DOUBLE DECK PCB TERMINAL STRIP
2 SOLDER PINS IN LINE PIN SPACING
5 MM / 0.197 IN
736-102 TO 736-124
PDF Datasheet
© 1992 - 2011 CADENAS GmbH
5 MM / 0.197 IN
736-102 TO 736-124
PDF Datasheet
ITEM-NO. (ITEM-NO.)
736-103
Cross section1 (Cross section / mm²)
0.08 - 2.5
Cross section2 (Cross section / AWG)
28 - 12
Strip length (Strip length / mm)
5-6
Measured voltage (Measured voltage / V)
320
Measured shock voltage (Measured shock voltage / kV)
4
Pollution degree (Pollution degree)
2
Current intensity (Current intensity / A)
21
RM (PIN SPACING / mm)
5
P (NO. OF POLES)
3
Height (Height / mm)
26.5
Width (Width / mm)
16
Depth (Depth / mm)
21
No. of connection Points (No. of connection Points)
6
No. of potentials (No. of potentials)
6
COLOR (COLOR)
grau
WEIGHT (WEIGHT / g)
7.16
Comment (Comment)
L = (No. of poles x Pin Spacing) + 1 mm
Dimensions (Dimensions)
1,3 + 0,1 mm
很抱歉,暂时无法提供与“736-103”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+58.121391+7.51281
