Data sheet from 03.02.2009
Item no.:
231-606/019-000
Product description:
MALE CONNECTOR; WITH FIXING FLANGE; 6 POLE; PIN
SPACING 5 MM / 0.197 IN; CAGE CLAMP®CONNECTION;
FOR SCREW OR SIMILAR MOUNTING TYPES
Packing unit 50 pieces
Product group
3 (Multi Conn. System)
Pin spacing from
5 mm
Pin spacing from
0,197 in
pole count
6
Cross section from [mm²]
0,08 mm²
Cross section to [mm²]
2,5 mm²
Cross section from [AWG]
28 AWG
Cross section to [AWG]
12 AWG
Connection method
Measured voltage EN
250 V
Measured shock voltage
4 kV
Pollution degree
3
Current intensity EN
12 A
Weight
10,21 g
Color
grey
No. of connection Points
6
No. of potentials
6
Height
14,3 mm
Height
0,563 in
Width
44,8 mm
Width
1,764 in
Depth
27,5 mm
1 von 3
Depth
1,083 in
Strip length from
8 mm
Strip length to
9 mm
Strip length
0,33 in
2 von 3
Item number
Admission office
Approval no.
Voltage [V]
Current [A]
Cross section [ mm² ]
231-606/019-000
BV
11915/A0
400
16
2,5
231-606/019-000
CCA
5764
250
12
0,08-2,5
231-606/019-000
CSA
154112-1466354
300
15
22-12
231-606/019-000
DEMKO
88126
250
231-606/019-000
KEMA
2083746.02
250
12
0,08-2,5
231-606/019-000
KR
HMB05880-EL003
250/400
12/16
2,5
231-606/019-000
NEMKO
P94101840
250
231-606/019-000
UR
E45171
600
15
12
231-606/019-000
UR
E45172
300
15
22-12
Sorting criteria: admission office - approval number
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
3 von 3
2,5
2,5
很抱歉,暂时无法提供与“231-606/019-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+111.707111+14.44464
