Data sheet | Item number: 2606-1101
PCB terminal block; lever; 6 mm²; Pin spacing 7.5 mm; 1-pole; Push-in CAGE
CLAMP®; 6,00 mm²; gray
www.wago.com/2606-1101
Color:
L = 10.35 mm
Item description
PCB terminal blocks with lever-actuated Push-in CAGE CLAMP® connection
Push-in termination of solid and ferruled conductors
Intuitive and tool-free operation
Several clamping units can be held open simultaneously – convenient for terminating multi-core cables
Testing can be performed both parallel and perpendicular to conductor entry
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
16.03.2021 Page 1/6
Data
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
800 V
Rated surge voltage (III/3)
8 kV
Rated voltage (III/2)
1000 V
Rated surge voltage (III/2)
8 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
8 kV
Rated current
41 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Ratings per UL
Approvals per
UL 1059
Ratings per CSA
Approvals per
CSA
Rated voltage CSA (Use Group B)
600 V
Rated current CSA (Use Group B)
31 A
Rated voltage CSA (Use Group C)
1000 V
Rated current CSA (Use Group C)
31 A
Connection data
Connection technology
Push-in CAGE CLAMP®
Actuation type
Lever
Solid conductor
0.2 … 10 mm² / 24 … 8 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 6 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 6 mm²
Fine-stranded conductor; with twin ferrule
0.25 … 2.5 mm²
Strip length
11 … 13 mm / 0.43 … 0.51 inch
Conductor connection direction to PCB
0 °
Pole No.
1
Total number of connection points
1
Hansastr. 27
32423 Minden
16.03.2021 Page 2/6
1
Total number of potentials
1
Number of connection types
1
Number of levels
1
Physical data
Pin spacing
7.5 mm / 0.295 inch
Width
10.35 mm / 0.407 inch
Height
28 mm / 1.102 inch
Height from the surface
24 mm / 0.945 inch
Depth
24.3 mm / 0.957 inch
Solder pin length
4 mm
Solder pin dimensions
1.5 x 1.2 mm
Drilled hole diameter with tolerance
2 (+0.1) mm
PCB contact
PCB Contact
THT
Solder pin arrangement
within the terminal block (in-line)
Number of solder pins per potential
1
Material data
Color
gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Color of actuator
orange
Weight
4.5 g
Environmental requirements
Limit temperature range
-60 … +105 °C
Hansastr. 27
32423 Minden
16.03.2021 Page 3/6
Commercial data
Packaging type
BOX
Country of origin
DE
GTIN
4055143586405
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 60947-7-4
NL-64739
CSA
C22.2
70146882
KEMA/KEUR
EN 60947-7-4
71113203
Approval
Certificate
name
cURus
Underwriters Laboratories Inc.
UL 1059
E45172
UL-Approvals
Logo
Compatible products
ferrule
Item no.: 216-108
Ferrule; Sleeve for 6 mm² / AWG 10; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-108
Item no.: 216-208
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-208
acc. to DIN 46228, Part 4/09.90; yellow
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-264
Hansastr. 27
32423 Minden
16.03.2021 Page 4/6
Item no.: 216-264
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-264
Item no.: 216-266
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-266
Item no.: 216-267
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-267
acc. to DIN 46228, Part 4/09.90; gray
Downloads
Documentation
Additional Information
Technical explanations
2019 Apr 3
pdf
2.0 MB
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 2606-1101
PCB Design
Symbol and Footprint 2606-1101
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Hansastr. 27
32423 Minden
16.03.2021 Page 5/6
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
CAE data
ZUKEN Portal 2606-1101
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2606-1101
PCB terminal block; lever; 6 mm²; Pin spacing 7.5 mm; 1-pole; Push-in CAGE CLAMP®;
6,00 mm²; gray
Installation Notes
Hansastr. 27
32423 Minden
16.03.2021 Page 6/6
很抱歉,暂时无法提供与“2606-1101”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+16.99920
- 10+14.42880
- 30+12.81960
