231-105/008-000
231-105/008-000
    WAGO(万可电子)
    P=5mm
    接线端子 间距:5.00mm 1x5P
231-105/008-000 数据手册
Printview: Female connector; with snap-in mounting foot; 5-pole; pin spacing 5 mm / 0.197 in; codable; with 2 locking latches; Plate thickness 0.6x1.2 mm; Fixing holes 3.5 mm Ø - Item No.: 231-105/008-000 . Female connector; with snap-in mounting foot; 5-pole; pin spacing 5 mm / 0.197 in; codable; with 2 locking latches; Plate thickness 0.6x1.2 mm; Fixing holes 3.5 mm Ø Item No.: 231-105/008-000 . Female connector; with snap-in mounting foot; 5-pole; pin spacing 5 mm / 0.197 in; codable; with 2 locking latches; Plate thickness 0.6x1.2 mm; Fixing holes 3.5 mm Ø; with 209-137 mounting adapter also for DIN 35 rail; with coding finger; with latch . Marking . Business data Supplier WAGO Item no. 231-105/008-000 EAN 4044918338783 Content 1 Order amount 100 Customer item number . Notes Universal connection for all conductor typesEasy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuationIntegrated test portsCoding option available Technical data Miscellaneous No. of Poles 5 Total number of connection points 5 Total number of potentials 5 Color gray Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Female connector; with snap-in mounting foot; 5-pole; pin spacing 5 mm / 0.197 in; codable; with 2 locking latches; Plate thickness 0.6x1.2 mm; Fixing holes 3.5 mm Ø - Item No.: 231-105/008-000 Technical data Pollution degree (1) 2 Rated voltage EN (1) [V] 320 [V] Rated surge voltage (1) [kV] 4 [kV] Nominal current [A] 16 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 630 [V] Bemessungsstossspannung (2) [kV] 4 [kV] Nominal current (2) [A] 16 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 320 [V] Rated surge voltage (3) [kV] 4 [kV] Nominal current (3) [A] 16 [A] Connection technology (1) CAGE CLAMP® Conductor type (1) solid Cross section from (1) [mm²] 0.08 [mm²] Cross section up to (1) [mm²] 2.5 [mm²] Cross section from (1) [AWG] 28 [AWG] Cross section up to (1) [AWG] 12 [AWG] Conductor type (2) fine-stranded Cross section from (2) [mm²] 0.08 [mm²] Cross section up to (2) [mm²] 2.5 [mm²] Conductor type (3) fine-stranded (with insulated ferrule) Cross section from (3) [mm²] 0.25 [mm²] Cross section up to (3) [mm²] 1.5 [mm²] Conductor type (4) fine-stranded (with uninsulated ferrule) Cross section from (4) [mm²] 0.25 [mm²] Cross section up to (4) [mm²] 2.5 [mm²] Stripped length from (1) [mm] 8 [mm] Stripped length up to (1) [mm] 9 [mm] Strip length from [inch] [in] 0.31 [in] Strip length up to [inch] [in] 0.35 [in] Stripped length (1) [in] 0.33 [in] WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Female connector; with snap-in mounting foot; 5-pole; pin spacing 5 mm / 0.197 in; codable; with 2 locking latches; Plate thickness 0.6x1.2 mm; Fixing holes 3.5 mm Ø - Item No.: 231-105/008-000 Technical data Material group I Insulating material Polyamide 6.6 (PA 6.6) Flammability rating per UL 94 V0 Lower limit temperature -60 [C] [C] Upper temperature limit [C] 85 [C] Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Copper alloy Contact plating tin-plated Fire load [MJ] 0.136 [MJ] Weight [g] 9.27 [g] Width [mm] 26.5 [mm] Width [in] 1.043 [in] Height [mm] 14.3 [mm] Height [in] 0.563 [in] Length [mm] 26.5 [mm] Length [in] 1.043 [in] Pin spacing from [mm] 5 [mm] Pin spacing up to [mm] 5 [mm] Pin spacing from [in] 0.197 [in] Pin spacing up to [in] 0.2 [in] Approbation Item No. Registration Registration no. Voltage [V] Current [A] Cross section [mm², AWG] 231-105/008-000 ABS 04-HG469925/1PDA 400 16 5,0 231-105/008-000 BV 11915/A0 400 16 2,5 231-105/008-000 CCA 2160224.01 250 16 0.08-2.50 231-105/008-000 CCA 5764 250 16 0,08-2,5 231-105/008-000 CSA 154112-1466354 300 15 22-12 231-105/008-000 GL 17296-00HH 400 16 5,0 231-105/008-000 KEMA 2083746.02 250 16 0,08-2,5 231-105/008-000 KR HMB05880-EL003 250/400 12/16 2,5 231-105/008-000 LR 96/20035 16 5,0 400 WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Female connector; with snap-in mounting foot; 5-pole; pin spacing 5 mm / 0.197 in; codable; with 2 locking latches; Plate thickness 0.6x1.2 mm; Fixing holes 3.5 mm Ø - Item No.: 231-105/008-000 Approbation 231-105/008-000 RMR 11130002 400 16 5,0 231-105/008-000 UL E45171 600 15 28-12 231-105/008-000 UL E45172 300 15 22-12 Accessories Insulation stop Item no. Description Pack. unit (Sub Pack) 231-670 Insulation stop; 0.08-0.2 mm² / 0.2 mm² "s" 200 231-671 Insulation stop; 0.25 - 0.5 mm² 25 231-672 Insulation stop; 0.75 - 1 mm² 25 Jumper Item no. 231-902 Description Pack. unit (Sub Pack) Comb-style jumper bar; for 5 mm and 5.08 mm pin spacing; reduces conductor size to 1.5 25 mm² 231-903 Comb-style jumper bar; 3-way; suitable for 231 Series female connectors; with 5 mm pin 25 spacing; insulated 231-905 Comb-style jumper bar; 5-way; suitable for 231 Series female connectors; with 5 mm pin 25 spacing; insulated 231-907 Comb-style jumper bar; 7-way; suitable for 231 Series female connectors; with 5 mm pin 25 spacing; insulated 231-910 Comb-style jumper bar; 10-way; suitable for 231 Series female connectors; with 5 mm pin 25 spacing; insulated Strain relief Item no. 232-605 Description Pack. unit (Sub Pack) Snap-on type strain relief housing; consists of strain relief support and housing; 5-pole; 25 suitable for 5 mm pin spacing Finger guard Item no. 231-668 Description Pack. unit (Sub Pack) Lockout caps; for covering unused clamping units 100 WAGO Kontakttechnik GmbH & Co. KG 4 Printview: Female connector; with snap-in mounting foot; 5-pole; pin spacing 5 mm / 0.197 in; codable; with 2 locking latches; Plate thickness 0.6x1.2 mm; Fixing holes 3.5 mm Ø - Item No.: 231-105/008-000 Accessories General accessory Item no. Description Pack. unit (Sub Pack) 209-132 Operating tool; for connecting comb-style jumper bar; 2-way; of insulating material 1 210-136 Test plug; 2 mm Ø; with 500 mm cable 1 210-137 Test plug; 2.3 mm Ø; with 500 mm cable 1 210-199 Stickers for operating instructions; for multi connection system 100 210-657 Operating tool with partially insulated shaft; blade (3.5 x 0.5) mm; short; suitable for 260, 261, 1 262, 264, 270, 280, 281, 869, 870 and 880 Series 210-658 Operating tool with partially insulated shaft; blade (3.5 x 0.5) mm; short; angled; particularly 1 suitable for 280 Series actuator and sensor terminal blocks and also for Series 260, 261, 262, 264, 280, 281, 869, 870, 880, 2002, 210-720 Operating tool with partially insulated shaft; Type 2, blade (3.5 x 0.5) mm; suitable for 260, 1 261, 262, 264, 270, 280, 281, 290, 775, 776, 777, 769, 780, 781, 869, 870, 880, 2002, 2003, 2004, 2005 and 2022 Series 231-131 Push-button; for female and male connectors; loose 25 231-159 Operating tool; for male and female connectors with CAGE CLAMP®; of Series 231, 232, 25 721, 722, 723, 731, 732 231-231 Combination operating tool; for male and female connectors with CAGE CLAMP® 25 231-291 Operating tool; for male and female connectors with CAGE CLAMP®; loose 25 231-661 Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing 25 WAGO Kontakttechnik GmbH & Co. KG 5 Printview: Female connector; with snap-in mounting foot; 5-pole; pin spacing 5 mm / 0.197 in; codable; with 2 locking latches; Plate thickness 0.6x1.2 mm; Fixing holes 3.5 mm Ø - Item No.: 231-105/008-000 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 6 Printview: Female connector; with snap-in mounting foot; 5-pole; pin spacing 5 mm / 0.197 in; codable; with 2 locking latches; Plate thickness 0.6x1.2 mm; Fixing holes 3.5 mm Ø - Item No.: 231-105/008-000 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 7
231-105/008-000 价格&库存
很抱歉,暂时无法提供与“231-105/008-000”相匹配的价格&库存,您可以联系我们找货
  • 1+90.869261+11.77075
  • 10+64.4619210+8.35008
  • 25+56.9542725+7.37757
  • 50+52.3935250+6.78680
  • 100+48.69261100+6.30740
  • 250+44.91916250+5.81861
  • 500+42.75530500+5.53831
  • 1000+41.065371000+5.31940
库存:9
