231-139/001-000
231-139/001-000
    WAGO(万可电子)
231-139/001-000 数据手册
Data sheet  |  Item number: 231-139/001-000 THT male header; 1.0 x 1.0 mm solder pin; straight; Pin spacing 5 mm; 9pole; gray www.wago.com/231-139/001-000 Color: L = (pole no. – 1) x pin spacing + 8.2 mm Item description 13.09.2019    Page 1/5 Data sheet  |  Item number: 231-139/001-000 www.wago.com/231-139/001-000 Horizontal or vertical PCB mounting via straight or angled solder pins Pin cross-section: 1 x 1 mm With coding fingers Safety information 1: The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 320 V Rated impulse voltage (III / 3) 4 kV Rated voltage (III / 2) 320 V Rated impulse voltage (III / 2) 4 kV Rated voltage (II / 2) 630 V Rated impulse voltage (II / 2) 4 kV Rated current 12 A Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Approvals per UL 1977 Rated voltage per UL 1977 (factory wiring only) 600 V Rated current per UL 1977 (factory wiring only) 10 A Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Connection data Total number of potentials 9 Number of connection types 1 13.09.2019    Page 2/5 Data sheet  |  Item number: 231-139/001-000 www.wago.com/231-139/001-000 Number of connection types 1 Number of levels 1 No. of poles 9 Geometrical Data Pin spacing 5 mm / 0.197 inch Width 48.2 mm / 1.898 inch Height 17 mm / 0.669 inch Height from the surface 12 mm / 0.472 inch Depth 8.4 mm / 0.331 inch Solder pin length 5 mm Solder pin dimensions 1 x 1 mm Drilled hole diameter (tolerance) 1.4(- … +0.1) mm Plug connection Contact type (pluggable connector) Male connector/plug Connector connection type for PCBs Mismating protection No Mating direction to the PCB 90 ° PCB contact PCB contact THT Solder pin arrangement over the entire male connector, in line Number of solder pins per potential 1 Material Data Color gray Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.051 MJ Weight 3.01 g Environmental Requirements Limit temperature range -60 … +100 °C 13.09.2019    Page 3/5 Data sheet  |  Item number: 231-139/001-000 www.wago.com/231-139/001-000 Commercial data Product Group 3 (Multi Conn. System) Country of origin DE GTIN 4044918863438 Customs Tariff No. 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. IEC 61984 NL-39756 CSA DEKRA Certification B.V. C22.2 1466354 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping - 19HG1869876PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE000016Z UL-Approvals Logo Certificate name Approval Additional Approval Text UL Underwriters Laboratories Inc. UL 1059 E4517219911118 UR UL International Germany GmbH UL 1977 E45171 Compatible products Coding 13.09.2019    Page 4/5 Data sheet  |  Item number: 231-139/001-000 www.wago.com/231-139/001-000 Coding Item no.: 231-129 Coding key; snap-on type; light gray www.wago.com/231-129 Item no.: 231-500 Spacer; for formation of groups; light gray www.wago.com/231-500 Marking accessories Item no.: 210-833 Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white www.wago.com/210-833 Item no.: 210-834 Marking strips; on reel; 5 mm wide; plain; Self-adhesive; white www.wago.com/210-834 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data CAD data 3D Download 231-139/001-000 EPLAN EPLAN Data Portal 231-139/001-000 Download   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.09.2019    Page 5/5
231-139/001-000 价格&库存
很抱歉,暂时无法提供与“231-139/001-000”相匹配的价格&库存,您可以联系我们找货
    • 1+21.00471
    库存:90
