793-611/000-023
793-611/000-023
    WAGO(万可电子)
    WMB Multiple marking system
793-611/000-023 数据手册
14 Colored Marker Cards WAGO Quick Marking System WSB➊ WAGO Multi Marking System WMB➊ Colored marker cards Horizontal/vertical marking Additional item-Nos. 10 strips with 10 markers per card for terminal block widths Horizontal marking Consecutive numbers each strip Vertical marking Consecutive numbers each strip 10 strips with 10 markers per card for terminal block widths 5 - 17.5 mm/0.197 in - 0.689 in (WSB/WMB) 4 - 4.2 mm/0.157 in - 0.165 in (WMB) 10 strips with 10 markers per card for terminal block widths 5 - 17.5 mm/0.197 in - 0.689 in (WSB/WMB) 4 - 4.2 mm/0.157 in - 0.165 in (WMB) Color Marking per card 1 . . . 10 (10x) 11 . . . 20 (10x) 21 . . . 30 (10x) 31 . . . 40 (10x) 41 . . . 50 (10x) 51 . . . 60 (10x) 61 . . . 70 (10x) 71 . . . 80 (10x) 81 . . . 90 (10x) 91 . . . 100 (10x) Item No. 209-502 209-503 209-504 209-505 209-506 209-569 209-570 209-571 209-572 209-573 Pack.-unit pcs 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards Marking per card 1 . . . 10 (10x) 11 . . . 20 (10x) 21 . . . 30 (10x) 31 . . . 40 (10x) 41 . . . 50 (10x) 51 . . . 60 (10x) 61 . . . 70 (10x) 71 . . . 80 (10x) 81 . . . 90 (10x) 91 . . . 100 (10x) Item No. 209-602 209-603 209-604 209-605 209-606 249-601 249-602 249-603 249-604 249-605 Pack.-unit pcs 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 1 . . . 50 (2x) 51 . . . 100 (2x) 101 . . . 150 (2x) 151 . . . 200 (2x) 209-566 209-507 209-508 209-509 5 cards 5 cards 5 cards 5 cards 1 . . . 50 (2x) 51 . . . 100 (2x) 101 . . . 150 (2x) 151 . . . 200 (2x) 209-666 209-607 209-608 209-609 5 cards 5 cards 5 cards 5 cards 201 . . . 301 . . . 401 . . . 501 . . . 601 . . . 701 . . . 801 . . . 901 . . . 209-510 209-511 209-512 209-513 209-514 209-515 209-516 209-517 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards ; (10x) 209-565 5 cards 201 . . . 300 (1x) 209-610 301 . . . 400 (1x) 209-611 401 . . . 500 (1x) 209-612 501 . . . 600 (1x) 209-613 601 . . . 700 (1x) 209-614 701 . . . 800 (1x) 209-615 801 . . . 900 (1x) 209-616 901 . . . 1000 (1x) 209-617 1001 . . . 1100 (1x) 209-688 1101 . . . 1200 (1x) 209-669 1201 . . . 1300 (1x) 209-670 1301 . . . 1400 (1x) 209-671 1401 . . . 1500 (1x) 209-672 1501 . . . 1600 (1x) 209-901 1601 . . . 1700 (1x) 209-902 1701 . . . 1800 (1x) 209-903 1801 . . . 1900 (1x) 209-912 1901 . . . 2000 (1x) 209-913 1... 9, ; (10x) 209-665 101, 101, 101, 102, . . . . . .130, 130, 130 (1x) 209-667 131, 131, 131, 132, . . . . . .160, 160, 160 (1x) 209-668 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 4 – 4.2 mm und 5 – 17.5 mm 0.157 in and 0.197 in – 0.689 in Item No. Colored marker cards All the markings shown are also available with black printing on colored marker cards. Add. item-No. for colored marker cards yellow . . ./000-002 red . . ./000-005 blue . . ./000-006 grey . . ./000-007 orange . . ./000-012 light green . . ./000-017 green . . ./000-023 violet . . ./000-024 Ordering examples Terminal block width 4 mm – WSB card Marking 1 . . . 50 on yellow card 209-766/000-002 Terminal block width 4 mm – WMB card Marking 1 . . . 50 on blue card 793-4566/000-006 Terminal block width 5 mm – WSB card Marking 1 . . . 50 on red card 209-566/000-005 Terminal block width 5 mm – WMB card Marking 1 . . . 50 on green card 793-5566/000-023 Note: Please note that colored marker cards are normally on longer delivery and more expensive than standard cards. ➊ All WSB cards shown on this page are also available as WMB cards with the same suffix. Item no. see table: WSB WMB rigid 209- . . . 793- . . . 249- . . . 794- . . . stretchable 5 – 5.2 mm 209- . . . 793-5 . . . 249- . . . 794-5 . . . stretchable 4 – 4.2 mm 209- . . . 793-4 . . . 249- . . . 794-4 . . . 1... 300 (1x) 400 (1x) 500 (1x) 600 (1x) 700 (1x) 800 (1x) 900 (1x) 1000 (1x) 9, for double deck terminal blocks 1, 3, 5, . . . 99 and 2, 4, 6, . . . 100 (1x) 209-599 for triple deck terminal blocks 1, 4, 7, . . . 99 (1x) 249-557 100, 103, 106, . . . 198 (1x) 249-558 5 cards 5 cards 5 cards plain, for selfmarking 209-501 5 cards Marking pen with fibre tip, for permanent marking 210-110 1 9 5 cards 5 cards for double deck terminal blocks 1, 3, 5, 7, 9, 11, . . . 99 and 2, 4, 6, 8, 10, 12, . . . 100 (1x) 209-699 5 cards 101, 103, 105, . . . 149 and 102, 104, 106, . . . 150 (2x) 209-900 5 cards for triple deck terminal blocks 1, 4, 7, . . . 99 (1x) 249-657 5 cards 100, 103, 106, . . . 198 (1x) 249-658 5 cards 14
793-611/000-023 价格&库存
很抱歉,暂时无法提供与“793-611/000-023”相匹配的价格&库存,您可以联系我们找货
