264-134
264-134
    WAGO(万可电子)
264-134 数据手册
Printview: 2-conductor Ex e II terminal strip; with fixing flanges; for screw or similar mounting types; Fixing hole 3.2 mm Ø; suitable for Ex e II applications; 4-pole - Item No.: 264-134 . 2-conductor Ex e II terminal strip; with fixing flanges; for screw or similar mounting types; Fixing hole 3.2 mm Ø; suitable for Ex e II applications; 4-pole Item No.: 264-134 . 2-conductor Ex e II terminal strip; with fixing flanges; for screw or similar mounting types; Fixing hole 3.2 mm Ø; suitable for Ex e II applications; 4-pole . Marking . Business data Supplier WAGO Item no. 264-134 EAN 4044918423076 Content 1 Order amount 100 Customer item number . Notes Technical data Miscellaneous No. of Poles 4 Total number of connection points 8 Total number of potentials 4 Color light gray Rated voltage EN (1) [V] 690 [V] Nominal current [A] 23 [A] Connection technology (1) CAGE CLAMP® Cross section from (1) [mm²] 0.5 [mm²] WAGO Kontakttechnik GmbH & Co. KG 1 Printview: 2-conductor Ex e II terminal strip; with fixing flanges; for screw or similar mounting types; Fixing hole 3.2 mm Ø; suitable for Ex e II applications; 4-pole - Item No.: 264-134 Technical data Cross section up to (1) [mm²] 2.5 [mm²] Cross section from (1) [AWG] 20 [AWG] Cross section up to (1) [AWG] 12 [AWG] Stripped length from (1) [mm] 8 [mm] Stripped length up to (1) [mm] 9 [mm] Stripped length (1) [in] 0.33 [in] Type of wiring Front-entry wiring Design horizontal Marking level Center marking Fire load [MJ] 0.351 [MJ] Weight [g] 17.065 [g] Width [mm] 40 [mm] Width [in] 1.575 [in] Height [mm] 22.1 [mm] Height [in] 0.87 [in] Length [mm] 32 [mm] Length [in] 1.26 [in] Approbation Item No. Registration Registration no. Voltage [V] Current [A] Cross section [mm², AWG] 264-134 AEX E185892 600 20 28-12 264-134 ATEx PTB 98 ATEX 3129 U 690 23 0.20-2.50 264-134 BV 07436/C0 264-134 CSA 18677-23 264-134 GOSENERGO-Ex 99.041 264-134 0,08-2,5 600 20 26-12 750 23 2,5 KR HMB05880-EL002 800 24 264-134 PRS TE/1718/880590/0 800 8 264-134 PTB IECExPTB04.000 690 3U 23 2,5 264-134 PTB PTB98Atex3129U 690 23 2,5 264-134 RosTest 8189158 23 2,5 690 WAGO Kontakttechnik GmbH & Co. KG 2 2,5 Printview: 2-conductor Ex e II terminal strip; with fixing flanges; for screw or similar mounting types; Fixing hole 3.2 mm Ø; suitable for Ex e II applications; 4-pole - Item No.: 264-134 Approbation 264-134 UL E45172 300 20 28-12 Accessories Jumper Item no. Description Pack. unit (Sub Pack) 264-402 Comb-style jumper bar; insulated; 2-way; reduces conductor size to 1.5 mm² 25 281-492 Alternate comb-style jumper bar; insulated; 2-way; IN = IN terminal block 25 End plate Item no. 264-363 Description Pack. unit (Sub Pack) End plate; with fixing flange; 4 mm thick 25 Marking accessories Item no. Description Pack. unit (Sub Pack) 2009-145 Mini-WSB Inline; plain; 1,700 Mini-WSB markers (5 mm) on roll; stretchable 5 - 5.2 mm 1 248-501 Miniature WSB quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers 5 per card 248-501/000-002 Miniature WSB quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers 5 per card 248-501/000-005 Miniature WSB quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers 5 per card 248-501/000-006 Miniature WSB quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers 5 per card 248-501/000-007 Miniature WSB quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers 5 per card 248-501/000-012 Miniature WSB quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers 5 per card 248-501/000-017 Miniature WSB quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers 5 per card 248-501/000-023 Miniature WSB quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers 5 per card 248-501/000-024 Miniature WSB quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card WAGO Kontakttechnik GmbH & Co. KG 3 5 Printview: 2-conductor Ex e II terminal strip; with fixing flanges; for screw or similar mounting types; Fixing hole 3.2 mm Ø; suitable for Ex e II applications; 4-pole - Item No.: 264-134 Accessories General accessory Item no. Description Pack. unit (Sub Pack) 209-196 Spare fixing/retaining screw; for cover 25 210-291 Stickers for operating instructions; for front-entry, miniature rail-mounted terminal blocks; 264 100 Series 210-549 Spare knurled nut; for cover 25 210-657 Operating tool with partially insulated shaft; blade (3.5 x 0.5) mm; short; suitable for 260, 261, 1 262, 264, 270, 280, 281, 869, 870 and 880 Series 210-658 Operating tool with partially insulated shaft; blade (3.5 x 0.5) mm; short; angled; particularly 1 suitable for 280 Series actuator and sensor terminal blocks and also for Series 260, 261, 262, 264, 280, 281, 869, 870, 880, 2002, 210-720 Operating tool with partially insulated shaft; Type 2, blade (3.5 x 0.5) mm; suitable for 260, 1 261, 262, 264, 270, 280, 281, 290, 775, 776, 777, 769, 780, 781, 869, 870, 880, 2002, 2003, 2004, 2005 and 2022 Series 280-432 Operating tool; of insulating material; 2-way 1 709-153 Cover; type 1; suitable for cover carrier, type 1; 1 m long 10 WAGO Kontakttechnik GmbH & Co. KG 4 Printview: 2-conductor Ex e II terminal strip; with fixing flanges; for screw or similar mounting types; Fixing hole 3.2 mm Ø; suitable for Ex e II applications; 4-pole - Item No.: 264-134 Images & drawings . WAGO Kontakttechnik GmbH & Co. KG 5 Printview: 2-conductor Ex e II terminal strip; with fixing flanges; for screw or similar mounting types; Fixing hole 3.2 mm Ø; suitable for Ex e II applications; 4-pole - Item No.: 264-134 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 6
264-134 价格&库存
很抱歉,暂时无法提供与“264-134”相匹配的价格&库存,您可以联系我们找货
  • 1+112.097811+14.53001
  • 10+79.6142510+10.31953
  • 25+70.5393125+9.14324
  • 50+65.0638050+8.43351
  • 100+60.63962100+7.86005
  • 250+56.14466250+7.27742
  • 500+53.57528500+6.94438
  • 1000+51.572181000+6.68474
库存:4
