Data sheet | Item number: 2059-303/998-403
SMD PCB terminal block; 0.5 mm²; Pin spacing 3 mm; 3-pole; PUSH WIRE®; in
tape-and-reel packaging; 0,50 mm²; white
www.wago.com/2059-303_998-403
Color:
L = (pole no. x pin spacing) – 0.1 mm
R = Feed direction
Item description
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/7
SMD PCB terminal blocks with PUSH WIRE® connection technology
Push-in termination of solid conductors
Easy conductor removal, e.g., via operating tool
Just 2.7 mm tall
Assemble terminal blocks without pole loss
Available in tape-and-reel packaging for automated assembly
Note:
Application note:
Suitable for lead-free, reflow-soldering profiles per DIN EN 61760-1 and IEC 60068-2-58 up to max.
260 °C peak temperature. Due to customer-specific variables (e.g., component configuration and orientation, type of soldering machine, solder
paste), trial runs are recommended to ensure product and process compatibility under actual manufacturing conditions.
Note:
Depending on reflow soldering temperatures and times, color deviations may occur. These deviations will have no impact on functionality.
Recommendation:
Recommendation for SMD stencil:
Material thickness, 150 µm. Pattern layout identical to solder pad layout.
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
63 V
Rated impulse voltage (III / 3)
2.5 kV
Rated voltage (III / 2)
160 V
Rated impulse voltage (III / 2)
2.5 kV
Rated voltage (II / 2)
320 V
Rated impulse voltage (II / 2)
2.5 kV
Rated current
3 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 2/7
Approvals per UL 1977
Rated voltage per UL 1977 (factory wiring only)
250 V
Rated current per UL 1977 (factory wiring only)
3 A
Connection data
Connection technology
PUSH WIRE®
Actuation type
Operating tool
Solid conductor
0.14 … 0.34 mm² / 26 … 22 AWG
Strip length
4 … 5.5 mm / 0.16 … 0.22 inch
Conductor entry angle to the PCB
0 °
No. of poles
3
Solid conductor (2)
0.5 mm² / 20 AWG
Note (conductor cross-section) 2
No reconnection of smaller conductor cross-sections (0.5 mm² / 20
AWG)
Strip length (2)
6 … 7.5 mm / 0.24 … 0.3 inch
Total number of connection points
3
Total number of potentials
3
Number of connection types
1
Number of levels
1
For conductors that are not rigid enough (26 AWG), the clamping
unit must be opened using an operating tool.
Geometrical Data
Pin spacing
3 mm / 0.118 inch
Width
8.9 mm / 0.35 inch
Height
2.7 mm / 0.106 inch
Depth
7.9 mm / 0.311 inch
Reel diameter of tape-and-reel packaging
330 mm
Tape width
16 mm
PCB contact
PCB contact
SMD
Material Data
Color
white
Material group
I
Insulating material
Subject to changes.
Hansastr. 27
32423 Minden
Polyphthalamide (PPA GF)
29.12.2019 Page 3/7
Insulating material
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Copper alloy
Contact plating
tin-plated
Weight
0.2 g
Environmental Requirements
Limit temperature range
-60 … +105 °C
Commercial data
Product Group
33 (Printed Circuit)
Packaging type
BOX
Country of origin
CH
GTIN
4055143082693
Customs Tariff No.
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL7680
CCA
EN 60838
NTR NL7720
KEMA/KEUR
EN 60947
71103560
KEMA/KEUR
EN 60838
71106226
UL-Approvals
Certificate
Logo
Approval
Subject to changes.
Hansastr. 27
32423 Minden
name
29.12.2019 Page 4/7
Logo
Approval
name
UL
Underwriters Laboratories Inc.
UL 1977
E45171
Compatible products
General accessories
Item no.: 2059-903
Board-to-Board Link; Pin spacing 3 mm; 3-pole; Length: 15.3 mm; white
www.wago.com/2059-903
Item no.: 2059-903/018-000
Board-to-Board Link; Pin spacing 3 mm; 3-pole; Length: 17.5 mm; white
/018-000
Item no.: 2059-903/021-000
Board-to-Board Link; Pin spacing 3 mm; 3-pole; Length: 20.5 mm; white
/021-000
Item no.: 2059-189
Operating tool; made of insulating material; for 2059 Series
www.wago.com/2059-189
Item no.: 206-859
Operating tool; for 2059 Series
www.wago.com/206-859
tools
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 2059-303/998-403
PCB Design
Symbol and Footprint 2059-303/998-403
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/7
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Installation Notes
Inserting a conductor
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/7
Inserting solid conductors via push-in
termination.
Easy conductor removal (e.g., via 206-859
Operating Tool)
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/7
很抱歉,暂时无法提供与“2059-303/998-403”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1750+7.755231750+1.00649
- 3500+7.441843500+0.96582
- 5250+7.292055250+0.94638
- 8750+7.132678750+0.92569
- 12250+7.0431612250+0.91408
- 国内价格
- 1+4.11480
- 10+3.25080
- 30+2.81880
- 100+2.38680
- 500+2.13840
- 1000+1.99800
