2060-852/998-404
2060-852/998-404
    WAGO(万可电子)
    SMD,P=8mm
    接线端子 间距:8.00mm 每排针脚数:2 排数:单排
2060-852/998-404 数据手册
SMD TERMINAL BLOCKS Small is Big! SMD TERMINAL BLOCKS A compact and low-profile PCB connection is required to achieve the most uniform light distribution, while minimizing shadowing. WAGO’s surface-mount terminal blocks, with their combination of a flat design and wide application scope, fully satisfy these demands. Furthermore, 1-, 2- and 3-pole terminal strips can be assembled without pole loss, providing total flexibility with just a few models. All SMD terminal blocks come in tape-and-reel packaging for full integration into an automated assembly process. Applications The numerous advantages of WAGO’s SMD line of PCB terminal blocks enable them to be used in many different applications. From compact, conventionally wired LED spotlights up to automatically wired, recessed ceiling luminaires, WAGO’s three SMD terminal block lines provide the perfect connection between driver and module. The terminal blocks accommodate a broad range of conductors making them highly versatile for worldwide applications. 5.6 mm 4.5 mm 2.7 mm ADVANTAGES: Info • Low profile minimizes on-board shadowing • Simple push-in termination of solid conductors • Terminal strips of different lengths can be assembled without pole loss, reducing the number of variants and lowering production costs • Available in 1–3 pole configurations • Delivery in tape-and-reel packaging for full integration into SMT soldering process • Potential for significant cost savings via automated pick-and-place assembly SURFACE-MOUNT TECHNOLOGY Surface-Mount Technology (SMT) means soldering electronic components directly onto PCB surface pads without drilling holes. The basic SMT process consists of applying solder paste to Automated assembly Printing (solder) Reflow Soldering Process: SMT components THR-Component SMD the PCB via solder dispensing equipment, screen or stencil printing. SMT assembly is performed using fully automated placement machines. Surface-mount components are soldered to the board in infrared, convection or vapor phase ovens. 2059 SERIES For the Smallest Sizes • Low profile of just 2.7 mm • Pin spacing: 3 mm • Terminate solid conductors from 26 to 22 AWG (0.14–0.34 mm2) • Simple push-in termination of solid conductors • Easy conductor removal via operating tool • Ratings: 160 V, 2.5 kV/2 (III), 3 A • Available in 1–3 pole variants • Assemble terminal strips without losing any poles • Available in tape-and-reel packaging SMD-Leiterplattenklemmen, 0,34 m Rastermaß 3 mm / 0.118 in 0,14 - 0,34 mm2 „e“ AWG 26 - 22 “sol.“ 160 V/2,5 kV/2 3 A Inserting solid conductors via push-in termination. Easy conductor removal, e.g., via the optional 206-859 Operating Tool. Conductor Data IEC/EN 60664-1 Connection technology PUSH WIRE® Overvoltage category III II Conductor size: solid 0.14–0.34 mm2 AWG 26–22 “sol.” Strip length 4–5.5 mm / 0.16–0.22 in. Pollution degree III 3 2 2 Rated voltage 63 V 160 V 320 V Rated impulse voltage 2.5 kV 2.5 kV 2.5 kV Rated current 3A 3A 3A (3) > 2.5 < 0.8 __> ( 0.5 ___> < Pole No. Item No. SMD terminal blocks in tape-and-reel packaging, white 1 2059-301/998-403 31800 (12 x 2650) 2 3 2059-302/998-403 2059-303/998-403 1 > 1.4< (3) Pin Spacing > 2.7 < 2059 Series, 3 mm Pin Spacing 0.3 ___> < R = Feed direc A = 8 mm (1-p A = 12 mm (2 LL ==(Pohlzahl x Rastermaß) - 0.1 mm (pole no. x pin spacing) – 0.1 mm Reel diameter: 330 mm Polzahl Bestellnr. VPE SMD-Leiterplattenklemmen im Gurt, weiß * 1 2 3 2059-301/998-403 2059-302/998-403 2059-303/998-403 31800 (12 x 2650) 21000 (12 x 1750) 21000 (12 x 1750) 2060 SERIES For Manual and Automated Wiring Systems • 4.5 mm tall • Pin spacing: 4 mm • Terminate conductors from 24 to 18 AWG (0.2– 0.75 mm2) • Simple push-in termination of solid conductors • Push-buttons simplify insertion/removal of all conductor types • Ratings: 160 V, 2.5 kV/2 (III), 9 A • Available in 1–3 pole variants • Assemble terminal strips without losing any poles • Available in tape-and-reel packaging Inserting solid conductors via push-in termination. Inserting/removing fine-stranded conductors by lightly depressing the push-button (e.g., using the optional 206860 Operating Tool). Conductor size: solid 0.2–0.75 mm2 Pollution degree 3 2 2 Conductor size: fine-stranded 0.2–0.75 mm2 Rated voltage 63 V 160 V 320 V Rated impulse voltage 2.5 kV 2.5 kV 2.5 kV Conductor size: fine-stranded 0.25–0.34 mm2 Rated current Approvals per 9A 9A 9A UL 1977 (with insulated ferrule) Conductor size: fine-stranded 0.25–0.34 mm2 (with uninsulated ferrule) Rated voltage, 1-pole 600 V AWG 24–18 Rated voltage, 2 or more poles 250 V Strip length 7–9 mm / 0.28–0.35 in. Rated current (UL) Pole No. 9A Item No. Pack. Unit SMD terminal blocks with push-buttons in tape-and-reel packaging, white 1 2060-451/998-404 13500 (9 x 1500) 2 3 2060-452/998-404 2060-453/998-404 9000 (9 x 1000) 6750 (9 x 750) Reel diameter: 330 mm > < 2.1 0.4 ___> < 2.2 III > 3.5 < (4) L = (pole no. x pin spacing) – 0.1 mm 0.4 > 2 < Overvoltage category CAGE CLAMP® S 1.2 Pin Spacing < 2060 Series, 4 mm Pin Spacing 0.4 ___> < 2060 SERIES 8 mm Pin Spacing Board-to-Board Link THR and Wave Soldering The 2-pole SMD terminal block with 8 mm pin spacing has been added to WAGO’s portfolio, providing higher rated voltages up to 630 V/6 kV/2 in LED and industrial applications. Besides standard wiring, several LED modules can be easily assembled into a single string using board-to-board connection links. This minimizes labor (no manual wiring) and materials needed for connecting LED modules. WAGO’s 2060 Series THR PCB Terminal Blocks with soldering pins are ideally suited for THR and wave soldering. The THR 2060 Series is available in light gray and black housings. For more information, go to www.wago.com/2060. Assembly: Place PCBs on a flat surface and connect terminal blocks on adjoining PCBs via board-to-board link. Disassembly: Pull PCBs apart (max. 10 connections/ disconnections). The PCBs must be secured. Pin Spacing 4 mm / 0.157 in. Pole No. Ratings per IEC/EN 60664-1 Board-to-board Overvoltage category III Pollution degree III II push-buttons Item No. Pack. Unit link for SMD terminal blocks with 3 2 2 Rated voltage 63 V 160 V 320 V 1 2060-901 1500 Rated impulse voltage 2.5 kV 2.5 kV 2.5 kV 2 2060-902 500 3 2060-903 375 Rated current 9A 9A 9A > 4.5 < 2060 Series, Board-to-Board Link > min. 4.4 … max. 5.4 min. 4.4 … max. 5.4 Rated voltage 2 0.4 ___> < > < 2.1 > III > 3.5 < ( 4 ) 0.4 > 2 < CAGE CLAMP® S Connection technology 1.2 > 2.2 < > 4.5 < 0.55 ____> < 1.6 < AWG Item No. SMD terminal blocks with push-buttons in tape-and-reel packaging, white 1 2061-601/998-404 8100 (9 x 900) 2 3 2061-602/998-404 2061-603/998-404 1.8 Pack. Unit 6300 (9 x 700) 4050 (9 x 450) ) Pole No. Reel diameter: 330 mm > Conductor size: solid > 4.6 < L = (pole no. x pin spacing) – 0.3 mm 0.4 > 2.4 < III > 2.1 < III < 5.6 > Overvoltage category < CAGE CLAMP® S > Connection technology 3.2 Pin Spacing _> 2.7 < 0888-0158/0100-6901 - SMD FAMILY BROCHURE 1.0 US - 03/2015 - Printed in Germany - Subject to design changes www.wago.com/SMD WAGO Kontakttechnik GmbH & Co. KG Postfach 2880 · D-32385 Minden Hansastraße 27 · D-32423 Minden Phone: Headquarters +49 571/887 - 0 Sales +49 571/887 - 222 Order Service +49 571/887 - 333 Fax: +49 571/887 - 169 Email: info@wago.com Online: www.wago.com
2060-852/998-404 价格&库存
很抱歉,暂时无法提供与“2060-852/998-404”相匹配的价格&库存,您可以联系我们找货
  • 750+6.52188750+0.84536
  • 1500+6.170601500+0.79983
  • 2250+6.001012250+0.77785
  • 3750+5.819523750+0.75432
  • 5250+5.717125250+0.74105
  • 7500+5.621527500+0.72866
库存:2981
2060-852/998-404
  • 1+15.679131+2.03232
  • 10+11.3364810+1.46943
  • 25+9.8723125+1.27964
  • 50+8.9264550+1.15704
  • 100+8.12577100+1.05326
  • 250+7.27362250+0.94280
库存:2981
2060-852/998-404
  • 75+11.5656975+1.49914
  • 250+8.01399250+1.03877
  • 750+7.62030750+0.98774
库存:1000
2060-852/998-404
  • 65+5.2216465+0.67683
库存:65
2060-852/998-404
  • 65+5.3127265+0.68863
库存:65
