A AC / 8 A DC H-C; Manual operation "closed" H-CM; Manual operation "common" H-O; Manual operation "open" GND AO-0 ... 3; Output 0 ... 3; 0-10 V/max. 20 mA GND 1 2 150 WAGO Application: Traffic Control System in Canton of Tessin (Gotthard Route), Switzerland WAGO Products: WAGO-I/O-SYSTEM (ETHERNET, CANopen), WAGO X-COM®-SYSTEM, MULTICONNECTION SYSTEM, TOPJOB®S Rail-Mounted Terminal Blocks 2 Interface Modules 151 2 289 Series Interface Modules with D-Subminiature Male and Female Connector 152 – 159 289 Series Interface Modules for Ribbon Cable Connectors Interface Module with High Density D-Sub Header for 19" Racks 160 – 165 166 289, 704, 706 Series Interface Modules for System Wiring - Interface Modules for Siemes-SIMATIC - Relay Output Module with Miniature Switching Relay WAGO Ribbon Cables 168 – 171 172 – 178 179 289 Series RJ-45 Interface Modules 180 – 182 289 Series Connection Modules for Sensors and Actuators 184 – 185 289 Series Rail-Mounted Modules - Diode Gates Rail-Mounted Modules - Resistor Gates 186 – 189 190 289 Series Rail-Mounted Modules for Building Custom Circuits 191 2 2 Interface Modules 152 flat cable 25 poles conductor no. Interface module with D-subminiature male connector, for mating connectors with solder connection, mating direction vertical Interface module with D-subminiature male connector, for mating connectors with IDC, mating direction vertical Mounting carrier for DIN 35 rail Mounting carrier for DIN 35 rail 1 2 3 4 5 6 7 8 etc. (1) Sub-Min-Dconnector 25 poles (2) (14) (3) (15) (4) (16) (no. of pins in brackets) terminal strip terminal strip locking thread - strain relief UNC 4-40 289-440 to 289-444 1 3 5 ... 1 2 3 ... 2 4 ... 50 max. ... 50 max. 1 3 5 ... 1 2 3 ... 26 27 28 ... 2 4 6 ... Description No. of Poles Width Item No. Pack. Unit No. of Poles Width Item No. Pack. Unit Interface module 9 15 25 37 50 38 53.5 79 120 157 289-445 289-446 289-447 289-448 289-449 1 1 1 1 1 9 15 25 37 50 38 53.5 79 120 157 289-440 289-441 289-442 289-443 289-444 1 1 1 1 1 Technical Data Operating voltage Nominal current Connector contact Contact resistance Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Storage temperature Dimensions (mm) W x H x L incl. mounting feet or mounting carrier Wire connection Cross sections Stripped lengths 125 V AC / DC 1A plating, 0.5 μm ... 0.8 μm Au over 2 μm Ni  3 mȍ 2 / 200 mating cycles 50 V / 0.8 kV / 2 125 V AC / DC 1A plating, 0.5 μm ... 0.8 μm Au over 2 μm Ni  3 mȍ 2 / 200 mating cycles 50 V / 0.8 kV / 2 -20 °C ... +50 °C -40 °C ... +70 °C W x 19 x 63,5 -20 °C ... +50 °C -40 °C ... +70 °C W x 19 x 63,5 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in 2 153 flat cable 25 poles conductor no. Interface module with D-subminiature male connector, for mating connectors with solder connection, mating direction vertical Interface module with D-subminiature male connector, for mating connectors with IDC, mating direction vertical Mounting carrier for DIN 35 rail Mounting carrier for DIN 35 rail 2 1 2 3 4 5 6 7 8 etc. (1) Sub-Min-Dconnector 25 poles (2) (14) (3) (15) (4) (16) (no. of pins in brackets) terminal strip terminal strip locking thread - strain relief UNC 4-40 289-540 to 289-544 1 3 5 ... 1 2 3 ... 2 4 ... 50 max. ... 50 max. 1 3 5 ... 1 2 3 ... 26 27 28 ... 2 4 6 ... Description No. of Poles Width Item No. Pack. Unit No. of Poles Width Item No. Pack. Unit Interface module 9 15 25 37 50 38 46 72 102 94 289-545 289-546 289-547 289-548 289-549 1 1 1 1 1 9 15 25 37 50 38 46 72 102 94 289-540 289-541 289-542 289-543 289-544 1 1 1 1 1 Technical Data Operating voltage Nominal current Connector contact Contact resistance Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Storage temperature Dimensions (mm) W x H x L incl. mounting feet or mounting carrier 125 V AC / DC 2A plating, 0.5 μm ... 0.8 μm Au over 2 μm Ni  3 mȍ 2 / 200 mating cycles 125 V / 0.8 kV / 2 125 V AC / DC 2A plating, 0.5 μm ... 0.8 μm Au over 2 μm Ni  3 mȍ 2 / 200 mating cycles 125 V / 0.8 kV / 2 -20 °C ... +50 °C -40 °C ... +70 °C W x 34 x 85 -20 °C ... +50 °C -40 °C ... +70 °C W x 34 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 Interface Modules 154 flat cable 25 poles conductor no. Interface module with D-subminiature female connector, for mating connectors with solder connection, mating direction vertical Interface module with D-subminiature female connector, for mating connectors with IDC, mating direction vertical Mounting carrier for DIN 35 rail Mounting carrier for DIN 35 rail 1 2 3 4 5 6 7 8 etc. (1) Sub-Min-Dconnector 25 poles (2) (14) (3) (15) (4) (16) (no. of pins in brackets) terminal strip terminal strip locking thread - strain relief UNC 4-40 289-450 to 289-454 ... 50 max. 2 4 ... 50 max. 1 2 3 ... 1 3 5 ... 1 2 3 ... 1 3 5 ... 26 27 28 ... 2 4 6 ... Description No. of Poles Width Item No. Pack. Unit No. of Poles Width Item No. Pack. Unit Interface module 9 15 25 37 50 38 53.5 79 120 157 289-455 289-456 289-457 289-458 289-459 1 1 1 1 1 9 15 25 37 50 38 53.5 79 120 157 289-450 289-451 289-452 289-453 289-454 1 1 1 1 1 Technical Data Operating voltage Nominal current Connector contact Contact resistance Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Storage temperature Dimensions (mm) W x H x L incl. mounting feet or mounting carrier Wire connection Cross sections Stripped lengths 125 V AC / DC 1A plating, 0.5 μm ... 0.8 μm Au over 2 μm Ni  10 mȍ 2 / 200 mating cycles 50 V / 0.8 kV / 2 125 V AC / DC 1A plating, 0.5 μm ... 0.8 μm Au over 2 μm Ni  10 mȍ 2 / 200 mating cycles 50 V / 0.8 kV / 2 -20 °C ... +50 °C -40 °C ... +70 °C W x 19 x 63,5 -20 °C ... +50 °C -40 °C ... +70 °C W x 19 x 63,5 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in 2 155 flat cable 25 poles conductor no. Interface module with D-subminiature female connector, for mating connectors with solder connection, mating direction vertical Interface module with D-Subminiature female connector, for mating connectors with IDC, mating direction vertical Mounting carrier for DIN 35 rail Mounting carrier for DIN 35 rail 2 1 2 3 4 5 6 7 8 etc. (1) Sub-Min-Dconnector 25 poles (2) (14) (3) (15) (4) (16) (no. of pins in brackets) terminal strip terminal strip locking thread - strain relief UNC 4-40 289-550 to 289-554 ... 50 max. 2 4 ... 50 max. 1 2 3 ... 1 3 5 ... 26 27 28 ... 2 4 6 ... 1 2 3 ... 1 3 5 ... Description No. of Poles Width Item No. Pack. Unit No. of Poles Width Item No. Pack. Unit Interface module 9 15 25 37 50 38 46 72 102 94 289-555 289-556 289-557 289-558 289-559 1 1 1 1 1 9 15 25 37 50 38 46 72 102 94 289-550 289-551 289-552 289-553 289-554 1 1 1 1 1 Technical Data Operating voltage Nominal current Connector contact Contact resistance Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Storage temperature Dimensions (mm) W x H x L incl. mounting feet or mounting carrier 125 V AC / DC 2A plating, 0.5 μm ... 0.8 μm Au over 2 μm Ni  10 mȍ 2 / 200 mating cycles 125 V / 0.8 kV / 2 125 V AC / DC 2A plating, 0.5 μm ... 0.8 μm Au over 2 μm Ni  10 mȍ 2 / 200 mating cycles 125 V / 0.8 kV / 2 -20 °C ... +50 °C -40 °C ... +70 °C W x 34 x 85 -20 °C ... +50 °C -40 °C ... +70 °C W x 34 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 Interface Modules 156 Interface module with D-subminiature female connector, for mating connectors with solder connection, mating direction vertical, shield (screen) connection Mounting carrier for DIN 35 rail Interface module with D-subminiature male connector, for mating connectors with solder connection, mating direction vertical, shield (screen) connection Mounting carrier for DIN 35 rail ... 50 max. 1 2 3 ... 1 2 3 ... 26 27 28 ... ... 50 max. S 1 2 3 ... 1 2 3 ... 26 27 28 ... s Description No. of Poles Width Item No. Pack. Unit No. of Poles Width Item No. Pack. Unit Interface module 9 15 25 37 33 43 68.5 99 289-575 289-576 289-577 289-578 1 1 1 1 9 15 25 37 38.5 46 71.5 102 289-585 289-586 289-587 289-588 1 1 1 1 Technical Data Operating voltage Nominal current Connector contact Contact resistance Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Storage temperature Dimensions (mm) W x H x L incl. mounting feet or mounting carrier 125 V AC / DC 2A plating, 0.5 μm ... 0.8 μm Au over 2 μm Ni  10 mȍ 2 / 200 mating cycles 125 V / 0.8 kV / 2 125 V AC / DC 2A plating, 0.5 μm ... 0.8 μm Au over 2 μm Ni  10 mȍ 2 / 200 mating cycles 125 V / 0.8 kV / 2 -20 °C ... +50 °C -40 °C ... +70 °C W x 34 x 85 -20 °C ... +50 °C -40 °C ... +70 °C W x 34 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 157 Interface module with D-subminiature female connector, for mating connectors with solder connection, mating direction vertical, shield (screen) connection Mounting carrier for DIN 35 rail Interface module with D-subminiature male connector, for mating connectors with solder connection, mating direction vertical, shield (screen) connection Mounting carrier for DIN 35 rail 2 Description No. of Poles Width Item No. Pack. Unit No. of Poles Width Item No. Pack. Unit Interface module 25 37 56 74 289-623 289-624 1 1 25 37 56 74 289-620 289-621 1 1 Technical Data Operating voltage Nominal current Connector contact Contact resistance Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mounting direction Pull relief stud bolt Ambient operating temperature Storage temperature Dimensions (mm) W x H x L incl. mounting feet or mounting carrier 125 V AC / DC 2A plating, 0.5 μm ... 0.8 μm Au over 2 μm Ni  10 mȍ 2 / 200 mating cycles 125 V / 0.8 kV / 2 125 V AC / DC 2A plating, 0.5 μm ... 0.8 μm Au over 2 μm Ni  10 mȍ 2 / 200 mating cycles 125 V / 0.8 kV / 2 vertical UNC 4-40 -20 °C ... +55 °C -40 °C ... +70 °C W x 62 x 85 -20 °C ... +50 °C -40 °C ... +70 °C W x 62 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 737 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 737 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 Interface Modules 158 Interface module with D-subminiature female connector with shield (screen) connection Mounting carrier for DIN 35 rail ... 25 max. 14 15 16 ... S 1 2 3 ... Description No. of Poles Width Item No. Pack. Unit Interface module 9 25 33 68.5 289-650 289-652 1 1 Technical Data Operating voltage Nominal current Connector contact Contact resistance Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mounting direction Pull relief stud bolt Ambient operating temperature Storage temperature Dimensions (mm) W x H x L incl. mounting feet or mounting carrier 125 V AC / DC 2A plating, 0.5 μm ... 0.8 μm Au over 2 μm Ni < 10 mȍ 2 / 200 mating cycles 125 V / 0.8 kV / 2 vertical UNC 4-40 -20 °C ... +50 °C -40 °C ... +70 °C W x 48 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 736 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 2 159 Interface module with D-subminiature male connector Interface module with D-subminiature female connector Mounting carrier for DIN 35 rail Mounting carrier for DIN 35 rail 2 1 2 3 ... 1 2 3 ... 37 20 21 22 ... ... ... 37 S 1 2 3 ... ... ... ... 19 1 solder pin per pole is available for testing and patching (except for shield (screen) contact) 37 1 2 3 ... ... ... ... 19 20 21 22 ... ... ... 37 S Description No. of Poles Width Item No. Pack. Unit No. of Poles Width Item No. Pack. Unit Interface module 9 15 25 37 33.5 43.5 69 99.5 289-720 289-721 289-722 289-723 1 1 1 1 9 15 25 37 33.5 43.5 69 99.5 289-725 289-726 289-727 289-728 1 1 1 1 Technical Data Operating voltage Nominal current Connector contact Contact resistance Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mounting direction Pull relief stud bolt Ambient operating temperature Storage temperature Dimensions (mm) W x H x L incl. mounting feet or mounting carrier 125 V AC / DC 2A plating, 0.5 μm ... 0.8 μm Au over 2 μm Ni  10 mȍ 2 / 200 mating cycles 125 V / 0.8 kV / 2 125 V AC / DC 2A plating, 0.5 μm ... 0.8 μm Au over 2 μm Ni  10 mȍ 2 / 200 mating cycles 125 V / 0.8 kV / 2 vertical UNC 4-40 -20 °C ... +50 °C -40 °C ... +70 °C W x 48 x 85 vertical UNC 4-40 -20 °C ... +50 °C -40 °C ... +70 °C W x 48 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 736 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 736 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 Interface Modules 160 Interface module for ribbon cable connectors acc. to DIN 41651 Interface module for ribbon cable connectors acc. to DIN 41651 Mounting carrier for DIN 35 rail Mounting carrier for DIN 35 rail 1 1 2 4 6 ... 1 3 5 ... 3 6 9 ... 2 5 8 ... 1 4 7 ... 16 15 nc 64 63 Description No. of Poles Width Item No. Pack. Unit No. of Poles Width Item No. Pack. Unit Interface module 10 14 16 35 40 45 289-611 289-612 289-613 1 1 1 20 26 34 40 50 64 47 55 65 74 88 114 289-614 289-615 289-616 289-617 289-618 289-619 1 1 1 1 1 1 Technical Data Operating voltage Nominal current Connector contact Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Mounting direction Ambient operating temperature Storage temperature Dimensions (mm) W x H x L incl. mounting feet or mounting carrier Wire connection Cross sections Stripped lengths Approvals Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier 125 V AC / DC 1A phosphor-bronze, 0.38 μm Au selectively over 1.3 μm Ni 3 125 V / 0.8 kV / 2 125 V AC / DC 1A phosphor-bronze, 0.38 μm Au selectively over 1.3 μm Ni 3 125 V / 0.8 kV / 2 vertical -20 °C ... +55 °C -40 °C ... +70 °C W x 48 x 85 vertical -20 °C ... +55 °C -40 °C ... +70 °C W x 62 x 85 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 736 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in IEC 60603-1 / DIN 41651 Part 1 and 2 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 737 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in IEC 60603-1 / DIN 41651 Part 1 and 2 see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 161 Interface module with header acc. to DIN 41 651 Interface module with header acc. to DIN 41 651 Mounting carrier for DIN 35 rail Mounting carrier for DIN 35 rail 2 1 1 2 4 6 ... 2 4 6 ... 1 3 5 ... 1 3 5 ... Description No. of Poles Width Item No. Pack. Unit No. of Poles Width Item No. Pack. Unit Interface module 10 14 16 20 26 34 40 50 64 41 51.5 56.5 66.5 81 102 126 151 187 289-401 289-402 289-403 289-404 289-405 289-406 289-407 289-408 289-409 1 1 1 1 1 1 1 1 1 10 14 16 20 26 34 40 50 64 64 38 43 46 53.5 71 94 114 132 170 120 289-501 289-502 289-503 289-504 289-505 289-506 289-507 289-508 289-509 289-510 1 1 1 1 1 1 1 1 1 1 Technical Data Operating voltage Nominal current Connector contact Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Dimensions (mm) W x H x L incl. mounting feet or mounting carrier Wire connection Cross sections Stripped lengths Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier 125 V AC / DC 1A phosphor-bronze, 0.38 μm Au selectively over 1.3 μm Ni 3 50 V / 0.8 kV / 2 125 V AC / DC 1A phosphor-bronze, 0.38 μm Au selectively over 1.3 μm Ni 3 50 V / 0.8 kV / 2 W x 28 x 63,5 W x 36 x 85 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in see page 323 white 709-198 / transparent 709-197 2 Interface Modules 162 Interface module for connectors acc. to DIN 41 612, with male connector, type E, with strain relief device for ERNI mating connector Mounting carrier for DIN 35 rail Interface module for connectors acc. to DIN 41 612, with male connector, type F, with strain relief device for Harting mating connector Mounting carrier for DIN 35 rail Harting 09 06 0482905 250V 4A 250V 4A ERNI 333 050 Description No. of Poles Width Item No. Pack. Unit No. of Poles Width Item No. Pack. Unit Interface module 48 128 289-434 1 48 128 289-436 1 Technical Data Operating voltage Nominal current Connector contact Contact resistance Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Dimensions (mm) W x H x L incl. mounting feet or mounting carrier 250 V AC / DC 4A Copper alloy, gold plated  16 mȍ 2 / 400 mating cycles 250 V / 1.5 kV / 2 250 V AC / DC 4A Copper alloy, gold plated  16 mȍ 1 / 500 mating cycles 250 V / 1.5 kV / 2 W x 55 x 85 W x 39 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 163 Interface module for connectors acc. to DIN 41 612, with male connector, type C, mating direction vertical Interface module for connectors acc. to DIN 41 612, with male connector, type C, mating direction horizontal Mounting carrier for DIN 35 rail Mounting carrier for DIN 35 rail 2 a c 1 3 ... a c 1 2 3 ... a c 1 3 ... 1 2 3 ... 2 4 ... 1 3 ... 2 4 6 ... 1 2 3 ... 1 3 ... a 2 4 ... a 2 4 6 ... c c 289-422 Interface module, for female connector with IDC Interface module, for female connector with solder contact Interface module, for female connector with solder contact a c 2 4 6 ... a Description 2 4 6 ... 2 4 ... No. of Poles Width 64 c 289-423 1 2 3 ... 1 2 3 ... 1 2 3 ... a 2 4 6 ... c 289-426 a c 2 4 6 ... a 2 4 ... c 2 4 6 ... 2 4 6 ... a 1 2 3 ... 289-424 a c 1 2 3 ... c 289-425 289-427 Item No. Pack. Unit No. of Poles Width Item No. Pack. Unit 187 289-422 1 64 187 289-423 1 32 97 289-424 1 32 97 289-425 1 64 187 289-426 1 64 187 289-427 1 Technical Data Operating voltage Nominal current Connector contact Contact resistance Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Dimensions (mm) W x H x L incl. mounting feet or mounting carrier Wire connection Cross sections Stripped lengths 125 V AC / DC 1A Copper alloy, gold plated  20 mȍ 2 / 400 mating cycles 50 V / 0.8 kV / 2 125 V AC / DC 1A Copper alloy, gold plated  20 mȍ 2 / 400 mating cycles 50 V / 0.8 kV / 2 W x 21 x 63,5 W x 21 x 63,5 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in 2 Interface Modules 164 Interface module for connectors acc. to DIN 41 612, with female connector, type C, mating direction vertical, for male connector with solder contact Mounting carrier for DIN 35 rail c a 2 4 6 ... c a 2 4 6 ... 2 4 6 ... 289-430 Interface module for connectors acc. to DIN 41 612, with female connector, type C, mating direction vertical, for female connector with IDC connection or with solder contact Mounting carrier for DIN 35 rail 1 2 3 ... a c 1 2 3 ... 289-431 c 2 4 6 ... 1 3 ... 289-522 c a c 1 2 3 ... a 2 4 ... a 1 2 3 ... 1 2 3 ... 289-526 a 1 2 3 ... a 1 3 ... 2 4 ... 1 2 3 ... 1 2 3 ... c c Description No. of Poles Width Item No. Pack. Unit No. of Poles Width Item No. Pack. Unit Interface module 32 64 97 187 289-430 289-431 1 1 64 64 171 171 289-522 289-526 1 1 Technical Data Operating voltage Nominal current Connector contact Contact resistance Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Dimensions (mm) W x H x L incl. mounting feet or mounting carrier 125 V AC / DC 1A Copper alloy, gold plated  20 mȍ 2 / 400 mating cycles 50 V / 0.8 kV / 2 125 V AC / DC 1A Copper alloy, gold plated  20 mȍ 2 / 400 mating cycles 125 V / 0.8 kV / 2 W x 21 x 63,5 W x 34 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 165 Interface module for connectors acc. to DIN 41 612, with female connector, type C, mating direction horizontal, for female connector with IDC connection or with solder contact Mounting carrier for DIN 35 rail Interface module for connectors acc. to DIN 41 612, with female connector, type C, mating direction vertical, for male connector with solder contact Mounting carrier for DIN 35 rail 2 a c 1 3 ... a c 2 4 ... 1 3 ... 289-523 1 2 3 ... c a a 1 2 3 ... 1 2 3 ... 289-527 c a 2 4 ... 1 2 3 ... 1 2 3 ... c 1 2 3 ... 1 2 3 ... 1 2 3 ... a c Description No. of Poles Width Item No. Pack. Unit No. of Poles Width Item No. Pack. Unit Interface module 64 64 171 171 289-523 289-527 1 1 64 171 289-531 1 Technical Data Operating voltage Nominal current Connector contact Contact resistance Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Dimensions (mm) W x H x L incl. mounting feet or mounting carrier 125 V AC / DC 1A Copper alloy, gold plated  20 mȍ 2 / 400 mating cycles 125 V / 0.8 kV / 2 125 V AC / DC 1A Copper alloy, gold plated  20 mȍ 2 / 400 mating cycles 125 V / 0.8 kV / 2 W x 34 x 85 W x 34 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 Interface Modules 166 Interface module with high density D-sub header for 19" racks Description No. of Poles Width Item No. Pack. Unit Interface module for 19" racks 62 80 289-822 1 Technical Data Operating voltage Nominal current Connector contact Contact resistance Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Touch-proof terminal strip Touch-proof HD D-sub header Dimensions (mm) W x H x L incl. mounting feet or mounting carrier Wire connection Cross sections Stripped lengths Mounting direction Pull relief stud bolt Ambient operating temperature Storage temperature Approvals 125 V AC / DC 1A Copper alloy, gold-plated 0.8 μm  10 mȍ 2 to DIN 41652 400 mating cycles, without corrosion 125 V / 0.8 kV / 2 IP20 IP00 W x 27 x 132 CAGE CLAMP® (WAGO 739 Series) 0.08 mm² ... 1.5 mm² / AWG 28 ... 14 * * (AWG14: THHN, THWN) 5 ... 6 mm / 0.22 in vertical UNC 4-40 -20 °C ... +55 °C -40 °C ... +70 °C EN 60664 2 167 2 168 Interface Modules for Siemens-SIMATIC® S5-95 U to 155 U, S7-300/ET 200 M and S7-400 SIMATIC® is a registered trademark of the Siemens AG Interface module, 8-pole, for Siemens-SIMATIC® S5-95 U to 155 U, S7-300/ET 200 M und S7-400 Single-wire connection, without LED Mounting carrier for DIN 35 rail Interface module, 8-pole, for Siemens-SIMATIC® S5-95 U to 155 U, S7-300/ET 200 M und S7-400 Single-wire connection, with LED Mounting carrier for DIN 35 rail Description Width Item No. Pack. Unit Width Item No. Pack. Unit Interface module 44 289-680 1 44 289-681 1 Technical Data Operating voltage Nominal current per signal wire Max. total current (supply) Connector contact Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Dimensions (mm) W x H x L incl. mounting feet or mounting carrier 125 V AC/DC 1A 2A phosphor-bronze, 0.38 μm Au selectively over 1.3 μm Ni 3 125 V / 0.8 kV / 2 24 V DC 1A 2A phosphor-bronze, 0.38 μm Au selectively over 1.3 μm Ni 3 W x 48 x 85 W x 48 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 736 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 736 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 169 SIMATIC® is a registered trademark of the Siemens AG Interface module, 8-pole, for Siemens-SIMATIC® S5-95 U to 155 U, S7-300/ET 200 M und S7-400 3-wire sensors, without LED Mounting carrier for DIN 35 rail Interface module, 8-pole, for Siemens-SIMATIC® S5-95 U to 155 U, S7-300/ET 200 M und S7-400 3-wire sensors, with LED Mounting carrier for DIN 35 rail 2 Description Width Item No. Pack. Unit Width Item No. Pack. Unit Interface module 54 289-682 1 54 289-683 1 Technical Data Operating voltage Nominal current per signal wire Max. total current (supply) Connector contact Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Dimensions (mm) W x H x L incl. mounting feet or mounting carrier 125 V AC/DC 1A 2A phosphor-bronze, 0.38 μm Au selectively over 1.3 μm Ni 3 125 V / 0.8 kV / 2 24 V DC 1A 2A phosphor-bronze, 0.38 μm Au selectively over 1.3 μm Ni 3 W x 62 x 85 W x 62 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 737 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 737 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 170 Interface Modules for Siemens-SIMATIC® S5-95 U to 155 U, S7-300/ET 200 M and S7-400 SIMATIC® is a registered trademark of the Siemens AG Interface module, 32-pole, for Siemens-SIMATIC® S5-95 U to 155 U, S7-300/ET 200 M und S7-400 Single-wire connection, without LED Mounting carrier for DIN 35 rail Interface module, 32-pole, for Siemens-SIMATIC® S5-95 U to 155 U, S7-300/ET 200 M und S7-400 Single-wire connection, with LED Mounting carrier for DIN 35 rail Description Width Item No. Pack. Unit Width Item No. Pack. Unit Interface module 112 289-684 1 112 289-685 1 Technical Data Operating voltage Nominal current per signal wire Max. total current (supply) Connector contact Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Dimensions (mm) W x H x L incl. mounting feet or mounting carrier 125 V AC/DC 1A 2 A / byte phosphor-bronze, 0.38 μm Au selectively over 1.3 μm Ni 3 125 V / 0.8 kV / 2 24 V DC 1A 2 A / byte phosphor-bronze, 0.38 μm Au selectively over 1.3 μm Ni 3 W x 48 x 85 W x 48 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 736 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 736 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 171 SIMATIC® is a registered trademark of the Siemens AG Interface module, 32-pole, for Siemens-SIMATIC® S5-95 U to 155 U, S7-300/ET 200 M und S7-400 3-wire sensors, without LED Mounting carrier for DIN 35 rail Interface module, 32-pole, for Siemens-SIMATIC® S5-95 U to 155 U, S7-300/ET 200 M und S7-400 3-wire sensors, with LED Mounting carrier for DIN 35 rail 2 Description Width Item No. Pack. Unit Width Item No. Pack. Unit Interface module 176 289-686 1 176 289-687 1 Technical Data Operating voltage Nominal current per signal wire Max. total current (supply) Connector contact Performance level Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Dimensions (mm) W x H x L incl. mounting feet or mounting carrier 125 V AC/DC 1A 2 A / byte phosphor-bronze, 0.38 μm Au selectively over 1.3 μm Ni 3 125 V / 0.8 kV / 2 24 V DC 1A 2 A / byte phosphor-bronze, 0.38 μm Au selectively over 1.3 μm Ni 3 W x 62 x 85 W x 62 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 737 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 737 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 16-Channel I/O Module with Interface Module 172 The new 750-14xx and 750-15xx Series I/O Modules with flat ribbon cable connection offer 16 digital channels in a module less than 1⁄2 inch (12mm) wide. Offering quick connections and a spaceefficient design, the DIN-rail mount interface modules simplify installation in confined areas and relocate the termination point. When combined with WAGO interface modules (e.g., item no. 289-614, 289611), a switch cabinet can be pre-wired before install to minimize wiring time and errors. This is beneficial as wiring can be performed independently of a plant’s construction. Pre-wired electronics can be installed right before start-up, saving valuable time during final stages of project completion. The modules are also ideal for connecting series machines or relay modules tasked with the higher loads common to buildings and industrial applications. The interface module also combines the advantages of relays (e.g., manual operation or rapid replacement with socked-mounted versions) with the benefits of a modern I/O system. Another ideal application would be the integration of pneumatic controllers into a fieldbus network. Most pneumatic modules have an appropriate connector and can be controlled by the WAGO-I/O-SYSTEM. Five variants are available: two 16-channel input or output modules (one high-side and one low-side switching variant), as well as a version combining 8 inputs and 8 outputs. 2 Application Examples 173 Item. No. Designation PLC Siemens S7-300 Card 6ES7 313-5BE01-0AB0 6ES7 314-6CG03-0AB0 6ES7 313-5BF03-0AB0 6ES7 322-1BH01-0AA0 6ES7 313-6BE01-0AB0 6ES7 322-1BH10-0AA0 6ES7 313-6BF03-0AB0 6ES7 322-1BH80-0AA0 6ES7 313-6CE01-0AB0 6ES7 322-1BL00-0AA0 6ES7 313-6CF03-0AB0 6ES7 322-1BP00-0AA0 6ES7 314-6BF01-0AB0 6ES7 322-1EH01-0AA0 6ES7 314-6BG03-0AB0 6ES7 323-1BL00-0AA0 6ES7 314-6CF01-0AB0 IC693 MDL740 IC693 MDL753 GEFANUC 90-30 / ALSPA 80-35 IC693 MDL742 704-5024 704-5044 704-5004 704-5014 704-5034 704-5054 704-5074 704-5064 TSX DMZ 28DT TSX DMZ 64DTK SCHNEIDER TSX 37 ( Micro ) TSX DMZ 28DTK T16S SCHNEIDER TSX 57 ( Premium ) TSX DSY 16T2 TSX DMY 28FK TSX DSY 32T2K TSX DMY 28RFK TSX DSY 64T2K BMX DDO 1602 BMX DDO 6402K BMX DDO 3202K BMX DDM 3202K 140 DDO 353 00 140 DDO 843 00 140 DDO 353 01 140 DVO 853 00 SCHNEIDER M340 SCHNEIDER QUANTUM 140 DDO 364 00 1769 - OB16 1769 - OB32 1769 - OB16P 1769 - OB32T 1756 - OB16D 1756 - OB32 ROCKWELL COMPACT-LOGIX (1769) ROCKWELL CONTROL-LOGIX (1756) 1756 - OB16E 753-530 (x2) WAGO-I/O-SYSTEM 750/753 750-1500 SIEMENS S7-300 GEFANUC 90-30 / ALSPA 80-35 704-5003 704-5013 SCHNEIDER TSX 57 ( Premium ) 6ES7 312-5BD01-0AB0 6ES7 322-8BF00-0AB0 6ES7 312-5BE03-0AB0 6ES7 323-1BH01-0AA0 6ES7 322-1BF01-0AA0 6ES7 327-1BH00-0AB0 IC693 MDL730 TSX DSZ 08T2 IC693 MDL732 TSX DSZ 08T2K TSX DSZ 04T22 TSX DMZ 16DTK TSX DSY 08T2 T8S SCHNEIDER M340 BMX DDM 16022 SCHNEIDER QUANTUM 140 DDM 390 00 ROCKWELL COMPACT LOGIX (1769) 1769 - OB8 1756 - OB8 ROCKWELL CONTROL LOGIX (1756) 1756 - OB8EI 753-530 WAGO-I/O-SYSTEM 750/753 750-1502, -1500 1756 - OB8I 2 2 Interface Modules for System Wiring 174 Relay output module with miniature switching relay for 16 channels, 1 changeover contact each (1 u) with integrated status indication, 20-pole ribbon cable connector to DIN 41651 — +F 17 19 18 20 1 + 16 — 1 17 19 18 20 16 Rel. 1 11 14 12 Rel. 16 AUTO ON OFF F = 1A • • • F = 1A • • • Rel. 1 161 164 162 11 14 12 AUTO + ON OFF +F Relay output module with miniature switching relay for 16 channels, 1 changeover contact each (1 u) with integrated status indication and manual operation, 20-pole ribbon cable connector to DIN 41651 Rel. 16 161 164 162 Description Item No. Pack. Unit Item No. Pack. Unit Switching relay module, for DIN 35 rail 704-5024 1 704-5044 1 Technical Data Contact material Contact type Operating voltage Max. switching voltage Max. continuous current Max. switching power (resistive) Status indication AgNi 90/10 1 changeover contact 24 V DC (± 10 %) 250 V AC / 48 V DC 5A 1250 VA / 50 W LED green : Channel LED yellow : Power supply 10 x 106 switching operations 4 kV 1 kV Supply: 1 A Relay output: – -25 °C ... +40 °C -40 °C ... +70 °C 111 x 65 x 105 AgNi 90/10 1 changeover contact 24 V DC (± 10 %) 250 V AC / 48 V DC 5A 1250 VA / 50 W LED green : Channel LED yellow : Power supply 10 x 106 switching operations 4 kV 1 kV Supply: 1 A Relay output: – -25 °C ... +40 °C -40 °C ... +70 °C 121 x 65 x 105 Wire connection Height from upper-edge of DIN 35 rail Input: 20-pole ribbon cable connector to DIN 41651 Output: CAGE CLAMP® Height from upper-edge of DIN 35 rail Input: 20-pole ribbon cable connector to DIN 41651 Output: CAGE CLAMP® Cross sections Stripped lengths 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in see page 173 Spare relay 857-152 see page 173 Spare relay 857-152 Mechanical life Dielectric strength contact-coil (AC, 1 min) Dielectric strength contact-contact Fuse Ambient operating temperature Storage temperature Dimensions (mm) L x W x H incl. mounting carrier and relay Application examples Accessories 2 175 Relay output module with miniature switching relay for 16 channels, 1 changeover contact each (1 u) with integrated status indication, 20-pole ribbon cable connector to DIN 41651 Relay output module with miniature switching relay for 16 channels, 1 changeover contact each (1 u) with integrated status indication and output fuse, 20-pole ribbon cable connector to DIN 41651 2 + — +F • • • + — 17 19 18 20 16 1 • • • 16 F = 1A 1 F = 1A 17 19 18 20 Rel. 16 Rel. 1 5A Rel. 1 11 14 12 161 164 162 Rel. 16 5A +F 11 14 12 161 164 162 Description Item No. Pack. Unit Item No. Pack. Unit Switching relay module, for DIN 35 rail Switching relay module without miniature switching relay, for DIN 35 rail 704-5004 1 704-5034 1 704-5014 1 Technical Data Contact material Contact type Operating voltage Max. switching voltage Max. continuous current Inrush current Max. switching power (resistive) Status indication AgNi 90/10 1 changeover contact 24 V DC (± 10 %) 250 V AC / 48 V DC 5A 2 s 16 A 1250 VA / 50 W LED green : Channel LED yellow : Power supply 30 x 106 switching operations 3 kV 1 kV Supply: 1 A Relay output: – -25 °C ... +50 °C -40 °C ... +70 °C 180 x 50 x 105 AgNi 90/10 1 changeover contact 24 V DC (± 10 %) 250 V AC / 48 V DC 5A 2 s 16 A 1250 VA / 50 W LED green : Channel LED yellow : Power supply 30 x 106 switching operations 4 kV 1 kV Supply: 1 A Relay output: 5 A -25 °C ... +50 °C -40 °C ... +70 °C 247 x 55 x 105 Wire connection Height from upper-edge of DIN 35 rail Input: 20-pole ribbon cable connector to DIN 41651 Output: CAGE CLAMP® Height from upper-edge of DIN 35 rail Input: 20-pole ribbon cable connector to DIN 41651 Output: CAGE CLAMP® Cross sections Stripped lengths 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in see page 173 Spare relay 788-154 see page 173 Spare relay 788-154 Mechanical life Dielectric strength contact-coil (AC, 1 min) Dielectric strength contact-contact Fuse Ambient operating temperature Storage temperature Dimensions (mm) L x W x H incl. mounting carrier and relay Application examples Accessories 2 Interface Modules for System Wiring 176 Relay output module with miniature switching relay for 16 channels, 1 make contact each (1 a) with integrated status indication, disconnect terminal block and output fuse, 20-pole ribbon cable connector to DIN 41651 +F + — Relay output module with miniature switching relay for 16 channels, 1 make contact each (1 a) with integrated status indication, double disconnect terminal block and output fuse, 20-pole ribbon cable connector to DIN 41651 +F • • • 8 9 • • • + — 17 19 18 20 16 1 • • • 16 F = 1A F = 1A 17 19 18 20 1 Rel. 1 Rel. 8 Rel. 9 Rel. 16 C1 C1 C2 C2 1F 1K 8F 8K C3 C3 C4 C4 9F 9K 5A Rel. 16 5A 2A 2A 2A 2A Rel. 1 16F 16K 11 Description Item No. Pack. Unit Switching relay module, for DIN 35 rail 704-5054 1 14 161 164 Item No. Pack. Unit 704-5074 1 Technical Data Contact material Contact type Operating voltage Max. switching voltage Max. continuous current Max. switching power (resistive) Status indication AgNi 90/10 1 make contact 24 V DC (± 10 %) 250 V AC / 48 V DC 2A 500 VA / 50 W LED green : Channel LED yellow : Power supply 30 x 106 switching operations 4 kV 1 kV Supply: 1 A Relay output: 2 A -25 °C ... +50 °C -40 °C ... +70 °C 240 x 55 x 105 AgNi 90/10 1 make contact 24 V DC (± 10 %) 250 V AC / 48 V DC 5A 1250 VA / 50 W LED green : Channel LED yellow : Power supply 30 x 106 switching operations 4 kV 1 kV Supply: 1 A Relay output: 5 A -25 °C ... +50 °C -40 °C ... +70 °C 240 x 55 x 105 Wire connection Height from upper-edge of DIN 35 rail Input: 20-pole ribbon cable connector to DIN 41651 Output: CAGE CLAMP® Height from upper-edge of DIN 35 rail Input: 20-pole ribbon cable connector to DIN 41651 Output: CAGE CLAMP® Cross sections Stripped lengths 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in see page 173 Spare relay 788-154 see page 173 Spare relay 788-154 Mechanical life Dielectric strength contact-coil (AC, 1 min) Dielectric strength contact-contact Fuse Ambient operating temperature Storage temperature Dimensions (mm) L x W x H incl. mounting carrier and relay Application examples Accessories 2 177 Relay output module with miniature switching relay for 16 channels, 2 changeover contacts each (2 u) with integrated status indication, 20-pole ribbon cable connector to DIN 41651 2 +F + — 1 • • • 16 F = 1A 17 19 18 20 1622 1621 1624 1612 122 1611 1614 121 124 Rel. 16 112 111 114 Rel. 1 Description Item No. Pack. Unit Switching relay module, for DIN 35 rail 704-5064 1 Technical Data Contact material Contact type Operating voltage Max. switching voltage Max. continuous current Inrush current Max. switching power (resistive) Status indication Mechanical life Dielectric strength contact-coil (AC, 1 min) Dielectric strength contact-contact Fuse Ambient operating temperature Storage temperature Dimensions (mm) L x W x H incl. mounting carrier and relay AgNi 90/10 2 changeover contact 24 V DC (± 10 %) 250 V AC / 48 V DC 5A 2s8A 1000 VA / 50 W LED green : Channel LED yellow : Power supply 30 x 106 switching operations 4 kV 1 kV Supply: 1 A Relay output: – -25 °C ... +50 °C -40 °C ... +70 °C 247 x 50 x 105 Wire connection Height from upper-edge of DIN 35 rail Input: 20-pole ribbon cable connector to DIN 41651 Output: CAGE CLAMP® Cross sections Stripped lengths 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Application examples Accessories see page 173 Spare relay 788-156 2 Interface Modules for System Wiring 178 +F 1 • • • + Rel. 1 11 14 12 — 9 8 F = 1A 10 F = 1A 9 Rel. 8 10 1 Rel. 1 81 84 82 8 • • • 11 14 12 AUTO — ON OFF + ON OFF +F Relay output module with miniature switching relay for 8 channels, 1 changeover contact each (1 u) with integrated status indication and manual operation, 10-pole ribbon cable connector to DIN 41651 AUTO Relay output module with miniature switching relay for 8 channels, 1 changeover contact each (1 u) with integrated status indication, 10-pole ribbon cable connector to DIN 41651 Rel. 8 81 84 82 Description Item No. Pack. Unit Item No. Pack. Unit Switching relay module, for DIN 35 rail 704-5003 1 704-5013 1 Technical Data Contact material Contact type Operating voltage Max. switching voltage Max. continuous current Max. switching power (resistive) Status indication AgNi 90/10 1 changeover contact 24 V DC (± 10 %) 250 V AC / 48 V DC 5A 1250 VA / 50 W LED green : Channel LED yellow : Power supply 10 x 106 switching operations 4 kV 1 kV Supply: 1 A Relay output: – -25 °C ... +40 °C -40 °C ... +70 °C 70 x 65 x 105 AgNi 90/10 1 changeover contact 24 V DC (± 10 %) 250 V AC / 48 V DC 5A 1250 VA / 50 W LED green : Channel LED yellow : Power supply 10 x 106 switching operations 4 kV 1 kV Supply: 1 A Relay output: – -25 °C ... +40 °C -40 °C ... +70 °C 75 x 65 x 105 Wire connection Height from upper-edge of DIN 35 rail Input: 10-pole ribbon cable connector to DIN 41651 Output: CAGE CLAMP® Height from upper-edge of DIN 35 rail Input: 10-pole ribbon cable connector to DIN 41651 Output: CAGE CLAMP® Cross sections Stripped lengths 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in see page 173 Spare relay 857-152 see page 173 Spare relay 857-152 Mechanical life Dielectric strength contact-coil (AC, 1 min) Dielectric strength contact-contact Fuse Ambient operating temperature Storage temperature Dimensions (mm) L x W x H incl. mounting carrier and relay Application examples Accessories 2 WAGO Ribbon Cables 179 2 WAGO ribbon cables provide fast and easy connection of WAGO I/O modules equipped with a ribbon cable connector (750-1400, -1402, -1500, -1501, 1502) to appropriate interface or relay modules (16-channel) featuring a 20-pole female connector. The cables are available in 1-, 2- and 3-meter lengths; each has one 20-pole female connector at both ends. Description Item No. Pack. Unit WAGO ribbon cable 20/20, lenght 1 m WAGO ribbon cable 20/20, lenght 2 m WAGO ribbon cable 20/20, lenght 3 m 706-3057/300-100 706-3057/300-200 706-3057/300-300 1 1 1 Technical Data Connections Wire cross-section Color coding Current per channel Operating temperature Degree of protection Length WAGO ribbon cables provide fast and easy connection of WAGO I/O modules equipped with a ribbon cable connector (750-1400, -1402, -1500, -1501, 1502) to appropriate interface or relay modules featuring a 10-pole female connector. For example, this cable connects 2 relay modules (8-channel) to a WAGO I/O module. The cables are available in 1- and 2-meter lengths; each has one 20-pole and two 10-pole female connectors on the ends. Description Item No. Pack. Unit WAGO ribbon cable 20/2x10, lenght 1 m WAGO ribbon cable 20/2x10, lenght 2 m 706-7753/302-100 706-7753/302-200 1 1 Technical Data 2 x 20-pole female connector acc. to DIN 41651 0.14 mm2 LiYY acc. to DIN VDE 47100 max. 1 A -25 °C ... +70 °C IP20 1 m (706-3057/300-100) 2 m (706-3057/300-200) 3 m (706-3057/300-300) Connections Wire cross-section Color coding Current per channel Operating temperature Degree of protection Length 1 x 20-pole / 2 x 10-pole female connector 0.14 mm2 LiYY acc. to DIN VDE 47100 max. 1 A -25 °C ... +70 °C IP20 1 m (706-7753/302-100) 2 m (706-7753/302-200) 2 Interface Modules 180 RJ-45 interface module with shield clamping unit for WAGO shield (screen) clamping saddle Mounting carrier for DIN 35 rail RJ-45 interface module cross-over connection Mounting carrier for DIN 35 rail Description Item No. Pack. Unit Item No. Pack. Unit Interface module 289-178 1 289-177 1 Technical Data Connecting cable Max. transmission length Connector Min. mating cycles Current load Voltage load Insulation resistance Dielectric strength contact-contact Contact resistance WAGO shield (screen) clamping saddle Ambient operating temperature Dimensions (mm) W x H x L incl. mounting feet or mounting carrier min. CAT5 100 m RJ-45 shielded 1000  2.1 A 35 V AC / 50 V DC > 500 Mȍ 1 kV eff. typ. 40 mȍ 11 mm wide; cable diameter up to 8 mm -20 °C ... +85 °C 30 x 67 x 85 min. CAT5 100 m RJ-45 shielded 1000  2.1 A 35 V AC / 50 V DC > 500 Mȍ 1 kV eff. typ. < 40 mȍ Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 739 Series) 0.08 mm² ... 1.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in ISO/IEC 11801: 2002-09; EN 55022 Height from upper-edge of DIN 35 rail Wire connection Cross sections Stripped lengths Approvals ISO/IEC 11801: 2002-09; EN 55022 Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 -20 °C ... +85 °C 30 x 51 x 85 2 181 RJ-45 interface module Mounting carrier for DIN 35 rail RJ-45 interface module Mounting carrier for DIN 35 rail 2 1 2 3 4 5 6 7 8 A 1 2 3 4 5 6 7 8 B S S S S 1 2 3 4 5 6 7 8 A 1 2 3 4 5 6 7 8 B Description Item No. Pack. Unit Item No. Pack. Unit Interface module 289-172 1 289-176 1 Technical Data Connecting cable Max. transmission length Connector Min. mating cycles Current load Voltage load Insulation resistance Dielectric strength contact-contact Contact resistance typ. Ambient operating temperature Dimensions (mm) W x H x L incl. mounting feet or mounting carrier min. CAT5 100 m RJ-45 shielded 500  1.5 A 30V AC / 42 V DC > 500 Mȍ 1 kV eff. < 20 mȍ -20 °C ... +85 °C 20,5 x 51 x 85 min. CAT5 100 m RJ-45 shielded 1000  2.1 A 35 V AC / 50 V DC > 500 Mȍ 1 kV eff. < 40 mȍ -20 °C ... +85 °C 30 x 51 x 85 Approvals Height from upper-edge of DIN 35 rail ISO/IEC 11801: 2002-09; EN 55022 Height from upper-edge of DIN 35 rail ISO/IEC 11801: 2002-09; EN 55022 Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 Interface Modules 182 RJ-45 interface module with shield clamping unit for WAGO shield (screen) clamping saddle Mounting carrier for DIN 35 rail RJ-45 interface module with shield clamping unit for WAGO shield (screen) clamping saddle Mounting carrier for DIN 35 rail Description Item No. Pack. Unit Item No. Pack. Unit Interface module 289-175 1 289-174 1 Technical Data Connecting cable Max. transmission length Connector Min. mating cycles Current load Insulation resistance Dielectric strength contact-contact Contact resistance Ambient operating temperature Dimensions (mm) W x H x L incl. mounting feet or mounting carrier Wire connection Cross sections Stripped lengths Approvals Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier WAGO shield (screen) clamping saddle min. CAT5 100 m RJ-45 shielded 500  1.5 A > 500 Mȍ 1 kV eff. typ. < 20 mȍ -20 °C ... +85 °C 24 x 40 x 85 min. CAT5 100 m RJ-45 shielded 500  1.5 A > 500 Mȍ 1 kV eff. typ. < 20 mȍ -20 °C ... +85 °C 24 x 40 x 85 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 739 Series) 0.08 mm² ... 1.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in ISO/IEC 11801: 2002-09; EN 55022 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 739 Series) 0.08 mm² ... 1.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in ISO/IEC 11801: 2002-09; EN 55022 see page 323 white 709-198 / transparent 709-197 790-108 (11 mm wide; cable diameter up to 8 mm) see page 323 white 709-198 / transparent 709-197 790-108 (11 mm wide; cable diameter up to 8 mm) 2 183 2 Front-entry Connection module for 8 x 3-conductor sensors Connection module for 8 x 3-conductor sensors LED indicator for positive or negative switching Graphic 289-665 Pack. Unit Connection module 289-664 1 + + + + + + + + + + Item No. – – – – – – – – – – 8 7 6 5 4 3 2 1 + + + + + + + + + + – – – – – – – – – – 8 7 6 5 4 3 2 1 Description 1 2 3 4 5 6 7 8 1 2 3 4 5 6 7 8 184 Connection Modules for Sensors and Actuators 2 Item No. Pack. Unit 289-665 289-666 1 1 Technical Data Operating voltage Max. current per connection Max. total current Power consumption LED Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Dimensions (mm) W x H x L incl. mounting feet or mounting carrier 125 V AC/DC 1A 8A 24 V DC (± 10 %) 1A 8A 5.2 mA 125 V / 1.5 kV / 2 56 x 34 x 85 56 x 34 x 105 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 185 Connection module for 8 actuators Connection module for 8 actuators with ground (earth) contact 2 1 2 3 4 5 6 7 8 – – – – – – – – – – 8 7 6 5 4 3 2 1 – – – – – – – – – – 8 7 6 5 4 3 2 1 1 2 3 4 5 6 7 8 Description Item No. Pack. Unit Item No. Pack. Unit Connection module 289-667 1 289-671 1 Technical Data Operating voltage Max. current per connection Max. total current Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Dimensions (mm) W x H x L incl. mounting feet or mounting carrier 125 V AC/DC 1A 8A 125 V / 1.5 kV / 2 125 V AC/DC 1A 8A 125 V / 1.5 kV / 2 56 x 34 x 85 56 x 34 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 see page 323 white 709-198 / transparent 709-197 2 Rail-Mounted Modules - Diode Gates 186 Open diode gate with 8 diodes 1 N 4007 can be connected individually * Max. admissible current acc. to the manufacter’s data sheet. With all diodes loaded, the continuous current must be reduced. Open diode gate with 8 diodes P 600 B can be connected individually 1 3 5 7 9 11 13 15 2 4 6 8 10 12 14 16 Description Item No. Pack. Unit Open diode gate 289-101 1 1 3 5 7 9 11 13 15 2 4 6 8 10 12 14 16 Item No. Pack. Unit 289-103 1 Technical Data Operating voltage Peak reverse voltage Rectified current for each diode * Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Dimensions (mm) L x W x H incl. mounting carrier and universal mounting feet 250 V AC/DC 1000 V 1A 250 V / 4 kV / 3 100 V AC/DC 100 V 6A 250 V / 4 kV / 3 -25 °C ... +40 °C 47 x 31.5 x 65.5 -25 °C ... +30 °C 47 x 31.5 x 65.5 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories Item No. Pack. Unit Item No. Pack. Unit Mounting carrier, for screw-fixing or DIN-rail mounting (with snap-fit type universal mounting feet to be ordered separately) 288-001 1 288-001 1 Universal mounting foot; snap-fit type; suitable for DIN 15, 32 and 35 rails (also see page 258) 288-002 10 288-002 10 2 187 Open diode gate with 9 diodes 1 N 5408 can be connected individually 2 inputs/2 outputs per diode including Mounting carrier for DIN 35 rail 2 * Max. admissible current acc. to the manufacter’s data sheet. With all diodes loaded, the continuous current must be reduced. 2 4 6 8 10 12 14 16 18 1 3 5 7 9 11 13 15 17 Description Item No. Pack. Unit Open diode gate 289-105 1 Technical Data Operating voltage Peak reverse voltage Rectified current for each diode * Rectified current for each diode Forward voltage for each Diode Forward current (resistent) for each diode Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Dimensions (mm) L x W x H incl. mounting carrier and universal mounting feet 250 V AC/DC 1000 V 3A 10 μA 1.3 V 3A 250 V / 4 kV / 3 -25 °C ... +40 °C 51 x 48 x 85 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 736 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-197 2 Rail-Mounted Modules - Diode Gates 188 Polarized diode gate with 14 diodes 1 N 4007 common cathode – * Max. admissible current acc. to the manufacter’s data sheet. With all diodes loaded, the continuous current must be reduced. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 + Polarized diode gate with 14 diodes 1 N 4007 common anode + + – – 1 2 3 4 5 6 7 8 9 10 11 12 13 14 – + Description Item No. Pack. Unit Item No. Pack. Unit Polarized diode gate 289-111 1 289-121 1 Technical Data Operating voltage Peak reverse voltage Rectified current for each diode * Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Dimensions (mm) L x W x H incl. mounting carrier and universal mounting feet 250 V AC/DC 1000 V 1A 250 V / 4 kV / 3 250 V AC/DC 1000 V 1A 250 V / 4 kV / 3 -25 °C ... +40 °C 47 x 31.5 x 65.5 -25 °C ... +40 °C 47 x 31.5 x 65.5 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories Item No. Pack. Unit Item No. Pack. Unit Mounting carrier, for screw-fixing or DIN-rail mounting (with snap-fit type universal mounting feet to be ordered separately) 288-001 1 288-001 1 Universal mounting foot; snap-fit type; suitable for DIN 15, 32 and 35 rails (also see page 258) 288-002 10 288-002 10 2 189 Lamp test circuit module with 20 diodes for testing 10 lamps with Mounting feet for DIN 35 rail LED gate module with 16 LEDs, common anode or cathode 2 1 2 3 4 5 6 7 8 9 10 11 13 12 14 15 16 17 18 19 20 21 22 Description Item No. Pack. Unit Gate module 289-151 1 8 7 6 5 4 3 2 1 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 – + + – – 16 15 14 13 12 11 10 9 + Item No. Pack. Unit 289-202 289-201 1 1 Technical Data Operating voltage Operating voltage range Power consumption at VN Peak reverse voltage Rectified current for each diode, resistive Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Dimensions (mm) W x H x L incl. mounting feet or mounting carrier Wire connection Cross sections Stripped lengths 250 V AC/DC 0 V ... 250 V AC/DC 24 V DC 20 V ... 26 V DC 5.6 mA each LED 1600 V 1A 250 V / 4 kV / 3 -25 °C ... +40 °C 69 x 21 x 50 -25 °C ... +40 °C 47 x 31.5 x 65.5 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories Item No. Pack. Unit Mounting carrier, for screw-fixing or DIN-rail mounting (with snap-fit type universal mounting feet to be ordered separately) 288-001 1 Universal mounting foot; snap-fit type; suitable for DIN 15, 32 and 35 rails (also see page 258) 288-002 10 2 Rail-Mounted Modules - Resistor Gates 190 Resistor gate with 1 end commoned, 8 resistors 2 k 2; 1 W Open resistor gate with 8 resistors 2 k 7; 0.6 W individual connection possible other resistors – contact factory * Max. admissible power dissipation of a single resistor. With all resistors loaded, the max. admissible power dissipation must be reduced. Description Item No. Pack. Unit Item No. Pack. Unit Resistor gate 289-113 1 289-114 1 Technical Data Operating voltage Resistor type Temperature coefficient Tolerance Power dissipation * Ambient operating temperature Dimensions (mm) L x W x H incl. mounting carrier and universal mounting feet 40 V AC/DC DIN 0414 50 ppm ± 1% 1W -25 °C ... +40 °C 47 x 31.5 x 65.5 40 V AC/DC DIN 0207 50 ppm ± 1% 0.6 W -25 °C ... +40 °C 47 x 31.5 x 65.5 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories Item No. Pack. Unit Item No. Pack. Unit Mounting carrier, for screw-fixing or DIN-rail mounting (with snap-fit type universal mounting feet to be ordered separately) 288-001 1 288-001 1 Universal mounting foot; snap-fit type; suitable for DIN 15, 32 and 35 rails (also see page 258) 288-002 10 288-002 10 2 Rail-Mounted Modules for Building Custom Circuits 191 Module with 2 x 8 drilled holes Diameter of drilled holes 1 mm, Pin spacing 3.83 mm x 16 mm Module with 2 x 8 soldering points Pin spacing 5 mm x 12 mm 2 Description Item No. Pack. Unit Item No. Pack. Unit Module for building custom circuits 289-102 1 289-131 1 Technical Data Operating voltage Nominal current Ambient operating temperature Dimensions (mm) L x W x H incl. mounting carrier and universal mounting feet 250 V AC/DC 3A -25 °C ... +40 °C 42.5 x 32 x 62.5 250 V AC/DC 3A -25 °C ... +40 °C 42.5 x 32 x 62.5 Wire connection Cross sections Stripped lengths Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories Item No. Pack. Unit Item No. Pack. Unit Mounting carrier, for screw-fixing or DIN-rail mounting (with snap-fit type universal mounting feet to be ordered separately) 288-001 1 288-001 1 Universal mounting foot; snap-fit type; suitable for DIN 15, 32 and 35 rails (also see page 258) 288-002 10 288-002 10 3 192 WAGO Application: Danone Group, Ochsenfurt Plant, Germany Producer of yogurt and other dairy-based products WAGO Products: WAGO-I/O-SYSTEM with PROFIBUS Couplers 3 Transducers 193 3 857 Series JUMPFLEX® Transducers WAGOframe WAGO USB Service Cable Accessories, 857 Series JUMPFLEX® 8-Channel Adapters for System Wiring 194 – 219 220 221 222 223 286 Series Pluggable Modules - Temperature Transducers 224 – 228 786 Series Pluggable Modules - Analog Signal Conditioning Accessories 230 – 232 233 3 857-400 Isolation amplifier, with zero/span adjustment IN+ 1 5 OUT+ IN OUT GND 1 2 6 GND 2 Us+ 3 7 Us+ POWER GND 3 4 8 GND 3 194 JUMPFLEX® Transducers ____________ Short description: The configurable 857-400 Isolation Amplifier is used to convert, amplify, filter and electrically isolate analog standard signals. The device has a 3-way isolation with a 2.5kV test voltage. On the input and output side, the following signals can be configured via DIP switches that are accessible from the side of the housing: 0 - 10V, 2 - 10V, 0 - 20mA, 4 - 20mA, 0 - 5V and 1 - 5V. Measurement range switching is calibrated. Item No. Pack. Unit Technical Data Isolation amplifier, with zero/span adjustment 857-400 1 Configuration Input signal General accessories Input resistance see pages 222 - 223 Output signal Load impedance Max. operating frequency Approvals Shipbuilding 4 r ANSI/ISA 12.12.01 Conformity marking g (pending) Class I, Div. 2, Grp. ABCD, T4 1 General Specifications Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 6 x 96 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP®S solid: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 fine-stranded: 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in 6 mm/0.23 in The device is supplied with 24VDC, which can be commoned using lateral push-in type jumper bars in a quick and cost effective way. A green LED on the front panel indicates normal operation. The isolation amplifier meets the requirements for safe isolation of input, output and supply circuits with 2.5kV test voltage according to EN 61140. Description Accessories _> _> 3 Response time (T10-90) Zero/span adjustment Voltage supply VN Supply voltage range Current input at 24 V DC Transmission error Temperature coefficient Test voltage (input/output/supply) Ambient operating temperature Storage temperature DIP switch 0 ... 20 mA, 4 ... 20 mA, 0... 5 V, 0 ... 10 V, 2 ... 10 V, 1 ... 5 V (calibrated switchable)  50 Ω (In = mA)  100 kΩ (In = V) 0 ... 20 mA, 4 ... 20 mA, 0... 5 V, 0 ... 10 V, 2 ... 10 V, 1 ... 5 V (calibrated switchable) 600 Ω (Out = mA) 2 kΩ (Out = V) 100 Hz / > 5 kHz (switchable via DIP switch) < 3.5 ms / < 100 μs ±3% 24 V DC 16.8 V ... 31.2 V < 25 mA < 0.1 % of the full scale value 0.01 % /K 2.5 kV AC, 50 Hz, 1 min -25 °C ... +70 °C -40 °C ... +85 °C S 3 195 DIP Switch Adjustability Dip Switch S1 (2-fold) Dip Switch S2 (6-fold) Input Signal 1 2 ▯ Output Signal 1 2 Transmission 3 0 … 20 mA ▯ 857-400 ▯ = ON 4 5 0 … 20 mA 4 … 20 mA Input / Output 1 : 1 ▯ 4 … 20 mA ▯ 0 … 10 V ▯ ▯ 0 … 10 V ▯ 2 … 10 V ▯ ▯ 2 … 10 V 0…5V ▯ ▯ ▯ 0…5V 1…5V ▯ ▯ ▯ 1…5V Max. Operating Frequency 6 ▯ Input LZ / Output DZ f approx.. 5 kHz max. ▯ fmax. < 100 Hz Input DZ / Output LZ LZ = Live Zero (displaced zero-point, e.g., 4 - 20 mA) DZ = Dead Zero (e.g., 0 - 20 mA) 3 Default Settings - Input: 0 ... 20 mA - Output: 0 ... 20 mA - Max. Operating Frequency: > 5 kHz 857-401 Isolation amplifier, configurable with digital output IN+ 1 GND 1 2 IN U,I OUT 5 OUT+ U,I 6 GND 2 DO 7 Us+ POWER 8 GND 3 DO 3 GND 3 4 196 JUMPFLEX® Transducers ____________ Short description: The software-configurable 857-401 Isolation Amplifier is used to convert, amplify, filter and electrically isolate analog standard signals. The device has a 3way isolation with a 2.5kV test voltage. DIP switches accessible from the side can be used to configure the signals in both input and output. In addition to standard signals, bipolar (± 10V, ± 20mA) and 0 to 30V signals can also be set on the input side. The analog output supports standard unipolar signals. In addition, the devices can be configured using FDT/DTM software. The software offers additional setting options such as special input and output signal combinations with intermediate values or inversion of the analog output. Measurement range switching is calibrated. A digital switching output is available that can also be configured using software. Item No. Pack. Unit Technical Data Isolation amplifier, configurable with digital output 857-401 1 Configuration Input signal Max. input signal Input resistance Configuration software WAGO USB Service Cable General accessories Output signal - 759-370 FDT Frame Application - DTM (Device Tool Manager) Download: see www.wago.com 750-923 see pages 222 - 223 Approvals Shipbuilding 4 r ANSI/ISA 12.12.01 Conformity marking g (pending) Class I Div2 ABCD T4 1 General Specifications Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 6 x 96 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP®S solid: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 fine-stranded: 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in 6 mm/0.23 in The device is supplied with 24VDC, which can be commoned using lateral push-in type jumper bars in a quick and cost effective way. A green LED on the front panel indicates normal operation. The isolation amplifier meets the requirements for safe isolation of input, output and supply circuits with 2.5kV test voltage according to EN 61140. Description Accessories _> _> 3 Load impedance Step response Voltage supply VN Supply voltage range Current input at 24 V DC Transmission error Temperature coefficient Min. measuring span Output - Digital Max. switching voltage Max. continuous current Test voltage (input/output/supply) Ambient operating temperature Storage temperature DIP switch or configuration software -10 ... +10 V, -20 ... +20 mA, 0 ... +30 V (31.2 V (UIN) 100 mA (IIN)  200 Ω (I input) > 100 kΩ (U input) 0 ... 20 mA, 4 ... 20 mA, 0 ... 10 V, 2 ... 10 V, 0... 5 V, 1 ... 5 V, 0 ... 10 mA, 2 ... 10 mA  600 Ω (I output)  2 kΩ (U output)  8 ms 24 V DC 16.8 V ... 31.2 V < 40 mA < 0.1 % of upper range value 0.01 % /K 1 V, 2 mA (configurable) Supply voltage applied 500 mA (up to 60 °C) 100 mA (60 °C ... 70 °C) 2.5 kV AC, 50 Hz, 1 min. -25 °C ... +70 °C -40 °C ... +85 °C S 3 197 DIP Switch Adjustability 857-401 ▯ = ON End Value Start Value Input Signal DIP S1 DIP S1 1 2 3 4 5 6 7 Voltage ● Current ● ● ● ● ● ● ● ● -7 -10 ● -4.5 -9 ● ● -4 -8 ● ● -3.5 -7 ● ● ● -3 -6 ● -2.5 -5 ● -2 -4 ● ● -1.5 -3 ● ● -1 -2 ● ● -0.5 -1 ● ● 0 0 ● ● ● 0.5 1 ● ● ● 1 2 ● ● 1.5 3 ● ● 2 4 ● ● ● 2.5 5 ● ● ● 3 6 ● ● ● 3.5 7 ● ● ● ● 4 8 ● 4.5 9 ● ● ● ● 5 10 ● 7 14 ● ● 7.5 15 ● ● 8 16 ● ● ● 8.5 17 ● ● 7 8 ● ● 19 ● ● 10 20 ● ● 10.5 ● 11 ● ● 11.5 ● ● ● 12 ● ● ● ● 13 ● ● ● ● 14 ● ● 15 ● ● 16 ● ● ● 17 ● ● ● 18 ● ● ● 19 ● ● ● 20 ● ● ● ● 21 ● ● ● ● 22 ● ● ● 23 ● ● ● 24 ● ● ● ● 25 ● ● ● ● 26 ● ● ● ● 27 ● ● ● ● 28 ● ● ● ● ● 29 ● ● ● ● ● 30 Measuring Range Overflow Measuring Range Underflow Upper limit of output range Lower limit of output range +2.5% -5% Upper limit of output range Lower limit of output range 9 Measuring Range Overflow/ Measuring Range Underflow Signalisation* 8 DO GND switched 10 1 2 DIP S1 3 ● ● ● ● ● ● ● -8 -7 -14 -6 -12 -5 -10 ● -4.5 -9 ● ● -4 -8 ● ● -3.5 -7 ● ● ● -3 -6 -2.5 -5 ● -2 -4 ● ● -1.5 -3 ● ● -1 -2 ● ● -0.5 -1 ● ● 0 0 ● ● ● 0.5 1 ● ● ● 1 2 ● ● 1.5 3 ● ● 2 4 ● ● ● 2.5 5 ● ● ● 3 6 ● ● 3.5 7 ● ● ● 4 8 ● ● ● ● 4.5 9 ● ● ● ● 5 10 DO ● ● ● Upper limit of output range Lower limit of output range ● Upper limit of output range Lower limit of output range ● 7 14 ● ● 7.5 15 ● ● 8 16 ● ● ● 8.5 17 ● ● 18 ● 9 ● ● 9.5 19 ● ● 10 20 10.5 ● ● ● ● ● ● 11 ● ● 11.5 ● ● ● 12 ● ● ● ● 13 ● ● ● not active active - Input signal: Voltage - Start value: 0 V - Output signal: Current - End value: 20 mA - Measuring range underflow: 0 mA - Measuring range overflow: 20.5 mA Digital output - not active 15 16 ● ● ● 17 ● ● ● 18 ● ● ● 19 ● ● ● 20 ● ● ● ● 21 ● ● ● ● 22 ● ● ● 23 ● ● ● 24 ● ● ● ● 25 ● ● ● ● 26 ● ● ● 27 ● ● ● ● 28 ● ● ● ● ● 29 ● ● ● ● ● 30 Default Settings Input 14 ● ● ● ● ● ● ● ● 1…5V * related to input signal ● ● - Start value: 0 mA 0…5V 12 ● ● 11 13 ● ● mA 6 ● ● V 5.5 6.5 ● ● 3 ● ● In delivery status all DIP switches are in the position “OFF“. 10 2 ● ● - End value: 10 V ● 1 ● ● -5.5 -11 ● ● DIP S2 10 -6.5 -13 ● ● ● -16 ● ● 9 ● -7.5 -15 ● ● -18 ● ● 8 -8.5 -17 ● ● -20 ● ● ● -10 ● ● ● 20 ● ● ● 10 -9 ● ● mA -9.5 -19 ● ● V ● ● DO Us+ switched ● 9 Output ● ● 18 9.5 ● 2 … 10 V ● 9 ● ● +2.5% 2 … 10 mA ● ● ● ● ● 11 ● ● ● 5.5 12 0 … 10 V ● ● ● ● 13 ● ● ● ● ● mA 6 ● ● V 6.5 ● ● 0 … 10 mA ● 7 ● ● ● ● 6 ● ● ● 4 … 20 mA 5 ● ● ● 0 … 20 mA ● ● -5.5 -11 ● 6 ● -12 -5 Output Signal Range 5 -6 ● ● 4 -14 4 -6.5 -13 ● ● ● -16 ● ● ● -18 3 ● -7.5 -15 ● ● -20 ● ● ● -10 -8 ● ● ● 0 2 -8.5 -17 ● ● ● 0 -9 ● ● mA -9.5 -19 ● ● V DIP S2 3 857-409 Bipolar isolation amplifier U+ 1 U– 2 I+ 3 I– 4 IN U; I 5 OUT+ OUT U; I 6 OUT7 Us+ POWER 8 GND 198 JUMPFLEX® Transducers ____________ Short description: The 857-409 Bipolar Isolation Amplifier records bipolar analog signals (e.g., ±10V or ± 20mA) and converts them into bipolar, analog standard signals. After conversion, the isolated signals are transmitted with high accuracy to the output where they are available in an amplified form and are electrically isolated. In addition, unipolar signals (e.g., 0 - 20mA or 0 - 10V) and live zero signals (e.g., 4 - 20mA or 2 - 10V) can be adjusted independently of one another at both input and ouput via DIP switches. Item No. Pack. Unit Technical Data Bipolar isolation amplifier 857-409 1 Configuration Input signal General accessories Output signal see pages 222 - 223 Load impedance Max. operating frequency Approvals Shipbuilding 4 r ANSI/ISA 12.12.01 Conformity marking g (pending) Class I, Div. 2, Grp. ABCD, T4 1 General Specifications Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 6 x 96 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP®S solid: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 fine-stranded: 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in 6 mm/0.23 in Adjusting the limiting frequency is also performed via DIP switches. Measured distance adjustment is carried out via zero/span potentiometers on the front of the device, while signal switching is performed in a calibrated way, which requires no additional adjustment when switching to another range. The device is supplied with 24VDC, which can be commoned using lateral push-in type jumper bars in a quick and cost effective way. A green LED on the front panel indicates normal operation. The bipolar isolation amplifier meets the requirements for safe isolation of input, output and supply circuits with 2.5kV test voltage according to EN 61140. Description Accessories _> _> 3 Zero/span adjustment Voltage supply VN Supply voltage range Transmission error Test voltage (input/output/supply) Ambient operating temperature Storage temperature DIP switch ± 5 V, 0 ... 5 V, 1 ... 5 V, ± 10 V, 0 ... 10 V, 2 ... 10 V, ± 10 mA, 0 ... 10 mA, 2 ... 10 mA, ± 20 mA, 0 ... 20 mA, 4 ... 20 mA ± 5 V, 0 ... 5 V, 1 ... 5 V, ± 10 V, 0 ... 10 V, 2 ... 10 V, ± 10 mA, 0 ... 10 mA, 2 ... 10 mA, ± 20 mA, 0 ... 20 mA, 4 ... 20 mA  600 Ω (I output)  2 kΩ (U output) 100 Hz / > 5 kHz (switchable via DIP switch) ±5% 24 V DC 16.8 V ... 31.2 V < 0.1 % of upper range value 2.5 kV AC, 50 Hz, 1 min -25 °C ... +70 °C -40 °C ... +85 °C S 3 199 DIP Switch Adjustability DIP Switch S1 (4-fold) 1 2 3 ▯ ▯ Input 4 DIP Switch S2 (6-fold) 1 2 3 ± 20 mA ▯ ▯ ± 10 mA ▯ ▯ 857-409 ▯ = ON ▯ ± 10 V ▯ ▯ ±5V ▯ ▯ ▯ Output 4 5 ▯ ▯ ▯ ± 20 mA ▯ ± 10 mA ▯ ± 10 V ▯ ±5V ▯ 0 … 10 mA ▯ 2 … 10 mA ▯ 0 … 10 V ▯ ▯ ▯ 2 … 10 V ▯ ▯ 0…5V ▯ ▯ ▯ 1…5V ▯ ▯ ▯ ▯ Default Settings - Input: ± 10 V - Output: ± 10 V - Max. Operating Frequency: > 5 kHz ▯ < 100 Hz approx. 5 kHz 0 … 20 mA 4 … 20 mA ▯ ▯ 6 ▯ 0 … 20 mA Max. Operating Frequency ▯ 4 … 20 mA ▯ 2 … 10 mA ▯ 2 … 10 V 0 … 10 mA 0 … 10 V 0…5V ▯ 1…5V 3 857-411,857-412 Isolation amplifiers, fixed setting for voltage or current signals IN+ 1 5 OUT+ IN OUT GND 1 2 6 GND 2 Us+ 3 7 Us+ POWER GND 3 4 8 GND 3 200 S JUMPFLEX® Transducers ____________ _> _> 3 6 mm/0.23 in Short description: The configurable isolation amplifiers convert, amplify, filter and electrically isolate analog standard signals. The devices have a 3-way isolation with a 2.5kV test voltage. The 857-411 Isolation Amplifier provides electrical isolation between the 0(4) - 20mA input and the 0(4) - 20mA output analog current signals. The 857-412 Isolation Amplifier provides electrical isolation between the 0(2) - 10V input and the 0(2) - 10V output analog voltage signals. The device is supplied with 24VDC, which can be commoned using lateral push-in type jumper bars in a quick and cost effective way. A green LED on the front panel indicates normal operation. The isolation amplifiers meet the requirements for safe isolation of input, output and supply circuits with 2.5kV test voltage according to EN 61140. Description Item No. Pack. Unit Technical Data Isolation amplifier, fixed setting for current signals Isolation amplifier, fixed setting for voltage signals 857-411 1 Input signal 857-412 1 Input resistance Output signal Accessories General accessories see pages 222 - 223 Load impedance g (pending) Class I, Div. 2, Grp. ABCD, T4 1 Max. operating frequency Response time (T10-90) Voltage supply VN Supply voltage range Current input at 24 V DC Transmission error Temperature coefficient Test voltage (input/output/supply) Ambient operating temperature Storage temperature Approvals Shipbuilding 4 r ANSI/ISA 12.12.01 Conformity marking General Specifications Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Dimensions (mm) W x H x L 6 x 96 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP®S solid: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 fine-stranded: 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in 6 x 96 x 94 0(4) ... 20 mA (857-411) 0(2) ... 10 V (857-412) (857-411)  50 Ω (In = mA)  100 kΩ (In = V) 0(4) ... 20 mA (857-411) (857-411) 0(2) ... 10 V (857-412) (857-412) 600 Ω (857-411) 2 kΩ (857-412) 100 Hz < 3.5 ms 24 V DC 16.8 V ... 31.2 V < 25 mA < 0.1 % of the full scale value 0.01 % /K 2.5 kV AC, 50 Hz, 1 min -25 °C ... +70 °C -40 °C ... +85 °C 857-451,857-452 S JUMPFLEX® Transducers Passive isolator, 1 channel, 2 channels 201 IN 1+ 1 5 OUT 1+ IN 1 OUT 1 GND 1 2 6 GND 2 IN 2+ 3 7 OUT 2+ IN 2 OUT 2 GND 3 4 8 GND 4 3 _> _> ____________ 6 mm/0.23 in Short description: The 1- and 2-channel passive isolators filter and electrically isolate 0(4) - 20mA analog standard signals. The devices have a 2-way isolation with a 2.5kV test voltage. The passive isolators require no additional power supply. The power required for signal isolation is derived from the input circuit. Description Item No. Pack. Unit Technical Data Passive isolator, 1 channel 857-451 1 Passive isolator, 2 channels 857-452 1 Input signal Voltage drop intput Output signal Load impedance Max. operating frequency Response time (T10-90) Transmission error Temperature coefficient Ambient operating temperature Storage temperature Accessories General accessories see pages 222 - 223 Approvals Shipbuilding 4 r ANSI/ISA 12.12.01 Conformity marking g (pending) Class I, Div. 2, Grp. ABCD, T4 1 General Specifications Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 3 6 x 96 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP®S solid: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 fine-stranded: 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in 0(4) ... 20 mA < 2.0 V 0(4) ... 20 mA 600 Ω 100 Hz < 3.5 ms < 0.1 % of the full scale value 0.01 % /K -25 °C ... +70 °C -40 °C ... +85 °C 857-420 Repeater power supply, configurable with current and voltage output USensor+ 1 5 OUT+ OUT 6 GND 2 IN 2 IN GND 1 3 GND 1 4 7 Us+ POWER 8 GND 3 202 JUMPFLEX® Transducers ____________ Short description: The 857-420 Repeater Power Supply links 2- or 3-wire transmitters located in the field. It provides the power required and transmits the analog signals in an electrically isolated way. On the output side, the repeater power supply can be configured for the following analog signals: 0 - 20mA, 4 - 20mA, 0 - 10V, 2 - 10V, 0 - 5V, 1 - 15V. The device has a 3-way isolation with a 2.5kV test voltage. The devices can be configured via DIP switches that are accessible from the side of the housing. Measurement range switching is calibrated. In addition, the device can also be operated as a mere isolation amplifier. Terminal assignment: [ IN+(2) and GND1(3) ]. The device is supplied with 24VDC, which can be commoned using lateral push-in type jumper bars in a quick and cost effective way. Item No. Pack. Unit Technical Data Repeater power supply, configurable with current and voltage output 857-420 1 Configuration Input signal General accessories Input resistance Output signal see pages 222 - 223 Load impedance Approvals Shipbuilding 4 r ANSI/ISA 12.12.01 Conformity marking g (pending) Class I, Div. 2, Grp. ABCD, T4 1 General Specifications Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 6 x 96 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP®S solid: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 fine-stranded: 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in 6 mm/0.23 in A green LED on the front panel indicates normal operation. The repeater power supply meets the requirements for safe isolation of input, output and supply circuits with 2.5kV test voltage according to EN 61140. Description Accessories _> _> 3 Max. operating frequency Response time (T10-90) Voltage supply VN Supply voltage range Current input at 24 V DC Transmitter supply Transmission error Temperature coefficient Test voltage (input/output/supply) Ambient operating temperature Storage temperature DIP switch 0 ... 20 mA, 4 ... 20 mA (calibrated switchable)  50 Ω 0 ... 20 mA, 4 ... 20 mA, 0... 5 V, 0 ... 10 V, 2 ... 10 V, 1 ... 5 V (calibrated switchable) 600 Ω (Out = mA) 2 kΩ (Out = V) 100 Hz < 3.5 ms DC 24 V 16.8 V ... 31.2 V < 45 mA Vv = 18 V at 30 mA < 0.1 % of the full scale value 0.01 % /K 2.5 kV AC, 50 Hz, 1 min -25 °C ... +70 °C -40 °C ... +85 °C S 3 203 DIP Switch Adjustability 857-420 ▯ = ON DIP 1 Input Output 1 2 3 0 … 20 mA 0 … 20 mA 0 … 20 mA 4 … 20 mA 0 … 20 mA 0 … 10 V ▯ ▯ 0 … 20 mA 2 … 10 V ▯ ▯ 0 … 20 mA 0…5V ▯ ▯ ▯ 0 … 20 mA 1…5V ▯ ▯ ▯ 4 … 20 mA 0 … 20 mA 4 … 20 mA 4 … 20 mA 4 … 20 mA 0 … 10 V ▯ ▯ 4 … 20 mA 2 … 10 V ▯ ▯ 4 … 20 mA 0…5V ▯ ▯ ▯ 4 … 20 mA 1…5V ▯ ▯ ▯ 4 5 6 n.c. ▯ n.c. n.c. ▯ n.c. n.c. ▯ n.c. ▯ n.c. ▯ n.c. n.c. n.c. ▯ n.c. n.c. Default Settings: - Input: 0 … 20 mA - Output: 0 … 20 mA - DIP 6: n.c. - not connected Connection assignment 857-420 IN OUT Transmitter passive +Us 1 OUT 2 Transmitter aktive + 2 Config + 1 +Us 1 5 + – 2 +IN 2 U/I GND 3 6 – 2-wire – 3 GND 3 3-wire 24 V DC = = POWER 24 V DC 7 + = 8 – 3 857-421 Repeater power supply, HART USensor+ 1 5 OUT + OUT 6 GND 2 IN 2 IN N.C. 3 N.C. 4 7 Us+ POWER 8 GND 3 204 JUMPFLEX® Transducers ____________ Short description: The 857-421 HART Repeater Power Supply links SMART transmitters located in the field. It provides the power required and transmits the analog signals in an electrically isolated way. Transmission of the data protocol (e.g., HART) is bi-directional for SMART transmitters. Digital signals for data communication between transmitter and process controller are superimposed on the analog current signal, and they are used for diagnosing and calibrating the field transmitters. The device has a 3-way isolation with a 2.5kV test voltage. The device is supplied with 24VDC, which can be commoned using lateral push-in type jumper bars in a quick and cost effective way. Item No. Pack. Unit Technical Data Repeater power supply, HART 857-421 1 Input signal Input resistance Output signal Load impedance Max. operating frequency Response time (T10-90) Voltage supply VN Supply voltage range Current input at 24 V DC Transmitter supply Transmission error Temperature coefficient Test voltage (input/output/supply) Ambient operating temperature Storage temperature General accessories see pages 222 - 223 Approvals Shipbuilding 4 r ANSI/ISA 12.12.01 Conformity marking g (pending) Class I, Div. 2, Grp. ABCD, T4 1 General Specifications Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 6 x 96 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP®S solid: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 fine-stranded: 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in 6 mm/0.23 in A green LED on the front panel indicates normal operation. The repeater power supply meets the requirements for safe isolation of input, output and supply circuits with 2.5kV test voltage according to EN 61140. Description Accessories _> _> 3 4 ... 20 mA  50 Ω 4 ... 20 mA 600 Ω 100 Hz signal /  2.5 kHz HART < 3.5 ms signal 24 V DC 16.8 V ... 31.2 V < 45 mA Vv = 18 V at 30 mA < 0.1 % of the full scale value 0.01 % /K 2.5 kV AC, 50 Hz, 1 min -25 °C ... +70 °C -40 °C ... +85 °C S 3 205 Simultaneous transmission of analog and digital signals 857-421 mA 20 HART - signal (digital) analog signal 3 4 t 857-423 Signal splitter with 2 configurable current outputs IN+ 1 5 OUT 1+ IN OUT 1 GND 1 2 6 GND 2 OUT 2+ 3 OUT 2 GND 4 4 7 Us+ POWER 8 GND 3 206 JUMPFLEX® Transducers ____________ _> _> 3 6 mm/0.23 in Short description: The 857-423 Signal Splitter is used to convert, amplify, filter and electrically isolate analog standard signals. The device has a 3-way isolation with a 2.5kV test voltage. The signal splitter transmits the configurable input signal (0 - 10V, 2 - 10V, 0 - 20mA, 4 - 20mA, 0 - 5V or 1 - 5V) in two analog current outputs that can be set independently of one another between 0 - 20mA and 4 - 20mA. Measurement range switching is calibrated. The device is supplied with 24VDC, which can be commoned using lateral push-in type jumper bars in a quick and cost effective way. A green LED on the front panel indicates normal operation. The signal splitter meets the requirements for safe isolation of input, output and supply circuits with 2.5kV test voltage according to EN 61140. Description Item No. Pack. Unit Technical Data Signal splitter with 2 configurable current outputs 857-423 1 Configuration Input signal Input resistance Accessories General accessories see pages 222 - 223 Output signal Load impedance Max. operating frequency Approvals Shipbuilding 4 r ANSI/ISA 12.12.01 Conformity marking g (pending) Class I, Div. 2, Grp. ABCD, T4 1 General Specifications Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 6 x 96 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP®S solid: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 fine-stranded: 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in Response time (T10-90) Voltage supply VN Supply voltage range Current input at 24 V DC Transmission error Temperature coefficient Test voltage (input/output/supply) Ambient operating temperature Storage temperature DIP switch 0 ... 20 mA, 4 ... 20 mA, 0... 5 V, 0 ... 10 V, 2 ... 10 V, 1 ... 5 V (calibrated switchable)  50 Ω (In = mA)  100 kΩ (In = V) 2 x 0(4) ... 20 mA (calibrated switchable) 2 x 300 Ω 100 Hz / 1 kHz (switchable via DIP switch) < 3.5 ms / < 300 μs 24 V DC 16.8 V ... 31.2 V < 35 mA < 0.1 % of the full scale value 0.01 % /K 2.5 kV AC, 50 Hz, 1 min -25 °C ... +70 °C -40 °C ... +85 °C S 3 207 DIP Switch Adjustability 857-423 ▯ = ON DIP Switch S1 (6-fold) Input Signal 1 2 Max. Operating Frequency 3 ▯ 4 0 … 20 mA ▯ ▯ 4 … 20 mA ▯ 2 … 10 V ▯ ▯ Output 1 5 fmax. approx. 1 kHz ▯ fmax. < 100 Hz Output 2 6 0 … 20 mA ▯ 4 … 20 mA 0 … 20 mA ▯ 4 … 20 mA 0 … 10 V 0…5V ▯ 1…5V 3 Default Settings - Input: 0 ... 20 mA - Output 1: 0 … 20 mA - Output 2: 0 … 20 mA - Max. Operating Frequency: < 100 Hz 857-800 Temperature transducer for Pt100, Pt200, Pt500 and Pt1000 as well as resistors 0 ... 1 kȍ; 0 ... 4.5 kȍ 5 OUT+ 1 OUT 6 GND 1 2 IN 7 Us+ POWER 8 GND 2 3 4 208 JUMPFLEX® Transducers ____________ Short description: The 857-800 Temperature Transducer is suitable for the connection of Pt100, Pt200, Pt500 and Pt1000 sensors in 2-, 3- and 4-conductor connection technology. On the input side, 0 - 1k or 0 - 4.5k resistance values can be measured. On the output side, the Pt100 temperature transducer converts the temperature signal into an analog standard signal. The following signals are available: 0 - 20mA, 4 - 20mA, 0 - 10V, 2 - 10V, 0 - 5V, 1 - 5V, 0 - 10mA and 2 - 10mA. The device has a 3-way isolation with a 2.5kV test voltage. The devices can be configured via DIP switches that are accessible from the side of the housing. Measurement range switching is calibrated. The device is supplied with 24VDC, which can be commoned using lateral push-in type jumper bars in a quick and cost effective way. _> _> 3 6 mm/0.23 in A green LED on the front panel indicates normal operation. The temperature transducer meets the requirements for safe isolation of input, output and supply circuits with 2.5kV test voltage according to EN 61140. Description Item No. Pack. Unit Technical Data Temperature transducer for Pt100, Pt200, Pt500 und Pt1000 as well as resistors 0 ... 1 kΩ; 0 ... 4.5 kΩ 857-800 1 Configuration Input signal DIP switch PT sensors and resistors Output signal 0 ... 20 mA, 4 ... 20 mA, 0 ... 10 V, 2 ... 10 V, 0... 5 V, 1 ... 5 V, 0 ... 10 mA, 2 ... 10 mA  600 Ω (Out = mA)  2 kΩ (Out = V) 180 ms (360 ms at 3-wire) 24 V DC 16.8 V ... 31.2 V < 40 mA Pt100, Pt200, Pt500, Pt1000 2-wire, 3-wire, 4-wire (switchable) -200 °C ... +850 °C 0 ... 1 kΩ , 0 ... 4.5 kΩ  0.1 % at max. measuring span ((10 K / set measuring span [K]) + 0.1) % Accessories General accessories see pages 222 - 223 Load impedance Approvals Shipbuilding 4 r ANSI/ISA 12.12.01 Conformity marking g (pending) Class I, Div. 2, Grp. ABCD, T4 1 General Specifications Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 6 x 96 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP®S solid: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 fine-stranded: 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in Step response Voltage supply VN Supply voltage range Current input at 24 V DC Sensor types Sensor connection Temperature range Resistor input Transmission error Transmission error of set measuring span Temperature coefficient Min. measuring span Test voltage (input/output/supply) Ambient operating temperature Storage temperature 0.02 % /K 50 K (50 Ω) (configurable) 2.5 kV AC, 50 Hz, 1 min -25 °C ... +70 °C -40 °C ... +85 °C S 3 209 DIP Switch Adjustability 857-800 ▯ = ON DIP Switch S1 Wire connection 1 Sensor type 2 3 4 2-wire ▯ 6 7 8 Pt100 3-wire ▯ Output signal 5 ▯ ▯ ▯ ▯ Pt500 ▯ Pt1000 ▯ 10 0 … 20 mA Pt200 4-wire 9 ▯ 1 kΩ ▯ 4.5 kΩ 4 … 20 mA ▯ ▯ 0 … 10 mA ▯ 2 … 10 mA ▯ 0 … 10 V ▯ 2 … 10 V ▯ ▯ 0…5V ▯ ▯ 1…5V ▯ ▯ Measuring range underflow Measuring range overflow Wire break Lower limit of output range -5 % Upper limit of output range +2.5 % Upper limit of output range 5% Lower limit of output range -12.5 % Upper limit of output range Upper limit of output range +2.5 % 5% Lower limit of output range Lower limit of output range ▯ Lower limit of output range Upper limit of output range Lower limit of output range Upper limit of output range Lower limit of output range ▯ ▯ Short circuit Upper limit of output range 5% Upper limit of output range 5% Lower limit of output range ▯ According to Namur NE 43 3 DIP Switch S2 Start temperature 1 2 3 4 ▯ ▯ -200 -328 -175 -283 ▯ -150 -238 ▯ -125 -193 ▯ -100 -148 ▯ ▯ -90 -130 ▯ ▯ -80 -112 ▯ -70 -94 ▯ -60 -76 ▯ ▯ -50 -58 ▯ ▯ -40 -40 ▯ ▯ -30 -22 ▯ ▯ -20 -4 ▯ ▯ ▯ -10 14 ▯ ▯ ▯ 0 32 ▯ ▯ ▯ ▯ End temperature °F ▯ ▯ ▯ °C 5 6 7 8 9 ▯ ▯ 32 5 41 ▯ 10 50 ▯ 15 59 ▯ 20 68 ▯ ▯ 25 77 ▯ ▯ 30 86 ▯ 35 95 ▯ 40 104 ▯ ▯ 45 113 ▯ ▯ 50 122 ▯ ▯ 55 131 ▯ ▯ 60 140 ▯ ▯ ▯ 65 149 ▯ ▯ ▯ 70 158 ▯ ▯ °F 0 ▯ ▯ °C ▯ ▯ ▯ 10 5 6 7 8 ▯ ▯ °F ▯ 75 167 80 176 ▯ 85 185 ▯ ▯ 90 194 ▯ ▯ 95 203 ▯ ▯ 100 212 ▯ ▯ ▯ 110 230 ▯ ▯ ▯ 120 248 ▯ ▯ 130 266 ▯ ▯ 140 284 ▯ ▯ ▯ 150 302 ▯ ▯ ▯ 160 320 ▯ ▯ ▯ 170 338 ▯ ▯ ▯ 180 356 ▯ ▯ ▯ ▯ 190 374 ▯ ▯ ▯ ▯ 200 392 ▯ ▯ °C ▯ ▯ ▯ 10 ▯ ▯ ▯ 9 5 6 7 8 ▯ ▯ In delivery status all DIP switches are in the position “OFF“. - 2-wire - Pt100 - Start temperature 0 °C - End temperature 100 °C - 0 … 20 mA - Measuring range underflow 0 mA - Measuring range overflow 20.5 mA - Wire break 21 mA - Short circuit 0 mA 410 220 428 230 446 ▯ ▯ 240 464 ▯ ▯ 250 482 ▯ ▯ 260 500 ▯ ▯ ▯ 270 518 ▯ ▯ ▯ 280 536 ▯ ▯ 290 554 ▯ ▯ 300 572 ▯ ▯ ▯ 325 617 ▯ ▯ ▯ 350 662 ▯ ▯ ▯ 375 707 ▯ ▯ ▯ 400 752 ▯ ▯ ▯ ▯ 425 797 ▯ ▯ ▯ ▯ 450 842 The minimum distance from the start temperature to the end temperature may not fall short of 50K degrees on the Celsius (C) scale or 122K degrees on the Fahrenheit (F) scale. Default settings °F 210 ▯ ▯ ▯ °C ▯ ▯ ▯ ▯ 10 ▯ ▯ ▯ 9 5 6 7 8 ▯ ▯ °F 475 887 932 ▯ 500 ▯ ▯ 525 997 ▯ ▯ ▯ 550 1022 ▯ ▯ ▯ 575 1067 ▯ ▯ ▯ 600 1022 ▯ ▯ ▯ ▯ 625 1112 ▯ ▯ ▯ ▯ 650 1202 ▯ ▯ ▯ 675 1247 ▯ ▯ ▯ 700 1292 ▯ ▯ ▯ ▯ 725 1337 ▯ ▯ ▯ ▯ 750 1382 ▯ ▯ ▯ ▯ 775 1427 ▯ ▯ ▯ ▯ 800 1472 ▯ ▯ ▯ ▯ ▯ 825 1517 ▯ ▯ ▯ ▯ ▯ 850 1562 ▯ ▯ °C ▯ ▯ ▯ ▯ 10 ▯ ▯ ▯ 9 ▯ 857-801 Temperature transducer for Pt100, Pt200, Pt500 and Pt1000 * as well as resistors 0 ... 1 kȍ; 0 ... 4.5 kȍ 5 OUT+ 1 OUT 6 GND 1 2 IN 7 Us+ POWER 8 GND 2 3 4 210 JUMPFLEX® Transducers ____________ Short description: The 857-801 Temperature Transducer is suitable for the connection of Pt100, Pt200, Pt500 and Pt1000 sensors in 2-, 3- and 4-conductor connection technology. On the input side, 0 - 1k or 0 - 4.5k resistance values can be measured. On the output side, the Pt100 temperature transducer converts the temperature signal into an analog standard signal. The following signals are available: 0 - 20mA, 4 - 20mA, 0 - 10V, 2 - 10V, 0 - 5V, 1 - 5V, 0 - 10mA and 2 - 10mA. The device has a 3-way isolation with a 2.5kV test voltage. The devices can be configured both via DIP switches that are accessible from the side of the housing and using a FDT/DTM software. The software offers additional setting options such as additional types of sensors at the input or inversion of the analog output. Measurement range switching is calibrated. Item No. Pack. Unit Technical Data Temperature transducer for Pt100, Pt200, Pt500 und Pt1000 * as well as resistors 0 ... 1 kΩ; 0 ... 4.5 kΩ 857-801 1 Configuration Input signal Output signal Accessories WAGO USB Service Cable General accessories - 759-370 FDT Frame Application - DTM (Device Tool Manager) Download: see www.wago.com 750-923 see pages 222 - 223 Approvals Shipbuilding 4 r ANSI/ISA 12.12.01 Conformity marking g (pending) Class I, Div. 2, Grp. ABCD, T4 1 General Specifications Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 6 x 96 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP®S solid: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 fine-stranded: 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in 6 mm/0.23 in The device is supplied with 24VDC, which can be commoned using lateral push-in type jumper bars in a quick and cost effective way. A green LED on the front panel indicates normal operation. The temperature transducer meets the requirements for safe isolation of input, output and supply circuits with 2.5kV test voltage according to EN 61140. Description Configuration software _> _> 3 Load impedance Step response Voltage supply VN Supply voltage range Current input at 24 V DC Sensor types Sensor connection Temperature range Resistor input Transmission error Transmission error of set measuring span Temperature coefficient Min. measuring span Test voltage (input/output/supply) Ambient operating temperature Storage temperature DIP switch or via software PT sensors and resistors 0 ... 20 mA, 4 ... 20 mA, 0 ... 10 V, 2 ... 10 V, 0... 5 V, 1 ... 5 V, 0 ... 10 mA, 2 ... 10 mA  600 Ω (Out = mA)  2 kΩ (Out = V) 180 ms (360 ms at 3-wire) 24 V DC 16.8 V ... 31.2 V < 40 mA Pt100, Pt200, Pt500, Pt1000 * 2-wire, 3-wire, 4-wire (switchable) -200 °C ... +850 °C 0 ... 1 kΩ , 0 ... 4.5 kΩ  0.1 % at max. measuring span ((10 K / set measuring span [K]) + 0.1) % 0.02 % /K 50 K (50 Ω) (configurable) 2.5 kV AC, 50 Hz, 1 min -25 °C ... +70 °C -40 °C ... +85 °C ( * Setting of other types of sensors as well as output signal inversion using the configuration software) S 3 211 DIP Switch Adjustability 857-801 ▯ = ON DIP Switch S1 Wire connection 1 Sensor type 2 3 4 2-wire ▯ 6 7 8 Pt100 3-wire ▯ Output signal 5 ▯ ▯ ▯ ▯ Pt500 ▯ Pt1000 ▯ Measuring range underflow 10 0 … 20 mA Pt200 4-wire 9 ▯ 1 kΩ ▯ 4.5 kΩ 4 … 20 mA ▯ ▯ 0 … 10 mA ▯ 2 … 10 mA ▯ 0 … 10 V ▯ 2 … 10 V ▯ ▯ 0…5V ▯ ▯ 1…5V ▯ ▯ Measuring range overflow Wire break Lower limit of output range -5 % Upper limit of output range +2.5 % Upper limit of output range Lower limit of output range 5% -12.5 % Lower limit of output range Upper limit of output range +2.5 % Upper limit of output range Lower limit of output range 5% Lower limit of output range Upper limit of output range Upper limit of output range 5% Lower limit of output range Upper limit of output range Lower limit of output range ▯ ▯ ▯ Short circuit Upper limit of output range 5% Lower limit of output range ▯ According to Namur NE 43 3 DIP Switch S2 Start temperature 1 2 3 4 ▯ ▯ -200 -328 -175 -283 ▯ -150 -238 ▯ -125 -193 ▯ -100 -148 ▯ ▯ -90 -130 ▯ ▯ -80 -112 ▯ -70 -94 ▯ -60 -76 ▯ ▯ -50 -58 ▯ ▯ -40 -40 ▯ ▯ -30 -22 ▯ ▯ -20 -4 ▯ ▯ ▯ -10 14 ▯ ▯ ▯ 0 32 ▯ ▯ ▯ ▯ End temperature °F ▯ ▯ ▯ °C 5 6 7 8 9 ▯ ▯ 32 5 41 ▯ 10 50 ▯ 15 59 ▯ 20 68 ▯ ▯ 25 77 ▯ ▯ 30 86 ▯ 35 95 ▯ 40 104 ▯ ▯ 45 113 ▯ ▯ 50 122 ▯ ▯ 55 131 ▯ ▯ 60 140 ▯ ▯ ▯ 65 149 ▯ ▯ ▯ 70 158 ▯ ▯ °F 0 ▯ ▯ °C ▯ ▯ ▯ 10 5 6 7 8 ▯ ▯ °F ▯ 75 167 80 176 ▯ 85 185 ▯ ▯ 90 194 ▯ ▯ 95 203 ▯ ▯ 100 212 ▯ ▯ ▯ 110 230 ▯ ▯ ▯ 120 248 ▯ ▯ 130 266 ▯ ▯ 140 284 ▯ ▯ ▯ 150 302 ▯ ▯ ▯ 160 320 ▯ ▯ ▯ 170 338 ▯ ▯ ▯ 180 356 ▯ ▯ ▯ ▯ 190 374 ▯ ▯ ▯ ▯ 200 392 ▯ ▯ °C ▯ ▯ ▯ 10 ▯ ▯ ▯ 9 5 6 7 8 ▯ ▯ In delivery status all DIP switches are in the position “OFF“. - 2-wire - Pt100 - Start temperature 0 °C - End temperature 100 °C - 0 … 20 mA - Measuring range underflow 0 mA - Measuring range overflow 20.5 mA - Wire break 21 mA - Short circuit 0 mA 410 220 428 230 446 ▯ ▯ 240 464 ▯ ▯ 250 482 ▯ ▯ 260 500 ▯ ▯ ▯ 270 518 ▯ ▯ ▯ 280 536 ▯ ▯ 290 554 ▯ ▯ 300 572 ▯ ▯ ▯ 325 617 ▯ ▯ ▯ 350 662 ▯ ▯ ▯ 375 707 ▯ ▯ ▯ 400 752 ▯ ▯ ▯ ▯ 425 797 ▯ ▯ ▯ ▯ 450 842 The minimum distance from the start temperature to the end temperature may not fall short of 50K degrees on the Celsius (C) scale or 122K degrees on the Fahrenheit (F) scale. Default settings °F 210 ▯ ▯ ▯ °C ▯ ▯ ▯ ▯ 10 ▯ ▯ ▯ 9 5 6 7 8 ▯ ▯ °F 475 887 932 ▯ 500 ▯ ▯ 525 997 ▯ ▯ ▯ 550 1022 ▯ ▯ ▯ 575 1067 ▯ ▯ ▯ 600 1022 ▯ ▯ ▯ ▯ 625 1112 ▯ ▯ ▯ ▯ 650 1202 ▯ ▯ ▯ 675 1247 ▯ ▯ ▯ 700 1292 ▯ ▯ ▯ ▯ 725 1337 ▯ ▯ ▯ ▯ 750 1382 ▯ ▯ ▯ ▯ 775 1427 ▯ ▯ ▯ ▯ 800 1472 ▯ ▯ ▯ ▯ ▯ 825 1517 ▯ ▯ ▯ ▯ ▯ 850 1562 ▯ ▯ °C ▯ ▯ ▯ ▯ 10 ▯ ▯ ▯ 9 ▯ 857-810 Temperature transducer for thermocouples of types J and K TC+ 1 5 OUT+ OUT TC– 2 6 GND 1 IN 7 Us+ POWER 8 GND 2 3 4 212 JUMPFLEX® Transducers ____________ Short description: The 857-810 Thermocouple Temperature Transducer is suitable for the connection of type J and K thermocouples. On the output side, the thermocouple temperature transducer converts the temperature signal into an analog standard signal. The following signals are available: 0 - 20mA, 4 - 20mA, 0 - 10V, 2 - 10V, 0 - 5V, 1 - 5V, 0 - 10mA and 2 - 10mA. The device has a 3-way isolation with a 2.5kV test voltage. It can be configured via DIP switches that are accessible from the side of the housing. Measurement range switching is calibrated. The device is supplied with 24VDC, which can be commoned using lateral push-in type jumper bars in a quick and cost effective way. Item No. Pack. Unit Technical Data Temperature transducer for thermocouples of types J and K 857-810 1 Configuration Input signal Output signal Accessories see pages 222 - 223 Load impedance Step response Voltage supply VN Supply voltage range Current input at 24 V DC Sensor types Temperature range Approvals Shipbuilding 4 r ANSI/ISA 12.12.01 Conformity marking g (pending) Class I, Div. 2, Grp. ABCD, T4 1 General Specifications Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 6 x 96 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP®S solid: 0.20 mm² ... 2.5 mm² / AWG 24 ... 12 fine-stranded: 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in 6 mm/0.23 in A green LED on the front panel indicates normal operation. The temperature transducer meets the requirements for safe isolation of input, output and supply circuits with 2.5kV test voltage according to EN 61140. Description General accessories _> _> 3 Cold junction compensation Cold junction error Transmission error Transmission error of set measuring span Temperature coefficient Min. measuring span Test voltage (input/output/supply) Ambient operating temperature Storage temperature DIP switch Thermocouples 0 ... 20 mA, 4 ... 20 mA, 0 ... 10 V, 2 ... 10 V, 0... 5 V, 1 ... 5 V, 0 ... 10 mA, 2 ... 10 mA  600 Ω (Out = mA)  2 kΩ (Out = V) 60 ms / 120 ms with cold junction compensation 24 V DC 16.8 V ... 31.2 V < 40 mA Thermocouples of types J and K Type J: -150 °C ... +1200 °C Type K: -150 °C ... +1350 °C on / off (default: on) 3 K (typ. 2 K )  0.1 % at max. measuring span (Typ J, K) (150 K / set measuring span [K]) % 0.04 % /K 100 K (configurable) 2.5 kV AC, 50 Hz, 1 min -25 °C ... +70 °C -40 °C ... +85 °C S 3 213 DIP Switch Adjustability 857-810 ▯ = ON DIP Switch S1 Cold junction compensation 2 3 4 on ▯ Output signal Sensor type 1 5 6 7 J off ▯ 0 … 20 mA K ▯ ▯ 4 … 20 mA ▯ 0 … 10 mA ▯ 2 … 10 mA ▯ 0 … 10 V ▯ 2 … 10 V ▯ ▯ 0…5V ▯ ▯ 1…5V ▯ ▯ Measuring range underflow 8 Measuring range overflow Lower limit of output range -5 % Upper limit of output range +2.5 % Upper limit of output range 5% Lower limit of output range Upper limit of output range +2.5 % Upper limit of output range 5% Lower limit of output range Upper limit of output range Upper limit of output range 5% Lower limit of output range Upper limit of output range ▯ ▯ ▯ ▯ Wire break Lower limit of output range According to Namur NE 43 DIP Switch S2 Start temperature 1 2 3 4 ▯ ▯ -200 -328 -175 -283 ▯ -150 -283 ▯ -125 -193 ▯ -100 -148 ▯ ▯ -90 -130 ▯ ▯ ▯ ▯ ▯ ▯ -80 -112 ▯ -70 -94 ▯ -60 -76 ▯ -50 -58 ▯ -40 -40 ▯ ▯ -30 -22 ▯ ▯ -20 -4 ▯ ▯ ▯ -10 14 ▯ ▯ ▯ 0 32 ▯ ▯ °F ▯ ▯ ▯ °C End temperature 5 6 7 8 9 10 ▯ ▯ 0 32 10 50 ▯ 20 68 ▯ 30 86 ▯ 40 104 ▯ ▯ 50 122 ▯ ▯ ▯ ▯ ▯ ▯ 60 140 ▯ 70 158 ▯ 80 176 ▯ 90 194 ▯ 100 212 ▯ ▯ 125 257 ▯ ▯ 150 302 ▯ ▯ ▯ 175 347 ▯ ▯ ▯ 200 392 ▯ ▯ °F ▯ ▯ ▯ °C 5 6 7 8 ▯ ▯ °F ▯ 225 437 250 482 ▯ 275 527 ▯ ▯ 300 572 ▯ ▯ 325 617 ▯ ▯ 350 662 ▯ ▯ ▯ 375 707 ▯ ▯ ▯ ▯ ▯ ▯ °C ▯ ▯ ▯ 10 ▯ ▯ ▯ 9 ▯ 400 752 ▯ ▯ 425 797 ▯ ▯ 450 842 ▯ ▯ 475 887 ▯ ▯ 500 932 ▯ ▯ ▯ 525 977 ▯ ▯ ▯ 550 1022 ▯ ▯ ▯ ▯ 575 1067 ▯ ▯ ▯ ▯ 600 1112 5 6 7 8 9 ▯ ▯ 650 1202 675 1247 ▯ ▯ 700 1292 ▯ ▯ 725 1337 ▯ ▯ 750 1382 ▯ ▯ ▯ 775 1427 ▯ ▯ ▯ ▯ ▯ 800 1472 ▯ ▯ 825 1517 ▯ ▯ 850 1562 ▯ ▯ 875 1607 ▯ ▯ 900 1652 ▯ ▯ ▯ 925 1697 ▯ ▯ ▯ 950 1742 ▯ ▯ ▯ ▯ 975 1787 ▯ ▯ ▯ ▯ 1000 1832 The minimum distance from the start temperature to the end temperature may not fall short of 100K degrees on the Celsius (C) scale or 212K degrees on the Fahrenheit (F) scale. Default settings In delivery status all DIP switches are in the position “OFF“. - Cold junction compensation “On“ - Termocouple of type J - Start temperature 0 °C - End temperature 1000 °C - 0 … 20 mA - Measuring range underflow 0 mA - Measuring range overflow 20.5 mA - Wire break 21 mA 1157 ▯ ▯ ▯ °F 625 ▯ ▯ ▯ °C ▯ ▯ ▯ ▯ 10 5 6 7 8 ▯ ▯ °F 1025 1877 ▯ 1050 1922 ▯ ▯ 1075 1967 ▯ ▯ ▯ 1100 2012 ▯ ▯ ▯ 1125 2057 ▯ ▯ ▯ 1150 2102 ▯ ▯ ▯ ▯ 1175 2147 ▯ ▯ ▯ ▯ ▯ ▯ °C ▯ ▯ ▯ ▯ 10 ▯ ▯ ▯ 9 ▯ ▯ ▯ 1200 2192 ▯ ▯ ▯ 1225 2237 ▯ ▯ ▯ 1250 2282 ▯ ▯ ▯ 1275 2327 2372 ▯ ▯ ▯ 1300 ▯ ▯ ▯ ▯ 1325 2417 ▯ ▯ ▯ ▯ 1350 2462 ▯ ▯ ▯ ▯ ▯ 1375 2507 ▯ ▯ ▯ ▯ ▯ 1400 2552 3 857-811 Temperature transducer for thermocouples of types J and K * TC+ 1 5 OUT+ OUT TC– 2 6 GND 1 IN 7 Us+ POWER 8 GND 2 3 4 214 JUMPFLEX® Transducers ____________ _> _> 3 6 mm/0.23 in A green LED on the front panel indicates normal operation. The temperature Short description: The 857-811 Thermocouple Temperature Transducer is suitable for the connec- transducer meets the requirements for safe isolation of input, output and supply tion of type J and K thermocouples. On the output side, the thermocouple tem- circuits with 2.5kV test voltage according to EN 61140. perature transducer converts the temperature signal into an analog standard signal. The following signals are available: 0 - 20mA, 4 - 20mA, 0 - 10V, 2 - 10V, 0 - 5V, 1 - 5V, 0 - 10mA and 2 - 10mA. The device has a 3-way isolation with a 2.5kV test voltage. It can be configured both via DIP switches that are accessible from the side of the housing and using a FDT/DTM software. The software offers additional setting options such as additional types of sensors at the input or inversion of the analog output. The device is supplied with 24VDC, which can be commoned using lateral push-in type jumper bars in a quick and cost effective way. Description Item No. Pack. Unit Technical Data Temperature transducer for thermocouples of types J and K * 857-811 1 Configuration Input signal Output signal Accessories Configuration software WAGO USB Service Cable General accessories - 759-370 FDT Frame Application - DTM (Device Tool Manager) Download: see www.wago.com 750-923 see pages 222 - 223 Load impedance g (pending) Class I, Div. 2, Grp. ABCD, T4 1 Cold junction compensation Cold junction error Transmission error Transmission error of set measuring span Approvals Shipbuilding 4 r ANSI/ISA 12.12.01 Conformity marking General Specifications Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 6 x 96 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP®S solid: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 fine-stranded: 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in Step response Voltage supply VN Supply voltage range Current input at 24 V DC Sensor types Temperature range Temperature coefficient Min. measuring span Test voltage (input/output/supply) Ambient operating temperature Storage temperature DIP switch or via software Thermocouples 0 ... 20 mA, 4 ... 20 mA, 0 ... 10 V, 2 ... 10 V, 0... 5 V, 1 ... 5 V, 0 ... 10 mA, 2 ... 10 mA  600 Ω (Out = mA)  2 kΩ (Out = V) 60 ms / 120 ms with cold junction compensation 24 V DC 16.8 V ... 31.2 V < 40 mA Thermocouples of types J and K * Type J: -150 °C ... +1200 °C Type K: -150 °C ... +1350 °C on / off (default: on) 3 K (typ. 2 K )  0.1 % at max. measuring span (Typ J, K) (150 K / set measuring span [K]) % 0.04 % /K 100 K (configurable) 2.5 kV AC, 50 Hz, 1 min -25 °C ... +70 °C -40 °C ... +85 °C ( * Setting of other types of sensors as well as output signal inversion using the configuration software) S 3 215 DIP Switch Adjustability 857-811 ▯ = ON DIP Switch S1 Cold junction compensation Sensor type 1 2 on ▯ Output signal 3 4 5 6 J off ▯ 7 8 0 … 20 mA K ▯ Measuring range underflow Measuring range overflow Wire break Lower limit of output range -5 % Upper limit of output range +2.5 % Upper limit of output range 5% Lower limit of output range Upper limit of output range +2.5 % Upper limit of output range 5% Lower limit of output range Upper limit of output range Upper limit of output range 5% Lower limit of output range Upper limit of output range 4 … 20 mA ▯ ▯ 0 … 10 mA ▯ 2 … 10 mA ▯ ▯ ▯ 0 … 10 V ▯ 2 … 10 V ▯ ▯ 0…5V ▯ ▯ 1…5V ▯ ▯ ▯ Lower limit of output range ▯ According to Namur NE 43 3 DIP Switch S2 Start temperature 1 2 3 4 ▯ ▯ -200 -328 -283 ▯ -150 -283 ▯ -125 -193 ▯ -100 -148 ▯ ▯ -90 -130 ▯ ▯ -80 -112 ▯ -70 -94 ▯ -60 -76 ▯ ▯ -50 -58 ▯ ▯ -40 -40 ▯ ▯ -30 -22 ▯ ▯ -20 -4 ▯ ▯ ▯ -10 14 ▯ ▯ ▯ 0 32 ▯ ▯ °F -175 ▯ ▯ °C ▯ ▯ ▯ End temperature 5 6 7 8 9 ▯ ▯ 0 32 50 ▯ 20 68 ▯ 30 86 ▯ 40 104 ▯ ▯ 50 122 ▯ ▯ 60 140 ▯ 70 158 ▯ 80 176 ▯ ▯ 90 194 ▯ ▯ 100 212 ▯ ▯ 125 257 ▯ ▯ 150 302 ▯ ▯ ▯ 175 347 ▯ ▯ ▯ 200 392 ▯ ▯ °F 10 ▯ ▯ °C ▯ ▯ ▯ 10 5 6 7 8 ▯ ▯ °F 225 437 250 482 ▯ 275 527 ▯ ▯ 300 572 ▯ ▯ 325 617 ▯ ▯ 350 662 ▯ ▯ ▯ 375 707 ▯ ▯ ▯ 400 752 ▯ ▯ 425 797 ▯ ▯ 450 842 ▯ ▯ ▯ 475 887 ▯ ▯ ▯ 500 932 ▯ ▯ ▯ 525 977 ▯ ▯ ▯ 550 1022 ▯ ▯ ▯ ▯ 575 1067 ▯ ▯ ▯ ▯ 600 1112 ▯ ▯ 10 ▯ ▯ ▯ 9 ▯ ▯ ▯ °C ▯ 5 6 7 8 ▯ ▯ In delivery status all DIP switches are in the position “OFF“. - Cold junction compensation “On“ - Termocouple of type J - Start temperature 0 °C - End temperature 1000 °C - 0 … 20 mA - Measuring range underflow 0 mA - Measuring range overflow 20.5 mA - Wire break 21 mA 1157 650 1202 675 1247 ▯ ▯ 700 1292 ▯ ▯ 725 1337 ▯ ▯ 750 1382 ▯ ▯ ▯ 775 1427 ▯ ▯ ▯ 800 1472 ▯ ▯ 825 1517 ▯ ▯ 850 1562 ▯ ▯ ▯ 875 1607 ▯ ▯ ▯ 900 1652 ▯ ▯ ▯ 925 1697 ▯ ▯ ▯ 950 1742 ▯ ▯ ▯ ▯ 975 1787 ▯ ▯ ▯ ▯ 1000 1832 The minimum distance from the start temperature to the end temperature may not fall short of 100K degrees on the Celsius (C) scale or 212K degrees on the Fahrenheit (F) scale. Default settings °F 625 ▯ ▯ ▯ °C ▯ ▯ ▯ ▯ 10 ▯ ▯ ▯ 9 5 6 7 8 ▯ ▯ °F 1025 1877 ▯ 1050 1922 ▯ ▯ 1075 1967 ▯ ▯ ▯ 1100 2012 ▯ ▯ ▯ 1125 2057 ▯ ▯ ▯ 1150 2102 ▯ ▯ ▯ ▯ 1175 2147 ▯ ▯ ▯ ▯ 1200 2192 ▯ ▯ ▯ 1225 2237 ▯ ▯ ▯ 1250 2282 ▯ ▯ ▯ ▯ 1275 2327 ▯ ▯ ▯ ▯ 1300 2372 ▯ ▯ ▯ ▯ 1325 2417 ▯ ▯ ▯ ▯ 1350 2462 ▯ ▯ ▯ ▯ ▯ 1375 2507 ▯ ▯ ▯ ▯ ▯ 1400 2552 ▯ ▯ °C ▯ ▯ ▯ ▯ 10 ▯ ▯ ▯ 9 ▯ 857-819 Millivolt transducer; Records all mV signals ranging from -100 mV to +100 mV; 0 mV ... 1000 mV. Application: Recording of lambda probes IN+ 1 IN– 2 N.C. 3 N.C. 4 IN mV OUT U,I 5 OUT+ 6 GND 1 7 Us+ POWER 8 GND 2 216 JUMPFLEX® Transducers ____________ _> _> 3 6 mm/0.23 in A green LED on the front panel indicates normal operation. The millivolt transShort description: The 857-819 Millivolt Transducer converts input millivolt signals into an analog ducer meets the requirements for safe isolation of input, output and supply circuits with 2.5kV test voltage according to EN 61140. standard signal on the output side. The following signals are available: 0 - 20mA, 4 - 20mA, 0 - 10V, 2 - 10V, 0 - 5V, 1 - 5V, 0 - 10mA and 2 - 10mA. The device has a 3-way isolation with a 2.5kV test voltage. The transducer can be configured either using FDT/DTM software or via DIP switches that are accessible from the side of the housing. The software offers additional setting options such as the ability to invert the output signal. The device is supplied with 24VDC, which can be commoned using lateral push-in type jumper bars in a quick and cost effective way. Description Item No. Pack. Unit Technical Data Millivolt transducer, with millivolt input as well as current and voltage output 857-819 1 Configuration Input signal Max. input signal Output signal Accessories Configuration software WAGO USB Service Cable General accessories - 759-370 FDT Frame Application - DTM (Device Tool Manager) Download: see www.wago.com 750-923 see pages 222 - 223 Approvals Shipbuilding 4 r ANSI/ISA 12.12.01 Conformity marking g (pending) Class I, Div. 2, Grp. ABCD, T4 1 General Specifications Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 6 x 96 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP®S solid: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 fine-stranded: 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in Load impedance Step response Voltage supply VN Supply voltage range Transmission error Temperature coefficient Min. measuring span Test voltage (input/output/supply) Ambient operating temperature Storage temperature DIP switch or configuration software -100 mV ... +100 mV, 0 mV ... 200 mV, 0 mV ... 300 mV, 0 mV ... 1000 mV (in 100 mV increments) 30 V 0 ... 20 mA, 4 ... 20 mA, 0 ... 10 V, 2 ... 10 V, 0... 5 V, 1 ... 5 V, 0 ... 10 mA, 2 ... 10 mA  600 Ω (I output)  2 kΩ (U output) 50 ms 24 V DC 16.8 V ... 31.2 V < 0.1 % of upper range value 0.01 %/K 10 mV (configurable) 2.5 kV AC, 50 Hz, 1 min -25 °C ... +70 °C -40 °C ... +85 °C S 3 217 DIP Switch Adjustability 857-819 ▯ = ON Start value DIP S1 1 2 3 4 5 6 7 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● mV 1 -100 -98 -96 -94 -92 -90 -88 -86 -84 -82 -80 -78 -76 -74 -72 -70 -68 -66 -64 -62 -60 -58 -56 -54 -52 -50 -48 -46 -44 -42 -40 -38 -36 ● 2 ● ● 3 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 6 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 5 ● ● ● ● ● ● 4 7 ● ● ● ● ● ● ● ● mV -34 -32 -30 -28 -26 -24 -22 -20 -18 -16 -14 -12 -10 -8 -6 -4 -2 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 1 2 ● ● ● ● 3 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 4 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 6 ● ● ● ● ● ● ● ● ● ● 5 7 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● mV 34 36 38 40 42 44 46 48 50 52 54 56 58 60 62 64 66 68 70 72 74 76 78 80 82 84 86 88 90 92 94 96 98 100 3 End value DIP S1 8 9 DIP S2 10 1 2 3 DIP S1 4 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● mV 8 -100 -98 -96 -94 -92 -90 -88 -86 -84 -82 -80 -78 -76 -74 -72 -70 -68 -66 -64 -62 -60 -58 -56 -54 -52 -50 -48 -46 -44 -42 -40 -38 -36 ● 9 ● ● ● ● ● ● DIP S2 10 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 2 ● ● ● ● ● ● 1 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 3 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● DIP S1 4 ● ● ● ● ● ● Measuring Range Underflow Measuring Range Overflow ● ● mV -34 -32 -30 -28 -26 -24 -22 -20 -18 -16 -14 -12 -10 -8 -6 -4 -2 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 8 9 ● ● ● ● DIP S2 10 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 1 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 3 ● ● ● ● ● ● ● ● ● ● 2 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● DIP S1 4 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● mV 34 36 38 40 42 44 46 48 50 52 54 56 58 60 62 64 66 68 70 72 74 76 78 80 82 84 86 88 90 92 94 96 98 100 8 ● ● 9 ● ● DIP S2 10 ● ● ● ● ● ● ● ● ● ● ● ● 1 ● ● ● ● ● ● ● 2 3 ● ● ● ● ● ● ● ● ● ● DIP Switch S2 Output Signal 6 7 8 9 10 0 … 20 mA ▯ ▯ 4 … 20 mA ▯ 0 … 10 mA ▯ 2 … 10 mA ▯ 0 … 10 V ▯ 2 … 10 V ▯ ▯ 0…5V ▯ ▯ 1…5V ▯ ▯ Default settings In delivery status all DIP switches are in the position “OFF“. Lower limit of output range -5 % Upper limit of output range +2.5 % Lower limit of output range Upper limit of output range +2.5 % Lower limit of output range Upper limit of output range Lower limit of output range Upper limit of output range ▯ - Measuring range 0 … 100 mV - Output range 0 … 20 mA ▯ ▯ ▯ According to Namur NE 43 - Measuring range overflow 20.5 mA - Measuring range underflow 0 mA 4 ● ● ● ● ● ● ● ● ● ● mV 100 200 300 400 500 600 700 800 900 1000 857-531 Threshold value switch with analog input and changeover relay output DO 1 DO 12 2 11 3 14 4 5 IN+ IN U,I 6 GND 1 7 Us+ POWER 8 GND 2 218 JUMPFLEX® Transducers ____________ _> _> 3 6 mm/0.23 in Short description: The threshold value switch for analog signals monitors analog standard signals and reports signals exceeding a preset threshold. It is equipped with an analog input and a changeover relay output. The device features a 24VDC nominal voltage supply. In addition, the device has a digital output (DO) to indicate other conditions, such as a range overflow or underflow. The threshold value switch can be configured via DIP switches and teach-in function via push-slider switch. Configuration via FDT/DTM software is also possible. Description Item No. Pack. Unit Technical Data Threshold value switch with analog input, changeover relay output and digital output 857-531 1 Configuration Input signal Max. input signal Input resistance Accessories Configuration software WAGO USB Service Cable General accessories - 759-370 FDT Frame Application - DTM (Device Tool Manager) Download: see www.wago.com 750-923 see pages 222 - 223 Output - Relay Contact type Max. switching voltage Max. continuous current (terminal Max. Switching power (resistive) Switching treshold Configurable rise and fall delay time g (pending) Class I, Div. 2, Grp. ABCD, T4 1 General Specifications Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 1 changeover contact 250 V AC max.6 A (to 60 °C), 3 A (60 to 70 °C) 1250 VA AC 1 bzw. 2 (adjustable) 10 s (via DIP switch), Approvals Shipbuilding 4 r ANSI/ISA 12.12.01 Conformity marking DIP switch, teach-in function, configuration software -10...+10 V, -20...+20 mA, 0...+30 V (31.2 V (UIN) 100 mA (IIN)  200 Ω (I input) > 100 kΩ (U input) 6 x 96 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP®S solid: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 fine-stranded: 0.34 mm² ... 2.5 mm² / AWG 22 ... 12 9 ... 10 mm / 0.37 in Output - Digital Max. switching voltage Max. continuous current Supply voltage range Test voltage (input/output/supply) Ambient operating temperature Storage temperature Supply voltage 500 mA (to 60 °C) 100 mA (60 to 70 °C) 16.8 V ... 31.2 V 2.5 kV AC, 50 Hz, 1 min -25 °C ... +70 °C -40 °C ... +85 °C S 3 219 DIP Switch Adjustability 857-531 ▯ = ON DIP S1 1 2 3 Input signal limits ± 0.25 V; ± 0.5 mA 4 5 Hysteresis ● 10 mV, 20 μA ±10 V ● ● ● 2 … 10 V ● 0…5V ● ● ● 5 mV; 10 μA 0 … 10 V 1…5V ● ±5V ● ● 0 … 15 V ● ● 0 … 30 V ● ± 20 mA ● ● ● 0 … 20 mA ● ● ● 4 … 20 mA ● ● 3 0 … 10 mA ● ● ● 2 … 10 mA ● ± 10 mA DIP S1 6 7 Configurable rise/ fall delay time in sec. 8 9 Measuring range overflow indication 0 ● DO Ub switched 1 ● ● ● ● DO GND switched DO not active ● active 2 ● ● 10 3 ● 4 ● 5 ● ● 8 ● ● 10 “Teach-In“ Switch Operation Press for 1 sec. Default settings Red LED flashes briefly Yellow LED flashes No flashing LED In delivery status all DIP switches are in the position “OFF“. - Input range: ± 10 V - Hysteresis: 5 mV - Configurable rise/fall delay time: 0 s SP2 SP1 SP2 SP1 SP1 SP2 SP1 SP2 SP1 SP1 Param. mode SP1 Param. mode SP1 SP2 Leave param. mode Param. mode SP1 SP2 Leave param. mode Param. mode SP1 Param. mode SP1 Leave param. mode Param. mode SP1 Leave param. mode Param. mode Leave param. mode Leave param. mode wihout storing a value SP2 SP2 Leave param. mode Leave param. mode - DO: not active 759-370 3 220 WAGOframe FDT frame application for parameterization, commissioning and diagnostics of devices with DTM device driver WAGOframe: Parameterizing a JUMPLEX® transducer WAGOframe: Wizard function WAGOframe is an FDT/DTM-based software used for parameterization, commissioning and diagnostics of field devices. DTM device drivers for the devices employed are required to use the WAGOframe FDT frame application. The WAGOframe FDT frame application provides a wizard, which simplifies the operation of components, such as WAGO JUMPFLEX® DTMs. For example, this wizard guides the user through the different operating modes of DTM device drivers. Depending on the PC communication interface used, an appropriate communication cable including DTM is required. Description Item No. Pack. Unit Technical Data WAGOframe 759-370 1 System requirements: PC Operating system RAM memory Hard disk storage CD-ROM Graphics resolution Mouse Other Accessories 857 Series JUMPFLEX® WAGO USB service cable 767 Series SPEEDWAY configuration USB communication cable Item No. Pack. Unit 750-923 1 756-4101/042-030 1 Included: Additional requirements: Pentium 1 GHz or higher Microsoft® Windows® 2000; Microsoft® Windows® XP Professional; Microsoft® Windows® Vista® min. 512 Mbytes (Windows® 2000 + XP); min. 1024 Mbytes (Windows® Vista®) min. 50 Mbytes required XGA or higher required Free interface in PC for communication with the device (e.g., USB, Serial, ETHERNET, ...) CD ROM with software and documentation Cable between PC communication interface and device. DTM software for the communication interface used in the PC. DTM software of the device. Cable between PC communication Windows® is a registered trademark of Microsoft Corporation 750-923 3 WAGO USB Service Cable 221 3 The WAGO USB Service Cable connects a PC (notebook) to either the service Interface of the 857 Series Signal Conditioners and Relay Modules (JUMPFLEX®) or to WAGO-I/O-SYSTEM buscouplers/controllers. Notice: Using the WAGO 759-923 USB Service Cable in combination with some of the programmable fieldbus controllers requires a certain firmware version or higher: 750-841 as from firmware version 12 750-872/0020-0000 as from firmware version 2 Description Item No. Pack. Unit Technical Data WAGO USB service cable 750-923 1 USB specification Operating system Operating temperature Interface USB Length Connector dimensions (WxHxD) Test voltage Conformity marking EMC 1-Immunity to interference EMC 1-Emission of interference 2.0 compatible/full-speed device Windows 98/2000/XP/VISTA -25 °C ... +70 °C type A/m 2.5 m 15 x 50 x 19 mm 2.5 kV, 50 Hz, 1 min. 1 acc. to EN 61000-4-3, EN 61000-4-6 acc. to EN 55022 3 JUMPFLEX® 8-Channel Adapter for System Wiring 222 8-channel adapter with 16-pin ribbon cable connector Analog Interface 15 13 11 9 7 5 3 1 16 14 12 10 8 6 4 2 FLK 16 Description Item No. Pack. unit JUMPFLEX® 8-channel adapter for system wiring 857-980 1 Technical Data Connection type, signal level Performance level Contact resistance Current carrying capacity Test voltage Overvoltage category Degree of pollution Accessories 16-pin ribbon cable connector acc. to DIN 41651 3  20 mΩ 1A 500 V / 50 Hz / 1 min. III 2 WAGO ribbon cable on request 3 Accessories, 857 Series 223 Push-in type jumper bar Commoning Description Push-in type jumper bars, light gray, insulated, 18 A Item no. suffix for colored push-in type jumper bars WMB Multi marking system Item No. Pack. Unit 859-402 859-403 859-404 859-405 859-406 859-407 859-408 859-409 859-410 ... /000-029 ... /000-005 ... /000-006 200 (8x25) 200 (8x25) 200 (8x25) 200 (8x25) 100 (4x25) 100 (4x25) 100 (4x25) 100 (4x25) 100 (4x25) Item No. Pack. Unit plain 793-501 5 cards 1 ... 10 (10x) 11 ... 20 (10x) 21 ... 30 (10x) 31 ... 40 (10x) 41 ... 50 (10x) 1 ... 50 (2x) 793-502 793-503 793-504 793-505 793-506 793-566 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 2-way 3-way 4-way 5-way 6-way 7-way 8-way 9-way 10-way yellow red blue Marking Description WMB Multi marking system Marking software and printer/plotter see Section 8 Marking 10 strips with 10 markers, white with black printing Operating tool Wire connection Description Operating tool, with partially insulated shaft WAGO USB service cable Type 2, blade (3.5 x 0.5) mm WAGO USB service cable Configuration Item No. Pack. Unit 210-720 750-923 1 1 3 3 Pluggable Modules - Temperature Transducers 224 Input: Pt100 type RTD element 3-wire, with error output for broken wire and short circuit of sensor Module width 20 mm / 0.787 in Module width 20 mm / 0.787 in 82,5 mm / 3,25 in Input: Pt100 type RTD element 2-wire, with error output for broken wire and short circuit of sensor 50 mm / 1.97 in u 73 mm / 2.87 in v Other temperature ranges contact factory. LED indication of broken wire or short circuit WSB marker card • Marking 1 ... 10; Item No.: 209-702 • Marking 1, 2, 3, 0V, +UB, OUT, ERR., 0V; Item No.: 249-622 • Marking 1, 2, 0V, +UB, OUT, ERR., 0V; Item No.: 249-623 5 cards, each containing 10 strips with 10 markers U, I +UB OUT ERROR 0V U, I +UB OUT ERROR 0V Description Output Item No. Pack. Unit Output Item No. Pack. Unit Temperature transducer 0 - 10 V 0 - 20 mA 4 - 20 mA 286-860 286-861 286-862 1 1 1 0 - 10 V 0 - 20 mA 4 - 20 mA 286-870 286-871 286-872 1 1 1 Technical Data Temperature range Operating voltage Nominal current Load impedance Error output - low upon error (fail safe) Transmission error (measuring range) Temperature coefficient Ambient operating temperature Electromagnetic compatibility test acc. to IEC 801-2/4/5 Accessories see page 233 Accessories see page 233 0 °C ... 100 °C 24 V DC (± 10 %) IBN 30 mA  2 kΩ (Out = V)  500 Ω (Out = mA) VB / max. 20 mA  0.3 % 0.02 %/K 0 °C ... +55 °C B acc. to EN 50082 T2 (E3.94) 0 °C ... 100 °C 24 V DC (± 10 %) IBN 30 mA  2 kΩ (Out = V)  500 Ω (Out = mA) VB / max. 20 mA  0.3 % 0.02 %/K 0 °C ... +55 °C B acc. to EN 50082 T2 (E3.94) Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 3 225 Input: Thermocouple K (NiCr-Ni) with error output for broken wire Module width 20 mm / 0.787 in Module width 20 mm / 0.787 in 82,5 mm / 3,25 in Input: Thermocouple J (Fe-CuNi) with error output for broken wire 50 mm / 1.97 in u 73 mm / 2.87 in v 3 Other temperature ranges contact factory. LED indication of broken wire or short circuit WSB marker card • Marking 1 ... 10; Item No.: 209-702 • Marking 1, 2, 3, 0V, +UB, OUT, ERR., 0V; Item No.: 249-622 • Marking 1, 2, 0V, +UB, OUT, ERR., 0V; Item No.: 249-623 5 cards, each containing 10 strips with 10 markers U, I +UB OUT ERROR 0V U, I +UB OUT ERROR 0V Description Output Item No. Pack. Unit Output Item No. Pack. Unit Temperature transducer 0 - 10 V 0 - 20 mA 4 - 20 mA 286-863 286-865 286-867 1 1 1 0 - 10 V 0 - 20 mA 4 - 20 mA 286-864 286-866 286-868 1 1 1 Technical Data Temperature range Operating voltage Nominal current Load impedance Error output - low upon error (fail safe) Transmission error (measuring range) Temperature coefficient Ambient operating temperature Electromagnetic compatibility test acc. to IEC 801-2/4/5 Accessories see page 233 Accessories see page 233 0 °C ... 750 °C 24 V DC (± 10 %) IBN  30 mA (Out = V) IBN  50 mA (Out = mA)  2 kΩ (Out = V)  500 Ω (Out = mA) VB / max. 20 mA 2% 0.02 %/K 0 °C ... +55 °C B acc. to EN 50082 T2 (E3.94) 0 °C ... 1000 °C 24 V DC (± 10 %) IBN  30 mA (Out = V) IBN  50 mA (Out = mA)  2 kΩ (Out = V)  500 Ω (Out = mA) VB / max. 20 mA 2% 0.02 %/K 0 °C ... +55 °C B acc. to EN 50082 T2 (E3.94) Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 3 Pluggable Modules - Temperature Transducers 226 Input: Pt100 type RTD element 3-wire, with error output for broken wire and short circuit of sensor -30 °C ... +150 °C Module width 20 mm / 0.787 in Module width 20 mm / 0.787 in 82,5 mm / 3,25 in Input: Pt100 type RTD element 2-wire, with error output for broken wire and short circuit of sensor -30 °C ... +150 °C 50 mm / 1.97 in u 73 mm / 2.87 in v Linear temperature curve Other temperature ranges contact factory. LED indication of broken wire or short circuit WSB marker card • Marking 1 ... 10; Item No.: 209-702 • Marking 1, 2, 3, 0V, +UB, OUT, ERR., 0V; Item No.: 249-622 • Marking 1, 2, 0V, +UB, OUT, ERR., 0V; Item No.: 249-623 5 cards, each containing 10 strips with 10 markers +24V OUT ERROR 0V +24V OUT ERROR 0V Description Output Item No. Pack. Unit Output Item No. Pack. Unit Temperature transducer 0 ... 10 V 0 ... 20 mA 4 ... 20 mA 286-860/150-030 286-861/150-030 286-862/150-030 1 1 1 0 ... 10 V 0 ... 20 mA 4 ... 20 mA 286-870/150-030 286-871/150-030 286-872/150-030 1 1 1 Technical Data Temperature range Operating voltage Nominal current Load impedance Error output (closed-current principle) Transmission error (full scale) Temperature coefficient Ambient operating temperature Electromagnetic compatibility test acc. to IEC 801-2/4/5 Accessories see page 233 Accessories see page 233 -30 °C ... 150 °C 24 V DC (± 10 %) IN 30 mA  2 kΩ (Out = V)  500 Ω (Out = mA) VB / 20 mA  0.2 %  0.02 %/K 0 °C ... +55 °C B acc. to EN 50082 T2 (E3.94) -30 °C ... 150 °C 24 V DC (± 10 %) IN 30 mA  2 kΩ (Out = V)  500 Ω (Out = mA) VB / 20 mA  0.2 %  0.02 %/K 0 °C ... +55 °C B acc. to EN 50082 T2 (E3.94) Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 3 227 Input: Pt100 type RTD element 3-wire, with error output for broken wire and short circuit of sensor 0 °C ... +300 °C Module width 20 mm / 0.787 in Module width 20 mm / 0.787 in 82,5 mm / 3,25 in Input: Pt100 type RTD element 2-wire, with error output for broken wire and short circuit of sensor 0 °C ... +300 °C 50 mm / 1.97 in u 73 mm / 2.87 in v 3 Linear temperature curve Other temperature ranges contact factory. LED indication of broken wire or short circuit WSB marker card • Marking 1 ... 10; Item No.: 209-702 • Marking 1, 2, 3, 0V, +UB, OUT, ERR., 0V; Item No.: 249-622 • Marking 1, 2, 0V, +UB, OUT, ERR., 0V; Item No.: 249-623 +24V OUT ERROR 0V +24V OUT ERROR 0V Description Output Item No. Pack. Unit Output Item No. Pack. Unit Temperature transducer 0 ... 10 V 0 ... 20 mA 4 ... 20 mA 286-860/000-300 286-861/000-300 286-862/000-300 1 1 1 0 ... 10 V 0 ... 20 mA 4 ... 20 mA 286-870/000-300 286-871/000-300 286-872/000-300 1 1 1 Technical Data Temperature range Operating voltage Nominal current Load impedance Error output (closed-current principle) Transmission error (full scale) Temperature coefficient Ambient operating temperature Electromagnetic compatibility test acc. to IEC 801-2/4/5 Accessories see page 233 Accessories see page 233 0 °C ... 300 °C 24 V DC (± 10 %) IN 30 mA  2 kΩ (Out = V)  500 Ω (Out = mA) VB / 20 mA  0.2 %  0.02 %/K 0 °C ... +55 °C B acc. to EN 50082 T2 (E3.94) 0 °C ... 300 °C 24 V DC (± 10 %) IN 30 mA  2 kΩ (Out = V)  500 Ω (Out = mA) VB / 20 mA  0.2 % 0.02 %/K 0 °C ... +55 °C B acc. to EN 50082 T2 (E3.94) Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 3 Pluggable Modules - Temperature Transducers 228 Input: Pt1000 type RTD element 2-wire, with error output for broken wire and short circuit of sensor 0 °C ... +100 °C 82,5 mm / 3,25 in Module width 20 mm / 0.787 in 50 mm / 1.97 in u 73 mm / 2.87 in v Linear temperature curve Other temperature ranges contact factory. LED indication of broken wire or short circuit WSB marker card • Marking 1 ... 10; Item No.: 209-702 • Marking 1, 2, 0V, +UB, OUT, ERR., 0V; Item No.: 249-623 5 cards, each containing 10 strips with 10 markers +24V OUT ERROR 0V Description Output Item No. Pack. Unit Temperature transducer 0 ... 10 V 0 ... 20 mA 4 ... 20 mA 286-873 286-874 286-875 1 1 1 Technical Data Temperature range Operating voltage Nominal current Load impedance Error output (closed-current principle) Transmission error (full scale) Temperature coefficient Ambient operating temperature Electromagnetic compatibility test acc. to IEC 801-2/4/5 Accessories see page 233 0 °C ... 100 °C 24 V DC (± 10 %) IN 30 mA  2 kΩ (Out = V)  500 Ω (Out = mA) VB / 20 mA  0.3 % 0.02 %/K 0 °C ... +55 °C B acc. to EN 50082 T2 (E3.94) Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in Item No. Pack. Unit 280-628 1 3 229 3 3 Pluggable Modules - Analog Signal Conditioning 230 Electrically isolated supply of input/output via DC/DC converter Isolation voltage input/ output/supply voltage 4 kV Input signal 0 V ... 10 V Module width 20 mm/ 0.787 in Module width 20 mm/ 0.787 in 112 mm / 4.41 in Separate supply voltage for input/output Isolation voltage input/output 4 kV Input signal 0 V ... 10 V 85 mm / 3.35 in u +24V WSB marker card • Marking V; Item No.: 209-784 • Marking 1 ... 10; Item No.: 209-702 • Marking +/-; Item No.: 209-652 5 cards, each containing 10 strips with 10 markers IN+ IN0V 7 3 +24V 1 IN+ 1 U 2 U/I 5 6 4 8 IN- OUT+ NC OUT0V 5 U 2 +24V U/I 6 3 7 4 8 OUT+ OUTNC 0V Description Output signal Item No. Pack. Unit Output signal Item No. Pack. Unit Analog signal conditioning modules, for signal transformation, amplification and transmission with electrical isolation of input and output of standard signals. 0 - 10 V 0 - 20 mA 4 - 20 mA 786-301 786-302 786-303 1 1 1 0 - 10 V 0 - 20 mA 4 - 20 mA 786-321 786-322 786-323 1 1 1 Technical Data Input signal Max. input voltage Input resistance Load impedance Line break detection Transmission error (full scale) Error of transmission typ. Temperature coefficient (full scale) Critical frequency (sinus) Isolation voltage input / output Supply voltage RR  6 % input/output Power consumption input Power consumption output Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Storage temperature Approvals Accessories see page 233 Accessories see page 233 0 V ... 10 V 13 V 100 kΩ  2 kΩ (Out = V);  750 Ω (Out = mA) Measuring output (LED green = off)  0.15 %  0.1 %  0.02 %/K 1 kHz 4 kV, 50 Hz, 1 min 20 V ... 30 V DC 8 mA ... 20 mA 15 mA ... 40 mA 250 V / 4 kV / 3 0 V ... 10 V 13 V 100 kΩ  2 kΩ (Out = V);  750 Ω (Out = mA) Measuring output (LED green = off)  0.15 %  0.1 %  0.02 %/K 1 kHz 4 kV, 50 Hz, 1 min 20 V ... 28 V DC 60 mA 60 mA 250 V / 4 kV / 3 0 °C ... + 55 °C -40 °C ... +80 °C EMC testing IEC 60801-2/4/5, Grade B met acc. to EN 50 082 Part 2 (suppl. 3.94) 0 °C ... + 55 °C -40 °C ... +80 °C EMC testing IEC 60801-2/4/5, Grade B met acc. to EN 50 082 Part 2 (suppl. 3.94) Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 3 231 Separate supply voltage for input/output Isolation voltage input/output 4 kV Input signal 4 mA ... 20 mA Module width 20 mm/ 0.787 in Module width 20 mm/ 0.787 in 112 mm / 4.41 in Separate supply voltage for input/output Isolation voltage input/output 4 kV Input signal 0 mA ... 20 mA 3 85 mm / 3.35 in u +24V WSB marker card • Marking V; Item No.: 209-784 • Marking 1 ... 10; Item No.: 209-702 • Marking +/-; Item No.: 209-652 5 cards, each containing 10 strips with 10 markers IN+ IN0V 7 3 +24V 1 IN+ I 2 U/I 5 6 4 8 OUT+ IN- 0V Description Output signal Item No. Analog signal conditioning modules, for signal transformation, amplification and transmission with electrical isolation of input and output of standard signals. 0 - 10 V 0 - 20 mA 4 - 20 mA 786-304 786-305 786-306 1 1 1 Input signal Max. input current Input resistance Max. voltage drop at input Load impedance Line break detection Transmission error (full scale) Error of transmission typ. Temperature coefficient (full scale) Critical frequency (sinus) Isolation voltage input / output Supply voltage RR  6 % input/output Power consumption input Power consumption output Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Storage temperature IN- +24V 2 I 3 U/I 5 6 8 4 OUT+ OUT0V Output signal Item No. Pack. Unit 0 - 10 V 0 - 20 mA 4 - 20 mA 786-307 786-308 786-309 1 1 1 Accessories see page 233 Accessories see page 233 0 mA ... 20 mA 22 mA  50 Ω  0.15 %  0.1 %  0.02 %/K 1 kHz 4 kV, 50 Hz, 1 min 20 V ... 30 V DC 7 mA ... 18 mA 9 ... 16 mA; 13 ... 35 mA; 22 ... 40 mA 250 V / 4 kV / 3 4 mA ... 20 mA 22 mA  400 Ω 8V  2 kΩ (Out = V);  750 Ω (Out = mA) Measuring input (LED green = off) and Measuring output (LED green = off) (786-309)  0.15 %  0.1 %  0.02 %/K 1 kHz 4 kV, 50 Hz, 1 min 20 V ... 30 V DC 7 mA ... 18 mA 25 mA; 50 mA; 50 mA 250 V / 4 kV / 3 0 °C ... + 55 °C -40 °C ... +80 °C 0 °C ... + 55 °C -40 °C ... +80 °C  2 kΩ (Out = V);  750 Ω (Out = mA) Measuring output (LED green = off) Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 7 1 OUT- Pack. Unit Technical Data IN+ 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 3 Pluggable Modules - Analog Signal Conditioning 232 Electrically isolated supply of input/output via DC/DC converter Isolation voltage input/output/supply voltage 4 kV Input signal 0 mA ... 20 mA Module width 20 mm/ 0.787 in 112 mm / 4.41 in Electrically isolated supply of input/output via DC/DC converter Isolation voltage input/output/supply voltage 4 kV Input signal 0 mA ... 20 mA Module width 20 mm/ 0.787 in 85 mm / 3.35 in u 1 IN+ WSB marker card • Marking V; Item No.: 209-784 • Marking 1 ... 10; Item No.: 209-702 • Marking +/-; Item No.: 209-652 5 cards, each containing 10 strips with 10 markers 5 I 2 INNC +24V U/I 6 3 7 4 8 IN+ OUT+ OUT- IN- NC NC +24V 0V 1 5 I 2 U/I 6 3 7 4 8 OUT+ OUTNC 0V Description Output signal Item No. Pack. Unit Output signal Item No. Pack. Unit Analog signal conditioning modules, for signal transformation, amplification and transmission with electrical isolation of input and output of standard signals. 0 - 10 V 0 - 20 mA 4 - 20 mA 786-324 786-325 786-326 1 1 1 0 - 10 V 0 - 20 mA 4 - 20 mA 786-337 786-338 786-339 1 1 1 Technical Data Input signal Max. input current Input resistance Max. voltage drop at input Load impedance Line break detection Transmission error (full scale) Error of transmission typ. Temperature coefficient (full scale) Critical frequency (sinus) Isolation voltage input / output Supply voltage RR  6 % input/output Power consumption input Power consumption output Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Storage temperature Accessories see page 233 Accessories see page 233 0 mA ... 20 mA 22 mA  50 Ω  0.15 %  0.1 %  0.02 %/K 1 kHz 4 kV, 50 Hz, 1 min 20 V ... 28 V DC 70 mA; 90 mA; 95 mA 70 mA; 90 mA; 95 mA 250 V / 4 kV / 3 4 mA ... 20 mA 22 mA  400 Ω 8V  2 kΩ (Out = V);  750 Ω (Out = mA) Measuring input (LED green = off) and Measuring output (LED green = off) (786-339)  0.15 %  0.1 %  0.02 %/K 1 kHz 4 kV, 50 Hz, 1 min 20 V ... 28 V DC 35 mA; 60 mA; 60 mA 35 mA; 60 mA; 60 mA 250 V / 4 kV / 3 0 °C ... + 55 °C -40 °C ... +80 °C 0 °C ... + 55 °C -40 °C ... +80 °C  2 kΩ (Out = V);  750 Ω (Out = mA) Measuring input (LED green = off) Accessories Terminal block for pluggable modules, with 2-conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator ➋ with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 3 WSB Marker Cards 233 Miniature quick marking card Description Marking: K 1 ... 10 (10 x) A1, A2, 13, 14 A1, A2, 11, 12 11, 12, 14, A1, A2, A2, 11, 12, 14 12, A1, A2, 24, 11, 14, 21, 22 A1, A1, A2, A2, 11, 12, 13, 14, 23, 24 12, A1, A2, 23, 24, 11, 13, 14, 21, 22 12, A1, A2, 23, 24, 11, 13, 14, 33, 34 14, A1, A2, 33, 34, 13, 23, 24, 43, 44 A1, A2, 32, 31, 34, 42, 41, 12, 11, 14, 22, 21, 24, 44 L+, 1, L-, L-, 11, 12, 13, 14 A1, A2, A3, 11, 12, 14 A1, A1, A2, A2, 12, 11, 11, 14 A1, A1, St, A2, A2, 12, 11, 11, 14 U1, U2, U3, U4, 0V, 12, 11, 11, 14, 14 U A1, A2, A2, 1, 3, 2 A1, A2, A2, 1, 2, 2 A1+, A1+, A2-, A2-, 1, RL1, RL2, 2 A1+, A1+, A2-, A2-, 1+, 1+, A, 2+/1, 2, 3, 0V, +UB, OUT, ERR., 0V 1, 2, 0V, +UB, OUT, ERR., 0V Lin, Lin, Lout, Lout, 24V, UA, UA, 0V Lin, Lin, Lout, 11, 14, 14, Lin, Lin, Lout Iin, Iin, Iout, Iout, 24V, 11, 12, 14, 0V S V F1 ... F10 D +, -, 1, 2, 3, 13, 14, 4, 5, 6 L, N, Quitt, Störung, Test, N, 14, 24 A1, A2, Quitt, Störung, 12, 11, 11, 14 Item No. Pack. Unit 209-782 209-702 209-952 209-953 209-994 209-995 209-693 209-691 209-690 209-692 249-656 209-954 249-607 209-996 209-601 209-951 209-789 209-685 209-686 209-955 249-651 209-552 249-622 249-623 209-957 249-654 209-997 209-682 209-784 209-787 209-783 249-608 249-606 249-653 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards Item No. Pack. Unit 209-701 209-701/000-002 209-701/000-005 209-701/000-006 209-701/000-007 209-701/000-012 209-701/000-017 209-701/000-023 209-701/000-024 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards, each containing 10 strips with 10 markers Colored marker cards Description Marker cards and tags WSB 4 mm/0.157 in (plain) Marking software and printer/plotter see Section 8 5 cards, each containing 10 strips with 10 markers white yellow red blue gray orange light green green violet 3 4 234 WAGO Application: Steag, Power Plant in Voerde, Germany WAGO Products: WAGO-I/O-SYSTEM with MODBUS Couplers 4 Power Supplies 235 4 787 Series EPSITRON – PRO – Power Supplies 236 – 239 787 Series EPSITRON – CLASSIC – Power Supplies 240 – 245 787 Series EPSITRON – ECO – Power Supplies 246 – 247 787 Series EPSITRON – Electronic Circuit Breakers 248 – 249 787 Series EPSITRON – UPS Charger and Controller EPSITRON – Lead Gel Battery Modules 250 251 – 252 288, 787 Series EPSITRON – Capacitive Buffer Modules EPSITRON – Back-up Capacitor Module 253 254 787 Series EPSITRON – Redundancy Module EPSITRON – Communication Cable 255 256 288, 289 Series Rail-Mounted Modules – Constant Voltage Sources Rail-Mounted Modules – Power Supplies 258 – 259 260 – 263 859, 289, 288 Series Rail-Mounted Terminal Blocks with DC/DC Converters Rail-Mounted Modules – DC/DC Converter 264 – 265 266 4 4 236 Primary Switch Mode Power Supplies EPSITRON - PRO - Power Output voltage 24 V DC; 5 A, open circuit and short-circuit protected, adjustable output voltage, LED status indication, PowerBoost Output voltage 24 V DC; 10 A, open circuit and short-circuit protected, adjustable output voltage, LED status indication, PowerBoost • Primary switch mode power supply with PowerBoost and TopBoost • Stand-by input for switching off the output and minimizing power consumption • Parallel operation, series connection possible • Prepared for class I equipment • Natural convection cooling when horizontally mounted • Enclosed for use in switchgear cabinets L N L DC+ DC+ DC DC - N DC+ DC+ DC DC - Description Vo nom Item No. Pack. unit Vo nom Item No. Pack. unit Primary switch mode power supplies, for DIN 35 rail 24 V DC, SELV 787-822 1 24 V DC, SELV 787-832 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Input current Ii Inrush current Mains failure hold-up time Internal/external fuse Nominal output voltage Vo nom Output voltage range Output current Io PowerBoost TopBoost Residual ripple Derating Adjustment accuracy Current limitation Efficiency Test voltage pri.-gr./pri.-sec./sec.-gr. Degree of protection Operational indication Power loss PV Signaling Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 100 V ... 240 V AC 85 V ... 264 V AC (120 V ... 373 V DC) 44 Hz ... 66 Hz 0.97 A at 230 V AC and 5 A DC < 15 A 35 ms typ. at 230 V AC 4 AT 24 V DC, SELV 22 V... 29.5 V DC adjustable 5 A at 24 V DC 10 A DC (for 4 sec.); 7.5 A DC (for another 2 sec.) 23 A DC (for 25 ms) < 70 mVpp -2.5 % / K ( > 55 °C) 1% 1.1 x Io typ. 87.8 % typ. - / 4.2 kV / IP20 LED green (Vo), LED red (error) 0.5 W (stand-by) / 5.0 W (no load) / 14.6 W (rated load) Relay contact DC O.K. (changeover contact) DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +70 °C -25 °C ... +85 °C 57 x 163 x 163 Height from upper-edge of DIN 35 rail Input/Output: WAGO 231 Series / WAGO 231 Series Signalising: WAGO 733 Series Input: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Output: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Signalising: 0.08 mm² ... 0.5 mm² / AWG 28 ... 20 Input: 8 ... 9 mm / 0.33 in Output: 8 ... 9 mm / 0.33 in Signalising: 5 ... 6 mm / 0.22 in 1100 g EN 60950, EN 61204-3, UL 60950*, UL 508*, EN 61000-6-2, EN 61000-6-3 (* pending) 100 V ... 240 V AC 85 V ... 264 V AC (120 V ... 373 V DC) 44 Hz ... 66 Hz 1.2 A at 230 V AC and 10 A DC  Ie (active inrush current limitation) 24 ms typ. at 230 V AC 6.3 AT 24 V DC, SELV 22 V... 29.5 V DC adjustable 10 A at 24 V DC 20 A DC (for 4 sec.); 15 A DC (for another 2 sec.) 60 A DC (for 25 ms) < 70 mVpp -2.5 % / K ( > 55 °C) 1% 1.1 x Io typ. 91.8 % typ. - / 4.2 kV / IP20 LED green (Vo), LED red (error) 0.8 W (stand-by) / 3.5 W (no load) / 19.7 W (rated load) Relay contact DC O.K. (changeover contact) DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +70 °C -25 °C ... +85 °C 57 x 163 x 179 Height from upper-edge of DIN 35 rail Input/Output: WAGO 231 Series / WAGO 231 Series Signalising: WAGO 733 Series Input: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Output: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Signalising: 0.08 mm² ... 0.5 mm² / AWG 28 ... 20 Input: 8 ... 9 mm / 0.33 in Output: 8 ... 9 mm / 0.33 in Signalising: 5 ... 6 mm / 0.22 in 1300 g EN 60950, EN 61204-3, UL 60950*, UL 508*, EN 61000-6-2, EN 61000-6-3 (* pending) 4 237 Output voltage 24 V DC; 10 A open circuit and short-circuit protected, adjustable output voltage, LED status indication; PowerBoost Output voltage 24 V DC; 10 A open circuit and short-circuit protected, adjustable output voltage, LED status indication; PowerBoost; LineMonitor • Primary switch mode power supply with PowerBoost and TopBoost • Line monitor for parameter setting and monitoring • prepared for class I equipment • natural convection cooling when horizontally mounted • encapsulated, for use in switchgear cabinets L1 L2 L3 L1 DC+ DC+ DC DC - L2 L3 DC+ DC+ DC DC - 4 Description Vo nom Item No. Pack. unit Vo nom Item No. Pack. unit Primary switch mode power supplies, for DIN 35 rail 24 V DC, SELV 787-840 1 24 V DC, SELV 787-850 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Input current Ii Inrush current Mains failure hold-up time Internal/external fuse Nominal output voltage Vo nom Output voltage range Output current Io PowerBoost TopBoost Residual ripple Derating Adjustment accuracy Current limitation Efficiency Test voltage pri.-gr./pri.-sec./sec.-gr. Degree of protection Operational indication Signaling LineMonitor, parameter setting Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 3x (2x) 400 V ... 500 V AC 340 V ... 550 V AC / 480 V ... 780 V DC 50 Hz ... 60 Hz 3 x 0.6 A at 340 V AC and 10 A DC < 30 A 22 ms typ. at 3 x 400 V AC 3 x 1.6 AT / 24 V DC, SELV 22.8 V ... 28.8 V DC adjustable 10 A at 24 V DC 20 A DC (for 4 s); 15 A DC (for 8 s) 70 A DC (for 50 ms) < 70 mVpp -3 % / K ( > 50 °C) 1% 1.1 x Io typ. 91.7 % typ. - / 4.2 kV / IP20 LED green (Vo), LED red (error) DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +70°C -25 °C ... +85 °C 57 x 163 x 179 Height from upper-edge of DIN 35 rail Input/Output: WAGO 231 Series / WAGO 231 Series Input: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Output: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Input: 8 ... 9 mm / 0.33 in Output: 8 ... 9 mm / 0.33 in 1000 g EN 60950, EN 61204-3, UL 60950, UL 508, EN 61000-6-2, EN 61000-6-3 3x (2x) 400 V ... 500 V AC 340 V ... 550 V AC / 480 V ... 780 V DC 50 Hz ... 60 Hz 3 x 0.6 A at 340 V AC and 10 A DC < 30 A 22 ms typ. at 3 x 400 V AC 3 x 1.6 AT / 24 V DC, SELV 22.8 V ... 28.8 V DC adjustable 10 A at 24 V DC 20 A DC (for 4 s); 15 A DC (for 8 s) 70 A DC (for 50 ms) < 70 mVpp -3 % / K ( > 50 °C) 1% 1.1 x Io typ. 91.7 % typ. - / 4.2 kV / IP20 LED green (Vo), LED yellow (warning), LED red (error) LED, LCD, 4 x signal output 24 V DC, 25 mA via LCD and RS-232 serial interface DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +70°C -25 °C ... +85 °C 57 x 163 x 179 Height from upper-edge of DIN 35 rail Input/Output: WAGO 231 Series / WAGO 231 Series Signalising: WAGO 733 Series Input: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Output: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Signalising: 0.08 mm² ... 0.5 mm² / AWG 28 ... 20 Input: 8 ... 9 mm / 0.33 in Output: 8 ... 9 mm / 0.33 in Signalising: 5 ... 6 mm / 0.22 in 1000 g EN 60950, EN 61204-3, UL 60950, UL 508, EN 61000-6-2, EN 61000-6-3 4 238 Primary Switch Mode Power Supplies EPSITRON - PRO - Power Output voltage 24 V DC; 10 A open circuit and short-circuit protected, adjustable output voltage, LED status indication; PowerBoost Output voltage 24 V DC; 10 A open circuit and short-circuit protected, adjustable output voltage, LED status indication; PowerBoost; LineMonitor • Primary switch mode power supply with PowerBoost and TopBoost • Line monitor for parameter setting and monitoring • prepared for class I equipment • natural convection cooling when horizontally mounted • encapsulated, for use in switchgear cabinets L1 L2 L3 L1 DC+ DC+ DC DC - L2 L3 DC+ DC+ DC DC - Description Vo nom Item No. Pack. unit Vo nom Item No. Pack. unit Primary switch mode power supplies, for DIN 35 rail 24 V DC, SELV 787-842 1 24 V DC, SELV 787-852 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Input current Ii Inrush current Mains failure hold-up time Internal/external fuse Nominal output voltage Vo nom Output voltage range Output current Io PowerBoost TopBoost Residual ripple Derating Adjustment accuracy Current limitation Efficiency Test voltage pri.-gr./pri.-sec./sec.-gr. Degree of protection Operational indication Signaling LineMonitor, parameter setting Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 3x (2x) 400 V ... 500 V AC 340 V ... 550 V AC / 480 V ... 780 V DC 50 Hz ... 60 Hz 3 x 1.0 A at 340 V AC and 20 A DC < 30 A 13 ms typ. at 3 x 400 V AC 3 x 2.5 AT / 24 V DC, SELV 22.8 V ... 28.8 V DC adjustable 20 A at 24 V DC 40 A DC (for 4 s); 30 A DC (for 8 s) 80 A DC (for 50 ms) < 70 mVpp -3 % / K ( > 50 °C) 1% 1.1 x Io typ. 92.9 % typ. - / 4.2 kV / IP20 LED green (Vo), LED red (error) DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +70°C -25 °C ... +85 °C 77 x 171 x 179 Height from upper-edge of DIN 35 rail Input/Output: WAGO 231 Series / WAGO 831 Series Input: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Output: 0.5 mm² ... 10 mm² / AWG 20 ... 8 Input: 8 ... 9 mm / 0.33 in Output: 13 ... 15 mm / 0.55 in 1300 g EN 60950, EN 61204-3, UL 60950, UL 508, EN 61000-6-2, EN 61000-6-3 3x (2x) 400 V ... 500 V AC 340 V ... 550 V AC / 480 V ... 780 V DC 50 Hz ... 60 Hz 3 x 1.0 A at 340 V AC and 20 A DC < 30 A 13 ms typ. at 3 x 400 V AC 3 x 2.5 AT / 24 V DC, SELV 22.8 V ... 28.8 V DC adjustable 20 A at 24 V DC 40 A DC (for 4 s); 30 A DC (for 8 s) 80 A DC (for 50 ms) < 70 mVpp -3 % / K ( > 50 °C) 1% 1.1 x Io typ. 92.9 % typ. - / 4.2 kV / IP20 LED green (Vo), LED yellow (warning), LED red (error) LED, LCD, 4 x signal output 24 V DC, 25 mA via LCD and RS-232 serial interface DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +70°C -25 °C ... +85 °C 77 x 171 x 179 Height from upper-edge of DIN 35 rail Input/Output: WAGO 231 Series / WAGO 831 Series Signalising: WAGO 733 Series Input: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Output: 0.5 mm² ... 10 mm² / AWG 20 ... 8 Signalising: 0.08 mm² ... 0.5 mm² / AWG 28 ... 20 Input: 8 ... 9 mm / 0.33 in Output: 13 ... 15 mm / 0.55 in Signalising: 5 ... 6 mm / 0.22 in 1300 g EN 60950, EN 61204-3, UL 60950, UL 508, EN 61000-6-2, EN 61000-6-3 4 239 Output voltage 24 V DC; 10 A open circuit and short-circuit protected, adjustable output voltage, LED status indication; PowerBoost Output voltage 24 V DC; 10 A open circuit and short-circuit protected, adjustable output voltage, LED status indication; PowerBoost; LineMonitor • Primary switch mode power supply with PowerBoost and TopBoost • Line monitor for parameter setting and monitoring • prepared for class I equipment • natural convection cooling when horizontally mounted • encapsulated, for use in switchgear cabinets L1 L2 L3 L1 DC+ DC+ DC DC - L2 L3 DC+ DC+ DC DC - 4 Description Vo nom Item No. Pack. unit Vo nom Item No. Pack. unit Primary switch mode power supplies, for DIN 35 rail 24 V DC, SELV 787-844 1 24 V DC, SELV 787-854 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Input current Ii Inrush current Mains failure hold-up time Internal/external fuse Nominal output voltage Vo nom Output voltage range Output current Io PowerBoost TopBoost Residual ripple Derating Adjustment accuracy Current limitation Efficiency Test voltage pri.-gr./pri.-sec./sec.-gr. Degree of protection Operational indication Signaling LineMonitor, parameter setting Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 3x (2x) 400 V ... 500 V AC 340 V ... 550 V AC / 480 V ... 780 V DC 50 Hz ... 60 Hz 3 x 2.0 A at 340 V AC and 40 A DC < 30 A 15 ms typ. at 3 x 400 V AC 3 x 3.2 AT / 24 V DC, SELV 22.8 V ... 28.8 V DC adjustable 40 A at 24 V DC 60 A DC (for 4 s); 50 A DC (for 8 s) 100 A DC (for 50 ms) < 70 mVpp -5 % / K ( > 45 °C) 1% 1.1 x Io typ. 93.6 % typ. - / 4.2 kV / IP20 LED green (Vo), LED red (error) DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +55°C -25 °C ... +85 °C 128 x 171 x 205 Height from upper-edge of DIN 35 rail Input/Output: WAGO 231 Series / WAGO 831 Series Input: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Output: 0.5 mm² ... 10 mm² / AWG 20 ... 8 Input: 8 ... 9 mm / 0.33 in Output: 13 ... 15 mm / 0.55 in 2500 g EN 60950, EN 61204-3, UL 60950, UL 508, EN 61000-6-2, EN 61000-6-3 3x (2x) 400 V ... 500 V AC 340 V ... 550 V AC / 480 V ... 780 V DC 50 Hz ... 60 Hz 2.0 A at 340 V AC < 30 A 15 ms typ. at 3 x 400 V AC 3 x 3.2 AT / 24 V DC, SELV 22.8 V ... 28.8 V DC adjustable 40 A at 24 V DC 60 A DC (for 4 s); 50 A DC (for 8 s) 100 A DC (for 50 ms) < 70 mVpp -5 % / K ( > 45 °C) 1% 1.1 x Io typ. 93.6 % typ. - / 4.2 kV / IP20 LED green (Vo), LED yellow (warning), LED red (error) LED, LCD, 4 x signal output 24 V DC, 25 mA via LCD and RS-232 serial interface DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +55°C -25 °C ... +85 °C 128 x 171 x 205 Height from upper-edge of DIN 35 rail Input/Output: WAGO 231 Series / WAGO 831 Series Signalising: WAGO 733 Series Input: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Output: 0.5 mm² ... 10 mm² / AWG 20 ... 8 Signalising: 0.08 mm² ... 0.5 mm² / AWG 28 ... 20 Input: 8 ... 9 mm / 0.33 in Output: 13 ... 15 mm / 0.55 in Signalising: 5 ... 6 mm / 0.22 in 2500 g EN 60950, EN 61204-3, UL 60950, UL 508, EN 61000-6-2, EN 61000-6-3 4 240 Primary Switch Mode Power Supplies EPSITRON - CLASSIC - Power Output voltage 12 V DC; 2 A open circuit and short-circuit protected, adjustable output voltage, LED status indication Output voltage 12 V DC; 4 A open circuit and short-circuit protected, adjustable output voltage, LED status indication, parallel connection possible, thermal overload protection • prepared for class I equipment • natural convection cooling when horizontally mounted • encapsulated, for use in switchgear cabinets L N L DC+ DC+ DC DC - N DC+ DC+ DC DC - Description Vo nom Item No. Pack. unit Vo nom Item No. Pack. unit Primary switch mode power supplies, for DIN 35 rail 12 V DC, SELV 787-601 1 12 V DC, SELV 787-611 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Input current Ii Inrush current Mains failure hold-up time Nominal output voltage Vo nom Output voltage range Output current Io Residual ripple Derating Adjustment accuracy Current limitation Efficiency Test voltage pri.-gr./pri.-sec./sec.-gr. Degree of protection Operational indication Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 110 V ... 230 V AC 90 V ... 264 V AC; 130 V ... 300 V DC (use of DC requires external protection) 50 Hz ... 60 Hz 0.3 A typ. at 230 V AC < 10 A > 20 ms at 230 V AC 12 V DC, SELV 11 V ... 15 V DC adjustable 2 A at 12 V DC < 100 mVpp to 20 MHz -3 % / K (>50 °C) 1.5 % from approx. 1.5 x Io 78 % typ. 4.2 kV IP20 LED green (12 V o.k.) DIN-rail mounting (DIN EN 50022) -10 °C ... +70 °C -25 °C ... +85 °C 40 x 95 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 231 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 8 ... 9 mm / 0.33 in 300 g EN 60950-1, EN 61204-3, EN 61204-7 110 V ... 230 V AC 90 V ... 264 V AC; 130 V ... 300 V DC (use of DC requires external protection) 50 Hz ... 60 Hz 0.6 A typ. at 230 V AC < 15 A > 20 ms at 230 V AC 12 V DC, SELV 11 V ... 15 V DC adjustable 4 A at 12 V DC < 100 mVpp to 20 MHz -3 % / K (>50 °C) 2% from approx. 1.1 x Io 84 % typ. 4.2 kV IP20 LED green (12 V o.k.) DIN-rail mounting (DIN EN 50022) -10 °C ... +70 °C -25 °C ... +85 °C 51 x 133 x 120 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 231 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 8 ... 9 mm / 0.33 in 690 g EN 60950-1, EN 61204-3, EN 61204-7 4 241 Output voltage 12 V DC; 8 A open circuit and short-circuit protected, adjustable output voltage, LED status indication, parallel connection possible, thermal overload protection Output voltage 24 V DC; 1 A open circuit and short-circuit protected, adjustable output voltage, LED status indication • prepared for class I equipment • Natural convection cooling when horizontally mounted • encapsulated, for use in switchgear cabinets L N L DC+ DC+ DC DC - N DC+ DC+ DC DC - 4 Description Vo nom Item No. Pack. unit Vo nom Item No. Pack. unit Primary switch mode power supplies, for DIN 35 rail 12 V DC, SELV 787-621 1 24 V DC, SELV 787-602 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Input current Ii Inrush current Discharge current Mains failure hold-up time Nominal output voltage Vo nom Output voltage range Output current Io Residual ripple Derating Adjustment accuracy Current limitation Efficiency Test voltage pri.-gr./pri.-sec./sec.-gr. Degree of protection Operational indication Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 110 V ... 230 V AC 90 V ... 264 V AC; 130 V ... 300 V DC (use of DC requires external protection) 50 Hz ... 60 Hz 1.2 A typ. at 230 V AC < 15 A > 20 ms at 230 V AC 12 V DC, SELV 11 V ... 15 V DC adjustable 8 A at 12 V DC < 100 mVpp to 20 MHz -3 % / K (>50 °C) 2% from approx. 1.1 x Io 85 % typ. 4.2 kV IP20 LED green (12 V o.k.) DIN-rail mounting (DIN EN 50022) -10 °C ... +70 °C -25 °C ... +85 °C 67 x 133 x 120 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 231 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 8 ... 9 mm / 0.33 in 952 g EN 60950-1, EN 61204-3, EN 61204-7 110 V ... 230 V AC 90 V ... 264 V AC; 130 V ... 300 V DC (use of DC requires external protection) 50 Hz ... 60 Hz 0.3 A typ. at 230 V AC < 10 A 900 μA typ. > 20 ms at 230 V AC 24 V DC, SELV 21.6 V ... 26.4 V DC adjustable 1.3 A at 24 V DC < 100 mVpp to 20 MHz -3 % / K (>50 °C) 1.5 % from approx. 1.5 x Io 81 % typ. 4.2 kV IP20 LED green (24 V o.k.) DIN-rail mounting (DIN EN 50022) -10 °C ... +70 °C -25 °C ... +85 °C 40 x 95 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 231 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 8 ... 9 mm / 0.33 in 300 g EN 60950-1, EN 61204-3, EN 61204-7, UL 60950, UL 508 4 242 Primary Switch Mode Power Supplies EPSITRON - CLASSIC - Power Output voltage 24 V DC; 2.5 A open circuit and short-circuit protected, adjustable output voltage, LED status indication, parallel connection possible, thermal overload protection Output voltage 24 V DC; 5 A open circuit and short-circuit protected, adjustable output voltage, LED status indication, parallel connection possible, thermal overload protection • prepared for class I equipment • natural convection cooling when horizontally mounted • encapsulated, for use in switchgear cabinets L N L DC+ DC+ DC DC - N DC+ DC+ DC DC - Description Vo nom Item No. Pack. unit Vo nom Item No. Pack. unit Primary switch mode power supplies, for DIN 35 rail 24 V DC, SELV 787-612 1 24 V DC, SELV 787-622 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Input current Ii Inrush current Discharge current Mains failure hold-up time Nominal output voltage Vo nom Output voltage range Output current Io Residual ripple Derating Adjustment accuracy Current limitation Efficiency Test voltage pri.-gr./pri.-sec./sec.-gr. Degree of protection Operational indication Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 110 V ... 230 V AC 90 V ... 264 V AC; 130 V ... 300 V DC (use of DC requires external protection) 50 Hz ... 60 Hz 0.6 A typ. at 230 V AC < 10 A 940 μA typ. > 20 ms at 230 V AC 24 V DC, SELV 22 V ... 28.8 V DC adjustable 2.5 A at 24 V DC < 100 mVpp to 20 MHz -3 % / K (>55 °C) 1.5 % from approx. 1.1 x Io 88 % typ. 4.2 kV IP20 LED green (24 V o.k.) DIN-rail mounting (DIN EN 50022) -10 °C ... +70 °C -25 °C ... +85 °C 51 x 133 x 120 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 231 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 8 ... 9 mm / 0.33 in 622 g EN 60950-1, EN 61204-3, EN 61204-7, UL 60950, UL 508 110 V ... 230 V AC 90 V ... 264 V AC; 130 V ... 300 V DC (use of DC requires external protection) 50 Hz ... 60 Hz 1.2 A typ. at 230 V AC < 50 A 550 μA typ. > 20 ms at 230 V AC 24 V DC, SELV 22 V ... 28.8 V DC adjustable 5 A at 24 V DC < 100 mVpp to 20 MHz -3 % / K (>55 °C) 1.5 % from approx. 1.1 x Io 89 % typ. 4.2 kV IP20 LED green (24 V o.k.) DIN-rail mounting (DIN EN 50022) -10 °C ... +70 °C -25 °C ... +85 °C 67 x 133 x 120 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 231 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 8 ... 9 mm / 0.33 in 790 g EN 60950-1, EN 61204-3, EN 61204-7, UL 60950, UL 508 4 243 Output voltage 24 V DC; 10 A open circuit and short-circuit protected, adjustable output voltage, LED status indication, parallel connection possible, thermal overload protection Output voltage 48 V DC; 1 A open circuit and short-circuit protected, adjustable output voltage, LED status indication, parallel connection possible • prepared for class I equipment • natural convection cooling when horizontally mounted • encapsulated, for use in switchgear cabinets L N L DC+ DC+ DC DC - N DC+ DC+ DC DC - 4 Description Vo nom Item No. Pack. unit Vo nom Item No. Pack. unit Primary switch mode power supplies, for DIN 35 rail 24 V DC, SELV 787-632 1 48 V DC, SELV 787-613 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Input current Ii Inrush current Discharge current Mains failure hold-up time Internal/external fuse Nominal output voltage Vo nom Output voltage range Output current Io Residual ripple Derating Adjustment accuracy Current limitation Efficiency Test voltage pri.-gr./pri.-sec./sec.-gr. Degree of protection Operational indication Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 110 V ... 230 V AC 85 V ... 264 V AC; 90 V ... 350 V DC 50 Hz ... 60 Hz 2.8 A at 230 V AC (6 A at 115 V AC) < 30 A 1 mA typ. >20 ms at 230 V AC, 24 V DC, 10 A 6.3 A / 16 A recommended 24 V DC, SELV 22.8 V ... 28.8 V DC adjustable 10 A at 24 V DC < 100 mVpp -3 % / K (>50 °C) 3% from 1.2 x Ia 88 % typ. 1.5 kV / 4.2 kV / 0.5 kV IP20 (EN 60529, 1991) LED green at Vo > DC 18 V /LED red at overcurrent DIN-rail mounting (DIN EN 50022) -10 °C ... +70 °C -25 °C ... +85 °C 115 x 87 x 140 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 231 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 8 ... 9 mm / 0.33 in 950 g EN 60950-1, EN 61204-3, EN 61204-7, UL 60950, UL 508 110 V ... 230 V AC 90 V ... 264 V AC; 130 V ... 300 V DC (use of DC requires external protection) 50 Hz ... 60 Hz 0.6 A typ. at 230 V AC < 50 A > 20 ms at 230 V AC 48 V DC, SELV 43.2 V ... 52.8 V DC adjustable 1 A at 48 V DC < 200 mVpp at 20 MHz -3 % / K (>60 °C) 2% from 1.1 x Ia 85 % typ. 4.2 kV IP20 LED green (48 V o.k.) DIN-rail mounting (DIN EN 50022) -10 °C ... +70 °C -25 °C ... +85 °C 51 x 133 x 120 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 231 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 8 ... 9 mm / 0.33 in 690 g EN 60950-1, EN 61204-3, EN 61204-7 4 244 Primary Switch Mode Power Supplies EPSITRON - CLASSIC - Power Output voltage 48 V DC; 2 A open circuit and short-circuit protected, adjustable output voltage, LED status indication, parallel connection possible • • • • • Output voltage 48 V DC; 5 A open circuit and short-circuit protected, adjustable output voltage, LED status indication, parallel connection possible Thermal overload protection Parallel connection possible Prepared for class I equipment Natural convection cooling when horizontally mounted Encapsulated, for use in switchgear cabinets L N L DC+ DC+ DC DC - N DC+ DC+ DC DC - Description Vo nom Item No. Pack. unit Vo nom Item No. Pack. unit Primary switch mode power supplies, for DIN 35 rail 48 V DC, SELV 787-623 1 48 V DC 787-633 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Input current Ii Inrush current Mains failure hold-up time Nominal output voltage Vo nom Output voltage range Output current Io Residual ripple Derating Adjustment accuracy Current limitation Efficiency Test voltage pri.-gr./pri.-sec./sec.-gr. Degree of protection Operational indication Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 110 V ... 230 V AC 90 V ... 264 V AC; 130 V ... 300 V DC (use of DC requires external protection) 50 Hz ... 60 Hz 1.2 A typ. at 230 V AC < 50 A > 20 ms at 230 V AC 48 V DC, SELV 42 V ... 52.8 V DC adjustable 2 A at 48 V DC < 200 mVpp at 20 MHz -3 % / K (>55 °C) 2% from 1.1 x Ia 90 % typ. 4.2 kV IP20 LED green (48 V o.k.) DIN-rail mounting (DIN EN 50022) -10 °C ... +70 °C -25 °C ... +85 °C 67 x 133 x 120 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 231 Series) 0.1 mm² ... 2.5 mm² / AWG 28 ... 12 0.5 mm² ... 10 mm² / AWG 20 ... 8 (THHN, THWN) 8 ... 9 mm / 0.33 in 800 g EN 60950-1, EN 61204-3, EN 61204-7 110 V ... 230 V AC 176 V ... 264 V AC / 90 V ... 132 V 50 Hz ... 60 Hz 2.8 A typ. at 230 V AC / 6.0 A typ. at 115 V AC < 50 A > 20 ms at 230 V AC 48 V DC 43.2 V ... 52.8 V DC adjustable 5 A at 48 V DC < 200 mVpp at 20 MHz -3 % / K (>50 °C) 3% from 1.2 x Ia 85 % typ. 4.2 kV IP20 LED green (48 V o.k.) DIN-rail mounting (DIN EN 50022) -10 °C ... +70 °C -25 °C ... +85 °C 115 x 87 x 140 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 231 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 8 ... 9 mm / 0.33 in 940 g EN 60950-1, EN 61204-3, EN 61204-7 4 245 Power supply for AS-Interface; Input 115V/230V AC; Output 30.5V DC; 3A • Min. cond. cross section acc. to AS-Interface specification: 1.5 mm2 • natural convection cooling when horizontally mounted • encapsulated, for use in switchgear cabinets L ASI+ N 4 ASI - Description Vo nom Item No. Pack. unit Primary switch mode power supply, for DIN 35 rail 30.5 V DC (PELV) 787-692 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Input current Ii Inrush current Mains failure hold-up time Internal/external fuse Nominal output voltage Vo nom Output voltage range Output current Io Residual ripple Mains / load regulation Derating Current limitation Efficiency Test voltage pri.-gr./pri.-sec./sec.-gr. Degree of protection Operational indication Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 110 V ... 230 V AC 90 V ... 264 V AC; 130 V ... 300 V DC (use of DC requires external protection) 50 Hz ... 60 Hz 2 A at 115 V AC / 1 A at 230 V AC < 50 A (cold) > 15 ms at 115 V AC / > 50 ms at 230 V AC 4 AT 30.5 V DC (PELV) 26 V ... 33 V DC 3 A at 30.5 V DC; 2.5 A at Vi < 97 V AC < 300 mVpp to 20 MHz < 750 mV -3 % / K (>55 °C) 3.4 A typ. 89 % typ. 4.2 kV IP20 LED green (operating condition at Vo) DIN-rail mounting (DIN EN 50022) -10 °C ... +70 °C -25 °C ... +85 °C 51 x 133 x 120 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 231 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 8 ... 9 mm / 0.33 in 690 g EN 60950-1, EN 61204-3, EN 61204-7, UL 60950, UL 508 4 246 Primary Switch Mode Power Supplies EPSITRON - ECO - Power Output voltage 24 V DC; 2.5 A open circuit and short-circuit protected, adjustable output voltage, LED status indication Output voltage 24 V DC; 5 A open circuit and short-circuit protected, adjustable output voltage, LED status indication • prepared for class I equipment • natural convection cooling when horizontally mounted • encapsulated, for use in switchgear cabinets L N 3 L DC+ DC+ DC– DC– N 3 DC+ DC+ DC– DC– Description Vo nom Item No. Pack. unit Vo nom Item No. Pack. unit Primary switch mode power supplies, for DIN 35 rail 24 V DC, SELV 787-712 1 24 V DC, SELV 787-722 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Input current Ii Inrush current Mains failure hold-up time Nominal output voltage Vo nom Output voltage range Output current Io Residual ripple Derating Adjustment accuracy Current limitation Efficiency Test voltage pri.-gr./pri.-sec./sec.-gr. Degree of protection Operational indication Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 230 V AC 85 V ... 264 V AC* *with derating -3 % / V (< 90 V) 47 Hz ... 63 Hz 0.7 A typ. at 230 V AC < 30 Ap > 20 ms at 230 V AC 24 V DC, SELV 22 V ... 28 V DC adjustable 2.5 A at 24 V DC < 100 mVpp to 20 MHz -3.3 % / K (>55 °C at 230 V AC) 1% from 1.15 to 1.4 x Io 82 % typ. 1.5 kV / 3 kV / 0.5 kV IP20 LED green (24 V DC o.k.), LED red (overload) DIN-rail mounting (DIN EN 50022) -10 °C ... +70°C -25 °C ... +85 °C 50 x 92 x 136 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 745 Series) 0.08 mm² ... 4 mm² / AWG 28 ... 12 (THHN, THWN) 8 ... 9 mm / 0.33 in 470 g EN 60950, EN 61000-6-2, EN 61000-6-3 UL 60950, UL 508* (* pending) 230 V AC 85 V ... 264 V AC* *with derating -0.8 % / V (< 110 V) 47 Hz ... 63 Hz 1.0 A typ. at 230 V AC < 30 Ap > 20 ms at 230 V AC 24 V DC, SELV 22 V ... 28 V DC adjustable 5 A at 24 V DC < 100 mVpp to 20 MHz -2.67 % / K ( > 40 °C) 1% from 1.15 to 1.4 x Io 82 % typ. 1.5 kV / 3 kV / 0.5 kV IP20 LED green (24 V DC o.k.), LED red (overload) DIN-rail mounting (DIN EN 50022) -10 °C ... +70°C -25 °C ... +85 °C 75 x 92 x 136 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 745 Series) 0.08 mm² ... 4 mm² / AWG 28 ... 12 (THHN, THWN) 8 ... 9 mm / 0.33 in 740 g EN 60950, EN 61000-6-2, EN 61000-6-3 UL 60950, UL 508* (* pending) 4 247 Output voltage 24 V DC; 10 A open circuit and short-circuit protected, adjustable output voltage, LED status indication • prepared for class I equipment • natural convection cooling when horizontally mounted • encapsulated, for use in switchgear cabinets L N 3 DC+ DC+ DC– DC– 4 Description Vo nom Item No. Pack. unit Primary switch mode power supply, for DIN 35 rail 24 V DC, SELV 787-732 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Input current Ii Inrush current Mains failure hold-up time Nominal output voltage Vo nom Output voltage range Output current Io Residual ripple Derating Adjustment accuracy Current limitation Efficiency Test voltage pri.-gr./pri.-sec./sec.-gr. Degree of protection Operational indication Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 230 V AC 85 V ... 264 V AC* *with derating -0.8 % / V (< 110 V) 47 Hz ... 63 Hz 1.5 A typ. at 230 V AC < 30 Ap > 20 ms at 230 V AC 24 V DC, SELV 22 V ... 28 V DC adjustable 10 A at 24 V DC < 100 mVpp to 20 MHz -2.67 % / K (>55 °C at 230 V AC) 1% from 1.15 to 1.4 x Io 82 % typ. 1.5 kV / 3 kV / 0.5 kV IP20 LED green (24 V DC o.k.), LED red (overload) DIN-rail mounting (DIN EN 50022) -10 °C ... +70°C -25 °C ... +85 °C 110 x 92 x 136 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 745 Series) 0.08 mm² ... 4 mm² / AWG 28 ... 12 (THHN, THWN) 8 ... 9 mm / 0.33 in 1030 g EN 60950, EN 61000-6-2, EN 61000-6-3 UL 60950, UL 508* (* pending) 4 EPSITRON - Electronic Circuit Breakers 248 Electronic circuit breaker 4-channel, 1 A ... 6 A DC, parametrizable Electronic circuit breaker 4-channel, 1 A ... 10 A DC, parametrizable • Electronic circuit breaker with 4 channels, parametrizable • Time-delayed switching of channels • Floating switch contact • Current and voltage monitoring via RS-232 interface and LCD • Watchdog functions with active signal ports Description Vo nom Item No. Pack. unit Vo nom Item No. Pack. unit Electronic circuit breakers, for DIN 35 rail 4 x 24 V DC 787-860 1 4 x 24 V DC 787-862 1 Technical Data Nominal input voltage Vi nom Input voltage range Internal/external fuse Nominal output voltage Vo nom Nominal current Voltage drop Trip time Switch-on capacity Switch-on behavior Parallel operation of single channels Series connection of several devices Degree of protection Operational indication Signaling Remote input LineMonitor, parameter setting Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 24 V DC 18 … 30 V DC 6.3 AT 4 x 24 V DC 4 x 1 ... 6 A DC (adjustable for each channel in 1 A steps) 120 mV at 6 A 100 s (100 ms .. 600 s; adjustable) 1000 μF per 1 A DC (max. 7000 μF) time-delayed channel switching (250 ms each) not permitted not permitted IP20 LED green (all channels o.k.), LED yellow (warning), LED red (at least one channel has tripped) LCD, 4 x signal output 24 V DC, 25 mA and 1 x floating relay contact 60 V DC, 3 A Reactivation of all tripped channels via 18 V … 30 V DC impulse for min. 50 ms via LCD and RS-232 serial interface DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +60°C -25 °C ... +85 °C 40 x 171 x 163 Height from upper-edge of DIN 35 rail Input: (WAGO 831 Series) Output: (WAGO 231 Series) Input: 0.5 mm² ... 10 mm² / AWG 20 ... 8 Output: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Input: 13 ... 15 mm / 0.55 in Output: 8 ... 9 mm / 0.33 in 800 g EN 60950, UL 508*, EN 61000-6-2, EN 61000-6-3 (* pending) 24 V DC 18 … 30 V DC 15 AT 4 x 24 V DC 4 x 1 ... 10 A DC (adjustable for each channel in 1 A steps) 120 mV at 6 A, 240 mV at 10 A 100 s (100 ms .. 600 s; adjustable) 1000 μF per 1 A DC (max. 7000 μF) time-delayed channel switching (250 ms each) not permitted not permitted IP20 LED green (all channels o.k.), LED yellow (warning), LED red (at least one channel has tripped) LCD, 4 x signal output 24 V DC, 25 mA and 1 x floating relay contact 60 V DC, 3 A Reactivation of all tripped channels via 18 V … 30 V DC impulse for min. 50 ms via LCD and RS-232 serial interface DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +60°C -25 °C ... +85 °C 40 x 171 x 163 Height from upper-edge of DIN 35 rail Input: (WAGO 831 Series) Output: (WAGO 231 Series) Input: 0.5 mm² ... 10 mm² / AWG 20 ... 8 Output: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Input: 13 ... 15 mm / 0.55 in Output: 8 ... 9 mm / 0.33 in 800 g EN 60950, UL 508*, EN 61000-6-2, EN 61000-6-3 (* pending) 4 249 Electronic circuit breaker 4-channel, 1 A ... 8 A DC, parametrizable, active current limitation • Electronic circuit breaker with 4 channels, parametrizable • Features active current limitation, reliably prevents voltage drops • Time-delayed switching of channels • Current and voltage monitoring via RS-232 interface and LCD • Watchdog functions with active signal ports 4 Description Vo nom Item No. Pack. unit Electronic circuit breakers, for DIN 35 rail 4 x 24 V DC 787-861 1 Technical Data Nominal input voltage Vi nom Input voltage range Internal/external fuse Nominal output voltage Vo nom Nominal current Voltage drop Trip time Switch-on capacity Switch-on behavior Parallel operation of single channels Series connection of several devices Trip current Current limitation Degree of protection Operational indication Signaling LineMonitor, parameter setting Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 24 V DC 18 … 30 V DC 15 AT 4 x 24 V DC 4 x 1 ... 8 A DC (adjustable for each channel in 1 A steps) 240 mV at 8 A 100 ms (100 ms .. 1.5 s; adjustable, depending on nominal current) max. 20,000 μF time-delayed channel switching (250 ms each) not permitted not permitted 1.1 x nominal current typ. 1.5 x nominal current typ. IP20 LED green (all channels o.k.), LED yellow (warnings), LED red (at least one channel has tripped) LCD, 4 x signal output 24 V DC, 25 mA via LCD and RS-232 serial interface DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +60°C -25 °C ... +85 °C 40 x 171 x 163 Height from upper-edge of DIN 35 rail Input: (WAGO 831 Series) Output: (WAGO 231 Series) Input: 0.5 mm² ... 10 mm² / AWG 20 ... 8 Output: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Input: 13 ... 15 mm / 0.55 in Output: 8 ... 9 mm / 0.33 in 800 g EN 60950, UL 2367*, EN 61000-6-2, EN 61000-6-3 (* pending) 4 EPSITRON - UPS Charger and Controller 250 UPS charger and controller 24 V DC, 10 A, parametrizable UPS charger and controller 24 V DC, 20 A parametrizable • Charger and controller for uninterruptible power supply (UPS) • Current and voltage monitoring, as well as parameter setting via LCD and RS-232 interface • Active signal outputs for watchdog functions • Remote input for switching off buffered output • Input for temperature control of connected battery DC+ DC– TEMP REMOTE DC+ DC– ACCU IN TEMP REMOTE ACCU DC+ DC+ DC– DC– DC+ DC– OUT IN DC+ DC+ DC– DC– DC+ DC– 3 OUT 3 Description Vo nom Item No. Pack. unit Vo nom Item No. Pack. unit UPS charger and controller, for DIN 35 rail 24 V DC 787-870 1 24 V DC 787-875 1 Technical Data Nominal input voltage Vi nom Input voltage range Input current Ii Inrush current Switch-on threshold (adjustable) Internal/external fuse Nominal output voltage Vo nom Output voltage range Output current Io Current limitation Buffer time Final load voltage Charging current Degree of protection Operational indication Signaling Remote input LineMonitor, parameter setting Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 24 V DC 20.4 V ... 28.8 V DC 0.1 A (no-load running); 0.8 A (charging); 10.8 A (max.) < 4 A (no load) 20 V ... 25.5 V DC 15 AT / 24 V DC Vi - 0.5 V DC (below switch-on threshold); 20 V ... 25.5 V DC (during buffer operation) 10 A typ. 11 A ... 14 A 10 s ... 600 s or constant (adjustable) 26 V ... 29.5 V DC or temperature controlled (adjustable) max. 0.6 A IP20 LED green (Vo), LED yellow (warning), LED red (error) LCD, 3 x signal output 24 V DC, 25 mA and 1 x floating relay contact 30 V DC, 1 A to switch off buffer operation via LCD and RS-232 serial interface DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +60°C -25 °C ... +85 °C 40 x 163 x 163 Height from upper-edge of DIN 35 rail Input: (WAGO 231 Series) Output: (WAGO 231 Series) Input: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Output: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Input: 8 ... 9 mm / 0.33 in Output: 8 ... 9 mm / 0.33 in 800 g EN 60950, UL 60950*, UL 508*, EN 61000-6-2, EN 61000-6-3 (* pending) 24 V DC 20.4 V ... 28.8 V DC 0.1 A (no-load running); 1.5 A (charging); 21.5 A (max.) < 4 A (no load) 20 V ... 25.5 V DC 15 AT / 24 V DC Vi - 1 V DC (below switch-on threshold); 20 V ... 25.5 V DC (buffer mode) 20 A typ. 22 A ... 26 A 10 s ... 600 s or constant (adjustable) 26 V ... 29.5 V DC or temperature controlled (adjustable) max. 1.0 A IP20 LED green (Vo), LED yellow (warning), LED red (error) LCD, 3 x signal output 24 V DC, 25 mA and 1 x floating relay contact 30 V DC, 1 A to switch off buffer operation via LCD and RS-232 serial interface DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +60 °C -25 °C ... +85 °C 57 x 163 x 171 Height from upper-edge of DIN 35 rail Intput/Output: (WAGO 831 Series) Signalising: (WAGO 733 Series) Input/Output: 0.5 mm² ... 10 mm² / AWG 20 ... 8 Signalising: 0.08 mm² ... 0.5 mm² / AWG 28 ... 20 Input/Output: 13 ... 15 mm / 0.55 in Signalising: 5 ... 6 mm / 0.22 in 1200 g EN 60950, UL 60950*, UL 508*, EN 61000-6-2, EN 61000-6-3 (* pending) 4 EPSITRON - Lead Gel Battery Modules 251 Lead gel battery module 24 V DC, 3.2 Ah Lead gel battery module 24 V DC, 7 Ah • Lead gel battery module for uninterruptible power supply (UPS) • Can be connected to 787-873 and 787-875 (only 787-872) UPS Controllers • Parallel connection to increase the buffer time • Features built-in NTC K164 temperature sensor DC+ DC– DC+ DC– TEMP TEMP 4 TEMP TEMP Description Vo nom Item No. Pack. unit Vo nom Item No. Pack. unit Lead gel battery modules 24 V DC 787-871 1 24 V DC 787-872 1 Technical Data Nominal input voltage Vi nom Internal/external fuse Nominal output voltage Vo nom Output current Io Final load voltage Charging current Capacity Temperature sensor Service life Degree of protection Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 24 V DC 15 AT / 24 V DC 12 A max. 27 V DC (at 25 °C) max. 0.8 A 3.2 Ah NTC K164 (4.7 kΩ) typ. 5/ 4/ 2 years at 20 °C/ 30 °C/ 40 °C IP20 Screw mount -10 °C ... +40 °C -20 °C ... +40 °C 76.2 x 168 x 175,5 Input/Output: (WAGO 231 Series) Temperature sensor: (WAGO 231 Series) Input/Output: 0.08 mm² ... 2.5 mm² / AWG 20 ... 12 Temperature sensor: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Input/Output: 8 ... 9 mm / 0.33 in Temperature sensor: 8 ... 9 mm / 0.33 in 4200 g battery is tested to VdS 24 V DC 25 AT / 24 V DC 21 A max. 27 V DC (at 25 °C) max. 1.8 A 7 Ah NTC K164 (4.7 kΩ) typ. 5/ 4/ 2 years at 20 °C/ 30 °C/ 40 °C IP20 Screw mount -10 °C ... +40 °C -20 °C ... +40 °C 86 x 239 x 217.5 Input/Output: (WAGO 831 Series) Temperature sensor: (WAGO 231 Series) Input/Output: 0.5 mm² ... 10 mm² / AWG 20 ... 8 Temperature sensor: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Input/Output: 13 ... 15 mm / 0.55 in Temperature sensor: 8 ... 9 mm / 0.33 in 6500 g battery is tested to VdS 4 EPSITRON - Lead Gel Battery Modules 252 Lead gel battery module 24 V DC, 12 Ah • Lead gel battery module for uninterruptible power supply (UPS) • Can be connected to 787-873 and 787-875 UPS Controllers • Parallel connection to increase the buffer time • Features built-in NTC K164 temperature sensor DC+ DC– TEMP TEMP Description Vo nom Item No. Pack. unit Lead gel battery module 24 V DC 787-873 1 Technical Data Nominal input voltage Vi nom Internal/external fuse Nominal output voltage Vo nom Output current Io Final load voltage Charging current Capacity Temperature sensor Service life Degree of protection Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 24 V DC 25 AT / 24 V DC 21 A max. 27 V DC (at 25 °C) max. 3 A 12 Ah NTC K164 (4.7 kΩ) typ. 5/ 4/ 2 years at 20 °C/ 30 °C/ 40 °C IP20 Screw mount -10 °C ... +40 °C -20 °C ... +40 °C 120.5 x 239 x 217.5 Input/Output: (WAGO 831 Series) Temperature sensor: (WAGO 231 Series) Input/Output: 0.5 mm² ... 10 mm² / AWG 20 ... 8 Temperature sensor: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Input/Output: 13 ... 15 mm / 0.55 in Temperature sensor: 8 ... 9 mm / 0.33 in 10600 g Battery is tested to VdS Vo nom Item No. Pack. unit 4 EPSITRON - Capacitive Buffer Modules 253 Capacitive buffer module 24 V DC, 10 A Capacitive buffer module 24 V DC, 20 A • Capacitive buffer module bridges short duration voltage drops • For uninterruptible power supply • Potential-free contact for charge condition monitoring DC+ IN DC– DC+ DC+ DC– DC– DC+ OUT IN DC– DC+ DC+ DC– DC– OUT 4 Description Vo nom Item No. Pack. unit Vo nom Item No. Pack. unit Capacitive buffer modules, for DIN 35 rail 24 V DC 787-880 1 24 V DC 787-881 1 Technical Data Nominal input voltage Vi nom Input voltage range Input current Ii Switch-on threshold (adjustable) Charging time Nominal output voltage Vo nom Output voltage range Output current Io Current limitation Buffer time Parallel operation Power loss PV Feedback voltage Degree of protection Operational indication Signaling Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 24 V DC 20 V ... 30 V DC 60 mA (no-load running); 1 A (charging); 11 A (max.) 20 V ... 24 V DC typ. 5 minutes 24 V DC Vi - 0.5 V DC (below switch-on threshold); 20.4 V ... 24 V DC (during buffer operation) 10 A electronic, typ. 11 A 0.06 s ... 7.2 s (depends on load current and switch-on threshold) yes 1.5 W open circuit 6.5 W nominal load max. 35 V DC IP20 LED green (Va > 20 V), LED yellow (charging), LED red (Va < 20 V) 1 x floating relay contact 30 V DC, 1 A DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +50°C -10 °C ... +60 °C 57 x 179 x 163 Input/Output: (WAGO 231 Series) Relay: (WAGO 231 Series) Input/Output: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Relay: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Input/Output: 8 ... 9 mm / 0.33 in Relay: 8 ... 9 mm / 0.33 in 1000 g EN 60950, UL 60950*, UL 508*, EN 61000-6-2, EN 61000-6-3 (* pending) 24 V DC 20 V ... 30 V DC 60 mA (no-load running); 1 A (charging); 22 A (max.) 20 V ... 24 V DC typ. 5 minutes 24 V DC Vi - 1 V DC (below switch-on threshold); 20.4 V ... 24 V DC (during buffer operation) 20 A electronic, typ. 22 A 0.17 s ... 16.5 s (depends on load current and switch-on threshold) yes 1.5 W open circuit 15 W nominal load max. 35 V DC IP20 LED green (Va > 20 V), LED yellow (charging), LED red (Va < 20 V) 1 x floating relay contact 30 V DC, 1 A DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +50°C -10 °C ... +60 °C 57 x 179 x 181 Input/Output: (WAGO 831 Series) Relay: (WAGO 231 Series) Input/Output: 0.5 mm² ... 10 mm² / AWG 20 ... 8 Relay: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Input/Output: 13 ... 15 mm / 0.55 in Relay: 8 ... 9 mm / 0.33 in 1000 g EN 60950, UL 60950*, UL 508*, EN 61000-6-2, EN 61000-6-3 (* pending) 4 EPSITRON - Back-Up Capacitor Module 254 Back-up capacitor module smoothes unstable 24 V DC power supplies Mounting carrier for DIN 35 rail This module is equipped with a capacitor which smoothes unstable 24VDC power supplies in case the voltage tolerances mentioned in our data sheets cannot be ensured. Reasons for voltage transients could be: • Voltage disconnections (switching transients) on primary side • Overloads on secondary side • Switching of inductive or capacitive loads The back-up capacitor module is connected between the 24V power supply and the electronic device which has to be protected. Notice: If using a non-filtered single-phase power supply, the capacitor causes a voltage increase. 24V 0V Power supply Supply via power jumper contacts 24 V 0V IN 24V OUT GND 0V Description Item No. Pack. Unit Back-up capacitor module 288-824 1 Technical Data Nominal voltage Nominal current Nominal capacity Weight Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 24 V DC (+25 %) 1A 10000 μF 104.4 g 38 x 81 x 85 Height from upper-edge of DIN 35 rail CAGE CLAMP® (236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 5 ... 6 mm / 0.22 in Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier see page 323 white 709-198 / transparent 709-196 4 EPSITRON - Redundancy Module 255 Redundancy module 24 V DC, 20 A • Redundancy module with 2 inputs for decoupling 2 power supplies • For redundant or uninterruptible power supply • With potential-free contact for input voltage monitoring 1 + − 2 + − + OUT IN 4 − Description Vo nom Item No. Pack. unit Redundancy module, for DIN 35 rail 24 V DC 787-885 1 Technical Data Nominal input voltage Vi nom Input voltage range Input current Ii Nominal output voltage Vo nom Output current Io Parallel operation Power loss PV Efficiency Degree of protection Operational indication Signaling Type of mounting Ambient operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Weight Approvals 2 x 24 V DC 18 V ... 30 V DC 2 x 20 A, max. 1 x 40 A 24 V DC 20 A, max. 40 A yes 1.5 W open circuit 14 W nominal load (20 A) / 26 W nominal load (40 A) 97 % typ. IP20 LED green (Vo), 2 x LED yellow (Vi) 1 x floating relay contact 30 V DC, 1 A DIN-rail mounting (EN 60715) in 2 positions -10 °C ... +60°C -25 °C ... +85 °C 40 x 163 x 181 Height from upper-edge of DIN 35 rail Input/Output: (WAGO 831 Series) Relay: (WAGO 231 Series) Input/Output: 0.5 mm² ... 10 mm² / AWG 20 ... 8 Relay: 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 Input/Output: 13 ... 15 mm / 0.55 in Relay: 8 ... 9 mm / 0.33 in 800 g EN 60950, UL 60950*, UL 508*, EN 61000-6-2, EN 61000-6-3 (* pending) 787-890 4 EPSITRON - RS-232 Communication Cable 256 1 2 3 4 RxD PC TxD PC 5 6 7 8 Pin 2 = RxD PC Pin 3 = TxD PC Pin 5 = GND The 787-890 Communication Cable is used for configuration and visualization via PC or controller. It is suitable for all 787 Series devices equipped with an RS-232 serial interface. PC software for 787 Series devices can be downloaded at: www.wago.com/epsitron Function blocks for communication with WAGO-I/O-SYSTEM 750 are also available. NOTE: The 787-890 Communication Cable is not electrically isolated. Description Item No. Pack. unit Technical Data RS-232 communication cable 787-890 1 Type of signal Connections Isolation Cross sections Ambient operating temperature Degree of protection Length RS-232 1 x 8-pole 231-108 Female Connector with strain relief (787-8xx Module side), 1x 9-pole SUB-D female connector (PC/controller side) No 3 x 0.34 mm² (AWG 22), shielded -10 °C ... +70 °C IP20 1.8 m 4 257 4 4 Rail-Mounted Modules - Constant Voltage Sources 258 24 V DC; 3 A Input 27 V ... 35 V DC 24 V DC; 3 A Input 24 V AC +10 %, 50 Hz ... 60 Hz Mounting feet for DIN 35 rail Mounting carrier for DIN 35 rail UE Constant voltage source UA ~ Constant voltage source ~ 0V UA1 UA2 0V 0V Description Item No. Pack. Unit Item No. Pack. Unit Constant voltage source 24 V DC 289-907 1 288-800 1 Technical Data Input voltage Output voltage Nominal output current Ambient operating temperature Weight Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier 27 V ... 35 V DC 24 V DC (± 10 %) 3A -25 °C ... +40 °C 88 g 78.5 x 39 x 66 Height from upper-edge of DIN 35 rail CAGE CLAMP® (236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in 24 V AC +10% 24 V DC (± 10 %) 3A -25 °C ... +40 °C 209 g 140 x 44 x 85 Height from upper-edge of DIN 35 rail CAGE CLAMP® (236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in see page 323 white 709-198 / translucent 709-196 4 259 24 V DC; 5 A Input 24 V AC +10 % Electronic overload protection Output voltage indication by LED Mounting carrier for DIN 35 rail ~ Constant voltage source with overload protection UA ~ 4 0V Description Item No. Pack. Unit Constant voltage source 24 V DC 288-801 1 Technical Data Input voltage Output voltage Nominal output current Overload protection Voltage returns after removal of overload Ambient operating temperature Weight Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier 24 V AC +10% 24 V DC (± 10 %) 5A electronic after 4s 0 °C ... +30 °C 600.5 g 170 x 85 x 108 Height from upper-edge of DIN 35 rail CAGE CLAMP® (236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in see page 323 white 709-198 / translucent 709-196 4 Rail-Mounted Modules - Power Supplies 260 115 V AC / 24 V DC; 0.5 A Output voltage indication by LED 230 V AC / 24 V DC; 0.5 A Output voltage indication by LED Mounting carrier for DIN 35 rail Mounting carrier for DIN 35 rail L grey regulator 0,8 A T + orange light grey N blue – L grey regulator 0,8 A T + orange light grey N blue – Description Item No. Pack. Unit Item No. Pack. Unit Power supply, with universal mounting carrier 288-809 1 288-810 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Power consumption at nominal load Nominal output voltage Vo nom Output voltage range Output current Io Residual ripple Output fuse Ambient operating temperature Weight Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier 115 V AC ± 10 % 50 Hz ... 60 Hz 30 VA 24 V DC ±4% 0.5 A  10 mVss 0.8 A slow 0 °C ... +50 °C 579 g 77 x 52 x 106 Height from upper-edge of DIN 35 rail CAGE CLAMP® (236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in Transformer acc. to VDE 0551 230 V AC ± 10 % 50 Hz ... 60 Hz 30 VA 24 V DC ±4% 0.5 A  10 mVss 0.8 A slow 0 °C ... +50 °C 552 g 77 x 52 x 106 Height from upper-edge of DIN 35 rail CAGE CLAMP® (236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in Transformer acc. to VDE 0551 see page 323 white 709-198 / translucent 709-196 see page 323 white 709-198 / translucent 709-196 4 261 230 V AC / 12 V DC; 0.5 A Output voltage indication by LED 115 V AC / 24 V DC; 2 A Output voltage indication by LED Mounting carrier for DIN 35 rail Mounting carrier for DIN 35 rail 0,5 A MT L grey regulator 0,8 A T L + orange light grey N blue – + grey regulator light grey N orange blue – Description Item No. Pack. Unit Item No. Pack. Unit Power supply, with universal mounting carrier 288-808 1 288-813 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Power consumption at nominal load Nominal output voltage Vo nom Output voltage range Output current Io Residual ripple Input fuse Output fuse Short-circuit current Ambient operating temperature Weight Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier 230 V AC ± 10 % 50 Hz ... 60 Hz 23 VA 12 V DC ±4% 0.5 A  10 mVss 0 °C ... +50 °C 574 g 77 x 52 x 106 Height from upper-edge of DIN 35 rail CAGE CLAMP® (236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in Transformer acc. to VDE 0551 115 V AC ± 10 % 50 Hz ... 60 Hz 80 VA 24 V DC ± 10 % 2A  80 mVss 0.8 A medium-slow electronic, short-circuit protected 2.5 A 0 °C ... +40 °C 1969 g 182 x 98 x 106 Height from upper-edge of DIN 35 rail CAGE CLAMP® (256 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in Transformer acc. to VDE 0551 see page 323 white 709-198 / translucent 709-196 see page 323 white 709-198 / translucent 709-196 0.8 A slow 4 4 Rail-Mounted Modules - Power Supplies 262 230 V AC / 24 V DC; 2 A Output voltage indication by LED 230 V AC / ± 12 V DC; 0.5 A 230 V AC / ± 15 V DC; 0.5 A Output voltage indication by LED Mounting carrier for DIN 35 rail Mounting carrier for DIN 35 rail 0,5 A MT L L + regulator light grey N + orange orange blue – Description Item No. Pack. Unit Power supply, with universal mounting carrier 288-812 1 T grey regulator grey light grey N blue regulator – dark grey Item No. Pack. Unit 288-814 288-815 1 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Power consumption at nominal load Nominal output voltage Vo nom Output voltage range Output current Io Residual ripple Input fuse Output fuse Short-circuit current Ambient operating temperature Weight Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier 230 V AC ± 10 % 50 Hz ... 60 Hz 80 VA 24 V DC ± 10 % 2A  80 mVss 0.5 A medium-slow electronic, short-circuit protected 2.5 A 0 °C ... +40 °C 1900 g 230 V AC ± 10 % 50 Hz ... 60 Hz 27 VA ± 12 V DC (288-814) ± 15 V DC (288-815) ±4% 2 x 0.5 A  10 mVss 2 x 0.8 A slow 182 x 98 x 106 Height from upper-edge of DIN 35 rail CAGE CLAMP® (256 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in Transformer acc. to VDE 0551 0 °C ... +40 °C 675 g (288-814) 665 g (288-815) 94 x 57 x 106 Height from upper-edge of DIN 35 rail CAGE CLAMP® (256 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in Transformer acc. to VDE 0551 see page 323 white 709-198 / translucent 709-196 see page 323 white 709-198 / translucent 709-196 4 263 230 V AC / ± 15 V DC; 2 x 1 A short-circuit proof Output voltage indication by LED Mounting carrier for DIN 35 rail L regulator grey + orange T light grey N blue regulator – dark grey Description Item No. Pack. Unit Power supply, with universal mounting carrier 288-816 1 Technical Data Nominal input voltage Vi nom Input voltage range Frequency Power consumption at nominal load Nominal output voltage Vo nom Output voltage range Output current Io Residual ripple Short-circuit current Ambient operating temperature Weight Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier 230 V AC ± 10 % 50 Hz ... 60 Hz 53 VA ± 15 V DC ±4% 2x1A  10 mVss approx. 1.5 A 0 °C ... +40 °C 1011 g 138 x 87 x 106 Height from upper-edge of DIN 35 rail CAGE CLAMP® (256 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in Transformer acc. to VDE 0551 see page 323 white 709-198 / translucent 709-196 4 4 Rail-Mounted Terminal Blocks with DC/DC Converter 264 DC/DC converter 24 V / 10 V, 0.5 A DC 56 mm/2.2 in DC/DC converter 24 V / 5 V, 0.5 A DC 91 mm/3.58 in Description VN / V O Item No. Pack. Unit VN / VO Item No. Pack. Unit DC/DC converter, for DIN 35 rail 24 V DC / 5 V DC ± 2 % 859-801 1 24 V DC / 10 V DC ± 2 % 859-802 1 Technical Data Nominal input voltage (VN) Input voltage range Output voltage Output current (max.) Line regulation, max. (full load, over input voltage range) Max. load regulation (no load to full load, nominal input Efficiency at full load (24 V DC in) Output noise peak-to-peak max. (20 MHz bandwidth) Switching frequency Isolation Reverse voltage protection, input Minimum load requirement Max. transient recovery time (recovery time for load change from 25 % to 75% of full load) Max. startup time (24 V DC in, full load) Max. hold time (nominal input voltage, full load) Input fuse Output short circuit protection Temperature coefficient Ambient operating temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 24 V DC 10 V ... 30 V DC 5 V DC ± 2 % 500 mA 2% 0.5 % 70 % 150 mV 200 kHz (nominal) non-isolated yes no 40 μs 24 V DC 15 V ... 30 V DC 10 V DC ± 2 % 500 mA 0.5 % 0.7 % 85 % 20 mV 200 kHz (nominal) non-isolated yes no 500 μs 3 ms 1 ms TVS diode temporary (short-circuit of the output for 1 minute without damage to the device) 70 ppm/°C 0 °C ... +40 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in 3 ms 500 μs TVS diode temporary (short-circuit of the output for 1 minute without damage to the device) 100 ppm/°C -25 °C ... +55 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in 4 265 DC/DC converter 24 V / 12 V, 0.5 A DC 56 mm/2.2 in DC/DC converter 12 V / 24 V, 250 mA DC 91 mm/3.58 in 4 Description VN / V O Item No. Pack. Unit VN / VO Item No. Pack. Unit DC/DC converter, for DIN 35 rail 12 V DC / 24 V DC ± 1 % 859-804 1 24 V DC / 12 V DC ± 2 % 859-805 1 Technical Data Nominal input voltage (VN) Input voltage range Output voltage Output current (max.) Line regulation, max. (full load, over input voltage range) Max. load regulation (no load to full load, nominal input Efficiency at full load (24 V DC in) Output noise peak-to-peak max. (20 MHz bandwidth) Switching frequency Isolation Reverse voltage protection, input Minimum load requirement Max. transient recovery time (recovery time for load change from 25 % to 75% of full load) Max. startup time (24 V DC in, full load) Max. hold time (nominal input voltage, full load) Input fuse Output short circuit protection Temperature coefficient Ambient operating temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths 12 V DC 8 V ... 16 V DC 24 V DC ± 1 % 250 mA 0.5 % 0.5 % 83 % 40 mV 1.2 MHz (nominal) non-isolated yes no 50 μs 24 V DC 15 V ... 30 V DC 12 V DC ± 2 % 500 mA 0.5 % 0.7 % 85 % 20 mV 200 kHz (nominal) non-isolated yes no 500 μs 8 ms 500 μs TVS diode fuse 3 ms 500 μs TVS diode temporary (short-circuit of the output for 1 minute without damage to the device) 100 ppm/°C -25 °C ... +55 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in 100 ppm/°C -25 °C ... +55 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in 4 Rail-Mounted Modules - DC/DC Converter IN + IN – OUT + OUT – 266 24 V / 24 V; 0.21 A DC 24 V / 18 V; 0.4 A DC Mounting feet for DIN 35 rail Mounting carrier for DIN 35 rail IN – IN – IN + OUT – OUT + OUT + IN + S OUT – 289-913 288-895 + DC 24V – + DC DC + DC 24V DC 24V – – + DC DC DC 18 V – Description Item No. Pack. Unit Item No. Pack. Unit DC/DC converter 289-913 1 288-895 1 Technical Data Input voltage Input voltage range Output voltage Nominal output current Peak output current Efficiency Test voltage input/output Short circuit protection Ambient operating temperature Weight Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths EMC 1-Immunity to interference EMC 1-Emission of interference Accessories WMB Multi marking system for mounting carrier Marker strips for mounting carrier 24 V DC ± 10 % 24 V DC (± 3 %) 210 mA 315 mA 65 % ... 75 % DC 500 V Thermal cut-out -25 °C ... +40 °C 77 g 83 x 25 x 77 Height from upper-edge of DIN 35 rail CAGE CLAMP® (236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in 24 V DC 18 V ... 36 V DC 18 V DC (± 1 %) 400 mA 82 % DC 1500 V permanent -25 °C ... +70 °C 75.9 g 50 x 25 x 85 Height from upper-edge of DIN 35 rail CAGE CLAMP® (256 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in acc. to EN 50082-2 (1996) * * Only in conjunction with DALI/DSI Master Module 750-641 acc. to EN 50081-1 (1993) * * Only in conjunction with DALI/DSI Master Module 750-641 see page 323 white 709-198 / translucent 709-196 4 267 4 5 268 WAGO Application: Lighting Control System, easyCredit Stadium in Nuremberg, Germany WAGO Products: WAGO-I/O-SYSTEM with ETHERNET Controllers, Power Supplies Units and Rail-Mounted Terminal Blocks 5 Overvoltage Protection 269 5 792 Series Rail-Mounted Terminal Blocks with Overvoltage Protection Accessories, 792 Series 270 – 272 273 280/870 Series Rail-Mounted Terminal Blocks with Overvoltage Protection 274 – 277 286 Series Pluggable Modules - Surge Suppression Devices Pluggable Modules - Surge Suppression Devices 278 – 279 280 – 283 5 5 Rail-Mounted Terminal Blocks with Overvoltage Protection 270 Overvoltage protection for information technology systems MD24 24 V DC; for protection of balanced interfaces (line/line) with electrical isolation (telecommunications) 56 mm/2.2 in Overvoltage protection for information technology systems ME24 24 V DC; for protection of 2 single lines (line/protected ground), unbalanced interfaces as well as RS-485 and RS-422 interfaces 91 mm/3.58 in 3 1 3 1 4 2 4 2 The coordination characteristics give information about the let-through energy of the overvoltage protector and the protection capacity. Description Nominal Voltage Item No. Pack. Unit Nominal Voltage Item No. Pack. Unit Overvoltage protection in terminal block, for DIN 35 Rail 24 V DC 792-800 1 24 V DC 792-801 1 Technical Data Nominal voltage Max. cont. operating voltage Nominal current Nominal discharge current ISN (8/20) μs Voltage protection level at IN category C2 Voltage protection level at 1 kV/μs category C3 Coordination characteristics Series impedance R / line Response time ta Limiting frequency Capacitance C Degree of protection Degree of protection with end and intermediate plate Operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 273 Accessories see page 273 DC 24 V 33 V DC / 23 V AC 0.5 A 5 kA per line ; 10 kA total  65 V (line/protected ground);  110 V (line/line)  45 V (line/protected ground);  90 V (line/line) X/1 1.8 ȍ  1 ns 6 MHz line/protected ground  1.0 nF (line/protected ground);  0.5 nF (line/line) IP00 IP20 -40 °C ... +80 °C -40 °C ... +80 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in IEC 61643-21 DC 24 V 33 V DC / 23 V AC 0.5 A 5 kA per line ; 10 kA total  50 V (line/line);  750 V (line/protected ground)  45 V (line/line);  650 V (line/protected ground) X/1 1.8 ȍ  100 ns (line/protected ground);  1 ns (line/line) 6 MHz line/protected ground  5 pF (line/protected ground);  1 nF (line/line) IP00 IP20 -40 °C ... +80 °C -40 °C ... +80 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in IEC 61643-21 5 271 Overvoltage protection for information technology systems MDEX24 24 V DC; for protection in intrinsically safe circuits 56 mm/2.2 in Overvoltage protection for information technology systems SD24 24 V DC; for protection of supply lines (power supply units) 91 mm/3.58 in 3 1 3 1 4 2 4 2 The coordination characteristics give information about the let-through energy of the overvoltage protector and the protection capacity. Description Nominal Voltage Item No. Pack. Unit Nominal Voltage Item No. Pack. Unit Overvoltage protection in terminal block, for DIN 35 Rail 24 V DC 792-802 1 24 V DC 792-803 1 5 Technical Data Nominal voltage Max. cont. operating voltage Max. Input voltage acc. to EN 50020 Ui Max. input current acc. to EN 50020 Ii Nominal current Nominal discharge current ISN (8/20) μs Voltage protection level at IN category C2 Voltage protection level at 1 kV/μs category C3 Coordination characteristics Series impedance R / line Response time ta Limiting frequency Capacitance C Degree of protection Degree of protection with end and intermediate plate Operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 273 Accessories see page 273 DC 24 V 33 V DC / 23 V AC DC 24 V 33 V DC / 23 V AC 30 V 0.5 A 0.5 A 5 kA per line ; 10 kA total  1500 V (line/protected ground);  50 V (line/line)  1400 V (line/protected ground);  45 V (line/line) X/1 1.8 ȍ  100 ns (line/protected ground);  1 ns (line/line) 6 MHz  6 pF (line/protected ground);  1 nF (line/line) IP00 IP20 -40 °C ... +80 °C -40 °C ... +80 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in IEC 61643-21 10 A 5 kA (line/protected ground); 300 A (line/line)  50 V (line/line);  750 V (line/protected ground)  45 V (line/line);  650 V (line/protected ground) X/1  100 ns (line/protected ground);  1 ns (line/line) 7 MHz  12 pF (line/protected ground);  1 nF (line/line) IP00 IP20 -40 °C ... +80 °C -40 °C ... +80 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in IEC 61643-21 5 Rail-Mounted Terminal Blocks with Overvoltage Protection 272 Overvoltage protection for information technology systems MDHF5 5 V DC; for protection of PROFIBUS networks 56 mm/2.2 in Overvoltage protection for information technology systems MD48LON 48 24 V DC; for protection of LON networks (FTT 10 or LPT 10) 91 mm/3.58 in 3 1 3 1 4 2 4 2 The coordination characteristics give information about the let-through energy of the overvoltage protector and the protection capacity. Description Nominal Voltage Item No. Pack. Unit Nominal Voltage Item No. Pack. Unit Overvoltage protection in terminal block, for DIN 35 Rail 48 V DC 792-804 1 5 V DC 792-805 1 Technical Data Nominal voltage Max. cont. operating voltage Nominal current Nominal discharge current ISN (8/20) μs Voltage protection level at IN category C2 Voltage protection level at 1 kV/μs category C3 Coordination characteristics Series impedance R / line Response time ta Limiting frequency Capacitance C Degree of protection Degree of protection with end and intermediate plate Operating temperature Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories see page 273 Accessories see page 273 DC 48 V 55 V DC / 38.5 V AC 1.7 A 5 kA per line ; 10 kA total  100 V (line/line);  750 V (line/protected ground)  70 V (line/line);  650 V (line/protected ground) X/1 0.4 ȍ  100 ns (line/lineound);  1 ns (line/protected ground) 10 MHz  0.6 pF (line/protected ground);  10 pF (line/line) IP00 IP20 -40 °C ... +80 °C -40 °C ... +80 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in IEC 61643-21 DC 5 V 6 V DC / 4.2 V AC 0.1 A 5 kA per line ; 10 kA total  27 V (line/line);  50 V (line/protected ground)  14 V (line/line);  14 V (line/protected ground) X/1 1ȍ  1 ns 250 MHz / 180 MHz line/protected ground  16 pF (line/protected ground);  19 pF (line/line) IP00 IP20 -40 °C ... +80 °C -40 °C ... +80 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 5 ... 6 mm / 0.22 in IEC 61131-3 5 Accessories, 792 Series 273 Operating tool Wire connection Marking pen with fibre tip Test pin End and intermediate plate Description Item No. Pack. Unit End and intermediate plate; 1 mm / 0.039 in thick, gray Test pin; Ø 1 mm / 0.039 in; test wire for sold. onto test plug Marking pen Operating tool, with partially insulated shaft 859-525 859-500 210-110 210-720 100 (4x25) 1 (1x1) 1 1 Item No. Pack. Unit 859-402 859-403 859-404 859-405 859-406 859-407 859-408 859-409 859-410 ... /000-029 ... /000-005 ... /000-006 200 (8x25) 200 (8x25) 200 (8x25) 200 (8x25) 100 (4x25) 100 (4x25) 100 (4x25) 100 (4x25) 100 (4x25) Item No. Pack. Unit plain 248-501 5 cards 1 ...10 (10 x) 11 ... 20 (10x) 21 ... 30 (10x) 31 ... 40 (10x) 41 ... 50 (10 x) 1 ... 50 (2 x) K 1 ... K 10 (10 x) K 11 ... K 20 (10 x) K 100 (10 x) U 1 ... U 10 (10 x) U 11 ... U 20 (10 x) U 100 (10 x) 248-502 248-503 248-504 248-505 248-506 248-566 248-450 248-451 248-452 248-453 248-454 248-455 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards Push-in type jumper bar for permanent marking Type 2, blade (3.5 x 0.5) mm Commoning Description Push-in type jumper bars, light gray, insulated, 18 A Item no. suffix for colored push-in type jumper bars Miniature quick marking card 2-way 3-way 4-way 5-way 6-way 7-way 8-way 9-way 10-way yellow red blue Marking Description Miniature WSB Quick marking system Marking software and printer/plotter see Section 8 Marking 10 strips with 10 markers, white with black printing 5 5 Rail-Mounted Terminal Blocks with Overvoltage Protection 274 Terminal block width 5 mm/0.197 in Terminal block width 5 mm/0.197 in (_________ 58,5mm/2.30 in ________) With suppressor diode VBN AC/DC 24 V ... AC 230 V; ISN 11 A ... 122 A Rated current 20 A (_________ 58,5mm/2.30 in ________) With varistor VBN AC/DC 24 V ... 110/120 V; ISN 60 A ... 130 A Rated current 20 A Through terminal blocks with the same shape see Full Line Catalog Volume 1 Description VN Item No. Pack. Unit Terminal block with surge suppression device and direct connection to DIN 35 rail 24 V DC 48 V DC 60 V DC 115 V DC 24 VAC 110/120 VAC 280-502/281-609 280-502/281-610 280-502/281-611 280-502/281-612 280-502/281-613 280-502/281-614 50 50 50 50 50 50 VN Item No. Pack. Unit 24 V DC 48 V DC 60 V DC 115 V DC 24 VAC 110/120 VAC 230 VAC 280-502/281-602 280-502/281-603 280-502/281-604 280-502/281-605 280-502/281-606 280-502/281-607 280-502/281-608 50 50 50 50 50 50 50 Technical Data VN Max. Operating Voltage VB max. Nominal Discharge Current ISN Max. Surge Current IS max. Capacity Protection Level Terminal blocks with varistor 24 V DC 48 V DC 60 V DC 115 V DC 24 VAC 110/120 VAC 31 V DC 65 V DC 85 V DC 150 V DC 30 V AC 140 V AC 60 A 60 A 130 A 130 A 60 A 130 A 250 A 250 A 1.2 kA 1.2 kA 250 A 1.2 kA  1.25 nF  0.72 nF  0.48 nF  0.22 nF  1.05 nF  0.18 nF 77 V DC 135 V DC 165 V DC 300 V DC 93 V AC 360 V AC Terminal blocks with suppressor diode 24 V DC 48 V DC 60 V DC 115 V DC 24 VAC 110/120 VAC 230 VAC 30.8 V DC 58 V DC 77 V DC 136 V DC 28 V AC 133 V AC 253 V AC 122 A 59 A 44 A 25 A 86 A 18 A 11 A  1 nF  0.63 nF  0.55 nF  0.4 nF  0.8 nF  0.35 nF  0.36 nF 64 V DC 111 V DC 162 V DC 282 V DC 84 V AC 388 V AC 706 V AC Technical Data Wire connection Cross sections Stripped lengths CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 8 ... 9 mm / 0.33 in CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 8 ... 9 mm / 0.33 in Accessories Item No. Pack. Unit Item No. Pack. Unit 280-341 280-340 100 (4*25) 100 (4*25) 280-341 280-340 100 (4*25) 100 (4*25) End and Intermediate Plate, 2.5 mm/0.098 in thick orange gray orange gray 5 275 With suppressor diode VBN AC/DC 24 V ... AC 230 V; ISN 37 A ... 305 A Rated current 20 A Terminal block width 10 mm/0.394 in Terminal block width 10 mm/0.394 in (___ 39,5 mm/1.56 in ___) (___ 39,5 mm/1.56 in ___) With varistor VBN AC/DC 24 V ... AC 230 V; ISN 300 A ... 1 kA Rated current 20 A Description VN Item No. Pack. Unit VN Item No. Pack. Unit Terminal block with surge suppression device and direct connection to DIN 35 rail 24 V DC 48 V DC 60 V DC 115 V DC 24 V AC 110/120 V AC 230 V AC 280-502/281-582 280-502/281-583 280-502/281-584 280-502/281-585 280-502/281-586 280-502/281-587 280-502/281-588 25 25 25 25 25 25 25 24 V DC 48 V DC 60 V DC 115 V DC 24 V AC 110/120 V AC 230 V AC 280-502/281-589 280-502/281-590 280-502/281-591 280-502/281-592 280-502/281-593 280-502/281-594 280-502/281-595 25 25 25 25 25 25 25 Technical Data VN Max. Operating Voltage VB max. Nominal Discharge Current ISN Max. Surge Current IS max. Capacity Protection Level Terminal blocks with varistor andend plate 24 V DC 48 V DC 60 V DC 115 V DC 24 V AC 110/120 V AC 230 V AC 31 V DC 56 V DC 85 V DC 150 V DC 30 V AC 150 V AC 275 V AC 300 A 300 A 1 kA 1 kA 300 A 1 kA 1 kA 1 kA 1 kA 4.5 kA 4.5 kA 1 kA 4.5 kA 4.5 kA  4.6 nF  2.8 nF  1.7 nF  0.8 nF  3.5 nF  0.57 nF  0.32 nF 77 V DC 135 V DC 165 V DC 300 V DC 93 V AC 360 V AC 710 V AC Terminal blocks with varistor and end plate 24 V DC 48 V DC 60 V DC 115 V DC 24 V AC 110/120 V AC 230 V AC 28 V DC 53 V DC 70 V DC 128 V DC 26 V AC 133 V AC 253 V AC 305 A 162 A 123 A 68 A 258 A 46 A 37 A  2.7 nF  1.7 nF  1.35 nF  0.85 nF  2.4 nF  0.63 nF  0.4 nF 59 V DC 111 V DC 146 V DC 265 V DC 70 V AC 388 V AC 706 V AC Technical Data Wire connection Cross sections Stripped lengths CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 8 ... 9 mm / 0.33 in CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 8 ... 9 mm / 0.33 in 5 5 Rail-Mounted Terminal Blocks with Overvoltage Protection 276 With gas filled surge arrester VBN AC 24 V ... 230 V; ISN 5 kA Rated current 20 A Terminal block width 10 mm/0.394 in Terminal block width 10 mm/0.394 in (____ 40 mm/1.57 in ____) (___ 39,5 mm/1.56 in ___) With gas filled surge arrester VBN AC 24 V ... 230 V; ISN 5 kA Rated current 20 A Description VN Item No. Pack. Unit VN Item No. Pack. Unit Terminal block with surge suppression device and direct connection to DIN 35 rail 24 V AC/DC 110/120 V AC/DC 230 V AC/DC 280-503/281-579 280-503/281-580 280-503/281-581 25 25 25 24 V AC/DC 110/120 V AC/DC 230 V AC/DC 870-523/281-579 870-523/281-580 870-523/281-581 25 25 25 Technical Data Max. operating voltage VB max. Nominal discharge current ISN Capacity Protection level Wire connection Cross sections Stripped lengths 70 V AC/90 V DC 180 V AC/230 V DC 450 V AC/600 V DC 5 kA  2 pF 600 V AC 650 V AC 1100 V AC CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 8 ... 9 mm / 0.33 in 70 V AC/90 V DC 180 V AC/230 V DC 450 V AC/600 V DC 5 kA  2 pF 600 V AC 650 V AC 1100 V AC CAGE CLAMP® 0.08 mm² ... 2.5 mm² / 4 mm² "f" / AWG 28 ... 14 6 ... 7 mm / 0.26 in Accessories End and Intermediate Plate, 2 mm/0.079 in thick gray orange Item No. Pack. Unit 870-518 870-519 100 (4*25) 100 (4*25) 5 277 With suppressor diode VBN AC/DC 24 V ... AC 230 V; ISN 37 A ... 305 A Rated current 20 A Terminal block width 10 mm/0.394 in Terminal block width 10 mm/0.394 in (____ 40 mm/1.57 in ____) (____ 40 mm/1.57 in ____) With varistor VBN AC/DC 24 V ... AC 230 V; ISN 300 A ... 1 kA Rated current 20 A Description VN Item No. Pack. Unit VN Item No. Pack. Unit Terminal block with surge suppression device and direct connection to DIN 35 rail 24 V DC 48 V DC 60 V DC 115 V DC 24 V AC 110/120 V AC 230 V AC 870-523/281-582 870-523/281-583 870-523/281-584 870-523/281-585 870-523/281-586 870-523/281-587 870-523/281-588 25 25 25 25 25 25 25 24 V DC 48 V DC 60 V DC 115 V DC 24 V AC 110/120 V AC 230 V AC 870-523/281-589 870-523/281-590 870-523/281-591 870-523/281-592 870-523/281-593 870-523/281-594 870-523/281-595 25 25 25 25 25 25 25 Technical Data VN Max. Operating Voltage VB max. Nominal Discharge Current ISN Max. Surge Current IS max. Capacity Protection Level Terminal block with varistor 24 V DC 48 V DC 60 V DC 115 V DC 24 V AC 110/120 V AC 230 V AC 31 V DC 56 V DC 85 V DC 150 V DC 30 V AC 150 V AC 275 V AC 300 A 300 A 1 kA 1 kA 300 A 1 kA 1 kA 1 kA 1 kA 4.5 kA 4.5 kA 1 kA 4.5 kA 4.5 kA  4.6 nF  2.8 nF  1.7 nF  0.8 nF  3.5 nF  0.57 nF  0.32 nF 77 V DC 135 V DC 165 V DC 300 V DC 93 V AC 360 V AC 710 V AC Terminal block with suppressor diode 24 V DC 48 V DC 60 V DC 115 V DC 24 V AC 110/120 V AC 230 V AC 28 V DC 53 V DC 70 V DC 128 V DC 26 V AC 133 V AC 253 V AC 169 A 90 A 69 A 68 A 258 A 46 A 37 A  2.7 nF  1.7 nF  1.35 nF  0.85 nF  2.4 nF  0.63 nF  0.4 nF 59 V DC 111 V DC 146 V DC 265 V DC 70 V AC 388 V AC 706 V AC Technical Data Wire connection Cross sections Stripped lengths CAGE CLAMP® 0.08 mm² ... 2.5 mm² / 4 mm² "f" / AWG 28 ... 14 6 ... 7 mm / 0.26 in CAGE CLAMP® 0.08 mm² ... 2.5 mm² / 4 mm² "f" / AWG 28 ... 14 6 ... 7 mm / 0.26 in 5 5 Pluggable Modules - Surge Suppression Devices 278 Single stage suppression for 3-wire control, signal or power circuits No interruption of current flow when changing module 24 V AC/DC Single stage suppression for 3-wire control, signal or power circuits No interruption of current flow when changing module 110 V / 120 V AC; 230 V AC Module width 15 mm / 0.591 in Module width 15 mm / 0.591 in Note: For isolation measurements the ground (earth) contact at the transient suppression module must be disconnected. WSB marker card • Marking F; Item No.: 209-791 • Marking 1 ... 10; Item No.: 209-702 • Marking Lin, N, PE Lout, N, PE, Lin, N, PE; Item No.: 249-655 5 cards, each containing 10 strips with 10 markers LIN LOUT LIN LOUT N N N N PE PE PE PE UBN Item No. Pack. Unit 230 V AC 115 V AC 286-835 286-835/115-000 1 1 Description UBN Item No. Pack. Unit Surge suppression module 24 V AC/DC 286-836 1 Technical Data Nominal operating voltage VBN Operating voltage Nominal current Nominal discharge current between L/N and PE Nominal discharge current between L and N Max. surge current between L/N and PE Max. surge current between L and N Protection level between L/N and PE Protection level between L and N Response time between L/N and PE Response time between L and N Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Dimensions (mm) L x H x W incl. terminal block Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 24 V AC/DC 35 V AC / 45 V DC 10 A 300 A 300 A 1 kA 1 kA 700 V 100 V 1 μs 25 ns 250 V / 4 kV / 3 230 V AC; 115 V AC 275 V AC; 150 V AC 10 A 1 kA 1 kA 4.5 kA 4.5 kA 1,3 kV; 1 kV 700 V; 400 V 1 μs 25 ns 250 V / 4 kV / 3 -25 °C ... +85 °C 17 x 82.5 x 73 -25 °C ... +85 °C 17 x 82.5 x 73 5 279 Single stage suppression for 3-wire control, signal or power circuits No interruption of current flow when changing module with fault indication 110 V / 120 V AC Module width 15 mm / 0.591 in Single stage suppression for 3-wire control, signal or power circuits No interruption of current flow when changing module with fault indication 230 V AC Module width 15 mm / 0.591 in LIN LIN Note: For isolation measurements the ground (earth) contact at the transient suppression module must be disconnected. WSB marker card • Marking F; Item No.: 209-791 • Marking 1 ... 10; Item No.: 209-702 • Marking Lin, N, PE Lout, N, PE, Lin, N, PE; Item No.: 249-655 5 cards, each containing 10 strips with 10 markers LOUT ϑ ϑ LOUT ϑ N PE N PE N PE ϑ N PE Description UBN Item No. Pack. Unit UBN Item No. Pack. Unit Surge suppression module 230 V AC 286-838 1 115 V AC 286-838/115-000 1 5 Technical Data Nominal operating voltage VBN Operating voltage Nominal current Nominal discharge current between L/N and PE Nominal discharge current between L and N Max. surge current between L/N and PE Max. surge current between L and N Protection level between L/N and PE Protection level between L and N Response time between L/N and PE Response time between L and N Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Dimensions (mm) L x H x W incl. terminal block Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 230 V AC 300 V AC 10 A 1 kA 1 kA 2.5 kA 2.5 kA 1 kV 800 V 1 μs 25 ns 250 V / 4 kV / 3 115 V AC 150 V AC 10 A 1 kA 1 kA 2.5 kA 2.5 kA 800 V 400 V 1 μs 25 ns 250 V / 4 kV / 3 -25 °C ... +85 °C 17 x 82.5 x 73 -25 °C ... +85 °C 17 x 82.5 x 73 5 Pluggable Modules - Surge Suppression Devices 280 Three-stage suppression for 3-wire data, measuring and control circuits 12 V DC Module width 20 mm / 0.787 in Module width 20 mm / 0.787 in 82,5 mm / 3,25 in Three-stage suppression for 2-wire data, measuring and control circuits 24 V DC 50 mm / 1.97 in u 73 mm / 2.87 in v Note: For isolation measurements the ground (earth) contact at the transient suppression module must be disconnected. WSB marker card • Marking F; Item No.: 209-791 • Marking 1 ... 10; Item No.: 209-702 • Marking +/-; Item No.: 209-652 • Marking Lin, PE, PE, N, Lout, PE, PE, N; Item No.: 249-652 5 cards, each containing 10 strips with 10 markers + + U LIN LOUT PE PE N N B – – Description UBN Item No. Pack. Unit UBN Item No. Pack. Unit Surge suppression module 24 V DC 286-833 1 12 V DC 286-834 1 Technical Data Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 24 V DC 30 V DC 0.1 A 12 V DC 14 V DC 6A 1.5 kA Nominal operating voltage VBN Operating voltage Nominal current Nominal discharge current between L/N and PE Nominal discharge current between L and N Max. surge current between L/N and PE Max. surge current between L and N Protection level between L/N and PE Protection level between L and N Response time between L/N and PE Response time between L and N Through resistance / inductivity Ambient operating temperature 5 kA 1.5 kA 5 kA  22 V  59 V  10 ns  10 ns 20 mȍ / 2 x 7 μH -25 °C ... +85 °C Accessories Terminal block for pluggable modules, with 2conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in 50 mȍ / 14 μH -25 °C ... +85 °C Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 5 281 Two-stage suppression for 3-wire control, signal or power circuits 24 V AC/DC Module width 20 mm / 0.787 in Module width 20 mm / 0.787 in 82,5 mm / 3,25 in Three-stage suppression for 3-wire data, measuring and control circuits 24 V DC 50 mm / 1.97 in u 73 mm / 2.87 in v Note: For isolation measurements the ground (earth) contact at the transient suppression module must be disconnected. WSB marker card • Marking F; Item No.: 209-791 • Marking 1 ... 10; Item No.: 209-702 • Marking Lin, PE, PE, N, Lout, PE, PE, N; Item No.: 249-652 • Marking PE, N, Lin, PE, N, Lout; Item No.: 209-911 5 cards, each containing 10 strips with 10 markers LIN LOUT LIN LOUT PE PE N N N N PE PE Description UBN Item No. Pack. Unit UBN Item No. Pack. Unit Surge suppression module 24 V DC 286-834/024-000 1 24 V AC/DC 286-831 1 5 Technical Data Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 24 V DC 30 V DC 6A 1.5 kA 24 V AC/DC 30 V AC / 38 V DC 6A 200 A 1.5 kA 500 A 1.5 kA  93 V  93 V  25 ns  25 ns 25 mȍ / 2 x 7 μH 250 V / 4 kV / 3 Nominal operating voltage VBN Operating voltage Nominal current Nominal discharge current between L/N and PE Nominal discharge current between L and N Max. surge current between L/N and PE Max. surge current between L and N Protection level between L/N and PE Protection level between L and N Response time between L/N and PE Response time between L and N Through resistance / inductivity Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature 1.5 kA  59 V  10 ns 50 mȍ / 14 μH -25 °C ... +85 °C Accessories Terminal block for pluggable modules, with 2conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in -25 °C ... +85 °C Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 5 Pluggable Modules - Surge Suppression Devices 282 Two-stage suppression for 3-wire control, signal or power circuits with filter 115 V DC, 230 V DC, 110 V / 120 V AC, 230 V AC/DC Module width 20 mm / 0.787 in Module width 25 mm / 0.984 in 82,5 mm / 3,25 in Two-stage suppression for 3-wire control, signal or power circuits 24 V AC/DC 50 mm / 1.97 in u 73 mm / 2.87 in v Note: For isolation measurements the ground (earth) contact at the transient suppression module must be disconnected. WSB marker card • Marking F; Item No.: 209-791 • Marking 1 ... 10; Item No.: 209-702 • Marking PE, N, Lin, PE, N, Lout; Item No.: 209-911 5 cards, each containing 10 strips with 10 markers LIN LOUT LIN LOUT N N N N PE PE PE PE UBN Item No. Pack. Unit 115 V DC 110 V/120 V AC 230 V DC 230 V AC 286-844 286-843 286-841 286-842 1 1 1 1 Description UBN Item No. Pack. Unit Surge suppression module 24 V AC/DC 286-832 1 Technical Data Accessories see pages 138 ... 139 Accessories see pages 138 ... 139 24 V AC/DC 115 V DC; 110 V/120 V AC 230 V DC; 230 V AC 180 V DC; 140 V AC 320 V DC; 250 V AC 6A 600 A 600 A 1.5 kA 1.5 kA  900 V  650 V  1 μs  25 ns - / 2 x 0.8 mH 250 V / 4 kV / 3 Nominal operating voltage VBN Operating voltage AC 30 V / 38 V DC Nominal current Nominal discharge current between L/N and PE Nominal discharge current between L and N Max. surge current between L/N and PE Max. surge current between L and N Protection level between L/N and PE Protection level between L and N Response time between L/N and PE Response time between L and N Through resistance / inductivity Nominal voltage acc. to VDE 0110 Part 1/4.97, IEC 60664-1 Ambient operating temperature Insertion loss 6A 200 A 1.5 kA 500 A 1.5 kA  93 V  59 V  25 ns  5 ns 25 mȍ / 2 x 7 μH 250 V / 4 kV / 3 -25 °C ... +85 °C Accessories Terminal block for pluggable modules, with 2conductor terminal blocks, orange separator ➊ with 4-conductor terminal blocks, orange separator with 4-conductor terminal blocks, marker plate ➋ wire range 0.08 mm² ... 2.5 mm² / AWG 28 ... 14; stripped length 8 ... 9 mm / 0.33 in 22 mm / 0.866 in 22 mm / 0.866 in 25 mm / 0.984 in -25 °C ... +85 °C 20 dB ... 40 dB / 0.15 MHz ... 30 MHz Item No. Pack. Unit 280-638 280-628 280-764 1 1 1 27 mm / 1.063 in 27 mm / 1.063 in 30 mm / 1.181 in Item No. Pack. Unit 280-639 280-629 280-765 1 1 1 5 283 5 6 284 WAGO Application: Plastic Technology Center (SKZ) in Würzburg, Germany WAGO Products: WAGO-I/O-SYSTEM with ETHERNET Controllers, DALI and EnOcean Components 6 Wireless Technology 285 6 789 Series EnOcean Radio Receivers in DIN-Rail-Mount Enclosure 288 770 Series WINSTA® - Radio Receiver 289 758 Series Radio Receiver and Transmitter 290 6 6 286 WAGO Radio Receiver with EnOcean Technology The Benefits for Electronic and Radio Technology Process energy from (push-buttons, vibration, motion, heat, light…) Energy converter Sensors Radio connection: 30m in the building, 300m in open field Power Receiver Signal processing Interface or actuator Ultra low power prozessor and transmitter KNX LonWorks® ETHERNET Radio Receiver in I/O Module BACnet tFor the seamless integration of EnOcean technology into the WAGO-I/O-SYSTEM 750 tThe module can be used with any controller of the WAGO-I/O-SYSTEM 750. tPre-programmed function blocks make integration easy tThe number of sensors is almost illimited Item No. 750-642 6 Radio Transmitter 287 Radio transmitter integrated in universal switch insert. Radio Receiver in DIN-Rail Mount Enclosure The stand-alone solution for DIN-rail mounting: 4-channel radio receiver module in 70mm DIN-rail mount enclosure. Version 1: 4 make contacts, up to 16 A load carrying capacity Version 2: 4 changeover contacts, up to 8 A load carrying capacity per channel. Item No. 758-940/001-000 (2-channel light) 758-940/003-000 (4-channel light) 758-940/002-000 (2-channel roller blinds) 758-940/004-000 (4-channel roller blinds) Item No. 789-601 (make contacts) Item No. 789-602 (changeover contacts) 6 External Antenna Radio Receiver in WINSTA® Box All integrated: e.g. a complete blinds control (2-way sunblind outputs for 230V/2A) or a 4-channel module for lighting control (4-way switch output 230V/16A) with receiver and all required switching relay. The WINSTA® boxes are suitable for wall-, floor- and ceiling-mounting. Item No. 770-629/102-000 (sunblinds control) Item No. 770-629/101-000 (lighting control) The antenna fits to all WAGO products shown here and is connected using an SMA socket. The antenna has a magnetic stand and a 2.5m long coax cable. Item No. 758-910 6 4-Channel EnOcean Radio Receivers in DIN-Rail Mount Enclosure 288 4-channel EnOcean radio receiver with 4 make contacts, 16 A 4-channel EnOcean radio receiver with 4 changeover contacts, 8 A The 4-channel radio receiver in DIN-rail mount enclosure is used to switch 4 independent electrical devices or loads. The radio receiver processes telegrams transmitted by sensors (binary information) using EnOcean radio technology (PTM + STM modules). The outputs are switched via relay contacts. • Radio receiver for battery-less and wireless sensors • LED indication of switch status • External antenna for optimum transmission range (required) • Frequency band 868 MHz • Transmitter-to-receiver assignment via learn mode 24V DC + - 24V DC + - 4-channel radio receiver 4-channel radio receiver Us Us K1...K4 EnOcean Receiver K1...K4 LRN 13 ... 44 K1...K4 LRN ... 14 K1...K4 EnOcean Receiver ... 14 12 11 ... 44 42 41 43 Description Item No. Pack. unit Item No. Pack. unit 4-channel EnOcean radio receiver 789-601 1 789-602 1 Technical Data Voltage supply Voltage range Current consumption (internal) Number of receive channels Number of channels Output current (per channel) Type of load Switching frequency Delay time transmitter /output command Switching voltage Fuse protection Isolation Ambient operating temperature Storage temperature Relative air humidity (no condensation) Degree of pollution Degree of protection Mounting position Dimensions (mm) W x H x L Wire connection Cross sections Stripped lengths Approvals Accessories: RF magnetic antenna incl. 3m connecting cable with SMA connector 24 V DC -15 % ... + 20 % max. 90 mA 40 (10 per output) 4 (relay outputs) max. 16 A, AC1 resistive / lamp load max. < 5 Hz < 100 ms; 40 ms ... 70 ms typ. 230 V AC Loads: wire breaker, max.16 A potential free contacts 0 °C ... +55 °C -25 °C ... +85 °C 85 % 2 IP20 any 70 x 55 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in Vibration and shock resistance acc. to IEC 60068-2-6 and IEC 60068-2-27 758-910 24 V DC -15 % ... + 20 % max. 90 mA 40 (10 per output) 4 (relay outputs) max. 8 A, AC1 resistive / motor load max. < 5 Hz < 100 ms; 40 ms ... 70 ms typ. 230 V AC Loads: wire breaker, max.16 A potential free contacts 0 °C ... +55 °C -25 °C ... +85 °C 85 % 2 IP20 any 70 x 55 x 90 Height from upper-edge of DIN 35 rail CAGE CLAMP® (WAGO 236 Series) 0.08 mm² ... 2.5 mm² / AWG 28 ... 12 (THHN, THWN) 5 ... 6 mm / 0.22 in Vibration and shock resistance acc. to IEC 60068-2-6 and IEC 60068-2-27 758-910 6 WINSTA® Radio Receiver 289 • Radio receiver for battery-less and wireless sensors • LED indication of switch status • External antenna for optimum transmission range (required) • Frequency band 868 MHz • Transmitter-to-receiver assignment via learn mode • The state of outputs can be predefined for a power failure scenario • Wire connection using WINSTA connectors 166 145 6.2 9.6 1 The 4-channel radio receiver is used to switch 4 independent electrical devices. The 2-channel radio receiver has 2 sunblind outputs that can be controlled independently from each other. The radio receiver processes telegrams transmitted by switches using EnOcean radio technology (STM modules). The outputs are switched via relay contacts. 6 30 2-channel radio receiver with sunblind outputs 22 4-channel radio receiver with 4 make contacts 150 190 Illustration and block diagram for 770-629/101-000 L PE N K1...K4 EnOcean Receiver LRN A1...A4 WINSTA 4-channel radio receiver ... L PE N L PE N Description Item No. Pack. unit Item No. Pack. unit WINSTA® radio receiver 770-629/101-000 1 770-629/102-000 1 Technical Data Voltage supply Voltage range Current consumption (internal) Number of channels Output current (per channel) Total current Inrush current Type of load Switching frequency Isolation Fuse protection Ambient operating temperature Storage temperature Relative air humidity (no condensation) Degree of pollution Degree of protection Mounting position Dimensions (mm) W x H x L Type of mounting Approvals Accessories: RF magnetic antenna incl. 3m connecting cable with SMA connector Connection accessories WINSTA connectors 230 V AC, 50 Hz ... 60 Hz, max. 16 A ± 10 % max. 21 mA 4 max. 16 A / 4 A max. 16 A max. 120 A / 50 ms resistive / lamp load max. 5 Hz isolated internal voltage supply 2500 V impulse withstand voltage External, 16 A max. 0 °C ... +55 °C -25 °C ... +85 °C 85 % 2 IP20 any 195 x 145 x 30 Wall screw fixing Vibration and shock resistance acc. to IEC 60068-2-6 and IEC 60068-2-27 758-910 230 V AC, 50 Hz ... 60 Hz, max. 16 A ± 10 % max. 21 mA 2 2 A motor load max. 4 A 25 A resistive / inductive max. 5 Hz isolated internal voltage supply 2500 V impulse withstand voltage External, 16 A max. 0 °C ... +55 °C -25 °C ... +85 °C 85 % 2 IP20 any 195 x 145 x 30 Wall screw fixing Vibration and shock resistance acc. to IEC 60068-2-6 and IEC 60068-2-27 758-910 Input: socket, 3 poles, e.g. 770-103; 4-channel output: plug, 3 poles, e.g. 770-113 Input: socket, 3 poles, e.g. 770-103; 2-channel output: plug, 4 poles, e.g. 770-114 6 6 Radio Receiver and Transmitter 290 External antenna, GSM 900/1800 Description Technical Data Item No. Pack. unit External antenna Frequency band: 870 MHz ... 960 MHz; 1710 MHz ... 1880 MHz VSWR: 870 MHz ... 960 MHz < 1.5; 1710 MHz ... 1880 MHz < 1.5 Gain: 870 MHz ... 960 MHz 0 dB; 1710 MHz ... 1880 MHz 0 dB Max. Power: 20 W Cable length: 250 cm Connector: SMA right angle plug + ferrite bead 758-910 1 Notes on operating the antenna with WAGO EnOcean radio receivers: The antenna is to be mounted on a plate measuring at least 9.8 x 9.8 inches (25 x 25 mm) The distance of interfering sources to the antenna and antenna line must be at least 11.8 inches (30 mm) and the free space between the antenna and the next wall must be at least 13.78 inches (35 mm). The antenna cable should, under no circumstances, be bent sharply, since irreversible damage may result to the antenna (RG 174 bend radius > 0.6 inches/15mm) Radio transmitter, EnOcean easyfit PTM 250 Description Technical Data Item No. Pack. unit 2-channel light 4-channel light 2-channel roller blind 4-channel roller blind Integrated radio transmitter: EnOcean PTM 200 Energy harvesting source: electrodynamic energy generator, maintenance free Radio technology /range: EnOcean 868 MHz, RPS Type 2; 300 m free field, typ. 30 m within buildings Total installation height: 14 mm (frame lies directly against the wall) Dimensions of rocker /frame cut-out /central plate: 50 x 50 mm / 55 x 55 mm / 71 x 71 mm Color: white 758-940/001-000 758-940/003-000 758-940/002-000 758-940/004-000 1 1 10 1 The universal switch insert can be integrated into numerous control programmes by different manufacturers, e.g.: BERKER, GIRA, JUNG and MERTEN. Delivery is without frame. Frames of the desired control programm have been orderen separately. 6 291 6 7 292 WAGO Application: Bellinzona Business Center (Tessin), Switzerland WAGO Products: WAGO-I/O-SYSTEM with ETHERNET Controllers, Power Supplies and Interface Modules 7 Empty Housings and Mounting Carriers 293 7 280, 286, 786 Series Empty Component Plug Housings for Building Custom Circuits Empty Component Plug Housings for Building Custom Circuits 294 – 295 296 859 Series Empty Electronic Terminal Block Housing 297 789 Series DIN-Rail Mounted Enclosures Accessories, 789 Series 298 299 209, 210, 288 Series Mounting Carrier for DIN-Rail Mounting PCBs Mounting Carrier and Feet for DIN-Rail Mounting PCBs 300 – 301 302 – 303 7 7 Empty Component Plug Housings for Building Custom Circuits 294 286 Series, empty component plug Description Item No. Pack. Unit Empty component plug, type 9 4-pole, 10 mm / 0.394 in wide Empty component plug, type 10 6-pole, 15 mm / 0.591 in wide Empty component plug, type 11 8-pole, 20 mm / 0.787 in wide Empty component plug, type 12 10-pole, 25 mm / 0.984 in wide 250 V/ 4 KV/ 3 (rated voltage/ rated surge voltage/ pollution degree); 6 A per contact; Module height 82.5 mm/3.25 in (from upper-edge of DIN 35 rail); PCB dimensions and component height see drawing and table PCB dimensions 286-110 286-111 286-112 286-113 1 1 1 1 No components should be mounted in this area 15 20 25 9.2 14.2 19.2 13 18 23 Ø 1,3 > Ø 1,3 > A < < < A Introduce cover in the outer groove of the plug and press completely down until snap-fit engaged. > Press screwdriver into appropriate slot (1) and remove cover with levering action (2). >B< Typ 1 Typ 2,3,4 Typ A B 1 5 3,2 2 10 8,2 3 10 8,2 4 10 8,2 7 Empty Electronic Terminal Block Housing 297 859-110 859-501 859-110 and 859-501 Description Item No. Pack. Unit Technical Data Modular housing for mounting electronic components in a rail-mounted terminal block Frame to enlarge the terminal block width 859-110 1 Housing material: PA 6.6 859-501 1 Flammability rating: V0 Color: gray (similar to RAL 7038) Degree of protection: IP20 Perm. ambient temperature: -25 °C ... +70 °C Storage temperature: -40 °C ... +85 °C Width: 6 mm (859-110), 8 mm (859-501) Mounting position: any Dimensions (W x H x L): (6 x 56 x 91) mm Height from upper-edge of DIN 35 rail Wire connection: CAGE CLAMP® Cross sections: 0.08 mm2 ... 2.5 mm2 /AWG 28 ... 14 Stripped lenghts: 5 ... 6 mm / 0.22 in PCB dimensions PCB dimensions 13 4,6 > > 11 < > 12,7 < Description Item No. Pack. Unit Lateral cover, size 1, small, 6.35 mm /0.25 in thick Fixing foot for mounting on DIN 35 rails Track section, size 1, 1 m /3’3’’ long 288-601 288-602 288-600 1 1 1 In order to determine the length of a complete mounting carrier: Length of PCB: L1 Length of track section: L2 = L1 — 11 mm /0.433 in Length of mounting carrier: L3 = L1 + 1.7 mm/0.067 in with lateral cover size 1, 6.35 mm/0.25 in thick. Distance between PCB and upper groove of track section is 5 mm/0.197 in PCB tolerances: thickness 1.5 mm ± 0.2 mm, length/width ± 0.2 mm; -0.1/+0.3 for milling contours Marker strips Description Phillips screw 2.9 x 13* * To be used from a module length of 35 mm/1.378 in. For smaller modules the lateral covers have to be riveted. Rivet length depends on module length. Rivets not in the WAGO product range. 7.5x0.5mm on roll 5x1m, white 7.5x0.5mm on roll 5x1m, translucent Item No. Pack. Unit 210-533 25 709-198 709-196 1 1 Mounting carrier size 1 288-601 288-600 288-602 210-533 7 Mounting Carrier for DIN-Rail Mounting PCBs 301 Mounting carrier size 2 < 15,8 > Description Item No. Pack. Unit Lateral cover, size 2, small*, 8.75 mm /0.344 in thick Fixing foot for mounting on DIN 35 rails Track section, size 2, 1 m /3’3’’ long 288-621 288-622 288-620 1 1 1 Mounting carrier size 2, with covering section Abdeckprofil Description Item No. Pack. Unit Lateral cover, size 2, big* 8.75 mm /0.344 in thick Covering section, size 2, 1 m /3’3’’ long 288-626 288-627 1 1 In order to determine the length of a complete mounting carrier: Length of PCB: L1 Length of track section: L2 = L1 — 15,8 mm/0.622 in Length of mounting carrier: L3 = L1 + 1.7 mm/0.067 in Length of covering section: L4 = L1 with lateral cover, size 2, 8.75 mm/0.344 in thick Distance between PCB and upper groove of track section is 5 mm/0.197 in PCB tolerances: thickness 1.5 mm ± 0.2 mm, length/width ± 0.2 mm; -0.1/+0.3 for milling contours Mounting carrier size 2 288-621 288-620 288-622 210-533 7 7 Mounting Carrier and Feet for DIN-Rail Mounting PCBs 302 Sockelbefestigung mit Schraube (M 4) Positionsanschlag Ø 4 mm >3 (_15_) Description Pack. Unit 288-001 288-002 288-003 1 10 1 Item No. Pack. Unit 209-120 209-119 25 50 Universal mounting foot Universal mounting foot For screw-fixing or DIN-rail mounting with snap-fit type universal mounting feet (then needs 2 x mounting feet) Snap-fit type, suitable for DIN 15, 32 and 35 rails Suitable for Europa card (100 x 160) mm > 4,6 < Mounting carrier Item No. >3,2< > 6,4 < 0,6 > Distance 19 mm 27 mm 43 mm - 20 > 2< 0 - 10 > 4 < 3 < Description Shield (screen) camps Note: Not for ground connections! Hmax 40 mm, B 10 mm Hmax 47 mm, B 17 mm Hmax 63 mm, B 23 mm Hmax 78 mm, B 30 mm Diameter of Connectable Conductor Item No. Pack. Unit 1.5 mm/0.059 in to 6.5 mm/0.256 in 5 mm/0.197 in to 11 mm/0.434 in 10 mm/0.394 in to 17 mm/0.670 in 16 mm/0.631 in to 24 mm/0.946 in 791-107 791-111 791-117 791-124 50 50 50 50 8 Accessories for Shield (Screen) Clamping Saddles and Shield (Screen) Clamps 309 Carrier with grounding foot Description Item No. Pack. Unit Carrier with grounding foot bar 90° to the rail, 10 mm (0.394 in) x 3 mm (0.118 in), bar a. foot – Cu with tin plating, 45 mm/1.774 in long 790-113 25 bar parallel to the rail, 10 mm (0.394 in) x 3 mm (0.118 in), bar a. foot – Cu with tin plating, 15 mm/0.591 in long 790-110 25 Carrier with grounding foot Carrier with grounding foot bar parallel to the rail, 10 mm (0.394 in) x 3 mm (0.118 in), bar a. foot – Cu with tin plating, 25 mm/0.986 in long 790-112 25 Carrier with grounding foot bar parallel to the rail, 10 mm (0.394 in) x 3 mm (0.118 in), bar a. foot – Cu with tin plating, 45 mm/1.774 in long 790-114 25 bar parallel to the rail, 10 mm (0.394 in) x 3 mm (0.118 in), bar a. foot – Cu with tin plating, 125 mm/4.929 in long 790-115 25 Carrier with 2 grounding feet Suitable shield (screen) clamping saddle or shield (screen) clamps for carrier with grounding foot 790-110 = 790-108; Carrier with grounding foot 790-112 = 790-108, 790-116, 791-111, 791-117; Carrier with grounding foot 790-114 = 790-108, 790-116, 790-124, 790-140, 791-107, 791-111, 791-117, 791-124 Carrier rail Stand off Shield termination Description Carrier rail Stand off Shield termination including cable tie for shield diameter 5 mm /0.197 in to 10 mm /0.394 in Item No. Pack. Unit special slotted, 1000 mm/3’.3’’ long, Cu with tin plating, special lengths on request for special slotted carrier rail, use M 5 size screw 55 mm/2.169 in long 790-145 790-144 709-350 1 200 (2x100) 100 (4x25) 150 mm/ 5.914 in long 709-352 100 (4x25) Isolated mounting foot U-shaped busbar 4 > 15 6< Description 1000 mm/3’.3’’ long 30 mm/1.181 in long 50 mm/1.969 in long for busbar, with standard screw M 4 x 8 mm for busbar, with sheet metal screw (3.5 x 9) mm Dimensions (W x H x L) mm; 63 x 60 x 83 Dimensions (W x H x L) mm; 100 x 60 x 118 Dimensions (W x H x L) mm; 63 x 35 x 83 Dimensions (W x H x L) mm; 100 x 35 x 118 210-133 790-133 790-134 790-100 790-101 790-190 790-191 790-192 790-193 20 (20x1) 20 (20x1) 20 (20x1) 50 (2x25) 50 (2x25) 25 (5x5) 25 (25x1) 25 (5x5) 25 (25x1) 8 Busbar carrier, angulate Busbar carrier, angulate 24 36,6 Busbar carrier Pack. Unit 57,6 Isolated mounting foot Isolated mounting foot U-shaped busbar,10 mm (0.394 in) x 3 mm (0.118 in),Cu with tin plating Item No. 45 Straight busbar, 10 mm (0.394 in) x 3 mm (0.118 in), bar – Cu with tin plating >10 < Isolated mounting foot Straight busbar 70 10 10 70 101,3 101,3 Description Busbar carrier Busbar carrier, angulate for busbars, 10 mm (0.394 in) x 3 mm (0.118 in) – Cu with tin plating for busbars, 10 mm (0.394 in) x 3 mm (0.118 in) – Cu with tin plating Item No. Pack. Unit 790-300 790-301 10 10 8 310 ProServe Designing, Assembling and Marking 8 311 Int er fa ce M od ule 50 s 7 TEM SYS -I/O GO WA 8 The benefits of ProServe are at your disposal every day. With unique features such as accuracy checking, ProServe does a lot of the work for you, therefore saving you time and money. Immediate access to professional and sophisticated services allows for error-free applications, higher flexibility in your daily business and better customer service. With 50 years of WAGO expertise at your disposal, put ProServe to work for you in your next application. 8 ProServe Marking: Now Easier than Ever 312 Configuration and marking of rail assemblies and I/O nodes, stand-alone or in combination with CAE systems. smartMARKING t&YUFOTJWFJNQPSUGVODUJPOTGSPN$"&TZTUFNT  .40êDFBOE8"(0TNBSU%&4*(/&3 t8:4*8:(NBSLJOH t"VUPNBUJDQMPUUFSDBMJCSBUJPO t&YUFOTJWFMJCSBSZJODMVEJOHNBSLFSDBSSJFST t4ZNCPMMJCSBSZ t5FYUMFOHUIDIFDLJOH t%JéFSFOUMBOHVBHFTBWBJMBCMF t0VUQVUPG&BTU&VSPQFBODIBSBDUFST t'VMMZDPNQBUJCMFXJUI&(FOHSBWJOHVOJU t%JSFDUPVUQVUPOUIFSNBMUSBOTGFSQSJOUFS t$SFBUJPOPGDVTUPNNBSLFSTGPSUIF engraver/plotter smartMARKING 8 ProServe: Open for All 313 One for all: WAGO ProServe has an interface suitable for most of the standard CAD/CAE systems. C A E System Manufacturer Article master data Macros ASCII data to smartDESIGNER XML data to smartDESIGNER XML data from smartDESIGNER XML data from productLOCATOR Aucos Aucotec Aucotec Aucotec $*.5FBN Innotec &$4.V. &1-"/ Ige-xao 5$4 84$"% 8 8 ProServe: Planning at a New Level  WAGO ProServe means finding instead of searching, drawing instead of scribbling. ProServe navigates safely through the WAGO range of products, generates parts lists and assembly drawings and even 3D views. smartDESIGNER and productLOCATOR t9.-JOUFSGBDFTUP$"&BOE  .$"%QSPHSBNT t0VUQVUJO1%'BOE)5.t%JéFSFOUTFBSDIGVODUJPOTBMMPXGPS quick selection of products t$SFBUJPOPGQBSUMJTUTJODMVEJOH product pictures and custom part numbers t$PNQMFYSBJMBTTFNCMJFTDBOCF easily designed in 3D t'BDJMJUZUPDSFBUFDVTUPNQBSU numbers t$SFBUJPOPGDVTUPNBSUJDMFTUPEFTJHO third-party products product LO CA TO R smart DE SI G N ER t%FGBVMUQBSUT GBWPVSJUFT DBOCF defi ned individually for time saving design t*OUFMMJHFOU VTFSPQUJNJ[FEBDDVSBDZ check features tMBOHVBHFTBWBJMBCMF t JUFNT Marking: t%JSFDUDSFBUJPOBOEPVUQVUPGNBSLJOH data to plotter or thermal transfer printer 8 ProServe: Thinking in All Dimensions 315 Rail-mounted terminal blocks are becoming even more efficient and more complex: Multilevel as well as base receptacle terminal blocks with different conductor entry angles can no longer be represented by a simple view. The 3D view provides a clear representation during planning and assembly. Use our data in your system – now also online. DXF - Step - IGS - DWG CAD Benefi ts in overview: t2VJDLEFTJHO t$SFBUFZPVS%PS%$"%mMFTGSPN WAGO ProServe. Now also online! t2VJDLPSEFSJOH t6TFSGSJFOEMZ t&YUFOTJWFBOEVTFSTQFDJmD documentation t/FUXPSLDPNQBUJCJMJUZ t4FWFSBMTPGUXBSFQSPEVDUTPOBTJOHMF  $% TNBSU%&4*(/&3   QSPEVDU-0$"503 TNBSU."3,*/(  8"(04$3*15 t"QSJDFMJTUJTJODMVEFE …all for free! 8 8 316 Thermal Transfer Printers WAGO TP 343 and TP 298 Description Pack. Unit Item No. Description Item No. Pack. Unit 258-343 1 Thermal Transfer Printer TP 343 Resolution 300 dpi, incl. ProServe Software; for 2009 and 709 Series marking strips 258-298 1 Thermal Transfer Printer TP 298 Resolution 300 dpi, incl. ProServe Software and Print Roller (258-178) for WMB Inline and 2009 and 709 Series marking strips Technical Data Technical Data Printing method Printhead system Print resolution Print speed Print width Print length RAM memory Interfaces Thermal/thermal transfer Thin-film transfer head 300 dpi up to 76 mm/sec. 6 - 104 mm (0.25" - 4.09") up to 990 mm (39") 2 MB DRAM, 1 MB Flash Parallel Centronics (LPT), RS-232 (COM), USB, ETHERNET 10/100 Base T Label sensor (material end, foil end, bottom reflective sensor) 2 cardboard cores (104 mm) for ink ribbon rewinder Operating instructions in German and Englisch Universal power supply unit 100 V ... 240 V AC / 50 Hz ... 60 Hz 230 x 200 x 290 (Dimension with winder ca. 450 mm) Double-walled plastic 1000 g CE, FCC Class A, UL, CUL, TUV 1 x USB cable; 1 x ETHERNET cable; unwinder set; marking strips (1 x 2009-110); ink ribbon (1 x 258-145) Sensors Other Voltage supply Operating voltage Dimensions (mm) W x H x L Enclosure Weight Safety Approvals Accessories Printing method Printhead system Print resolution Print speed Print width See-through/reflective sensor Processor 32 Bit ColdFire/clock rate RAM memory Program memory Slot for memory card Interfaces Accessories (optional) Operating voltage Dimensions (mm) W x H x L Weight Operating temperature rel. humidity Safety Approvals Accessories Thermal/thermal transfer Thick-film 300 dpi 100 mm/sec. 108.4 mm standard 64 MHz 8 MB RAM 4 MB Flash CompactFlash Type 1 ETHERNET 10/100 Base T, RS-232 (COM), USB Cutter, external unwinder, external rewinder, memory card Compact Flash Type 16-512 MB 100 V ... 240 V AC / 50 Hz ... 60 Hz, PFC 242 x 274 x 446 10000 g 10 °C ... 35 °C 30 % ... 85 % CE, FCC class 1 1 x USB cable; 1 x serial cable; marking strips (1 x 2009-110); ink ribbon (1 x 258-149) Application table for ink ribbon/marking accessories/printer Item No. Width Ink Ribbon Marking Accessories Printer 258-143 60 mm resin/wax Labels (paper) all types 258-144 100 mm resin/wax Labels (paper) Wire Marking 211-155 / 211-156 all types 258-145 38 mm resin 258-149 50 mm resin 258-150 76 mm resin Cable Marking 211-111 and 211-121 Labels (polyester) up to 76 mm all types 258-157 100 mm resin Labels (polyester) up to 100 mm all types Marking Strip Series 2009 2009-xxx Marking Strip Series 709 709-xxx WMB Inline (not printable with TP 343) Marking Strip Series 2009 2009-xxx Marking Strip Series 709 709-xxx WMB Inline (not printable with TP 343) TP 298 & TP 343 TP 298+ 8 Accessories 317 Ink ribbon for labels Ink ribbon for marker strips Description Item No. Ink ribbon for labels resin/wax, width 60 mm x 300 m resin/wax, width 100 mm x 300 m resin, 38 mm x 300 m resin, 50 mm x 300 m 76 mm wide x 300 m 100 mm wide x 300 m Ink ribbon for marker strips and WMB Inline Ink ribbon for cable marking 258-143 258-144 258-145 258-149 258-150 258-157 All ink ribbons are suitable for TP 298 and TP 343 printers. For detailed ordering information, please refer to the "Application table for ink ribbon/marking accessories/printer" External coil mounting system Cutter TP 298 Spare roller TP 298 Description Item No. External coil mounting system Cutter TP 298 Spare roller TP 298 for labels Spare roller TP 298 for labels Spare roller TP 298 for WMB Inline Spare roller TP 298 for WMB Inline Carrying case for TP 298 Carrying case for TP 343 Retractable handle for carrying case TP 298 / TP 343 WMB Inline for WMB Inline 8,000 markers (2009-135) (up to item no. 40.000) (up to item no. 40.000) (up to item no. 40.000) (up to item no. 40.000) 258-169 258-161 258-162 258-177 258-166 258-178 258-171 258-342 258-173 Marking strips Description WMB Inline, pitch 4 mm, stretchable, 4 mm ... 4.2 mm, on reel WMB Inline, pitch 5 mm, stretchable, 5 mm ... 5.2 mm, on reel WMB Inline, pitch 5 mm, stretchable, 5 mm ... 5.2 mm, on reel Marking strips for TOPJOB®S Series, white, plain, 11 mm wide Marking strips for 870, 869, 862, 270 Series white, plain, 7.5 mm wide Marking strips for 870, 869, 862, 270 Series transparent, plain, 7.5 mm wide Item No. white, 2000 pieces white, 1500 pieces white, 8000 pieces 50 m coil 50 m coil 2009-114 2009-115 2009-135 2009-110 709-178 50 m coil 709-177 8 8 Accessories 318 Marker card Marker card (12 mm) for Plotter Labels on roll Labels on DIN A4 sheets Dimensions of self-laminating label Description Marker card for TT Printer Item No. 12 mm 23 mm 12 mm (258-370 Carrier Plates are required for plotting) 23 mm (258-370 Carrier Plates are required for plotting) 211-121 211-111 211-120 Marker surface "S"=8 mm, "B"=18 mm, "L"=35 mm for max. cable Ø 9 mm, 9.000 labels per roll Marker surface "S"=13 mm, "B"=23 mm, "L"=51 mm for max. cable Ø 12 mm, 5.000 labels per roll 211-155 Marker surface "S"=9 mm, "B"=17 mm, "L"=35 mm for max. cable Ø 8 mm, 70 labels per roll Marker surface "S"=13 mm, "B"=21 mm, "L"=56 mm for max. cable Ø 14 mm, 32 labels per roll 211-150 Marking sleeve 12 mm, for wire Ø 1.6 mm ... 3.2 mm or 0.25 mm² ... 1.5 mm² 2.2 mm ... 4.5 mm or 0.5 mm² ... 4 mm² 3.7 mm ... 5.9 mm or 2.5 mm² ... 6 mm² 4.8 mm ... 7.5 mm or 6 mm² ... 16 mm² 211-112 211-113 211-114 211-115 Marking sleeve 23 mm, for wire Ø 1.6 mm ... 3.2 mm or 0.25 mm² ... 1.5 mm² 2.2 mm ... 4.5 mm or 0.5 mm² ... 4 mm² 3.7 mm ... 5.9 mm or 2.5 mm² ... 6 mm² 4.8 mm ... 7.5 mm or 6 mm² ... 16 mm² 211-122 211-123 211-124 211-125 Marking sleeve for cable tie 23 mm, for wires from 10 mm² 211-129 Marker card for Plotter Labels on roll for thermal transfer printer Labels on DIN A4 sheets for laser printer (258-383 Carrier Plates are required for plotting) Cable tie (2.5 x 100) mm Label for I/O marking 211-110 211-156 211-151 807-090/101-100 211-211 Marking strips Receptacle for marking strips Plotter, 12 x 7 mm (258-371 Carrier Plates are required for plotting) 15 mm, white 50 m roll transp. 1 m long Continuous label 3 mm, white 12 lengths at 25 m 210-732 Label roll Label roll Label roll Label roll Label roll Label roll Label roll Label roll Label roll 70 x 100 mm, white 500 pieces/reel 70 x 100 mm, silver 500 pieces/reel 6 x 15 mm, white 3000 pieces/reel 6 x 15 mm, yellow 3000 pieces/reel 9 x 15 mm, white 3000 pieces/reel 9 x 15 mm, yellow 3000 pieces/reel 8 x 20 mm, white 3000 pieces/reel 8 x 20 mm, yellow 3000 pieces/reel 9.5 x 25 mm, white 3000 pieces/reel 210-703 210-704 210-705 210-705/000-002 210-706 210-706/000-002 210-707 210-707/000-002 210-708 210-701 709-120 8 319 8 8 320 Engraving Plotters with Engraver EG 450 Plotter IP 350 A3 / Plotter IP 350 A4 Description Item No. Pack. Unit Plotter IP 350 A3 incl. ProServe Software Plotter IP 350 A4 incl. ProServe Software 258-350 1 258-451 1 Technical Data Plot area Interfaces Language Data buffer Speed Drive system Pen storage unit Plotter pen Addressable resolution Repeatability (accuracy) Repeatability when changing the pen Voltage supply Operating voltage Voltage range Current consumption (internal) Dimensions (mm) W x H x L Weight Operating temperature rel. humidity Safety Approvals Immunity to interference Description Item No. EG 450 Engraver 258-450 as an extension of IP 350 Flat Plotter. Consisting of "EC 450" Control Unit and "VC 450" Vacuum Cleaner, including graver 0.3 mm + 0.4 mm Pack. Unit 1 Technical Data 440 mm x 305 mm (258-350) 220 mm x 305 mm (258-451) paralell (centronics); USB 1.1 based on HP-GL 7475A 16 MB max. 400 mm/sec. two phase stepper motor max. 4 pens with best possible sealing Special plotter pens with HP receptacle 0.01 mm 0.05 mm 0.05 mm using pens of best quality via separate desktop power supply unit equipped with exchangeable supply line 120 V ... 240 V AC / 50 Hz ... 60 Hz 90 V ... 264 V AC 0.3 A max. at 220 V AC 125 x 660 x 440 11069 g 10 °C ... 35 °C 35 % ... 75 % acc. to UL-UL1950 CSA-950/VDE EN60950 acc. to FCC Class B FCC Part 15 and VDE Class B EN 55022 1. Engraving spindle Speed Torque Frequency Energy consumption max. Collets Tensioning mechanism Run-out with collet Motor type Enclosure Clamping diameter Type of ball bearing Cooling system Field of application Operating time of bearing min. 5000 rpm, max. 50000 rpm 6 Ncm 83 Hz ... 830 Hz 60 W Diameter of mandrel 3 mm Head tension 0.03 mm three-phase, asynchronous, brushless Aluminium 25 mm Steel, permanent lubrication integrated fan exclusively engraving min. 1000 hrs if handled properly Notice: Never clean engraving spindle using compressed air, do not use lubricants when engraving. 2. Control unit VEB 500 Operating voltage 100 V ... 240 V AC / 50 Hz ... 60 Hz 3. Vacuum cleaner VC 500 Vacuum cleaner bag Typ Y98 General Specifications Dimensions (mm) W x H x L Weight 240 x 290 x 315 Control unit + Vacuum cleaner (an top of each other) Engraving spindle + Control unit + Vacuum cleaner + Accessories 8000 g 8 Accessories 321 Full plotter package Description Item No. Version 1 1 plotter incl. power supply and centronics cable; 1 ProServe Software; 258-350/000-001 4 WMB carrier plates 5 mm/0.197 in; 20 WMB marker cards 5 mm/0.197 in; 1 plotter pen, line width 0.25 mm disposable; 1 plotter pen, line width 0.35 mm disposable Version 2 1 plotter incl. power supply and centronics cable; 1 ProServe Software; 258-350/000-002 4 WSB carrier plates; 20 WSB marker cards; 1 plotter pen, line width 0.25 mm disposable; 1 plotter pen, line width 0.35 mm disposable Version 3 1 plotter incl. power supply and centronics cable; 1 ProServe Software; 258-350/000-003 2 WMB (5 mm/0.197 in) carrier plates; 2 miniature WSB carrier plates; 10 WMB (5 mm/0.197 in) marker cards; 10 miniature WSB marker cards; 1 plotter pen, line width 0.25 mm disposable; 1 plotter pen, line width 0.35 mm disposable Version 4 1 plotter incl. power supply and centronics cable; 1 ProServe Software; 258-350/000-004 1 WMB carrier plate 5 mm/0.197 in; 1 WSB carrier plate 5 mm/0.197 in; 1 miniature WSB carrier plate; 1 WSB carrier plate 4 mm/0.157 in; 5 WMB marker cards 5 mm/0.197 in; 5 WSB marker cards 5 mm/0.197 in; 5 miniature WSB marker cards; 5 WMB marker cards 4 mm/ 0.157 in; 1 plotter pen, line width 0.25 mm disposable; 1 plotter pen, line width 0.35 mm disposable Plotter is suitable for marking any type of WAGO marker card or competitor’s markers. Includes the ProServe DVD-ROM and WAGO smartMARKING software. WAGO plotter pen (disposable) 0.18 mm line width WAGO plotter pen (disposable) 0.25 mm line width WAGO plotter pen (disposable) 0.35 mm line width Description WAGO plotter pen WAGO ink cartridges WAGO plotter pen (disposable) Cover Service kit WAGO cleaning set WAGO pen cleaner Graver set Graver Service kit Item No. line width 0.18 mm/0.007 in line width 0.25 mm/0.010 in line width 0.35 mm/0.014 in line width 0.50 mm/0.020 in black, for permanent marking, not refillable (5 x 1 ml) 258-226 258-227 258-228 258-229 258-141 line width 0.18 mm/0.007 in line width 0.25 mm/0.010 in line width 0.35 mm/0.014 in 258-326 258-327 258-328 258-146 258-147 258-139 258-140 258-452 (4 alternative pen storage units) suitable for cleaning all EKS Pens line width 0.2/0.3/0.4/0.5/0.7/1.0 mm line width of graver 0.2 mm line width of graver 0.3 mm line width of graver 0.4 mm line width of graver 0.5 mm line width of graver 0.7 mm line width of graver 1.0 mm Vacuum cleaner bag for Engraver EG 450 WAGO plotter pens are suitable for any kind of smooth surfaces. No additional adapter is required. 258-452/000-002 258-452/000-003 258-452/000-004 258-452/000-005 258-452/000-007 258-452/000-010 258-457 8 8 322 Accessories Marker card carrier plates for plotter IP 350 Description Carrier plates for marker cards Carrier plates for murrplastik Carrier plates for Conta-Clip Carrier plates for Phoenix Universal Carrier plates Carrier plates for Weidmüller Carrier plates for Wörtz/Allen Bradley Carrier plates for Möller Carrier plates for Partex Carrier plates for ABB Entrelec Item No. WSB 5 mm/0.197 in (209-501) WSB 4 mm/0.157 in (209-701) Miniature WSB (248-501) Group marking carriers (209-112) T-marking strips (209-290) WCB (249-200) WTB (799-501) WMB 5/5.2 mm (793-5501); WMB 4/4.2 mm (793-4501) Marker tags (209-199 + 209-200) Marker strips (2009-110 + 2009-130 and 790-...) WMB-Inline (2009-115 + 2009-135) MP-400; KS 4/12, 4/18, 4/23, 4/30 MP-401; KES, KLG, KMR, KPX, KS 15x17/27/49/67, KSA, KSF, KSI, KSK, KSO, KSS, KTE, KWI, SKS, WGO, KAB BS 5/6 KPX KSEX; 10/500 KSEX; 18/500 Universal ZBM ZB ZBN ZBFM BNZ BN-ZB SS-ZB LBHZ PAB GPE DIN A4 DIN A3 MC Universal MC SF4-6 Universal XB M22-XST PA+1 PA+2 PK2 PVC PA+ 2 Universal Siemens SPS 258-361 258-362 258-363 258-364 258-365 258-366 258-367 258-368 258-369 258-410 258-412 258-370 258-371 258-397 258-396 258-470 258-471 258-398 258-372 258-373 258-374 258-375 258-377 258-378 258-379 258-380 258-381 258-382 258-383 258-472 258-387 258-388 258-389 258-390 258-391 258-392 258-393 258-399 258-394 258-473 8 Marking System 323 WMB Multi marking system Miniature quick marking card Colored marker cards Description WMB Inline Item No. Item No. Pack. Unit WMB Multi marking system for terminal block width 3.5 mm WMB Multi marking system for terminal block width 4 - 4.2 mm strechable 4 - 4.2 mm WMB Multi marking system for terminal block width 5 - 17.5 mm strechable 5 - 5.2 mm Miniature WSB quick marking system for terminal block width 5 - 17.5 mm plain 793-3501 5 cards plain 793-4501 5 cards plain plain 793-5501 248-501 5 cards 5 cards Additional item no. for colored marker cards yellow red blue gray orange light green green violet WMB Inline, pitch 4 mm, stretchable, 4 mm ... 4.2 mm, on reel WMB Inline, pitch 5 mm, stretchable, 5 mm ... 5.2 mm, on reel WMB Inline, pitch 5 mm, stretchable, 5 mm ... 5.2 mm, on reel white, 2000 pieces white, 1500 pieces white, 8000 pieces Separation of a strip from the WMB Marker card ➊ ➋ 2009-114 2009-115 2009-135 1 Coil 1 Coil Group marker carrier 209-112 to be on 788 Series relay sockets with pluggable miniature switching ➌ ➍ ➎ ➏ 8 Description Group marker carrier adjustable in height (43.5 mm ... 60 mm), for end stops 249-116 and 249-117 Group marker carrier Group marker carrier Marker card Protection cover 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards Stretching of a strip, stretchable from 4 mm up to 4.2 mm, stretchable from 5 mm up to 5.2 mm Group marker carrier adjustable in height Group marker carrier .../000-002 .../000-005 .../000-006 .../000-007 .../000-012 .../000-017 .../000-023 .../000-024 for 1 marker card or self-adhesive label and transparent cover protection for 2 WSB Quick markers or 1 x continuous marking strip with marker surface 41 mm/1.61 in, 6 mm/0.23 in wide for up to 3 WMB markers, 15 mm/0.591 in wide for snapping into screwless end stops, 10 mm/0.394 in wide from white cardboard, for self-marking, 100 markers per sheet transparent Item No. Pack. Unit 249-119 ➊ 249-118 ➋ 249-120 209-140 ➌ 209-112 ➍ 209-113 ➎ 209-114 ➏ 50 (2x25) 100 (4x25) 50 (2x25) 50 (2x25) 50 (1x50) 1 (1x1) 50 (1x50) 8 324 WAGO Wire and Cable Marking Wire marking The following marker cards are available: Marker cards for plotter marking ... ... or marker cards on roll for thermal transfer printing Slide the marker card into the marking sleeve receptacle. Changing the marking is also possible after the wire has been connected … or are supplied on roll for the thermal transfer printer Remove the printed label from the sheet or roll and wrap it around the wire or cable. The transparent laminate protects the marking Remove the rest of the card by twisting it off Fix the 211-129 marking sleeve using cable ties to individual wire or cable Cable marking Self-laminating labels are available on A4 sheets for the laser printer (plotter) … 8 WAGO Wire and Cable Marking 325 Marking sleeve 12 mm Marking sleeve 23 mm Marking sleeve 23 mm, for cable tie Description Marking sleeve* 12 mm, for wire Ø 1.6 mm ... 3.2 mm or 0.25 mm² ... 1.5 mm² 2.2 mm ... 4.5 mm or 0.5 mm² ... 4 mm² 3.7 mm ... 5.9 mm or 2.5 mm² ... 6 mm² 4.8 mm ... 7.5 mm or 6 mm² ... 16 mm² 1.6 mm ... 3.2 mm or 0.25 mm² ... 1.5 mm² 2.2 mm ... 4.5 mm or 0.5 mm² ... 4 mm² 3.7 mm ... 5.9 mm or 2.5 mm² ... 6 mm² 4.8 mm ... 7.5 mm or 6 mm² ... 16 mm² 23 mm, for wires from 10 mm² Marking sleeve* 23 mm, for wire Ø Marking sleeve* for cable tie Cable tie (2.5 x 100) mm Marker card Marker card (12 mm) for Plotter Marker card (23 mm) for Printer Marker card for TT Printer 23 mm Plotter, 23 mm (258-370 Carrier Plates are required for plotting) 12 mm Plotter, 12 mm (258-370 Carrier Plates are required for plotting) Labels on roll Labels on DIN A4 sheets Description Labels on roll for thermal transfer printer Labels on DIN A4 sheets for laser printer (258-383 Carrier Plates are required for plotting) Pack. Unit 211-112 211-113 211-114 211-115 211-122 211-123 211-124 211-125 211-129 2000 2000 1000 1000 2000 2000 1000 1000 1000 807-090/101-100 1000 Item No. Pack. Unit 211-111 211-110 1 18 211-121 211-120 1 30 Marker card (23 mm) for Plotter Description Marker card for TT Printer Item No. Marker surface "S"=8 mm, "B"=18 mm, "L"=35 mm for max. cable Ø 9 mm, 9.000 labels per roll Marker surface "S"=13 mm, "B"=23 mm, "L"=51 mm for max. cable Ø 12 mm, 5.000 labels per roll Marker surface "S"=9 mm, "B"=17 mm, "L"=35 mm for max. cable Ø 8 mm, 70 labels per roll Marker surface "S"=13 mm, "B"=21 mm, "L"=56 mm for max. cable Ø 14 mm, 32 labels per roll Dimensions of self-laminating label Item No. Pack. Unit 211-155 1 211-156 1 211-150 20 211-151 25 8 8 Carrier Rails and Angled Support Bracket 15 ° Pack. Unit 2000± 1,5 Item No. 1 (_15 _) 1 (_15_) 2,2- 2,5 _____> < 1,5 (_25_) 2000± 1,5 Item No. > < 5,2 Steel carrier rail acc. to EN 60715 > 7,5 < Steel carrier rail acc. to EN 60715 15 ° 326 Pack. Unit 2000± 1,5 Item No. Pack. Unit Steel rail, IN 125 A (referred to a length of 1 m) 35 x 15 mm, 1.5 mm/0.059 in thick, 2 m long, unslotted 210-114 10 Steel rail, IN 125 A (referred to a length of 1 m) 35 x 15 mm, 1.5 mm/0.059 in thick, 2 m long, slotted 210-197 10 Steel rail, IN 125 A (referred to a length of 1 m) 35 x 15 mm, 2.3 mm/0.091 in thick, 2 m long, unslotted 210-118 10 Copper carrier rail Aluminum carrier rail Angled support bracket 10 Item No. 2000± 1,5 Pack. Unit Aluminum carrier rail, IN 76 A (referred to a length of 1 m) 35 x 8.2 mm, 1.5 mm/0.059 in thick, 2 m long, unslotted 210-196 10 ° 35 Item No. Angled support bracket, without screw 210-148 Screw M 5 x 8 210-149 >18 < 1 Ø7 8,2 15 ° Pack. Unit 1,6 (_15_) 1 Item No. >< Copper carrier rail, IN 309 A (referred to a length of 1 m) 210-198 M5 > < >
209-120 价格&库存
很抱歉,暂时无法提供与“209-120”相匹配的价格&库存,您可以联系我们找货
    • 1+2.43012
    • 25+2.18702
    • 50+2.18592
    库存:2
