2216-1304
    WAGO(万可电子)
2216-1304 数据手册
Data sheet  |  Item number: 2216-1304 3-conductor through terminal block; with push-button; 16 mm²; with test port; suitable for Ex i applications; side and center marking; for DIN-rail 35 x 15 and 35 x 7.5; Push-in CAGE CLAMP®; 16,00 mm2; blue www.wago.com/2216-1304 Color: Item description Safety information 1: 15 mm high DIN-35 rails shall be used for a current load higher than 76 A! Data Electrical data Ratings per IEC/EN 60664-1 05.09.2019    Page 1/10 Data sheet  |  Item number: 2216-1304 www.wago.com/2216-1304 Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 800 V Rated impulse voltage (III / 3) 8 kV Rated current 76 A Rated current (2) 90 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Push-in Push-button Connectable conductor materials Copper Nominal cross section 16 mm² Solid conductor 0.5 … 16 mm² / 20 … 6 AWG Solid conductor, push-in termination 2.5 … 16 mm² / 14 … 6 AWG Fine-stranded conductor 0.5 … 25 mm² / 20 … 4 AWG Strip length 18 … 20 mm / 0.71 … 0.79 inch Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross section can also be inserted via push-in termination. Total number of connection points 3 Total number of potentials 1 Number of levels 1 Type of wiring Front-entry wiring Number of jumper slots 2 Geometrical Data Width 12 mm / 0.472 inch Height from upper-edge of DIN-35 rail 37.1 mm / 1.461 inch Depth 91.8 mm / 3.622 inch Mechanical data Design horizontal Type of mounting DIN-35 rail Marking level Center/side marking Material Data Color blue Insulating material Polyamide 66 (PA 66) Weight 32.179 g 05.09.2019    Page 2/10 Data sheet  |  Item number: 2216-1304 www.wago.com/2216-1304 Commercial data Country of origin DE GTIN 4055143732796 Customs Tariff No. 85369010000 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text Certificate name AEx Underwriters Laboratories Inc. UL 60079 E185892 ATEX Physikalisch Technische Bundesanstalt EN 60079-0 PTB 18 ATEX 1009 U IECEx Physikalisch Technische Bundesanstalt IEC 60079 IECEx PTB 18.0016U (Ex eb IIC Gb and EX eb I Mb) Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL 7669 CSA DEKRA Certification B.V. C22.2 70175032 KEMA/KEUR DEKRA Certification B.V. EN 60947 71102881 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping - 19HG1866350PDA DNV GL - TAE00003JT 05.09.2019    Page 3/10 Data sheet  |  Item number: 2216-1304 www.wago.com/2216-1304 DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00003JT LR Lloyds Register - 19/20050 Approval Additional Approval Text Certificate name cURus Underwriters Laboratories Inc. C22.2 No. 158 4788362287 UL-Approvals Logo Compatible products Carrier rail Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm www.wago.com/210-112 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715 www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm www.wago.com/210-115 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-118 Item no.: 210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silvercolored www.wago.com/210-196 Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715 www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 End plate 05.09.2019    Page 4/10 Data sheet  |  Item number: 2216-1304 www.wago.com/2216-1304 End plate Item no.: 2016-1391 End and intermediate plate; 1 mm thick; gray www.wago.com/2016-1391 Item no.: 2016-1392 End and intermediate plate; 1 mm thick; orange www.wago.com/2016-1392 Item no.: 210-721 Operating tool; Blade: 5.5 x 0.8 mm; with a partially insulated shaft www.wago.com/210-721 Item no.: 2009-174 Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray www.wago.com/2009-174 Item no.: 2009-182 Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray www.wago.com/2009-182 Item no.: 2016-511 Modular TOPJOB®S connector; modular; for jumper contact slot; 1-pole; 16,00 mm2; gray www.wago.com/2016-511 Item no.: 2016-549 Spacer module; modular; e.g., for bridging commoned terminal blocks; gray www.wago.com/2016-549 tools check General accessories Item no.: 2016-100 Finger guard; touchproof cover protects unused conductor entries; yellow www.wago.com/2016-100 Item no.: 216-210 Ferrule; Sleeve for 16 mm² / AWG 6; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-210 Item no.: 216-284 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-284 Item no.: 216-286 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-286 Item no.: 216-287 Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-287 Item no.: 216-288 Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; yellow www.wago.com/216-288 Item no.: 216-289 Ferrule; Sleeve for 10 mm² / AWG 8; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; red www.wago.com/216-289 Item no.: 2016-402 Push-in type jumper bar; insulated; 2-way; Nominal current 76 A; light gray www.wago.com/2016-402 Item no.: 2016-403 Push-in type jumper bar; insulated; 3-way; Nominal current 76 A; light gray www.wago.com/2016-403 ferrule Jumper Item no.: 2016-404 Push-in type jumper bar; insulated; 4-way; Nominal current 76 A; light gray www.wago.com/2016-404 05.09.2019    Page 5/10 Data sheet  |  Item number: 2216-1304 www.wago.com/2216-1304 Item no.: 2016-404 Push-in type jumper bar; insulated; 4-way; Nominal current 76 A; light gray www.wago.com/2016-404 Item no.: 2016-405 Push-in type jumper bar; insulated; 5-way; Nominal current 76 A; light gray www.wago.com/2016-405 Item no.: 2016-405/011-000 Star point jumper; insulated; 3-way (1-3-5); IN = IN terminal block; light gray www.wago.com/2016-405 /011-000 Item no.: 2016-433 Push-in type jumper bar; insulated; from 1 to 3; Nominal current 76 A; light gray www.wago.com/2016-433 Item no.: 2016-434 Push-in type jumper bar; insulated; from 1 to 4; Nominal current 76 A; light gray www.wago.com/2016-434 Item no.: 2016-435 Push-in type jumper bar; insulated; from 1 to 5; Nominal current 76 A; light gray www.wago.com/2016-435 Item no.: 2016-499 Step-down jumper; insulated; from 16/10 mm² to 10/6/4/2.5 mm²; Nominal current 57 A; light gray www.wago.com/2016-499 Item no.: 210-123 Wire commoning chain; insulated; 50 connections www.wago.com/210-123 Item no.: 285-430 Step-down jumper; insulated; from 285-13x to 2010 and 2016 Series TOPJOB®S terminal blocks; Nominal current 90 A; gray www.wago.com/285-430 Marking accessories Item no.: 2009-110 Marking strips; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Item no.: 2009-115 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-115 /000-002 Item no.: 2009-115/000-006 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-007 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-115 /000-007 Item no.: 2009-115/000-012 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-115 /000-012 Item no.: 2009-115/000-017 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-115 /000-023 05.09.2019    Page 6/10 Data sheet  |  Item number: 2216-1304 www.wago.com/2216-1304 Item no.: 2009-115/000-024 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-115 /000-024 Item no.: 2009-145 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-145 Item no.: 2009-145/000-002 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-145 /000-002 Item no.: 2009-145/000-005 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-145 /000-005 Item no.: 2009-145/000-006 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-145 /000-006 Item no.: 2009-145/000-007 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-145 /000-007 Item no.: 2009-145/000-012 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-145 /000-012 Item no.: 2009-145/000-023 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-145 /000-023 Item no.: 2009-145/000-024 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-145 /000-024 Item no.: 2009-191 Group marker carrier www.wago.com/2009-191 Item no.: 2009-192 Group marker carrier www.wago.com/2009-192 Item no.: 2009-193 Group marker carrier www.wago.com/2009-193 Item no.: 2009-198 Adaptor www.wago.com/2009-198 Item no.: 248-501 Miniature WSB Quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card www.wago.com/248-501 Item no.: 248-501/000-002 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/248-501 /000-002 Item no.: 248-501/000-005 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 /000-005 Item no.: 248-501/000-006 www.wago.com/248-501 05.09.2019    Page 7/10 Data sheet  |  Item number: 2216-1304 www.wago.com/2216-1304 Item no.: 248-501/000-006 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 /000-006 Item no.: 248-501/000-007 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 /000-007 Item no.: 248-501/000-012 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 /000-012 Item no.: 248-501/000-017 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 /000-017 Item no.: 248-501/000-023 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 /000-023 Item no.: 248-501/000-024 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 /000-024 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-002 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-005 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-006 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-007 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-012 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-017 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-023 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-024 Item no.: 793-5501 05.09.2019    Page 8/10 Data sheet  |  Item number: 2216-1304 www.wago.com/2216-1304 Item no.: 793-5501 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snapon type; white Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-002 on type; yellow Item no.: 793-5501/000-005 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/793-5501 /000-005 Item no.: 793-5501/000-006 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/793-5501 /000-006 Item no.: 793-5501/000-007 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/793-5501 /000-007 Item no.: 793-5501/000-012 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/793-5501 /000-012 Item no.: 793-5501/000-017 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/793-5501 /000-017 Item no.: 793-5501/000-023 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/793-5501 /000-023 Item no.: 793-5501/000-024 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/793-5501 /000-024 Downloads Documentation Bid Text 2216-1304 docx 15.3 kB Download pdf 2.1 MB Download URL Download Additional Information Technical explanations Apr 3, 2019 CAD/CAE-Data CAD data EPLAN Download 05.09.2019    Page 9/10 Data sheet  |  Item number: 2216-1304 www.wago.com/2216-1304 EPLAN Data Portal Download   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 05.09.2019    Page 10/10
2216-1304 价格&库存
很抱歉,暂时无法提供与“2216-1304”相匹配的价格&库存,您可以联系我们找货
    • 20+20.85698
    库存:200
