280-764
280-764
    WAGO(万可电子)
280-764 数据手册
Data sheet  |  Item number: 280-764 Terminal block for pluggable modules; 8-pole; with 4-conductor terminal blocks; with marker carrier; with orange separator; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/280-764 Color: Data Electrical data Rated continuous current 10 A Safety and protection: Rated voltage 400 V Rated surge voltage 6 kV Pollution degree 3 Connection data Total number of potentials 2 Number of connection types 4 Connection technology CAGE CLAMP® Solid conductor 0.08 … 2.5 mm² / 28 … 14 AWG Fine-stranded conductor 0.08 … 2.5 mm² / 28 … 14 AWG Strip length 8 … 9 mm / 0.31 … 0.35 inch Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 1/12 Data sheet  |  Item number: 280-764 www.wago.com/280-764 Strip length 8 … 9 mm / 0.31 … 0.35 inch Wiring type Front-entry wiring Geometrical Data Width 25 mm / 0.984 inch Height from upper-edge of DIN-rail 28 mm / 1.102 inch Depth 73 mm / 2.874 inch Mechanical data Mounting type DIN-35 rail Material Data Color gray Fire load 0.664 MJ Weight 36.2 g Commercial data Packaging type BOX Country of origin DE GTIN 4044918635707 Customs tariff number 85369010000 Counterpart Compatible products Marking accessories Item no.: 2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 2009-115/000-002 www.wago.com/2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow /000-002 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 2/12 Data sheet  |  Item number: 280-764 www.wago.com/280-764 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow /000-002 Item no.: 2009-115/000-006 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-007 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-115 /000-007 Item no.: 2009-115/000-012 www.wago.com/2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange /000-012 Item no.: 2009-115/000-017 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 www.wago.com/2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green /000-023 Item no.: 2009-115/000-024 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-115 /000-024 Item no.: 249-105 Group marker carrier; gray www.wago.com/249-105 Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap- www.wago.com/793-5501 on type; white Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-002 on type; yellow Item no.: 793-5501/000-005 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-005 on type; red Item no.: 793-5501/000-006 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-006 on type; blue Item no.: 793-5501/000-007 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-007 on type; gray Item no.: 793-5501/000-012 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-012 on type; orange Item no.: 793-5501/000-017 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/793-5501 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 3/12 Data sheet  |  Item number: 280-764 www.wago.com/280-764 Item no.: 793-5501/000-017 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap- /000-017 on type; green Item no.: 793-5501/000-023 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-023 on type; light green Item no.: 793-5501/000-024 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-024 on type; violet Carrier rail Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm www.wago.com/210-112 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715 www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm www.wago.com/210-115 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-118 Item no.: 210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silvercolored www.wago.com/210-196 Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715 www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715 www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715 www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715 www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715 www.wago.com/210-508 Protective Warning Marker Item no.: 280-415 Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow www.wago.com/280-415 tools Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 4/12 Data sheet  |  Item number: 280-764 www.wago.com/280-764 tools Item no.: 210-657 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short www.wago.com/210-657 Item no.: 210-658 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short www.wago.com/210-658 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft www.wago.com/210-720 Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated www.wago.com/216-101 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-104 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-104 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-203 Item no.: 216-204 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-204 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 ferrule General accessories Item no.: 286-110 Empty component plug housing; Type 9; 10 mm wide; 4-pole; gray www.wago.com/286-110 Item no.: 286-111 Empty component plug housing; Type 10; 15 mm wide; 6-pole; gray www.wago.com/286-111 Item no.: 286-112 Empty component plug housing; Type 11; 20 mm wide; 8-pole; gray www.wago.com/286-112 Item no.: 286-113 Empty component plug housing; Type 12; 25 mm wide; 10-pole; gray www.wago.com/286-113 Item no.: 286-304 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 5/12 Data sheet  |  Item number: 280-764 www.wago.com/280-764 Item no.: 286-304 Relay module; Nominal input voltage: 24 VDC; 1 changeover contact; Limiting continuous current: 7 A; Red status indicator; Module width: 15 mm; gray www.wago.com/286-304 Item no.: 286-304/004-000 Relay module; Nominal input voltage: 24 VDC; 1 changeover contact; Limiting continuous current: 7 A; Path; Red status indicator; Module width: 15 mm; gray www.wago.com/286-304 /004-000 Item no.: 286-307/004-000 www.wago.com/286-307 Relay module; Nominal input voltage: 110 VDC; 1 changeover contact; Limiting continuous current: 7 /004-000 A; Path; Red status indicator; Module width: 15 mm; gray Item no.: 286-312 Relay module; Relay with 2 changeover contacts (2u); gray www.wago.com/286-312 Item no.: 286-312/004-000 www.wago.com/286-312 Relay module; Nominal input voltage: 24 VDC; 2 changeover contacts; Limiting continuous current: 5 /004-000 A; Path; Red status indicator; Module width: 20 mm; gray Item no.: 286-316 Relay module; Nominal input voltage: 220 VDC; 2 changeover contacts; Limiting continuous current: 7 A; Red status indicator; Module width: 20 mm; gray www.wago.com/286-316 Item no.: 286-320 Relay module; Nominal input voltage: 24 VDC; 1 break and 1 make contact; Limiting continuous current: 6 A; Red status indicator; Module width: 20 mm; gray www.wago.com/286-320 Item no.: 286-320/004-000 www.wago.com/286-320 Relay module; Nominal input voltage: 24 VDC; 1 break and 1 make contact; Path; Red status indicator; /004-000 Module width: 20 mm; gray Item no.: 286-328 Relay module; Nominal input voltage: 24 VDC; 2 make contact; Limiting continuous current: 6 A; Red status indicator; Module width: 20 mm; gray www.wago.com/286-328 Item no.: 286-328/004-000 www.wago.com/286-328 Relay module; Nominal input voltage: 24 VDC; 2 make contact; Limiting continuous current: 6 A; Path; /004-000 Red status indicator; Module width: 20 mm; gray Item no.: 286-336/001-000 Relay module; Nominal input voltage: 24 VDC; 2 break and 2 make contacts; Red status indicator; Module width: 25 mm; gray www.wago.com/286-336 /001-000 Item no.: 286-344/004-000 www.wago.com/286-344 Relay module; Nominal input voltage: 24 VDC; 3 break contacts and 1 make contact; Path; Red status /004-000 indicator; Module width: 25 mm; gray Item no.: 286-352/004-000 Relay module; Nominal input voltage: 24 VDC; 4 make contacts; Limiting continuous current: 5 A; Path; Red status indicator; Module width: 25 mm; gray www.wago.com/286-352 /004-000 Item no.: 286-364 Relay module; Nominal input voltage: 24 VDC; 1 make contact; Limiting continuous current: 5 A; Red status indicator; Module width: 10 mm; gray www.wago.com/286-364 Item no.: 286-364/004-000 Relay module; Nominal input voltage: 24 VDC; 1 make contact; Path; Red status indicator; Module Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 6/12 Data sheet  |  Item number: 280-764 www.wago.com/280-764 Item no.: 286-364/004-000 Relay module; Nominal input voltage: 24 VDC; 1 make contact; Path; Red status indicator; Module width: 10 mm; gray www.wago.com/286-364 /004-000 Item no.: 286-368 Relay module; Nominal input voltage: 24 VDC; 1 break contact; Limiting continuous current: 5 A; Red status indicator; Module width: 10 mm; gray www.wago.com/286-368 Item no.: 286-368/004-000 Relay module; Nominal input voltage: 24 VDC; 1 break contact; Path; Red status indicator; Module width: 10 mm www.wago.com/286-368 /004-000 Item no.: 286-376 Relay module; Nominal input voltage: 24 VDC; 1 make contact; Limiting continuous current: 5 A; for switching higher DC loads; Red status indicator; Module width: 15 mm; gray www.wago.com/286-376 Item no.: 286-380 Bistable relay module; Nominal input voltage: 24 VDC; 1 changeover contact; Limiting continuous current: 6 A; Red status indicator; Module width: 15 mm; gray www.wago.com/286-380 Item no.: 286-381 Bistable relay module; Nominal input voltage: 24 VDC; 1 changeover contact; Limiting continuous current: 6 A; Red status indicator; Module width: 15 mm; gray www.wago.com/286-381 Item no.: 286-394/004-000 Relay module; Nominal input voltage: 24 VDC; 1 changeover contact; Path; Red status indicator; Module width: 15 mm; light gray www.wago.com/286-394 /004-000 Item no.: 286-427 Timer relay module; Nominal input voltage: 24 VDC; Limiting continuous current: 5 A; Pulse lengthening: 1 … 10 s; Red status indicator; Module width: 20 mm; gray www.wago.com/286-427 Item no.: 286-507 Relay module; Nominal input voltage: 115 VAC; 1 changeover contact; Limiting continuous current: 7 www.wago.com/286-507 A; Red status indicator; Module width: 15 mm; gray Item no.: 286-508 Relay module; Nominal input voltage: 230 VAC; 1 changeover contact; Limiting continuous current: 7 www.wago.com/286-508 A; Red status indicator; Module width: 15 mm; gray Item no.: 286-516 Relay module; Nominal input voltage: 230 VAC; 2 changeover contacts; Limiting continuous current: 7 A; Red status indicator; Module width: 15 mm; gray www.wago.com/286-516 Item no.: 286-573 Latching relay module; Nominal input voltage: 24 VDC; 1 changeover contact; Limiting continuous current: 6 A; Red status indicator; Module width: 15 mm www.wago.com/286-573 Item no.: 286-575 Latching relay module; Nominal input voltage: 24 VDC; 1 changeover contact; Limiting continuous current: 3 A; Path; Red status indicator; Module width: 22 mm www.wago.com/286-575 Item no.: 286-604/004-000 Timer relay module; Nominal input voltage: 24 VDC; Limiting continuous current: 6 A; On-delay: 10 … 100 s; Red status indicator; Module width: 20 mm; gray www.wago.com/286-604 /004-000 Item no.: 286-640 Timer relay module; Nominal input voltage: 24 VDC; Limiting continuous current: 6 A; Path; Multifunction/Multitime; Yellow status indicator; Module width: 6 mm; gray www.wago.com/286-640 Item no.: 286-640/004-000 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 7/12 Data sheet  |  Item number: 280-764 www.wago.com/280-764 Item no.: 286-640/004-000 Multifunction timing relay module; Relay with 1 changeover contact (1u); 4 time ranges; for railway operations; 4 functions; gray www.wago.com/286-640 /004-000 Item no.: 286-661 Current flow monitoring module; AC currents; adjustable; light gray www.wago.com/286-661 Item no.: 286-662 Current flow monitoring module; DC currents; Monitoring range: 0.4 A – 3.5 A; 1 make contact; light gray www.wago.com/286-662 Item no.: 286-664 Current flow monitoring module; AC currents; Monitoring range: 1 A – 10 A; 1 changeover contact; light gray www.wago.com/286-664 Item no.: 286-665 Current flow monitoring module; AC currents; Monitoring range: 1 A – 10 A; 1 changeover contact; light gray www.wago.com/286-665 Item no.: 286-721 Optocoupler module; Nominal input voltage: 24 VDC; Output voltage range: 15 … 30 VDC; Limiting continuous current: 5 A; 3-wire connection/low-side switching; Red status indicator; Module width: 15 mm; gray www.wago.com/286-721 Item no.: 286-723 Optocoupler module; Nominal input voltage: 24 VDC; Output voltage range: 15 … 30 VDC; Limiting continuous current: 4 A; 3-wire connection/high-side switching; Red status indicator; Module width: 15 mm; gray www.wago.com/286-723 Item no.: 286-725 Optocoupler module; Input AC/DC 10 V ... 30 V; Output DC 24 V/ 1 mA ... 0.5 A; negative switching; gray www.wago.com/286-725 Item no.: 286-742 S0 interface power supply; Input voltage: 230 VAC; S0 interface www.wago.com/286-742 Item no.: 286-752 Optocoupler module; Nominal input voltage: 24 VDC; Output voltage range: 20 … 30 VDC; Limiting continuous current: 0.5 A; 3-wire connection/high-side switching; Frequency: 25 kHz; Red status indicator; Module width: 15 mm; gray www.wago.com/286-752 Item no.: 286-752/002-000 Optocoupler module; Red status indicator; gray www.wago.com/286-752 /002-000 Item no.: 286-790 Optocoupler module; gray www.wago.com/286-790 Item no.: 286-791 Optocoupler module; Nominal input voltage: 24 VDC; Output voltage range: 20 … 60 VDC; Limiting continuous current: 0.1 A; 2-wire connection; Frequency: 3 kHz; Red status indicator; Module width: 10 mm; gray www.wago.com/286-791 Item no.: 286-792 Optocoupler module; Red status indicator; gray www.wago.com/286-792 Item no.: 286-794 Optocoupler module; Nominal input voltage: 24 VDC; Output voltage range: 20 … 60 VDC; Limiting continuous current: 0.1 A; 2-wire connection; Red status indicator; Module width: 10 mm; gray www.wago.com/286-794 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 8/12 Data sheet  |  Item number: 280-764 www.wago.com/280-764 continuous current: 0.1 A; 2-wire connection; Red status indicator; Module width: 10 mm; gray Item no.: 286-797 Optocoupler module; Red status indicator www.wago.com/286-797 Item no.: 286-803 Component module with diode; gray www.wago.com/286-803 Item no.: 286-805 Component module with diode; light gray www.wago.com/286-805 Item no.: 286-807 Component module with diode; with 7 pcs; Diode 1N4007; with common anode; light gray www.wago.com/286-807 Item no.: 286-809 Component module with diode; light gray www.wago.com/286-809 Item no.: 286-822 Component module with LED; Red LED; with common cathode www.wago.com/286-822 Item no.: 286-826 AND gate module with 6 inputs; light gray www.wago.com/286-826 Item no.: 286-830 Bridge rectifier module; Input voltage: 24 VAC; with varistor protective circuit; gray www.wago.com/286-830 Item no.: 286-831 Surge suppression module for signal technology; Nominal voltage: 24 VAC/DC; for 2 signal paths with common surge arrester; plugged on rail-mount terminal block, 15 mm wide; gray www.wago.com/286-831 Item no.: 286-832 Surge suppression module for signal technology; Nominal voltage: 24 VAC/DC; for 2 signal paths with common surge arrester; pluggable on rail-mount terminal block, 20 mm wide; gray www.wago.com/286-832 Item no.: 286-833 Surge suppression module for signal technology; Nominal voltage: 24 VDC; for 1 signal path; plugged www.wago.com/286-833 on rail-mount terminal block, 15 mm wide; gray Item no.: 286-834 Surge suppression module for signal technology; Nominal voltage: 12 VDC; for 2 signal paths with common surge arrester; pluggable on rail-mount terminal block, 20 mm wide; gray www.wago.com/286-834 Item no.: 286-834/024-000 Surge suppression module for signal technology; Nominal voltage: 24 VDC; for 2 signal paths with common surge arrester; pluggable on rail-mount terminal block, 15 mm wide; gray www.wago.com/286-834 /024-000 Item no.: 286-835 Surge suppression module for signal technology; Nominal voltage: 230 VAC; for 2 signal paths with common surge arrester; plugged on rail-mount terminal block, 15 mm wide www.wago.com/286-835 Item no.: 286-835/115-000 Surge suppression module for signal technology; Nominal voltage: 115 VAC; for 2 signal paths with common surge arrester; plugged on rail-mount terminal block, 15 mm wide; gray www.wago.com/286-835 /115-000 Item no.: 286-836 Surge suppression module for signal technology; Nominal voltage: 24 VAC/DC; for 2 signal paths with common surge arrester; plugged on rail-mount terminal block, 15 mm wide; gray www.wago.com/286-836 Item no.: 286-838 Surge suppression module for signal technology; Nominal voltage: 230 VAC; for 2 signal paths with Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/286-838 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 9/12 Data sheet  |  Item number: 280-764 www.wago.com/280-764 Surge suppression module for signal technology; Nominal voltage: 230 VAC; for 2 signal paths with common surge arrester; with visual indicator; gray www.wago.com/286-838 Item no.: 286-840 Bridge rectifier module; Input voltage: 250 VAC; with varistor protective circuit; gray www.wago.com/286-840 Item no.: 286-841 Surge suppression module for signal technology; Nominal voltage: 220 VDC; for 2 signal paths with common surge arrester; pluggable on rail-mount terminal block, 25 mm wide; gray www.wago.com/286-841 Item no.: 286-842 Surge suppression module for signal technology; Nominal voltage: 230 VAC; for 2 signal paths with common surge arrester; pluggable on rail-mount terminal block, 25 mm wide; gray www.wago.com/286-842 Item no.: 286-843 Surge suppression module for signal technology; Nominal voltage: 115 VAC; for 2 signal paths with common surge arrester; pluggable on rail-mount terminal block, 25 mm wide; gray www.wago.com/286-843 Item no.: 286-844 Surge suppression module for signal technology; for 2 signal paths with common surge arrester; pluggable on rail-mount terminal block, 25 mm wide; gray www.wago.com/286-844 Item no.: 286-890 Component module with fuse; for (5 x 20) mm microfuse; Nominal voltage: 24 VAC/DC; gray www.wago.com/286-890 Item no.: 286-891 Component module with fuse; for (5 x 20) mm microfuse; Nominal voltage: 230 VAC/DC; gray www.wago.com/286-891 Item no.: 286-895 Switching module; with changeover rocker switch; Switching voltage: 250 VAC; Switching current: 6 A; gray www.wago.com/286-895 Item no.: 286-896 Switching module; with momentary switch; Switching voltage: 250 VAC; Switching current: 6 A; gray www.wago.com/286-896 Item no.: 786-102 Empty component plug housing; Type 15; 20 mm wide; 8-pole; gray www.wago.com/786-102 Item no.: 210-103 Wire commoning chain; insulated; black www.wago.com/210-103 Item no.: 210-123 Wire commoning chain; insulated; blue www.wago.com/210-123 Item no.: 280-482 Jumper; 2-way; insulated; gray www.wago.com/280-482 Item no.: 280-483 Jumper; 3-way; insulated; gray www.wago.com/280-483 Item no.: 280-484 Jumper; 4-way; insulated; gray www.wago.com/280-484 Item no.: 280-485 Jumper; 5-way; insulated; gray www.wago.com/280-485 Jumper Item no.: 280-490 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 10/12 Data sheet  |  Item number: 280-764 www.wago.com/280-764 Item no.: 280-490 Jumper; 10-way; insulated; gray www.wago.com/280-490 Item no.: 280-492 Jumper; 2-way; insulated; gray www.wago.com/280-492 Item no.: 709-110 Wire commoning chain; 2.5 mm²; insulated; black www.wago.com/709-110 Item no.: 709-111 Wire commoning chain; 2.5 mm²; insulated; black www.wago.com/709-111 Item no.: 709-112 Wire commoning chain; 2.5 mm²; insulated; black www.wago.com/709-112 Item no.: 210-148 Angled support bracket; without screw www.wago.com/210-148 Item no.: 210-149 Screw M 5 x 8; for angled support bracket www.wago.com/210-149 assembling Downloads Documentation Bid Text 280-764 Feb 19, 2019 xml 2.8 kB Download Feb 20, 2019 docx 14.4 kB Download URL Download EPLAN Data Portal 280-764 URL Download WSCAD Universe 280-764 URL Download ZUKEN Portal 280-764 URL Download GAEB X81 - Datei 280-764 GAEB docx - Datei CAD/CAE-Data CAD data 2D/3D Models 280-764 CAE data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 11/12 Data sheet  |  Item number: 280-764 www.wago.com/280-764 Installation Notes Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.07.2020    Page 12/12
280-764 价格&库存
很抱歉,暂时无法提供与“280-764”相匹配的价格&库存,您可以联系我们找货
