222-412/VE00-2500
222-412/VE00-2500
    WAGO(万可电子)
    端子 对接接头,闭端,单独开口 连接器 按进式 12-28 AWG 灰色,橙色
222-412/VE00-2500 数据手册
ELECTRICAL INSTALLATION PRODUCTS Splicing Connectors and Chassis Mount Terminal Blocks 221 SERIES LEVER-NUTS® The Next Generation of Compact Splicing Connectors 221 SERIES LEVER-NUTS® The Difference is Clear: • Connect any combination of solid, stranded and flexible copper wires faster and more reliably • Minimize space consumption in the junction box – by 40% compared to 222 Series • Visually inspect for proper strip length and complete wire insertion through its transparent housing • Operate comfortably and with lower operating forces by using familiar orange levers Electrical Data Rated voltage Nominal current Wire Size 600 V (1000 V signs & fixtures) 20 A Solid conductor 24 - 12 AWG l Flexible conductor 24 - 12 AWG L Stranded conductor Strip length Maximum operating temperature Approvals 24 - 12 AWG 11 mm / 0.43 in. 105 ⁰C Splicing wire connector 667 F Dual integrated test ports allow for easy testing of connection integrity COMPACT SPLICING CONNECTORS FOR ALL WIRE TYPES 8.3 mm 8.3 mm 18.6 mm 18.6 mm L 11 mm / 0.43 in. 1 13. mm 2-conductor connector Transparent 8.3 mm m L 11 mm / 0.43 in. 5-conductor connector Item No. Pack.-unit pcs Item No. Pack.-unit pcs 221-412/VE00-2500 2500 (bulk) 221-413/VE00-2500 2500 (bulk) 221-412 1=box of 100 pcs 221-413 1=box of 50 pcs Transparent Item No. Pack.-unit pcs 221-415/VE00-1000 1000 (bulk) 221-415 Operating tool for 221 Series Item No. 210-102 Two Test Slots Pack.-unit pcs 1 Wire Inserted Properly Wire Stripped Properly m .9 m 29 L 11 mm / 0.43 in. 3-conductor connector Transparent 18.6 mm 7m 18. Easily combine various types and sizes of wires • AWG 24 - 12 solid, stranded, flexible • 0.14 - 4 mm2 ″f-st″ • 0.2 - 4 mm2 ″s+st″ L l 1=box of 25 pcs 222 SERIES LEVER-NUTS® The Original Lever-Operated Splicing Connector 222 SERIES LEVER-NUTS® For all connections requiring: • Stranded/solid wires • Wide range of wire sizes • Combination of different wire sizes and types in one connector • Built-in test point • Low installed cost and safe operation • Maintenance-free connection • A reusable connector Electrical Data Rated voltage Nominal current Wire Size 600 V (1000 V signs & fixtures) 20 A Solid conductor 28 - 12 AWG l Flexible conductor 28 - 12 AWG L Stranded conductor Strip length Maximum operating temperature Approvals 28 - 12 AWG 9 ... 10 mm / 0.37 in. 105 ⁰C Splicing wire connector Grounding Equip. 64KA 667 F Integrated test port allows for easy testing of connection integrity CLASSIC SPLICING CONNECTORS FOR ALL WIRE TYPES 14.5 mm 14.5 mm 20.5 mm 20.5 mm L 9 ... 10 mm / 0.37 in. 12.4 mm 2-conductor connector Gray Pack.-unit pcs 222-412/PW05-0005 1=blister of 5 pcs 222-412/PW05-350 222-412/VE00-2500 20.5 mm L 9 ... 10 mm / 0.37 in. 17 mm 3-conductor connector Item No. 222-412 14.5 mm 1=box of 50 pcs 1=jar of 350 pcs 2,500 (bulk) Gray 5-conductor connector Item No. Pack.-unit pcs 222-413/PW05-0005 1=blister of 5 pcs 222-413 222-413/PW05-250 222-413/VE00-2500 L 9 ... 10 mm / 0.37 in. 26.6 mm 1=box of 50 pcs 1=jar of 250 pcs 2,500 (bulk) Gray Item No. Pack.-unit pcs 222-415/PW05-0005 1=blister of 5 pcs 222-415 222-415/PW05-150 222-415/VE00-1000 1=box of 40 pcs 1=jar of 150 pcs 1,000 (bulk) Operating tool for 222 Series Item No. 210-101 1) Strip wire Pack.-unit pcs 1 2) Push up lever 3) Insert conductor and push down lever. Repeat as necessary. ACCESSORIES For 221 and 222 Series LEVER-NUTS® CAN DO MORE ASSEMBLY Mounting accessories convert these connectors into terminal block solutions: • Mounting flexibility includes horizontal or vertical; snap to DIN-rail or screw-mount to flat surface • Multiple cable tie locations • Marking surfaces available for circuit identification 221: Inserting or removing connector from mounting carrier 222: Inserting or removing connector from the end of the carrier, securing with snap lock Mounting of strain relief plate to the mounting carrier Snapping the universal right angled adapter on the mounting carrier MOUNTING CARRIERS FOR LEVER-NUTS® Mounting carrier for 221 Series Item No. 221-500 Mounting carrier Pack.-unit pcs 10 for 222 Series Item No. 222-500 Strain relief plate Pack.-unit pcs 10 for 221 and 222 Series mounting carriers Item No. 222-505 Pack.-unit pcs 10 Universal right angled adapter for 221 and 222 Series, in combination with mounting carriers for horizontal mounting on DIN 35 rail Item No. 222-510 Pack.-unit pcs 10 MOUNTING Vertical mounting on DIN 35 rail with wire ties providing strain relief Mounting carrier with strain relief plate mounted vertically on flat surface Vertical mounting with strain relief plate on DIN 35 rail. Wiring locations identified by marker strips (210-334) Horizontal mounting with strain relief plate on flat surface. Wiring locations identified using marker strips (210-334) Horizontal mounting with strain relief plate on DIN 35 rail using angled DIN-rail adapter Horizontal mounting on DIN 35 rail using angled DIN-rail adapter 773 SERIES WALL-NUTS® PUSHWIRE® Connectors for Junction Boxes 773 SERIES WALL-NUTS® Highlights: • PUSHWIRE connection of solid and rigid-stranded wire • Save up to 50% in wiring time over twist-type connectors • Transparent housing for visual inspection of complete insertion • Color-coded for quick identification • Versions for 10 AWG, high temp, and hazardous locations Electrical Data Rated voltage Nominal current 3-conductor only Wire Size 600 V (1000 V signs & fixtures) 20 A 30 A Solid conductor 18 - 12 AWG l Stranded tin-bonded 22 - 16 AWG Stranded conductor (≤ 19 strands) Solid and stranded (3-conductor only) Strip length 3-conductor only Maximum operating temperature Approvals 16 - 12 AWG 14 - 10 AWG 10 ... 13 mm / 0.45 in. 12 ... 13 mm / 0.49 in. 105 ⁰C Splicing wire connector Grounding Equip. 667 F 64KA 773 SERIES WALL-NUTS® .5 .5 l 10 ... 13 mm / 0.45 in. Pack.-unit pcs 1=box of 100 pcs 773-162/PW25-0010 1=blister of 10 pcs 773-102/PW05-650 1=jar of 650 pcs 773-102/VE00-0500 500 (bulk) 773-102/VE00-2500 2,500 (bulk) 773-112 (for grounding) l 10 ... 13 mm / 0.45 in. 4-conductor connector Trasparent housing, yellow face 773-162 13 mm l 10 ... 13 mm / 0.45 in. 2-conductor connector Item No. mm m m m m 9.2 mm 1=box of 100 pcs Pack.-unit pcs 773-164 773-164/PW25-0010 773-104/PW05-400 773-104/VE00-0500 773-104/VE00-2500 773-114 (for grounding) 1=box of 100 pcs 1=blister of 10 pcs 1=jar of 400 pcs 500 (bulk) 2,500 (bulk) 1=box of 100 pcs 14.2 mm Transparent housing, black face Item No. Pack.-unit pcs 773-166 773-166/PW25-0010 773-106/PW00-250 773-166/VE00-0500 773-166/VE00-2500 773-116 (for grounding) 1=box of 50 pcs 1=blister of 10 pcs 1=jar of 250 pcs 500 (bulk) 2,500 (bulk) 1=box of 50 pcs 18 AWG “str.” 13.1 mm .5 m 24 mm m 25.6 mm m m m m .1 .5 20 19 19 13.1 mm 13 mm l 10 ... 13 mm / 0.45 in. l 12 ... 13 mm / 0.49 in. l 10 ... 13 mm / 0.45 in. 8-conductor connector 3- conductor connector for 10 AWG 4-conductor connector Item No. Item No. Transparent housing, dark gray face Item No. Transparent housing, red face Pack.-unit pcs 773-168 773-168/PW25-0010 773-108/VE00-2500 773-118 (for grounding) 1=box of 50 pcs 1=blister of 10 pcs 2,500 (bulk) 1=box of 50 pcs .5 19 13.1 mm m m 13 mm l 10 ... 13 mm / 0.45 in. 4-conductor connector for high temperature applications up to 150 ⁰C Black housing, black face Item No. 773-514 Pack.-unit pcs 50 18.8 mm 6-conductor connector Transparent housing, orange face Item No. 13.1 mm .5 19 13.1 mm 19 19 13.1 mm 773-173 773-173/PW25-0005 773-173/PW05-200 773-173/VE00-0500 773-173/VE00-2500 Pack.-unit pcs 1=box of 50 pcs 1=blister of 5 pcs 1=jar of 200 pcs 500 (bulk) 2,500 (bulk) with special port for 18 AWG stranded wire Transparent housing, light gray face 773-124 773-124/VE01-0000 Pack.-unit pcs 1=box of 100 pcs 2,500 (bulk) 773 SERIES WALL-NUTS® For Ex e Applications .1 m m m m m m l 10 ... 13 mm / 0.45 in. 19 mm l 10 ... 13 mm / 0.45 in. 2-conductor pushwire connector 773-492 4 19 .1 .1 13 mm 9 mm Item No. Pack.-unit pcs 100 l 10 ... 13 mm / 0.45 in. 4-conductor pushwire connector Item No. 773-494 4 Pack.-unit pcs 100 Item No. Pack.-unit pcs 773-496 4 100 20 .1 .1 19 m m m m 25.6 mm 24 mm l 10 ... 13 mm / 0.45 in. l 12 ... 13 mm / 0.49 in. 8-conductor pushwire connector 3-conductor pushwire connector for 10 AWG 773-498 4 6-conductor connector 14.2 mm 13.1 mm Item No. 13.1 mm 13.1 mm 19 19 13.1 mm Pack.-unit pcs 100 Item No. 773-493 4 Highlights: • Compact design allows a high concentration of more connectors in an Ex-junction box or Ex-terminal box resulting in space-savings and cost-effective installation solutions • Easy wiring provides time-saving installation • Resistance to vibration (shock-proof) • Built-in test slot for easy troubleshooting • Maintenance-free connection Pack.-unit pcs 50 Electrical Data Rated voltage Nominal current 3-conductor only Wire Size 550 V 24 A 42 A Solid conductor 18 - 12 AWG l Stranded tin-bonded 22 - 16 AWG Stranded conductor (≤ 19 strands) Solid and stranded (3-conductor only) Strip length 3-conductor only Maximum operating temperature Approvals 16 - 12 AWG 14 - 10 AWG 10 ... 13 mm / 0.45 in. 12 ... 13 mm / 0.49 in. 105 ⁰C Splicing wire connector 667 F MOUNTING CARRIERS FOR WALL-NUTS® Mounting carrier for Ex e applications Mounting carrier for pushwire connectors Item No. Item No. light gray 773-331 4 Pack.-unit pcs 10 orange 773-332 Pack.-unit pcs 10 ASSEMBLY Simple insertion of 773 into carrier - no tools required End stops are locked in place to secure the connectors Mounting carrier with connectors snaps on DIN RAIL Removal of carrier from DIN RAIL For hazardous applications, this 773 Series MUST be used in conjunction with the mounting carrier specified on this page (item number 773-331). Certification according to ATEX / UL Ex is based upon the use of the entire system (connector and mounting carrier). 224 SERIES INLINE CONNECTORS PUSHWIRE® and Squeeze-to-Open 224 SERIES Highlights: • Connect solid line-side wire with flexible or stranded load-side wire (eg. ceiling fan or light fixture) • Pushwire connect to line side; squeeze to connect load side • Daisy chain power with 2-conductor line-side versions • Perfect for use in ceiling fan or fixture installations Electrical Data Rated voltage Nominal current Wire Size 224-101/224-104 224-112/224-114 224-201 Strip length Maximum operating temp. Approvals 300 V 20 A Line Side Load Side 2x 16 - 14 AWG sol 20 - 16 AWG sol / str / flx 14 - 12 AWG sol 20 - 16 AWG sol / str / flx (line and load side) 9 ... 11 mm / 0.39 in. 105 ⁰C (120 ⁰C) Splicing wire connector 667 F • The perfect in-line connector for solid-to-flexible wire • Also with dual squeeze-to-open version for flexible-to-flexible wire • Tool-free connection 20 - 16 AWG sol / str / flx VK 224 SERIES INLINE CONNECTORS 15.5 mm 15.5 mm 8.5 20.5 mm mm 8.5 15.5 mm 20.5 mm mm 15.5 mm 9.5 15.5 mm 20.5 mm mm 8.5 mm 42 mm 9.5 l 9 ... 11 mm / 0.39 in. l 9 ... 11 mm / 0.39 in. l 9 ... 11 mm / 0.39 in. Inline connector Dual squeeze-to-open connector Inline connector Item No. Item No. with PUSHWIRE and squeeze-to-open connection Item No. 224-101 224-112 (daisy chain) Pack.-unit pcs 100 100 accepts flexible wire on both sides 224-201 Pack.-unit pcs 50 LINE SIDE Connection: Insert stripped solid conductor into circular entry and push to stop Removal: Hold wire to be removed and twist and pull the conductor LOAD SIDE Connection: Squeeze connector housing and insert stripped conductor into square entry, then release Removal: Squeeze connector housing and withdraw conductor 20.5 mm mm for increased operating temperature of 120 ⁰C 224-104 224-114 (daisy chain) Pack.-unit pcs 100 100 243 SERIES MICRO PUSHWIRE® Connectors for Junction Boxes 243 SERIES Highlights: • Common up to eight small, solid wires quickly and conveniently • Gang multiple connectors together with their dovetail features • Test the circuit through the front-facing test port • Differentiate circuits with multiple color options Electrical Data Rated voltage Nominal current Wire Size Solid conductor Strip length Maximum operating temperature Approvals 150 V 7A 22 - 18 AWG l 5 ... 6 mm / 0.22 in. U 105 ⁰C K MICRO PUSHWIRE® CONNECTORS FOR JUNCTION BOXES 5.8 mm 5.8 mm 10 243-804 243-304 243-504 m 4-conductor connector 243-204 m m l 5 ... 6 mm / 0.22 in. l 5 ... 6 mm / 0.22 in. Item No. 10 m 10 mm 18.4 mm 8-conductor connector Pack.-unit pcs 100 100 100 100 Item No. 243-208 243-808 243-308 243-508 Assemble modular connectors into ganged connector strips Mounting carrier Pack.-unit pcs 50 50 50 for DIN-rail or flat surface mounting Item No. Pack.-unit pcs 243-113 (6 connectors) 10 243-112 (4 connectors) 10 50 Removing mounting carrier from DIN-rail assembly 873 SERIES LUMI-NUTS® PUSHWIRE® Connector for Luminaire Disconnect 873 SERIES LUMI-NUTS® Highlights: • Molded in color coding for circuit wiring • 2 connections per pole on male side for daisy chaining • 20 A current capacity to support multiple fixture loads • 2-piece contact construction featuring high grade stainless steel spring (for contact force) and electrolytic copper current bar (for electrical integrity) • Integrated locking latch - automatic locking with mating of connectors - simple push down to disengage • UL94V-0 flame retardant rated housing Electrical Data Rated voltage Nominal current Wire Size Solid conductor Stranded conductor (≤19 strands) Strip length Maximum operating temperature Male (plug) Female (socket) 20 A 6A 600 V 600 V 18 - 12 AWG l 18 AWG l 16 - 12 AWG 11 ... 13 mm / 0.47 in. Approvals Luminaire Disconnect 3NLY 9 ... 11 mm / 0.47 in. 105 ⁰C K 873 SERIES LUMI-NUTS® Fits through 1/2" knockout 42 13.2 mm m m l 9 ... 11 mm / 0.39 in. 873-902 873-902/VE00-0500 873-902/VE00-5000 m 19 mm 1=jar of 200 pcs 500 (bulk) 2,500 (bulk) for switching and dimming applications Item No. Pack.-unit pcs 873-903/PW05-100 1=jar of 100 pcs 873-903 873-903/VE00-0500 13.2 mm m m 11 ... 13 mm / 0.47 in. L l 9 ... 11 mm / 0.39 in. 3-pole connector 1=box of 25 pcs 42 m 11 ... 13 mm / 0.47 in. L l 9 ... 11 mm / 0.39 in. Fits through 1/2 in knockout Pack.-unit pcs 873-902/PW05-200 13.2 mm 13 mm 2-pole connector Item No. 42 1=box of 20 pcs 19 mm 11 ... 13 mm / 0.47 in. L 3-pole connector with "make first/break last" ground circuit Item No. 873-953/VE00-0500 Pack.-unit pcs 500 (bulk) 500 (bulk) APPLICATION NOTE Touch-proof, 'hot-pluggable' connectors are required for ballast supply wiring in the USA and Canada. When exchanging a ballast: 1) The touch-proof connector is disconnected first 2) The ballast is replaced 3) Power connection is restored by plugging the connection back together. This speeds ballast replacement while enhancing safety by protecting the installer from electrical shock. Luminaire disconnect 873-902 (2-pole) in disconnected state. Both plug and socket are touch-proof. Marking details include circuit identification and strip length indication 873 Series LUMI-NUTS® are approved according to UL2459 and CSA 22.2 for this type of application. 862 SERIES Terminal Blocks for Chassis Mounting 862 SERIES Highlights: • Integrated push button, with molded-in slots, accommodates fast and easy wiring of all conductor types - by hand or slotted tip/Phillips screwdriver • 4 conductors/pole allows for flexible wiring or convenient jumpering • Convenient automatic grounding contact available • Snap-in mounting feet for fast assembly • Flexible marking options: standard marking (pre-marked), marker strip or custom marked for large quantity orders • Built-in test points simplify testing with 2 mm/0.079 in. diameter test plug Electrical Data Rated voltage Nominal current Wire Size Solid / stranded conductor Solid / stranded conductor Strip length Maximum operating temperature Approvals 300 V 20 A 600 V 5A 600 V 20 A 22 - 12 AWG U 20 - 12 AWG 2 10 ... 11 mm / 0.41 in. U 4* 120 ⁰C * Ex versions available - contact factory for part numbers. K MOUNTING OPTIONS om Mount fr elf s ia v w belo screw g in p p ta Ø) into (2.9 mm using l ho termina ia screw Mount v mm Ø) (3 t u and n p from to ssis nto cha Mount o ing screw tapp top by self Ø) from (2.9 mm mmØ) screw (3 sis ia v t n u as Mo ad in ch into thre Ø) ut (3 mm w and n re c s ia v p Mount from to 24 36 24 12 DIMENSIONS (MM) MOUNTING FOOT Mounting foot for DIN rail mounting Item No. 209-120 Pack.-unit pcs 25 48 Mounti nap-in ng via s g feet mountin 862 SERIES TERMINAL BLOCKS Available in black and white 2 poles/8 connection points Item No. black Item No. white without marking 862-552 862-652 500 N-L1 (pre-marked), without ground contact 862-2552 862-2652 500 for fastening screw (3 mm ∅) or for self tapping screw (2.9) mm ∅ from top L1-N (pre-marked), without ground contact 862-1552 without marking 862-1652 3 poles/12 connection points Pack.-unit pcs Item No. black Item No. white 862-503 862-603 250 862-2503 862-2603 250 500 PE-N-L1 (pre-marked), without ground contact 862-1503 N-PE-L1 (pre-marked), without ground contact N-PE-L1 (pre-marked), with ground contact 862-8503 PE-N-L1, (pre-marked), with ground contact 862-9503 for self tapping screw 2.9 mm ∅ from below without marking 862-562 862-662 500 N-L1 (pre-marked), without ground contact 862-2562 862-2662 500 L1-N (pre-marked), without ground contact 862-1562 1 snap-in foot per pole 862-1662 862-532 862-632 500 N-L1 (pre-marked), without ground contact 862-2532 862-2632 500 862-1532 without marking 862-1632 862-1603 250 862-8603 250 862-9603 250 500 without marking L1-N (pre-marked), without ground contact Pack.-unit pcs 500 PE-N-L1 (pre-marked), without ground contact 862-533 862-633 250 862-2533 862-2633 250 862-1533 N-PE-L1 (pre-marked), without ground contact N-PE-L1 (pre-marked), with ground contact 862-1633 250 862-8533 862-8633 250 without marking 862-593 862-693 250 N-PE-L1 (pre-marked), without ground contact 862-2593 862-2693 250 PE-N-L1 (pre-marked), with ground contact 862-9533 snap-in feet at pos. 1+3 PE-N-L1 (pre-marked), without ground contact 862-1593 N-PE-L1 (pre-marked), with ground contact 862-8593 PE-N-L1 (pre-marked), with ground contact 862-9593 862-9633 250 862-1693 250 862-8693 250 862-9693 250 ACCESSORIES Test plug, with cable 500 mm Item No. 210-136 (2 mm ∅) 210-137 (2.3 mm ∅) Pack.-unit pcs 1 50 (5 x 10) Marker strip, 7.5 mm wide, on roll, 50 m long Item No. 709-178 709-177 Pack.-unit pcs 1 1 Comb-type jumper bar Screwdriver Item No. Item No. 862-482 Pack.-unit pcs 5 210-720 Pack.-unit pcs 1 862 SERIES TERMINAL BLOCKS 4 poles/16 connection points Item No. black Item No. white without marking 862-504 862-604 200 N-PE-L1-L2 (pre-marked), without ground contact 862-2504 862-2604 200 for fastening screw (3 mm ∅) or for self tapping screw (2.9) mm ∅ from top PE-N-L1-L2 (pre-marked), without ground contact N-PE-L1-L2 (pre-marked), with ground contact PE-N-L1-L2 (pre-marked), with ground contact without marking 862-1504 862-8504 862-9504 862-1604 862-8604 862-9604 Pack.-unit pcs 200 862-534 862-634 200 N-PE-L1-L2 (pre-marked), without ground contact 862-2534 862-2634 200 862-1534 862-8534 862-9534 862-1634 862-8634 862-9634 200 N-PE-L1-L2 (pre-marked), without ground contact 862-2594 862-2694 200 PE-N-L1-L2 (pre-marked), with ground contact snap-in feet at pos. 2 + 4 862-2605 200 862-8594 862-9594 862-1694 862-8694 862-9694 862-8605 862-9605 200 200 200 200 862-694 N-PE-L1-L2 (pre-marked), with ground contact 862-2505 862-1605 200 862-594 862-1594 Pack.-unit pcs 200 without marking PE-N-L1-L2 (pre-marked), without ground contact 200 862-9505 without marking snap-in feet at pos. 1+ 4 862-605 862-8505 PE-N-L1-L2-L3 (pre-marked), with ground contact PE-N-L1-L2 (pre-marked), with ground contact 862-505 862-1505 L3-N-PE-L1-L2 (pre-marked), with ground contact N-PE-L1-L2 (pre-marked), with ground contact Item No. white 200 L3-N-PE-L1-L2 (pre-marked), without ground contact PE-N-L1-L2 (pre-marked), without ground contact Item No. black 200 PE-N-L1-L2-L3 (pre-marked), without ground contact 1 snap-in foot per pole 5 poles/20 connection points 200 200 200 without marking 862-525 862-625 200 L3-N-PE-L1-L2 (pre-marked), without ground contact 862-2525 862-2625 200 PE-N-L1-L2-L3 (pre-marked), without ground contact L3-N-PE-L1-L2 (pre-marked), with ground contact PE-N-L1-L2-L3 (pre-marked), with ground contact snap-in feet at pos. 1 + 3 + 5 862-1525 862-8525 862-9525 862-1625 862-8625 862-9625 200 200 200 without marking 862-515 862-615 200 L3-N-PE-L1-L2 (pre-marked), without ground contact 862-2515 862-2615 200 PE-N-L1-L2-L3 (pre-marked), without ground contact L3-N-PE-L1-L2 (pre-marked), with ground contact PE-N-L1-L2-L3 (pre-marked), with ground contact Versions available with ATEX and IECEx — contact factory for part numbers. 862-1515 862-8515 862-9515 862-1615 862-8615 862-9615 200 200 200 ACCESSORIES AND OPERATING TOOLS ACCESSORIES WAGO offers a complete range of accessory products to make installation and testing quick and easy: • Operating tools for actuating the CAGE CLAMP® • Test devices and accessories to reliably detect voltage • Convenient wire cutting and stripping tools • Ferrules and crimping tools to install them SCREWDRIVERS, TESTBOY AND BANANA PLUGS Screwdriver Testboy with flashlight Item No. Pack.-unit pcs 210-720 (3.5 x 0.5 mm blade) 1 210-719 (2.5 x 0.4 mm blade) 210-721 (5.5 x 0.8 mm blade) 210-722 (set of all 3) 1 Voltage range 120 V up to 1000 V AC Item No. 206-804 Banana plugs, for sockets ∅ 4 mm Pack.-unit pcs 1 1 28 - 14 AWG Item No. 215-111 (mixed colors) 215-211 215-212 215-311 1 215-411 215-511 215-711 215-811 215-911 Set of screwdrivers in a box The following can be detected by the WAGO Testboy: • Live conductors • Line breaks • Blown fuses • Defective switches • Defective lamps Pack.-unit pcs 50 50 50 50 50 50 50 50 50 Connection of conductors via banana plugs: Press button fully and insert stripped conductor into square entry and release STRIPPING TOOLS AND CABLE CUTTER Quickstrip 10 stripping tool Quickstrip 16 stripping tool Cable cutter Item No. Item No. Item No. wire stripping for 34 - 8 AWG wire cutting for up to 8 AWG str / 16 AWG sol 206-124 Pack.-unit pcs 1 FOR QUICKSTRIP 10 wire stripping for 10 - 5 AWG wire cutting for up to 8 AWG str / 16 AWG sol Pack.-unit pcs 206-125 1 Replacement blade cassette Item No. Item No. 206-126 206-118 FOR QUICKSTRIP 16 Replacement blade cassette 34 - 8 AWG for up to 2 AWG conductors Pack.-unit pcs 1 10 - 5 AWG 206-128 Pack.-unit pcs 1 Replacement "V" blade cassette 34 - 12 AWG for PTFE Item No. 206-127 Pack.-unit pcs 1 Quickstrip 16: Stripping of cable Quickstrip 16: Cutting of cable Cutting of cable Pack.-unit pcs 1 FERRULES AND CRIMPING TOOLS INSULATED FERRULES Insulated Ferrules UNINSULATED FERRULES Sleeve for mm² AWG Stripped length (mm) L (mm) L1 (mm) D (mm) D1 (mm) D2 (mm) 0.75 20 12.0 16.0 10.0 3.3 2.8 1.2 216-242 1,000 1.0 18 12.0 16.0 10.0 3.5 3.0 1.4 216-243 1,000 0.5 1.5 22 12.0 16 12.0 Uninsulated Ferrules 16.0 16.0 10.0 10.0 3.1 4.0 2.6 1.0 3.5 Item No. 216-241 1.7 216-244 Pack.-unit pcs 1,000 1,000 Sleeve for mm² AWG Stripped length (mm) L (mm) D (mm) D2 (mm) Item No. Pack.-unit pcs 0.75 20 10.0 10.0 2.3 1.2 216-142 1,000 0.5 1.0 1.5 22 10.0 18 10.0 16 10.0 2.1 10.0 10.0 2.5 10.0 2.8 Visit our online catalog at eshop.wago.com for a complete offering of ferrules. CRIMPING TOOLS Variocrimp 4 for insulated or uninsulated ferrules Variocrimp 16 for insuldated or uninsulated ferrules Item No. Item No. 24 - 12 AWG (from 0.25 - 4 mm²) 206-204 Pack.-unit pcs 1 10 - 6 AWG (from 6 - 16 mm²) 206-216 Pack.-unit pcs 1 1.0 1.4 1.7 216-141 216-143 216-144 1,000 1,000 1,000 SMART DATA ENGINEERING Component Labeling The WAGO smartPRINTER: • The industry's most affordable printing option • Label your entire control cabinet • Mark your devices with industry exclusive multi-line continuous marker strips • No drying time • Minimal maintenance Visit www.smartprinter.us for more information. + smartPRINTER = smartSCRIPT SOFTWARE MARKED 862 SERIES WIRE MARKING WITH smartPRINTER 258-5000 258-5005 709-178 smartPRINTER Item No. Pack.-unit pcs 258-5015 (carrying case) 1 258-5000 1 Marker Strips for 862 Series Item No. Length 709-178 50 m 709-177 211-861; 211-862; 211-863 50 m 211-855; 211-856; 211-857 Self-laminating and thread-on labels Heat shrink labels max. 9 mm 1/8" Cable diameter Wire marking max. 12 mm max. 22 mm Item No. 211-855 (self-laminating) 211-856 (self-laminating) 0.75-1.5 mm² 2.5-6.0 mm² 6.0-16 mm² 211-857 (self-laminating) 211-861 (thread-on) 211-862 (thread-on) 211-863 (thread-on) Visit www.smartprinter.us for more materials. Size Wire diameter 3/16" 1.8-4.1 mm 1/4" 1/2" 1/8" 3/16" 1/4" 1.1-2.7 mm 2.3-5.5 mm 4.7-10.8 mm 1.1-2.7 mm 1.8-4.1 mm 2.3-5.5 mm Item No. 51223870 51223871 51223872 51273038 51227742 51227743 51227744 Ink ribbon Item No. Length 258-5014 (heatshrink / self-laminating) 50 m 258-5005 (standard) 50 m 211-812, 211-813, 211-823, 211-824, 211-829 Marking sleeves Wire diameter Item No. Marker No. (length) 5.0-11.0 mm 211-813 211-811 (12 mm) 1.4-5.0 mm 1.4-5.0 mm 5.0-11.0 mm Cable tie secured 211-812 211-823 211-824 211-829 211-811 (12 mm) 211-821 (23 mm) 211-821 (23 mm) 211-821 (23 mm) Mexico WAGO Corporation Queretaro Tel. 001/800/309/5975 + 52/442/221/5946 Fax + 52/442/221/5063 www.wago.mx WAGO is a registered trademark of WAGO Verwaltungsgesellschaft mbH. ”Copyright – WAGO Kontakttechnik GmbH & Co. KG – all rights reserved. The content and structure of the WAGO Websites, catalogs, videos, and other WAGO media are subject to copyright. The dissemination or changing of the content of these pages and videos is not permitted. Furthermore, the content may neither be copied nor made available to third parties for commercial purposes. Also subject to copyright are the images and videos that were made available to WAGO Kontakttechnik GmbH & Co. KG by third parties.” 04/2017 - Printed in the United States 0888-0832/0000-0353 Canada WAGO Corporation Tel. 800/DIN Rail (346-7245) Fax 262/255-3232 www.wago.ca 60337976 WAGO Corporation N120 W19129 Freistadt Road Germantown, Wisconsin 53022 Telephone: 800 / DIN Rail (346-7245) Fax: 262 / 255-3232 info.us@wago.com www.wago.us
222-412/VE00-2500 价格&库存
很抱歉,暂时无法提供与“222-412/VE00-2500”相匹配的价格&库存,您可以联系我们找货
