Data sheet | Item number: 264-204
4-conductor terminal strip; 4-pole; without push-buttons; with fixing flanges;
for screw or similar mounting types; Fixing hole 3.2 mm Ø; 2.5 mm²; CAGE
CLAMP®; 2,50 mm²; gray
www.wago.com/264-204
i
Picture differs from the item.
Color:
Data
Electrical data
Ratings per IEC/EN
Nominal voltage (III/3)
800 V
Rated surge voltage (III/3)
8 kV
Rated current
24 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
16.03.2021 Page 1/11
Solid conductor
Fine-stranded conductor
Note (conductor cross-section)
12 AWG: THHN, THWN
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Pole No.
4
Total number of connection points
16
Total number of potentials
4
Number of levels
1
Wiring type
Front-entry wiring
Physical data
Width
56 mm / 2.205 inch
Height from the surface
22.1 mm / 0.87 inch
Depth
32 mm / 1.26 inch
Module width
10 mm / 0.394 inch
Mechanical data
Design
horizontal type
Mounting type
Mounting flange
Marking level
Center marking
Material data
Color
gray
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Fire load
0.514 MJ
Weight
27 g
Commercial data
Packaging type
BOX
Country of origin
DE
GTIN
4044918418683
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Hansastr. 27
32423 Minden
Certificate
16.03.2021 Page 2/11
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
EN 60998
NL-49768
CCA
EN 60998
NTR NL7342
CCA
EN 60998
2175624.01
CSA
C22.2
70010891
Approval
ABS
American Bureau of Shipping
19HG1869868PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
LR
Lloyds Register
IEC 60998
91/20242
(E7)
Logo
Ship Approvals
Logo
Certificate
name
UL-Approvals
Logo
Approval
UR
Underwriters Laboratories Inc.
UL 1059
Certificate
name
20180629E45172
Hansastr. 27
32423 Minden
16.03.2021 Page 3/11
Compatible products
check
Item no.: 210-136
Test plug; 2 mm Ø; with 500 mm cable; red
www.wago.com/210-136
Item no.: 210-137
Test plug; 2.3 mm Ø; with 500 mm cable; yellow
www.wago.com/210-137
Item no.: 249-139
Test plug module; without locking device; modular; for 4-conductor terminal blocks; gray
www.wago.com/249-139
Item no.: 209-130
Operating tool; suitable for 264, 280 and 281 Series; 1-way; of insulating material; white
www.wago.com/209-130
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured
www.wago.com/210-657
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured
www.wago.com/210-658
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
Item no.: 280-432
Operating tool; made of insulating material; 2-way; white
www.wago.com/280-432
Item no.: 709-153
Cover; Type 1; suitable for cover carrier, type 1; 1 m long; transparent
www.wago.com/709-153
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-106
Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-106
Item no.: 216-121
www.wago.com/216-121
tools
assembling
ferrule
Item no.: 216-122
Hansastr. 27
32423 Minden
www.wago.com/216-122
16.03.2021 Page 4/11
Item no.: 216-122
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-123
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-205
Ferrule; Sleeve for 2.08 mm² / AWG 14; insulated; electro-tin plated; yellow
www.wago.com/216-205
Item no.: 216-206
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; blue
www.wago.com/216-206
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-321
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-321
Item no.: 216-322
Hansastr. 27
32423 Minden
www.wago.com/216-322
16.03.2021 Page 5/11
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
Jumper
Item no.: 264-402
Jumper; for conductor entry; 2-way; insulated; gray
www.wago.com/264-402
Item no.: 280-492
Jumper; 2-way; insulated; gray
www.wago.com/280-492
Marking accessories
Item no.: 2009-145
www.wago.com/2009-145
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
Item no.: 2009-145/000-002
yellow
/000-002
Item no.: 2009-145/000-005
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-145/000-006
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006
Item no.: 2009-145/000-007
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007
Item no.: 2009-145/000-012
orange
/000-012
Item no.: 2009-145/000-023
green
/000-023
Item no.: 2009-145/000-024
violet
/000-024
Item no.: 209-290
Marker tags; not stretchable; plain; snap-on type; white
www.wago.com/209-290
Item no.: 248-501
Miniature WSB Quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card
www.wago.com/248-501
Item no.: 248-501/000-002
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 248-501/000-005
Hansastr. 27
32423 Minden
16.03.2021 Page 6/11
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 248-501/000-006
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 248-501/000-007
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 248-501/000-012
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 248-501/000-017
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 248-501/000-023
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 248-501/000-024
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Downloads
Documentation
Bid Text
264-204
2017 Jun 14
doc
25.1 kB
Download
2019 Feb 19
xml
3.3 kB
Download
2019 Apr 3
pdf
2.2 MB
Download
URL
Download
doc - Datei
264-204
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 264-204
Hansastr. 27
32423 Minden
16.03.2021 Page 7/11
CAE data
EPLAN Data Portal 264-204
URL
Download
WSCAD Universe 264-204
URL
Download
ZUKEN Portal 264-204
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 264-204
4-conductor terminal strip; 4-pole; without push-buttons; with fixing flanges; for
screw or similar mounting types; Fixing hole 3.2 mm Ø; 2.5 mm²; CAGE CLAMP®; 2,50
mm²; gray
Installation Notes
Installation
Assembling modular terminal blocks into
terminal strips.
Mounting an “end terminal block“ with
mounting flange.
Mounting an end plate.
Hansastr. 27
32423 Minden
16.03.2021 Page 8/11
Removing a terminal block.
Conductor termination
CAGE CLAMP® connection
Inserting a conductor.
With ferruled conductors, it is necessary to
use a terminal block one size smaller than
the conductor's nominal cross-section.
Commoning
Commoning with comb-style jumper bar.
Testing
Hansastr. 27
32423 Minden
16.03.2021 Page 9/11
Testing
Testing by touch contact to the CAGE
CLAMP® spring (limited to 0.5 A and 48 V
test voltage) – test pins are not protected
against accidental contact.
Testing via CAGE CLAMP® on the current bar
(max. nominal current: 6 A).
CAGE CLAMP® clamps individual test
contacts.
The maximum test voltage is 400 V.
Terminal strip with mounting flanges:
End plate with mounting flange
Center terminal blocks
End terminal block with mounting
flange
Hansastr. 27
32423 Minden
16.03.2021 Page 10/11
Mounting and securing a terminal strip
directly to the plate via screw-type flanges.
Marking
Marking via Mini-WSB Quick Marking System.
Hansastr. 27
32423 Minden
16.03.2021 Page 11/11
很抱歉,暂时无法提供与“264-204”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+149.351691+19.34627
