Printview: 4-conductor ground terminal block; suitable for Ex e II applications - Item No.: 2002-1407
Item No.: 2002-1407
Marking
Business data
Supplier
WAGO
Item no.
2002-1407
GTIN / EAN
4017332999311
Content
1
Order amount
100
Customer item number
Notes
Technical data
Miscellaneous
Total number of connection points
4
Total number of potentials
1
Color
green-yellow
Ratings according to 1
IEC/EN 60947-7-2
Connection technology (1)
Push-in CAGE CLAMP®
Nominal cross section 1
2.5 mm²
Solid sizes 1
0.25 … 4 mm² / 22 … 12 AWG
solid, directly pluggable 1
0.75 … 4 mm² / 18 … 12 AWG
Fine-stranded wires 1
min. fine-stranded with insulated ferrule, push-in terminati 0.75 mm² / 18 AWG
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Strip length 1
10 … 12 mm / 0.39 … 0.47 in
Type of wiring
Front-entry wiring
Design
horizontal
Marking level
Center/Side marking
Insulating material
Polyamide 66 (PA 66)
Fire load [MJ]
0.118 [MJ]
Weight [g]
10.1 [g]
Width
5.2 mm / 0.205 in
Height from upper-edge of DIN-rail [mm]
32.9 [mm]
32.9 mm / 1.295 in
Length
69.9 mm / 2.752 in
Type of mounting
DIN 35 rail
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“2002-1407”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+130.583571+16.97946
- 10+92.8638210+12.07486
- 25+82.4502125+10.72080
- 50+76.1983350+9.90788
- 100+71.16031100+9.25280
- 250+66.05525250+8.58901
- 500+63.14258500+8.21028
- 1000+60.874771000+7.91540
- 国内价格
- 1+131.10825
- 10+84.22964
- 100+71.45103
- 250+66.32535
- 500+63.39470
- 1000+61.11662
