282-607
282-607
    WAGO(万可电子)
    端子块连接器 2 位置 接地,地面 绿色,黄色 10-24AWG
282-607 数据手册
Printview: 2-conductor ground terminal block - Item No.: 282-607 . 2-conductor ground terminal block Item No.: 282-607 . 2-conductor ground terminal block . Marking . Business data Supplier WAGO Item no. 282-607 GTIN / EAN 4045454100209 Content 1 Order amount 50 Customer item number . Notes Technical data Miscellaneous Total number of connection points 2 Total number of potentials 1 Color green-yellow Ratings according to 1 IEC/EN 60947-7-2 Connection technology (1) CAGE CLAMP® Solid sizes 1 0.2 … 6 mm² / 24 … 10 AWG Fine-stranded wires 1 0.2 … 6 mm² / 24 … 10 AWG Strip length 1 12 … 13 mm / 0.47 … 0.51 in Type of wiring Front-entry wiring Design horizontal WAGO Kontakttechnik GmbH & Co. KG 1 Printview: 2-conductor ground terminal block - Item No.: 282-607 Technical data Marking level Side marking Insulating material Polyamide 66 (PA 66) Weight [g] 19.094 [g] Width 8 mm / 0.315 in Height from upper-edge of DIN-rail [mm] 31.5 [mm] Height from upper-edge of DIN-rail 31.5 mm / 1.24 in Length 62 mm / 2.441 in Type of mounting DIN 35 rail WAGO Kontakttechnik GmbH & Co. KG 2 Printview: 2-conductor ground terminal block - Item No.: 282-607 Images & drawings . WAGO Kontakttechnik GmbH & Co. KG 3 Printview: 2-conductor ground terminal block - Item No.: 282-607 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
282-607 价格&库存
很抱歉,暂时无法提供与“282-607”相匹配的价格&库存,您可以联系我们找货
