750-370
750-370
    WAGO(万可电子)
750-370 数据手册
750-370 2-port; 100 Mbit/s; digital and analog signals 01 02 PROFINET IO LINK A Link B Fieldbus connection RJ-45 BF 24V 0V Fieldbus connection RJ-45 I/O ACT1 D DIA Status voltage supply -System -Power jumper contacts Data contacts Supply 24 V 0V + + Supply via power jumper contacts 24 V — — ON 1 2 3 4 5 6 7 8 Dip switch C ACT2 750-370 36 PROFINET IO Fieldbus Coupler W 1 Configuration interface 0V Power jumper contacts This fieldbus coupler connects to the WAGO-I/O-SYSTEM as a slave of the PROFINET IO, the open Industrial ETHERNET standard for automation. The fieldbus coupler supports all I/O modules. The buscoupler automatically configures, creating a local process image which may include analog, digital or specialty modules. Analog and specialty module data is sent via words and/or bytes; digital data is sent bit by bit. This buscoupler can integrate into the application as a PROFINET IO device. The buscoupler features an integrated 2-port switch, allowing easy line structure creation without requiring any additional network components. The device name can be assigned via LLDP protocol or be adjusted by a DIP switch if the protocol is not supported by the control systems. Description Item No. Pack. Unit System Data PROFINET IO 100 MBit 2-port 750-370 1 No. of couplers connected to Master Transmission medium Max. length of fieldbus segment Baud rate Buscoupler connection Protocols Accessories Item No. Miniature WSB Quick marking system plain with marking 248-501 see pages 304 ... 305 Approvals Conformity marking 1 Pack. Unit 5 limited by PROFINET specification Twisted Pair S-UTP 100 Ω cat. 5 100 m between switch and 750-370; max. length of network limited by PROFINET specification 10/100 Mbit/s 2 x RJ-45 PROFINET IO RT, DCP, SNMP, LLDP 1 37 1 24 V 1 5 10 nF 24 V /0 V DC DC I/O modules 0V 2 6 3 7 0V ELECTRONICS FIELDBUS INTERFACE ELECTRONICS FIELDBUS INTERFACE 24 V 24 V 0V 4 10 nF 8 750-370 Technical Data Number of I/O modules with bus extension Fieldbus Max. input process image Max. output process image Configuration Voltage supply Max. input current (24 V) Efficiency of the power supply Internal current consumption (5 V) Total current for I/O modules (5 V) Isolation Voltage via power jumper contacts Current via power jumper contacts (max.) General Specifications 64 128 320 bytes 320 bytes via PC 24 V DC (-15 % ... +20 %) 500 mA 87 % 300 mA 1700 mA 500 V system/supply 24 V DC (-15 % ... +20 %) 10 A DC Operating temperature Wire connection Cross sections Stripped lengths Dimensions (mm) W x H x L Weight Storage temperature Relative air humidity (no condensation) Vibration resistance Shock resistance Degree of protection EMC 1-Immunity to interference EMC 1-Emission of interference 0 °C ... +55 °C CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 8 ... 9 mm / 0.33 in 51 x 65 x 100 Height from upper-edge of DIN 35 rail 180 g -25 °C ... +85 °C 95 % acc. to IEC 60068-2-6 acc. to IEC 60068-2-27 IP20 acc. to EN 61000-6-2 (2005) acc. to EN 61000-6-3 (2007)
750-370 价格&库存
很抱歉,暂时无法提供与“750-370”相匹配的价格&库存,您可以联系我们找货
