2061-603/998-404
2061-603/998-404
    WAGO(万可电子)
    接线端子 每排针脚数:3 排数:单排
2061-603/998-404 数据手册
Printview: SMD PCB terminal block; Push-button; 1.5 mm²; Pin spacing 6 mm; 3-pole; Push-in CAGE CLAMP®; in tape-and-reel packaging - Item No.: 2061-603/998-404 . SMD PCB terminal block; Push-button; 1.5 mm²; Pin spacing 6 mm; 3-pole; Push-in CAGE CLAMP®; in tape-and-reel packaging Item No.: 2061-603/998-404 . SMD PCB terminal block; Push-button; 1.5 mm²; Pin spacing 6 mm; 3-pole; Push-in CAGE CLAMP®; in tape-andreel packaging . Marking . Business data Supplier WAGO Item no. 2061-603/998-404 GTIN / EAN 4055143242783 Content 1 Order amount 450 Customer item number . Notes Item description:SMD PCB terminal blocks with Push-in CAGE CLAMP® connection and push-buttonsJust 5.6 mm tallPush-in termination of solid and ferruled conductorsPush-buttons simplify insertion/removal of all conductor typesAvailable in tape-and-reel packaging for automated assemblyNote:Einsatzhinweise:Geeignet für bleifreie Reflow-Lötprofile in Anlehnung an DIN EN 61760-1 bzw. DIN EN 60068-2-58 bis zu einer Peak-Temperatur von max. 260 °C. Aufgrund von unterschiedlichen anwendungsspezifischen Einflussgrößen (Bauteilanordnung und ausrichtung, Lötanlage, Lötpaste) wird empfohlen, mittels Testläufen ein geeignetes Profil unter Fertigungsbedingungen zu ermitteln.Recommendation:Recommendation for SMD stencil:Material thickness, 150 µm. Pattern layout identical to solder pad layout. WAGO Kontakttechnik GmbH & Co. KG 1 Printview: SMD PCB terminal block; Push-button; 1.5 mm²; Pin spacing 6 mm; 3-pole; Push-in CAGE CLAMP®; in tape-and-reel packaging - Item No.: 2061-603/998-404 Technical data Miscellaneous Packaging type BOX Ratings per IEC/EN 60664-1 Rated voltage (III / 3) [V] 250 [V] Rated impulse voltage (III / 3) [kV] 4 [kV] Rated voltage (III/2) [V] 320 [V] Rated impulse voltage (III / 2) [kV] 4 [kV] Rated voltage (II / 2) [V] 630 [V] Rated impulse voltage (II / 2) [kV] 4 [kV] Rated current [A] 17.5 [A] Legend (ratings) (III / 2) Overvoltage category III / Pollution degree 2 Approvals per UL 1977 Rated voltage UL (Use Group B) [V] 300 [V] Rated current UL (Use Group B) [A] 10 [A] Rated voltage UL (Use Group D) [V] 300 [V] Rated current UL (Use Group D) [A] 10 [A] No. of poles 3 Total number of connection points 3 Total number of potentials 3 Number of connection types 1 Number of levels 1 Connection technology Push-in CAGE CLAMP® Actuation type Operating lever Solid conductor 0.5 … 1.5 mm² / 20 … 16 AWG Fine-stranded conductor 0.5 … 1.5 mm² / 20 … 16 AWG Fine-stranded conductor with ferrule with plastic collar 0.5 … 0.75 mm² Fine-stranded conductor with ferrule without plastic collar 0.5 … 0.75 mm² / … Strip length 7 … 10 mm / 0.28 … 0.39 Inch Pin spacing 6 mm (0.24 in) Width 17.7 mm / 0.697 Inch Height 5.6 mm / 0.22 Inch Height from the surface 5.6 mm / 0.22 Inch Depth 15.8 mm / 0.622 Inch Reel diameter of tape-and-reel packaging [mm] 330 [mm] WAGO Kontakttechnik GmbH & Co. KG 2 Printview: SMD PCB terminal block; Push-button; 1.5 mm²; Pin spacing 6 mm; 3-pole; Push-in CAGE CLAMP®; in tape-and-reel packaging - Item No.: 2061-603/998-404 Technical data Tape width [mm] 24 [mm] PCB contact SMD Color white Material group I Insulating material Polyphtalamide (PPA GF) Flammability class per UL94 V0 Contact material Copper alloy Contact plating tin-plated Weight [g] 1.609 [g] Limit temperature range -60 … 105 °C WAGO Kontakttechnik GmbH & Co. KG 3 Printview: SMD PCB terminal block; Push-button; 1.5 mm²; Pin spacing 6 mm; 3-pole; Push-in CAGE CLAMP®; in tape-and-reel packaging - Item No.: 2061-603/998-404 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 4 Printview: SMD PCB terminal block; Push-button; 1.5 mm²; Pin spacing 6 mm; 3-pole; Push-in CAGE CLAMP®; in tape-and-reel packaging - Item No.: 2061-603/998-404 WAGO Kontakttechnik GmbH & Co. KG 5 Printview: SMD PCB terminal block; Push-button; 1.5 mm²; Pin spacing 6 mm; 3-pole; Push-in CAGE CLAMP®; in tape-and-reel packaging - Item No.: 2061-603/998-404 WAGO Kontakttechnik GmbH & Co. KG 6 Printview: SMD PCB terminal block; Push-button; 1.5 mm²; Pin spacing 6 mm; 3-pole; Push-in CAGE CLAMP®; in tape-and-reel packaging - Item No.: 2061-603/998-404 WAGO Kontakttechnik GmbH & Co. KG 7 Printview: SMD PCB terminal block; Push-button; 1.5 mm²; Pin spacing 6 mm; 3-pole; Push-in CAGE CLAMP®; in tape-and-reel packaging - Item No.: 2061-603/998-404 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 8
2061-603/998-404 价格&库存
很抱歉,暂时无法提供与“2061-603/998-404”相匹配的价格&库存,您可以联系我们找货
  • 450+18.32955450+2.38092
  • 900+17.41979900+2.26275
  • 1350+16.982061350+2.20589
  • 2250+16.514572250+2.14516
  • 3150+16.251223150+2.11095
  • 4500+16.005654500+2.07906
库存:507
