2060-1453/998-404
2060-1453/998-404
    WAGO(万可电子)
    插件,P=4mm
    接线端子 间距:4.00mm 每排针脚数:3 排数:单排
2060-1453/998-404 数据手册
Data sheet  |  Item number: 2060-1453/998-404 THR PCB terminal block; push-button; 0.75 mm²; Pin spacing 4 mm; 3-pole; Push-in CAGE CLAMP®; in tape-and-reel packaging; 0,75 mm2; white www.wago.com/2060-1453/998-404 Color: R = Feed direction L = (pole no. x pin spacing) – 0.1 mm A = (pole no. x pin spacing) + 4 mm 20.09.2019    Page 1/6 Data sheet  |  Item number: 2060-1453/998-404 www.wago.com/2060-1453/998-404 Item description THR PCB terminal blocks with push-buttons and Push-in CAGE CLAMP® connection Push-in termination of solid and ferruled conductors Convenient termination/removal of fine-stranded conductors via push-buttons Just 4.5 mm tall Available in tape-and-reel packaging for automated assembly Also suitable for wave soldering Note: Application note: Suitable for lead-free, reflow-soldering profiles per DIN EN 61760-1 and IEC 60068-2-58 up to max. 260 °C peak temperature. Due to customer-specific variables (e.g., component configuration and orientation, type of soldering machine, solder paste), trial runs are recommended to ensure product and process compatibility under actual manufacturing conditions. Recommendation: Recommendation for stencil: 150 µm material thickness The stencil hole diameter is identical to the outer diameter of the metal-plated PCB hole. Data Electrical data 20.09.2019    Page 2/6 Data sheet  |  Item number: 2060-1453/998-404 www.wago.com/2060-1453/998-404 Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 63 V Rated impulse voltage (III / 3) 2.5 kV Rated voltage (III / 2) 160 V Rated impulse voltage (III / 2) 2.5 kV Rated voltage (II / 2) 320 V Rated impulse voltage (II / 2) 2.5 kV Rated current 9  A Approvals per UL 1977 Rated voltage per UL 1977 (factory wiring only) 320 V Rated current per UL 1977 (factory wiring only) 9  A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Push-button Solid conductor 0.2 … 0.75 mm² / 24 … 18 AWG Fine-stranded conductor 0.2 … 0.75 mm² / 24 … 18 AWG Fine-stranded conductor with ferrule with plastic collar 0.25 … 0.34 mm² Fine-stranded conductor with ferrule without plastic collar 0.25 … 0.34 mm² Strip length 6 … 7 mm / 0.24 … 0.28 inch Conductor entry angle to the PCB 0  ° Total number of connection points 3 Total number of potentials 3 Number of connection types 1 Number of levels 1 No. of poles 3 Geometrical Data Pin spacing 4 mm / 0.157 inch Width 11.9 mm / 0.467 inch Height 6.9 mm / 0.272 inch Height from the surface 4.5 mm / 0.177 inch Depth 12.7 mm / 0.5 inch Solder pin length 2.4 mm Solder pin dimensions 1.2 x 0.75 mm Reel diameter of tape-and-reel packaging 330 mm Tape width 24 mm PCB contact 20.09.2019    Page 3/6 Data sheet  |  Item number: 2060-1453/998-404 www.wago.com/2060-1453/998-404 PCB contact PCB contact THR Solder pin arrangement over the entire terminal strip, in line Number of solder pins per potential 2 Material Data Color white Material group I Insulating material Polyphthalamide (PPA GF) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper alloy Contact plating tin-plated Weight 0.769 g Environmental Requirements Limit temperature range -60 … +105 °C Commercial data Country of origin CH GTIN 4055143331180 Customs Tariff No. 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL7724 CCA DEKRA Certification B.V. EN 60838 NTR NL 2168246 KEMA/KEUR DEKRA Certification B.V. EN 60838 2168246.01 KEMA/KEUR DEKRA Certification B.V. EN 60947 71-108183 20.09.2019    Page 4/6 Data sheet  |  Item number: 2060-1453/998-404 www.wago.com/2060-1453/998-404 KEMA/KEUR DEKRA Certification B.V. EN 60998 71-108181 UL-Approvals Logo Approval Additional Approval Text cURus Underwriters Laboratories Inc. UL 1977 Certificate name E4517120111005 Compatible products ferrule Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-131 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Item no.: 2060-189 Operating tool; made of insulating material; for 2060 Series www.wago.com/2060-189 Item no.: 206-860 Operating tool; for 2060 Series www.wago.com/206-860 tools Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download 20.09.2019    Page 5/6 Data sheet  |  Item number: 2060-1453/998-404 www.wago.com/2060-1453/998-404 CAD/CAE-Data CAD data 3D Download 2060-1453/998-404 URL Download   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.09.2019    Page 6/6
2060-1453/998-404 价格&库存
很抱歉,暂时无法提供与“2060-1453/998-404”相匹配的价格&库存,您可以联系我们找货
