2086-1223/300-000
2086-1223/300-000
    WAGO(万可电子)
    插件,P=3.5mm
    接线端子 间距:3.50mm 每排针脚数:3 排数:单排
2086-1223/300-000 数据手册
Data sheet | Item number: 2086-1223/300-000 THR PCB terminal block; push-button; 1.5 mm²; Pin spacing 3.5 mm; 3-pole; Push-in CAGE CLAMP®; Solder pin length 1.5 mm; 1,50 mm²; black www.wago.com/2086-1223/300-000 Color: Dimensions in mm L = (pole no. – 1) x pin spacing + 4.2 mm Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 1/9 Data sheet | Item number: 2086-1223/300-000 www.wago.com/2086-1223/300-000 Dimensions in mm A = even number of poles B = odd number of poles Item description Ideal for compact device connection, panel feedthrough and tight spaces Push-in CAGE CLAMP® allows push-in termination of solid and fine-stranded conductors with ferrules SMD and THR variants available Delivery in tape-and-reel packaging for full integration into SMT soldering process Push-button moves in direction of conductor connection Conductor connection and mating direction both parallel and perpendicular to the PCB Choice of double pin spacing or alternating pin spacing, 3.5 and 5 mm pin spacing Data Electrical data Ratings per IEC/EN Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 250 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 320 V Rated surge voltage (III/2) 4 kV Nominal voltage (II/2) 630 V Rated surge voltage (II/2) 4 kV Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 2/9 Data sheet | Item number: 2086-1223/300-000 www.wago.com/2086-1223/300-000 Rated surge voltage (II/2) 4 kV Rated current 17.5 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Ratings per UL Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group C) 300 V Rated current UL (Use Group C) 10 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Ratings per CSA Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Connection data Total number of potentials 3 Number of connection types 1 Number of levels 1 Connection 1 Connection technology Push-in CAGE CLAMP® Actuation type Push-button Solid conductor 0.14 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor 0.14 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 0.75 mm² Fine-stranded conductor; with uninsulated ferrule 0.25 … 1.5 mm² Conductor diameter 24 … 16 AWG Strip length 8 … 9 mm / 0.31 … 0.35 inch Conductor connection direction to PCB 0  ° Pole No. 3 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 3/9 Data sheet | Item number: 2086-1223/300-000 www.wago.com/2086-1223/300-000 Physical data Pin spacing 3.5 mm / 0.138 inch Width 11.2 mm / 0.441 inch Height 9.3 mm / 0.366 inch Height from the surface 7.8 mm / 0.307 inch Depth 13.6 mm / 0.535 inch Solder pin length 1.5 mm Solder pin dimensions 0.3 x 0.8 mm Plated through-hole diameter (THR) 1 (+0.1) mm PCB contact PCB Contact THR Solder pin arrangement over the entire terminal strip (staggered) Number of solder pins per potential 1 Material data Color black Insulation material Polyphthalamide (PPA GF) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Weight 1.5 g Environmental requirements Limit temperature range -60 … +105 °C Commercial data PU (SPU) 288 Stück Packaging type BOX Country of origin CH GTIN 4055144094091 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 4/9 Data sheet | Item number: 2086-1223/300-000 www.wago.com/2086-1223/300-000 Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. IEC 60947-7-4 NL-74022 CSA DEKRA Certification B.V. C22.2 80060692 KEMA/KEUR DEKRA Certification B.V. EN 60947-7-4 71119449 Optional accessories Testing and measuring     Testing accessories Item no.: 735-500 Test pin; 1 mm Ø; with solder connection for test wire www.wago.com/735-500 Item no.: 859-500 Test pin; 1 mm Ø; with solder connection for test wire www.wago.com/859-500 Tool     Operating tool Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-101 Item no.: 216-104 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored www.wago.com/216-104 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-142 Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-142 Ferrule     Ferrule Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/216-132 Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 5/9 Data sheet | Item number: 2086-1223/300-000 www.wago.com/2086-1223/300-000 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-121 Item no.: 216-143 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-143 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored www.wago.com/216-131 Item no.: 216-141 Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-141 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-144 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92; silver-colored www.wago.com/216-144 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 THR Soldering Process pdf 2.0 MB Download pdf 548.2 kB Download Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 6/9 Data sheet | Item number: 2086-1223/300-000 www.wago.com/2086-1223/300-000 CAD/CAE-Data CAD data 2D/3D Models 2086-1223/300-000 URL Download URL Download URL Download CAE data ZUKEN Portal 2086-1223/300-000 Environmental Product Compliance Compliance Search Environmental Product Compliance 2086-1223/300-000 THR PCB terminal block; push-button; 1.5 mm²; Pin spacing 3.5 mm; 3-pole; Push-in CAGE CLAMP®; Solder pin length 1.5 mm; 1,50 mm²; black Installation Notes Conductor termination Inserting solid conductor via push-in termination. Conductor removal Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 7/9 Data sheet | Item number: 2086-1223/300-000 www.wago.com/2086-1223/300-000 Removing fine-stranded conductors via push-buttons. Conductor termination Inserting and removing fine-stranded conductors via push-buttons. Testing Testing via 1 mm Ø test pin. Touch contact with current bar. Marking Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 8/9 Data sheet | Item number: 2086-1223/300-000 www.wago.com/2086-1223/300-000 Pole marking via direct marking perpendicular to conductor entry. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 13.09.2021    Page 9/9
2086-1223/300-000 价格&库存
很抱歉,暂时无法提供与“2086-1223/300-000”相匹配的价格&库存,您可以联系我们找货
