261-301
261-301
    WAGO(万可电子)
    板对板连接器
261-301 数据手册
Data sheet from 04.02.2009 Item no.: 261-301 Product description: 2-CONDUCTOR TERMINAL BLOCK; LATERAL MARKING; WITH FIXING FLANGE; WITH MOUNTING FEET 209-123 FOR TS 35; SIDE-ENTRY; CAGE CLAMP®CONNECTION Packing unit 200 4*50 pieces Product group 9 (Std Chassis Mt Blocks) Cross section from [mm²] 0,08 mm² Cross section to [mm²] 2,5 mm² Cross section from [AWG] 28 AWG Cross section to [AWG] 14 AWG Connection method CAGE CLAMP®CONNECTION Measured voltage EN 500 V Measured shock voltage 6 kV Pollution degree 3 Current intensity EN 24 A Weight 2,3 g Color grey Wiring type Side-entry No. of connection Points 2 No. of potentials 1 Height 18 mm Height 0,709 in Width 6 mm Width 0,236 in Depth 28 mm Depth 1,103 in Strip length from 8 mm Strip length to 9 mm Strip length 0,33 in 1 von 2 Data sheet from 04.02.2009 Item number Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 261-301 ABS 04-HG476174-PDA 500 26 2,5 261-301 BV 07436/C0 500 24 0,08-2,5 261-301 CCA NL5801 500 261-301 CSA 18677-45 300/600 20/5 26-14 261-301 DNV E7569 500 24 2,5 261-301 GL 17295-00HH 500 24 2,5 261-301 KEMA 2079569.02 500 261-301 KR HMB05880-EL002 500 24 2,5 261-301 LR 92/20242(E5) 400 24 2,5 261-301 PRS TE/1718/880590/08 500 261-301 RMR 11130002 500 26 2,5 261-301 UR E45172 300/600 15/5 28-14 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 2 von 2 0,08-2,5 0,08-2,5 0,08-2,5
261-301 价格&库存
很抱歉,暂时无法提供与“261-301”相匹配的价格&库存,您可以联系我们找货
  • 50+13.8699850+1.79665
  • 250+9.89490250+1.28174
  • 500+9.53094500+1.23459
库存:650
261-301
    • 139+6.15058139+0.79672
    • 250+5.90434250+0.76482
    • 500+4.29047500+0.55577
    • 1000+4.150231000+0.53760
    • 2500+4.027842500+0.52175
    库存:2990
    261-301
      • 1+5.56640
      • 10+4.40020
      • 50+3.81220
      • 100+3.23400
      库存:209
