870-904
870-904
    WAGO(万可电子)
870-904 数据手册
Data sheet from 19.01.2012 Item no.: 870-904 Product description: 2-Conductor through terminal block suitable for Ex i applications Produkt kann von Bild abweichen / product may differ Packing unit 100 pieces RoHS compliant Product group 16 (RAIL MOUNTED TERMINAL BLOCK WITH CCC) Cross section [mm²] 0.08 - 2.5 mm² Cross section [AWG] 28 - 14 AWG Wiring method s + f-st Connection method CAGE CLAMP®COMPACT CONNECTION Cross section [mm²] 0.08 - 4 mm² Cross section [AWG] 28 - 12 AWG Wiring method f Connection method CAGE CLAMP®COMPACT CONNECTION Measured voltage EN 500 V Measured shock voltage 6 kV Pollution degree 3 Current intensity EN 24 A Weight 4.1 g Color blue Wiring type Front-entry No. of connection Points 2 No. of potentials 1 Height 1 von 4 27.5 mm Height 1.08 in Width 5 mm Width 0.197 in 2 von 4 Data sheet from 19.01.2012 Depth 44.5 mm Depth 1.75 in Strip length from 6 mm Strip length to 7 mm Strip length 0.26 in Mounting TS 35 3 von 4 Data sheet from 19.01.2012 Item number Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 870-904 ABS 05-HG476175/3-PDA 500 24 2,5 870-904 CCA NL6826 500 24 2,5 870-904 cURus E45172 300 20 28-12 870-904 DNV E-9214 500 24 2,5 870-904 GL 17295-00HH 500 24 2,5 870-904 KEMA 2143311.01 500 24 2,5 870-904 LR 91/20112(E6) 500 24 2,5 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 4 von 4
870-904 价格&库存
很抱歉,暂时无法提供与“870-904”相匹配的价格&库存,您可以联系我们找货
