Data sheet | Item number: 280-765
Terminal block for pluggable modules; 10-pole; with 4-conductor terminal
blocks; with marker carrier; with orange separator; for DIN-rail 35 x 15 and 35
x 7.5; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; gray
www.wago.com/280-765
Color:
Data
Electrical data
Rated continuous current
10 A
Safety and protection:
Rated voltage
400 V
Rated surge voltage
6 kV
Pollution degree
3
Connection data
Total number of potentials
2
Number of connection types
4
Connection technology
CAGE CLAMP®
Solid conductor
0.08 … 2.5 mm² / 28 … 14 AWG
Fine-stranded conductor
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.07.2020 Page 1/12
Strip length
Wiring type
Front-entry wiring
Geometrical Data
Width
30 mm / 1.181 inch
Height from upper-edge of DIN-rail
28 mm / 1.102 inch
Depth
73 mm / 2.874 inch
Mechanical data
Mounting type
DIN-35 rail
Material Data
Color
gray
Fire load
0.803 MJ
Weight
44.4 g
Commercial data
Packaging type
BOX
Country of origin
DE
GTIN
4044918635738
Customs tariff number
85369010000
Counterpart
Compatible products
General accessories
Item no.: 286-110
Empty component plug housing; Type 9; 10 mm wide; 4-pole; gray
www.wago.com/286-110
Item no.: 286-111
Empty component plug housing; Type 10; 15 mm wide; 6-pole; gray
www.wago.com/286-111
Item
no.: 286-112
Subject to changes.
Please
Hansastr. 27
32423 Minden
13.07.2020 Page 2/12
Item no.: 286-112
Empty component plug housing; Type 11; 20 mm wide; 8-pole; gray
www.wago.com/286-112
Item no.: 286-113
Empty component plug housing; Type 12; 25 mm wide; 10-pole; gray
www.wago.com/286-113
Item no.: 286-304
Relay module; Nominal input voltage: 24 VDC; 1 changeover contact; Limiting continuous current: 7
A; Red status indicator; Module width: 15 mm; gray
www.wago.com/286-304
Item no.: 286-304/004-000
A; Path; Red status indicator; Module width: 15 mm; gray
/004-000
Item no.: 286-307/004-000
www.wago.com/286-307
Relay module; Nominal input voltage: 110 VDC; 1 changeover contact; Limiting continuous current: 7
/004-000
Item no.: 286-312
Relay module; Relay with 2 changeover contacts (2u); gray
www.wago.com/286-312
Item no.: 286-312/004-000
Relay module; Nominal input voltage: 24 VDC; 2 changeover contacts; Limiting continuous current: 5
/004-000
A; Path; Red status indicator; Module width: 20 mm; gray
Item no.: 286-316
Relay module; Nominal input voltage: 220 VDC; 2 changeover contacts; Limiting continuous current:
7 A; Red status indicator; Module width: 20 mm; gray
www.wago.com/286-316
Item no.: 286-320
Relay module; Nominal input voltage: 24 VDC; 1 break and 1 make contact; Limiting continuous
current: 6 A; Red status indicator; Module width: 20 mm; gray
www.wago.com/286-320
Item no.: 286-320/004-000
Relay module; Nominal input voltage: 24 VDC; 1 break and 1 make contact; Path; Red status indicator;
/004-000
Item no.: 286-328
Relay module; Nominal input voltage: 24 VDC; 2 make contact; Limiting continuous current: 6 A; Red
www.wago.com/286-328
Item no.: 286-328/004-000
Relay module; Nominal input voltage: 24 VDC; 2 make contact; Limiting continuous current: 6 A; Path;
/004-000
Item no.: 286-336/001-000
Relay module; Nominal input voltage: 24 VDC; 2 break and 2 make contacts; Red status indicator;
Module width: 25 mm; gray
www.wago.com/286-336
/001-000
Item no.: 286-344/004-000
www.wago.com/286-344
Relay module; Nominal input voltage: 24 VDC; 3 break contacts and 1 make contact; Path; Red status
/004-000
indicator; Module width: 25 mm; gray
Item no.: 286-352/004-000
Relay module; Nominal input voltage: 24 VDC; 4 make contacts; Limiting continuous current: 5 A;
Path; Red status indicator; Module width: 25 mm; gray
www.wago.com/286-352
/004-000
Hansastr. 27
32423 Minden
13.07.2020 Page 3/12
Item no.: 286-364
Relay module; Nominal input voltage: 24 VDC; 1 make contact; Limiting continuous current: 5 A; Red
status indicator; Module width: 10 mm; gray
www.wago.com/286-364
Item no.: 286-364/004-000
Relay module; Nominal input voltage: 24 VDC; 1 make contact; Path; Red status indicator; Module
width: 10 mm; gray
/004-000
Item no.: 286-368
Relay module; Nominal input voltage: 24 VDC; 1 break contact; Limiting continuous current: 5 A; Red
www.wago.com/286-368
Item no.: 286-368/004-000
Relay module; Nominal input voltage: 24 VDC; 1 break contact; Path; Red status indicator; Module
width: 10 mm
/004-000
Item no.: 286-376
Relay module; Nominal input voltage: 24 VDC; 1 make contact; Limiting continuous current: 5 A; for
switching higher DC loads; Red status indicator; Module width: 15 mm; gray
www.wago.com/286-376
Item no.: 286-380
Bistable relay module; Nominal input voltage: 24 VDC; 1 changeover contact; Limiting continuous
current: 6 A; Red status indicator; Module width: 15 mm; gray
www.wago.com/286-380
Item no.: 286-381
www.wago.com/286-381
Item no.: 286-394/004-000
Relay module; Nominal input voltage: 24 VDC; 1 changeover contact; Path; Red status indicator;
Module width: 15 mm; light gray
www.wago.com/286-394
/004-000
Item no.: 286-427
Timer relay module; Nominal input voltage: 24 VDC; Limiting continuous current: 5 A; Pulse
lengthening: 1 … 10 s; Red status indicator; Module width: 20 mm; gray
www.wago.com/286-427
Item no.: 286-507
Relay module; Nominal input voltage: 115 VAC; 1 changeover contact; Limiting continuous current: 7 www.wago.com/286-507
Item no.: 286-508
Relay module; Nominal input voltage: 230 VAC; 1 changeover contact; Limiting continuous current: 7 www.wago.com/286-508
Item no.: 286-516
Relay module; Nominal input voltage: 230 VAC; 2 changeover contacts; Limiting continuous current:
7 A; Red status indicator; Module width: 15 mm; gray
www.wago.com/286-516
Item no.: 286-573
Latching relay module; Nominal input voltage: 24 VDC; 1 changeover contact; Limiting continuous
www.wago.com/286-573
Item no.: 286-575
current: 3 A; Path; Red status indicator; Module width: 22 mm
www.wago.com/286-575
Item no.: 286-604/004-000
Timer relay module; Nominal input voltage: 24 VDC; Limiting continuous current: 6 A; On-delay: 10 …
100 s; Red status indicator; Module width: 20 mm; gray
www.wago.com/286-604
/004-000
Item no.: 286-640
Hansastr. 27
32423 Minden
13.07.2020 Page 4/12
Item no.: 286-640
Timer relay module; Nominal input voltage: 24 VDC; Limiting continuous current: 6 A; Path;
Multifunction/Multitime; Yellow status indicator; Module width: 6 mm; gray
www.wago.com/286-640
Item no.: 286-640/004-000
Multifunction timing relay module; Relay with 1 changeover contact (1u); 4 time ranges; for railway
operations; 4 functions; gray
/004-000
Item no.: 286-661
Current flow monitoring module; AC currents; adjustable; light gray
www.wago.com/286-661
Item no.: 286-662
Current flow monitoring module; DC currents; Monitoring range: 0.4 A – 3.5 A; 1 make contact; light
gray
www.wago.com/286-662
Item no.: 286-664
Current flow monitoring module; AC currents; Monitoring range: 1 A – 10 A; 1 changeover contact;
light gray
www.wago.com/286-664
Item no.: 286-665
light gray
www.wago.com/286-665
Item no.: 286-721
Optocoupler module; Nominal input voltage: 24 VDC; Output voltage range: 15 … 30 VDC; Limiting
continuous current: 5 A; 3-wire connection/low-side switching; Red status indicator; Module width:
15 mm; gray
www.wago.com/286-721
Item no.: 286-723
continuous current: 4 A; 3-wire connection/high-side switching; Red status indicator; Module width:
15 mm; gray
www.wago.com/286-723
Item no.: 286-725
Optocoupler module; Input AC/DC 10 V ... 30 V; Output DC 24 V/ 1 mA ... 0.5 A; negative switching;
gray
www.wago.com/286-725
Item no.: 286-742
S0 interface power supply; Input voltage: 230 VAC; S0 interface
www.wago.com/286-742
Item no.: 286-752
Optocoupler module; Nominal input voltage: 24 VDC; Output voltage range: 20 … 30 VDC; Limiting
continuous current: 0.5 A; 3-wire connection/high-side switching; Frequency: 25 kHz; Red status
www.wago.com/286-752
Item no.: 286-752/002-000
Optocoupler module; Red status indicator; gray
/002-000
Item no.: 286-790
Optocoupler module; gray
www.wago.com/286-790
Item no.: 286-791
Optocoupler module; Nominal input voltage: 24 VDC; Output voltage range: 20 … 60 VDC; Limiting
continuous current: 0.1 A; 2-wire connection; Frequency: 3 kHz; Red status indicator; Module width:
10 mm; gray
www.wago.com/286-791
Item no.: 286-792
Hansastr. 27
32423 Minden
www.wago.com/286-792
13.07.2020 Page 5/12
Item no.: 286-792
Item no.: 286-794
continuous current: 0.1 A; 2-wire connection; Red status indicator; Module width: 10 mm; gray
www.wago.com/286-794
Item no.: 286-797
www.wago.com/286-797
Item no.: 286-803
Component module with diode; gray
www.wago.com/286-803
Item no.: 286-805
Component module with diode; light gray
www.wago.com/286-805
Item no.: 286-807
Component module with diode; with 7 pcs; Diode 1N4007; with common anode; light gray
www.wago.com/286-807
Item no.: 286-809
www.wago.com/286-809
Item no.: 286-822
Component module with LED; Red LED; with common cathode
www.wago.com/286-822
Item no.: 286-826
AND gate module with 6 inputs; light gray
www.wago.com/286-826
Item no.: 286-830
Bridge rectifier module; Input voltage: 24 VAC; with varistor protective circuit; gray
www.wago.com/286-830
Item no.: 286-831
Surge suppression module for signal technology; Nominal voltage: 24 VAC/DC; for 2 signal paths
with common surge arrester; plugged on rail-mount terminal block, 15 mm wide; gray
www.wago.com/286-831
Item no.: 286-832
with common surge arrester; pluggable on rail-mount terminal block, 20 mm wide; gray
www.wago.com/286-832
Item no.: 286-833
Surge suppression module for signal technology; Nominal voltage: 24 VDC; for 1 signal path; plugged www.wago.com/286-833
Item no.: 286-834
Surge suppression module for signal technology; Nominal voltage: 12 VDC; for 2 signal paths with
www.wago.com/286-834
Item no.: 286-834/024-000
Surge suppression module for signal technology; Nominal voltage: 24 VDC; for 2 signal paths with
common surge arrester; pluggable on rail-mount terminal block, 15 mm wide; gray
/024-000
Item no.: 286-835
Surge suppression module for signal technology; Nominal voltage: 230 VAC; for 2 signal paths with
www.wago.com/286-835
Item no.: 286-835/115-000
Surge suppression module for signal technology; Nominal voltage: 115 VAC; for 2 signal paths with
/115-000
Hansastr. 27
32423 Minden
13.07.2020 Page 6/12
Item no.: 286-836
www.wago.com/286-836
Item no.: 286-838
common surge arrester; with visual indicator; gray
www.wago.com/286-838
Item no.: 286-840
Bridge rectifier module; Input voltage: 250 VAC; with varistor protective circuit; gray
www.wago.com/286-840
Item no.: 286-841
Surge suppression module for signal technology; Nominal voltage: 220 VDC; for 2 signal paths with
common surge arrester; pluggable on rail-mount terminal block, 25 mm wide; gray
www.wago.com/286-841
Item no.: 286-842
www.wago.com/286-842
Item no.: 286-843
www.wago.com/286-843
Item no.: 286-844
Surge suppression module for signal technology; for 2 signal paths with common surge arrester;
www.wago.com/286-844
Item no.: 286-890
Component module with fuse; for (5 x 20) mm microfuse; Nominal voltage: 24 VAC/DC; gray
www.wago.com/286-890
Item no.: 286-891
Component module with fuse; for (5 x 20) mm microfuse; Nominal voltage: 230 VAC/DC; gray
www.wago.com/286-891
Item no.: 286-895
Switching module; with changeover rocker switch; Switching voltage: 250 VAC; Switching current: 6
A; gray
www.wago.com/286-895
Item no.: 286-896
Switching module; with momentary switch; Switching voltage: 250 VAC; Switching current: 6 A; gray
www.wago.com/286-896
Item no.: 786-103
Empty component plug housing; Type 16; 25 mm wide; 10-pole; gray
www.wago.com/786-103
Item no.: 210-103
Wire commoning chain; insulated; black
www.wago.com/210-103
Item no.: 210-123
Wire commoning chain; insulated; blue
www.wago.com/210-123
Item no.: 280-482
Jumper; 2-way; insulated; gray
www.wago.com/280-482
Item no.: 280-483
Jumper; 3-way; insulated; gray
www.wago.com/280-483
Jumper
Item no.: 280-484
Hansastr. 27
32423 Minden
www.wago.com/280-484
13.07.2020 Page 7/12
Item no.: 280-484
Jumper; 4-way; insulated; gray
Item no.: 280-485
Jumper; 5-way; insulated; gray
www.wago.com/280-485
Item no.: 280-490
Jumper; 10-way; insulated; gray
www.wago.com/280-490
Item no.: 280-492
www.wago.com/280-492
Item no.: 709-110
Wire commoning chain; 2.5 mm²; insulated; black
www.wago.com/709-110
Item no.: 709-111
www.wago.com/709-111
Item no.: 709-112
www.wago.com/709-112
Item no.: 210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25
mm
www.wago.com/210-112
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-113
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715
www.wago.com/210-114
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18
mm
www.wago.com/210-115
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-118
Item no.: 210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silvercolored
www.wago.com/210-196
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715
www.wago.com/210-505
Carrier rail
Item no.: 210-506
Hansastr. 27
32423 Minden
www.wago.com/210-506
13.07.2020 Page 8/12
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715
www.wago.com/210-508
Marking accessories
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow /000-002
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange /000-012
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light
green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green /000-023
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 249-105
Group marker carrier; gray
www.wago.com/249-105
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap- www.wago.com/793-5501
on type; white
Item no.: 793-5501/000-002
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-002
on type; yellow
Item no.: 793-5501/000-005
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-005
on type; red
Item no.: 793-5501/000-006
Hansastr. 27
32423 Minden
13.07.2020 Page 9/12
on type; blue
/000-006
Item no.: 793-5501/000-007
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-007
on type; gray
Item no.: 793-5501/000-012
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-012
on type; orange
Item no.: 793-5501/000-017
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-017
on type; green
Item no.: 793-5501/000-023
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-023
on type; light green
Item no.: 793-5501/000-024
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-024
on type; violet
assembling
Item no.: 210-148
Angled support bracket; without screw
www.wago.com/210-148
Item no.: 210-149
Screw M 5 x 8; for angled support bracket
www.wago.com/210-149
Protective Warning Marker
Item no.: 280-415
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/280-415
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short
www.wago.com/210-657
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short
www.wago.com/210-658
Item no.: 210-720
www.wago.com/210-720
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated
www.wago.com/216-101
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated
www.wago.com/216-102
tools
ferrule
Item no.: 216-103
Hansastr. 27
32423 Minden
www.wago.com/216-103
13.07.2020 Page 10/12
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated
www.wago.com/216-104
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Downloads
Documentation
Bid Text
280-765
Feb 19, 2019
xml
2.8 kB
Download
Feb 20, 2019
docx
14.3 kB
Download
URL
Download
EPLAN Data Portal 280-765
URL
Download
WSCAD Universe 280-765
URL
Download
URL
Download
GAEB X81 - Datei
280-765
GAEB docx - Datei
CAD/CAE-Data
CAD data
2D/3D Models 280-765
CAE data
ZUKEN Portal 280-765
Hansastr. 27
32423 Minden
13.07.2020 Page 11/12
URL
Download
Installation Notes
Hansastr. 27
32423 Minden
13.07.2020 Page 12/12
很抱歉,暂时无法提供与“280-765”相匹配的价格&库存,您可以联系我们找货
