857-357
    WAGO(万可电子)
    通用 继电器 SPDT(1 Form C) 115VAC/DC 线圈 DIN 轨道
857-357 数据手册
Relay with 1 changeover contact (1u) (gold contacts) for normal switching power Nominal input voltage VN 24 V, 115 V, 230 V AC/DC Switching current (A) Relay with 1 changeover contact (1u) (gold contacts) for normal switching power Nominal input voltage VN 24 V DC 10 resistive load 1 0.1 1 10 100 400 Switching voltage (V) DC load limit curve * In order to prevent the gold layer from being damaged, 30 VDC switching voltages and 50 mA currents shall not be exceeded. Higher switching power leads to evaporation of the gold layer. The resulting deposits in the housing may reduce the service life. A1 A2 Description VN IN Item No. Pack. Unit Relay socket with miniature switching relay, for DIN 35 rail 24 V DC 10 mA 857-314 1 Technical Data Coil: Input voltage range Contacts: Contact material Max. continuous current Max. switching voltage Max. switching power (resistive) Recommended minimum load Pull-in/drop-out/bounce time typ. Mechanical life General specifications: Nominal voltage to EN 60664-1 Dielectric strength, contact-coil (AC, 1 min) Dielectric strength open contact (AC, 1 min) Dielectric strength contact-contact (AC, 1 min) Ambient operating temperature at VN Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Strip length Standards/specifications WAGO Kontakttechnik GmbH & Co. KG Subject to design changes 14.01.2015 VN IN Item No. Pack. Unit 24 V AC/DC 115 V AC/DC 230 V AC/DC 8.5 mA 4 mA 3.5 mA 857-364 857-367 857-368 1 1 1 Accessories see pages 33 … 35 Accessories see pages 33 … 35 VN -15 % ... +20 % VN -15 % ... +20 % (857-364/857-367) VN -15 % ... +10 % (857-368) AgNi + Au 6A* 250 VAC * (1250 VA AC; DC see load limit curve) 1 VDC / 1 mA / 1 mW, 24 VDC / 0.05 mA 8ms / 4ms / 5 x 106 switching operations AgNi + Au 6A* 250 VAC * 1500 VA AC; DC see load limit curve * 1 VDC / 1 mA / 1 mW 8ms / 4ms / 5 x 106 switching operations 250 V / 4 kV / 2 4 kVrms 1 kVrms -25 °C ... +60 °C -40 °C ... +70 °C 6 x 81 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP® S 0.34 … 2.5 mm² / AWG 22 … 14 9 … 10 mm / 0.35 … 0.39 in EN 60664-1; EN 61810-1; EN 61140; r; (857-314: g) 250 V / 4 kV / 2 4 kVrms 1 kVrms -25 °C ... +60 °C -40 °C ... +70 °C 6 x 81 x 94 Height from upper-edge of DIN 35 rail CAGE CLAMP® S 0.34 … 2.5 mm² / AWG 22 … 14 9 … 10 mm / 0.35 … 0.39 in EN 60664-1; EN 61810-1; r (857-368: g) Postfach 2880 - D-32385 Minden Hansastr. 27 - D-32423 Minden Tel.: +49(0)571/887-0 E-Mail: info@wago.com Fax: +49(0)571/887-169 www.wago.com
857-357 价格&库存
很抱歉,暂时无法提供与“857-357”相匹配的价格&库存,您可以联系我们找货
  • 1+195.20300
库存:6
