721-603/019-000
721-603/019-000
    WAGO(万可电子)
    P=5mm
    接线端子 间距:5mm 排数:1
721-603/019-000 数据手册
Data sheet from 22.01.2013 Item no.: 721-603/019-000 Product description: MALE CONNECTOR WITH FIXING FLANGE 3 POLE PIN SPACING 5 MM / 0.197 IN 100% PROTECTED AGAINST MISMATING WITHOUT PRECEDING GROUND CONTACT FOR SCREW OR SIMILAR MOUNTING TYPES FOR PARALLEL OR PERPENDICULAR MOUNTING Produkt kann von Bild abweichen / product may differ Packing unit 50 pieces RoHS compliant Product group 3 (Multi Conn. System) Weight 5.596 g Color light gray No. of connection Points 3 No. of potentials 3 pole count 3 Height 14.3 mm Height 0.563 in Width 29.8 mm Width 1.173 in Depth 27.5 mm Depth 1.083 in Pin spacing from 5 mm Pin spacing from 0.197 in Pollution degree 2 Measured voltage EN 320 V 1 von 4 Measured shock voltage 4 kV Current intensity EN 12 A Pollution degree 2 Measured voltage EN 630 V Measured shock voltage 4 kV Current intensity EN 12 A 2 von 4 Data sheet from 22.01.2013 Connection method CAGE CLAMP® CONNECTION Cross section [mm²] 0.08 - 2.5 mm² Wiring method solid Cross section [mm²] 0.08 - 2.5 mm² Cross section [mm²] 0.25 - 1.5 mm² Cross section [mm²] 0.25 - 2.5 mm² Cross section [AWG] 28 - 12 AWG Strip length from 8 mm Strip length to 9 mm Material group I xxx-xxx/032-000 Strain relief plate 11,5 mm 3 von 4 Data sheet from 22.01.2013 Item no. Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 721-603/019-000 ABS 04-HG469925/1-PDA 250 12 0,08-2,5 721-603/019-000 BV 11915/A0 250 12 721-603/019-000 CCA 5764 250 12 0,08-2,5 721-603/019-000 CSA 154112-1466354 300 15 28-12 721-603/019-000 DNV E-9218 250 12 0,08-2,5 721-603/019-000 GL 17296-00HH 250 12 721-603/019-000 KEMA 2083746.02 250 12 0,08-2,5 721-603/019-000 KR HMB05880-EL003 250/400 12/16 2,5 721-603/019-000 LR 96/20035 250 12 0,08-2,5 721-603/019-000 RMR 11130002 250 12 0,08-2,5 721-603/019-000 UR E45171 600 20 12 721-603/019-000 UR E45172 300 15 28-12 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 4 von 4
721-603/019-000 价格&库存
很抱歉,暂时无法提供与“721-603/019-000”相匹配的价格&库存,您可以联系我们找货
