231-365/001-000
231-365/001-000
    WAGO(万可电子)
    插件,P=5.08mm
231-365/001-000 数据手册
Data sheet from 23.11.2010 Item no.: 231-365/001-000 Product description: Header straight solder pin, 1.2 x 1.2 mm /0.047 x 0.047 in 5 pole pin spacing 5.08 mm / 0.2 in mating direction perpendicular to pcb with closed end Produkt kann von Bild abweichen / product may differ Packing unit 200 4*50 pieces Product group 3 (Multi Conn. System) Weight 2.09 g Color orange pole count 5 Height 12 mm Height 0.472 in Width 28.6 mm Width 1.126 in Depth 8.4 mm Depth 0.331 in Pin spacing from 5.08 mm Pin spacing from 0.2 in Rating based on IEC/EN 60664-1 Overvoltage category EN I III Pollution degree 2 Measured voltage EN 320 V Measured shock voltage 4 kV Current intensity EN 12 A Overvoltage category EN II II 1 von 4 Pollution degree 2 Measured voltage EN 630 V Measured shock voltage 4 kV 2 von 4 Data sheet from 23.11.2010 Current intensity EN 12 A Overvoltage category EN III III Degree of pollution 3 Rated voltage EN 320 V Rated surge voltage 4 kV Nominal current 12 A Solder pin length [mm] 5 mm Solder pin width A [mm] 1.2 mm Solder pin width B [mm] 1.2 mm Diameter of drilled hole [mm] 1.7 mm Tolerance of drilled hole diameter [mm] 0.1 mm Material group I Insulating material PA 6.6 Temperature stability -60 °C to +100 °C Flammability category, based on UL 94 V0 Contact material Electrolytic copper (Ecu) Contact plating tin-plated 3 von 4 Data sheet from 23.11.2010 Item number Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 231-365/001-000 ABS 04-HG469925/1-PDA 400 12 0,8-2,5 231-365/001-000 BV 11915/A0 400 16 2,5 231-365/001-000 CCA 5764 250 16 1,2x,21 231-365/001-000 CSA 154112-1466354 300 15 231-365/001-000 GL 17296-00HH 400 12 0,8-2,5 231-365/001-000 KEMA 2083746.02 250 16 1,2x,21 231-365/001-000 KR HMB05880-EL003 250/400 12/16 2,5 231-365/001-000 LR 96/20035 400 12 0,8-2,5 231-365/001-000 RMR 11130002 400 12 0,8-2,5 231-365/001-000 UR E45171 600 15 231-365/001-000 UR E45172 300/150/300 15/15/10 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 4 von 4
231-365/001-000 价格&库存
很抱歉,暂时无法提供与“231-365/001-000”相匹配的价格&库存,您可以联系我们找货
