2200-1301
2200-1301
    WAGO(万可电子)
    WAGO - 2200-1301 - 3-CONDUCTOR THROUGH TERMINAL BLOCK
2200-1301 数据手册
Data sheet  |  Item number: 2200-1301 3-conductor through terminal block; with push-button; 1 mm²; with test port; side and center marking; for DIN-rail 35 x 15 and 35 x 7.5; Push-in CAGE CLAMP®; 1,00 mm2; gray www.wago.com/2200-1301 Color: Data Electrical data 05.09.2019    Page 1/10 Data sheet  |  Item number: 2200-1301 www.wago.com/2200-1301 Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 800 V Rated impulse voltage (III / 3) 8 kV Rated current 13.5 A Rated current (2) 18 A Approvals per UL 1059 Rated voltage UL (Use Group B) 600 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group C) 600 V Rated current UL (Use Group C) 10 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Push-in Push-button Connectable conductor materials Copper Nominal cross section 1 mm² Solid conductor 0.14 … 1.5 mm² / 24 … 16 AWG Solid conductor, push-in termination 0.5 … 1.5 mm² / 20 … 16 AWG Fine-stranded conductor 0.14 … 1.5 mm² / 24 … 16 AWG Strip length 9 … 11 mm / 0.35 … 0.43 inch Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross section can also be inserted via push-in termination. Total number of connection points 3 Total number of potentials 1 Number of levels 1 Type of wiring Front-entry wiring Number of jumper slots 2 Geometrical Data Width 3.5 mm / 0.138 inch Height from upper-edge of DIN-35 rail 32.9 mm / 1.295 inch Depth 58.2 mm / 2.291 inch Mechanical data Design horizontal Type of mounting DIN-35 rail Marking level Center/side marking 05.09.2019    Page 2/10 Data sheet  |  Item number: 2200-1301 www.wago.com/2200-1301 Material Data Color gray Insulating material Polyamide 66 (PA 66) Weight 4.166 g Commercial data Country of origin DE GTIN 4055143691611 Customs Tariff No. 85369010000 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text Certificate name AEx Underwriters Laboratories Inc. UL 60079 4788311594 ATEX Physikalisch Technische Bundesanstalt IEC 60079-0 PTB 18 ATEX 1003 U IECEx Physikalisch Technische Bundesanstalt IEC 60079 IECEx PTB 18.0010U (Ex eb IIC Gb and Ex eb I Mb) Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL 7663 CSA DEKRA Certification B.V. C22.2 70173737 KEMA/KEUR DEKRA Certification B.V. EN 60947 71102874 Ship Approvals Certificate 05.09.2019    Page 3/10 Data sheet  |  Item number: 2200-1301 www.wago.com/2200-1301 Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping - 19HG1866350PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00003JT LR Lloyds Register - 19/20050 Approval Additional Approval Text Certificate name cURus Underwriters Laboratories Inc. UL 1059 4788311592 UL-Approvals Logo Compatible products ferrule Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight www.wago.com/216-242 crimped; acc. to DIN 46228, Part 4/09.90; gray Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; red www.wago.com/216-243 Item no.: 2000-1391 End and intermediate plate; 0.7 mm thick; gray www.wago.com/20001391 Item no.: 2000-1392 End and intermediate plate; 0.7 mm thick; orange www.wago.com/20001392 End plate 05.09.2019    Page 4/10 Data sheet  |  Item number: 2200-1301 www.wago.com/2200-1301 check Item no.: 2000-510 TOPJOB®S L-type test plug module; modular; for jumper contact slot; 1,00 mm2; gray www.wago.com/2000-510 Item no.: 2000-511 TOPJOB®S L-type test plug module; modular; for jumper contact slot; 1-pole; 1,00 mm2; gray www.wago.com/2000-511 Item no.: 2000-549 Spacer module; modular; e.g., for bridging commoned terminal blocks; gray www.wago.com/2000-549 Item no.: 2000-552 Modular TOPJOB®S connector; modular; for jumper contact slot; 2-pole; 1,00 mm2; gray www.wago.com/2000-552 Item no.: 2000-553 Modular TOPJOB®S connector; modular; for jumper contact slot; 3-pole; 1,00 mm2; gray www.wago.com/2000-553 Item no.: 2000-554 Modular TOPJOB®S connector; modular; for jumper contact slot; 4-pole; 1,00 mm2; gray www.wago.com/2000-554 Item no.: 2000-555 Modular TOPJOB®S connector; modular; for jumper contact slot; 5-pole; 1,00 mm2; gray www.wago.com/2000-555 Item no.: 2000-556 Modular TOPJOB®S connector; modular; for jumper contact slot; 6-pole; 1,00 mm2; gray www.wago.com/2000-556 Item no.: 2000-557 Modular TOPJOB®S connector; modular; for jumper contact slot; 7-pole; 1,00 mm2; gray www.wago.com/2000-557 Item no.: 2000-558 Modular TOPJOB®S connector; modular; for jumper contact slot; 8-pole; 1,00 mm2; gray www.wago.com/2000-558 Item no.: 2000-559 Modular TOPJOB®S connector; modular; for jumper contact slot; 9-pole; 1,00 mm2; gray www.wago.com/2000-559 Item no.: 2000-560 Modular TOPJOB®S connector; modular; for jumper contact slot; 10-pole; 1,00 mm2; gray www.wago.com/2000-560 Item no.: 2009-174 Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray www.wago.com/2009-174 Item no.: 2009-182 Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray www.wago.com/2009-182 Item no.: 210-136 Test plug; 2 mm Ø; with 500 mm cable; red www.wago.com/210-136 Item no.: 210-137 Test plug; 2.3 mm Ø; with 500 mm cable; yellow www.wago.com/210-137 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm www.wago.com/210-112 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715 www.wago.com/210-114 Carrier rail 05.09.2019    Page 5/10 Data sheet  |  Item number: 2200-1301 www.wago.com/2200-1301 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm www.wago.com/210-115 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-118 Item no.: 210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver- www.wago.com/210-196 colored Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715 www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; copper-colored www.wago.com/210-198 Item no.: 2000-402 Push-in type jumper bar; insulated; 2-way; Nominal current 14 A; light gray www.wago.com/2000-402 Item no.: 2000-402/000-005 Push-in type jumper bar; insulated; 2-way; Nominal current 14 A; red www.wago.com/2000-402 /000-005 Item no.: 2000-402/000-006 Push-in type jumper bar; insulated; 2-way; Nominal current 14 A; blue www.wago.com/2000-402 /000-006 Item no.: 2000-402/000-018 Push-in type jumper bar; insulated; 2-way; Nominal current 14 A; yellow-green www.wago.com/2000-402 /000-018 Item no.: 2000-403 Push-in type jumper bar; insulated; 3-way; Nominal current 14 A; light gray www.wago.com/2000-403 Item no.: 2000-403/000-005 Push-in type jumper bar; insulated; 3-way; Nominal current 14 A; red www.wago.com/2000-403 /000-005 Item no.: 2000-403/000-006 Push-in type jumper bar; insulated; 3-way; Nominal current 14 A; blue www.wago.com/2000-403 /000-006 Item no.: 2000-404 Push-in type jumper bar; insulated; 4-way; Nominal current 14 A; light gray www.wago.com/2000-404 Item no.: 2000-404/000-005 Push-in type jumper bar; insulated; 4-way; Nominal current 14 A; red www.wago.com/2000-404 /000-005 Item no.: 2000-404/000-006 Push-in type jumper bar; insulated; 4-way; Nominal current 14 A; blue www.wago.com/2000-404 /000-006 Item no.: 2000-405 www.wago.com/2000-405 Jumper 05.09.2019    Page 6/10 Data sheet  |  Item number: 2200-1301 www.wago.com/2200-1301 Item no.: 2000-405 Push-in type jumper bar; insulated; 5-way; Nominal current 14 A; light gray www.wago.com/2000-405 Item no.: 2000-405/000-005 Push-in type jumper bar; insulated; 5-way; Nominal current 14 A; red www.wago.com/2000-405 /000-005 Item no.: 2000-405/000-006 Push-in type jumper bar; insulated; 5-way; Nominal current 14 A; blue www.wago.com/2000-405 /000-006 Item no.: 2000-405/011-000 Star point jumper; insulated; 3-way (1-3-5); IN = IN terminal block; light gray www.wago.com/2000-405 /011-000 Item no.: 2000-406 Push-in type jumper bar; insulated; 6-way; Nominal current 14 A; light gray www.wago.com/2000-406 Item no.: 2000-406/000-005 Push-in type jumper bar; insulated; 6-way; Nominal current 14 A; red www.wago.com/2000-406 /000-005 Item no.: 2000-406/000-006 Push-in type jumper bar; insulated; 6-way; Nominal current 14 A; blue www.wago.com/2000-406 /000-006 Item no.: 2000-406/020-000 Delta jumper; insulated; 1-2 3-4 5-6; IN = IN terminal block; light gray www.wago.com/2000-406 /020-000 Item no.: 2000-407 Push-in type jumper bar; insulated; 7-way; Nominal current 14 A; light gray www.wago.com/2000-407 Item no.: 2000-407/000-005 Push-in type jumper bar; insulated; 7-way; Nominal current 14 A; red www.wago.com/2000-407 /000-005 Item no.: 2000-407/000-006 Push-in type jumper bar; insulated; 7-way; Nominal current 14 A; blue www.wago.com/2000-407 /000-006 Item no.: 2000-408 Push-in type jumper bar; insulated; 8-way; Nominal current 14 A; light gray www.wago.com/2000-408 Item no.: 2000-408/000-005 Push-in type jumper bar; insulated; 8-way; Nominal current 14 A; red www.wago.com/2000-408 /000-005 Item no.: 2000-408/000-006 Push-in type jumper bar; insulated; 8-way; Nominal current 14 A; blue www.wago.com/2000-408 /000-006 Item no.: 2000-409 Push-in type jumper bar; insulated; 9-way; Nominal current 14 A; light gray www.wago.com/2000-409 Item no.: 2000-409/000-005 Push-in type jumper bar; insulated; 9-way; Nominal current 14 A; red www.wago.com/2000-409 /000-005 Item no.: 2000-409/000-006 www.wago.com/2000-409 05.09.2019    Page 7/10 Data sheet  |  Item number: 2200-1301 www.wago.com/2200-1301 Item no.: 2000-409/000-006 Push-in type jumper bar; insulated; 9-way; Nominal current 14 A; blue www.wago.com/2000-409 /000-006 Item no.: 2000-410 Push-in type jumper bar; insulated; 10-way; Nominal current 14 A; light gray www.wago.com/2000-410 Item no.: 2000-410/000-005 Push-in type jumper bar; insulated; 10-way; Nominal current 14 A; red www.wago.com/2000-410 /000-005 Item no.: 2000-410/000-006 Push-in type jumper bar; insulated; 10-way; Nominal current 14 A; blue www.wago.com/2000-410 /000-006 Item no.: 2000-433 Push-in type jumper bar; insulated; from 1 to 3; Nominal current 14 A; light gray www.wago.com/2000-433 Item no.: 2000-433/000-005 Push-in type jumper bar; insulated; from 1 to 3; Nominal current 14 A; red www.wago.com/2000-433 /000-005 Item no.: 2000-433/000-006 Push-in type jumper bar; insulated; from 1 to 3; Nominal current 14 A; blue www.wago.com/2000-433 /000-006 Item no.: 2000-434 Push-in type jumper bar; insulated; from 1 to 4; Nominal current 14 A; light gray www.wago.com/2000-434 Item no.: 2000-435 Push-in type jumper bar; insulated; from 1 to 5; Nominal current 14 A; light gray www.wago.com/2000-435 Item no.: 2000-436 Push-in type jumper bar; insulated; from 1 to 6; Nominal current 14 A; light gray www.wago.com/2000-436 Item no.: 2000-437 Push-in type jumper bar; insulated; from 1 to 7; Nominal current 14 A; light gray www.wago.com/2000-437 Item no.: 2000-438 Push-in type jumper bar; insulated; from 1 to 8; Nominal current 14 A; light gray www.wago.com/2000-438 Item no.: 2000-439 Push-in type jumper bar; insulated; from 1 to 9; Nominal current 14 A; light gray www.wago.com/2000-439 Item no.: 2000-440 Push-in type jumper bar; insulated; from 1 to 10; Nominal current 14 A; light gray www.wago.com/2000-440 Item no.: 2009-402 Push-in type wire jumper; insulated; wire length 60 mm; Conductor cross section 0.75 mm²; suitable for 2000 and 2020 Series rail-mounted terminal blocks; gray www.wago.com/2009-402 Item no.: 2009-404 Push-in type wire jumper; insulated; wire length 110 mm; Conductor cross section 0.75 mm²; suitable for 2000 and 2020 Series rail-mounted terminal blocks; gray www.wago.com/2009-404 Item no.: 2009-406 Push-in type wire jumper; insulated; wire length 250 mm; Conductor cross section 0.75 mm²; suitable for 2000 and 2020 Series rail-mounted terminal blocks; gray www.wago.com/2009-406 Item no.: 210-103 Wire commoning chain; insulated; 50 connections; black www.wago.com/210-103 Item no.: 210-123 05.09.2019    Page 8/10 Data sheet  |  Item number: 2200-1301 www.wago.com/2200-1301 Item no.: 210-123 Wire commoning chain; insulated; 50 connections www.wago.com/210-123 Item no.: 2009-110 Marking strips; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Item no.: 2009-113 WMB-Inline; for Smart Printer; on reel; plain; snap-on type; white www.wago.com/2009-113 Item no.: 2009-113/000-002 WMB-Inline; for Smart Printer; on reel; plain; snap-on type; yellow www.wago.com/2009-113 /000-002 Item no.: 2009-113/000-005 WMB-Inline; for Smart Printer; on reel; plain; snap-on type; red www.wago.com/2009-113 /000-005 Item no.: 2009-113/000-006 WMB-Inline; for Smart Printer; on reel; plain; snap-on type; blue www.wago.com/2009-113 /000-006 Item no.: 2009-113/000-007 WMB-Inline; for Smart Printer; on reel; plain; snap-on type; gray www.wago.com/2009-113 /000-007 Item no.: 2009-113/000-012 WMB-Inline; for Smart Printer; on reel; plain; snap-on type; orange www.wago.com/2009-113 /000-012 Item no.: 2009-113/000-017 WMB-Inline; for Smart Printer; on reel; plain; snap-on type; light green www.wago.com/2009-113 /000-017 Item no.: 2009-113/000-023 WMB-Inline; for Smart Printer; on reel; plain; snap-on type; green www.wago.com/2009-113 /000-023 Item no.: 2009-113/000-024 WMB-Inline; for Smart Printer; on reel; plain; snap-on type; violet www.wago.com/2009-113 /000-024 Item no.: 793-3501 WMB marking card; as card; plain; snap-on type; white www.wago.com/793-3501 Item no.: 210-647 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-647 Item no.: 210-648 Operating tool with partially insulated shaft; Blade (2.5 x 0.4) mm; short; angled www.wago.com/210-648 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Marking accessories tools 05.09.2019    Page 9/10 Data sheet  |  Item number: 2200-1301 www.wago.com/2200-1301 Downloads Documentation Bid Text 2200-1301 docx 15.1 kB Download pdf 2.1 MB Download URL Download Additional Information Technical explanations Apr 3, 2019 CAD/CAE-Data CAD data 3D Download 2200-1301 EPLAN EPLAN Data Portal Download   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 05.09.2019    Page 10/10
2200-1301 价格&库存
很抱歉,暂时无法提供与“2200-1301”相匹配的价格&库存,您可以联系我们找货
  • 48+21.8628948+2.83201
  • 50+20.0282250+2.59436
  • 100+18.45458100+2.39052
  • 250+12.66827250+1.64099
  • 500+11.88990500+1.54016
  • 1000+11.253341000+1.45770
  • 5000+10.322005000+1.33706
库存:200
2200-1301
  • 48+22.3786348+2.89882
  • 50+20.5001350+2.65549
  • 100+18.89044100+2.44698
  • 250+12.96704250+1.67969
  • 500+12.17023500+1.57647
  • 1000+11.518511000+1.49205
  • 5000+10.566075000+1.36868
库存:200
