734-116
734-116
    WAGO(万可电子)
    P=3.5mm
    接线端子 间距:3.50mm 1x16P
734-116 数据手册
Data sheet  |  Item number: 734-116 1-conductor female plug; 100% protected against mismating; 1.5 mm²; Pin spacing 3.5 mm; 16-pole; 1,50 mm²; light gray www.wago.com/734-116 Color: Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 1/11 Data sheet  |  Item number: 734-116 www.wago.com/734-116 L = (pole no. x pin spacing) + 2.2 mm Item description Universal connection for all conductor types Easy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuation Strain relief plates and housings for field assembly 100% protected against mismating Coding via coding fingers Safety information 1: The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 160 V Rated impulse voltage (III / 3) 2.5 kV Rated voltage (III / 2) 160 V Rated impulse voltage (III / 2) 2.5 kV Rated voltage (II / 2) 320 V Rated impulse voltage (II / 2) Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 2.5 kV Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 2/11 Data sheet  |  Item number: 734-116 www.wago.com/734-116 Rated impulse voltage (II / 2) 2.5 kV Rated current 10 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Connection data Connection technology CAGE CLAMP® Actuation type Operating tool Solid conductor 0.08 … 1.5 mm² / 28 … 14 AWG Fine-stranded conductor 0.08 … 1.5 mm² / 28 … 14 AWG Fine-stranded conductor with ferrule with plastic collar 0.25 … 1.5 mm² Fine-stranded conductor with ferrule without plastic collar 0.25 … 1.5 mm² Strip length 6 … 7 mm / 0.24 … 0.28 inch No. of poles 16 Total number of connection points 16 Total number of potentials 16 Number of connection types 1 Number of levels 1 Note (conductor cross-section) Terminating 1.5 mm² conductors is possible; however insulation diameter does not allow clamping units to be terminated in a row. Conductor entry direction to mating direction 0  ° Geometrical Data Pin spacing 3.5 mm / 0.138 inch Width 58.2 mm / 2.291 inch Height Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 13.4 mm / 0.528 inch Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 3/11 Data sheet  |  Item number: 734-116 www.wago.com/734-116 Height 13.4 mm / 0.528 inch Depth 18.6 mm / 0.732 inch Plug connection Contact type (pluggable connector) Female connector/socket Connector connection type for conductors Mismating protection Yes Material Data Color light gray Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper alloy Contact plating tin-plated Fire load 0.184 MJ Weight 12 g Environmental Requirements Limit temperature range -60 … +100 °C Commercial data Product Group 3 (Multi Conn. System) Packaging type BOX Country of origin DE GTIN 4044918493901 Customs Tariff No. 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CCA DEKRA Certification B.V. EN 61984 nl-54190 CCA DEKRA Certification B.V. EN 61984 2169534.02 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 4/11 Data sheet  |  Item number: 734-116 www.wago.com/734-116 CSA DEKRA Certification B.V. C22.2 1465035 Approval Additional Approval Text ABS American Bureau of Shipping - 19HG1869876PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE000016Z LR Lloyds Register IEC 61984 96/20035 (E5) Ship Approvals Logo Certificate name UL-Approvals Logo Certificate name Approval Additional Approval Text UL UL International Germany GmbH UL 1977 20150318E45171 UR Underwriters Laboratories Inc. UL 1059 20190122E45172 Compatible products Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 5/11 Data sheet  |  Item number: 734-116 www.wago.com/734-116 Strain relief plate Item no.: 734-126 Strain relief plate; light gray www.wago.com/734-126 Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated www.wago.com/216-101 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-104 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-104 Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated www.wago.com/216-121 Item no.: 216-122 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated www.wago.com/216-122 Item no.: 216-123 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-123 Item no.: 216-124 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-124 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-131 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-141 Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-141 Item no.: 216-142 Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-142 Item no.: 216-143 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-143 Item no.: 216-144 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-144 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 ferrule Item no.: 216-152 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 6/11 Data sheet  |  Item number: 734-116 www.wago.com/734-116 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-203 Item no.: 216-204 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-204 Item no.: 216-221 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-221 Item no.: 216-222 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-222 Item no.: 216-223 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-223 Item no.: 216-224 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-224 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-284 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-284 Item no.: 216-301 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 7/11 Data sheet  |  Item number: 734-116 www.wago.com/734-116 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 Marking accessories Item no.: 210-332/350-202 www.wago.com/210-332 Marking strips; as a DIN A4 sheet; MARKED; 1-16 (240x); Height of marker strip: 3 mm; Strip length 182 /350-202 mm; Horizontal marking; Self-adhesive; white Item no.: 210-332/350-204 Marking strips; as a DIN A4 sheet; MARKED; 17-32 (240x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /350-204 Item no.: 210-332/350-206 Marking strips; as a DIN A4 sheet; MARKED; 33-48 (240x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /350-206 Item no.: 210-250 Operating tool; for MCS MINI & MIDI with CAGE CLAMP® connection; red www.wago.com/210-250 Item no.: 210-251 Operating tool; for MCS MICRO & MINI with CAGE CLAMP® connection; yellow www.wago.com/210-251 Item no.: 210-647 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-647 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Item no.: 734-190 Combination operating tool; natural www.wago.com/734-190 Item no.: 734-191 Operating tool; loose; black www.wago.com/734-191 Item no.: 734-230 Push-button www.wago.com/734-230 Item no.: 734-231 Operating tool; black www.wago.com/734-231 tools Insulation stop Item no.: 734-671 Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 8 pieces/strip; light gray www.wago.com/734-671 check Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 8/11 Data sheet  |  Item number: 734-116 www.wago.com/734-116 check Item no.: 735-500 Test pin; 1 mm Ø; with solder connection for test wire www.wago.com/735-500 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data CAD data 2D/3D Models 734-116 CAE data EPLAN Data Portal 734-116 Download Installation Notes Inserting a conductor Inserting a conductor via (2.5 x 0.4) mm screwdriver – CAGE CLAMP® actuation perpendicular to conductor entry. Inserting a conductor via (2.5 x 0.4) mm screwdriver – CAGE CLAMP® actuation parallel to conductor entry. Inserting a conductor into CAGE CLAMP® unit via operating lever (734-191). Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 9/11 Data sheet  |  Item number: 734-116 www.wago.com/734-116 Inserting a conductor into CAGE CLAMP® unit via operating tool (210-251 or 210-250). Coding Coding a female connector – removing coding finger(s). Testing Testing via 1 mm Ø test pin (735-500) – CAGE CLAMP® connection – touch contact. Marking Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 10/11 Data sheet  |  Item number: 734-116 www.wago.com/734-116 Labeling via direct marking or self-adhesive strips. Assembly Strain relief housing for 734 Series Male and Female Connectors with CAGE CLAMP® connection. Product family MCS MINI Show all products from the family Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 11/11
734-116
物料型号:WAGO 734-116 器件简介:WAGO 734-116是一款1极女性连接器,具有100%防错配保护,适用于1.5 mm²导线,针间距为3.5 mm,16极,适用于1.50 mm²导线,颜色为浅灰色。 引脚分配:16极,针间距3.5 mm。 参数特性:额定电压160V,额定脉冲电压2.5kV,额定电流10A。符合IEC/EN 60664-1标准。 功能详解:该连接器适用于所有类型的导线,易于预装和在设备上的垂直或水平CAGE CLAMP®操作。具有现场组装的防拔板和外壳,通过编码手指进行编码。 应用信息:适用于多种商业和工业应用,特别是在需要可靠电气连接和防错配保护的场合。 封装信息:材料组I,绝缘材料为聚酰胺66 (PA 66),阻燃等级为UL94 VO级。夹持弹簧材料为铬镍弹簧钢,接触材料为铜合金,接触镀锡。产品重量12克。
734-116 价格&库存
很抱歉,暂时无法提供与“734-116”相匹配的价格&库存,您可以联系我们找货
    库存:25
    734-116
    • 1+232.503141+29.85851
    • 10+166.8551310+21.42786
    • 25+149.4814825+19.19670
    • 50+139.2002050+17.87636
    • 100+130.99626100+16.82280
    • 250+122.75661250+15.76464
    • 500+118.08885500+15.16520
    库存:55
