281-511
281-511
    WAGO(万可电子)
    连接器 保险丝插头 用于 DIN 导轨端子块
281-511 数据手册
Printview: Fuse plug with pull-tab; for miniature metric fuses 5 x 20 mm and 5 x 25 mm; 6 mm wide - Item No.: 281-511 . Fuse plug with pull-tab; for miniature metric fuses 5 x 20 mm and 5 x 25 mm; 6 mm wide Item No.: 281-511 . Fuse plug with pull-tab; for miniature metric fuses 5 x 20 mm and 5 x 25 mm; 6 mm wide . Marking . Business data Supplier WAGO Item no. 281-511 GTIN / EAN 4050821032540 Content 1 Order amount 50 Customer item number . Notes Technical data Miscellaneous Color gray Rated voltage EN (1) [V] 250 [V] Nominal current [A] 6.3 [A] Marking level Center marking Insulating material Polyamide 66 (PA 66) Weight [g] 6.147 [g] Width 6 mm / 0.236 in Safety information 1 Electrical ratings are given by the fuse. WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Fuse plug with pull-tab; for miniature metric fuses 5 x 20 mm and 5 x 25 mm; 6 mm wide - Item No.: 281-511 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Fuse plug with pull-tab; for miniature metric fuses 5 x 20 mm and 5 x 25 mm; 6 mm wide - Item No.: 281-511 WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Fuse plug with pull-tab; for miniature metric fuses 5 x 20 mm and 5 x 25 mm; 6 mm wide - Item No.: 281-511 . WAGO Kontakttechnik GmbH & Co. KG 4 Printview: Fuse plug with pull-tab; for miniature metric fuses 5 x 20 mm and 5 x 25 mm; 6 mm wide - Item No.: 281-511 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 5
281-511 价格&库存
很抱歉,暂时无法提供与“281-511”相匹配的价格&库存,您可以联系我们找货
