270-570
    WAGO(万可电子)
    4-Conductor sensor Terminal Block, with colored Conductor entries, 2.5 mm2, Cage Clamp
270-570 数据手册
Data sheet | Item number: 270-570 4-conductor sensor terminal block; with colored conductor entries; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/270-570 Color: Data Electrical data Ratings per IEC/EN Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.03.2021    Page 1/10 Data sheet | Item number: 270-570 www.wago.com/270-570 Ratings per IEC/EN Nominal voltage (III/3) 250 V Rated surge voltage (III/3) 4 kV Rated current 18 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Connection data Connection technology CAGE CLAMP® Actuation type Operating tool Connectable conductor materials Copper Solid conductor 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor 0.08 … 2.5 mm² / 28 … 12 AWG Note (conductor cross-section) 12 AWG: THHN, THWN Strip length 6 … 7 mm / 0.24 … 0.28 inch Total number of connection points 5 Total number of potentials 4 Number of levels 4 Wiring type Front-entry wiring Physical data Width 5 mm / 0.197 inch Height 83 mm / 3.268 inch Mechanical data Design horizontal type Mounting type DIN-35 rail Marking level Side marking Material data Color gray Fire load 0.201 MJ Weight 10.5 g Commercial data Product Group 1 (Rail Mounted Terminal Blocks) Packaging type BOX Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.03.2021    Page 2/10 Data sheet | Item number: 270-570 www.wago.com/270-570 Packaging type BOX Country of origin CN GTIN 4050821035305 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL 6828 CCA DEKRA Certification B.V. EN 60947 2143311.03 CSA DEKRA Certification B.V. C22.2 1565649 Approval Additional Approval Text UR Underwriters Laboratories Inc. UL 1059 UL-Approvals Logo Certificate name 20190731E45172 Required accessories End plate Item no.: 270-320 End and intermediate plate; 1 mm thick; for quadruple-deck terminal blocks; gray www.wago.com/270-320 Item no.: 270-322 End and intermediate plate; 1 mm thick; for quadruple-deck terminal blocks; orange www.wago.com/270-322 Compatible products Jumper Item no.: 270-409 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/270-409 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.03.2021    Page 3/10 Data sheet | Item number: 270-570 www.wago.com/270-570 Item no.: 270-409 Jumper; 9-way; silver-colored www.wago.com/270-409 Item no.: 270-417 Jumper; 17-way; silver-colored www.wago.com/270-417 Item no.: 270-480 Jumper; 80-way; silver-colored www.wago.com/270-480 Item no.: 870-402 Jumper; 2-way; insulated; light gray www.wago.com/870-402 Item no.: 870-403 Jumper; 3-way; insulated; light gray www.wago.com/870-403 Item no.: 870-404 Push-in type jumper bar; insulated; 4-way; Nominal current 18 A; light gray www.wago.com/870-404 Item no.: 870-405 Jumper; 5-way; insulated; light gray www.wago.com/870-405 Item no.: 870-405/011-000 Ready-made push-in type jumper bar; insulated; 3-way (1-3-5); Nominal current 18 A; light gray www.wago.com/870-405 /011-000 Item no.: 870-406 Jumper; 6-way; insulated; light gray www.wago.com/870-406 Item no.: 870-407 Jumper; 7-way; insulated; light gray www.wago.com/870-407 Item no.: 870-407/011-000 Ready-made push-in type jumper bar; insulated; 1-3-5-7; Nominal current 18 A; light gray www.wago.com/870-407 /011-000 Item no.: 870-408 Jumper; 8-way; insulated; light gray www.wago.com/870-408 Item no.: 870-409 Jumper; 9-way; insulated; light gray www.wago.com/870-409 Item no.: 870-409/011-000 Ready-made push-in type jumper bar; insulated; 1-3-5-7-9; Nominal current 18 A; light gray www.wago.com/870-409 /011-000 Marking accessories Item no.: 2009-110 Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Item no.: 2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-115 /000-002 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.03.2021    Page 4/10 Data sheet | Item number: 270-570 www.wago.com/270-570 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow /000-002 Item no.: 2009-115/000-006 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-007 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-115 /000-007 Item no.: 2009-115/000-012 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-115 /000-012 Item no.: 2009-115/000-017 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-115 /000-023 Item no.: 2009-115/000-024 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-115 /000-024 Item no.: 2009-145 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white Item no.: 2009-145/000-002 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-145 /000-002 Item no.: 2009-145/000-005 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-145 /000-005 Item no.: 2009-145/000-006 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006 Item no.: 2009-145/000-007 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007 Item no.: 2009-145/000-012 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-145 /000-012 Item no.: 2009-145/000-023 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-145 /000-023 Item no.: 2009-145/000-024 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.03.2021    Page 5/10 Data sheet | Item number: 270-570 www.wago.com/270-570 Item no.: 2009-145/000-024 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-145 /000-024 Item no.: 248-501 Miniature WSB Quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card www.wago.com/248-501 Item no.: 248-501/000-002 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/248-501 /000-002 Item no.: 248-501/000-005 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/248-501 /000-005 Item no.: 248-501/000-006 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/248-501 /000-006 Item no.: 248-501/000-007 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/248-501 /000-007 Item no.: 248-501/000-012 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/248-501 /000-012 Item no.: 248-501/000-017 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/248-501 /000-017 Item no.: 248-501/000-023 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/248-501 /000-023 Item no.: 248-501/000-024 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/248-501 /000-024 Item no.: 709-177 Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; translucent www.wago.com/709-177 Item no.: 709-178 Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; white www.wago.com/709-178 Item no.: 709-196 Marking strips; for laser printer; translucent www.wago.com/709-196 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/793-501 /000-002 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.03.2021    Page 6/10 Data sheet | Item number: 270-570 www.wago.com/270-570 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/793-501 /000-005 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/793-501 /000-006 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/793-501 /000-007 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/793-501 /000-012 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/793-501 /000-017 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/793-501 /000-023 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/793-501 /000-024 Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; white Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-002 type; yellow Item no.: 793-5501/000-005 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-005 type; red Item no.: 793-5501/000-006 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-006 type; blue Item no.: 793-5501/000-007 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-007 type; gray Item no.: 793-5501/000-012 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-012 type; orange Item no.: 793-5501/000-017 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.03.2021    Page 7/10 Data sheet | Item number: 270-570 www.wago.com/270-570 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; green /000-017 Item no.: 793-5501/000-023 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-023 type; light green Item no.: 793-5501/000-024 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-024 type; violet tools Item no.: 210-657 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured www.wago.com/210-657 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Insulation stop Item no.: 280-470 Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 5 pieces/strip; white www.wago.com/280-470 Item no.: 280-471 Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray www.wago.com/280-471 Item no.: 280-472 Insulation stop; 0.75 - 1 mm²; 5 pieces/strip www.wago.com/280-472 Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-121 Item no.: 216-122 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-122 Item no.: 216-123 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored www.wago.com/216-123 Item no.: 216-124 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-124 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored www.wago.com/216-131 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-221 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-221 Item no.: 216-222 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-222 ferrule Item no.: 216-223 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/216-223 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.03.2021    Page 8/10 Data sheet | Item number: 270-570 www.wago.com/270-570 Item no.: 216-223 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-223 Item no.: 216-224 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-224 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 Downloads Documentation Bid Text 270-570 2017 May 31 doc 24.6 kB Download 2019 Feb 19 xml 3.3 kB Download 2019 Apr 3 pdf 2.2 MB Download EPLAN Data Portal 270-570 URL Download WSCAD Universe 270-570 URL Download ZUKEN Portal 270-570 URL Download URL Download URL Download doc - Datei 270-570 X81 - Datei Additional Information Technical explanations CAD/CAE-Data CAE data CAD data 2D/3D Models 270-570 Environmental Product Compliance Compliance Search Environmental Product Compliance 270-570 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.03.2021    Page 9/10 Data sheet | Item number: 270-570 www.wago.com/270-570 Environmental Product Compliance 270-570 URL Download 4-conductor sensor terminal block; with colored conductor entries; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; gray Installation Notes Commoning Inserting a jumper. Commoning a supply voltage using uninsulated push-in type jumper bars, 2- to 9-way or 17-way (2 x 8 bits), depending on application. Commoning signal level voltage via insulated push-in type jumper bars (870 Series) – 2- to 9-way, depending on application. Sensor LED terminal blocks cannot be commoned! Marking Marking strip (Item No. 709‑196) Not suitable for LED terminal blocks! Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 16.03.2021    Page 10/10
270-570 价格&库存
很抱歉,暂时无法提供与“270-570”相匹配的价格&库存,您可以联系我们找货
