Printview: 3-conductor ground terminal block - Item No.: 282-687
Item No.: 282-687
Marking
Business data
Supplier
WAGO
Item no.
282-687
GTIN / EAN
4044918471749
Content
1
Order amount
25
Customer item number
Notes
Technical data
Miscellaneous
Total number of connection points
3
Total number of potentials
1
Color
green-yellow
Ratings according to 1
IEC/EN 60947-7-2
Connection technology (1)
CAGE CLAMP®
Solid sizes 1
0.2 … 6 mm² / 24 … 10 AWG
Fine-stranded wires 1
Strip length 1
12 … 13 mm / 0.47 … 0.51 in
Type of wiring
Front-entry wiring
Design
horizontal
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Marking level
Center marking
Insulating material
Polyamide 66 (PA 66)
Fire load [MJ]
0.312 [MJ]
Weight [g]
27.59 [g]
Width
8 mm / 0.315 in
Height from upper-edge of DIN-rail [mm]
32.5 [mm]
32.5 mm / 1.28 in
Length
93 mm / 3.661 in
Type of mounting
DIN 35 rail
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“282-687”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+109.501041+13.64190
- 4+108.164584+13.47540
- 20+106.6499220+13.28670
- 40+106.0262340+13.20900
- 125+104.24428125+12.98700
