250-110
250-110
    WAGO(万可电子)
250-110 数据手册
Data sheet | Item number: 250-110 PCB terminal block; push-button; 1.5 mm²; Pin spacing 3.5 mm; 10-pole; Push-in CAGE CLAMP®; 1,50 mm²; gray www.wago.com/250-110 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.11.2021    Page 1/11 Data sheet | Item number: 250-110 www.wago.com/250-110 Dimensions in mm L = (pole no. x pin spacing) + 1.5 mm Item description Compact terminal strips with push-buttons Push-in terminations of solid and ferruled conductors Termination/removal of fine-stranded conductors via push-buttons 45° conductor entry angle provides easy, space-saving wiring Custom color combinations Terminal strips also available with spacers upon request Data Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.11.2021    Page 2/11 Data sheet | Item number: 250-110 www.wago.com/250-110 Data Notes Variants: Other pole numbers Other colors Mixed-color PCB connector strips Terminal strips with spacers Direct marking Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/ Electrical data Ratings per IEC/EN Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 160 V Rated surge voltage (III/3) 2.5 kV Rated voltage (III/2) 160 V Rated surge voltage (III/2) 2.5 kV Nominal voltage (II/2) 320 V Rated surge voltage (II/2) 2.5 kV Rated current 8  A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Ratings per UL Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 5  A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 5  A Ratings per CSA Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.11.2021    Page 3/11 Data sheet | Item number: 250-110 www.wago.com/250-110 Connection data Total number of connection points 10 Total number of potentials 10 Number of connection types 1 Number of levels 1 Connection 1 Connection technology Push-in CAGE CLAMP® Actuation type Push-button Solid conductor 0.2 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor 0.2 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 1 mm² Fine-stranded conductor; with uninsulated ferrule 0.25 … 1 mm² Strip length 8.5 … 9.5 mm / 0.33 … 0.37 inch Conductor connection direction to PCB 45 ° Pole No. 10 Physical data Pin spacing 3.5 mm / 0.138 inch Width 36.5 mm / 1.437 inch Height 16.7 mm / 0.657 inch Height from the surface 13.1 mm / 0.516 inch Depth 12 mm / 0.472 inch Solder pin length 3.6 mm Solder pin dimensions 0.4 x 0.75 mm Drilled hole diameter with tolerance 1 (+0.1) mm PCB contact PCB Contact THT Solder pin arrangement over the entire terminal strip (in-line) Number of solder pins per potential 1 Material data Color gray Material group I Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.11.2021    Page 4/11 Data sheet | Item number: 250-110 www.wago.com/250-110 Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.106 MJ Weight 4.7 g Environmental requirements Limit temperature range -60 … +105 °C Commercial data Product Group 4 (Printed Circuit) PU (SPU) 120 (30) Stück Packaging type box Country of origin CH GTIN 4044918647731 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60998 NTR NL7449 CCA DEKRA Certification B.V. EN 60947 NTR NL7100 CSA DEKRA Certification B.V. C22.2 1132097 KEMA/KEUR DEKRA Certification B.V. EN 60998 71-105258 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.11.2021    Page 5/11 Data sheet | Item number: 250-110 www.wago.com/250-110 KEMA/KEUR DEKRA Certification B.V. EN 60947 2160584.18 VDE VDE Prüf- und Zertifizierungsinstitut EN 60998 40028888 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping - 19HG1869876PDA BV Bureau Veritas S.A. IEC 60998 11915/D0 BV DNV GL Det Norske Veritas, Germanischer Lloyd - TAE000016Z UL-Approvals Logo Approval Additional Approval Text Certificate name UL UL International Germany GmbH UL 1059 E45172 Optional accessories Testing and measuring     Testing accessories Item no.: 735-500 Test pin; 1 mm Ø; with solder connection for test wire www.wago.com/735-500 Ferrule     Ferrule Item no.: 216-101 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.11.2021    Page 6/11 Data sheet | Item number: 250-110 www.wago.com/250-110 Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-101 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-123 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored www.wago.com/216-123 Item no.: 216-122 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-122 Item no.: 216-142 Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-142 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-121 Item no.: 216-143 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-143 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored www.wago.com/216-131 Item no.: 216-141 Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-141 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-203 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-223 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-223 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.11.2021    Page 7/11 Data sheet | Item number: 250-110 www.wago.com/250-110 crimped; acc. to DIN 46228, Part 4/09.90; white Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-222 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-222 Item no.: 216-221 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-221 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; light turquoise www.wago.com/216-302 Tool     Operating tool Item no.: 210-657 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured www.wago.com/210-657 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Marking accessories     Marking strip Item no.: 210-332/350-202 www.wago.com/210-332 Marking strips; as a DIN A4 sheet; MARKED; 1-16 (240x); Height of marker strip: 3 mm; Strip length 182 /350-202 mm; Horizontal marking; Self-adhesive; white Item no.: 210-332/350-206 Marking strips; as a DIN A4 sheet; MARKED; 33-48 (240x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /350-206 Item no.: 210-332/350-204 Marking strips; as a DIN A4 sheet; MARKED; 17-32 (240x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /350-204 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.11.2021    Page 8/11 Data sheet | Item number: 250-110 www.wago.com/250-110 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download pdf 125.0 kB Download URL Download EPLAN Data Portal 250-110 URL Download ZUKEN Portal 250-110 URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 250-110 CAE data PCB Design Symbol and Footprint 250-110 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.11.2021    Page 9/11 Data sheet | Item number: 250-110 www.wago.com/250-110 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Environmental Product Compliance Compliance Search Environmental Product Compliance 250-110 URL Download PCB terminal block; push-button; 1.5 mm²; Pin spacing 3.5 mm; 10-pole; Push-in CAGE CLAMP®; 1,50 mm²; gray Installation Notes Conductor termination Inserting solid conductors via push-in termination. Inserting fine-stranded conductors via pushbuttons, 250 Series – 3.5 mm pin spacing. Conductor termination Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.11.2021    Page 10/11 Data sheet | Item number: 250-110 www.wago.com/250-110 Space-saving wiring, 250 Series – 5 mm pin spacing. Testing Testing with 11 mm Ø test pin, on the conductor, 250 Series – 2.5 … 3.5 mm pin spacing. Testing with 2 mm Ø test plug, touch contact, 250 Series – 5 mm pin spacing. Marking Labeling via self-adhesive strips or direct marking. Mixed-color terminal strips (with or without spacer) are available upon request. Labeling via self-adhesive strips or direct marking. Mixed-color terminal strips (with or without spacer) are available upon request. Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.11.2021    Page 11/11
250-110 价格&库存
很抱歉,暂时无法提供与“250-110”相匹配的价格&库存,您可以联系我们找货
