713-1426
713-1426
    WAGO(万可电子)
    插件,P=3.5mm
    接线端子 间距:3.5mm
713-1426 数据手册
4 282 Female Connectors, Double-Row Pin Spacing: 3.5 mm MCS MINI HD ● ● ● ● ● ● Universal connection for all conductor types  nique, compact, double-row connector system for conductor cross U sections up to 1.5 mm2 High-density, “wire-to-board” connectors for use in very confined spaces  entered strain relief plate anchors conductors, while acting as C convenient connection and disconnection handle. It also provides easy access to operating slots — even when wired.  ptional dual-purpose lever doubles as a lock and disconnection aid, O while preventing accidental disconnection in closed position 100% protected against mismating, available with coding fingers Technical data: Pin Spacing Ratings per Overvoltage category Pollution degree Rated voltage Rated surge voltage Nominal current Approvals per Use group UL 1059 Rated voltage Nominal current UL Nominal current CSA 3.5 mm 0.138 in. IEC/EN 60664-1 III III II 3 2 2 80 V 160 V 250 V 2.5 kV 2.5 kV 2.5 kV 10 A 10 A 10 A UL/CSA B C D 150 V – – 10 A – – 10 A – – Derating Curve 713-1103 female connector with 713-1403 male header Pin spacing: 3.5 mm / Conductor size: 1.5 mm2”f-st” Based on: EN 60512-5-2 / Reduction factor: 0.8 Current in A 20 15 10 5 Conductor data: Connection technology Conductor size: solid Conductor size: fine-stranded Conductor size: fine-stranded Conductor size: fine-stranded AWG Strip length CAGE CLAMP® 0.08–1.5 mm2 0.08–1.5 mm2 0.25–1.0 mm2 (with insulated ferrule) 0.25–1.0 mm2 (with uninsulated ferrule) 28–16 6–7 mm / 0.24–0.28 in. Material data: 0 10 20 40 50 60 70 80 90 100 105 Ambient operating temperature in °C 6-, 16-, 24-, 36-pole MCS MINI HD accessories: Material group II Insulating material Glass fiber-reinforced polyamide 6.6 (PA 6.6-GF) Flammability rating per UL 94 0V Lower/Upper limit temperature -60 °C / +100 °C Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper alloy Contact plating tin-plated MCS connectors are also available upon request with gold-plated or partially gold-plated contact surfaces. Depending on the version requested, “item no. suffix . . . /010-000” is added to the “basic item no.” Marking accessories Operating tools Direct marking Strain relief plates MCS — MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Additional approvals and corresponding ratings can be found at www.wago.com. 30 For additional technical information, see Section 13. Conductor rated current Pages: 570 – 573 296 297 296 "4 Female Connectors, Double-Row MCS MINI HD 283 With levers Pin spacing: 3.5 mm / 0.138 in. Pin spacing: 3.5 mm / 0.138 in. 0.08–1.5 mm2 160 V/2.5 kV/2 10 A 28–16 AWG 150 V/10 A 0.08–1.5 mm2 160 V/2.5 kV/2 10 A With screw flanges Pin spacing: 3.5 mm / 0.138 in. 28–16 AWG 150 V/10 A 0.08–1.5 mm2 160 V/2.5 kV/2 10 A 28–16 AWG 150 V/10 A 4 L = [(pole no./2) – 1] x pin spacing + 5.2 mm Coding finger Pole No. Item No. Pack. Unit Female connector, double-row, black  6  (3x2)  8  (4x2) 10  (5x2) 12  (6x2) 14  (7x2) 16  (8x2) 18  (9x2) 20 (10x2) 22 (11x2) 24 (12x2) 26 (13x2) 28 (14x2) 30 (15x2) 32 (16x2) 34 (17x2) 36 (18x2) 713-1103 713-1104 713-1105 713-1106 713-1107 713-1108 713-1109 713-1110 713-1111 713-1112 713-1113 713-1114 713-1115 713-1116 713-1117 713-1118 L = [(pole no./2) – 1] x pin spacing + 12.2 mm L = [(pole no./2) – 1] x pin spacing + 13.6 mm Pole No. Pole No. Item No. Pack. Unit Female connector with levers, double-row, black 100 50 50 50 50 25 25 25 25 25 25 20 20 20 20 20  6  (3x2)  8  (4x2) 10  (5x2) 12  (6x2) 14  (7x2) 16  (8x2) 18  (9x2) 20 (10x2) 22 (11x2) 24 (12x2) 26 (13x2) 28 (14x2) 30 (15x2) 32 (16x2) 34 (17x2) 36 (18x2) 713-1103/037-000 713-1104/037-000 713-1105/037-000 713-1106/037-000 713-1107/037-000 713-1108/037-000 713-1109/037-000 713-1110/037-000 713-1111/037-000 713-1112/037-000 713-1113/037-000 713-1114/037-000 713-1115/037-000 713-1116/037-000 713-1117/037-000 713-1118/037-000 Item No. Pack. Unit Female connector with screw flanges, double-row, black 50 50 50 25 25 25 25 20 20 20 20 20 20 20 10 10  6  (3x2)  8  (4x2) 10  (5x2) 12  (6x2) 14  (7x2) 16  (8x2) 18  (9x2) 20 (10x2) 22 (11x2) 24 (12x2) 26 (13x2) 28 (14x2) 30 (15x2) 32 (16x2) 34 (17x2) 36 (18x2) 713-1103/107-000 713-1104/107-000 713-1105/107-000 713-1106/107-000 713-1107/107-000 713-1108/107-000 713-1109/107-000 713-1110/107-000 713-1111/107-000 713-1112/107-000 713-1113/107-000 713-1114/107-000 713-1115/107-000 713-1116/107-000 713-1117/107-000 713-1118/107-000 50 50 25 25 25 25 25 20 20 20 20 20 20 10 10 10 4 284 Male Headers with Solder Pins, Double-Row Pin Spacing: 3.5 mm MCS MINI HD ● ● ●  ale headers may be mounted horizontally or vertically via straight or M angled solder pins  eader housing is molded of THR-compatible insulation material for H lead-free reflow soldering  eparated pin slots prevent damage and make the headers touch-proof S when unplugged ● 100% protected against mismating ● Coding pins available Technical data: Pin Spacing Ratings per Overvoltage category Pollution degree Rated voltage Rated surge voltage Nominal current Approvals per Use group UL 1059 Rated voltage Nominal current UL Nominal current CSA 3.5 mm 0.138 in. IEC/EN 60664-1 III III II 3 2 2 80 V 160 V 250 V 2.5 kV 2.5 kV 2.5 kV 10 A 10 A 10 A UL/CSA B C D 150 V – – 10 A – – 12 A – – Derating Curve 713-1103 female connector with 713-1403 male header Pin spacing: 3.5 mm / Conductor size: 1.5 mm2”f-st” Based on: EN 60512-5-2 / Reduction factor: 0.8 Current in A 20 15 10 5 Solder pin data: Solder pin: length/width Solder pin: drilled hole diameter 3.8 mm / 0.8 x 0.8 mm 0 1.2+0.1 mm 10 20 30 40 50 60 70 80 90 100 105 Ambient operating temperature in °C 6-, 16-, 24-, 36-pole Conductor rated current For other pin lengths, please contact factory. Material data: MCS MINI HD accessory: Material group I Insulating material Glass-fiber-reinforced polyphthalamide (PPA-GF) Flammability rating per UL 94 0V Lower/Upper limit temperature -60 °C / +100 °C Contact material Electrolytic copper (ECu) Contact plating tin-plated MCS connectors are also available upon request with gold-plated or partially gold-plated contact surfaces. Depending on the version requested, “item no. suffix . . . /010-000” is added to the “basic item no.” Coding pin carrier MCS — MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Additional approvals and corresponding ratings can be found at www.wago.com. For additional technical information, see Section 13. Page: 297 Male Headers with Solder Pins, Double-Row MCS MINI HD 4 285 With straight solder pins Pin spacing: 3.5 mm / 0.138 in. 160 V/2.5 kV/2 10 A With angled solder pins Pin spacing: 3.5 mm / 0.138 in. 150 V/10 A 160 V/2.5 kV/2 10 A 150 V/10 A 4 2,6 2,6 2,6 2,6 L = [(pole no./2) – 1] x pin spacing + 5.2 mm Pole No. Item No. Pack. Unit Male header with straight solder pins, double-row, black  6  (3x2)  8  (4x2) 10  (5x2) 12  (6x2) 14  (7x2) 16  (8x2) 18  (9x2) 20 (10x2) 22 (11x2) 24 (12x2) 26 (13x2) 28 (14x2) 30 (15x2) 32 (16x2) 34 (17x2) 36 (18x2) 713-1403 713-1404 713-1405 713-1406 713-1407 713-1408 713-1409 713-1410 713-1411 713-1412 713-1413 713-1414 713-1415 713-1416 713-1417 713-1418 100 50 50 50 50 25 25 25 25 25 25 20 20 20 20 20 Pole No. Item No. Pack. Unit Male header with angled solder pins, double-row, black  6  (3x2)  8  (4x2) 10  (5x2) 12  (6x2) 14  (7x2) 16  (8x2) 18  (9x2) 20 (10x2) 22 (11x2) 24 (12x2) 26 (13x2) 28 (14x2) 30 (15x2) 32 (16x2) 34 (17x2) 36 (18x2) 713-1423 713-1424 713-1425 713-1426 713-1427 713-1428 713-1429 713-1430 713-1431 713-1432 713-1433 713-1434 713-1435 713-1436 713-1437 713-1438 100 50 50 50 50 25 25 25 25 25 25 20 20 20 20 20 Strain relief plates for in-the-field assembly Strain relief plates, factory-assembled Operating tool for female connectors with CAGE CLAMP® for female connectors with CAGE CLAMP® with partially insulated shaft Type 1 Width Item No. Pack. Unit Strain relief plate, black 11 mm 25 mm 39 mm 53 mm Width Pole No. Item No. Suffix: Strain relief plate, pre-assembled 713-126 713-127 713-128 713-129 100 (4 x 25) 100 (4 x 25) 100 (4 x 25) 100 (4 x 25) 11 mm 25 mm 39 mm 53 mm Ordering example: Female connector, 3.5 mm pin spacing, 20-pole, black with strain relief plate: 713-1110/033-000 > D < > 3,5< The arrangement of the attachments for cable ties allows single conductors or multi-core cables to be secured in different ways. The width of the cable tie must correspond to the hole dimensions in the drawing for the strain relief plates. WAGO does not offer the recommended cable ties and cable binding tools; those are available from suppliers such as Hellermann. Strain Relief Housing Dimensions Pole No. B H D   6–12  14–20  22–28  30–36 11 25 39 53 38.7 43.7 48.7 54.2 3 4.2 4.2 4.9 An “item no. suffix”, referring to the width of the strain relief plate, is added to the “basic item no.” and determines the type of female connector. >3< Item No. 210-719 . . . /032-000 . . . /033-000 . . . /034-000 . . . /035-000  6–12 14–20 22–28 30–36 Color Pack. Unit Operating tool with partially insulated shaft, type 1, (2.5 x 0.4) mm blade 296 Accessories Strain Relief Plates and Operating Tool MCS MINI HD 4 1 Accessories Coding Pin Carrier and Direct Marking MCS MINI HD Coding pin carrier Direct marking MCS MINI HD Pack. Unit Coding pin carrier with six coding pins 714-101 297 Direct marking 1 – pole no. of female connectors for conductor termination for male headers Item No. 4 Direct Marking MCS MINI HD 713 Series female connectors can be marked with “1 – pole no.” via factory direct printing 100 (4 x 25) Two standard marking orientations are available: 1. Marking perpendicular to conductor entry 2. Marking parallel to conductor entry Other custom marking options are available upon request. WAGO recommends pole marking on the PCB for 713 Series male headers. Marking Perpendicular to Conductor Entry Item No. Suffix: /. . . - 047 Ordering examples: Female connector, double-row, 3.5 mm pin spacing, 16-pole, black: 713-1108/000-0047 Female connector with screw flanges, double-row, 3.5 mm pin spacing, 16-pole, black: 713-1108/000-0047 Female connector with levers and strain relief plate, double-row, 3.5 mm pin spacing, 16-pole, black: 713-1108/037-047/033-000 The marking type is always defined by the second 4-digit block of the item no. suffix for items with standard colors and materials. Example: 713-1110/. . . - xxxx xxxx = Item no. suffix for direct pole marking Marking parallel with Conductor Connection Additional Item No.: /. . . - 9037 Ordering examples: Female connector, double-row, 3.5 mm pin spacing, 16-pole, black: 713-1108/000-9037 Female connector with levers, double-row, 3.5 mm pin spacing, 16-pole, black: 713-1108/037-9037 Coding a male header. Coding a female connector. Female connector with strain relief plate, double-row, 3.5 mm pin spacing , 16-pole, black: 713-1108/033-9037 4 4 300 Female Connectors with Push-Buttons Pin Spacing: 3.5 mm MCS MINI SL ● F emale connectors terminate both solid and ferruled, fine-stranded conductors via simple push-in terminations. ● Integrated push-buttons provide convenient, tool-free operation ● Ultra-low profile at just 7.8 mm, for conductor size up to 1.5 mm2 ● Coding and testing options available Technical data: Pin Spacing Rating per Overvoltage category Pollution degree Rated voltage Rated surge voltage Nominal current Approvals per Use group UL 1059 Rated voltage Nominal current UL Nominal current CSA 3.5 mm 0.138 in. IEC/EN 60664-1 III III II 3 2 2 160 V 160 V 320 V 2.5 kV 2.5 kV 2.5 kV 8A 8A 8A UL/CSA B C D 150 V – – 8A – – – – – Conductor data: Connection technology Conductor size: solid Conductor size: fine-stranded Conductor size: fine-stranded Conductor size: fine-stranded AWG Strip length CAGE CLAMP® S 0.2–1.5 mm2 0.2–1.5 mm2 0.25–0.75 mm2 (with insulated ferrule) 0.25–1.5 mm2 (with uninsulated ferrule) 24–16 9–10 mm / 0.35–0.39 in. Material data: Material group Insulating material Temperature stability Flammability rating per UL 94 Clamping spring material Contact material Contact plating MCS MINI SL accessories: I Polyamide 6.6 (PA 6.6) -60 °C to +100 °C 0V Chrome nickel spring steel (CrNi) Copper alloy tin-plated Marking accessories Operating tool Direct marking Test pin MCS — MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Additional approvals and corresponding ratings can be found at www.wago.com. *CSA approval pending For additional technical information, see Section 13. Pages: 570 – 573 301 301 568 !4 Female Connectors with Push-Buttons MCS MINI SL 301 Pin spacing: 3.5 mm / 0.138 in. 0.2–1.5 mm2 160 V/2.5 kV/2 8 A Pole No. 24–16 AWG Item No. Pack. Unit 714-102 714-103 714-104 714-105 714-106 714-108 714-110 714-112 714-114 714-115 714-116 > 3,5 > 2,1 > Direct marking 1 – pole no. 150 V/8 A Female connector with push-buttons, black  2  3​  4​  5​  6​  8​ 10 12​ 14​ 15​ 16​ Operating tool (screwdriver), with partially insulated shaft, 210-719 Marking Perpendicular to Conductor Entry Item No. Suffix: /. . . - 047 Ordering example: 1 Female connector with push-buttons, 3.5 mm pin spacing, 6-pole, black: 714-106/000-047 4 4 302 Male Headers with Solder Pins Pin Spacing: 3.5 mm MCS MINI SL ● ● ● ●  ale headers may be mounted horizontally or vertically via straight or M angled solder pins  eader housing is molded of THR-compatible insulation material for H reflow soldering  eparated pin slots prevent damage and make the headers touch-proof S when unplugged Coding pins available Technical data: Pin Spacing Rating per Overvoltage category Pollution degree Rated voltage Rated surge voltage Nominal current Approvals per Use group UL 1059 Rated voltage Nominal current UL Nominal current CSA 3.5 mm 0.138 in. IEC/EN 60664-1 III III II 3 2 2 160 V 160 V 320 V 2.5 kV 2.5 kV 2.5 kV 8A 8A 8A UL/CSA B C D 150 V – – 8A – – – – – Solder pin data: Solder pin: length/width Solder pin: drilled hole diameter 3.4 mm / 0.8 x 0.8 mm 1.2+0.1 mm Material data: Material group Insulating material Temperature stability Flammability rating per UL 94 Contact material Contact plating MCS MINI SL accessory: I Glass-fiber-reinforced polyphthalamide (PPA-GF) -60 °C to +115 °C 0V Electrolytic copper (ECu) tin-plated Coding pin carrier MCS — MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Additional approvals and corresponding ratings can be found at www.wago.com. *CSA approval pending For additional technical information, see Section 13. Page: 303 Male Headers with Solder Pins MCS MINI SL 4 303 With straight solder pins Pin spacing: 3.5 mm / 0.138 in. < 6,9 > > 3 > > 3,4 > 3,5 > 3,4 0,8 __> > 0,8 > 4 2,45 > 3,5 0,8 _> > > < 6,9 > > 3 2,45 160 V/2.5 kV/2 8 A 150 V/8 A > 160 V/2.5 kV/2 8 A Coding pin carrier With angled solder pins Pin spacing: 3.5 mm / 0.138 in. L = (No. of poles -1) x pin spacing + 4.9 mm Pole No. Item No. Pack. Unit Male header with straight solder pins, black  2​  3​  4​  5​  6​  8​ 10 12​ 14​ 15​ 16​ 714-132 714-133 714-134 714-135 714-136 714-138 714-140 714-142 714-144 714-145 714-146 For other lengths, please contact factory. Pole No. Item No. Pack. Unit Male header with angled solder pins, black 200 200 200 200 200 200 100 100 100 100 100  2  3​  4​  5​  6​  8​ 10 12​ 14​ 15​ 16​ 714-162 714-163 714-164 714-165 714-166 714-168 714-170 714-172 714-174 714-175 714-176 Item No. Pack. Unit Coding pin carrier with six coding pins 200 200 200 200 200 200 100 100 100 100 100 714-101 100 (4 x 25)
713-1426 价格&库存
很抱歉,暂时无法提供与“713-1426”相匹配的价格&库存,您可以联系我们找货
