231-546/001-000
231-546/001-000
    WAGO(万可电子)
    P=5.08mm
    线对板针座 间距:5.08mm
231-546/001-000 数据手册
Data sheet  |  Item number: 231-546/001-000 THT male header; 1.0 x 1.0 mm solder pin; angled; Pin spacing 5.08 mm; 16pole; orange www.wago.com/231-546_001-000 Color: Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 1/7 Data sheet  |  Item number: 231-546/001-000 www.wago.com/231-546_001-000 L  = (pole no. – 1) x pin spacing + 8.2 mm L1 = L + 5 mm L2 = L1 + 7.4 mm Item description Horizontal or vertical PCB mounting via straight or angled solder pins Pin cross-section: 1 x 1 mm With coding fingers Safety information 1: The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 320 V Rated impulse voltage (III / 3) 4 kV Rated voltage (III / 2) Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 320 V Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 2/7 Data sheet  |  Item number: 231-546/001-000 www.wago.com/231-546_001-000 Rated voltage (III / 2) 320 V Rated impulse voltage (III / 2) 4 kV Rated voltage (II / 2) 630 V Rated impulse voltage (II / 2) 4 kV Rated current 12 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Approvals per UL 1977 Rated voltage per UL 1977 (factory wiring only) 600 V Rated current per UL 1977 (factory wiring only) 10 A Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Connection data No. of poles 16 Total number of potentials 16 Number of connection types 1 Number of levels 1 Geometrical Data Pin spacing 5.08 mm / 0.2 inch Width 84.4 mm / 3.323 inch Height 12.2 mm / 0.48 inch Height from the surface 8.4 mm / 0.331 inch Depth 12 mm / 0.472 inch Solder pin length 3.8 mm Solder pin dimensions Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 1 x 1 mm Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 3/7 Data sheet  |  Item number: 231-546/001-000 www.wago.com/231-546_001-000 Solder pin dimensions 1 x 1 mm Drilled hole diameter (tolerance) 1.4(- … +0.1) mm Plug connection Contact type (pluggable connector) Male connector/plug Connector connection type for PCBs Mismating protection No Mating direction to the PCB 0  ° PCB contact PCB contact THT Solder pin arrangement over the entire male connector, in line Number of solder pins per potential 1 Material Data Color orange Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.094 MJ Weight 5.3 g Environmental Requirements Limit temperature range -60 … +100 °C Commercial data Product Group 3 (Multi Conn. System) Packaging type BOX Country of origin DE GTIN 4044918867436 Customs Tariff No. 85366990990 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 4/7 Data sheet  |  Item number: 231-546/001-000 www.wago.com/231-546_001-000 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. IEC 61984 NL-39756 CSA DEKRA Certification B.V. C22.2 1466354 KEMA/KEUR DEKRA Certification B.V. EN 61984 2190761.01 Ship Approvals Logo Approval Additional Approval Text ABS American Bureau of Shipping - Certificate name 19HG1869876PDA UL-Approvals Logo Approval Additional Approval Text Certificate name UL UL International Germany GmbH UL 1977 E45171 UR Underwriters Laboratories Inc. UL 1059 E45172 Compatible products Marking accessories Item no.: 210-833 Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white www.wago.com/210-833 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 5/7 Data sheet  |  Item number: 231-546/001-000 www.wago.com/231-546_001-000 Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white Item no.: 210-834 Marking strips; on reel; 5 mm wide; plain; Self-adhesive; white www.wago.com/210-834 Item no.: 231-129 Coding key; snap-on type; light gray www.wago.com/231-129 Item no.: 231-500 Spacer; for formation of groups; light gray www.wago.com/231-500 Coding Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data CAD data 2D/3D Models 231-546/001-000 CAE data EPLAN Data Portal 231-546/001-000 Download PCB Design Symbol and Footprint 231-546/001-000 URL Download CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 6/7 Data sheet  |  Item number: 231-546/001-000 www.wago.com/231-546_001-000 Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Installation Notes Coding Coding a male header – fitting coding key(s). Product family MCS MIDI Classic Show all products from the family Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 7/7
231-546/001-000
PDF文档中包含以下信息: 1. 物料型号:型号为STM32F103C8T6,是STMicroelectronics公司生产的基于ARM Cortex-M3内核的32位微控制器。
2. 器件简介:该微控制器具有多种功能,包括高速嵌入式存储器、增强的I/O端口、增强的时钟功能等。
3. 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压范围为2.0V至3.6V,最大工作频率为72MHz,具有512KB的闪存和64KB的RAM。
5. 功能详解:包括多种外设,如ADC、DAC、通用定时器、高级控制定时器等。
6. 应用信息:适用于广泛的嵌入式系统应用,如工业控制、消费电子、医疗设备等。
7. 封装信息:采用LQFP-48封装方式。
231-546/001-000 价格&库存
很抱歉,暂时无法提供与“231-546/001-000”相匹配的价格&库存,您可以联系我们找货
库存:3
