Data sheet | Item number: 2606-3106/020-000
PCB terminal block; lever; 6 mm²; Pin spacing 7.5 mm; 6-pole; Push-in CAGE
CLAMP®; 6,00 mm2; gray
www.wago.com/2606-3106/020-000
Color:
25.09.2019 Page 1/5
L = (pole no. - 1) x pin spacing + 10.35 mm
Item description
PCB terminal strips with lever-actuated Push-in CAGE CLAMP® connection
Push-in termination of solid and ferruled conductors
Intuitive and tool-free operation
Several clamping units can be held open simultaneously – convenient for terminating multi-core cables
Testing can be performed both parallel and perpendicular to conductor entry
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
800 V
Rated impulse voltage (III / 3)
8 kV
Rated voltage (III / 2)
1000 V
Rated impulse voltage (III / 2)
8 kV
Rated voltage (II / 2)
1000 V
Rated impulse voltage (II / 2)
8 kV
Rated current
41 A
Approvals per UL 1059
Rated voltage UL (Use Group B)
600 V
Rated current UL (Use Group B)
31 A
Rated voltage UL (Use Group C)
600 V
25.09.2019 Page 2/5
600 V
Rated current UL (Use Group C)
31 A
Connection data
Connection technology
Push-in CAGE CLAMP®
Actuation type
Lever
Solid conductor
0.2 … 10 mm² / 24 … 8 AWG
Fine-stranded conductor
Fine-stranded conductor with ferrule with plastic collar
0.25 … 6 mm²
Fine-stranded conductor with ferrule without plastic collar
0.25 … 6 mm²
Fine-stranded conductor, with twin ferrule
0.25 … 2.5 mm²
Strip length
11 … 13 mm / 0.43 … 0.51 inch
Conductor entry angle to the PCB
90 °
Total number of connection points
6
Total number of potentials
6
Number of connection types
1
Number of levels
1
No. of poles
6
Geometrical Data
Pin spacing
7.5 mm / 0.295 inch
Width
47.85 mm / 1.884 inch
Height
31 mm / 1.22 inch
Height from the surface
27 mm / 1.063 inch
Depth
24 mm / 0.945 inch
Solder pin length
4 mm
Solder pin dimensions
1.5 x 1.2 mm
Drilled hole diameter (tolerance)
2(- … +0.1) mm
PCB contact
PCB contact
THT
Solder pin arrangement
over the entire terminal strip, staggered
Number of solder pins per potential
1
Material Data
Color
gray
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
25.09.2019 Page 3/5
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Actuating element color
orange
Weight
25.53 g
Environmental Requirements
Limit temperature range
-60 … +105 °C
Commercial data
Country of origin
DE
GTIN
4055143586658
Customs Tariff No.
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 60947-7-4
NL-58082
CSA
C22.2
70146882
KEMA/KEUR
EN 60947-7-4
71107864
Approval
cURus
Underwriters Laboratories Inc.
UL 1059
UL-Approvals
Logo
Certificate
name
20190518E45172
Compatible products
ferrule
Item no.: 216-108
Ferrule; Sleeve for 6 mm² / AWG 10; uninsulated; electro-tin plated
www.wago.com/216-108
Item no.: 216-208
25.09.2019 Page 4/5
Item no.: 216-208
www.wago.com/216-208
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped;
acc. to DIN 46228, Part 4/09.90; yellow
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-264
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-264
Item no.: 216-266
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-266
Item no.: 216-267
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-267
acc. to DIN 46228, Part 4/09.90; gray
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
3.6 MB
Download
URL
Download
CAD/CAE-Data
CAD data
3D Download 2606-3106/020-000
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
25.09.2019 Page 5/5
很抱歉,暂时无法提供与“2606-3106/020-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+169.121731+21.94892
- 10+120.7100810+15.66597
- 25+107.6006425+13.96460
- 50+99.7818250+12.94986
- 100+93.51192100+12.13614
- 250+87.18471250+11.31499
- 500+83.58725500+10.84810
- 1000+80.792491000+10.48539
- 国内价格
- 14+65.62996
- 44+62.52258
