2626-3101/000-023
2626-3101/000-023
    WAGO(万可电子)
2626-3101/000-023 数据手册
Data sheet | Item number: 2626-3101/000-023 PCB terminal block; 6 mm²; Pin spacing 7.5 mm; 1-pole; Push-in CAGE CLAMP®; 6,00 mm²; green www.wago.com/2626-3101/000-023 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 23.07.2021    Page 1/7 Data sheet | Item number: 2626-3101/000-023 www.wago.com/2626-3101/000-023 Dimensions in mm L = 9.3 mm Item description PCB terminal blocks with Push-in CAGE CLAMP® connection Push-in termination of solid and ferruled conductors Ideal for panel feedthrough applications via operation parallel to conductor entry Testing can be performed both parallel and perpendicular to conductor entry Data Electrical data Ratings per IEC/EN Ratings per IEC/EN 60664-1 Rated surge voltage (III/3) 8 kV Rated voltage (III/2) 1000 V Rated surge voltage (III/2) 8 kV Nominal voltage (II/2) 1000 V Rated surge voltage (II/2) 8 kV Rated current 48 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 23.07.2021    Page 2/7 Data sheet | Item number: 2626-3101/000-023 www.wago.com/2626-3101/000-023 Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Ratings per UL Approvals per UL 1059 Rated voltage UL (Use Group B) 600 V Rated current UL (Use Group B) 38 A Rated voltage UL (Use Group C) 600 V Rated current UL (Use Group C) 38 A Ratings per CSA Approvals per CSA Rated voltage CSA (Use Group B) 600 V Rated current CSA (Use Group B) 38 A Rated voltage CSA (Use Group C) 1000 V Rated current CSA (Use Group C) 38 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Operating tool Solid conductor 0.2 … 10 mm² / 24 … 8 AWG Fine-stranded conductor 0.2 … 10 mm² / 24 … 8 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 6 mm² Fine-stranded conductor; with uninsulated ferrule 0.25 … 6 mm² Fine-stranded conductor; with twin ferrule 0.25 … 2.5 mm² Strip length 13 … 15 mm / 0.51 … 0.59 inch Conductor connection direction to PCB 90 ° Pole No. 1 Total number of connection points 1 Total number of potentials 1 Number of connection types 1 Number of levels 1 Physical data Pin spacing 7.5 mm / 0.295 inch Width 9.3 mm / 0.366 inch Height 28.2 mm / 1.11 inch Height from the surface 24.2 mm / 0.953 inch Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 23.07.2021    Page 3/7 Data sheet | Item number: 2626-3101/000-023 www.wago.com/2626-3101/000-023 Height from the surface 24.2 mm / 0.953 inch Depth 18.5 mm / 0.728 inch Solder pin length 4 mm Solder pin dimensions 1.5 x 1 mm Drilled hole diameter with tolerance 2 (+0.1) mm Mechanical data Mounting type Feed-through mounting PCB contact PCB Contact THT Solder pin arrangement Over the entire terminal strip (in-line) Number of solder pins per potential 2 Material data Color green Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Weight 4.5 g Environmental requirements Limit temperature range -60 … +105 °C Commercial data Packaging type box Country of origin DE GTIN 4055143787871 Customs tariff number 85369010000 Optional accessories Ferrule Item no.: 216-108 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 23.07.2021    Page 4/7 Data sheet | Item number: 2626-3101/000-023 www.wago.com/2626-3101/000-023 Item no.: 216-108 Ferrule; Sleeve for 6 mm² / AWG 10; uninsulated; electro-tin plated; silver-colored www.wago.com/216-108 Item no.: 216-208 Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-208 acc. to DIN 46228, Part 4/09.90; yellow Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-266 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-266 Item no.: 216-267 Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-267 acc. to DIN 46228, Part 4/09.90; gray Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 2626-3101/000-023 PCB Design Symbol and Footprint 2626-3101/000-023 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 23.07.2021    Page 5/7 Data sheet | Item number: 2626-3101/000-023 www.wago.com/2626-3101/000-023 KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian CAE data ZUKEN Portal 2626-3101/000-023 URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 2626-3101/000-023 PCB terminal block; 6 mm²; Pin spacing 7.5 mm; 1-pole; Push-in CAGE CLAMP®; 6,00 mm²; green Installation Notes Conductor termination Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 23.07.2021    Page 6/7 Data sheet | Item number: 2626-3101/000-023 www.wago.com/2626-3101/000-023 Insert fine-stranded conductors and remove all conductors via operating tool Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 23.07.2021    Page 7/7
2626-3101/000-023 价格&库存
很抱歉,暂时无法提供与“2626-3101/000-023”相匹配的价格&库存,您可以联系我们找货
