788-312
788-312
    WAGO(万可电子)
788-312 数据手册
Data sheet  |  Item number: 788-312 Relay module; Nominal input voltage: 24 VDC; 2 changeover contacts; Limiting continuous current: 8 A; Red status indicator; Module width: 15 mm; 2,50 mm²; gray www.wago.com/788-312 Similiar to picture Color: Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at {0}. 29.12.2019    Page 1/14 Data sheet  |  Item number: 788-312 www.wago.com/788-312 Current-carrying capacity curve DC load limit curve Item description Note: Reinforced insulation between coil and contacts A separator plate (e.g., 209-191) must be used for voltages greater than 250 V between adjacent relay modules and for compliance with the reinforced insulation requirements. To protect the relay coils and contacts, inductive loads must be dampened with an effective protection circuit. Data Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at {0}. 29.12.2019    Page 2/14 Data sheet  |  Item number: 788-312 www.wago.com/788-312 Data Technical Data Control circuit Nominal input voltage UN DC 24 V Input voltage range ±10 % Nominal input current at UN 19 mA Load circuit: Number of changeover contacts 2 Contact material (relay) AgNi 90/10 Limiting continuous current 8 A Max. make current (resistive) (AC) 15 A / 4 s Max. switching voltage AC 250 V Max. switching power (resistive) AC 2000 VA; DC see load limit curve Switching capacity AC-15: 3 A / AC 250 V; DC-13: 2 A / DC 24 V Recommended minimum load 12 V / 10 mA Pull-in time (typ.) 8 ms Drop-out time (typ.) 13 ms Bounce time (typ) 10 ms Electrical life (N.O.; resistive load; 23 °C) 10 x 103 switching operations Mechanical life 30 x 106 switching operations Max. switching load with load/without load 6 min-1 / 1200 min-1 Signaling Status indication LED red Safety and protection: Rated voltage 250 V Rated impulse voltage 4 kV Pollution degree 3 Dielectric strength, control/load circuit (AC, 1 min) 5 kVrms Dielectric strength open contact (AC, 1 min) 1 kVrms Dielectric strength, load/load circuit (AC, 1 min) 2.5 kVrms Protection class IP20 Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at {0}. 29.12.2019    Page 3/14 Data sheet  |  Item number: 788-312 www.wago.com/788-312 Connection data Connection technology Push-in CAGE CLAMP® Solid conductor 0.34 … 2.5 mm² / 22 … 14 AWG Fine-stranded conductor 0.34 … 2.5 mm² / 22 … 14 AWG Strip length 9 … 10 mm / 0.35 … 0.39 inch Geometrical Data Width 15 mm / 0.591 inch Height from upper-edge of DIN-35 rail 54 mm / 2.126 inch Depth 86 mm / 3.386 inch Mechanical data Type of mounting DIN-35 rail Material Data Color gray Fire load 1.349 MJ Weight 45.5 g Environmental Requirements Surrounding air (operating) temperature at UN -40 … 70 °C Surrounding air (storage) temperature -40 … 70 °C Processing temperature -25 … +50 °C Standards and specifications Standards/specifications EN 61010-2-201; EN 61810-1; EN 61373; UL 508 Elementary relay WAGO elementary relay 788-156 Commercial data Product Group 6 (Interface Electronics) Packaging type BOX Country of origin Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us CN Do you have any questions about our products? We are always happy to take your call at {0}. 29.12.2019    Page 4/14 Data sheet  |  Item number: 788-312 www.wago.com/788-312 Country of origin CN GTIN 4055143184137 Customs Tariff No. 85364900990 Approvals / Certificates UL-Approvals Logo Approval Additional Approval Text UL UL International Netherlands B.V. (ORDINARY LOCATIONS) UL 508 Certificate name E175199 Sec.6 Compatible products tools Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft www.wago.com/210-720 Item no.: 788-113 Comb-style jumper bar; 2-way; insulated www.wago.com/788-113 Item no.: 788-114 Comb-style jumper bar; 3-way; insulated www.wago.com/788-114 Item no.: 788-115 Comb-style jumper bar; 4-way; insulated www.wago.com/788-115 Item no.: 788-116 Comb-style jumper bar; 6-way; insulated www.wago.com/788-116 Item no.: 788-117 Comb-style jumper bar; 8-way; insulated www.wago.com/788-117 Item no.: 788-118 Comb-style jumper bar; 2-way (1-3); insulated www.wago.com/788-118 Item no.: 859-402 Push-in type jumper bar; Light gray; Insulated; 18 A; 2-position www.wago.com/859-402 Jumper Item no.: 859-402/000-005 Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at {0}. 29.12.2019    Page 5/14 Data sheet  |  Item number: 788-312 www.wago.com/788-312 Item no.: 859-402/000-005 Push-in type jumper bar; 2-way; Nominal current 18 A; insulated; red www.wago.com/859-402 /000-005 Item no.: 859-402/000-006 Push-in type jumper bar; 2-way; Nominal current 18 A; insulated; blue www.wago.com/859-402 /000-006 Item no.: 859-402/000-029 Push-in type jumper bar; 2-way; Nominal current 18 A; insulated; yellow www.wago.com/859-402 /000-029 Marking accessories Item no.: 2009-110 Marking strips; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Item no.: 2009-115 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-115 /000-002 Item no.: 2009-115/000-006 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-007 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-115 /000-007 Item no.: 2009-115/000-012 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-115 /000-012 Item no.: 2009-115/000-017 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-115 /000-023 Item no.: 209-128 Adaptor www.wago.com/209-128 Item no.: 209-183 Marker card; white www.wago.com/209-183 Item no.: 210-110 Fiber-tip pen www.wago.com/210-110 Item no.: 249-105 Group marker carrier Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us www.wago.com/249-105 Do you have any questions about our products? We are always happy to take your call at {0}. 29.12.2019    Page 6/14 Data sheet  |  Item number: 788-312 www.wago.com/788-312 Item no.: 249-105 Group marker carrier www.wago.com/249-105 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/793-501 /000-002 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/793-501 /000-005 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/793-501 /000-006 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/793-501 /000-007 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/793-501 /000-012 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/793-501 /000-017 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/793-501 /000-023 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/793-501 /000-024 Item no.: 793-502 WMB marking card; as card; MARKED; 1 ... 10 (10x); not stretchable; Horizontal marking; snap-on type; white www.wago.com/793-502 Item no.: 793-502/000-002 WMB marking card; as card; MARKED; 1 ... 10 (10x); not stretchable; Horizontal marking; snap-on type; yellow www.wago.com/793-502 /000-002 Item no.: 793-502/000-005 WMB marking card; as card; MARKED; 1 ... 10 (10x); not stretchable; Horizontal marking; snap-on type; red www.wago.com/793-502 /000-005 Item no.: 793-502/000-006 WMB marking card; as card; MARKED; 1 ... 10 (10x); not stretchable; Horizontal marking; snap-on type; blue www.wago.com/793-502 /000-006 Item no.: 793-502/000-007 Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us www.wago.com/793-502 Do you have any questions about our products? We are always happy to take your call at {0}. 29.12.2019    Page 7/14 Data sheet  |  Item number: 788-312 www.wago.com/788-312 Item no.: 793-502/000-007 WMB marking card; as card; MARKED; 1 ... 10 (10x); not stretchable; Horizontal marking; snap-on type; gray www.wago.com/793-502 /000-007 Item no.: 793-502/000-012 WMB marking card; as card; MARKED; 1 ... 10 (10x); not stretchable; Horizontal marking; snap-on type; orange www.wago.com/793-502 /000-012 Item no.: 793-502/000-017 WMB marking card; as card; MARKED; 1 ... 10 (10x); not stretchable; Horizontal marking; snap-on type; light green www.wago.com/793-502 /000-017 Item no.: 793-502/000-023 WMB marking card; as card; MARKED; 1 ... 10 (10x); not stretchable; Horizontal marking; snap-on type; green www.wago.com/793-502 /000-023 Item no.: 793-502/000-024 WMB marking card; as card; MARKED; 1 ... 10 (10x); not stretchable; Horizontal marking; snap-on type; violet www.wago.com/793-502 /000-024 Item no.: 793-503 WMB marking card; as card; MARKED; 11 ... 20 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-503 white Item no.: 793-503/000-002 www.wago.com/793-503 WMB marking card; as card; MARKED; 11 ... 20 (10x); not stretchable; Horizontal marking; snap-on type; /000-002 yellow Item no.: 793-503/000-005 www.wago.com/793-503 WMB marking card; as card; MARKED; 11 ... 20 (10x); not stretchable; Horizontal marking; snap-on type; /000-005 red Item no.: 793-503/000-006 www.wago.com/793-503 WMB marking card; as card; MARKED; 11 ... 20 (10x); not stretchable; Horizontal marking; snap-on type; /000-006 blue Item no.: 793-503/000-007 www.wago.com/793-503 WMB marking card; as card; MARKED; 11 ... 20 (10x); not stretchable; Horizontal marking; snap-on type; /000-007 gray Item no.: 793-503/000-012 www.wago.com/793-503 WMB marking card; as card; MARKED; 11 ... 20 (10x); not stretchable; Horizontal marking; snap-on type; /000-012 orange Item no.: 793-503/000-017 www.wago.com/793-503 WMB marking card; as card; MARKED; 11 ... 20 (10x); not stretchable; Horizontal marking; snap-on type; /000-017 light green Item no.: 793-503/000-023 www.wago.com/793-503 WMB marking card; as card; MARKED; 11 ... 20 (10x); not stretchable; Horizontal marking; snap-on type; /000-023 green Item no.: 793-503/000-024 WMB marking card; as card; MARKED; 11 ... 20 (10x); not stretchable; Horizontal marking; snap-on type; violet Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at {0}. 29.12.2019    Page 8/14 Data sheet  |  Item number: 788-312 www.wago.com/788-312 violet www.wago.com/793-503 /000-024 Item no.: 793-504 WMB marking card; as card; MARKED; 21 ... 30 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-504 white Item no.: 793-504/000-002 www.wago.com/793-504 WMB marking card; as card; MARKED; 21 ... 30 (10x); not stretchable; Horizontal marking; snap-on type; /000-002 yellow Item no.: 793-504/000-005 www.wago.com/793-504 WMB marking card; as card; MARKED; 21 ... 30 (10x); not stretchable; Horizontal marking; snap-on type; /000-005 red Item no.: 793-504/000-006 www.wago.com/793-504 WMB marking card; as card; MARKED; 21 ... 30 (10x); not stretchable; Horizontal marking; snap-on type; /000-006 blue Item no.: 793-504/000-012 www.wago.com/793-504 WMB marking card; as card; MARKED; 21 ... 30 (10x); not stretchable; Horizontal marking; snap-on type; /000-012 orange Item no.: 793-504/000-017 www.wago.com/793-504 WMB marking card; as card; MARKED; 21 ... 30 (10x); not stretchable; Horizontal marking; snap-on type; /000-017 light green Item no.: 793-504/000-023 www.wago.com/793-504 WMB marking card; as card; MARKED; 21 ... 30 (10x); not stretchable; Horizontal marking; snap-on type; /000-023 green Item no.: 793-505 WMB marking card; as card; MARKED; 31 ... 40 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-505 white Item no.: 793-505/000-005 www.wago.com/793-505 WMB marking card; as card; MARKED; 31 ... 40 (10x); not stretchable; Horizontal marking; snap-on type; /000-005 red Item no.: 793-505/000-006 www.wago.com/793-505 WMB marking card; as card; MARKED; 31 ... 40 (10x); not stretchable; Horizontal marking; snap-on type; /000-006 blue Item no.: 793-505/000-007 www.wago.com/793-505 WMB marking card; as card; MARKED; 31 ... 40 (10x); not stretchable; Horizontal marking; snap-on type; /000-007 gray Item no.: 793-505/000-012 www.wago.com/793-505 WMB marking card; as card; MARKED; 31 ... 40 (10x); not stretchable; Horizontal marking; snap-on type; /000-012 orange Item no.: 793-506 WMB marking card; as card; MARKED; 41 ... 50 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-506 white Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at {0}. 29.12.2019    Page 9/14 Data sheet  |  Item number: 788-312 www.wago.com/788-312 white Item no.: 793-506/000-005 www.wago.com/793-506 WMB marking card; as card; MARKED; 41 ... 50 (10x); not stretchable; Horizontal marking; snap-on type; /000-005 red Item no.: 793-506/000-006 www.wago.com/793-506 WMB marking card; as card; MARKED; 41 ... 50 (10x); not stretchable; Horizontal marking; snap-on type; /000-006 blue Item no.: 793-506/000-012 www.wago.com/793-506 WMB marking card; as card; MARKED; 41 ... 50 (10x); not stretchable; Horizontal marking; snap-on type; /000-012 orange Item no.: 793-506/000-017 www.wago.com/793-506 WMB marking card; as card; MARKED; 41 ... 50 (10x); not stretchable; Horizontal marking; snap-on type; /000-017 light green Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; white Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-002 type; yellow Item no.: 793-5501/000-005 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/793-5501 /000-005 Item no.: 793-5501/000-006 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/793-5501 /000-006 Item no.: 793-5501/000-007 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/793-5501 /000-007 Item no.: 793-5501/000-012 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/793-5501 /000-012 Item no.: 793-5501/000-014 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; brown www.wago.com/793-5501 /000-014 Item no.: 793-5501/000-017 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/793-5501 /000-017 Item no.: 793-5501/000-023 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/793-5501 /000-023 Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at {0}. 29.12.2019    Page 10/14 Data sheet  |  Item number: 788-312 www.wago.com/788-312 Item no.: 793-5501/000-024 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/793-5501 /000-024 Item no.: 793-566 WMB marking card; as card; MARKED; 1 ... 50 (2x); not stretchable; Horizontal marking; snap-on type; white www.wago.com/793-566 Item no.: 793-566/000-002 WMB marking card; as card; MARKED; 1 ... 50 (2x); not stretchable; Horizontal marking; snap-on type; yellow www.wago.com/793-566 /000-002 Item no.: 793-566/000-005 WMB marking card; as card; MARKED; 1 ... 50 (2x); not stretchable; Horizontal marking; snap-on type; red www.wago.com/793-566 /000-005 Item no.: 793-566/000-006 WMB marking card; as card; MARKED; 1 ... 50 (2x); not stretchable; Horizontal marking; snap-on type; blue www.wago.com/793-566 /000-006 Item no.: 793-566/000-007 WMB marking card; as card; MARKED; 1 ... 50 (2x); not stretchable; Horizontal marking; snap-on type; gray www.wago.com/793-566 /000-007 Item no.: 793-566/000-012 WMB marking card; as card; MARKED; 1 ... 50 (2x); not stretchable; Horizontal marking; snap-on type; orange www.wago.com/793-566 /000-012 Item no.: 793-566/000-017 WMB marking card; as card; MARKED; 1 ... 50 (2x); not stretchable; Horizontal marking; snap-on type; light green www.wago.com/793-566 /000-017 Item no.: 793-566/000-023 WMB marking card; as card; MARKED; 1 ... 50 (2x); not stretchable; Horizontal marking; snap-on type; green www.wago.com/793-566 /000-023 Item no.: 793-566/000-024 WMB marking card; as card; MARKED; 1 ... 50 (2x); not stretchable; Horizontal marking; snap-on type; violet www.wago.com/793-566 /000-024 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 ferrule Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight www.wago.com/216-244 crimped; acc. to DIN 46228, Part 4/09.90; black Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at {0}. 29.12.2019    Page 11/14 Data sheet  |  Item number: 788-312 www.wago.com/788-312 crimped; acc. to DIN 46228, Part 4/09.90; black Item no.: 216-542 Twin ferrule; Sleeve for 2 x 1 mm² / AWG 2 x 18; red, insulated; 12 mm long; red www.wago.com/216-542 General accessories Item no.: 209-145 Group marker carrier www.wago.com/209-145 Item no.: 209-184 Protection cover; transparent www.wago.com/209-184 Item no.: 788-120 Accessories for relay modules; Operation status indicator: red www.wago.com/788-120 Item no.: 788-156 Basic relay; Nominal input voltage: 24 VDC; 2 changeover contacts; Limiting continuous current: 8 A; Module width: 13 mm; Module height: 15 mm www.wago.com/788-156 Downloads Documentation Instruction Leaflet Sockets with Elementary Relay/ SSR V 1.0.0 pdf 2.4 MB Download V 1.0.0 pdf 265.8 kB Download URL Download Additional Information Disposal; Electrical and electronic equipment, Packaging CAD files CAD data 2D/3D Models 788-312 CAE data EPLAN Data Portal 788-312 Download WSCAD Universe 788-312 Download Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at {0}. 29.12.2019    Page 12/14 Data sheet  |  Item number: 788-312 www.wago.com/788-312 Installation Notes Inserting a conductor Leiter anschließen Jumpered Easy commoning using adjacent jumpers Marking Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at {0}. 29.12.2019    Page 13/14 Data sheet  |  Item number: 788-312 www.wago.com/788-312 Marking using WMB Multi markers and group marker carriers Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.us Do you have any questions about our products? We are always happy to take your call at {0}. 29.12.2019    Page 14/14
788-312 价格&库存
很抱歉,暂时无法提供与“788-312”相匹配的价格&库存,您可以联系我们找货
    • 1+204.50039
    库存:1
    788-312
    • 1+75.924391+9.85360
    • 10+72.9640410+9.46940
    库存:458
