862-8503
862-8503
    WAGO(万可电子)
862-8503 数据手册
Data sheet from 22.01.2013 Item no.: 862-8503 Product description: 4-CONDUCTOR DEVICE CONNECTORS FOR TOP FIXING SCREWS AND NUTS 3 MM Ø OR FOR SELF-TAPPING SCREW 2.9 MM Ø N-PE-L1 3 POLE Produkt kann von Bild abweichen / product may differ Packing unit 250 pieces RoHS compliant Product group 9 (Std Chassis Mt Blocks) pole count 3 Cross section [mm²] 0.5 - 4 mm² Cross section [AWG] 20 - 12 AWG Connection method CAGE CLAMP®S Connection Measured voltage EN 500 V Measured shock voltage 6 kV Pollution degree 3 Current intensity EN 32 A Weight 20.894 g Color black No. of connection Points 12 No. of potentials 3 Height 22.3 mm Height 0.878 in Width 36 mm Width 1.417 in Depth 1 von 3 35 mm Depth 1.378 in Strip length from 10 mm Strip length to 11 mm Strip length 0.41 in 2 von 3 Data sheet from 22.01.2013 Item no. Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 862-8503 CSA 154112-1505030 300 20 22-12 862-8503 DNV E-10423 500 32 4,0 862-8503 ENEC15 143856-01 500 32 0,5-4 862-8503 GL 33242-06HH 500 32 4 862-8503 LR 91/20112(E6) 500 32 4,0 862-8503 LR 91/20112E4 500 32 4 862-8503 UR E45172 300 20 22-12 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 3 von 3
862-8503 价格&库存
很抱歉,暂时无法提供与“862-8503”相匹配的价格&库存,您可以联系我们找货
  • 1+41.132941+5.30283
  • 10+29.2413210+3.76977
  • 25+25.6108625+3.30174
  • 50+23.3475950+3.00996
  • 100+21.47814100+2.76895
  • 250+19.54022250+2.51911
  • 500+18.41486500+2.37403
  • 1000+17.528161000+2.25972
  • 5000+16.152555000+2.08238
库存:354
