852-1813
852-1813
    WAGO(万可电子)
    WAGO - 852-1813 - ENET SW, INDUS, RJ45X8/SFPX2, DIN RAIL
852-1813 数据手册
Data sheet | Item number: 852-1813  NEW Lean Managed Switch; 8-Port 1000BASE-T; 2-Slot 1000BASE-SX/LX; light gray www.wago.com/852-1813 Color: Item description The 852-1813 is a configurable industrial ETHERNET switch with eight 10/100/1000BASE-T ports and two 100BASE-FX/1000BASE-FX/SX/ZX SFP ports (SFP modules are available as an option). Enclosed in a rugged housing, this switch offers both a redundant power supply and relay-based function monitoring. This device also streamlines network management: Commissioning and diagnostics are intuitive and can be performed without extensive IT knowledge. The topology map clearly displays the switch and connected devices. Key diagnostic information is displayed on the diagnostics dashboard. The following functions increase the robustness, availability and security of the network. Security: Network segmentation per IEEE802.1Q (max. 5 VLANs), authentication of network devices per IEEE802.1X, firewall functions using the accesscontrol list (max. 32 entries)/service control, port security Subject to changes. Please also observe the further product documentation! WAGO Pty. Ltd. 2-4 Overseas Drive Noble Park Victoria 3174 Tel.: +61 (0)3 8791 6300 | Fax: +61 (0)3 9701 0177 Email: sales.anz@wago.com Do you have any questions about our products? We are always happy to take your call at +61 (0)3 8791 6300. 29.11.2020    Page 1/4 Data sheet | Item number: 852-1813  NEW www.wago.com/852-1813 control list (max. 32 entries)/service control, port security Availability: Rapid Spanning Tree Protocol (RSTP) for meshed and ring networks, ETHERNET Ring Protection Switching (ERPS) for up to two rings per switch, loop detection and storm control on each port Configuration/Diagnostics/Maintenance: Port mirroring, Modbus® registers, SNMP v3, SNMP trap events, alarm threshold, port statistics, backup and restore, system log, syslog server, command line interface with SSH/Telnet, topology map and dashboard Data Technical Data Switching mode Store‐and‐forward; non-blocking Number of 1000BASE-T ports 8 Number of 100Base-FX ports 2 Communication standards IEEE 802.3 10BASE-T IEEE 802.3u 100BASE-TX/FX IEEE 802.3ab 1000BASE-T IEEE 802.3z 1000BASE-SX/LX IEEE 802.3x Flow Control IEEE 802.1d Spanning Tree Protocol (STP) IEEE 802.1w Rapid Spanning Tree Protocol (RSTP) IEEE 802.1Q VLAN Tagging IEEE 802.1p Prioritization IEEE 802.1x Port Authentication IEEE 802.1ab Link Layer Discovery Protocol (LLDP) IEEE 802.3az Energy Efficient Ethernet ITU-T G8032v1/v2 Ethernet Ring Protection Switching (ERPS) Redundancy function Redundant DC power supply; STP; RSTP; ERPSv1/v2 (max. 2 rings per switch, max. 16 switches per ring, switching time < 800 ms) Configuration options DIP switch for signal contact Web-Based Management Command Line Interface SNMPv1/v2c/v3 Diagnostics Signal contact; Modbus TCP; port status; port statistics; port load; traffic monitor; syslog; SNMP traps; loop detection; diagnostics dashboard; topology map MAC table (size) 8000 addresses Jumbo frame size 10000. Byte Supply voltage DC 24 … 48 V; (±15 %); 24 … 48 VDC (UL) Power consumption (max.) 11 W ESD (contact/air discharge) 8 KV / 15 KV Baud rate Copper cable: 10/1000 Mbit/s; Fiber optic:1000 Mbit/s Transmission medium (communication/fieldbus) Fiber optic: SX Multi-Mode, LX Single-Mode Optical fiber type Single-mode and multi-mode VLAN Port-based and tag-based (max. 5 VLANs) Subject to changes. Please also observe the further product documentation! WAGO Pty. Ltd. 2-4 Overseas Drive Noble Park Victoria 3174 Tel.: +61 (0)3 8791 6300 | Fax: +61 (0)3 9701 0177 Email: sales.anz@wago.com Do you have any questions about our products? We are always happy to take your call at +61 (0)3 8791 6300. 29.11.2020    Page 2/4 Data sheet | Item number: 852-1813  NEW www.wago.com/852-1813 VLAN Port-based and tag-based (max. 5 VLANs) Connection data Connection technology: communication/fieldbus Copper cable: 8 x RJ-45; Fiber optic: 2 x SFP; LC fiber-optic connector Physical data Width 50 mm / 1.969 inch Height 116 mm / 4.567 inch Depth from upper edge of DIN-rail 100 mm / 3.937 inch Mechanical data Weight 570 g Color light gray Conformity marking CE Environmental Requirements Surrounding air temperature (operation) -40 … 60 °C Surrounding air temperature (storage) -40 … 85 °C Protection type IP30 Relative humidity (without condensation) 95 % Mounting type DIN-35 rail Vibration resistance per IEC 60068-2-6 Shock resistance per IEC 60068-2-27 EMC immunity to interference per EN 61000-6-2 EMC emission of interference per EN 61000-6-4 Commercial data Packaging type BOX Country of origin TW GTIN 4055144019513 Customs tariff number 85176200000 Approvals / Certificates UL-Approvals Certificate Logo Approval Additional Approval Text Subject to changes. Please also observe the further product documentation! WAGO Pty. Ltd. 2-4 Overseas Drive Noble Park Victoria 3174 Tel.: +61 (0)3 8791 6300 | Fax: +61 (0)3 9701 0177 Email: sales.anz@wago.com name Do you have any questions about our products? We are always happy to take your call at +61 (0)3 8791 6300. 29.11.2020    Page 3/4 Data sheet | Item number: 852-1813  NEW www.wago.com/852-1813 Logo Approval Additional Approval Text name UL Underwriters Laboratories Inc. (ORDINARY LOCATIONS) UL 61010-2-201 E175199 Downloads Documentation Manual Lean Managed Switch V 1.0.0 23-Sep-2020 8 Ports 1000BASE-T; 2 Slots BASE-FX/TX pdf 8.6 MB Download Installation Notes Subject to changes. Please also observe the further product documentation! WAGO Pty. Ltd. 2-4 Overseas Drive Noble Park Victoria 3174 Tel.: +61 (0)3 8791 6300 | Fax: +61 (0)3 9701 0177 Email: sales.anz@wago.com Do you have any questions about our products? We are always happy to take your call at +61 (0)3 8791 6300. 29.11.2020    Page 4/4
852-1813 价格&库存
很抱歉,暂时无法提供与“852-1813”相匹配的价格&库存,您可以联系我们找货
