750-890/040-000
750-890/040-000
    WAGO(万可电子)
    WAGO - 750-890/040-000 - MODBUS TCP, 2 X ENET, SD CARD SLOT, GREY
750-890/040-000 数据手册
Data sheet | Item number: 750-890/040-000 Controller Modbus TCP; 4th generation; 2 x ETHERNET, SD Card Slot; Extreme; dark gray www.wago.com/750-890/040-000 Color: Item description WAGO’s Modbus TCP Controller can be used as a programmable controller within ETHERNET networks in conjunction with the WAGO-I/O-SYSTEM. It supports all digital, analog and specialty modules found within the 750/753 Series, and is suitable for data rates of 10/100 Mbit/s. Two ETHERNET interfaces and an integrated switch allow the fieldbus to be wired in a line topology. This eliminates additional network devices, such as switches or hubs. Both interfaces support autonegotiation and Auto-MDI(X). The DIP switch configures the last byte of the IP address and may be used for IP address assignment. This controller supports Modbus TCP for use in industrial environments. It also supports a wide variety of standard ETHERNET protocols for easy integration into IT environments (HTTP(S), BootP, DHCP, DNS, SNTP, SNMP, (S)FTP). An integrated Webserver provides user configuration options, while displaying PLC status information. The IEC 61131-3 programmable controller is multitasking-capable and features a battery-backed RTC. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 15.03.2021    Page 1/12 Data sheet | Item number: 750-890/040-000 www.wago.com/750-890/040-000 The IEC 61131-3 programmable controller is multitasking-capable and features a battery-backed RTC. A data memory of 8 MB is available. The controller is equipped with a removable memory card slot. A memory card can be used to transfer device parameters or files (e.g., boot files) from one controller to another. The memory card can be accessed via FTP and be used as an additional drive. The device is ideal for operation in harsh environments thanks to: Extended temperature range Greater immunity to impulse voltages and electromagnetic interference Higher vibration and shock resistance Data Technical data Communication Modbus (TCP, UDP) ETHERNET protocols (S)FTP HTTP(S) BootP DHCP DNS SNTP (S)FTP SNMP Visualization Web Visu CPU 32 bits Programming languages per IEC 61131-3 Instruction List (IL) Ladder Diagram (LD) Function Block Diagram (FBD), Continuous Function Chart (CFC) Structured Text (ST) Sequential Function Chart (SFC) Programming environment WAGO-I/O-PRO V2.3 (based on CODESYS V2.3) Configuration options WAGO-I/O-CHECK Web-Based Management CODESYS Library Baud rate (communication/fieldbus 1) 10/100 Mbit/s Baud rate 10/100 Mbit/s Transmission medium (communication/fieldbus) Twisted Pair S-UTP; 100 Ω; Cat. 5; 100 m maximum cable length Transmission performance Class D per EN 50173 Program memory 8 MB Data memory 8 MB Non-volatile software memory 32 Kbytes Memory card type SD and SDHC up to 32 GB (all guaranteed properties only valid with WAGO Memory Card) SD and SDHC up to 32 GB (All guaranteed properties are only valid Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 15.03.2021    Page 2/12 Data sheet | Item number: 750-890/040-000 www.wago.com/750-890/040-000 SD and SDHC up to 32 GB (All guaranteed properties are only valid in connection with the WAGO memory card.) Memory card slot Push-push mechanism; Cover lid (sealable) Number of modules per node (max.) 64 Input and output (fieldbus) process image (max.) 1020 Worte/1020 Worte Indicators LED (LINK/ACT) green: Network connection via ports 1 … 2; LED (MS, NS) red/green: Status of node, network; LED (I/O, USR) red /green/orange: Local data bus status, status programmable by user; LED (A, B) green: System power supply status, field supply Derating Derating (supply voltage): Surrounding air temperatures under laboratory conditions: (-25 … +30 %); for -40 … +55 °C: 24 V (-25 … +20 %); for +55 … +70 °C: 24 V (-25 … +10 %); Lower limit in all temperature ranges: −27.5 % (including 15 % residual ripple) Supply voltage (system) 24 VDC; via pluggable connector (CAGE CLAMP® connection); Derating must be observed! DC 24 V; via pluggable connector (CAGE CLAMP® connection); Derating must be observed! Input current (typ.) at nominal load (24 V) 500 mA Power supply efficiency (typ.) at nominal load (24 V) 90 % Power consumption (5 V system supply) 440 mA Total current (system supply) 1,700 mA Supply voltage (field) 24 VDC; Power supply via pluggable connector (CAGE CLAMP® connection); Transmission via power jumper contacts; Derating must be observed! DC 24 V; Power supply via pluggable connector (CAGE CLAMP® connection); Transmission via power jumper contacts; Derating must be observed! Current carrying capacity (power jumper contacts) 10 A Number of outgoing power jumper contacts 2 Rated surge voltage 1 kV Connection data Connection technology: communication/fieldbus Modbus TCP/UDP: 2 x RJ-45 Connection technology: system supply 2 x CAGE CLAMP® Connection technology: field supply 4 x CAGE CLAMP® Connection type (1) System/field supply Solid conductor 0.25 … 2.5 mm² / 24 … 14 AWG Fine-stranded conductor 0.25 … 2.5 mm² / 24 … 14 AWG Strip length 8 … 9 mm / 0.31 … 0.35 inch Connection technology: device configuration 1 x Male connector; 4-pole Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 15.03.2021    Page 3/12 Data sheet | Item number: 750-890/040-000 www.wago.com/750-890/040-000 Physical data Width 61.5 mm / 2.421 inch Height 100 mm / 3.937 inch Depth 71.9 mm / 2.831 inch Depth from upper edge of DIN-rail 64.7 mm / 2.547 inch Mechanical data Weight 149.9 g 149.8 g Color dark gray Housing material Polycarbonate; polyamide 6.6 Polycarbonate, polyamide 6.6 Conformity marking CE Environmental requirements Surrounding air temperature (operation) -40 … 70 °C Surrounding air temperature (storage) -40 … 85 °C Protection type IP20 Pollution degree (5) 2 per IEC 61131-2 Operating altitude without temperature derating: 0 … 2000 m; with temperature derating: 2000 … 5000 m (0.5 K/100 m); 5000 m (max.) Relative humidity (without condensation) 95 % Relative humidity (with condensation) Short-term condensation per Class 3K7/IEC EN 60721-3-3 and EDIN 40046-721-3 (except for wind-driven precipitation, water and ice formation) Mounting position horizontal (standing/lying); vertical Mounting type DIN-35 rail Vibration resistance per IEC 60068-2-6 (acceleration: 5g), EN 60870-2-2, IEC 60721-3-1, -3, EN 50155; EN 61373 Shock resistance per IEC 60068-2-27 (15g/11 ms/half-sine/1,000 shocks; 25g/6 ms/1, 000 shocks), EN 50155, EN 61373 EMC immunity to interference per EN 61000-6-1, -2; EN 61131-2; marine applications; EN 50121-32; EN 50121-4, -5; EN 60255-26; EN 60870-2-1; EN 61850-3; IEC 61000-6-5; IEEE 1613; VDEW: 1994 EMC emission of interference per EN 61000-6-3, -4, EN 61131-2, EN 60255-26, marine applications, EN 60870-2-1, EN 61850-3, EN 50121-3-2, EN 501214, -5 Exposure to pollutants per IEC 60068-2-42 and IEC 60068-2-43 Fire load 0.157 MJ Permissible H2S contaminant concentration at a relative humidity 75 10 ppm Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 15.03.2021    Page 4/12 Data sheet | Item number: 750-890/040-000 www.wago.com/750-890/040-000 Permissible H2S contaminant concentration at a relative humidity 75 10 ppm % Permissible SO2 contaminant concentration at a relative humidity 75 25 ppm % Commercial data Packaging type BOX Country of origin DE GTIN 4055143978279 Customs tariff number 85371091990 Approvals / Certificates Ex-Approvals Logo Certificate name Approval Additional Approval Text ATEX TUEV Nord Cert GmbH EN 60079-0 TUEV 17 ATEX 193969X IECEx TUEV Nord Cert GmbH IEC 60079-0 IECEx TUN 16.0046X UL Underwriters Laboratories Inc. (HAZARDOUS LOCATIONS) UL 121201 E198726 Sec.1 Country specific Approvals Logo Certificate name Approval Additional Approval Text KC National Radio Research Agency Article 58-2, Clause 3 Approval Additional Approval Text Certificate name DNV GL DNVGL-CG-339,Dec.2019 TAA00000Y7 MSIPREM-W43PFC750 Ship Approvals Logo Det Norske Veritas, Germanischer Lloyd Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 15.03.2021    Page 5/12 Data sheet | Item number: 750-890/040-000 www.wago.com/750-890/040-000 Det Norske Veritas, Germanischer Lloyd UL-Approvals Logo Approval Additional Approval Text UL Underwriters Laboratories Inc. (ORDINARY LOCATIONS) UL 61010-2-201 Certificate name E175199 Sec11 Compatible products software Item no.: 759-333 WAGO-I/O-PRO www.wago.com/759-333 Item no.: 759-333/000-923 WAGO-I/O-PRO; USB-Set www.wago.com/759-333 /000-923 Item no.: 759-911 WAGO-I/O-PRO; CD www.wago.com/759-911 Carrier rail Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112 silver-colored Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115 silver-colored Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-118 Item no.: 210-196 www.wago.com/210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; copperSubject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/210-198 Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 15.03.2021    Page 6/12 Data sheet | Item number: 750-890/040-000 www.wago.com/750-890/040-000 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715; silver-colored www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-508 wiring and connectors Item no.: 750-975 ETHERNET RJ-45 connector, IP20; ETHERNET 10/100 Mbit/s; for field assembly; light gray www.wago.com/750-975 Item no.: 750-977/000-011 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 22 www.wago.com/750-977 /000-011 Item no.: 750-977/000-012 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 22 www.wago.com/750-977 /000-012 Item no.: 750-977/000-021 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 24 www.wago.com/750-977 /000-021 Item no.: 750-977/000-022 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 24 www.wago.com/750-977 /000-022 Item no.: 750-978/000-011 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 22; Strain relief www.wago.com/750-978 /000-011 Item no.: 750-978/000-012 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 22; Strain relief www.wago.com/750-978 /000-012 Item no.: 750-978/000-021 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568A; AWG 24; Strain relief www.wago.com/750-978 /000-021 Item no.: 750-978/000-022 Connector ETHERNET; RJ-45; Cat. 6A; straight; Code T568B; AWG 24; Strain relief www.wago.com/750-978 /000-022 Item no.: 750-979/000-011 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/750-979 Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 15.03.2021    Page 7/12 Data sheet | Item number: 750-890/040-000 www.wago.com/750-890/040-000 Item no.: 750-979/000-011 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568A; AWG 22; Strain relief www.wago.com/750-979 /000-011 Item no.: 750-979/000-012 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568B; AWG 22; Strain relief www.wago.com/750-979 /000-012 Item no.: 750-979/000-021 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568A; AWG 24; Strain relief www.wago.com/750-979 /000-021 Item no.: 750-979/000-022 Connector ETHERNET; RJ-45; Cat. 6A; angled; Code T568B; AWG 24; Strain relief www.wago.com/750-979 /000-022 Marking accessories Item no.: 2009-145 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white Item no.: 2009-145/000-002 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-145 /000-002 Item no.: 2009-145/000-005 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-145 /000-005 Item no.: 2009-145/000-006 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006 Item no.: 2009-145/000-007 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007 Item no.: 2009-145/000-012 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-145 /000-012 Item no.: 2009-145/000-023 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-145 /000-023 Item no.: 2009-145/000-024 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-145 /000-024 Item no.: 248-501 Miniature WSB Quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card www.wago.com/248-501 Item no.: 248-501/000-002 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/248-501 /000-002 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 15.03.2021    Page 8/12 Data sheet | Item number: 750-890/040-000 www.wago.com/750-890/040-000 Item no.: 248-501/000-005 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/248-501 /000-005 Item no.: 248-501/000-006 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/248-501 /000-006 Item no.: 248-501/000-007 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/248-501 /000-007 Item no.: 248-501/000-012 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/248-501 /000-012 Item no.: 248-501/000-017 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/248-501 /000-017 Item no.: 248-501/000-023 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/248-501 /000-023 Item no.: 248-501/000-024 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/248-501 /000-024 Item no.: 750-103 Group marker carrier; transparent www.wago.com/750-103 Item no.: 750-107 Group marker carrier; transparent www.wago.com/750-107 shield connection Item no.: 790-108 Shield clamping saddle; 11 mm wide; diameter of compatible conductor; 3 ... 8 mm www.wago.com/790-108 Item no.: 790-116 Shield clamping saddle; 19 mm wide; diameter of compatible conductor; 7 ... 16 mm www.wago.com/790-116 Item no.: 790-124 Shield clamping saddle; 27 mm wide; diameter of compatible conductor; 6 ... 24 mm www.wago.com/790-124 Item no.: 790-140 Shield clamping saddle; diameter of compatible conductor www.wago.com/790-140 Item no.: 790-208 Shield clamping saddle; 12.4 mm wide; 3 ... 8 mm www.wago.com/790-208 Item no.: 790-216 Shield clamping saddle; 21.8 mm wide; 6 ... 16 mm www.wago.com/790-216 Item no.: 790-220 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 15.03.2021    Page 9/12 Data sheet | Item number: 750-890/040-000 www.wago.com/750-890/040-000 Item no.: 790-220 Shield clamping saddle; 30 mm wide; 6 ... 20 mm www.wago.com/790-220 Item no.: 850-804 IP65 enclosure; Stainless steel; WxHxD (400x123x200 mm); 4 x M20, 16 x M16, 28 x M12 cable grip www.wago.com/850-804 Item no.: 850-804/000-001 IP65 enclosure; Stainless steel; WxHxD (400x123x200 mm); 2 x M20, 13 x M16, 32 x M12 cable grip www.wago.com/850-804 /000-001 Item no.: 850-805 IP65 enclosure; Stainless steel; WxHxD (600x123x200 mm); 4 x M20, 19 x M16, 67 x M12 cable grip www.wago.com/850-805 Item no.: 850-814/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (200x120x200 mm); without flange plate www.wago.com/850-814 /002-000 Item no.: 850-815/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (300x120x200 mm); without flange plate www.wago.com/850-815 /002-000 Item no.: 850-816/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (400x120x200 mm); without flange plate www.wago.com/850-816 /002-000 Item no.: 850-817/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (600x120x200 mm); without flange plate www.wago.com/850-817 /002-000 Item no.: 850-825 IP65 enclosure; Aluminium (RAL 7032); WxHxD (160x100x160 mm); 9 x M12, 4 x M20 www.wago.com/850-825 Item no.: 850-826 IP65 enclosure; Aluminium (RAL 7032); WxHxD (240x100x160 mm); 4 x M20, 4 x M16, 14 x M12 cable grip www.wago.com/850-826 Item no.: 850-826/002-000 IP65 enclosure; Aluminium (RAL 7035); WxHxD (240x100x160 mm); 4 x M20, 4 x M16, 14 x M12 cable grip www.wago.com/850-826 /002-000 Item no.: 850-827 IP65 enclosure; Aluminium (RAL 7032); WxHxD (320x100x160 mm); 4 x M20, 8 x M16, 17 x M12 cable grip www.wago.com/850-827 Item no.: 850-827/002-000 IP65 enclosure; Aluminium (RAL 7035); WxHxD (320x100x160 mm); 4 x M20, 8 x M16, 17 x M12 cable grip www.wago.com/850-827 /002-000 Item no.: 850-828 IP65 enclosure; Aluminium (RAL 7032); WxHxD (480x100x160 mm); 4 x M20, 10 x M16, 35 x M12 cable grip www.wago.com/850-828 system box Item no.: 850-828/002-000 IP65 enclosure; Aluminium (RAL 7035); WxHxD (480x100x160 mm); 4 x M20, 10 x M16, 35 x M12 cable grip Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 15.03.2021    Page 10/12 Data sheet | Item number: 750-890/040-000 www.wago.com/750-890/040-000 grip www.wago.com/850-828 /002-000 Item no.: 850-834 IP65 enclosure; Polyester (RAL 7032); WxHxD (164x100x164 mm); 9 x M12, 4 x M20 www.wago.com/850-834 Item no.: 850-835 IP65 enclosure; Polyester (RAL 7032); WxHxD (244x100x164 mm); 4 x M20, 4 x M16, 14 x M12 cable grip www.wago.com/850-835 Item no.: 850-836 IP65 enclosure; Polyester (RAL 7032); WxHxD (324x100x164 mm); 4 x M20, 8 x M16, 17 x M12 cable grip www.wago.com/850-836 Item no.: 758-879/000-001 Memory Card SD; SLC-NAND; 2 GByte; Temperature from -40 to 90 °C www.wago.com/758-879 /000-001 Item no.: 758-879/000-2108 Memory Card SD; pSLC-NAND; 8 GB; Temperature range: -40 to 90°C www.wago.com/758-879 /000-2108 memory card General accessories Item no.: 750-921 Bluetooth® Adapter; light gray www.wago.com/750-921 Item no.: 750-923 Configuration cable; USB connector; Length: 2.5 m; black www.wago.com/750-923 Item no.: 750-923/000-001 Configuration cable; USB connector; Length: 5 m www.wago.com/750-923 /000-001 Downloads Documentation Manual Controller Modbus TCP; 4th Generation; 2 x ETHERNET, SD Card Slot; XTR pdf 7.0 MB Download 750-890/040-000 xml 13.3 kB Download 750-890/040-000 docx 20.9 kB Download extreme V 1.0.1 18 Jan 2021 Bid Text Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 15.03.2021    Page 11/12 Data sheet | Item number: 750-890/040-000 www.wago.com/750-890/040-000 Additional Information Disposal; Electrical and electronic equipment, Packaging V 1.0.0 pdf 265.8 kB Download V 1.3.0 1 Feb 2021 pdf 6.3 MB Download pdf 517.0 kB Download System Description System Manual XTR Basic conditions and recommendations for higher operational safety 750 XTR Controller, General Product Information Installation Notes Product family Controller 750 XTR Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 15.03.2021    Page 12/12
750-890/040-000 价格&库存
很抱歉,暂时无法提供与“750-890/040-000”相匹配的价格&库存,您可以联系我们找货
    • 1+16602.46957
    库存:1
