750-8202/025-001
    WAGO(万可电子)
    Compact PLC Controller
750-8202/025-001 数据手册
750-8202 PFC200 CS 2ETH RS Marking area 01 02 Serial interface X3 RS232/485 SYS RST RUN I/O MS NS U7 U6 U5 U4 U3 U2 U1 A B 24V 0V SD Fieldbus connection RJ-45 Fieldbus connection RJ-45 750-8202 58 PLC – PFC200 Controller ACT X2 LNK ETH ACT X1 LNK 3 — 0V Programmable to IEC 61131-3 • Programmable via WAGO-I/O-PRO V2.3 • Direct connection of WAGO I/O modules • 2 x ETHERNET (configurable), RS-232/-485 • Linux operating system with RT-Preemption patch • Configuration via CODESYS, e!COCKPIT or Web-based management interface • Maintenance-free Item No. Pack. Unit System Data PFC200 CS 2ETH RS PFC200 CS 2ETH RS/T Extended temperature range: -20 °C ... +60 °C PFC200 CS 2ETH RS Telecontrol/T Extended temperature range: -20 °C ... +60 °C PFC200 CS 2ETH RS Telecontrol ECO/T Extended temperature range: -20 °C ... +60 °C 750-8202 750-8202/025-000 1 1 750-8202/025-001 1 750-8202/025-002 1 CPU Operating system Main memory (RAM) Internal memory (flash) Retain memory ETHERNET Transmission medium Accessories Item No. Pack. Unit WAGO-I/O-PRO V2.3, RS-232 kit SD memory card, 2 GB Miniature WSB Quick marking system plain with marking 759-333 758-879/000-001 1 1 248-501 see Section 11 5 Baud rate Interface (serial) Protocols 750-8202/025-001 and -002 Programming IEC 61131-3 SD card slot Type of memory card Approvals WAGO Kontakttechnik GmbH & Co. KG Subject to design changes — Power jumper contacts Description Conformity marking Korea Certification Marine applications (versions upon request) r UL 508 r ANSI/ISA 12.12.01 4 TÜV 14 ATEX 148929 X IECEx TUN 14.0035 X + RUN STOP RESET Configuration and programming interface The PFC200 Controller is a compact PLC for the modular WAGO-I/O-SYSTEM. Besides network and fieldbus interfaces, the controller supports all digital, analog and specialty modules found within the 750/753 Series. Two ETHERNET interfaces and integrated switch enable line topology wiring. An integrated Web server provides the user with configuration options and status information from the PFC200. Besides the processing industry and building automation, typical markets for the PFC200 include the standard machine and plant industries (e.g., packaging, bottling, textiles, production and metal & wood processing). + Status voltage supply -System -Power jumper contacts Data contacts Supply 24 V 0V Supply via power jumper contacts 24 V Cortex A8, 600 MHz Real-time Linux (with RT-Preemption patch) 256 Mbytes 256 Mbytes 128 Kbytes 2 x RJ-45 (switched) Twisted Pair S-UTP 100 Ω, Cat 5; Max. line length: 100 m 10/100 Mbit/s; 10Base-T/100Base-TX RS-232/-485 (switchable) DHCP, DNS, NTP, FTP, FTPS, SNMP, HTTP, HTTPS, SSH, MODBUS (TCP, UDP, RTU) IEC 60870-5-101/-103/-104, IEC 61850-7-4, IEC 61400-25, DNP3 WAGO-I/O-PRO V2.3, e!COCKPIT IL, LD, FBD (CFC), ST, FC Push-push mechanism, sealable cover lid SD and SDHC up to 32 GB (All guaranteed properties are only valid in connection with the WAGO 758-879/ 000-001 memory card.) 1 (750-8202) GL Class I, Div. 2, Grp. ABCD, T4 II 3 G Ex nA IIC T4 Gc (750-8202) Ex nA IIC T4 Gc (750-8202) 26.01.2016 Postfach 2880 - D-32385 Minden Hansastr. 27 - D-32423 Minden Tel.: +49(0)571/887-0 E-Mail: info@wago.com Fax: +49(0)571/887-169 www.wago.com 3 59 1 1 5 10 nF 0V 2 6 24 V DC DC 5 2/6 I/O modules 24 V ELECTRONICS Bob Smith Termination 47 nF Bob Smith Termination 47 nF 3 7 0V ELECTRONICS ETHERNET Interface RS-232/-485 10 nF 3/7 10 nF 4 8 Interface RS-232/-485 3.1 10 nF 4/8 750-8202 Technical Data Number of I/O modules (per node) with bus extension 750-8202/025-002 Input and output process image (max.) Internal data bus MODBUS I/O interfaces (serial) Diagnostic LEDs User LEDs Memory configuration CODESYS 2.3 Program memory Data memory Non-volatile memory (retain) Memory configuration e!RUNTIME Program and data memory Non-volatile memory (retain) Power supply Max. input current (24 V) Total current for I/O modules (5 V) Isolation General Specifications 64 250 4 1000 words 1000 words 1 x serial interface per TIA/EIA 232 and TIA/EIA 485 (switchable), 9-pole D-sub female connector Power supply; SYS; RUN; FIELDBUS (MS, NS); USER (U1 ... U7); Internal data bus via CODESYS library 16 MB 64 MB 128 KB 60 MB (dynamically distributed) 128 KB 24 V DC (-25 % ... +30 %) 550 mA 1700 mA 500 V system/supply Dimensions (mm) W x H x L Weight EMC immunity of interference EMC emission of interference Degree of protection Type of mounting Housing material Ambient conditions Operating temperature Storage temperature Relative air humidity (no condensation) Wire connection Cross sections Strip lengths 79 x 65 x 100 Height from upper-edge of DIN 35 rail 209.7 g acc. to EN 61000-6-2, marine applications acc. to EN 61000-6-3, marine applications IP20 acc. to DIN 60529 DIN 35 rail PC 0 °C ... +55 °C -25 °C ... +85 °C 95 % CAGE CLAMP® 0.08 mm² ... 2.5 mm² / AWG 28 ... 14 8 ... 9 mm / 0.33 in
750-8202/025-001 价格&库存
很抱歉,暂时无法提供与“750-8202/025-001”相匹配的价格&库存,您可以联系我们找货
