209-666
209-666
    WAGO(万可电子)
    连接器 标签,卡入式 用于 5mm 宽接线板
209-666 数据手册
Printview: WSB quick marking system; Vertical marking; 1 ... 50 (2x); for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card; consecutive numbers each strip - Item No.: 209-666 . WSB quick marking system; Vertical marking; 1 ... 50 (2x); for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card; consecutive numbers each strip Item No.: 209-666 . WSB quick marking system; Vertical marking; 1 ... 50 (2x); for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card; consecutive numbers each strip . Marking . Business data Supplier WAGO Item no. 209-666 GTIN / EAN 4017332273442 Content 1 Order amount 5 Customer item number . Notes Technical data Miscellaneous Color white Fire load [MJ] 0.234 [MJ] Weight [g] 7.8 [g] Printing direction Vertical marking WAGO Kontakttechnik GmbH & Co. KG 1 Printview: WSB quick marking system; Vertical marking; 1 ... 50 (2x); for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card; consecutive numbers each strip - Item No.: 209-666 Images & drawings . WAGO Kontakttechnik GmbH & Co. KG 2 Printview: WSB quick marking system; Vertical marking; 1 ... 50 (2x); for terminal block width 5 - 17.5 mm; 10 strips with 10 markers per card; consecutive numbers each strip - Item No.: 209-666 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 3
209-666 价格&库存
很抱歉,暂时无法提供与“209-666”相匹配的价格&库存,您可以联系我们找货
    • 5+74.82967
    库存:65
