51012503
51012503
    WAGO(万可电子)
    CIRCUIT BREAKER, 24V,10A
51012503 数据手册
DIN Rail Mount Pluggable Thermal Circuit Breakers Conductor Range: AWG 24 - 10 AWG (stranded and solid) Terminal Block Width: Strip Length: l 8 mm / 0.315 in 12 - 13 mm / 0.49 in Electrical Specs: 600 V maximum* 25/30 A maximum* *Current / Voltage limited to circuit breaker specifications. Consult factory for other ratings. DIN rail mount pluggable miniature thermal circuit breakers are used for protection of power distribution systems, automation systems, and process control applications. These wide variety of circuit breakers have unique characteristics that tailor to the needs and performance of many different applications. The WAGO circuit breaker terminal block uses CAGE CLAMP® connection technology that reduces wiring time and provides a connection that is corrosion-resistant, temperature cycling resistant and maintenance-free. An excellent alternative to traditional fusing methods. Technical Data Voltage rating: Current ratings: Typical life: Ambient temperature: Insulation co-ordination: (IEC 60664 and 60664A) Insulation resistance: Description Thermal circuit breaker, plug-in type, push button reset 0.10 A AC 250 V DC 65 V 0.25 A AC 250 V DC 65 V 0.5 A AC 250 V DC 65 V 1.0 A AC 250 V DC 65 V 2.0 A AC 250 V DC 65 V 3.0 A AC 250 V DC 65 V 4.0 A AC 250 V DC 65 V 5.0 A AC 250 V DC 65 V 6.0 A AC 250 V DC 65 V 7.0 A AC 250 V DC 65 V 8.0 A AC 250 V DC 65 V 10.0 A AC 250 V DC 65 V Thermal circuit breaker, plug-in type, on-off switch, switching duty rated 0.10 A AC 250 V DC 65 V 0.25 A AC 250 V DC 65 V 0.5 A AC 250 V DC 65 V 1.0 A AC 250 V DC 65 V 2.0 A AC 250 V DC 65 V 3.0 A AC 250 V DC 65 V 4.0 A AC 250 V DC 65 V 5.0 A AC 250 V DC 65 V 6.0 A AC 250 V DC 65 V 7.0 A AC 250 V DC 65 V 8.0 A AC 250 V DC 65 V 10.0 A AC 250 V DC 65 V Item No. AC 250 V; DC 65 V 0.1...10 A 3,000 operations at 1 x IN (low-resistive) 500 operations at 2 x IN (inductive) -20...+60°C (T 60) -4...+140°F Rated impulse Pollution withstand voltage degree 2.5 kV 2 reinforced insulation in operating area >100 MΩ (DC 500 V) Interrupting capacity: Pack.-unit pcs Typical time/current characteristics at +23°C/+73.4° F 51014625 51011135 51011136 51011137 51011138 51011139 51011140 51017673 51011141 51014524 51011142 51011143 1 1 1 1 1 1 1 1 1 1 1 1 51012494 51012495 51012496 51012497 51012498 51012499 51012500 51012501 51014523 51012502 51012503 1 1 1 1 1 1 1 1 1 1 1 (UL 1077) Vibration: Shock: Corrosion: Humidity: AC 250 V: 2,000 A DC 65 V: 200 A 5 g (57-500 Hz) ±0.38 mm (10-57Hz) to IEC 60068-2-6, test Fc, 10 frequency cycles/axis 25 g (11 ms) to IEC 60068-2-27, test Ea 96 hours at 5% salt mist, to IEC 60068-2-11, test Ka 240 hours at 95% RH to IEC 60068-2-3, test Ca Technical Data Voltage rating: Current ratings: Typical life: Ambient temperature: Interrupting capacity ICN: DC 28 V Vibration 3...25 A (30 A upon request) 6,000 operations at IN 3,000 operations at 2 x IN ≤ 20 A 1,000 operations at 2 x IN 25 A Shock -30...+60°C (-22...140°F) 3...15 A 200 A 3...15 A 400 A Corrosion: 20...25 A 400 A Humidity: Description Item No. Miniaturized thermal automotive circuit breaker, color coded, manual release 15 A DC 28 V 20 A DC 28 V 25 A DC 28 V Miniaturized thermal automotive circuit breaker, on-off switch 15 A DC 28 V Pack.-unit pcs 51014338 51014339 51014340 1 1 1 51014689 1 3 or 4 A: 8 g (57-500 Hz) ±0.65 mm (10-57 Hz) 5...25 A: 10 g (57-500 Hz) ±0.76 mm (10-57 Hz), to IEC 60068-2-6, test Fc, 10 frequency cycles/axis 3 or 4 A: 35 g (11 ms) 5...25 A: 50 g (11 ms) to IEC 60068-2-27, test EA 96 hours at 5% salt mist, to IEC 60068-2-11, test Ka 240 hours at 95% RH to IEC 60068-2-3, test Ca Typical time/current characteristics at +23°C/+73.4° F Technical Data Voltage rating: Current ratings: Service short-circuit breaking capacity: Ambient temperature: Ultimate short-circuit breaking capacity: Item No. Description Thermal automotive circuit breaker, color coded housing, standard fuseblock mounting 15 A DC 28 V 20 A DC 28 V 25 A DC 28 V 30 A DC 28 V Base Terminal Blocks Item No. 51016020 51014617 51014618 51014619 DC 32 V 6...30 A Vibration: 300 operations at ≤ 50 A -30...+60°C (-22...140°F) Shock: (with mounting socket 12) ≥ 3 break operations at 150 A, or ≥ 1 break operation at 2,000 A Pack.-unit pcs Item No. End plate, 2 mm /0.079 in thick 282-333 orange 282-334 gray Description Humidity: Typical time/current characteristic curve Pack.-unit pcs Item No. Adjacent jumper, insulated, IN 41 A 282-402 gray 100 (4 x 25) 100 (4 x 25) Pack.-unit pcs Test plug adapter, for test plug 4 mm /0.157 in Ø 209-170 50 (2 x 25) Corrosion: 1 1 1 1 282-696 2-conductor circuit breaker terminal block, gray 282-698/281-413 ...with 24 V indicator, tripped circuit 51012247 ...with 110 V indicator, tripped circuit Accessories (with mounting socket 12) 5 g (57-500 Hz) ±0.38mm (10-57 Hz) to IEC 60068-2-6, Test Fc, 10 frequency cycles/axis 25 g (11 ms) to IEC 60068-2-27, Test Ea 96 hours at 5% salt. mist, to IEC 60068-2-11, test Ka 240 hours at 95% RH to IEC 60068-2-3, test Ca End stop, for DIN 35 rail 249-116 249-117 25 25 25 Pack.-unit pcs 100 (4 x 25) 100 (4 x 25) 50 (2 x 25) Item No. Alternate jumper, insulated, IN 41 A 282-409 gray Pack.-unit pcs 100 (4 x 25) DIN Rail, 35 mm x 7.5 mm, slotted, 2 M long 210-112 10 WAGO Service Worldwide Germany WAGO Kontakttechnik Minden Tel. ++0571/887-443 Fax ++0571/887-541 Belgium WAGO Kontakttechnik Zaventem Tel. ++32/2/7 17 90 90 Fax ++32/2/7 17 90 99 China WAGO ELECTRONIC Co. Ltd. Tianjin Tel. ++86/22/82125854/64/74 Fax ++86/22/82125984 England WAGO, Ltd. Rugby Tel. ++44/1788/568008 Fax ++44/1788/568050 51011218 0888-0832/0000-0048 rev3 0 Austria WAGO Kontakttechnik GmgH Wien Tel. ++43/1/615 07 80 Fax ++43/1/615 07 75 France WAGO CONTACT SA. Paris Tel. ++33/148172590 Fax ++33/148632520 Italy WAGO ELETTRONICA SRL San Lazzaro di Savena (BO) Tel. ++39/051/625-91-25 Fax ++39/051/625-91-27 Japan WAGO Co. of JAPAN Ltd. Tokyo Tel. ++81/3/3254/8881 Fax ++81/3/3254/8885 Poland WAGO ELWAG sp. z o. o. Wroclaw Tel. ++48/71/33-66-626 Fax ++48/71/33-60-952 Singapore WAGO Electronic Pte. Ltd. Singapur Tel. ++65/2866776 Fax ++65/2842425 Switzerland WAGO CONTACT SA Domdidier Tel. ++65/2866776 Fax ++65/2842425 WAGO Corporation N120 W19129 Freistadt Road Germantown, Wisconsin 53022 Telephone: 800 / DIN Rail (346-7245) Fax: 262 / 255-3232 info.us@wago.com www.wago.us Circuit Breakers DIN Rail Mount Pluggable Circuit Breakers
51012503 价格&库存
很抱歉,暂时无法提供与“51012503”相匹配的价格&库存,您可以联系我们找货
