231-464/001-000
231-464/001-000
    WAGO(万可电子)
    插件,P=5mm
231-464/001-000 数据手册
HEADER RIGHT ANGLE SOLDER PIN, 1.2 X 1.2 MM/ 0.047 X 0.047 IN PIN SPACING 5 MM / 0.197 IN 231-462/001-000 TO 231-484/001-000 PDF Datasheet © 1992 - 2011 CADENAS GmbH HEADER RIGHT ANGLE SOLDER PIN, 1.2 X 1.2 MM/ 0.047 X 0.047 IN PIN SPACING 5 MM / 0.197 IN 231-462/001-000 TO 231-484/001-000 ITEM-NO. (ITEM-NO.) 231-464/001-000 Measured voltage (Measured voltage / V) 320 PDF Datasheet © 1992 - 2011 CADENAS GmbH Measured shock voltage (Measured shock voltage / kV) 4 Pollution degree (Pollution degree) 2 Current intensity (Current intensity / A) 16 RM (PIN SPACING / mm) 5 P (NO. OF POLES) 4 Height (Height / mm) 8.4 Width (Width / mm) 23.2 Depth (Depth / mm) 12 COLOR (COLOR) grau WEIGHT (WEIGHT / g) Dimensions (Dimensions) 1.682 A = (No. of poles x Pin Spacing) + 3,2 mm | B = A + 4,8 mm | C = B + 7,2 mm 1,7 + 0,1 mm RGB (RGB) 0.67,0.67,0.67,0 Comment (Comment)
231-464/001-000 价格&库存
很抱歉,暂时无法提供与“231-464/001-000”相匹配的价格&库存,您可以联系我们找货
