Data sheet | Item number: 236-406
PCB terminal block; 2.5 mm²; Pin spacing 5/5.08 mm; 6-pole; CAGE CLAMP®;
commoning option; 2,50 mm²; gray
www.wago.com/236-406
Color:
L = (pole no. x pin spacing) + 2.3 mm
Item
description
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/11
Item description
PCB terminal strips with CAGE CLAMP® connection and screwdriver actuation
parallel or perpendicular to conductor entry
Versions with Ex approval
Mixed-color PCB terminal strips from factory
Operating tools for factory wiring
45° conductor entry angle permits a wide range of applications and wiring options
Set to metric or inch pin spacing by compressing PCB terminal strips or pulling them apart
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
250 V
Rated impulse voltage (III / 3)
4 kV
Rated voltage (III / 2)
320 V
Rated impulse voltage (III / 2)
4 kV
Rated voltage (II / 2)
630 V
Rated impulse voltage (II / 2)
4 kV
Rated current
24 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
15 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
15 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 2/11
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
Fine-stranded conductor with ferrule with plastic collar
0.25 … 1.5 mm²
Fine-stranded conductor with ferrule without plastic collar
0.25 … 1.5 mm²
Strip length
5 … 6 mm / 0.2 … 0.24 inch
Conductor entry angle to the PCB
45 °
No. of poles
6
Total number of connection points
6
Total number of potentials
6
Number of connection types
1
Number of levels
1
Note (conductor cross-section)
12 AWG: THHN, THWN
Geometrical Data
Pin spacing
5/5.08 mm / 0.197/0.2 inch
Width
32.3 mm / 1.272 inch
Height
17 mm / 0.669 inch
Height from the surface
13 mm / 0.512 inch
Depth
14 mm / 0.551 inch
Solder pin length
4 mm
Solder pin dimensions
0.7 x 0.7 mm
Drilled hole diameter (tolerance)
1.1(- … +0.1) mm
PCB contact
PCB contact
THT
Solder pin arrangement
over the entire terminal strip, in line
Number of solder pins per potential
2
Material Data
Color
gray
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability
class per UL94
Subject
to changes.
Hansastr. 27
32423 Minden
V0
29.12.2019 Page 3/11
Insulating material
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.076 MJ
Weight
5.4 g
Environmental Requirements
Limit temperature range
-60 … +105 °C
Commercial data
Product Group
4 (Printed Circuit)
Packaging type
BOX
Country of origin
CH
GTIN
4044918769693
Customs Tariff No.
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60998
NTR NL7195
CCA
EN 60947
2168090.01
CCA
EN 60947
NTR NL7109
CSA
C22.2 No. 158
1673957
UL-Approvals
Approval
Subject to changes.
Hansastr. 27
32423 Minden
Certificate
29.12.2019 Page 4/11
Approval
Certificate
name
UR
Underwriters Laboratories Inc.
UL 1059
E45172,
sec. 6
Logo
Compatible products
ferrule
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated
www.wago.com/216-101
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated
www.wago.com/216-104
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-123
www.wago.com/216-123
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-131
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-141
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-142
Item no.: 216-143
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/11
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-144
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-263
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/11
Item no.: 216-263
www.wago.com/216-263
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
www.wago.com/216-322
Item no.: 231-127
Testing plug module with contact stud; for 236 Series; Pin spacing 5 mm / 0.197 in; 2,50 mm²; gray
www.wago.com/231-127
Item no.: 231-128
Testing plug module with contact stud; Pin spacing 5.08 mm / 0.2 in; 2,50 mm²; orange
www.wago.com/231-128
check
Marking accessories
Item no.: 210-332/500-202
www.wago.com/210-332
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182
/500-202
mm; Horizontal marking; Self-adhesive; white
Item no.: 210-332/500-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length
182 mm; Horizontal marking; Self-adhesive; white
/500-204
Item no.: 210-332/500-205
Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182
/500-205
Item no.: 210-332/500-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length
/500-206
Item no.: 210-332/508-202
/508-202
Item no.: 210-332/508-204
/508-204
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/11
Item no.: 210-332/508-205
/508-205
Item no.: 210-332/508-206
/508-206
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short
www.wago.com/210-657
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short
www.wago.com/210-658
Item no.: 210-720
www.wago.com/210-720
Item no.: 236-332
Operating tool; natural
www.wago.com/236-332
Item no.: 236-335
Operating tool
www.wago.com/236-335
tools
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 236-406
CAE data
EPLAN Data Portal 236-406
Download
PCB Design
Symbol and Footprint 236-406
URL
Download
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 8/11
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Installation Notes
Inserting a conductor
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 9/11
Inserting a conductor via 3.5 mm
screwdriver.
screwdriver.
Screwdriver actuation parallel to conductor
entry.
Screwdriver actuation perpendicular to
conductor entry.
Inserting a conductor via operating tool.
Compared to standard screwdrivers, these
operating tools are far more convenient for
wiring PCB terminal strips at factory.
Assembly
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 10/11
PCB Terminal Strips placed behind each
other save space – staggering them by half
the pin spacing simplifies subsequent wiring
of the first row.
Assembly
Combining PCB terminal blocks with
different pin spacing.
Marking
Labeling via factory direct marking.
Labeling with self-adhesive marking strips.
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 11/11
