733-362
733-362
    WAGO(万可电子)
    插件,P=2.5mm
    接线端子 间距:2.50mm 1x2P 直插
733-362 数据手册
Data sheet from 04.02.2009 Item no.: 733-362 Product description: HEADER; RIGHT ANGLE SOLDER PIN 0.8x0.8 MM; 2 POLE; PIN SPACING 2.5 MM / 0.098 IN; 100% PROTECTED AGAINST MISMATING; MATING DIRECTION PARALLEL TO PCB Packing unit 200 pieces Product group 3 (Multi Conn. System) Pin spacing from 2,5 mm Pin spacing from 0,098 in pole count 2 Measured voltage EN 250 V Measured shock voltage 2,5 kV Pollution degree 2 Current intensity EN 4A Weight 0,404 g Color light grey Height 7,8 mm Height 0,307 in Width 7,5 mm Width 0,295 in Depth 8,9 mm Depth 0,35 in 1 von 2 Data sheet from 04.02.2009 Item number Admission office Approval no. Voltage [V] Current [A] 733-362 ABS 04-HG469925-PDA 250 4 733-362 BV 11915/A0 250 4 733-362 CCA NL5640 250 4 733-362 CSA 154112-1465035 150 4 733-362 DNV E-6997 250 4 733-362 GL 17296-00HH 250 4 733-362 KEMA 2077592.01 250 4 733-362 LR 96/20035 250 6 733-362 RMR 11130002 250 4 733-362 UR E45171 250 4 733-362 UR E45172 150 4 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 2 von 2 Cross section [ mm² ] 28-20 28-20
733-362 价格&库存
很抱歉,暂时无法提供与“733-362”相匹配的价格&库存,您可以联系我们找货
库存:97
733-362
    • 1+1.87000
    • 200+1.85130
    • 400+1.83260
    库存:107
