Data sheet | Item number: 289-555
Interface module; with solder pin; Female connector; 9-pole; Mating
connector with solder connection; Vertical mounting; PCB terminal blocks,
double-row; in mounting carrier; 2,50 mm²
www.wago.com/289-555
Similiar to picture
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
06.06.2020 Page 1/6
Data
Electrical Data
Operating voltage
≤ AC/DC 125 V
Nominal current
2 A
Contact resistance (max.)
30 mΩ
Safety and protection:
Rated voltage
125 V
Rated surge voltage
0.8 kV
Pollution degree
2
Protection type
IP20
Connection data
Connection type (1)
System
Pole No.
9
Pluggable connectors
D-sub female connector
For mating connector
with solder contact
Mating direction
Vertical
Connection type 2
Field
Pole number 2
9
Design 2
PCB terminal blocks (double-row)
Hansastr. 27
32423 Minden
06.06.2020 Page 2/6
Pole number 2
9
Design 2
Connection technology 2
CAGE CLAMP®
WAGO Connector 2
WAGO 236 Series
Solid conductor 2
0,08 … 2,5 mm² / 28 … 12 AWG
Fine-stranded conductor 2
Strip length 2
5 … 6 mm / 0.2 … 0.24 inch
Note (conductor cross-section)
12 AWG: THHN, THWN
Performance level
2 / 200 mating cycles
Strain relief
UNC 4-40 stud bolt
Geometrical Data
Width
38 mm / 1.496 inch
Height from upper-edge of DIN-rail
34 mm / 1.339 inch
Depth
85 mm / 3.346 inch
Mechanical data
Mounting type
DIN-35 rail
Housing design
Mounting carrier
Material Data
Contact material (connector)
Au over Ni
Fire load
0.6 MJ
Weight
46.8 g
Environmental Requirements
Surrounding air temperature (operation)
-20 … 50 °C
Surrounding air temperature (storage)
-40 … 70 °C
Relative humidity
≤ 85% (non-condensing)
Operating altitude (max.)
2000 m
Standards and specifications
Standards/specifications
EN 61010-2-201; UL 840
Commercial data
Product Group
6 (Interface Electronics)
Packaging type
BOX
Hansastr. 27
32423 Minden
06.06.2020 Page 3/6
Packaging type
BOX
Country of origin
DE
GTIN
4045454371180
Customs tariff number
85369010000
Approvals / Certificates
UL-Approvals
Logo
Approval
Additional Approval Text
UL
Underwriters Laboratories Inc. (ORDINARY
LOCATIONS)
UL 508
Certificate
name
E175199
Vol.2 Sec.
1
Counterpart
Compatible products
tools
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft
www.wago.com/210-720
Marking accessories
Item no.: 709-177
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; translucent
www.wago.com/709-177
Item no.: 709-178
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; white
www.wago.com/709-178
Item no.: 709-196
Marking strips; for laser printer; translucent
www.wago.com/709-196
Item no.: 709-198
Marking strips; white
www.wago.com/709-198
Downloads
Documentation
Bid Text
289-555
Feb 6, 2015
doc
27.6 kB
Download
doc - Datei
Hansastr. 27
32423 Minden
06.06.2020 Page 4/6
27.6 kB
doc - Datei
Instruction Leaflet
pdf
1.3 MB
Download
pdf
265.8 kB
Download
URL
Download
EPLAN Data Portal 289-555
URL
Download
WSCAD Universe 289-555
URL
Download
Additional Information
Disposal; Electrical and electronic equipment, Packaging
V 1.0.0
CAD/CAE-Data
CAD data
2D/3D Models 289-555
CAE data
Handling Instructions
Conductor termination
Connection of conductor – Operating tool
actuation parallel to conductor entry.
actuation perpendicular to conductor entry.
Installation
Hansastr. 27
32423 Minden
06.06.2020 Page 5/6
Assembly of a module on the carrier rail
Removing a module from the DIN-rail.
Hansastr. 27
32423 Minden
06.06.2020 Page 6/6
很抱歉,暂时无法提供与“289-557”相匹配的价格&库存,您可以联系我们找货
